VIS - No Connection
Warum?
admin github: 6.2.20 for 1 days latest: 6.2.20 for 4 days stable: 6.2.20 for 4 daysUpss ...
@thomas-braun sagte in VIS - No Connection:
iobroker update iobroker list instancesliefert folgendes:
pi@raspberrypi:~ $ iobroker update Used repository: stable hash unchanged, use cached sources update done Adapter "admin" : 6.2.20 , installed 5.3.8 [Updateable] Adapter "alexa2" : 3.11.2 , installed 3.12.0 Adapter "backitup" : 2.4.10 , installed 2.4.6 [Updateable] Adapter "binance" : 1.1.3 , installed 1.1.3 Adapter "daswetter" : 3.1.2 , installed 3.1.2 Adapter "discovery" : 3.0.5 , installed 3.0.3 [Updateable] Adapter "dwd" : 2.8.3 , installed 2.8.3 Adapter "email" : 1.1.3 , installed 1.0.10 [Updateable] Adapter "eusec" : 0.9.4 , installed 0.9.1 [Updateable] Adapter "fb-checkpresence": 1.1.19 , installed 1.1.14 [Updateable] Adapter "fritzbox" : 0.2.1 , installed 0.2.1 Adapter "history" : 2.2.0 , installed 1.11.1 [Updateable] Adapter "hm-rega" : 3.0.40 , installed 3.0.40 Adapter "hm-rpc" : 1.15.12 , installed 1.15.12 Adapter "ical" : 1.13.1 , installed 1.12.1 [Updateable] Adapter "icons-fatcow-hosting": 0.1.0 , installed 0.1.0 Adapter "icons-mfd-png" : 1.1.0 , installed 1.1.0 Adapter "icons-mfd-svg" : 1.1.0 , installed 1.1.0 Adapter "influxdb" : 3.1.7 , installed 2.6.3 [Updateable] Adapter "info" : 1.9.19 , installed 1.9.19 Adapter "iot" : 1.11.8 , installed 1.11.4 [Updateable] Adapter "javascript" : 6.0.0 , installed 5.2.21 [Updateable] Controller "js-controller" : 4.0.23 , installed 3.3.22 [Updateable] Adapter "logparser" : 1.1.0 , installed 1.1.0 Adapter "mercedesme" : 0.0.56 , installed 0.0.56 Adapter "mihome-lamp" : 1.1.0 , installed 1.1.0 Adapter "mihome-vacuum" : 3.4.2 , installed 3.3.3 [Updateable] Adapter "shelly" : 6.0.0 , installed 5.3.2 [Updateable] Adapter "simple-api" : 2.7.0 , installed 2.6.5 [Updateable] Adapter "snmp" : 2.1.7 , installed 0.5.0 [Updateable] Adapter "socketio" : 4.2.0 , installed 4.2.0 Adapter "sprinklecontrol": 0.2.9 , installed 0.2.9 Adapter "synology" : 2.1.9 , installed 2.1.7 [Updateable] Adapter "tankerkoenig" : 2.1.1 , installed 2.1.1 Adapter "tr-064" : 4.2.16 , installed 4.2.16 Adapter "trashschedule" : 2.0.3 , installed 1.4.5 [Updateable] Adapter "upnp" : 1.0.21 , installed 1.0.21 Adapter "vis" : 1.4.15 , installed 1.4.15 Adapter "vis-canvas-gauges": 0.1.5 , installed 0.1.5 Adapter "vis-hqwidgets" : 1.2.0 , installed 1.2.0 Adapter "vis-icontwo" : 0.89.0 , installed 0.87.0 [Updateable] Adapter "vis-inventwo" : 3.3.1 , installed 3.3.1 Adapter "vis-jqui-mfd" : 1.0.12 , installed 1.0.12 Adapter "vis-plumb" : 1.0.2 , installed 1.0.2 Adapter "vis-rgraph" : 0.0.2 , installed 0.0.2 Adapter "vis-timeandweather": 1.2.2 , installed 1.1.7 [Updateable] Adapter "weatherunderground": 3.4.2 , installed 3.4.2 Adapter "web" : 4.3.0 , installed 4.3.0 Adapter "whatsapp-cmb" : 0.2.2 , installed 0.2.2 Adapter "ws" : 1.3.0 , installed 1.3.0 pi@raspberrypi:~ $ iobroker list instances system.adapter.admin.0 : admin : raspberrypi - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.alexa2.0 : alexa2 : raspberrypi - enabled + system.adapter.backitup.0 : backitup : raspberrypi - enabled + system.adapter.binance.0 : binance : raspberrypi - enabled system.adapter.daswetter.0 : daswetter : raspberrypi - enabled + system.adapter.discovery.0 : discovery : raspberrypi - enabled system.adapter.dwd.0 : dwd : raspberrypi - enabled + system.adapter.email.0 : email : raspberrypi - enabled + system.adapter.eusec.0 : eusec : raspberrypi - enabled system.adapter.fb-checkpresence.0 : fb-checkpresence : raspberrypi - disabled + system.adapter.fritzbox.0 : fritzbox : raspberrypi - enabled system.adapter.gartenbewaesserung.0 : gartenbewaesserung : raspberrypi - disabled + system.adapter.history.0 : history : raspberrypi - enabled + system.adapter.hm-rega.0 : hm-rega : raspberrypi - enabled + system.adapter.hm-rpc.0 : hm-rpc : raspberrypi - enabled, port: 18701 + system.adapter.hm-rpc.1 : hm-rpc : raspberrypi - enabled, port: 12001 + system.adapter.hm-rpc.2 : hm-rpc : raspberrypi - enabled, port: 12010 system.adapter.ical.0 : ical : raspberrypi - enabled system.adapter.ical.1 : ical : raspberrypi - enabled system.adapter.icons-fatcow-hosting.0 : icons-fatcow-hosting : raspberrypi - disabled system.adapter.icons-mfd-png.0 : icons-mfd-png : raspberrypi - disabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : raspberrypi - disabled + system.adapter.influxdb.0 : influxdb : raspberrypi - enabled, port: 8086 system.adapter.info.0 : info : raspberrypi - enabled + system.adapter.iot.0 : iot : raspberrypi - enabled + system.adapter.javascript.0 : javascript : raspberrypi - enabled + system.adapter.logparser.0 : logparser : raspberrypi - enabled system.adapter.mercedesme.0 : mercedesme : raspberrypi - enabled + system.adapter.mihome-lamp.0 : mihome-lamp : raspberrypi - enabled, port: 54321 + system.adapter.mihome-vacuum.0 : mihome-vacuum : raspberrypi - enabled, port: 54321 + system.adapter.shelly.0 : shelly : raspberrypi - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.snmp.0 : snmp : raspberrypi - enabled + system.adapter.sourceanalytix.0 : sourceanalytix : raspberrypi - enabled + system.adapter.sprinklecontrol.0 : sprinklecontrol : raspberrypi - enabled + system.adapter.synology.0 : synology : raspberrypi - enabled, port: 5001 + system.adapter.tankerkoenig.0 : tankerkoenig : raspberrypi - enabled + system.adapter.tr-064.0 : tr-064 : raspberrypi - enabled + system.adapter.trashschedule.0 : trashschedule : raspberrypi - enabled system.adapter.upnp.0 : upnp : raspberrypi - enabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : raspberrypi - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : raspberrypi - disabled system.adapter.vis-icontwo.0 : vis-icontwo : raspberrypi - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : raspberrypi - enabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : raspberrypi - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : raspberrypi - disabled system.adapter.vis-plumb.0 : vis-plumb : raspberrypi - disabled system.adapter.vis-rgraph.0 : vis-rgraph : raspberrypi - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : raspberrypi - disabled system.adapter.vis.0 : vis : raspberrypi - enabled system.adapter.weatherunderground.0 : weatherunderground : raspberrypi - enabled + system.adapter.web.0 : web : raspberrypi - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : raspberrypi - enabled + instance is alive pi@raspberrypi:~ $iobroker stop iobroker update iobroker upgrade self iobroker start -
iob upgrade allliefert folgendes :
pi@raspberrypi:~ $ iob upgrade all No connection to databases possible ... pi@raspberrypi:~ $ iob upgrade all This upgrade of "vis-timeandweather" will introduce the following changes: ========================================================================== -> 1.2.2: Refactoring of build process done -> 1.2.1: Fixed the icon display in custom weather forecast Refactoring of build process done ========================================================================== Would you like to upgrade vis-timeandweather from @1.1.7 to @1.2.2 now? [(y)es, (n)o]: y Update vis-timeandweather from @1.1.7 to @1.2.2 NPM version: 8.15.0 npm install iobroker.vis-timeandweather@1.2.2 --loglevel error --prefix "/opt/iobroker" (System call)dann bricht er ab.
pi@raspberrypi:~ $ iob start admin No connection to databases possible ... pi@raspberrypi:~ $ -
pi@raspberrypi:~ $ iob start admin No connection to databases possible ... pi@raspberrypi:~ $iob stop iob upgrade backitup --debug -
pi@raspberrypi:~ $ iob start admin No connection to databases possible ... pi@raspberrypi:~ $@pahan sagte in VIS - No Connection:
dann bricht er ab.
Kann man das sehen?
Oder rödelt die Kiste einfach 'am Limit vor sich hin'? -
dann bricht er ab.
Kann man das sehen?
Oder rödelt die Kiste einfach 'am Limit vor sich hin'?@thomas-braun sagte in VIS - No Connection:
dann bricht er ab.
Kann man das sehen?
Oder rödelt die Kiste einfach 'am Limit vor sich hin'?sieht dann einfach so aus:
pi@raspberrypi:~ $ iobroker upgrade self Update js-controller from @3.3.22 to @4.0.23 NPM version: 8.15.0 npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call) -
dann bricht er ab.
Kann man das sehen?
pi@raspberrypi:~ $ iobroker upgrade self Update js-controller from @3.3.22 to @4.0.23 NPM version: 8.15.0 npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)upgrade selferst wenn die Adapter auf Stand sind! -
upgrade selferst wenn die Adapter auf Stand sind!@thomas-braun sagte in VIS - No Connection:
upgrade selferst wenn die Adapter auf Stand sind!ok, verstanden, jetzt mache ich erstmal diesen Befehl:
iob upgrade backitup --debugwobei er schon seit paar Minuten hängt
hängt
Ich glaube ja, die Kiste 'hängt' nicht final, die hat nur ordentlich zu kämpfen.
hängt
hängt
das kann schon sein, nur was soll einen Pi4 mit 4GB so schnell aus der Ruhe bringen?
...jedenfalls sieht es aktuell so aus:
pi@raspberrypi:~ $ iob upgrade backitup --debug This upgrade of "backitup" will introduce the following changes: ========================================================================== -> 2.4.10: Code cleaning dependencies updated Disclaimer added Travis Support removed Fix backup-download with ssl -> 2.4.9: German Wiki added English Wiki added ignore .tar.gz files for zigbee Backups -> 2.4.8: Fix restore from local Mount path -> 2.4.7: dependencies updated many small bugfixes Fix Sentry Error Messages Default SMB Version 3.1.1 ========================================================================== Would you like to upgrade backitup from @2.4.6 to @2.4.10 now? [(y)es, (n)o]: y Update backitup from @2.4.6 to @2.4.10 host.raspberrypi Adapter "system.adapter.backitup.0" is stopped. NPM version: 8.15.0 npm install iobroker.backitup@2.4.10 --prefix "/opt/iobroker" (System call) npm WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm, npm WARN old lockfile so supplemental metadata must be fetched from the registry. npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient... npm WARN old lockfile added 10 packages, removed 64 packages, and changed 33 packages in 5m 108 packages are looking for funding run `npm fund` for details upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript Update "system.adapter.backitup.0" upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js applicati Adapter "backitup" updated host.raspberrypi Adapter "system.adapter.backitup.0" is started -
hängt
pi@raspberrypi:~ $ iob upgrade backitup --debug This upgrade of "backitup" will introduce the following changes: ========================================================================== -> 2.4.10: Code cleaning dependencies updated Disclaimer added Travis Support removed Fix backup-download with ssl -> 2.4.9: German Wiki added English Wiki added ignore .tar.gz files for zigbee Backups -> 2.4.8: Fix restore from local Mount path -> 2.4.7: dependencies updated many small bugfixes Fix Sentry Error Messages Default SMB Version 3.1.1 ========================================================================== Would you like to upgrade backitup from @2.4.6 to @2.4.10 now? [(y)es, (n)o]: y Update backitup from @2.4.6 to @2.4.10 host.raspberrypi Adapter "system.adapter.backitup.0" is stopped. NPM version: 8.15.0 npm install iobroker.backitup@2.4.10 --prefix "/opt/iobroker" (System call) npm WARN old lockfile npm WARN old lockfile The package-lock.json file was created with an old version of npm, npm WARN old lockfile so supplemental metadata must be fetched from the registry. npm WARN old lockfile npm WARN old lockfile This is a one-time fix-up, please be patient... npm WARN old lockfile added 10 packages, removed 64 packages, and changed 33 packages in 5m 108 packages are looking for funding run `npm fund` for details upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript Update "system.adapter.backitup.0" upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js applicati Adapter "backitup" updated host.raspberrypi Adapter "system.adapter.backitup.0" is started@pahan sagte in VIS - No Connection:
Aufwändige Operationen im npm tree...
iob update | grep backitup -
löschen
Nö, wenn die Konvertierung funktioniert würde ich das auch so lassen.
dann eben erst wenn es final hängt
Ich glaube das schnurrt...
iob update | grep backitup@thomas-braun sagte in VIS - No Connection:
iob update | grep backitupliefert:
pi@raspberrypi:~ $ iob update | grep backitup Adapter "backitup" : 2.4.10 , installed 2.4.10 pi@raspberrypi:~ $ -
Made my day !!!
Ich sehe das Admin Logo über den Port 8081 !!!
Vielen Lieben Dank !!!
jetzt ist nur die Frage, ob ich das Update der Adapter über die Shell machen soll,
oder doch über die Admin-Oberfläche ?...wenn diese sich öffnet ...
oder doch über die Admin-Oberfläche ?Was ist denn das für eine Frage? Über die Kommandozeile natürlich. Geht das überhaupt anders?
