  4. VIS - No Connection
VIS - No Connection
vis
185 Beiträge 10 Kommentatoren 22.1k Aufrufe 10 Beobachtet
    @pahan
    iob status
    Pahan
    #82
    @thomas-braun sagte in VIS - No Connection:
    iob status
    liefert nach 1ms:
    pi@raspberrypi:~ $ iob status
    pi@raspberrypi:~ $
    • P Pahan
      iob status
      liefert nach 1ms:
      pi@raspberrypi:~ $
      #83
      @pahan
      Das Verhalten gab es schon mal irgendwo...
      Ich weiß aber nicht mehr was da geholfen hat.
      systemctl status iobroker.service
      sudo systemctl stop iobroker.service
      curl -fsL https://iobroker.net/fix.sh | bash -
      P 1 Antwort Letzte Antwort
        @pahan
        Pahan
        #84
        @pahan
        liefert folgendes :
        pi@raspberrypi:~ $ systemctl status iobroker.service
         iobroker.service
             Loaded: masked (Reason: Unit iobroker.service is masked.)
             Active: inactive (dead)
        • P Pahan
          @pahan
          liefert folgendes :
           iobroker.service
          #85
          @pahan
          masked ist natürlich Käse!
          sudo systemctl unmask iobroker.service
          sudo systemctl start iobroker.service
            @pahan
            Pahan
            #86
            habe jetzt etwas rumprobiert:
            pi@raspberrypi:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
            library: loaded
            Library version=2022-06-15
                Welcome to the ioBroker installation fixer!
                Script version: 2022-06-03
                You might need to enter your password a couple of times.
                Installing prerequisites (1/3)
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://repos.influxdata.com/debian bullseye InRelease
            Hit:4 https://packages.grafana.com/oss/deb stable InRelease
            Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
            Reading package lists... Done
            Installed gcc-c++
                Checking ioBroker user and directory permissions (2/3)
                Checking autostart (3/3)
            Enabling autostart...
            Autostart enabled!
                Your installation was fixed successfully
                Run iobroker start to start ioBroker again!
            ● iobroker.service - ioBroker Server
                 Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
                   Docs: http://iobroker.net
            pi@raspberrypi:~ $ iobroker start
            pi@raspberrypi:~ $ sudo systemctl unmask iobroker.service
            pi@raspberrypi:~ $ sudo systemctl start iobroker.service
            pi@raspberrypi:~ $
            • P Pahan
              library: loaded
              Installed gcc-c++
              Autostart enabled!
              pi@raspberrypi:~ $
              #87
              @pahan
              sudo reboot
              Dann mal als erstes
              iobroker status
              sollte dann wieder laufen.
                @pahan
                sudo reboot
                Dann mal als erstes
                iobroker status
                Pahan
                #88
                @pahan
                sudo reboot
                Dann mal als erstes
                iobroker status
                nach "gefühlt" einer Minute kommt folgendes:
                pi@raspberrypi:~ $ iobroker status
                Objects type: file
                States  type: file
                pi@raspberrypi:~ $
                aber der iobroker ist unter ip:8081 oder ip:8082 nach wie vor nicht erreichbar
                • P Pahan
                  @pahan
                  sudo reboot
                  Dann mal als erstes
                  iobroker status
                  Objects type: file
                  States  type: file
                  pi@raspberrypi:~ $
                  #89
                  @pahan
                  iobroker update
                  iobroker list instances
                    @pahan
                    iobroker update
                    Pahan
                    #90
                    iobroker update
                    liefert folgendes:
                    pi@raspberrypi:~ $ iobroker update
                    Used repository: stable
                    hash unchanged, use cached sources
                    update done
                    Adapter    "admin"         : 6.2.20   , installed 5.3.8 [Updateable]
                    Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
                    Adapter    "backitup"      : 2.4.10   , installed 2.4.6 [Updateable]
                    Adapter    "binance"       : 1.1.3    , installed 1.1.3
                    Adapter    "daswetter"     : 3.1.2    , installed 3.1.2
                    Adapter    "discovery"     : 3.0.5    , installed 3.0.3 [Updateable]
                    Adapter    "dwd"           : 2.8.3    , installed 2.8.3
                    Adapter    "email"         : 1.1.3    , installed 1.0.10 [Updateable]
                    Adapter    "eusec"         : 0.9.4    , installed 0.9.1 [Updateable]
                    Adapter    "fb-checkpresence": 1.1.19  , installed 1.1.14 [Updateable]
                    Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
                    Adapter    "history"       : 2.2.0    , installed 1.11.1 [Updateable]
                    Adapter    "hm-rega"       : 3.0.40   , installed 3.0.40
                    Adapter    "hm-rpc"        : 1.15.12  , installed 1.15.12
                    Adapter    "ical"          : 1.13.1   , installed 1.12.1 [Updateable]
                    Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
                    Adapter    "icons-mfd-png" : 1.1.0    , installed 1.1.0
                    Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.1.0
                    Adapter    "influxdb"      : 3.1.7    , installed 2.6.3 [Updateable]
                    Adapter    "info"          : 1.9.19   , installed 1.9.19
                    Adapter    "iot"           : 1.11.8   , installed 1.11.4 [Updateable]
                    Adapter    "javascript"    : 6.0.0    , installed 5.2.21 [Updateable]
                    Controller "js-controller" : 4.0.23   , installed 3.3.22 [Updateable]
                    Adapter    "logparser"     : 1.1.0    , installed 1.1.0
                    Adapter    "mercedesme"    : 0.0.56   , installed 0.0.56
                    Adapter    "mihome-lamp"   : 1.1.0    , installed 1.1.0
                    Adapter    "mihome-vacuum" : 3.4.2    , installed 3.3.3 [Updateable]
                    Adapter    "shelly"        : 6.0.0    , installed 5.3.2 [Updateable]
                    Adapter    "simple-api"    : 2.7.0    , installed 2.6.5 [Updateable]
                    Adapter    "snmp"          : 2.1.7    , installed 0.5.0 [Updateable]
                    Adapter    "socketio"      : 4.2.0    , installed 4.2.0
                    Adapter    "sprinklecontrol": 0.2.9   , installed 0.2.9
                    Adapter    "synology"      : 2.1.9    , installed 2.1.7 [Updateable]
                    Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
                    Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
                    Adapter    "trashschedule" : 2.0.3    , installed 1.4.5 [Updateable]
                    Adapter    "upnp"          : 1.0.21   , installed 1.0.21
                    Adapter    "vis"           : 1.4.15   , installed 1.4.15
                    Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
                    Adapter    "vis-hqwidgets" : 1.2.0    , installed 1.2.0
                    Adapter    "vis-icontwo"   : 0.89.0   , installed 0.87.0 [Updateable]
                    Adapter    "vis-inventwo"  : 3.3.1    , installed 3.3.1
                    Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
                    Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
                    Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
                    Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
                    Adapter    "weatherunderground": 3.4.2   , installed 3.4.2
                    Adapter    "web"           : 4.3.0    , installed 4.3.0
                    Adapter    "whatsapp-cmb"  : 0.2.2    , installed 0.2.2
                    Adapter    "ws"            : 1.3.0    , installed 1.3.0
                    pi@raspberrypi:~ $ iobroker list instances
                      system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.binance.0                : binance               : raspberrypi                              -  enabled
                      system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                      system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                    + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
                    + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
                      system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                    + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                      system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
                    + system.adapter.history.0                : history               : raspberrypi                              -  enabled
                    + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
                    + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
                    + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
                    + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                      system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                      system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                      system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                    + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                      system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                    + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                    + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
                      system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              -  enabled
                    + system.adapter.mihome-lamp.0            : mihome-lamp           : raspberrypi                              -  enabled, port: 54321
                    + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
                    + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                    + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
                    + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
                    + system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              -  enabled
                    + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5001
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
                    + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
                    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                      system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                      system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                      system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
                    + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
                    + instance is alive
                    pi@raspberrypi:~ $
                    • P Pahan
                      iobroker update
                      liefert folgendes:
                      update done
                      + instance is alive
                      pi@raspberrypi:~ $
                      #91
                      @pahan
                      iob upgrade all
                      iob start admin
                        @pahan
                        iob upgrade all
                        iob start admin
                        GlasfaserG Offline
                        GlasfaserG Offline
                        #92
                        Da stimmt etwas nicht mir der repo !!!
                        • GlasfaserG Glasfaser
                          #93
                          @glasfaser
                          Warum?
                          admin
                          github:	6.2.20 for 1 days
                          latest:	6.2.20 for 4 days
                          stable:	6.2.20 for 4 days
                            @glasfaser
                            Warum?
                            admin
                            GlasfaserG Offline
                            GlasfaserG Offline
                            #94
                            Upss ...
                            • P Pahan
                              iobroker update
                              liefert folgendes:
                              update done
                              + instance is alive
                              pi@raspberrypi:~ $
                              #95
                              @pahan
                              iobroker stop
                              iobroker update
                              iobroker upgrade self
                              iobroker start
                              • P Offline
                                Pahan
                                #96
                                @pahan
                                iob upgrade all
                                liefert folgendes :
                                pi@raspberrypi:~ $ iob upgrade all
                                No connection to databases possible ...
                                This upgrade of "vis-timeandweather" will introduce the following changes:
                                -> 1.2.2:
                                Refactoring of build process done
                                -> 1.2.1:
                                Fixed the icon display in custom weather forecast
                                Would you like to upgrade vis-timeandweather from @1.1.7 to @1.2.2 now? [(y)es, (n)o]: y
                                Update vis-timeandweather from @1.1.7 to @1.2.2
                                NPM version: 8.15.0
                                npm install iobroker.vis-timeandweather@1.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
                                dann bricht er ab.
                                pi@raspberrypi:~ $ iob start admin
                                pi@raspberrypi:~ $
                                • P Pahan
                                  @pahan
                                  iob upgrade all
                                  liefert folgendes :
                                  -> 1.2.2:
                                  -> 1.2.1:
                                  NPM version: 8.15.0
                                  dann bricht er ab.
                                  pi@raspberrypi:~ $
                                  #97
                                  @pahan
                                  iob stop
                                  iob upgrade backitup --debug
                                  • P Pahan
                                    @pahan
                                    iob upgrade all
                                    liefert folgendes :
                                    -> 1.2.2:
                                    -> 1.2.1:
                                    NPM version: 8.15.0
                                    dann bricht er ab.
                                    pi@raspberrypi:~ $
                                    #98
                                    @pahan sagte in VIS - No Connection:
                                    dann bricht er ab.
                                    Kann man das sehen?
                                    Oder rödelt die Kiste einfach 'am Limit vor sich hin'?
                                      dann bricht er ab.
                                      Kann man das sehen?
                                      Pahan
                                      #99
                                      dann bricht er ab.
                                      Kann man das sehen?
                                      sieht dann einfach so aus:
                                      pi@raspberrypi:~ $ iobroker upgrade self
                                      Update js-controller from @3.3.22 to @4.0.23
                                      NPM version: 8.15.0
                                      npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                      • P Pahan
                                        dann bricht er ab.
                                        Kann man das sehen?
                                        NPM version: 8.15.0
                                        #100
                                        @pahan
                                        upgrade self erst wenn die Adapter auf Stand sind!
                                          @pahan
                                          Pahan
                                          #101
                                          @pahan
                                          ok, verstanden, jetzt mache ich erstmal diesen Befehl:
                                          wobei er schon seit paar Minuten hängt
