  4. VIS - No Connection
VIS - No Connection
vis
185 Beiträge 10 Kommentatoren 22.1k Aufrufe 10 Beobachtet
    @pahan
    masked ist natürlich Käse!
    sudo systemctl unmask iobroker.service
    sudo systemctl start iobroker.service
    Pahan
    #86
    habe jetzt etwas rumprobiert:
    pi@raspberrypi:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
    library: loaded
    Library version=2022-06-15
        Welcome to the ioBroker installation fixer!
        Script version: 2022-06-03
        You might need to enter your password a couple of times.
        Installing prerequisites (1/3)
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://repos.influxdata.com/debian bullseye InRelease
    Hit:4 https://packages.grafana.com/oss/deb stable InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:~ $ systemctl status iobroker.service
    ● iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
         Active: inactive (dead)
           Docs: http://iobroker.net
    pi@raspberrypi:~ $ iobroker start
    pi@raspberrypi:~ $ sudo systemctl unmask iobroker.service
    pi@raspberrypi:~ $ sudo systemctl start iobroker.service
    pi@raspberrypi:~ $
    • P Pahan
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      pi@raspberrypi:~ $
      #87
      @pahan
      sudo reboot
      Dann mal als erstes
      iobroker status
      sollte dann wieder laufen.
      P 1 Antwort Letzte Antwort
        @pahan
        sudo reboot
        Dann mal als erstes
        iobroker status
        Pahan
        #88
        @thomas-braun sagte in VIS - No Connection:
        @pahan
        sudo reboot
        Dann mal als erstes
        iobroker status
        nach "gefühlt" einer Minute kommt folgendes:
        pi@raspberrypi:~ $ iobroker status
        Objects type: file
        States  type: file
        pi@raspberrypi:~ $
        aber der iobroker ist unter ip:8081 oder ip:8082 nach wie vor nicht erreichbar
        • P Pahan
          @pahan
          sudo reboot
          Dann mal als erstes
          iobroker status
          Objects type: file
          States  type: file
          pi@raspberrypi:~ $
          #89
          @pahan
          iobroker update
          iobroker list instances
            @pahan
            iobroker update
            Pahan
            #90
            iobroker update
            liefert folgendes:
            pi@raspberrypi:~ $ iobroker update
            Used repository: stable
            hash unchanged, use cached sources
            update done
            Adapter    "admin"         : 6.2.20   , installed 5.3.8 [Updateable]
            Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
            Adapter    "backitup"      : 2.4.10   , installed 2.4.6 [Updateable]
            Adapter    "binance"       : 1.1.3    , installed 1.1.3
            Adapter    "daswetter"     : 3.1.2    , installed 3.1.2
            Adapter    "discovery"     : 3.0.5    , installed 3.0.3 [Updateable]
            Adapter    "dwd"           : 2.8.3    , installed 2.8.3
            Adapter    "email"         : 1.1.3    , installed 1.0.10 [Updateable]
            Adapter    "eusec"         : 0.9.4    , installed 0.9.1 [Updateable]
            Adapter    "fb-checkpresence": 1.1.19  , installed 1.1.14 [Updateable]
            Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
            Adapter    "history"       : 2.2.0    , installed 1.11.1 [Updateable]
            Adapter    "hm-rega"       : 3.0.40   , installed 3.0.40
            Adapter    "hm-rpc"        : 1.15.12  , installed 1.15.12
            Adapter    "ical"          : 1.13.1   , installed 1.12.1 [Updateable]
            Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
            Adapter    "icons-mfd-png" : 1.1.0    , installed 1.1.0
            Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.1.0
            Adapter    "influxdb"      : 3.1.7    , installed 2.6.3 [Updateable]
            Adapter    "info"          : 1.9.19   , installed 1.9.19
            Adapter    "iot"           : 1.11.8   , installed 1.11.4 [Updateable]
            Adapter    "javascript"    : 6.0.0    , installed 5.2.21 [Updateable]
            Controller "js-controller" : 4.0.23   , installed 3.3.22 [Updateable]
            Adapter    "logparser"     : 1.1.0    , installed 1.1.0
            Adapter    "mercedesme"    : 0.0.56   , installed 0.0.56
            Adapter    "mihome-lamp"   : 1.1.0    , installed 1.1.0
            Adapter    "mihome-vacuum" : 3.4.2    , installed 3.3.3 [Updateable]
            Adapter    "shelly"        : 6.0.0    , installed 5.3.2 [Updateable]
            Adapter    "simple-api"    : 2.7.0    , installed 2.6.5 [Updateable]
            Adapter    "snmp"          : 2.1.7    , installed 0.5.0 [Updateable]
            Adapter    "socketio"      : 4.2.0    , installed 4.2.0
            Adapter    "sprinklecontrol": 0.2.9   , installed 0.2.9
            Adapter    "synology"      : 2.1.9    , installed 2.1.7 [Updateable]
            Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
            Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
            Adapter    "trashschedule" : 2.0.3    , installed 1.4.5 [Updateable]
            Adapter    "upnp"          : 1.0.21   , installed 1.0.21
            Adapter    "vis"           : 1.4.15   , installed 1.4.15
            Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
            Adapter    "vis-hqwidgets" : 1.2.0    , installed 1.2.0
            Adapter    "vis-icontwo"   : 0.89.0   , installed 0.87.0 [Updateable]
            Adapter    "vis-inventwo"  : 3.3.1    , installed 3.3.1
            Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
            Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
            Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
            Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
            Adapter    "weatherunderground": 3.4.2   , installed 3.4.2
            Adapter    "web"           : 4.3.0    , installed 4.3.0
            Adapter    "whatsapp-cmb"  : 0.2.2    , installed 0.2.2
            Adapter    "ws"            : 1.3.0    , installed 1.3.0
            pi@raspberrypi:~ $ iobroker list instances
              system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.binance.0                : binance               : raspberrypi                              -  enabled
              system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
              system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
            + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
            + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
              system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
            + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
              system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
            + system.adapter.history.0                : history               : raspberrypi                              -  enabled
            + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
            + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
            + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
            + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
              system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
              system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
            + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
              system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
            + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
            + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
              system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              -  enabled
            + system.adapter.mihome-lamp.0            : mihome-lamp           : raspberrypi                              -  enabled, port: 54321
            + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
            + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
            + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
            + system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              -  enabled
            + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5001
            + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
            + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
              system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
              system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
              system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
            + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
            + instance is alive
            pi@raspberrypi:~ $
            • P Pahan
              iobroker update
              liefert folgendes:
              update done
              + instance is alive
              pi@raspberrypi:~ $
              #91
              @pahan
              iob upgrade all
              iob start admin
                @pahan
                iob upgrade all
                iob start admin
                GlasfaserG Offline
                GlasfaserG Offline
                #92
                Da stimmt etwas nicht mir der repo !!!
                • GlasfaserG Glasfaser
                  #93
                  @glasfaser
                  Warum?
                  admin
                  github:	6.2.20 for 1 days
                  latest:	6.2.20 for 4 days
                  stable:	6.2.20 for 4 days
                    @glasfaser
                    Warum?
                    admin
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #94
                    Upss ...
                    • P Pahan
                      iobroker update
                      liefert folgendes:
                      update done
                      + instance is alive
                      pi@raspberrypi:~ $
                      #95
                      @pahan
                      iobroker stop
                      iobroker update
                      iobroker upgrade self
                      iobroker start
                      • P Offline
                        Pahan
                        #96
                        @pahan
                        iob upgrade all
                        liefert folgendes :
                        pi@raspberrypi:~ $ iob upgrade all
                        No connection to databases possible ...
                        This upgrade of "vis-timeandweather" will introduce the following changes:
                        -> 1.2.2:
                        Refactoring of build process done
                        -> 1.2.1:
                        Fixed the icon display in custom weather forecast
                        Would you like to upgrade vis-timeandweather from @1.1.7 to @1.2.2 now? [(y)es, (n)o]: y
                        Update vis-timeandweather from @1.1.7 to @1.2.2
                        NPM version: 8.15.0
                        npm install iobroker.vis-timeandweather@1.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
                        dann bricht er ab.
                        pi@raspberrypi:~ $ iob start admin
                        pi@raspberrypi:~ $
                        • P Pahan
                          @pahan
                          iob upgrade all
                          liefert folgendes :
                          -> 1.2.2:
                          -> 1.2.1:
                          NPM version: 8.15.0
                          dann bricht er ab.
                          pi@raspberrypi:~ $
                          #97
                          @pahan
                          iob stop
                          iob upgrade backitup --debug
                          • P Pahan
                            @pahan
                            iob upgrade all
                            liefert folgendes :
                            -> 1.2.2:
                            -> 1.2.1:
                            NPM version: 8.15.0
                            dann bricht er ab.
                            pi@raspberrypi:~ $
                            #98
                            @pahan sagte in VIS - No Connection:
                            dann bricht er ab.
                            Kann man das sehen?
                            Oder rödelt die Kiste einfach 'am Limit vor sich hin'?
                              dann bricht er ab.
                              Kann man das sehen?
                              Pahan
                              #99
                              dann bricht er ab.
                              Kann man das sehen?
                              sieht dann einfach so aus:
                              pi@raspberrypi:~ $ iobroker upgrade self
                              Update js-controller from @3.3.22 to @4.0.23
                              NPM version: 8.15.0
                              npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                              • P Pahan
                                dann bricht er ab.
                                Kann man das sehen?
                                NPM version: 8.15.0
                                #100
                                @pahan
                                upgrade self erst wenn die Adapter auf Stand sind!
                                  @pahan
                                  Pahan
                                  #101
                                  @pahan
                                  ok, verstanden, jetzt mache ich erstmal diesen Befehl:
                                  wobei er schon seit paar Minuten hängt
                                  • P Pahan
                                    @pahan
                                    #102
                                    hängt
                                    Ich glaube ja, die Kiste 'hängt' nicht final, die hat nur ordentlich zu kämpfen.
                                      hängt
                                      Pahan
                                      #103
                                      hängt
                                      das kann schon sein, nur was soll einen Pi4 mit 4GB so schnell aus der Ruhe bringen?
                                      ...jedenfalls sieht es aktuell so aus:
                                      pi@raspberrypi:~ $ iob upgrade backitup --debug
                                      This upgrade of "backitup" will introduce the following changes:
                                      -> 2.4.10:
                                      Code cleaning
                                      dependencies updated
                                      Disclaimer added
                                      Travis Support removed
                                      Fix backup-download with ssl
                                      -> 2.4.9:
                                      German Wiki added
                                      English Wiki added
                                      ignore .tar.gz files for zigbee Backups
                                      -> 2.4.8:
                                      Fix restore from local Mount path
                                      -> 2.4.7:
                                      many small bugfixes
                                      Fix Sentry Error Messages
                                      Default SMB Version 3.1.1
                                      Would you like to upgrade backitup from @2.4.6 to @2.4.10 now? [(y)es, (n)o]: y
                                      Update backitup from @2.4.6 to @2.4.10
                                      host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                                      NPM version: 8.15.0
                                      npm install iobroker.backitup@2.4.10 --prefix "/opt/iobroker" (System call)
                                      npm WARN old lockfile
                                      npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                      npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                      npm WARN old lockfile This is a one-time fix-up, please be patient...
                                      added 10 packages, removed 64 packages, and changed 33 packages in 5m
                                      108 packages are looking for funding
                                        run `npm fund` for details
                                      upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                      Update "system.adapter.backitup.0"
                                      upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                      upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                      upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                      upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                      upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                      upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                      upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                      upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                      upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                      upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js applicati
                                      Adapter "backitup" updated
                                      host.raspberrypi Adapter "system.adapter.backitup.0" is started
                                      • P Offline
                                        Pahan
                                        #104
                                        soll ich nochmal das versuchen?
                                        iobroker stop
                                        iobroker update
                                        iobroker start
                                        • HomoranH Offline
                                          HomoranH Offline
                                          #105
                                          löschen
