  4. VIS - No Connection
VIS - No Connection
vis
185 Beiträge 10 Kommentatoren 22.1k Aufrufe 10 Beobachtet
  • P Pahan
    @thomas-braun sagte in VIS - No Connection:
    @pahan
    Das Verhalten gab es schon mal irgendwo...
    Ich weiß aber nicht mehr was da geholfen hat.
    systemctl status iobroker.service
    liefert folgendes :
    pi@raspberrypi:~ $ systemctl status iobroker.service
     iobroker.service
         Loaded: masked (Reason: Unit iobroker.service is masked.)
         Active: inactive (dead)
    #85
    @pahan
    masked ist natürlich Käse!
    sudo systemctl unmask iobroker.service
    sudo systemctl start iobroker.service
    P 1 Antwort Letzte Antwort
      @pahan
      Pahan
      #86
      habe jetzt etwas rumprobiert:
      pi@raspberrypi:~ $ curl -fsL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2022-06-15
          Welcome to the ioBroker installation fixer!
          Script version: 2022-06-03
          You might need to enter your password a couple of times.
          Installing prerequisites (1/3)
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://repos.influxdata.com/debian bullseye InRelease
      Hit:4 https://packages.grafana.com/oss/deb stable InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      ● iobroker.service - ioBroker Server
           Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
             Docs: http://iobroker.net
      pi@raspberrypi:~ $ iobroker start
      pi@raspberrypi:~ $ sudo systemctl unmask iobroker.service
      pi@raspberrypi:~ $ sudo systemctl start iobroker.service
      pi@raspberrypi:~ $
      • P Pahan
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        pi@raspberrypi:~ $
        #87
        @pahan
        sudo reboot
        Dann mal als erstes
        iobroker status
        sollte dann wieder laufen.
          @pahan
          sudo reboot
          Dann mal als erstes
          iobroker status
          Pahan
          #88
          @pahan
          sudo reboot
          Dann mal als erstes
          iobroker status
          nach "gefühlt" einer Minute kommt folgendes:
          pi@raspberrypi:~ $ iobroker status
          Objects type: file
          States  type: file
          pi@raspberrypi:~ $
          aber der iobroker ist unter ip:8081 oder ip:8082 nach wie vor nicht erreichbar
          • P Pahan
            @pahan
            sudo reboot
            Dann mal als erstes
            iobroker status
            Objects type: file
            States  type: file
            pi@raspberrypi:~ $
            #89
            @pahan
            iobroker update
            iobroker list instances
              @pahan
              iobroker update
              Pahan
              #90
              iobroker update
              liefert folgendes:
              pi@raspberrypi:~ $ iobroker update
              Used repository: stable
              hash unchanged, use cached sources
              update done
              Adapter    "admin"         : 6.2.20   , installed 5.3.8 [Updateable]
              Adapter    "alexa2"        : 3.11.2   , installed 3.12.0
              Adapter    "backitup"      : 2.4.10   , installed 2.4.6 [Updateable]
              Adapter    "binance"       : 1.1.3    , installed 1.1.3
              Adapter    "daswetter"     : 3.1.2    , installed 3.1.2
              Adapter    "discovery"     : 3.0.5    , installed 3.0.3 [Updateable]
              Adapter    "dwd"           : 2.8.3    , installed 2.8.3
              Adapter    "email"         : 1.1.3    , installed 1.0.10 [Updateable]
              Adapter    "eusec"         : 0.9.4    , installed 0.9.1 [Updateable]
              Adapter    "fb-checkpresence": 1.1.19  , installed 1.1.14 [Updateable]
              Adapter    "fritzbox"      : 0.2.1    , installed 0.2.1
              Adapter    "history"       : 2.2.0    , installed 1.11.1 [Updateable]
              Adapter    "hm-rega"       : 3.0.40   , installed 3.0.40
              Adapter    "hm-rpc"        : 1.15.12  , installed 1.15.12
              Adapter    "ical"          : 1.13.1   , installed 1.12.1 [Updateable]
              Adapter    "icons-fatcow-hosting": 0.1.0   , installed 0.1.0
              Adapter    "icons-mfd-png" : 1.1.0    , installed 1.1.0
              Adapter    "icons-mfd-svg" : 1.1.0    , installed 1.1.0
              Adapter    "influxdb"      : 3.1.7    , installed 2.6.3 [Updateable]
              Adapter    "info"          : 1.9.19   , installed 1.9.19
              Adapter    "iot"           : 1.11.8   , installed 1.11.4 [Updateable]
              Adapter    "javascript"    : 6.0.0    , installed 5.2.21 [Updateable]
              Controller "js-controller" : 4.0.23   , installed 3.3.22 [Updateable]
              Adapter    "logparser"     : 1.1.0    , installed 1.1.0
              Adapter    "mercedesme"    : 0.0.56   , installed 0.0.56
              Adapter    "mihome-lamp"   : 1.1.0    , installed 1.1.0
              Adapter    "mihome-vacuum" : 3.4.2    , installed 3.3.3 [Updateable]
              Adapter    "shelly"        : 6.0.0    , installed 5.3.2 [Updateable]
              Adapter    "simple-api"    : 2.7.0    , installed 2.6.5 [Updateable]
              Adapter    "snmp"          : 2.1.7    , installed 0.5.0 [Updateable]
              Adapter    "socketio"      : 4.2.0    , installed 4.2.0
              Adapter    "sprinklecontrol": 0.2.9   , installed 0.2.9
              Adapter    "synology"      : 2.1.9    , installed 2.1.7 [Updateable]
              Adapter    "tankerkoenig"  : 2.1.1    , installed 2.1.1
              Adapter    "tr-064"        : 4.2.16   , installed 4.2.16
              Adapter    "trashschedule" : 2.0.3    , installed 1.4.5 [Updateable]
              Adapter    "upnp"          : 1.0.21   , installed 1.0.21
              Adapter    "vis"           : 1.4.15   , installed 1.4.15
              Adapter    "vis-canvas-gauges": 0.1.5   , installed 0.1.5
              Adapter    "vis-hqwidgets" : 1.2.0    , installed 1.2.0
              Adapter    "vis-icontwo"   : 0.89.0   , installed 0.87.0 [Updateable]
              Adapter    "vis-inventwo"  : 3.3.1    , installed 3.3.1
              Adapter    "vis-jqui-mfd"  : 1.0.12   , installed 1.0.12
              Adapter    "vis-plumb"     : 1.0.2    , installed 1.0.2
              Adapter    "vis-rgraph"    : 0.0.2    , installed 0.0.2
              Adapter    "vis-timeandweather": 1.2.2   , installed 1.1.7 [Updateable]
              Adapter    "weatherunderground": 3.4.2   , installed 3.4.2
              Adapter    "web"           : 4.3.0    , installed 4.3.0
              Adapter    "whatsapp-cmb"  : 0.2.2    , installed 0.2.2
              Adapter    "ws"            : 1.3.0    , installed 1.3.0
              pi@raspberrypi:~ $ iobroker list instances
                system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
              + system.adapter.binance.0                : binance               : raspberrypi                              -  enabled
                system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
              + system.adapter.email.0                  : email                 : raspberrypi                              -  enabled
              + system.adapter.eusec.0                  : eusec                 : raspberrypi                              -  enabled
                system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
              + system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              -  enabled
                system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
              + system.adapter.history.0                : history               : raspberrypi                              -  enabled
              + system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              -  enabled
              + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              -  enabled, port: 18701
              + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              -  enabled, port: 12001
              + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              -  enabled, port: 12010
                system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
              + system.adapter.influxdb.0               : influxdb              : raspberrypi                              -  enabled, port: 8086
                system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
              + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
              + system.adapter.logparser.0              : logparser             : raspberrypi                              -  enabled
                system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              -  enabled
              + system.adapter.mihome-lamp.0            : mihome-lamp           : raspberrypi                              -  enabled, port: 54321
              + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              -  enabled, port: 54321
              + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
              + system.adapter.snmp.0                   : snmp                  : raspberrypi                              -  enabled
              + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              -  enabled
              + system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              -  enabled
              + system.adapter.synology.0               : synology              : raspberrypi                              -  enabled, port: 5001
              + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              -  enabled
              + system.adapter.tr-064.0                 : tr-064                : raspberrypi                              -  enabled
              + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                system.adapter.upnp.0                   : upnp                  : raspberrypi                              -  enabled
                system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
              + system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              -  enabled
                system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              -  enabled
              + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi                              -  enabled
              + instance is alive
              pi@raspberrypi:~ $
              • P Pahan
                iobroker update
                liefert folgendes:
                update done
                + instance is alive
                pi@raspberrypi:~ $
                #91
                @pahan
                iob upgrade all
                iob start admin
                  @pahan
                  iob upgrade all
                  iob start admin
                  GlasfaserG Offline
                  GlasfaserG Offline
                  #92
                  Da stimmt etwas nicht mir der repo !!!
                  • GlasfaserG Glasfaser
                    #93
                    @glasfaser
                    Warum?
                    admin
                    github:	6.2.20 for 1 days
                    latest:	6.2.20 for 4 days
                    stable:	6.2.20 for 4 days
                      @glasfaser
                      Warum?
                      admin
                      GlasfaserG Offline
                      GlasfaserG Offline
                      #94
                      Upss ...
                      • P Pahan
                        iobroker update
                        liefert folgendes:
                        update done
                        + instance is alive
                        pi@raspberrypi:~ $
                        #95
                        @pahan
                        iobroker stop
                        iobroker update
                        iobroker upgrade self
                        iobroker start
                        • P Offline
                          Pahan
                          #96
                          @pahan
                          iob upgrade all
                          liefert folgendes :
                          pi@raspberrypi:~ $ iob upgrade all
                          No connection to databases possible ...
                          This upgrade of "vis-timeandweather" will introduce the following changes:
                          -> 1.2.2:
                          Refactoring of build process done
                          -> 1.2.1:
                          Fixed the icon display in custom weather forecast
                          Would you like to upgrade vis-timeandweather from @1.1.7 to @1.2.2 now? [(y)es, (n)o]: y
                          Update vis-timeandweather from @1.1.7 to @1.2.2
                          NPM version: 8.15.0
                          npm install iobroker.vis-timeandweather@1.2.2 --loglevel error --prefix "/opt/iobroker" (System call)
                          dann bricht er ab.
                          pi@raspberrypi:~ $ iob start admin
                          pi@raspberrypi:~ $
                          • P Pahan
                            @pahan
                            iob upgrade all
                            liefert folgendes :
                            -> 1.2.2:
                            -> 1.2.1:
                            NPM version: 8.15.0
                            dann bricht er ab.
                            pi@raspberrypi:~ $
                            #97
                            @pahan
                            iob stop
                            iob upgrade backitup --debug
                            • P Pahan
                              @pahan
                              iob upgrade all
                              liefert folgendes :
                              -> 1.2.2:
                              -> 1.2.1:
                              NPM version: 8.15.0
                              dann bricht er ab.
                              pi@raspberrypi:~ $
                              #98
                              @pahan sagte in VIS - No Connection:
                              dann bricht er ab.
                              Kann man das sehen?
                              Oder rödelt die Kiste einfach 'am Limit vor sich hin'?
                                dann bricht er ab.
                                Kann man das sehen?
                                Pahan
                                #99
                                dann bricht er ab.
                                Kann man das sehen?
                                sieht dann einfach so aus:
                                pi@raspberrypi:~ $ iobroker upgrade self
                                Update js-controller from @3.3.22 to @4.0.23
                                NPM version: 8.15.0
                                npm install iobroker.js-controller@4.0.23 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                • P Pahan
                                  dann bricht er ab.
                                  Kann man das sehen?
                                  NPM version: 8.15.0
                                  #100
                                  @pahan
                                  upgrade self erst wenn die Adapter auf Stand sind!
                                    @pahan
                                    Pahan
                                    #101
                                    @pahan
                                    ok, verstanden, jetzt mache ich erstmal diesen Befehl:
                                    wobei er schon seit paar Minuten hängt
                                    • P Pahan
                                      @pahan
                                      #102
                                      hängt
                                      Ich glaube ja, die Kiste 'hängt' nicht final, die hat nur ordentlich zu kämpfen.
                                        hängt
                                        Pahan
                                        #103
                                        hängt
                                        das kann schon sein, nur was soll einen Pi4 mit 4GB so schnell aus der Ruhe bringen?
                                        ...jedenfalls sieht es aktuell so aus:
                                        pi@raspberrypi:~ $ iob upgrade backitup --debug
                                        This upgrade of "backitup" will introduce the following changes:
                                        -> 2.4.10:
                                        Code cleaning
                                        dependencies updated
                                        Disclaimer added
                                        Travis Support removed
                                        Fix backup-download with ssl
                                        -> 2.4.9:
                                        German Wiki added
                                        English Wiki added
                                        ignore .tar.gz files for zigbee Backups
                                        -> 2.4.8:
                                        Fix restore from local Mount path
                                        -> 2.4.7:
                                        many small bugfixes
                                        Fix Sentry Error Messages
                                        Default SMB Version 3.1.1
                                        Would you like to upgrade backitup from @2.4.6 to @2.4.10 now? [(y)es, (n)o]: y
                                        Update backitup from @2.4.6 to @2.4.10
                                        host.raspberrypi Adapter "system.adapter.backitup.0" is stopped.
                                        NPM version: 8.15.0
                                        npm install iobroker.backitup@2.4.10 --prefix "/opt/iobroker" (System call)
                                        npm WARN old lockfile
                                        npm WARN old lockfile The package-lock.json file was created with an old version of npm,
                                        npm WARN old lockfile so supplemental metadata must be fetched from the registry.
                                        npm WARN old lockfile This is a one-time fix-up, please be patient...
                                        added 10 packages, removed 64 packages, and changed 33 packages in 5m
                                        108 packages are looking for funding
                                          run `npm fund` for details
                                        upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
                                        Update "system.adapter.backitup.0"
                                        upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
                                        upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
                                        upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
                                        upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
                                        upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
                                        upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
                                        upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
                                        upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
                                        upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
                                        upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js applicati
                                        Adapter "backitup" updated
                                        host.raspberrypi Adapter "system.adapter.backitup.0" is started
                                        • P Offline
                                          Pahan
                                          #104
                                          soll ich nochmal das versuchen?
                                          iobroker stop
                                          iobroker update
                                          iobroker start
