  4. VIS - No Connection
VIS - No Connection
vis
185 Beiträge 10 Kommentatoren 22.1k Aufrufe 10 Beobachtet
    @pahan sagte in VIS - No Connection:
    4 packages can be upgraded.
    iobroker stop
    sudo apt update
    sudo apt full-upgrade
    sudo reboot
    Pahan
    #41
    @thomas-braun sagte in VIS - No Connection:
    iobroker stop
    sudo apt update
    sudo reboot
    alles gemacht, lief durch, der letzte Befehl gab folgendes aus:
    pi@raspberrypi:~ $ sudo apt full-upgrade
    Reading package lists... Done
    Building dependency tree... Done
    Calculating upgrade... Done
    The following package was automatically installed and is no longer required:
      libfuse2
    Use 'sudo apt autoremove' to remove it.
    0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    pi@raspberrypi:~ $ sudo reboot
    aktueller Status ist wie folgt:
    pi@raspberrypi:~ $ systemctl status iobroker
    ● iobroker.service - ioBroker Server
         Loaded: loaded (/lib/systemd/system/iobroker.service; enabled; vendor preset: enabled)
         Active: active (running) since Tue 2022-02-01 21:08:07 CET; 6min ago
           Docs: http://iobroker.net
       Main PID: 1144 (iobroker.js-con)
          Tasks: 44 (limit: 4915)
            CPU: 59.558s
         CGroup: /system.slice/iobroker.service
                 ├─1144 iobroker.js-controller
                 ├─1454 io.alexa2.0
                 ├─1469 io.backitup.0
                 └─1534 io.web.0
    Feb 01 21:10:28 raspberrypi bash[1144]: host.raspberrypi check instance "system.adapter.vis-rgraph.0" for host "raspberrypi"
    Feb 01 21:10:28 raspberrypi bash[1144]: host.raspberrypi check instance "system.adapter.vis-timeandweather.0" for host "raspberrypi"
    Feb 01 21:10:28 raspberrypi bash[1144]: host.raspberrypi check instance "system.adapter.vis.0" for host "raspberrypi"
    Feb 01 21:10:28 raspberrypi bash[1144]: host.raspberrypi check instance "system.adapter.web.0" for host "raspberrypi"
    Feb 01 21:10:37 raspberrypi sudo[1492]: iobroker : PWD=/opt/iobroker/node_modules/iobroker.backitup ; USER=root ; COMMAND=/usr/bin/mount >
    Feb 01 21:10:37 raspberrypi sudo[1492]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Feb 01 21:10:37 raspberrypi sudo[1492]: pam_unix(sudo:session): session closed for user root
    Feb 01 21:10:48 raspberrypi sudo[1559]: iobroker : PWD=/opt/iobroker/node_modules/iobroker.backitup ; USER=root ; COMMAND=/usr/bin/umount>
    Feb 01 21:10:48 raspberrypi sudo[1559]: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=1001)
    Feb 01 21:10:50 raspberrypi sudo[1559]: pam_unix(sudo:session): session closed for user root
    pi@raspberrypi:~ $
      Pahan
      #42
      auch wenn alles i.O. aussehen mag, der iobroker läuft nach wie vor nicht
      Thomas BraunT BananaJoeB 2 Antworten Letzte Antwort
      • P Pahan
        #43
        @pahan
        iobroker status
        P 1 Antwort Letzte Antwort
          @pahan
          iobroker status
          Pahan
          schrieb am zuletzt editiert von Pahan
          #44
          iobroker status> ```
          pi@raspberrypi:~ $ iobroker status
          Objects type: file
          States  type: file
          pi@raspberrypi:~ $
          • P Pahan
            BananaJoeB Offline
            BananaJoeB Offline
            BananaJoe
            #45
            @pahan
            heißt auch das der Adapter nicht gestartet ist.
            systemctl start iobroker
            Und danach mal in das Log schauen:
            tail -n 100 /opt/iobroker/log/iobroker.current.log
            uns schauen was da steht wenn er es nicht schaffen sollte zu starten (und hier posten)
            • BananaJoeB BananaJoe
              @pahan
              Pahan
              #46
              @bananajoe sagte in VIS - No Connection:
              @pahan
              anbei die Eingabe und die Ausgabe....
              pi@raspberrypi:~ $ systemctl start iobroker
              ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
              Authentication is required to start 'iobroker.service'.
              Authenticating as: ,,, (pi)
              Password:
              ==== AUTHENTICATION COMPLETE ===
              pi@raspberrypi:~ $ tail -n 100 /opt/iobroker/log/iobroker.current.log
              2022-02-01 18:39:47.689  - info: host.raspberrypi stopInstance system.adapter.hm-rega.0 (force=false, process=false)
              2022-02-01 18:39:47.689  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.0 (force=false, process=false)
              2022-02-01 18:39:47.690  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.1 (force=false, process=false)
              2022-02-01 18:39:47.691  - info: host.raspberrypi stopInstance system.adapter.hm-rpc.2 (force=false, process=false)
              2022-02-01 18:39:47.691  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
              2022-02-01 18:39:47.692  - info: host.raspberrypi stopInstance system.adapter.ical.1 (force=false, process=false)
              2022-02-01 18:39:47.692  - info: host.raspberrypi stopInstance system.adapter.mihome-vacuum.0 (force=false, process=false)
              2022-02-01 18:39:47.693  - info: host.raspberrypi stopInstance system.adapter.shelly.0 (force=false, process=false)
              2022-02-01 18:39:47.693  - info: host.raspberrypi stopInstance system.adapter.synology.0 (force=false, process=false)
              2022-02-01 18:39:47.694  - info: host.raspberrypi stopInstance system.adapter.tr-064.0 (force=false, process=false)
              2022-02-01 18:39:47.694  - info: host.raspberrypi stopInstance system.adapter.weatherunderground.0 (force=false, process=false)
              2022-02-01 18:39:47.695  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
              2022-02-01 18:39:47.695  - info: host.raspberrypi stopInstance system.adapter.binance.0 (force=false, process=false)
              2022-02-01 18:39:47.696  - info: host.raspberrypi stopInstance system.adapter.daswetter.0 (force=false, process=false)
              2022-02-01 18:39:47.696  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=false)
              2022-02-01 18:39:47.697  - info: host.raspberrypi stopInstance system.adapter.dwd.0 (force=false, process=false)
              2022-02-01 18:39:47.697  - info: host.raspberrypi stopInstance system.adapter.eufy-security.0 (force=false, process=false)
              2022-02-01 18:39:47.698  - info: host.raspberrypi stopInstance system.adapter.fb-checkpresence.0 (force=false, process=false)
              2022-02-01 18:39:47.698  - info: host.raspberrypi stopInstance system.adapter.fritzbox.0 (force=false, process=false)
              2022-02-01 18:39:47.699  - info: host.raspberrypi stopInstance system.adapter.gartenbewaesserung.0 (force=false, process=false)
              2022-02-01 18:39:47.699  - info: host.raspberrypi stopInstance system.adapter.info.0 (force=false, process=false)
              2022-02-01 18:39:47.700  - info: host.raspberrypi stopInstance system.adapter.iot.0 (force=false, process=false)
              2022-02-01 18:39:47.700  - info: host.raspberrypi stopInstance system.adapter.logparser.0 (force=false, process=false)
              2022-02-01 18:39:47.700  - info: host.raspberrypi stopInstance system.adapter.mercedesme.0 (force=false, process=false)
              2022-02-01 18:39:47.701  - info: host.raspberrypi stopInstance system.adapter.mihome-lamp.0 (force=false, process=false)
              2022-02-01 18:39:47.701  - info: host.raspberrypi stopInstance system.adapter.snmp.0 (force=false, process=false)
              2022-02-01 18:39:47.702  - info: host.raspberrypi stopInstance system.adapter.sourceanalytix.0 (force=false, process=false)
              2022-02-01 18:39:47.702  - info: host.raspberrypi stopInstance system.adapter.sprinklecontrol.0 (force=false, process=false)
              2022-02-01 18:39:47.702  - info: host.raspberrypi stopInstance system.adapter.tankerkoenig.0 (force=false, process=false)
              2022-02-01 18:39:47.703  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=false)
              2022-02-01 18:39:47.703  - info: host.raspberrypi stopInstance system.adapter.upnp.0 (force=false, process=false)
              2022-02-01 18:39:47.703  - info: host.raspberrypi stopInstance system.adapter.vis-canvas-gauges.0 (force=false, process=false)
              2022-02-01 18:39:47.704  - info: host.raspberrypi stopInstance system.adapter.vis-hqwidgets.0 (force=false, process=false)
              2022-02-01 18:39:47.704  - info: host.raspberrypi stopInstance system.adapter.vis-inventwo.0 (force=false, process=false)
              2022-02-01 18:39:47.705  - info: host.raspberrypi stopInstance system.adapter.vis-jqui-mfd.0 (force=false, process=false)
              2022-02-01 18:39:47.705  - info: host.raspberrypi stopInstance system.adapter.vis-materialdesign.0 (force=false, process=false)
              2022-02-01 18:39:47.705  - info: host.raspberrypi stopInstance system.adapter.vis-plumb.0 (force=false, process=false)
              2022-02-01 18:39:47.706  - info: host.raspberrypi stopInstance system.adapter.vis-rgraph.0 (force=false, process=false)
              2022-02-01 18:39:47.706  - info: host.raspberrypi stopInstance system.adapter.vis-timeandweather.0 (force=false, process=false)
              2022-02-01 18:39:47.707  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=false)
              2022-02-01 18:39:47.707  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
              2022-02-01 18:39:47.728  - info: backitup.0 (1499) Got terminate signal TERMINATE_YOURSELF
              2022-02-01 18:39:47.733  - info: web.0 (1639) Got terminate signal TERMINATE_YOURSELF
              2022-02-01 18:39:47.736  - info: backitup.0 (1499) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              2022-02-01 18:39:47.737  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
              2022-02-01 18:39:47.727  - info: alexa2.0 (1588) Got terminate signal TERMINATE_YOURSELF
              2022-02-01 18:39:47.739  - info: web.0 (1639) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              2022-02-01 18:39:47.740  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
              2022-02-01 18:39:47.741  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
              2022-02-01 18:39:47.742  - info: alexa2.0 (1588) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
              2022-02-01 18:39:48.739  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 killing pid 1588
              2022-02-01 18:39:48.742  - info: host.raspberrypi stopInstance system.adapter.backitup.0 killing pid 1499
              2022-02-01 18:39:48.743  - info: host.raspberrypi stopInstance system.adapter.web.0 killing pid 1639
              2022-02-01 18:39:55.804  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2022-02-01 18:39:55.805  - info: host.raspberrypi All instances are stopped.
              2022-02-01 18:39:55.865  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2022-02-01 18:39:55.866  - info: host.raspberrypi All instances are stopped.
              2022-02-01 18:39:55.924  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
              2022-02-01 18:39:55.925  - info: host.raspberrypi All instances are stopped.
              2022-02-01 18:39:56.503  - info: host.raspberrypi terminated
              2022-02-01 21:08:11.162  - info: host.raspberrypi iobroker.js-controller version 3.3.22 js-controller starting
              2022-02-01 21:08:11.169  - info: host.raspberrypi Copyright (c) 2014-2021 bluefox, 2014 hobbyquaker
              2022-02-01 21:08:11.170  - info: host.raspberrypi hostname: raspberrypi, node: v14.19.0
              2022-02-01 21:08:11.170  - info: host.raspberrypi ip addresses: 192.168.178.36 fe80::32fa:9c31:3feb:e244
              2022-02-01 21:10:27.194  - info: host.raspberrypi connected to Objects and States
              2022-02-01 21:10:27.443  - info: host.raspberrypi added notifications configuration of host
              2022-02-01 21:10:28.420  - info: host.raspberrypi 51 instances found
              2022-02-01 21:10:28.511  - info: host.raspberrypi starting 4 instances
              2022-02-01 21:10:28.538  - warn: host.raspberrypi startInstance cannot find adapter "eufy-security@0.7.4". Try to install it... 1 attempt
              2022-02-01 21:10:28.539  - info: host.raspberrypi iobroker install eufy-security@0.7.4 using installedFrom
              2022-02-01 21:10:28.843  - info: host.raspberrypi instance system.adapter.alexa2.0 started with pid 1454
              2022-02-01 21:10:30.810  - info: alexa2.0 (1454) starting. Version 3.12.0 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.19.0, js-controller: 3.3.22
              2022-02-01 21:10:34.536  - info: host.raspberrypi instance system.adapter.backitup.0 started with pid 1469
              2022-02-01 21:10:34.786  - error: host.raspberrypi iobroker npm-install: host.raspberrypi Unknown packetName eufy-security
              2022-02-01 21:10:34.803  - info: host.raspberrypi iobroker npm-install: host.raspberrypi download eufy-securityFile not found: eufy-security
              2022-02-01 21:10:34.837  - info: host.raspberrypi iobroker npm-install: exit 1
              2022-02-01 21:10:36.513  - info: alexa2.0 (1454) Alexa-Push-Connection (macDms = true) established. Disable Polling
              2022-02-01 21:10:36.561  - info: backitup.0 (1469) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.19.0, js-controller: 3.3.22
              2022-02-01 21:10:36.728  - info: backitup.0 (1469) [iobroker] backup was activated at 11:20 every 1 day(s)
              2022-02-01 21:10:36.871  - info: alexa2.0 (1454) Unknown Device, but enabling commands, Try it and report back if commands work.
              2022-02-01 21:10:36.872  - info: alexa2.0 (1454) Report to developer as GitHub issue with details for device. Please grab full next line pot. from logfile on disk if cutted
              2022-02-01 21:10:36.873  - info: alexa2.0 (1454)     Device-type:A2N49KXGVA18AR (REMINDERS,VOLUME_SETTING,ASX_TIME_ZONE,ADAPTIVE_LISTENING,SUPPORTS_SOFTWARE_VERSION,MICROPHONE,TIMERS_AND_ALARMS,NO_TIME_ZONE_SETTING,PERSISTENT_CONNECTION)
              2022-02-01 21:10:36.976  - info: backitup.0 (1469) [ccu] backup was activated at 01:30 every 3 day(s)
              2022-02-01 21:10:38.534  - info: vis.0 (1484) starting. Version 1.4.6 in /opt/iobroker/node_modules/iobroker.vis, node: v14.19.0, js-controller: 3.3.22
              2022-02-01 21:10:38.797  - info: vis.0 (1484) vis license is OK.
              2022-02-01 21:10:40.528  - info: vis.0 (1484) Changes in index.html detected => update cache.manifest
              2022-02-01 21:10:40.581  - info: vis.0 (1484) Upload vis anew, while changes detected...
              2022-02-01 21:10:40.734  - info: host.raspberrypi instance system.adapter.web.0 started with pid 1534
              2022-02-01 21:10:43.444  - info: web.0 (1534) starting. Version 3.4.16 in /opt/iobroker/node_modules/iobroker.web, node: v14.19.0, js-controller: 3.3.22
              2022-02-01 21:10:43.735  - info: host.raspberrypi "system.adapter.vis.0" disabled
              2022-02-01 21:10:43.737  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
              2022-02-01 21:10:43.758  - info: host.raspberrypi "system.adapter.vis.0" enabled
              2022-02-01 21:10:43.759  - info: host.raspberrypi stopInstance system.adapter.vis.0 (force=false, process=true)
              2022-02-01 21:10:43.980  - info: web.0 (1534) socket.io server listening on port 8082
              2022-02-01 21:10:43.986  - info: web.0 (1534) http server listening on port 8082
              2022-02-01 21:10:53.614  - info: alexa2.0 (1454) Subscribing to states...
              2022-02-01 21:10:53.615  - info: alexa2.0 (1454) Deleting the following states: ["Echo-Devices.G070VM14937317FB.Info.multiroomParents"]
              2022-02-01 21:11:33.380  - info: vis.0 (1484) Uploaded. 0
              2022-02-01 21:11:33.894  - info: vis.0 (1484) Terminated (NO_ERROR): Without reason
              2022-02-01 21:11:34.603  - info: host.raspberrypi instance system.adapter.vis.0 terminated while should be started once
              pi@raspberrypi:~ $
              • P Pahan
                @pahan
                Password:
                pi@raspberrypi:~ $
                BananaJoeB Offline
                BananaJoeB Offline
                BananaJoe
                #47
                eufy-security
                als du den Befehl ausgeführt hast (tail) war er noch am starten
                läuft er denn jetzt? Wenn nicht den tail wiederholen und was noch zum obigen fehlt posten.
                Der eufy-security spackt rum, ansonsten sieht es gar nicht so schlecht aus
                  eufy-security
                  Pahan
                  #48
                  eufy-security
                  ja, mit dem eufy adapter scheint es in letzter Zeit Schwierigkeiten zu geben, aber ich befürchte in meinem Fall deutlich größere Probleme bekommen zu haben...zumindest startet der iobroker auch nach einer längerer Wartezeit leider nicht. Anbei die aktuelle Ausgabe des tails..:
                  pi@raspberrypi:~ $
                  • P Pahan
                    eufy-security
                    pi@raspberrypi:~ $
                    BananaJoeB Offline
                    BananaJoeB Offline
                    BananaJoe
                    #49
                    ich sehe keine Admin-Instanz in deinen Logs. ist auf Port 8082 was erreichbar?
                      Pahan
                      #50
                      in der Tat, auf port 8082 ist die alte VIS erreichbar,
                      auf port 8081 nach wie vor nichts
                      P HomoranH 2 Antworten Letzte Antwort
                      • P Pahan
                        Pahan
                        #51
                        ich habe auch schon eine admin-instanz hinzugefügt, nun habe zwei davon, aber keine davon funktioniert.
                        • P Pahan
                          HomoranH Offline
                          HomoranH Offline
                          #52
                          dann fangen wir mal wieder von vorne an! Bitte aktuelle Ausgabe von:
                          iobroker list instances
                            Pahan
                            #53
                            @homoran sagte in VIS - No Connection:
                            gibt aus:
                            pi@raspberrypi:~ $ iobroker list instances
                              system.adapter.admin.0                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.admin.1                  : admin                 : raspberrypi                              - disabled, port: 8081, bind: 0.0.0.0, run as: admin
                            + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                            + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                              system.adapter.binance.0                : binance               : raspberrypi                              - disabled
                              system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                              system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                              system.adapter.dwd.0                    : dwd                   : raspberrypi                              - disabled
                              system.adapter.email.0                  : email                 : raspberrypi                              - disabled
                              system.adapter.eufy-security.0          : eufy-security         : raspberrypi                              - disabled
                              system.adapter.fb-checkpresence.0       : fb-checkpresence      : raspberrypi                              - disabled
                              system.adapter.fritzbox.0               : fritzbox              : raspberrypi                              - disabled
                              system.adapter.gartenbewaesserung.0     : gartenbewaesserung    : raspberrypi                              - disabled
                              system.adapter.history.0                : history               : raspberrypi                              - disabled
                              system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
                              system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 18701
                              system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi                              - disabled, port: 12001
                              system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi                              - disabled, port: 12010
                              system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                              system.adapter.ical.1                   : ical                  : raspberrypi                              - disabled
                              system.adapter.icons-fatcow-hosting.0   : icons-fatcow-hosting  : raspberrypi                              - disabled
                              system.adapter.icons-mfd-png.0          : icons-mfd-png         : raspberrypi                              - disabled
                              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi                              - disabled
                              system.adapter.influxdb.0               : influxdb              : raspberrypi                              - disabled, port: 8086
                              system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                              system.adapter.iot.0                    : iot                   : raspberrypi                              - disabled
                              system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                              system.adapter.logparser.0              : logparser             : raspberrypi                              - disabled
                              system.adapter.mercedesme.0             : mercedesme            : raspberrypi                              - disabled
                              system.adapter.mihome-lamp.0            : mihome-lamp           : raspberrypi                              - disabled, port: 54321
                              system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi                              - disabled, port: 54321
                              system.adapter.shelly.0                 : shelly                : raspberrypi                              - disabled, port: 1882, bind: 0.0.0.0
                              system.adapter.snmp.0                   : snmp                  : raspberrypi                              - disabled
                              system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi                              - disabled
                              system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
                              system.adapter.synology.0               : synology              : raspberrypi                              - disabled, port: 5000
                              system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
                              system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                              system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              - disabled
                              system.adapter.upnp.0                   : upnp                  : raspberrypi                              - disabled
                              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi                              - disabled
                              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi                              - disabled
                              system.adapter.vis-icontwo.0            : vis-icontwo           : raspberrypi                              - disabled
                              system.adapter.vis-inventwo.0           : vis-inventwo          : raspberrypi                              - disabled
                              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi                              - disabled
                              system.adapter.vis-materialdesign.0     : vis-materialdesign    : raspberrypi                              - disabled
                              system.adapter.vis-plumb.0              : vis-plumb             : raspberrypi                              - disabled
                              system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi                              - disabled
                              system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi                              - disabled
                              system.adapter.vis.0                    : vis                   : raspberrypi                              -  enabled
                              system.adapter.weatherunderground.0     : weatherunderground    : raspberrypi                              - disabled
                            + instance is alive
                            pi@raspberrypi:~ $
                            • P Pahan
                              gibt aus:
                              + instance is alive
                              pi@raspberrypi:~ $
                              #54
                              admin.1
                              iobroker del iobroker.admin.1
                              iobroker start iobroker.admin.0
                              • P Pahan
                                gibt aus:
                                + instance is alive
                                pi@raspberrypi:~ $
                                HomoranH Offline
                                HomoranH Offline
                                #55
                                beide auf Port 8081 geht ja auch nicht.
                                deswegen laufen wahrscheinlich beide nicht mehr
                                iobroker start admin.0
                                  Pahan
                                  #56
                                  er ist angesprungen, vielen vielen Dank für Eure Unterstützung !!!
                                  • P Pahan
                                    HomoranH Offline
                                    HomoranH Offline
                                    #57
                                    er ist angesprungen
                                    und spätestens jetzt den admin.1 löschen
                                      Pahan
                                      #58
                                      aber jetzt mal eine generelle Frage zum Abschluss:
                                      ich werde es in Zukunft sein lassen, auf Beta zu laufen, diese habe ich in den Einstellungen auch schon gelöscht.
                                      Was empfiehlt sich nun, alle Adapter auf die stable Version downzugraden oder das doch so laufen zu lassen?
                                      HomoranH BananaJoeB 2 Antworten Letzte Antwort
                                      • P Pahan
                                        HomoranH Offline
                                        HomoranH Offline
                                        #59
                                        wenn jetzt (wirklich) keine Probleme mehr sind lässt du das Repo auf stable.
                                        Irgendwann sind die jetzigen Verionen dann auch da drin. Danach kommen auch dort weitere Upgrades
                                        • P Pahan
                                          BananaJoeB Offline
                                          BananaJoeB Offline
                                          BananaJoe
                                          #60
                                          Öhm, du kannst auch alles auf Beta laufen lassen (mache ich zum Beispiel). Dann solltest du aber halt eine gute Backup-Strategie haben für den Fall es es mal Mist ist (hatte ich aber erst einmal).
                                          Mein ioBroker läuft in einer VM (virtuelle Maschine), da hab ich eine Kopie des kompletten Systems. Und/oder ich kann Snapshots machen (Zustand einfrieren um später dahin zurück springen zu können.)
                                          Im Prinzip könnet die Komplettsicherung des Ordners /opt/iobroker reichen wenn ich mich nicht irre. Der müsste im Fehlerfall gelöscht und wieder zurückkopiert werden (unter Beibehaltung aller Besitzer und Berechtigungen).
                                          Wenn man das eher scheut dann halt auf Stable bleiben (aber selbst da hätte ich gerne ein simples Backup. Ich liebe VMs einfach)
