  4. Test Adapter device-reminder V 1.x
adapterdevice-remindergeräteüberwachungtest
626 Beiträge 76 Kommentatoren 220.9k Aufrufe 69 Beobachtet
  • K Offline
    kaschperle83
    #141
    der Device Reminder ist bisher gut gelaufen. Aber auf einmal bekomme ich folgende Fehlermeldung im Log:
    device-reminder.0	2021-02-16 20:13:21.345	error	at processTicksAndRejections (internal/process/task_queues.js:97:5)
    device-reminder.0	2021-02-16 20:13:21.345	error	at sendMsg (/opt/iobroker/node_modules/iobroker.device-reminder/main.js:758:63)
    device-reminder.0	2021-02-16 20:13:21.345	error	(8447) TypeError: Cannot read property 'name' of undefined
    device-reminder.0	2021-02-16 20:13:21.345	error	(8447) unhandled promise rejection: Cannot read property 'name' of undefined
    Unhandled	2021-02-16 20:13:21.344	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Was könnte das sein?
    Hier nochmal der Log ab Start:
    device-reminder.0	2021-02-16 20:17:02.657	info	(8675) Terminated (NO_ERROR): Without reason
    device-reminder.0	2021-02-16 20:17:02.656	info	(8675) terminating
    device-reminder.0	2021-02-16 20:17:02.612	error	(8675) TypeError: Cannot read property 'name' of undefined at sendMsg (/opt/iobroker/node_modules/iobroker.device-reminder/main.js:758:63) at processTicksAndRejections (internal/process/task_q
    device-reminder.0	2021-02-16 20:17:02.612	error	(8675) unhandled promise rejection: Cannot read property 'name' of undefined
    device-reminder.0	2021-02-16 20:17:02.611	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    device-reminder.0	2021-02-16 20:16:50.907	info	(8675) Device "Trockner" was successfully created
    device-reminder.0	2021-02-16 20:16:50.668	info	(8675) Device "Waschmachine Markus" was successfully created
    device-reminder.0	2021-02-16 20:16:50.627	info	(8675) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v12.20.1, js-controller: 3.1.6
    device-reminder.0	2021-02-16 20:16:48.046	info	(8659) Device "Trockner" was successfully created
    device-reminder.0	2021-02-16 20:16:47.997	info	(8659) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    device-reminder.0	2021-02-16 20:16:47.662	info	(8659) Device "Waschmachine Markus" was successfully created
    device-reminder.0	2021-02-16 20:16:47.615	info	(8659) starting. Version 1.0.6 in /opt/iobroker/node_modules/iobroker.device-reminder, node: v12.20.1, js-controller: 3.1.6
    XenonX 1 Antwort Letzte Antwort
    • K kaschperle83
      XenonX Offline
      XenonX Offline
      Xenon
      Forum Testing Developer
      schrieb am zuletzt editiert von Xenon
      #142
      @kaschperle83 was wurde geändert? Er findet den Namen deines Telegramkontaktes nicht. Der Fehler kommt nicht von alleine
      wenn euch mein Beitrag geholfen hat, bewertet ihn bitte unten rechts :)
      K 1 Antwort Letzte Antwort
      • XenonX Xenon
        kaschperle83
        #143
        @xenon eigentlich wurde an Telegram nichts geändert. Aber dem Anhaltspunkt werde ich mal nachgehen.
          Peter213
          schrieb am zuletzt editiert von Peter213
          #144
          ich wollte gerade auch mal den Adapter testen doch irgendwie wird bei mir auch kein Telegram User angezeigt. Habe unter den Objekten den Eintrag users gerade überprüft und da steht auch was drin "{"82....837":{"firstName":"Sebastian"}}" Trotzdem wird mir nirgends im Adapter was mit Telegram angezeigt. Was kann ich noch prüfen?
          • JB_SullivanJ Offline
            JB_Sullivan
            schrieb am zuletzt editiert von JB_Sullivan
            #145
            Bitte löschen - mein Fehler
            • P Peter213
              XenonX Offline
              XenonX Offline
              Xenon
              #146
              @peter213 schick mal einen Screenshot von deinem Telegram Objekt (kannst die id ja schwärzen)
              P 1 Antwort Letzte Antwort
              • XenonX Xenon
                Peter213
                #147
                @xenon
                hier mein Telegram Adapter.
                XenonX 2 Antworten Letzte Antwort
                • P Peter213
                  @xenon
                  XenonX Offline
                  XenonX Offline
                  Xenon
                  #148
                  @peter213 sagte in Test Adapter device-reminder V 1.x:
                  @xenon
                  Puh ich bin grad überfragt. Hast du mal zum test einen anderen messenger zusätzlich angelegt? Bei WhatsApp kann man zb einfach irgendeinen datenpunkt auswählen
                  • P Peter213
                    @xenon
                    XenonX Offline
                    XenonX Offline
                    Xenon
                    #149
                    @peter213 ich habe jetzt zahlreiche Konstellationen durch probiert und mir wird telegram immer angezeigt. Besteht die Möglichkeit per teamviewer oder anydesk zusammen nachzuschauen?
                    • XenonX Offline
                      XenonX Offline
                      Xenon
                      #150
                      Wie gehts weiter?
                      Aktuell bearbeite ich drei weitere Wünsche aus der Community:
                      • Überwachung der maximalen Laufzeit: Es soll erinnert werden, wenn ein Gerät länger als Zeit X in Betrieb ist
                      • Anwesenheitsabhängig melden: Wenn niemand zu Hause ist, kommen nur Textnachrichten. Schaltet die Anwesenheit auf wahr wird per alexa und Co nachgemeldet. Die Anwesenheit muss allerdings vom User selber ermittelt und in einem DP zur Verfügung gestellt werden.
                      • Ansagen in Schleifen: Es wird möglich sein eine Ansage zu wiederholen. Dafür wird dann aber ein weiterer DP vom User benötigt um diese Schleife abbrechen zu können. Fehlt dieser, wird kein Loop gestartet.
                      • zusätzlich wird ein neuer DP zur Verfügung gestellt, der die letzte Laufzeit speichert
                      In Klärung ist auch weiterhin, ob automatisch ein timeout geschaltet werden kann, sobald ein definiertes Gerät einen bestimmten Zustand annimmt.
                      Viel zu tun also und danke für eure Anregungen ;)
                      • DickenD Offline
                        DickenD Offline
                        Dicken
                        #151
                        Hey, ich hab grad ne denkblockade, vllt kann mir ja einer helfen.
                        Ich habe den Status meiner Waschmaschine vorher mittels Programm in der CCU abgefragt und habe damals nach diversen Tests, die perfekten Einstellungen rausgefunden.
                        Die Waschmaschine startet bei größer als 3W und endet bei kleiner als 3W. Diese Werte werden wärend dem Waschvorgang nicht unterschritten, also eigentlich ganz einfach >3 Watt Waschvorgang läuft, <3W Waschvorgang beendet.
                        Wie müssen jetzt meine Werte da eingetragen werden?
                        Also ich tippe mal auf
                        starting value = 3
                        final value = 3
                        aber was geb ich dann bei number of values "start" und "end" ein?
                        Danke schonmal für eure Hilfe :)
                        S XenonX 2 Antworten Letzte Antwort
                        • DickenD Dicken
                          starting value = 3
                          final value = 3
                          sauerstofff
                          #152
                          @dicken wenn du kein Entprellen der Werte benötigst, kannst du dort 1 eintragen. 0 hatte bei mir nicht funktioniert.
                          DickenD XenonX 2 Antworten Letzte Antwort
                          • S sauerstofff
                            DickenD Offline
                            DickenD Offline
                            Dicken
                            #153
                            @sauerm
                            Bei start und end denke ich? Dankeschön, werde ich testen :)
                            • DickenD Dicken
                              starting value = 3
                              final value = 3
                              XenonX Offline
                              XenonX Offline
                              Xenon
                              #154
                              @dicken https://github.com/Xenon-s/ioBroker.device-reminder/blob/master/README_GER.md#default-devices
                              • S sauerstofff
                                XenonX Offline
                                XenonX Offline
                                Xenon
                                #155
                                @sauerm sagte in Test Adapter device-reminder V 1.x:
                                Genau, 0 kann nicht funktionieren da ja mindestens ein Wert für einen Vergleich benötigt wird 😉
                                • XenonX Xenon
                                  sauerstofff
                                  #156
                                  @xenon tatsächlich funktionierten bei meinen Geräten die Entprellintervalle nicht so gut. Unser Knitterschutz des Trockners geht teilweise 5 min. oder länger in einen Warte modus welcher nicht vom Standby zu unterscheidenn ist. Ich hatte mal einstel6bei denen es zwar funktionierte, dann aber mit so langer Wartezeit, dass zwischenzeitlich das Gerät bereits aus war 😅
                                  Ich nehme daher direkt 0W, da sich unsere Maschinen nach gewisser Zeit komplett ausschalten (was sich super tracken lässt ;) )
                                  Vielleicht könnte man irgendwann dafür einen Menüeintrag erstellen? (bei Wert x sofort Meldung raus) :)
                                  • S sauerstofff
                                    DickenD Offline
                                    DickenD Offline
                                    Dicken
                                    schrieb am zuletzt editiert von Dicken
                                    #157
                                    hab jetzt soweit alles eingetragen, auch die Alexa, wie kann ich sie denn jetzt sprechen lassen, wenn die waschmaschine fertig ist zbsp? Muss ich da ein zusätzliches script schreiben?
                                    • DickenD Dicken
                                      XenonX Offline
                                      XenonX Offline
                                      Xenon
                                      #158
                                      @dicken ich frage mich, wofür ich eigentlich stundenlang eine readme schreibe...
                                      DickenD 1 Antwort Letzte Antwort
                                      • XenonX Xenon
                                        DickenD Offline
                                        DickenD Offline
                                        Dicken
                                        #159
                                        @xenon sagte in Test Adapter device-reminder V 1.x:
                                        Sorry, aber ich hab die Readme gelesen und danach auch eingerichtet. Meine Alexa ist eingetragen und mit der Waschmaschine verlinkt.
                                        Ich hab allerdings nichts gefunden wo ich der Alexa sagen kann, was sie wann sagen soll.
                                        XenonX da_WoodyD 2 Antworten Letzte Antwort
                                        • S sauerstofff
                                          XenonX Offline
                                          XenonX Offline
                                          Xenon
                                          #160
                                          Du darfst nicht vergessen dass hier mit Verbrauchsmessung gearbeitet wird. Je mehr Werte du aufzeichnen lässt umso sicherer das Ergebnis, aber umso länger dauert auch die Endemeldung. Mein trockner zb läuft mit 2W und 45 Werten. Meldet ca. 7 min nach tatsächlichem Ende und das mit knitterschutz.
                                          Dein Vorschlag mit "schalte direkt bei wert X ab" ist unmöglich umzusetzen. Das kann man in einem Script für sich machen, aber nicht in einem Adapter der mehr als 2500 Installation hat. Dafür ist die Maße an Geräten viel zu groß
