  4. master / slave fehler
slave
79 Beiträge 5 Kommentatoren 9.5k Aufrufe 3 Beobachtet
    @rasen1992 sagte in master / slave fehler:
    'deconz.listsudo'
    Da hast du auch einen Fehler in den sourcen drin...
    iobroker host this
    rasen1992
    #41
    @Thomas-Braun
    was bedeutet der Fehler ??
    pi@raspberrypi:~ $ iobroker host this
    A host with the name "raspberrypi" already exists!
    • R rasen1992
      @Thomas-Braun
      #42
      @rasen1992
      Das heißt nur, dass die Datei nicht eingelesen werden wird. Da hast du offenbar eine Doublette drin. deconz.list dürfte es geben.
      iobroker start all
      R 1 Antwort Letzte Antwort
        @rasen1992
        iobroker start all
        rasen1992
        #43
        @Thomas-Braun
        pi@raspberrypi:~ $ iobroker start all
        The adapter "discovery.0" was started.
        The adapter "firetv.0" was started.
        The adapter "icons-icons8.0" was started.
        The adapter "icons-mfd-svg.0" was started.
        The adapter "icons-open-icon-library-png.0" was started.
        The adapter "icons-ultimate-png.0" was started.
        The adapter "info.0" was started.
        The adapter "material.0" was started.
        The adapter "node-red.0" was started.
        The adapter "ping.0" was started.
        The adapter "vis-colorpicker.0" was started.
        The adapter "vis-jqui-mfd.0" was started.
        The adapter "vis-materialdesign.0" was started.
        The adapter "vis-timeandweather.0" was started.
        The adapter "zigbee.0" was started.
        • R rasen1992
          @Thomas-Braun
          #44
          @rasen1992
          iobroker status
            @rasen1992
            iobroker status
            rasen1992
            #45
            @Thomas-Braun
            pi@raspberrypi:~ $ iobroker status
            iobroker is not running on this host.
            No iobroker host is running.
            Objects type: file
            States  type: file
            pi@raspberrypi:~ $
            • R rasen1992
              @Thomas-Braun
              Objects type: file
              States  type: file
              pi@raspberrypi:~ $
              #46
              @rasen1992
              sudo apt update
              sudo apt dist-upgrade
              sudo reboot
                @rasen1992
                sudo apt update
                sudo reboot
                rasen1992
                schrieb am zuletzt editiert von rasen1992
                #47
                @Thomas-Braun
                pi@raspberrypi:~ $ sudo apt update
                Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
                Hit:3 http://phoscon.de/apt/deconz buster InRelease
                Hit:4 http://archive.raspberrypi.org/debian buster InRelease
                Reading package lists... Done
                Building dependency tree
                All packages are up to date.
                N: Ignoring file 'deconz.listsudo' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
                pi@raspberrypi:~ $ sudo apt dist-upgrade
                Calculating upgrade... Done
                0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                kann ich irgendwie den multihost wieder abschalten ?
                • R rasen1992
                  @Thomas-Braun
                  #48
                  abschalten ?
                  iobroker multihost disable
                    abschalten ?
                    rasen1992
                    #49
                    @Thomas-Braun
                    oke ja hat auch nichts gebracht...
                    Type of objects DB [file, couch, redis], default [file]: ENTER
                    Host of objects DB(file), default[127.0.0.1]: <0.0.0.0>
                    Port of objects DB(file), default[9001]: ENTER
                    Type of states DB [file, redis], default [file]: ENTER
                    Host of states DB (file), default[0.0.0.0]: ENTER
                    Port of states DB (file), default[9000]: ENTER
                    Host name of this machine [hostname]: ENTER
                    beim Slave
                    Host of objects DB(file), default[127.0.0.1]: <IP ADRESSE> vom Hauptsystem
                    Host of states DB (file), default[cubie]:<IP ADRESSE> vom Hauptsystem
                    nur wegen dem alles geschrottet ? ...
                    • R rasen1992
                      @Thomas-Braun
                      beim Slave
                      #50
                      @rasen1992
                      Ich blick immer noch nicht ganz durch was du da veranstaltet hast.
                      Die Einstellung
                      ist jedenfalls falsch.
                      default[cubie]
                      sieht auch falsch aus.
                        @rasen1992
                        Die Einstellung
                        default[cubie]
                        rasen1992
                        #51
                        @Thomas-Braun
                        also ich habe einen 2. raspberrypi aufgesetzt (beide hatten den gleichen Namen) und habe diese Anleitung befolgt
                        https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                        und ja dann wars vorbei
                        • R rasen1992
                          @Thomas-Braun
                          #52
                          @rasen1992
                          Du musst auch Anleitungen lesen...
                          Installation
                          Wichtig: Die verschiedenenen Hosts müssen unbedingt eindeutige Hostnamen besitzen.
                          Und dann auch die aktuelle Anleitung hernehmen:
                          https://www.iobroker.net/#de/documentation/config/multihost.md
                            @rasen1992
                            Installation
                            rasen1992
                            #53
                            @Thomas-Braun ja leider übersehen... also am besten in die Tonne oder ? ...
                            • R rasen1992
                              #54
                              @rasen1992
                              Keine Ahnung. Ich geh jetzt zwar nicht in die Tonne, aber in's Bett.
                                @rasen1992
                                rasen1992
                                #55
                                @Thomas-Braun
                                danke trotzdem für die Hilfe
                                Kann geclosed werden, SD CARD FORMATTER hat das Problem gelöst.
                                • R rasen1992
                                  @Thomas-Braun
                                  UncleSamU Offline
                                  UncleSamU Offline
                                  UncleSam
                                  #56
                                  Schreib doch bitte einfach "[gelöst]" vor oder hinter den Titel des Themas, danke :)
                                  • UncleSamU UncleSam
                                    rasen1992
                                    #57
                                    muss leider nochmal das Thema aufgreifen, ich habe mir jetzt wieder einen Host eingerichtet.
                                    Wenn ich die Admin seite von meinem Master aufrufe wird unter Host mein Slave angezeigt, der ist auch Grün. Sollte soweit dann passen, aber wenn ich mir die installierten Adapter von meinem Slave unter Adapter anzeigen lassen möchte, wird mir nichts angezeigt.
                                    Im Log wird mir folgendes angezeigt
                                    host.pislave	2020-10-22 05:29:36.340	warn	does not start any instances on this host
                                    host.pislave	2020-10-22 05:29:36.290	info	35 instances found
                                    host.pislave	2020-10-22 05:28:53.286	info	connected to Objects and States
                                    host.pislave	2020-10-22 05:28:52.713	info	ip addresses: 192.168.0.66 fe80::cd13:c8bf:618:8b65
                                    host.pislave	2020-10-22 05:28:52.710	info	hostname: pislave, node: v12.19.0
                                    host.pislave	2020-10-22 05:28:52.709	info	Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    host.pislave	2020-10-22 05:28:52.700	info	iobroker.js-controller version 3.1.6 js-controller starting
                                    host.pislave	2020-10-22 05:28:30.821	info	terminated
                                    host.pislave	2020-10-22 05:28:27.401	info	received SIGTERM
                                    host.pislave	2020-10-22 05:15:11.082	warn	does not start any instances on this host
                                    host.pislave	2020-10-22 05:15:11.040	info	35 instances found
                                    host.pislave	2020-10-22 05:14:24.902	info	connected to Objects and States
                                    host.pislave	2020-10-22 05:14:21.713	info	ip addresses: 192.168.0.66 fe80::cd13:c8bf:618:8b65
                                    host.pislave	2020-10-22 05:14:21.710	info	hostname: pislave, node: v12.19.0
                                    host.pislave	2020-10-22 05:14:21.709	info	Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                    host.pislave	2020-10-22 05:14:21.701	info	iobroker.js-controller version 3.1.6 js-controller starting
                                    host.pislave	2020-10-22 05:14:01.295	error	uncaught exception: Connection is closed.
                                    host.pislave	2020-10-22 05:14:01.219	info	received SIGTERM
                                    host.pislave	2020-10-22 05:13:58.140	error	connect ECONNREFUSED 192.168.0.88:9001
                                    host.pislave	2020-10-22 05:13:54.570	error	connect ETIMEDOUT
                                    host.pislave	2020-10-22 05:13:48.561	error	connect ETIMEDOUT
                                    host.pislave	2020-10-22 05:13:39.564	error	connect ETIMEDOUT
                                    host.pislave	2020-10-22 05:13:36.553	error	connect ETIMEDOUT
                                    Wenn ich per SSH mich mit dem Slave verbinde und
                                    iobroker list adapters eingebe werden mir auch nur die Adapter vom Master angezeigt...
                                    evtl. weil ich nicht redis eingestellt habe bei setup custom ? bekomme dann nämlich folgenden Fehler
                                    ^[[Api@raspberrypi:~ $ iobroker setup custom
                                    Current configuration:
                                    - Objects database:
                                      - Type: file
                                      - Host/Unix Socket: 0.0.0.0
                                      - Port: 9001
                                    - States database:
                                      - Type: file
                                      - Port: 9000
                                    - Data Directory: ../../iobroker-data/
                                    Type of objects DB [(f)ile, (r)edis], default [file]: f
                                    Host / Unix Socket of objects DB(file), default[0.0.0.0]:
                                    Type of states DB [(f)file, (r)edis], default [file]: r
                                    When States are stored in a Redis database please make sure to configure Redis
                                    persistence to make sure a Redis problem will not cause data loss!
                                    Host / Unix Socket of states DB (redis), default[0.0.0.0]: 0.0.0.0
                                    Port of states DB (redis), default[6379]:
                                    Host name of this machine [raspberrypi]:
                                    This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                                    Do you want to migrate objects and states from "file/file" to "file/redis" [y/N]: y
                                    Connecting to previous DB "file"...
                                    Creating backup ...
                                    This can take some time ... please be patient!
                                    host.raspberrypi 3456 states saved
                                    host.raspberrypi 4112 objects saved
                                    Backup created: /opt/iobroker/backups/2020_10_22-06_23_18_backupiobroker-migration.tar.gz
                                    updating conf/iobroker.json
                                    Connecting to new DB "file" ...
                                    No connection to states 0.0.0.0:6379[redis]
                                    New Database could not be connected. Please check your settings. No settings have been changed.
                                    restoring conf/iobroker.json
                                    Danke schonmal
                                    Thomas BraunT UncleSamU 2 Antworten Letzte Antwort
                                    • R rasen1992
                                      - Objects database:
                                        - Type: file
                                        - Port: 9001
                                      - States database:
                                        - Type: file
                                        - Port: 9000
                                      Creating backup ...
                                      Danke schonmal
                                      #58
                                      @rasen1992 Hast du denn redis aktiv?
                                      • R rasen1992
                                        - Objects database:
                                          - Type: file
                                          - Port: 9001
                                        - States database:
                                          - Type: file
                                          - Port: 9000
                                        Creating backup ...
                                        Danke schonmal
                                        UncleSamU Offline
                                        UncleSamU Offline
                                        UncleSam
                                        #59
                                        Ohne Redis:
                                        Die Fehlermeldung does not start any instances on this host kommt davon, dass keine Instanzen für den Host pislave konfiguriert sind. Bist du sicher, dass da nicht etwas schief gegangen ist? Stimmt der Hostname überein? Sind die Adapter Instanzen aktiviert?
                                        Mit Redis:
                                        Läuft Redis auf dem Host raspberrypi und ist mit dem angegebenen Port erreichbar? Du musst Redis selber installieren und wenn nötig konfigurieren.
                                          Ohne Redis:
                                          Mit Redis:
                                          rasen1992
                                          #60
                                          @UncleSam @Thomas-Braun
                                          danke schonmal für die Hilfe,
                                          @UncleSam also Adapter + Instanzen habe ich auf dem Slave angelegt bevor ich ihn Konfiguriert habe, Hostname stimmt überein und er wird mir Grün angezeigt.
                                          bzgl. Redis werde ich mir am Abend dann nochmal genauer ansehen, müssten die Adapter bei der Variante ohne Redis auch angezeigt werden auf meinem Master-Pi ?
                                          bzw. was genau bringt sich Redis überhaupt ? ...
                                          ed: Redis ist nicht installiert, muss ich nachholen :)
