  4. master / slave fehler
slave
79 Beiträge 5 Kommentatoren 9.5k Aufrufe 3 Beobachtet
    @rasen1992
    Das heißt nur, dass die Datei nicht eingelesen werden wird. Da hast du offenbar eine Doublette drin. deconz.list dürfte es geben.
    iobroker start all
    rasen1992
    @Thomas-Braun
    pi@raspberrypi:~ $ iobroker start all
    The adapter "discovery.0" was started.
    The adapter "firetv.0" was started.
    The adapter "icons-icons8.0" was started.
    The adapter "icons-mfd-svg.0" was started.
    The adapter "icons-open-icon-library-png.0" was started.
    The adapter "icons-ultimate-png.0" was started.
    The adapter "info.0" was started.
    The adapter "material.0" was started.
    The adapter "node-red.0" was started.
    The adapter "ping.0" was started.
    The adapter "vis-colorpicker.0" was started.
    The adapter "vis-jqui-mfd.0" was started.
    The adapter "vis-materialdesign.0" was started.
    The adapter "vis-timeandweather.0" was started.
    The adapter "zigbee.0" was started.
    • R rasen1992
      @Thomas-Braun
      @rasen1992
      iobroker status
      R 1 Antwort Letzte Antwort
        @rasen1992
        iobroker status
        rasen1992
        @Thomas-Braun
        pi@raspberrypi:~ $ iobroker status
        iobroker is not running on this host.
        No iobroker host is running.
        Objects type: file
        States  type: file
        pi@raspberrypi:~ $
        • R rasen1992
          @Thomas-Braun
          Objects type: file
          States  type: file
          pi@raspberrypi:~ $
          @rasen1992
          sudo apt update
          sudo apt dist-upgrade
          sudo reboot
            @rasen1992
            sudo apt update
            sudo reboot
            rasen1992
            schrieb am zuletzt editiert von rasen1992
            @Thomas-Braun
            pi@raspberrypi:~ $ sudo apt update
            Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
            Hit:3 http://phoscon.de/apt/deconz buster InRelease
            Hit:4 http://archive.raspberrypi.org/debian buster InRelease
            Reading package lists... Done
            Building dependency tree
            All packages are up to date.
            N: Ignoring file 'deconz.listsudo' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
            pi@raspberrypi:~ $ sudo apt dist-upgrade
            Calculating upgrade... Done
            0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
            kann ich irgendwie den multihost wieder abschalten ?
            • R rasen1992
              @Thomas-Braun
              @rasen1992 sagte in master / slave fehler:
              abschalten ?
              iobroker multihost disable
                abschalten ?
                rasen1992
                @Thomas-Braun
                oke ja hat auch nichts gebracht...
                Type of objects DB [file, couch, redis], default [file]: ENTER
                Host of objects DB(file), default[127.0.0.1]: <0.0.0.0>
                Port of objects DB(file), default[9001]: ENTER
                Type of states DB [file, redis], default [file]: ENTER
                Host of states DB (file), default[0.0.0.0]: ENTER
                Port of states DB (file), default[9000]: ENTER
                Host name of this machine [hostname]: ENTER
                beim Slave
                Host of objects DB(file), default[127.0.0.1]: <IP ADRESSE> vom Hauptsystem
                Host of states DB (file), default[cubie]:<IP ADRESSE> vom Hauptsystem
                nur wegen dem alles geschrottet ? ...
                • R rasen1992
                  @Thomas-Braun
                  beim Slave
                  @rasen1992
                  Ich blick immer noch nicht ganz durch was du da veranstaltet hast.
                  Die Einstellung
                  ist jedenfalls falsch.
                  default[cubie]
                  sieht auch falsch aus.
                    @rasen1992
                    Die Einstellung
                    default[cubie]
                    rasen1992
                    @Thomas-Braun
                    also ich habe einen 2. raspberrypi aufgesetzt (beide hatten den gleichen Namen) und habe diese Anleitung befolgt
                    https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                    und ja dann wars vorbei
                    • R rasen1992
                      @Thomas-Braun
                      @rasen1992
                      Du musst auch Anleitungen lesen...
                      Installation
                      Wichtig: Die verschiedenenen Hosts müssen unbedingt eindeutige Hostnamen besitzen.
                      Und dann auch die aktuelle Anleitung hernehmen:
                      https://www.iobroker.net/#de/documentation/config/multihost.md
                        @rasen1992
                        Installation
                        rasen1992
                        @Thomas-Braun ja leider übersehen... also am besten in die Tonne oder ? ...
                        • R rasen1992
                          @rasen1992
                          Keine Ahnung. Ich geh jetzt zwar nicht in die Tonne, aber in's Bett.
                            @rasen1992
                            rasen1992
                            @Thomas-Braun
                            danke trotzdem für die Hilfe
                            Kann geclosed werden, SD CARD FORMATTER hat das Problem gelöst.
                            UncleSamU 1 Antwort Letzte Antwort
                            • R rasen1992
                              @Thomas-Braun
                              UncleSamU Offline
                              UncleSamU Offline
                              UncleSam
                              Schreib doch bitte einfach "[gelöst]" vor oder hinter den Titel des Themas, danke :)
                              Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
                              ♡-lichen Dank an meine Sponsoren
                              • UncleSamU UncleSam
                                rasen1992
                                muss leider nochmal das Thema aufgreifen, ich habe mir jetzt wieder einen Host eingerichtet.
                                Wenn ich die Admin seite von meinem Master aufrufe wird unter Host mein Slave angezeigt, der ist auch Grün. Sollte soweit dann passen, aber wenn ich mir die installierten Adapter von meinem Slave unter Adapter anzeigen lassen möchte, wird mir nichts angezeigt.
                                Im Log wird mir folgendes angezeigt
                                host.pislave	2020-10-22 05:29:36.340	warn	does not start any instances on this host
                                host.pislave	2020-10-22 05:29:36.290	info	35 instances found
                                host.pislave	2020-10-22 05:28:53.286	info	connected to Objects and States
                                host.pislave	2020-10-22 05:28:52.713	info	ip addresses: 192.168.0.66 fe80::cd13:c8bf:618:8b65
                                host.pislave	2020-10-22 05:28:52.710	info	hostname: pislave, node: v12.19.0
                                host.pislave	2020-10-22 05:28:52.709	info	Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                host.pislave	2020-10-22 05:28:52.700	info	iobroker.js-controller version 3.1.6 js-controller starting
                                host.pislave	2020-10-22 05:28:30.821	info	terminated
                                host.pislave	2020-10-22 05:28:27.401	info	received SIGTERM
                                host.pislave	2020-10-22 05:15:11.082	warn	does not start any instances on this host
                                host.pislave	2020-10-22 05:15:11.040	info	35 instances found
                                host.pislave	2020-10-22 05:14:24.902	info	connected to Objects and States
                                host.pislave	2020-10-22 05:14:21.713	info	ip addresses: 192.168.0.66 fe80::cd13:c8bf:618:8b65
                                host.pislave	2020-10-22 05:14:21.710	info	hostname: pislave, node: v12.19.0
                                host.pislave	2020-10-22 05:14:21.709	info	Copyright (c) 2014-2020 bluefox, 2014 hobbyquaker
                                host.pislave	2020-10-22 05:14:21.701	info	iobroker.js-controller version 3.1.6 js-controller starting
                                host.pislave	2020-10-22 05:14:01.295	error	uncaught exception: Connection is closed.
                                host.pislave	2020-10-22 05:14:01.219	info	received SIGTERM
                                host.pislave	2020-10-22 05:13:58.140	error	connect ECONNREFUSED 192.168.0.88:9001
                                host.pislave	2020-10-22 05:13:54.570	error	connect ETIMEDOUT
                                host.pislave	2020-10-22 05:13:48.561	error	connect ETIMEDOUT
                                host.pislave	2020-10-22 05:13:39.564	error	connect ETIMEDOUT
                                host.pislave	2020-10-22 05:13:36.553	error	connect ETIMEDOUT
                                Wenn ich per SSH mich mit dem Slave verbinde und
                                iobroker list adapters eingebe werden mir auch nur die Adapter vom Master angezeigt...
                                evtl. weil ich nicht redis eingestellt habe bei setup custom ? bekomme dann nämlich folgenden Fehler
                                ^[[Api@raspberrypi:~ $ iobroker setup custom
                                Current configuration:
                                - Objects database:
                                  - Type: file
                                  - Host/Unix Socket: 0.0.0.0
                                  - Port: 9001
                                - States database:
                                  - Type: file
                                  - Port: 9000
                                - Data Directory: ../../iobroker-data/
                                Type of objects DB [(f)ile, (r)edis], default [file]: f
                                Host / Unix Socket of objects DB(file), default[0.0.0.0]:
                                Type of states DB [(f)file, (r)edis], default [file]: r
                                When States are stored in a Redis database please make sure to configure Redis
                                persistence to make sure a Redis problem will not cause data loss!
                                Host / Unix Socket of states DB (redis), default[0.0.0.0]: 0.0.0.0
                                Port of states DB (redis), default[6379]:
                                Host name of this machine [raspberrypi]:
                                This host appears to be a Master or a Single host system. Is this correct? [Y/n]: y
                                Do you want to migrate objects and states from "file/file" to "file/redis" [y/N]: y
                                Connecting to previous DB "file"...
                                Creating backup ...
                                This can take some time ... please be patient!
                                host.raspberrypi 3456 states saved
                                host.raspberrypi 4112 objects saved
                                Backup created: /opt/iobroker/backups/2020_10_22-06_23_18_backupiobroker-migration.tar.gz
                                updating conf/iobroker.json
                                Connecting to new DB "file" ...
                                No connection to states 0.0.0.0:6379[redis]
                                New Database could not be connected. Please check your settings. No settings have been changed.
                                restoring conf/iobroker.json
                                Danke schonmal
                                Thomas BraunT UncleSamU 2 Antworten Letzte Antwort
                                • R rasen1992
                                  - Objects database:
                                    - Type: file
                                    - Port: 9001
                                  - States database:
                                    - Type: file
                                    - Port: 9000
                                  Creating backup ...
                                  Danke schonmal
                                  @rasen1992 Hast du denn redis aktiv?
                                  • R rasen1992
                                    - Objects database:
                                      - Type: file
                                      - Port: 9001
                                    - States database:
                                      - Type: file
                                      - Port: 9000
                                    Creating backup ...
                                    Danke schonmal
                                    UncleSamU Offline
                                    UncleSamU Offline
                                    UncleSam
                                    Ohne Redis:
                                    Die Fehlermeldung does not start any instances on this host kommt davon, dass keine Instanzen für den Host pislave konfiguriert sind. Bist du sicher, dass da nicht etwas schief gegangen ist? Stimmt der Hostname überein? Sind die Adapter Instanzen aktiviert?
                                    Mit Redis:
                                    Läuft Redis auf dem Host raspberrypi und ist mit dem angegebenen Port erreichbar? Du musst Redis selber installieren und wenn nötig konfigurieren.
                                      Ohne Redis:
                                      Mit Redis:
                                      rasen1992
                                      @UncleSam @Thomas-Braun
                                      danke schonmal für die Hilfe,
                                      @UncleSam also Adapter + Instanzen habe ich auf dem Slave angelegt bevor ich ihn Konfiguriert habe, Hostname stimmt überein und er wird mir Grün angezeigt.
                                      bzgl. Redis werde ich mir am Abend dann nochmal genauer ansehen, müssten die Adapter bei der Variante ohne Redis auch angezeigt werden auf meinem Master-Pi ?
                                      bzw. was genau bringt sich Redis überhaupt ? ...
                                      ed: Redis ist nicht installiert, muss ich nachholen :)
                                      • R rasen1992
                                        das darf man nicht :-(
                                        der Slave muss quasi bis auf admin und js-controller nackert sein
                                          rasen1992
                                          @Homoran
                                          Also darf ich erst nach dem einbinden als Host einen Adapter installieren ?
