  4. master / slave fehler
slave
79 Beiträge 5 Kommentatoren 9.5k Aufrufe 3 Beobachtet
  • R rasen1992
    @Thomas-Braun
    pi@raspberrypi:~ $ iobroker list instances
      system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      system.adapter.alexa2.0                : alexa2                -  enabled
      system.adapter.backitup.0              : backitup              -  enabled
      system.adapter.broadlink2.0            : broadlink2            -  enabled
      system.adapter.cloud.0                 : cloud                 -  enabled
      system.adapter.daswetter.0             : daswetter             -  enabled
      system.adapter.deconz.0                : deconz                -  enabled, port: 80
      system.adapter.discovery.0             : discovery             - disabled
      system.adapter.feiertage.0             : feiertage             -  enabled
      system.adapter.firetv.0                : firetv                - disabled
      system.adapter.ical.0                  : ical                  -  enabled
      system.adapter.icons-icons8.0          : icons-icons8          - disabled
      system.adapter.icons-mfd-svg.0         : icons-mfd-svg         - disabled
      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png - disabled
      system.adapter.icons-ultimate-png.0    : icons-ultimate-png    - disabled
      system.adapter.info.0                  : info                  - disabled
      system.adapter.iot.0                   : iot                   -  enabled
      system.adapter.javascript.0            : javascript            -  enabled
      system.adapter.material.0              : material              - disabled
      system.adapter.mihome-vacuum.0         : mihome-vacuum         -  enabled, port: 54321
      system.adapter.mqtt.0                  : mqtt                  -  enabled, port: 1883, bind: 0.0.0.0
      system.adapter.nello.0                 : nello                 -  enabled
      system.adapter.node-red.0              : node-red              - disabled, port: 1880, bind: 0.0.0.0
      system.adapter.ping.0                  : ping                  - disabled
      system.adapter.radar2.0                : radar2                -  enabled
      system.adapter.scenes.0                : scenes                -  enabled
      system.adapter.shelly.0                : shelly                -  enabled, port: 1882, bind: 0.0.0.0
      system.adapter.telegram.0              : telegram              -  enabled, port: 8443, bind: 0.0.0.0
      system.adapter.terminal.0              : terminal              -  enabled, port: 8088, bind: 192.168.0.15, run as: admin
      system.adapter.text2command.0          : text2command          -  enabled
      system.adapter.vis-colorpicker.0       : vis-colorpicker       - disabled
      system.adapter.vis-jqui-mfd.0          : vis-jqui-mfd          - disabled
      system.adapter.vis-materialdesign.0    : vis-materialdesign    - disabled
      system.adapter.vis-timeandweather.0    : vis-timeandweather    - disabled
      system.adapter.vis.0                   : vis                   -  enabled
      system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      system.adapter.zigbee.0                : zigbee                - disabled, port: /dev/ttyACM0
    + instance is alive
    @rasen1992
    iobroker start admin
    R 1 Antwort Letzte Antwort
      @rasen1992
      rasen1992
      @Thomas-Braun
      pi@raspberrypi:~ $ iobroker start admin
      pi@raspberrypi:~ $ iobroker status admin
      Instance "admin.0" is not running
      • R rasen1992
        @Thomas-Braun
        @rasen1992
        iobroker fix
          @rasen1992
          iobroker fix
          rasen1992
          schrieb am zuletzt editiert von rasen1992
          pi@raspberrypi:~ $ iobroker fix
          library: loaded
          Library version=2020-06-12
              Welcome to the ioBroker installation fixer!
              Script version: 2020-06-15
              You might need to enter your password a couple of times.
              Installing prerequisites (1/3)
          Hit:1 http://archive.raspberrypi.org/debian buster InRelease
          Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
          Hit:4 http://phoscon.de/apt/deconz buster InRelease
          Reading package lists... Done
          N: Ignoring file 'deconz.listsudo' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          iobroker is not running on this host.
          No iobroker host is running.
          Objects type: file
          States  type: file
          • R rasen1992
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            Objects type: file
            States  type: file
            @rasen1992 sagte in master / slave fehler:
            'deconz.listsudo'
            Da hast du auch einen Fehler in den sourcen drin...
            iobroker host this
              'deconz.listsudo'
              iobroker host this
              rasen1992
              @Thomas-Braun
              was bedeutet der Fehler ??
              pi@raspberrypi:~ $ iobroker host this
              A host with the name "raspberrypi" already exists!
              • R rasen1992
                @Thomas-Braun
                @rasen1992
                Das heißt nur, dass die Datei nicht eingelesen werden wird. Da hast du offenbar eine Doublette drin. deconz.list dürfte es geben.
                iobroker start all
                  @rasen1992
                  iobroker start all
                  rasen1992
                  @Thomas-Braun
                  pi@raspberrypi:~ $ iobroker start all
                  The adapter "discovery.0" was started.
                  The adapter "firetv.0" was started.
                  The adapter "icons-icons8.0" was started.
                  The adapter "icons-mfd-svg.0" was started.
                  The adapter "icons-open-icon-library-png.0" was started.
                  The adapter "icons-ultimate-png.0" was started.
                  The adapter "info.0" was started.
                  The adapter "material.0" was started.
                  The adapter "node-red.0" was started.
                  The adapter "ping.0" was started.
                  The adapter "vis-colorpicker.0" was started.
                  The adapter "vis-jqui-mfd.0" was started.
                  The adapter "vis-materialdesign.0" was started.
                  The adapter "vis-timeandweather.0" was started.
                  The adapter "zigbee.0" was started.
                  • R rasen1992
                    @Thomas-Braun
                    @rasen1992
                    iobroker status
                      @rasen1992
                      iobroker status
                      rasen1992
                      @Thomas-Braun
                      Objects type: file
                      States  type: file
                      pi@raspberrypi:~ $
                      • R rasen1992
                        @Thomas-Braun
                        Objects type: file
                        States  type: file
                        pi@raspberrypi:~ $
                        @rasen1992
                        sudo apt update
                        sudo apt dist-upgrade
                        sudo reboot
                          @rasen1992
                          sudo apt update
                          sudo reboot
                          rasen1992
                          @Thomas-Braun
                          pi@raspberrypi:~ $ sudo apt update
                          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                          Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
                          Hit:3 http://phoscon.de/apt/deconz buster InRelease
                          Hit:4 http://archive.raspberrypi.org/debian buster InRelease
                          Building dependency tree
                          All packages are up to date.
                          pi@raspberrypi:~ $ sudo apt dist-upgrade
                          Calculating upgrade... Done
                          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                          kann ich irgendwie den multihost wieder abschalten ?
                          • R rasen1992
                            @Thomas-Braun
                            abschalten ?
                            iobroker multihost disable
                              abschalten ?
                              rasen1992
                              @Thomas-Braun
                              oke ja hat auch nichts gebracht...
                              Type of objects DB [file, couch, redis], default [file]: ENTER
                              Host of objects DB(file), default[127.0.0.1]: <0.0.0.0>
                              Port of objects DB(file), default[9001]: ENTER
                              Type of states DB [file, redis], default [file]: ENTER
                              Host of states DB (file), default[0.0.0.0]: ENTER
                              Port of states DB (file), default[9000]: ENTER
                              Host name of this machine [hostname]: ENTER
                              beim Slave
                              Host of objects DB(file), default[127.0.0.1]: <IP ADRESSE> vom Hauptsystem
                              Host of states DB (file), default[cubie]:<IP ADRESSE> vom Hauptsystem
                              nur wegen dem alles geschrottet ? ...
                              • R rasen1992
                                @Thomas-Braun
                                beim Slave
                                @rasen1992
                                Ich blick immer noch nicht ganz durch was du da veranstaltet hast.
                                Die Einstellung
                                ist jedenfalls falsch.
                                default[cubie]
                                sieht auch falsch aus.
                                  @rasen1992
                                  Die Einstellung
                                  default[cubie]
                                  rasen1992
                                  @Thomas-Braun
                                  also ich habe einen 2. raspberrypi aufgesetzt (beide hatten den gleichen Namen) und habe diese Anleitung befolgt
                                  https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                                  und ja dann wars vorbei
                                  • R rasen1992
                                    @Thomas-Braun
                                    @rasen1992
                                    Du musst auch Anleitungen lesen...
                                    Installation
                                    Wichtig: Die verschiedenenen Hosts müssen unbedingt eindeutige Hostnamen besitzen.
                                    Und dann auch die aktuelle Anleitung hernehmen:
                                    https://www.iobroker.net/#de/documentation/config/multihost.md
                                      @rasen1992
                                      Installation
                                      rasen1992
                                      @Thomas-Braun ja leider übersehen... also am besten in die Tonne oder ? ...
                                      • R rasen1992
                                        @rasen1992
                                        Keine Ahnung. Ich geh jetzt zwar nicht in die Tonne, aber in's Bett.
                                          @rasen1992
                                          rasen1992
                                          @Thomas-Braun
                                          danke trotzdem für die Hilfe
                                          Kann geclosed werden, SD CARD FORMATTER hat das Problem gelöst.
                                          UncleSamU 1 Antwort Letzte Antwort
