  4. master / slave fehler
slave
79 Beiträge 5 Kommentatoren 9.5k Aufrufe 3 Beobachtet
    @rasen1992
    iobroker start admin
    rasen1992
    @Thomas-Braun
    pi@raspberrypi:~ $ iobroker start admin
    pi@raspberrypi:~ $ iobroker status admin
    Instance "admin.0" is not running
    • R rasen1992
      @Thomas-Braun
      @rasen1992
      iobroker fix
      R 1 Antwort Letzte Antwort
        @rasen1992
        iobroker fix
        rasen1992
        schrieb am zuletzt editiert von rasen1992
        pi@raspberrypi:~ $ iobroker fix
        library: loaded
        Library version=2020-06-12
            Welcome to the ioBroker installation fixer!
            Script version: 2020-06-15
            You might need to enter your password a couple of times.
            Installing prerequisites (1/3)
        Hit:1 http://archive.raspberrypi.org/debian buster InRelease
        Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
        Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
        Hit:4 http://phoscon.de/apt/deconz buster InRelease
        Reading package lists... Done
        N: Ignoring file 'deconz.listsudo' in directory '/etc/apt/sources.list.d/' as it has an invalid filename extension
        Installed gcc-c++
            Checking ioBroker user and directory permissions (2/3)
            Checking autostart (3/3)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        iobroker is not running on this host.
        No iobroker host is running.
        Objects type: file
        States  type: file
        • R rasen1992
          library: loaded
          Installed gcc-c++
          Autostart enabled!
          Objects type: file
          States  type: file
          @rasen1992 sagte in master / slave fehler:
          'deconz.listsudo'
          Da hast du auch einen Fehler in den sourcen drin...
          iobroker host this
            'deconz.listsudo'
            iobroker host this
            rasen1992
            @Thomas-Braun
            was bedeutet der Fehler ??
            pi@raspberrypi:~ $ iobroker host this
            A host with the name "raspberrypi" already exists!
            • R rasen1992
              @Thomas-Braun
              @rasen1992
              Das heißt nur, dass die Datei nicht eingelesen werden wird. Da hast du offenbar eine Doublette drin. deconz.list dürfte es geben.
              iobroker start all
                @rasen1992
                iobroker start all
                rasen1992
                @Thomas-Braun
                pi@raspberrypi:~ $ iobroker start all
                The adapter "discovery.0" was started.
                The adapter "firetv.0" was started.
                The adapter "icons-icons8.0" was started.
                The adapter "icons-mfd-svg.0" was started.
                The adapter "icons-open-icon-library-png.0" was started.
                The adapter "icons-ultimate-png.0" was started.
                The adapter "info.0" was started.
                The adapter "material.0" was started.
                The adapter "node-red.0" was started.
                The adapter "ping.0" was started.
                The adapter "vis-colorpicker.0" was started.
                The adapter "vis-jqui-mfd.0" was started.
                The adapter "vis-materialdesign.0" was started.
                The adapter "vis-timeandweather.0" was started.
                The adapter "zigbee.0" was started.
                • R rasen1992
                  @Thomas-Braun
                  @rasen1992
                  iobroker status
                    @rasen1992
                    iobroker status
                    rasen1992
                    @Thomas-Braun
                    Objects type: file
                    States  type: file
                    pi@raspberrypi:~ $
                    • R rasen1992
                      @Thomas-Braun
                      Objects type: file
                      States  type: file
                      pi@raspberrypi:~ $
                      @rasen1992
                      sudo apt update
                      sudo apt dist-upgrade
                      sudo reboot
                        @rasen1992
                        sudo apt update
                        sudo reboot
                        rasen1992
                        @Thomas-Braun
                        pi@raspberrypi:~ $ sudo apt update
                        Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
                        Hit:2 https://deb.nodesource.com/node_12.x buster InRelease
                        Hit:3 http://phoscon.de/apt/deconz buster InRelease
                        Hit:4 http://archive.raspberrypi.org/debian buster InRelease
                        Building dependency tree
                        All packages are up to date.
                        pi@raspberrypi:~ $ sudo apt dist-upgrade
                        Calculating upgrade... Done
                        0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                        kann ich irgendwie den multihost wieder abschalten ?
                        • R rasen1992
                          @Thomas-Braun
                          abschalten ?
                          iobroker multihost disable
                            abschalten ?
                            rasen1992
                            @Thomas-Braun
                            oke ja hat auch nichts gebracht...
                            Type of objects DB [file, couch, redis], default [file]: ENTER
                            Host of objects DB(file), default[127.0.0.1]: <0.0.0.0>
                            Port of objects DB(file), default[9001]: ENTER
                            Type of states DB [file, redis], default [file]: ENTER
                            Host of states DB (file), default[0.0.0.0]: ENTER
                            Port of states DB (file), default[9000]: ENTER
                            Host name of this machine [hostname]: ENTER
                            beim Slave
                            Host of objects DB(file), default[127.0.0.1]: <IP ADRESSE> vom Hauptsystem
                            Host of states DB (file), default[cubie]:<IP ADRESSE> vom Hauptsystem
                            nur wegen dem alles geschrottet ? ...
                            • R rasen1992
                              @Thomas-Braun
                              beim Slave
                              @rasen1992
                              Ich blick immer noch nicht ganz durch was du da veranstaltet hast.
                              Die Einstellung
                              ist jedenfalls falsch.
                              default[cubie]
                              sieht auch falsch aus.
                                @rasen1992
                                Die Einstellung
                                default[cubie]
                                rasen1992
                                @Thomas-Braun
                                also ich habe einen 2. raspberrypi aufgesetzt (beide hatten den gleichen Namen) und habe diese Anleitung befolgt
                                https://www.iobroker.net/docu/index-24.htm?page_id=3068&lang=de
                                und ja dann wars vorbei
                                • R rasen1992
                                  @Thomas-Braun
                                  @rasen1992
                                  Du musst auch Anleitungen lesen...
                                  Installation
                                  Wichtig: Die verschiedenenen Hosts müssen unbedingt eindeutige Hostnamen besitzen.
                                  Und dann auch die aktuelle Anleitung hernehmen:
                                  https://www.iobroker.net/#de/documentation/config/multihost.md
                                    @rasen1992
                                    Installation
                                    rasen1992
                                    @Thomas-Braun ja leider übersehen... also am besten in die Tonne oder ? ...
                                    • R rasen1992
                                      @rasen1992
                                      Keine Ahnung. Ich geh jetzt zwar nicht in die Tonne, aber in's Bett.
                                        @rasen1992
                                        rasen1992
                                        @Thomas-Braun
                                        danke trotzdem für die Hilfe
                                        Kann geclosed werden, SD CARD FORMATTER hat das Problem gelöst.
                                        UncleSamU 1 Antwort Letzte Antwort
                                        • R rasen1992
                                          @Thomas-Braun
                                          UncleSamU Offline
                                          UncleSamU Offline
                                          UncleSam
                                          Schreib doch bitte einfach "[gelöst]" vor oder hinter den Titel des Themas, danke :)
                                          Bitte bei Problemen mit meinen Adaptern, Issue auf GitHub erfassen: Loxone | I2C | Luxtronik2
                                          ♡-lichen Dank an meine Sponsoren
