  4. [HowTo] ioBroker Restore unter Linux durchführen
    6.7k
restorerestore backupbackituphow-to
527 Beiträge 80 Kommentatoren 198.8k Aufrufe 76 Beobachtet
    @sebi_7_6
    Schau per
    iob logs --watch | uniq
    dem Backup in der Konsole zu.
    Sebi_7_6
    schrieb am zuletzt editiert von Sebi_7_6
    #401
    @thomas-braun said in [HowTo] ioBroker Restore unter Linux durchführen:
    irgendwie stoppt er nur alles...Ab 18:23:30 habe ich die Wiederherstellung gestartet.
    2023-04-22 18:23:30.999  - info: bring.0 (10071) [END] Stopping Bring! adapter...
    2023-04-22 18:23:31.013  - info: host.raspberrypi received SIGTERM
    2023-04-22 18:23:31.019  - info: backitup.0 (9766) cleaned everything up...
    2023-04-22 18:23:30.999  - info: trashschedule.0 (9969) cleaned everything up...
    2023-04-22 18:23:31.033  - info: admin.0 (9373) terminating http server on port 8081
    2023-04-22 18:23:31.034  - info: wled.0 (10341) cleaned everything up...
    2023-04-22 18:23:31.025  - info: accuweather.0 (9854) cleaned everything up...
    2023-04-22 18:23:31.022  - info: host.raspberrypi stopInstance system.adapter.admin.0 (force=false, process=true)
    2023-04-22 18:23:31.025  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 (force=false, process=true)
    2023-04-22 18:23:31.028  - info: host.raspberrypi stopInstance system.adapter.ical.0 (force=false, process=false)
    2023-04-22 18:23:31.030  - info: host.raspberrypi stopInstance system.adapter.tuya.0 (force=false, process=true)
    2023-04-22 18:23:31.033  - info: host.raspberrypi stopInstance system.adapter.discovery.0 (force=false, process=true)
    2023-04-22 18:23:31.035  - info: host.raspberrypi stopInstance system.adapter.backitup.0 (force=false, process=true)
    2023-04-22 18:23:31.037  - info: host.raspberrypi stopInstance system.adapter.accuweather.0 (force=false, process=true)
    2023-04-22 18:23:31.040  - info: host.raspberrypi stopInstance system.adapter.iot.0 (force=false, process=false)
    2023-04-22 18:23:31.047  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 (force=false, process=true)
    2023-04-22 18:23:31.049  - info: host.raspberrypi stopInstance system.adapter.bring.0 (force=false, process=true)
    2023-04-22 18:23:31.050  - info: host.raspberrypi stopInstance system.adapter.daswetter.0 (force=false, process=false)
    2023-04-22 18:23:31.053  - info: host.raspberrypi stopInstance canceled schedule system.adapter.daswetter.0
    2023-04-22 18:23:31.054  - info: host.raspberrypi stopInstance system.adapter.web.0 (force=false, process=true)
    2023-04-22 18:23:31.056  - info: host.raspberrypi stopInstance system.adapter.habpanel.0 (force=false, process=false)
    2023-04-22 18:23:31.057  - info: host.raspberrypi stopInstance system.adapter.wled.0 (force=false, process=true)
    2023-04-22 18:23:31.160  - info: bring.0 (10071) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.182  - info: alexa2.0 (9495) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.188  - info: admin.0 (9373) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.200  - info: backitup.0 (9766) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.202  - info: accuweather.0 (9854) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.208  - info: bring.0 (10071) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.195  - info: tuya.0 (9601) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.205  - info: trashschedule.0 (9969) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.192  - info: alexa2.0 (9495) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.230  - info: web.0 (10270) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.220  - info: wled.0 (10341) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.237  - info: admin.0 (9373) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.224  - info: discovery.0 (9680) Got terminate signal TERMINATE_YOURSELF
    2023-04-22 18:23:31.244  - info: backitup.0 (9766) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.244  - info: wled.0 (10341) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.253  - info: trashschedule.0 (9969) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.276  - info: discovery.0 (9680) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.286  - info: accuweather.0 (9854) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.289  - info: host.raspberrypi stopInstance system.adapter.admin.0 send kill signal
    2023-04-22 18:23:31.305  - info: host.raspberrypi stopInstance system.adapter.alexa2.0 send kill signal
    2023-04-22 18:23:31.307  - info: host.raspberrypi stopInstance system.adapter.tuya.0 send kill signal
    2023-04-22 18:23:31.309  - info: host.raspberrypi stopInstance system.adapter.discovery.0 send kill signal
    2023-04-22 18:23:31.310  - info: host.raspberrypi stopInstance system.adapter.backitup.0 send kill signal
    2023-04-22 18:23:31.311  - info: host.raspberrypi stopInstance system.adapter.accuweather.0 send kill signal
    2023-04-22 18:23:31.312  - info: host.raspberrypi stopInstance system.adapter.trashschedule.0 send kill signal
    2023-04-22 18:23:31.313  - info: host.raspberrypi stopInstance system.adapter.bring.0 send kill signal
    2023-04-22 18:23:31.314  - info: host.raspberrypi stopInstance system.adapter.web.0 send kill signal
    2023-04-22 18:23:31.315  - info: host.raspberrypi stopInstance system.adapter.wled.0 send kill signal
    2023-04-22 18:23:31.496  - info: web.0 (10270) terminated http server on port 8082
    2023-04-22 18:23:31.510  - info: web.0 (10270) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:31.808  - info: host.raspberrypi instance system.adapter.bring.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:31.917  - info: host.raspberrypi instance system.adapter.alexa2.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:32.107  - info: host.raspberrypi instance system.adapter.admin.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:32.115  - info: host.raspberrypi instance system.adapter.wled.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:32.227  - info: host.raspberrypi instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:32.229  - info: host.raspberrypi instance system.adapter.accuweather.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:32.231  - info: host.raspberrypi instance system.adapter.discovery.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:32.272  - info: host.raspberrypi instance system.adapter.trashschedule.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:32.349  - info: host.raspberrypi instance system.adapter.web.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:34.043  - info: tuya.0 (9601) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2023-04-22 18:23:34.663  - info: host.raspberrypi instance system.adapter.tuya.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    2023-04-22 18:23:34.665  - info: host.raspberrypi All instances are stopped.
    2023-04-22 18:23:34.804  - info: host.raspberrypi terminated
    • S Sebi_7_6
      hab heute mein Raspi neu installiert und IoBroker drauf gemacht. Wollte mein Backup einspiele und er sagt Wiederherstellung wird gestartet dann dreht sich der Kreis und dann ist IoBroker Offline und muss den Dienst erst wieder neustarten! Aber er hat nichts wiederhergestellt?
      Wo liegt hier das Problem?
      #402
      @sebi_7_6 sagte in [HowTo] ioBroker Restore unter Linux durchführen:
      Was machst du da genau?
        Sebi_7_6
        #403
        Stelle meine Sicherung wieder her .
        • S Sebi_7_6
          #404
          @sebi_7_6
          Mach es mal komplett im Terminal.
          iobroker restore <backup name or path>
            @sebi_7_6
            Sebi_7_6
            #405
            iobroker controller daemon is not running
            host.raspberrypi OK.
            The current version of js-controller differs from the version in the backup.
            The js-controller version of the backup can not be restored automatically.
            To restore the js-controller version of the backup, execute "npm i iobroker.js-controller@4.0.23 --production" inside your ioBroker directory
            If you really want to restore the backup with the current installed js-controller, execute the restore command with the --force flag
            • S Sebi_7_6
              #406
              Dann hast du ja den Grund.
                Sebi_7_6
                #407
                Jaja :-) Warum sagt er mir das in der GUI nicht. Denke jeder hat nich immer sein Version aktuell obwohl ich es eigentlich dachte, dass sie es wäre.
                Und was mache ich jetzt ?
                • S Sebi_7_6
                  #408
                  @sebi_7_6
                  Steht doch da. Die alte Version installieren.
                  Dann passt auch das Backup da wieder rein.
                  Weil GUIs notorisch lügen und Informationen zurückhalten.
                  Bitte gewöhn dir an für Texte aus der Konsole die CodeTags zu verwenden.
                    @sebi_7_6
                    Sebi_7_6
                    #409
                    Danke für den Hinweis.
                    Ich danke dir aufjedenfall recht Herzlich für deine Hilfe!
                      Sebi_7_6
                      #410
                      Das Backup hat soweit funktioniert nur das HABPanel nicht. Hab es entfernt und die Instanz wieder neu installiert.
                      Aber es steht immer 2x drinn. Clicke ich drauf kommt so etwas ..
                      URIError: Failed to decode param '%web_protocol%://%web_bind%:%web_port%/habpanel/index.html'
                          at decodeURIComponent (<anonymous>)
                          at decode_param (/opt/iobroker/node_modules/express/lib/router/layer.js:172:12)
                          at Layer.match (/opt/iobroker/node_modules/express/lib/router/layer.js:148:15)
                          at matchLayer (/opt/iobroker/node_modules/express/lib/router/index.js:585:18)
                          at next (/opt/iobroker/node_modules/express/lib/router/index.js:226:15)
                          at compression (/opt/iobroker/node_modules/compression/index.js:220:5)
                          at Layer.handle [as handle_request] (/opt/iobroker/node_modules/express/lib/router/layer.js:95:5)
                          at trim_prefix (/opt/iobroker/node_modules/express/lib/router/index.js:328:13)
                          at /opt/iobroker/node_modules/express/lib/router/index.js:286:9
                          at Function.process_params (/opt/iobroker/node_modules/express/lib/router/index.js:346:12)
                      • S Sebi_7_6
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Glasfaser
                        #411
                        Was entfernt , nur die Instanz ... oder auch den Adapter !?
                        Zeige mal
                        iob diag
                          Sebi_7_6
                          #412
                          Beides
                          Adapter State
                            system.adapter.accuweather.0            : accuweather           : raspberrypi                              - disabled
                          + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          + system.adapter.alexa2.0                 : alexa2                : raspberrypi                              -  enabled
                          + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                          + system.adapter.bring.0                  : bring                 : raspberrypi                              -  enabled
                            system.adapter.cloud.0                  : cloud                 : raspberrypi                              - disabled
                            system.adapter.daswetter.0              : daswetter             : raspberrypi                              -  enabled
                            system.adapter.discovery.0              : discovery             : raspberrypi                              - disabled
                            system.adapter.dwd.0                    : dwd                   : raspberrypi                              -  enabled
                            system.adapter.feiertage.0              : feiertage             : raspberrypi                              -  enabled
                            system.adapter.hue-extended.0           : hue-extended          : raspberrypi                              - disabled
                            system.adapter.ical.0                   : ical                  : raspberrypi                              - disabled
                          + system.adapter.iot.0                    : iot                   : raspberrypi                              -  enabled
                            system.adapter.javascript.0             : javascript            : raspberrypi                              - disabled
                          + system.adapter.lg-thinq.0               : lg-thinq              : raspberrypi                              -  enabled
                            system.adapter.lgtv.0                   : lgtv                  : raspberrypi                              - disabled
                            system.adapter.openweathermap.0         : openweathermap        : raspberrypi                              - disabled
                          + system.adapter.ping.0                   : ping                  : raspberrypi                              -  enabled
                          + system.adapter.pushbullet.0             : pushbullet            : raspberrypi                              -  enabled
                            system.adapter.schoolfree.0             : schoolfree            : raspberrypi                              - disabled
                            system.adapter.smartthings.0            : smartthings           : raspberrypi                              - disabled
                          + system.adapter.spotify-premium.0        : spotify-premium       : raspberrypi                              -  enabled
                            system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi                              - disabled
                            system.adapter.tr-064.0                 : tr-064                : raspberrypi                              - disabled
                          + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                          + system.adapter.tuya.0                   : tuya                  : raspberrypi                              -  enabled
                            system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                            system.adapter.web.0                    : web                   : raspberrypi                              - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                          + system.adapter.wled.0                   : wled                  : raspberrypi                              -  enabled
                          + instance is alive
                          ioBroker-Repositories
                          Active repo(s): stable
                          Installed ioBroker-Instances
                          Used repository: stable
                          Adapter    "accuweather"  : 1.2.1    , installed 1.2.1
                          Adapter    "admin"        : 6.3.5    , installed 6.2.17 [Updatable]
                          Adapter    "alexa2"       : 3.23.2   , installed 3.19.9 [Updatable]
                          Adapter    "backitup"     : 2.6.16   , installed 2.4.10 [Updatable]
                          Adapter    "bring"        : 1.8.1    , installed 1.8.1
                          Adapter    "cloud"        : 4.3.0    , installed 4.2.2  [Updatable]
                          Adapter    "daswetter"    : 3.1.7    , installed 3.1.7
                          Adapter    "discovery"    : 3.1.0    , installed 3.0.3  [Updatable]
                          Adapter    "dwd"          : 2.8.3    , installed 2.8.3
                          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                          Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
                          Adapter    "ical"         : 1.13.2   , installed 1.13.2
                          Adapter    "iot"          : 1.14.2   , installed 1.11.9 [Updatable]
                          Adapter    "javascript"   : 6.1.4    , installed 6.0.0  [Updatable]
                          Controller "js-controller": 4.0.24   , installed 4.0.23 [Updatable]
                          Adapter    "lg-thinq"     : 0.1.4    , installed 0.0.7  [Updatable]
                          Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
                          Adapter    "openweathermap": 0.3.3   , installed 0.3.3
                          Adapter    "ping"         : 1.5.3    , installed 1.5.3
                          Adapter    "pushbullet"   : 0.0.11   , installed 0.0.11
                          Adapter    "schoolfree"   : 1.1.1    , installed 1.0.1  [Updatable]
                          Adapter    "smartthings"  : 0.0.4    , installed 0.0.3  [Updatable]
                          Adapter    "socketio"     : 4.2.0    , installed 4.2.0
                          Adapter    "spotify-premium": 1.2.1  , installed 1.2.1
                          Adapter    "tankerkoenig" : 3.3.7    , installed 3.3.7
                          Adapter    "tr-064"       : 4.2.18   , installed 4.2.16 [Updatable]
                          Adapter    "trashschedule": 2.2.0    , installed 2.2.0
                          Adapter    "tuya"         : 3.13.1   , installed 3.13.1
                          Adapter    "vis"          : 1.4.16   , installed 1.4.15 [Updatable]
                          Adapter    "web"          : 4.3.0    , installed 4.3.0
                          Adapter    "wled"         : 0.6.7    , installed 0.6.7
                          Adapter    "ws"           : 1.3.0    , installed 1.3.0
                          Objects and States
                          Objects:        9978
                          States:         8091
                          Wie ich gesehen habe ist es bei der VIS genauso.
                          Hab jetzt beide deinstalliert und nur HABPanel wieder installiert.
                          Aber es erscheint wieder 2x im Dashboard und dann der Fehler wenn man ihn aufruft.
                          da ist auch nichts zum starten oder Einstellungen usw.
                          • H Offline
                            Habedere
                            schrieb am zuletzt editiert von Habedere
                            #413
                            habe die Tage auch mein Backup neu eingespielt und hab etwas Probleme...
                            Los gings hiermit:
                            No connection to states 127.0.0.1:6379
                            Hab dann redis neu installiert. Soweit so gut...
                            Nun wie folgt probiert bzw. Fehlermeldung erhalten:
                            nulu@raspberrypi:~ $ iobroker stop
                            iobroker host this
                            iobroker start
                            A host with the name "raspberrypi" already exists!
                            Scheint aktiv zu sein, kann aber nicht darauf zugreifen:
                            nulu@raspberrypi:~ $ iobroker list instances
                              system.adapter.awattar.0                : awattar               : raspberrypi                              - disabled
                              system.adapter.broadlink2.0             : broadlink2            : raspberrypi                              - disabled
                              system.adapter.daswetter.0              : daswetter             : raspberrypi                              - disabled
                              system.adapter.discovergy.0             : discovergy            : raspberrypi                              - disabled
                              system.adapter.easee.0                  : easee                 : raspberrypi                              - disabled
                              system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                              system.adapter.history.0                : history               : raspberrypi                              - disabled
                              system.adapter.hm-rega.0                : hm-rega               : raspberrypi                              - disabled
                              system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi                              - disabled, port: 0
                              system.adapter.info.0                   : info                  : raspberrypi                              - disabled
                              system.adapter.mobile.0                 : mobile                : raspberrypi                              - disabled
                              system.adapter.modbus.3                 : modbus                : raspberrypi                              - disabled
                              system.adapter.modbus.4                 : modbus                : raspberrypi                              - disabled
                              system.adapter.mqtt.0                   : mqtt                  : raspberrypi                              - disabled, port: 1883, bind: 0.0.0.0
                              system.adapter.rpi2.0                   : rpi2                  : raspberrypi                              - disabled
                              system.adapter.socketio.0               : socketio              : raspberrypi                              - disabled, port: 8084, bind: 0.0.0.0, run as: admin
                              system.adapter.solarwetter.0            : solarwetter           : raspberrypi                              - disabled
                              system.adapter.sonoff.0                 : sonoff                : raspberrypi                              - disabled, port: 1884, bind: 0.0.0.0
                              system.adapter.sprinklecontrol.0        : sprinklecontrol       : raspberrypi                              - disabled
                              system.adapter.sql.0                    : sql                   : raspberrypi                              - disabled, port: 3306
                              system.adapter.statistics.0             : statistics            : raspberrypi                              - disabled
                              system.adapter.telegram.0               : telegram              : raspberrypi                              - disabled, port: 8443, bind: 0.0.0.0
                              system.adapter.vis-history.0            : vis-history           : raspberrypi                              - disabled
                              system.adapter.worx.0                   : worx                  : raspberrypi                              - disabled
                              system.adapter.yamaha.0                 : yamaha                : raspberrypi                              - disabled
                              system.adapter.zigbee.0                 : zigbee                : raspberrypi                              - disabled, port: /dev/ttyUSB0
                            + instance is alive
                            Jemand einen Tipp wo ich ansezten kann?
                            PS: hier noch der vollständige Diag
                            Skript v.2023-04-16
                            *** BASE SYSTEM ***
                            Model           : Raspberry Pi 3 Model B Rev 1.2
                            Architecture    : aarch64
                            Docker          : false
                            Virtualization  : none
                            Distributor ID: Debian
                            Description:    Debian GNU/Linux 11 (bullseye)
                            Release:        11
                            Codename:       bullseye
                            PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
                            NAME="Debian GNU/Linux"
                            VERSION_ID="11"
                            VERSION="11 (bullseye)"
                            VERSION_CODENAME=bullseye
                            ID=debian
                            HOME_URL="https://www.debian.org/"
                            SUPPORT_URL="https://www.debian.org/support"
                            BUG_REPORT_URL="https://bugs.debian.org/"
                            Systemuptime and Load:
                             16:57:57 up 7 min,  1 user,  load average: 0.39, 0.39, 0.22
                            CPU threads: 4
                            Raspberry only:
                            throttled=0x0
                            Other values than 0x0 hint to temperature/voltage problems
                            temp=55.3'C
                            volt=1.3000V
                            *** Time and Time Zones ***
                                           Local time: Tue 2023-04-25 16:57:58 CEST
                                       Universal time: Tue 2023-04-25 14:57:58 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            *** User and Groups ***
                            nulu
                            /home/nulu
                            nulu adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                            *** X-Server-Setup ***
                            X-Server:       false
                            Desktop:
                            Terminal:       tty
                            Boot Target:    multi-user.target
                            *** MEMORY ***
                            Mem:            909M        150M        540M        1.0M        218M        702M
                            Swap:            99M          0B         99M
                            Total:          1.0G        150M        640M
                                      909 M total memory
                                      150 M used memory
                                      233 M active memory
                                       62 M inactive memory
                                      540 M free memory
                                       18 M buffer memory
                                      199 M swap cache
                                       99 M total swap
                                        0 M used swap
                                       99 M free swap
                            Raspberry only:
                            oom events: 0
                            lifetime oom required: 0 Mbytes
                            total time in oom handler: 0 ms
                            max time spent in oom handler: 0 ms
                            *** FILESYSTEM ***
                            /dev/root      ext4      110G  2.8G  103G   3% /
                            devtmpfs       devtmpfs  325M     0  325M   0% /dev
                            tmpfs          tmpfs     455M     0  455M   0% /dev/shm
                            tmpfs          tmpfs     182M  1.1M  181M   1% /run
                            /dev/sda1      vfat      255M   31M  225M  13% /boot
                            tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                            [Tue Apr 25 16:50:07 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60i vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=e2d113b0-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Tue Apr 25 16:50:13 2023] EXT4-fs (sda2): mounted filesystem with ordered data mode. Quota mode: none.
                            [Tue Apr 25 16:50:13 2023] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
                            [Tue Apr 25 16:50:17 2023] EXT4-fs (sda2): re-mounted. Quota mode: none.
                            Show mounted filesystems (real ones only):
                            TARGET  SOURCE    FSTYPE OPTIONS
                            /       /dev/sda2 ext4   rw,noatime
                            `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                            /var:
                            644M    /var/
                            271M    /var/lib
                            196M    /var/cache
                            191M    /var/cache/apt
                            124M    /var/lib/mysql
                            Archived and active journals take up 72.0M in the file system.
                            /opt/iobroker/backups:
                            4.0K    /opt/iobroker/backups/
                            /opt/iobroker/iobroker-data:
                            47M     /opt/iobroker/iobroker-data/
                            16M     /opt/iobroker/iobroker-data/files
                            13M     /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                            14M     /opt/iobroker/iobroker-data/objects.jsonl
                            6.3M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js.map
                            5.2M    /opt/iobroker/iobroker-data/states.jsonl
                            2.8M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_js-node_modules_iobr-99c23e.847b8ad9.chunk.js
                            1.6M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map
                            *** NodeJS-Installation ***
                            /usr/bin/nodejs         v18.16.0
                            /usr/bin/node           v18.16.0
                            /usr/bin/npm            9.5.1
                            /usr/bin/npx            9.5.1
                            nodejs:
                              Installed: 18.16.0-deb-1nodesource1
                              Candidate: 18.16.0-deb-1nodesource1
                              Version table:
                             *** 18.16.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_18.x bullseye/main arm64 Packages
                                    100 /var/lib/dpkg/status
                                 12.22.12~dfsg-1~deb11u3 500
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                 12.22.5~dfsg-2~11u1 500
                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            No problems detected
                            *** ioBroker-Installation ***
                            ioBroker Status
                            iobroker is not running on this host.
                            Objects type: jsonl
                            States  type: jsonl
                            MULTIHOSTSERVICE/enabled: false
                            Core adapters versions
                            js-controller:  4.0.24
                            admin:          6.3.5
                            javascript:     "javascript" not found
                            Adapters from github:   0
                            Adapter State
                            + instance is alive
                            Adapter    "admin"        : 6.3.5    , installed 6.3.5
                            Adapter    "backitup"     : 2.6.16   , installed 2.5.9  [Updatable]
                            Adapter    "flot"         : 1.11.0   , installed 1.11.0
                            Adapter    "history"      : 2.2.4    , installed 2.2.4
                            Controller "js-controller": 4.0.24   , installed 4.0.24
                            Objects and States
                            Objects:        9496
                            States:         83
                            Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:2 http://deb.debian.org/debian bullseye InRelease
                            Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:5 https://deb.nodesource.com/node_18.x bullseye InRelease
                            Reading package lists...
                            Pending Updates: 0
                            *** Listening Ports ***
                            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14720      558/sshd: /usr/sbin
                            tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      110        12805      612/mariadbd
                            tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      111        13827      544/redis-server 12
                            tcp6       0      0 :::22                   :::*                    LISTEN      0          14722      558/sshd: /usr/sbin
                            tcp6       0      0 ::1:6379                :::*                    LISTEN      111        13828      544/redis-server 12
                            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12790      779/dhcpcd
                            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14624      432/avahi-daemon: r
                            udp        0      0 0.0.0.0:44832           0.0.0.0:*                           108        14626      432/avahi-daemon: r
                            udp6       0      0 :::60532                :::*                                108        14627      432/avahi-daemon: r
                            udp6       0      0 :::5353                 :::*                                108        14625      432/avahi-daemon: r
                            2023-04-25 16:58:01.301  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                            2023-04-25 16:58:01.327  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                            2023-04-25 16:58:01.331  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                            2023-04-25 16:58:01.332  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                            2023-04-25 16:58:05.120  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
                            2023-04-25 16:58:31.388  - error: host.raspberrypi No connection to databases possible, restart
                            2023-04-25 16:58:31.401  - info: host.raspberrypi iobroker _restart
                            2023-04-25 16:58:39.163  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                            2023-04-25 16:58:39.176  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                            2023-04-25 16:58:39.179  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                            2023-04-25 16:58:39.180  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                            2023-04-25 16:58:43.156  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
                            2023-04-25 16:59:09.234  - error: host.raspberrypi No connection to databases possible, restart
                            2023-04-25 16:59:09.245  - info: host.raspberrypi iobroker _restart
                            2023-04-25 16:59:16.522  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                            2023-04-25 16:59:16.536  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                            2023-04-25 16:59:16.539  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                            2023-04-25 16:59:16.541  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                            2023-04-25 16:59:20.553  - info: host.raspberrypi-Server  Error inMem-objects listening on port 6379: Error: listen EADDRINUSE: address already in use 127.0.0.1:6379
                            2023-04-25 16:59:46.590  - error: host.raspberrypi No connection to databases possible, restart
                            2023-04-25 16:59:46.602  - info: host.raspberrypi iobroker _restart
                            2023-04-25 16:59:54.337  - info: host.raspberrypi iobroker.js-controller version 4.0.24 js-controller starting
                            2023-04-25 16:59:54.353  - info: host.raspberrypi Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
                            2023-04-25 16:59:54.356  - info: host.raspberrypi hostname: raspberrypi, node: v18.16.0
                            2023-04-25 16:59:54.357  - info: host.raspberrypi ip addresses: 192.168.178.3 fdc8:6d06:a691:4a6d:84c6:b886:6e48:f44e fe80::d47e:3b7d:8adc:4dd3
                            • H Habedere
                              Los gings hiermit:
                              iobroker host this
                              iobroker start
                              + instance is alive
                              Skript v.2023-04-16
                              *** BASE SYSTEM ***
                              Docker          : false
                              Release:        11
                              Codename:       bullseye
                              VERSION_ID="11"
                              ID=debian
                              CPU threads: 4
                              Raspberry only:
                              throttled=0x0
                              temp=55.3'C
                              volt=1.3000V
                                               RTC time: n/a
                                            NTP service: active
                                        RTC in local TZ: no
                              nulu
                              /home/nulu
                              X-Server:       false
                              Desktop:
                              Terminal:       tty
                              *** MEMORY ***
                              Swap:            99M          0B         99M
                                        909 M total memory
                                        150 M used memory
                                        233 M active memory
                                        540 M free memory
                                         18 M buffer memory
                                        199 M swap cache
                                         99 M total swap
                                          0 M used swap
                                         99 M free swap
                              Raspberry only:
                              oom events: 0
                              *** FILESYSTEM ***
                              /var:
                              644M    /var/
                              271M    /var/lib
                              196M    /var/cache
                              191M    /var/cache/apt
                              124M    /var/lib/mysql
                              /usr/bin/npm            9.5.1
                              /usr/bin/npx            9.5.1
                              nodejs:
                                Version table:
                              ioBroker Status
                              Objects type: jsonl
                              States  type: jsonl
                              admin:          6.3.5
                              Adapter State
                              + instance is alive
                              Objects and States
                              Objects:        9496
                              States:         83
                              Pending Updates: 0
                              #414
                              @habedere
                              iob start admin
                              liefert?
                              H 2 Antworten Letzte Antwort
                                @habedere
                                iob start admin
                                liefert?
                                Habedere
                                #415
                                @thomas-braun sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                                iob start admin
                                Garnichts
                                • H Habedere
                                  iob start admin
                                  Garnichts
                                  #416
                                  @habedere
                                  Starte die Kiste komplett durch.
                                  H 1 Antwort Letzte Antwort
                                    @habedere
                                    Habedere
                                    #417
                                    Reboot mehrmals durchgeführt - keine Reaktion auf den Befehl
                                    • H Habedere
                                      Los gings hiermit:
                                      iobroker host this
                                      iobroker start
                                      + instance is alive
                                      Skript v.2023-04-16
                                      *** BASE SYSTEM ***
                                      Docker          : false
                                      Release:        11
                                      Codename:       bullseye
                                      VERSION_ID="11"
                                      ID=debian
                                      CPU threads: 4
                                      Raspberry only:
                                      throttled=0x0
                                      temp=55.3'C
                                      volt=1.3000V
                                                       RTC time: n/a
                                                    NTP service: active
                                                RTC in local TZ: no
                                      nulu
                                      /home/nulu
                                      X-Server:       false
                                      Desktop:
                                      Terminal:       tty
                                      *** MEMORY ***
                                      Swap:            99M          0B         99M
                                                909 M total memory
                                                150 M used memory
                                                233 M active memory
                                                540 M free memory
                                                 18 M buffer memory
                                                199 M swap cache
                                                 99 M total swap
                                                  0 M used swap
                                                 99 M free swap
                                      Raspberry only:
                                      oom events: 0
                                      *** FILESYSTEM ***
                                      /var:
                                      644M    /var/
                                      271M    /var/lib
                                      196M    /var/cache
                                      191M    /var/cache/apt
                                      124M    /var/lib/mysql
                                      /usr/bin/npm            9.5.1
                                      /usr/bin/npx            9.5.1
                                      nodejs:
                                        Version table:
                                      ioBroker Status
                                      Objects type: jsonl
                                      States  type: jsonl
                                      admin:          6.3.5
                                      Adapter State
                                      + instance is alive
                                      Objects and States
                                      Objects:        9496
                                      States:         83
                                      Pending Updates: 0
                                      crunchipC Offline
                                      crunchipC Offline
                                      #418
                                      @habedere sagte in [HowTo] ioBroker Restore unter Linux durchführen:
                                      Objects type: jsonl States type: jsonl
                                      https://www.iobroker.net/#de/documentation/config/redis.md
                                      ist zwar eingeschaltet aber läuft nicht
                                        Habedere
                                        #419
                                        @crunchip
                                        Du meinst redis?
                                        Dachte schon:
                                        nulu@raspberrypi:~ $ sudo systemctl status redis-server
                                        sudo systemctl enable redis-server
                                        ● redis-server.service - Advanced key-value store
                                             Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor >
                                             Active: active (running) since Tue 2023-04-25 17:06:50 CEST; 12min ago
                                               Docs: http://redis.io/documentation,
                                                     man:redis-server(1)
                                           Main PID: 544 (redis-server)
                                             Status: "Ready to accept connections"
                                              Tasks: 5 (limit: 779)
                                                CPU: 3.902s
                                             CGroup: /system.slice/redis-server.service
                                                     └─544 /usr/bin/redis-server 127.0.0.1:6379
                                        Apr 25 17:06:49 raspberrypi systemd[1]: Starting Advanced key-value store...
                                        Apr 25 17:06:50 raspberrypi systemd[1]: Started Advanced key-value store.
                                        lines 1-14/14 (END)...skipping...
                                             Loaded: loaded (/lib/systemd/system/redis-server.service; enabled; vendor preset: enabled)
                                                     man:redis-server(1)
                                                CPU: 3.902s
                                        Irgendwas passt da nicht - läuft ioBroker nun oder nicht?
                                        nulu@raspberrypi:~ $ iobroker status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        • H Habedere
                                          @crunchip
                                          Du meinst redis?
                                          Dachte schon:
                                                       man:redis-server(1)
                                                  CPU: 3.902s
                                                       man:redis-server(1)
                                                  CPU: 3.902s
                                          Objects type: jsonl
                                          States  type: jsonl
                                          crunchipC Offline
                                          crunchipC Offline
                                          #420
                                          @habedere ja dein iobroker läuft, aus deinem Beitrag weiter oben aber der admin nicht
                                          redis ist zwar installiert aber nicht in Benutzung, da du aktuell jsonl verwendest, wenn du vorher redis verwendet hast musst du auch wieder umstellen auf redis
                                          da laufen scheinbar mehrere Prozesse
