  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • ub.privatU ub.privat
    mariadb-client-10.0 mariadb-client-10.3 mariadb-client-core-10.0 mariadb-client-core-10.3
    Thomas BraunT Offline
    #1581
    @ub-privat
    Und auf der anderen Kiste läuft welche Version? Ich würde da möglichst nah herangehen mit der Nummer.
    ub.privatU 1 Antwort Letzte Antwort
      @ub-privat
      ub.privatU Offline
      ub.privatU Offline
      ub.privat
      #1582
      Server-Version: 10.3.29-MariaDB - Source distribution
        #1583
        @ub-privat
        sudo apt install mariadb-client-10.3
        ub.privatU 2 Antworten Letzte Antwort
          @ub-privat
          ub.privatU Offline
          ub.privatU Offline
          ub.privat
          #1584
          das System noch einmal neu gebootet. Nun nochmals manuell das Backup anstoßen?
            @ub-privat
            ub.privatU Offline
            ub.privatU Offline
            ub.privat
            schrieb am zuletzt editiert von ub.privat
            #1585
            Schaut schon ein wenig "besser" aus:
            Started iobroker ...
            [DEBUG] [mount] - noserverino option: false
            [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Uwe,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.20/300_SMARTHOME/310_BACKUP/IOB_1 /opt/iobroker/backups"
            [DEBUG] [mount] - mount successfully completed
            [DEBUG] [mount] - done
            [DEBUG] [iobroker] - host.raspberrypi 15818 states saved
            [DEBUG] [iobroker] - host.raspberrypi 18629 objects saved
            [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz
            [DEBUG] [iobroker] - done
            [DEBUG] [influxDB] - InfluxDB-Backup started ...
            [DEBUG] [influxDB] - Start InfluxDB Backup ...
            [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
            [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz
            [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
            [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
            [DEBUG] [influxDB] - InfluxDB-Backup for is finish
            [DEBUG] [influxDB] - done
            [DEBUG] [mysql] - MySql-Backup started ...
            [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u ioBroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.sql
            mysqldump: Got error: 1045: "Access denied for user 'ioBroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
            [DEBUG] [historyDB] - compress from historyDB started ...
            [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
            [DEBUG] [grafana] - Start Grafana Backup ...
            [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
            [DEBUG] [grafana] - Created dashboard directory
            [DEBUG] [grafana] - Created dashboards_manually_restore directory
            [DEBUG] [grafana] - Created datasource directory
            [DEBUG] [grafana] - start Grafana request ...
            [DEBUG] [grafana] - Grafana is available ... Status: 200
            [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
            [DEBUG] [grafana] - start Grafana backup compress ...
            [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
            [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
            [DEBUG] [grafana] - cannot found Grafana Backup files
            [DEBUG] [grafana] - done
            [DEBUG] [cifs] - done
            [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz...
            [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz...
            [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.tar.gz" not found
            [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_12_14-18_36_58_backupiobroker.tar.gz" not found
            [DEBUG] [googledrive] - done
            [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
            [DEBUG] [clean] - done
            [DEBUG] [email] - done
            [DEBUG] [historyHTML] - new history html values created
            [DEBUG] [historyHTML] - done
            [DEBUG] [historyJSON] - new history json values created
            [DEBUG] [historyJSON] - done
            [DEBUG] [umount] - mount activ, umount is started ...
            [DEBUG] [umount] - umount successfully completed
            [DEBUG] [umount] - done
            [EXIT] 0
            Nun kommt diese Fehlermeldung:
            InFlux DB und ioBroker - Backup wurden geschrieben! Freu...
            Jetzt nich die mySQL hinbekommen!
            Ich verstehe aber nicht, warum jetzt die GZ-Datei geschrieben wird!?
              [EXIT] 0
              #1586
              @ub-privat
              Der User muss dann auf dem Server auch angelegt sein. Sonst darf der natürlich auch keinen mysqldump ausführen.
                @ub-privat
                ub.privatU Offline
                ub.privatU Offline
                ub.privat
                #1587
                ich muss nun in der MariaDB den Fritzbox-User mit dem entsprechenden Passwort anlegen/einrichten?
                Puuh, da muss ich mal schauen, wie ich das hinbekomme...
                wäre dies die korrekte Vorgehensweise?
                https://forum.iobroker.net/topic/3327/mariadb-auf-diskstation-als-datenbank-für-flot
                  #1588
                  @ub-privat
                  Keine Ahnung von mariadb.
                    @ub-privat
                    ub.privatU Offline
                    ub.privatU Offline
                    ub.privat
                    #1589
                    OK, Schade.
                    Aktuell sind diese User eingerichtet:
                    aber ist denn 'ioBroker'@'raspberrypi-3.fritz.box' nicht gleich der Benutzer "iobroker"?
                    Wie gesagt, alles "learning by doing" und die grenzenlose Forumshilfe!
                      @ub-privat
                      ub.privatU Offline
                      ub.privatU Offline
                      ub.privat
                      #1590
                      dann werede ich erst einmal die iobroker- und influx-Backups beobachten!
                      Vielen Dank für deine Hilfe! DANKE.
                        OK, Schade.
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #1591
                        gelöscht
                        • mickymM mickym
                          gelöscht
                          mickymM Offline
                          mickymM Offline
                          mickym
                          #1592
                          @ub-privat Ich versteh das alles ehrlich gesagt nicht. Du gibst doch in dem SQL-Adapter einen Benutzer an und den musst Du in der mySQL (mariaDB) anlegen. Das hat doch nichts mit irgendwelchen Domänennamen etc. zu tun.
                          Bei mir heißt der auch zufälligerweise iobroker:
                          Im backitup Adapter musst Du den mySQL Benutzernamen dann ja auch nochmal eintragen. Verstehe momentan nicht, wo das Problem liegt.
                          • mickymM mickym
                            ub.privatU Offline
                            ub.privatU Offline
                            ub.privat
                            #1593
                            @mickym
                            die Einträge habe ich sowohl im SQL und Backitup-Adapter korrekt vorgenommen.
                            In der MariaDB ist er auch angelegt --> siehe Bild weiter oben.
                            Adapter sind auch korrekt = grün.
                            Wo ist dein Bildauschnitt her?
                            mickymM Thomas BraunT 2 Antworten Letzte Antwort
                              @mickym
                              mickymM Offline
                              mickymM Offline
                              mickym
                              #1594
                              @ub-privat Ich habe mir für Windows HeidiSQL installiert - damit kann ich die mariaDB easy mit der GUI administrieren. ;)
                                @mickym
                                #1595
                                @ub-privat
                                ioBroker (im Backitup-Adapter) ist nicht iobroker (auf der Maria)
                                • mickymM mickym
                                  ub.privatU Offline
                                  ub.privatU Offline
                                  ub.privat
                                  #1596
                                  @mickym
                                  Da muss ich nch eine Menge lernen!
                                    @ub-privat
                                    ub.privatU Offline
                                    ub.privatU Offline
                                    ub.privat
                                    #1597
                                    OK, nun ist der Faden weg! Das verstehe ich nicht... sorry.
                                      @mickym
                                      mickymM Offline
                                      mickymM Offline
                                      mickym
                                      #1598
                                      @ub-privat Aber ich glaube @Thomas-Braun hat mit Luchs Augen entdeckt, dass Du den iobroker im backitup Adapter falsch geschrieben hast. ;)
                                      Thomas BraunT ub.privatU 2 Antworten Letzte Antwort
                                      • mickymM mickym
                                        #1599
                                        @mickym
                                        Ja. Ich hab meine Nickelbrille extra poliert.
                                        • mickymM mickym
                                          ub.privatU Offline
                                          ub.privatU Offline
                                          ub.privat
                                          #1600
                                          @mickym
                                          ioBroker habe ich schnell in iobroker korrigiert! Fehlermeldung bleibt aber identisch!
                                          [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u iobroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-19_19_30_backupiobroker.sql
                                          mysqldump: Got error: 1045: "Access denied for user 'iobroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
