  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 2.7m Aufrufe 113 Beobachtet
  • NegaleinN Negalein
    @simatec
    bemerkte gerade, dass seit 10 Tagen Lokal und Dropbox nicht gesichert wird.
    FTP funktioniert problemlos.
    	Zeile 81633: 2021-10-25 23:00:43.355  - error: backitup.0 (713) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    	Zeile 81634: 2021-10-25 23:00:43.359  - error: backitup.0 (713) unhandled promise rejection: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
    	Zeile 81635: 2021-10-25 23:00:43.359  - error: backitup.0 (713) Error: ENOENT: no such file or directory, open '/opt/iobroker/backups/tmpScripts/script.json'
    	Zeile 81636: 2021-10-25 23:00:43.359  - error: backitup.0 (713) Exception-Code: ENOENT: ENOENT: no such file or direct2021-10-25 23:00:43.956  - error: host.ioBroker Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
    	Zeile 81638: 2021-10-25 23:00:43.956  - error: host.ioBroker instance system.adapter.backitup.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    	Zeile 81639: 2021-10-25 23:00:43.956  - info: host.ioBroker Restart adapter system.adapter.backitup.0 because enabled
    	Zeile 81719: 2021-10-25 23:01:14.015  - info: host.ioBroker instance system.adapter.backitup.0 started with pid 10779
    	Zeile 81769: 2021-10-25 23:01:15.168  - info: backitup.0 (10779) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.17.1, js-controller: 3.3.18
    	Zeile 81771: 2021-10-25 23:01:15.198  - info: backitup.0 (10779) [iobroker] backup was activated at 23:00 every 1 day(s)
    	Zeile 81780: 2021-10-25 23:01:15.231  - info: backitup.0 (10779) [ccu] backup was activated at 01:30 every 3 day(s)
    	Zeile 84595: 2021-10-25 23:37:18.362  - info: host.ioBroker stopInstance system.adapter.backitup.0 (force=false, process=true)
    	Zeile 84695: 2021-10-25 23:37:18.445  - info: backitup.0 (10779) cleaned everything up...
    	Zeile 84888: 2021-10-25 23:37:18.699  - info: backitup.0 (10779) Got terminate signal TERMINATE_YOURSELF
    	Zeile 84961: 2021-10-25 23:37:18.789  - info: backitup.0 (10779) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    	Zeile 84985: 2021-10-25 23:37:18.944  - info: host.ioBroker stopInstance system.adapter.backitup.0 send kill signal
    	Zeile 85076: 2021-10-25 23:37:20.509  - info: host.ioBroker instance system.adapter.backitup.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
    	Zeile 85974: 2021-10-25 23:38:58.260  - info: host.ioBroker instance system.adapter.backitup.0 started with pid 716
    	Zeile 85980: 2021-10-25 23:38:59.071  - info: backitup.0 (716) starting. Version 2.2.1 in /opt/iobroker/node_modules/iobroker.backitup, node: v14.17.1, js-controller: 3.3.18
    	Zeile 85981: 2021-10-25 23:38:59.099  - info: backitup.0 (716) [iobroker] backup was activated at 23:00 every 1 day(s)
    	Zeile 85982: 2021-10-25 23:38:59.123  - info: backitup.0 (716) [ccu] backup was activated at 01:30 every 3 day(s)
    simatecS Offline
    simatecS Offline
    simatec
    #1541
    @negalein Bitte mal den Debuglog posten
    • Besuche meine Github Seite
    • HowTo Restore ioBroker
    • simatecS Offline
      simatecS Offline
      simatec
      #1542
      Ab sofort steht auf Github und in Kürze auch im latest die finale Version 2.2.2 zur Verfügung.
      Diese wird die nächsten Tage auch in Stable gehen.
      Changelog
      2.2.2 (06.11.2021)
      • (simatec) Fix CCU option to use self-signed certificates
      • (simatec) Fix Config Menu
      • (simatec) dependabot added
      • (simatec) small Bugfixes
      Dr. BakteriusD 1 Antwort Letzte Antwort
      • simatecS simatec
        Changelog
        2.2.2 (06.11.2021)
        Dr. BakteriusD Offline
        Dr. Bakterius
        #1543
        @simatec sagte in Test Adapter Backitup v2.2.x:
        Wird darin auch der Fehler behoben sein, dass nach erfolglosem Mount solange keine Backups erfolgen bis der Adapter neu gestartet wird?
          simatecS Offline
          simatecS Offline
          simatec
          #1544
          @dr-bakterius Gibt es dazu ein Issue?
          • simatecS simatec
            Dr. Bakterius
            #1545
            Keine Ahnung. Aber -> Du hattest geschrieben
              simatecS Offline
              simatecS Offline
              simatec
              #1546
              @dr-bakterius Ist bisher nicht eingeflossen ... Leider verliert man hier im Forum den Überblick.
              Mache mal bitte ein Issue mit genauer Fehlerbeschreibung auf.
              Dr. BakteriusD ? 2 Antworten Letzte Antwort
              • simatecS simatec
                Dr. Bakterius
                #1547
                Ich hoffe das passt so (https://github.com/simatec/ioBroker.backitup/issues/567)
                • simatecS simatec
                  #1548
                  @simatec
                  Hallo und erst einmal vielen Dank für die kontinuierliche Arbeit und Verbesserung des Backitup-Adapters.
                  Angestoßen durch Forumsbeiträge aber auch eigene Nutzung wäre für eine Standardbackuplösung wie Backitup eine kleine Ergänzung wirklich toll.
                  Es wird sehr viel gesichert, aber ich habe auch immer ein paar individuelle Dinge wie Skripte auf meinem System abgelegt die ich mit dem IOBroker ausführe und nutze. Hierzu und auch für viele weitere Fälle kann man nicht zusätzlich eine Rubrick in "Was wird gesichert" implementieren um ein Custom Folder anzugeben, was mitgesichert wird und dann natürlich bei einem Restore auch wieder da ist?
                  Möchte dazu ungern Ordner missbrauchen wo das derzeit über Funktionen wie zB Zigbee passiert.
                  Denkst Du/Ihr das würde Sinn machen und kann ergänzt werden?
                  Besten Dank und Grüße!
                    @simatec
                    simatecS Offline
                    simatecS Offline
                    simatec
                    #1549
                    @pete0815
                    Wenn du den History Adapter nicht nutzt, kannst du die Backup Option dafür zweckentfremden.
                    ? 1 Antwort Letzte Antwort
                    • simatecS simatec
                      @pete0815
                      #1550
                      @simatec
                      Thx. Habe ihn mal unabsichtlich zweckentfremdet und den Pfad etwas zu weit gefasst. Hieraus ist ggf. auch mein Verständnis "gewachsen" wie nützlich das doch ist. Nutze aber history und der Fehler im Pfad ist korrigiert :)
                      Könnte jetzt meine individuellen Skripte dort speichern und sie werden mit gesichert, aber gehören sie dahin? Glaube nein und hätte bei individuellen Pfaden eher an das home-Verzeichnes bzw. Unterordner darin gedacht.
                        @simatec
                        simatecS Offline
                        simatecS Offline
                        simatec
                        #1551
                        @pete0815 Das ist so nicht geplant, da wir der Meinung sind, dass Backitup bereits schon eher zu viel an Backup Optionen anbietet, die schon weit über iobroker hinausgehen
                        • David G.D Online
                          David G.D Online
                          David G.
                          #1552
                          Ich habe mal eine Frage zum Datenpunkt
                          backitup.0.history.iobrokerSuccess
                          Ab wann sagt mir dieser, dass das letzte Backup nicht erfolgreich war?
                          Heute ist der FTP-Speicher auf meiner FritzBox vollgelaufen.
                          Per Telegram habe ich eine Meldung bekommen, dass das Backup nicht komplett war.
                          Der history Datenpunkt sagt jedoch, dass alles gut ist.
                          • F Offline
                            firebowl
                            #1553
                            Ich versuche gerade meinen ioBroker inkl. influxdb und Grafana von meinem Raspi auf eine virtuelle Ubuntu Instanz auf meinem NUC umzuziehen.
                            Bis jetzt hab ich eine recht leere ioBroker Instanz und influxdb installiert. Leider scheitere ich beim Restore des influxdb Backups via backitup Adapter.
                            Ich habe die Einstellungen 1:1 übernommen.
                            Über "Wiederherstellen" und "Sicherungen Abrufen" werden mir auch die ganzen Sicherungen angezeigt, die auf meinem NAS (OMV) liegen.
                            Wenn ich jetzt die influxdb Sicherung auswähle und wiederherstellen möchte bekomme ich die Fehlermeldung (hab ich auch weiter oben im Thread gesehen):
                            Error: Command failed: sudo mount -t cifs -o username=iobroker,password='xxxxxx',rw,file_mode=0777,dir_mode=0777 //raspinas/Backup/ioBroker /opt/iobroker/backupsmount error(16): Device or resource busyRefer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
                            umount: /opt/iobroker/backups: not mounted.
                            [influxDB] Error: EPERM: operation not permitted, utime '/opt/iobroker/backups/influxDBtmp/'
                            • F firebowl
                              simatecS Offline
                              simatecS Offline
                              simatec
                              #1554
                              @firebowl Du hast keine vollen Schreibrechte auf deinem NAS. Backitup legt für den restore ein tmp Ordner an, in dem das Influx Backup entpackt und von da aus wiederhergestellt wird.
                              Und hier scheitern deine Rechte auf dem NAS
                              Du kannst dich laut Log garnicht mit dem NAS verbinden.
                              Hast du cifs-utils installiert und wie sehen deine Einstellungen auf dem NAS aus?
                              F 1 Antwort Letzte Antwort
                              • simatecS simatec
                                firebowl
                                #1555
                                @simatec Hmm, kann eigentlich nicht sein. Hab gerade zum Testen von einer Windowskiste aus das Verzeichnis gemounted mit den gleichen Credentials die auch der backitup Adapter nutzt. So kann ich dort Dateien erstellen und löschen, auch im influxDBtmp Ordner.
                                Verstehe nicht so ganz warum die Instanz vom Raspi aus dort schreiben kann aber die Instanz vom NUC aus nicht.
                                simatecS 2 Antworten Letzte Antwort
                                • F firebowl
                                  simatecS Offline
                                  simatecS Offline
                                  simatec
                                  #1556
                                  @firebowl cifs-utils installiert?
                                  • F firebowl
                                    simatecS Offline
                                    simatecS Offline
                                    simatec
                                    #1557
                                    @firebowl sagte in Test Adapter Backitup v2.2.x:
                                    Nutzt du auf dem NUC Proxmox? Wenn ja VM oder LXC?
                                    • simatecS simatec
                                      firebowl
                                      #1558
                                      @simatec Ähh sorry, ja ist drauf.
                                      • simatecS simatec
                                        firebowl
                                        #1559
                                        @simatec Proxmox und VM weil ich bei LXC den ConBee II nicht sauber zum laufen bekomm. ;)
                                        • F firebowl
                                          simatecS Offline
                                          simatecS Offline
                                          simatec
                                          #1560
                                          @firebowl Laut der Log Ausgabe würde ich daruf tippen, dass dein Mount-Point bereits belegt ist.
                                          Also einfach mal alle Systeme inkl. NAS neustarten
