  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 3.0m Aufrufe 113 Beobachtet
  • ub.privatU ub.privat
    Schaut schon ein wenig "besser" aus:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Uwe,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.20/300_SMARTHOME/310_BACKUP/IOB_1 /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 15818 states saved
    [DEBUG] [iobroker] - host.raspberrypi 18629 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    [DEBUG] [mysql] - MySql-Backup started ...
    [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u ioBroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.sql
    mysqldump: Got error: 1045: "Access denied for user 'ioBroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
    [DEBUG] [historyDB] - compress from historyDB started ...
    [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
    [DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
    [DEBUG] [grafana] - start Grafana backup compress ...
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [DEBUG] [grafana] - cannot found Grafana Backup files
    [DEBUG] [grafana] - done
    [DEBUG] [cifs] - done
    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz...
    [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz...
    [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.tar.gz" not found
    [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_12_14-18_36_58_backupiobroker.tar.gz" not found
    [DEBUG] [googledrive] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [email] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    Nun kommt diese Fehlermeldung:
    InFlux DB und ioBroker - Backup wurden geschrieben! Freu...
    Jetzt nich die mySQL hinbekommen!
    Ich verstehe aber nicht, warum jetzt die GZ-Datei geschrieben wird!?
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #1586
    @ub-privat
    Der User muss dann auf dem Server auch angelegt sein. Sonst darf der natürlich auch keinen mysqldump ausführen.
    ub.privatU 1 Antwort Letzte Antwort
      @ub-privat
      ub.privatU
      ub.privatU
      ub.privat
      schrieb am zuletzt editiert von ub.privat
      #1587
      ich muss nun in der MariaDB den Fritzbox-User mit dem entsprechenden Passwort anlegen/einrichten?
      Puuh, da muss ich mal schauen, wie ich das hinbekomme...
      wäre dies die korrekte Vorgehensweise?
      https://forum.iobroker.net/topic/3327/mariadb-auf-diskstation-als-datenbank-für-flot
        Thomas BraunT
        Thomas BraunT
        #1588
        @ub-privat
        Keine Ahnung von mariadb.
        ub.privatU 2 Antworten Letzte Antwort
          @ub-privat
          ub.privatU
          ub.privatU
          ub.privat
          #1589
          OK, Schade.
          Aktuell sind diese User eingerichtet:
          aber ist denn 'ioBroker'@'raspberrypi-3.fritz.box' nicht gleich der Benutzer "iobroker"?
          Wie gesagt, alles "learning by doing" und die grenzenlose Forumshilfe!
            @ub-privat
            ub.privatU
            ub.privatU
            ub.privat
            #1590
            dann werede ich erst einmal die iobroker- und influx-Backups beobachten!
            Vielen Dank für deine Hilfe! DANKE.
              OK, Schade.
              mickymM
              mickymM
              mickym
              #1591
              gelöscht
              • mickymM mickym
                gelöscht
                mickymM
                mickymM
                mickym
                #1592
                @ub-privat Ich versteh das alles ehrlich gesagt nicht. Du gibst doch in dem SQL-Adapter einen Benutzer an und den musst Du in der mySQL (mariaDB) anlegen. Das hat doch nichts mit irgendwelchen Domänennamen etc. zu tun.
                Bei mir heißt der auch zufälligerweise iobroker:
                Im backitup Adapter musst Du den mySQL Benutzernamen dann ja auch nochmal eintragen. Verstehe momentan nicht, wo das Problem liegt.
                • mickymM mickym
                  ub.privatU
                  ub.privatU
                  ub.privat
                  #1593
                  @mickym
                  die Einträge habe ich sowohl im SQL und Backitup-Adapter korrekt vorgenommen.
                  In der MariaDB ist er auch angelegt --> siehe Bild weiter oben.
                  Adapter sind auch korrekt = grün.
                  Wo ist dein Bildauschnitt her?
                  mickymM Thomas BraunT 2 Antworten Letzte Antwort
                    @mickym
                    mickymM
                    mickymM
                    mickym
                    #1594
                    @ub-privat Ich habe mir für Windows HeidiSQL installiert - damit kann ich die mariaDB easy mit der GUI administrieren. ;)
                      @mickym
                      Thomas BraunT
                      Thomas BraunT
                      #1595
                      @ub-privat
                      ioBroker (im Backitup-Adapter) ist nicht iobroker (auf der Maria)
                      • mickymM mickym
                        ub.privatU
                        ub.privatU
                        ub.privat
                        #1596
                        @mickym
                        Da muss ich nch eine Menge lernen!
                          @ub-privat
                          ub.privatU
                          ub.privatU
                          ub.privat
                          #1597
                          OK, nun ist der Faden weg! Das verstehe ich nicht... sorry.
                            @mickym
                            mickymM
                            mickymM
                            mickym
                            #1598
                            @ub-privat Aber ich glaube @Thomas-Braun hat mit Luchs Augen entdeckt, dass Du den iobroker im backitup Adapter falsch geschrieben hast. ;)
                            Thomas BraunT ub.privatU 2 Antworten Letzte Antwort
                            • mickymM mickym
                              Thomas BraunT
                              Thomas BraunT
                              #1599
                              @mickym
                              Ja. Ich hab meine Nickelbrille extra poliert.
                              • mickymM mickym
                                ub.privatU
                                ub.privatU
                                ub.privat
                                #1600
                                @mickym
                                ioBroker habe ich schnell in iobroker korrigiert! Fehlermeldung bleibt aber identisch!
                                [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u iobroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-19_19_30_backupiobroker.sql
                                mysqldump: Got error: 1045: "Access denied for user 'iobroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
                                  @mickym
                                  mickymM
                                  mickymM
                                  mickym
                                  #1601
                                  @ub-privat Hast Du den Port absichtlich verbogen - normalerweise ist der 3306
                                  EDIT: 3306 nicht 3006
                                  • mickymM mickym
                                    ub.privatU
                                    ub.privatU
                                    ub.privat
                                    #1602
                                    @mickym
                                    Nein definitv nicht. Werde ich auch noch einmal probieren.
                                      @mickym
                                      mickymM
                                      mickymM
                                      mickym
                                      #1603
                                      @ub-privat sagte in Test Adapter Backitup v2.2.x:
                                      @mickym
                                      3306 nicht 3006
                                      • mickymM mickym
                                        @mickym
                                        3306 nicht 3006
                                        ub.privatU
                                        ub.privatU
                                        ub.privat
                                        #1604
                                        @mickym
                                        @Thomas-Braun
                                        nun scheint es zu funktionieren - manuell!
                                        Alle Datein erscheinen und sind nicht mehr 0kB groß.
                                        Habe in der DB noch einmal das Kennwort neu eingegeben und auf Groß- und Kleinschreibung geachtet.
                                        Jetzt kommt diese Meldung:
                                        [ERROR] [mysql] - [IGNORED] Error: ENOENT: no such file or directory, lstat '/opt/iobroker/backups/mysql_2021_12_14-19_27_16_backupiobroker.sql'
                                        Damit kann ich für heute leben, schaue, ob die automatische Sicherung funktioniert.
                                        Erst einmal allen vielen Dank!
                                          @mickym
                                          @Thomas-Braun
                                          mickymM
                                          mickymM
                                          mickym
                                          #1605
                                          @ub-privat Diese Fehlermeldungen verschwinden von alleine - damit versucht der Backit-Up Adapter ältere Sicherungsdateien zu löschen. Vielleicht hast Du die mit 0 kB selbst gelöscht. ;)
                                          33.2k
                                          84.3k
