  4. Test Adapter ioBroker.backitup v3.1.x
backitupbackitup backupccuhistorymysqlredisrestorerestore backup
2.8k Beiträge 170 Kommentatoren 3.0m Aufrufe 113 Beobachtet
  • ub.privatU ub.privat
    @simatec
    @Thomas-Braun
    Nachdem ich nun die fast 1500 Beiträge gelesen/überflogen habe, muss ich um eure Unterstützung bitten.
    Als ich den Adapter eingerichtet habe und einmalig manuell das Backup erstellt wurde, sah alles super aus! Freude war groß...
    3 Tage mit viel probieren sind vorbei, die automatischen Backups liefern nur Datein mit einer Größe von 0kB ???
    So schaut der Vorgang aus:
    Started iobroker ...
    [DEBUG] [mount] - noserverino option: false
    [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=Uwe,password=****,rw,file_mode=0777,dir_mode=0777,vers=3.1.1 //192.168.178.20/300_SMARTHOME/310_BACKUP/IOB_1 /opt/iobroker/backups"
    [DEBUG] [mount] - mount successfully completed
    [DEBUG] [mount] - done
    [DEBUG] [iobroker] - host.raspberrypi 15813 states saved
    [DEBUG] [iobroker] - host.raspberrypi 18592 objects saved
    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_14-16_59_04_backupiobroker.tar.gz
    [DEBUG] [iobroker] - done
    [DEBUG] [influxDB] - InfluxDB-Backup started ...
    [DEBUG] [influxDB] - Start InfluxDB Backup ...
    [DEBUG] [influxDB] - InfluxDB Backup tmp directory created
    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_12_14-16_59_23_backupiobroker.tar.gz
    [DEBUG] [influxDB] - Try deleting the InfluxDB tmp directory
    [DEBUG] [influxDB] - InfluxDB tmp directory was successfully deleted
    [DEBUG] [influxDB] - InfluxDB-Backup for is finish
    [DEBUG] [influxDB] - done
    [DEBUG] [mysql] - MySql-Backup started ...
    [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u ioBroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-16_59_27_backupiobroker.sql
    /bin/sh: 1: mysqldump: not found
    [DEBUG] [historyDB] - compress from historyDB started ...
    [ERROR] [historyDB] - [IGNORED] Backitup cannot found source "undefined" for compress!
    [DEBUG] [grafana] - Start Grafana Backup ...
    [DEBUG] [grafana] - Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Created dashboard directory
    [DEBUG] [grafana] - Created dashboards_manually_restore directory
    [DEBUG] [grafana] - Created datasource directory
    [DEBUG] [grafana] - start Grafana request ...
    [DEBUG] [grafana] - Grafana is available ... Status: 200
    [DEBUG] [grafana] - Error on Grafana Dashoard Request: Error: Request failed with status code 401
    [DEBUG] [grafana] - start Grafana backup compress ...
    [DEBUG] [grafana] - Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
    [DEBUG] [grafana] - Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
    [DEBUG] [grafana] - cannot found Grafana Backup files
    [DEBUG] [grafana] - done
    [DEBUG] [ftp] - FTP connected.
    [DEBUG] [ftp] - Send iobroker_2021_12_14-16_59_04_backupiobroker.tar.gz
    [DEBUG] [ftp] - Send influxDB_2021_12_14-16_59_23_backupiobroker.tar.gz
    [DEBUG] [ftp] - Send mysql_2021_12_14-16_59_27_backupiobroker.tar.gz
    [ERROR] [ftp] - File "/opt/iobroker/backups/mysql_2021_12_14-16_59_27_backupiobroker.tar.gz" not found
    [DEBUG] [ftp] - Send historyDB_2021_12_14-16_59_27_backupiobroker.tar.gz
    [ERROR] [ftp] - File "/opt/iobroker/backups/historyDB_2021_12_14-16_59_27_backupiobroker.tar.gz" not found
    [DEBUG] [ftp] - done
    [DEBUG] [cifs] - done
    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_12_14-16_59_04_backupiobroker.tar.gz...
    [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_12_14-16_59_23_backupiobroker.tar.gz...
    [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/mysql_2021_12_14-16_59_27_backupiobroker.tar.gz" not found
    [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_12_14-16_59_27_backupiobroker.tar.gz" not found
    [DEBUG] [googledrive] - done
    [ERROR] [clean] - Backup files not deleted from /opt/iobroker/backups because some errors.
    [DEBUG] [clean] - done
    [DEBUG] [email] - done
    [DEBUG] [historyHTML] - new history html values created
    [DEBUG] [historyHTML] - done
    [DEBUG] [historyJSON] - new history json values created
    [DEBUG] [historyJSON] - done
    [DEBUG] [umount] - mount activ, umount is started ...
    [DEBUG] [umount] - umount successfully completed
    [DEBUG] [umount] - done
    [EXIT] 0
    Bei allen Sicherungsquellen wird das Backup mit 0kB abgelegt.
    Hier sieht man, am 10.12. lief alles super, konnte auch einwandfrei rückspielen. An den anderen Tagen nur 0kB Datein.
    Mir ist bewußt, dass einige ERROR's stehen, aber leider für mich nicht verständlich, daher meine Bitte nach Hilfe!
    Danke schon mal vorab.
    Thomas BraunT
    Thomas BraunT
    Most Active Developer
    #1577
    @ub-privat sagte in Test Adapter Backitup v2.2.x:
    mysqldump not found
    Da fehlt wohl was. Welche Datenbank? mariadb? mariadb-client dann installiert?
    Dann würde ich auch nicht per ftp agieren sondern mit smb/cifs oder nfs.
    ub.privatU 1 Antwort Letzte Antwort
      mysqldump not found
      ub.privatU
      ub.privatU
      ub.privat
      #1578
      Danke für die schnelle Antwort.
      Ja eine MariaDB ist auf der Syno DS216P installiert. Diese wird auch aktiv angesprochen.
      Einen Client habe ich auf dem Raspi definitiv nicht installiert (weiß leider nicht wie!).
      FTP habe ich nur als alternitves Sicherungsziel verwendet, kann also kurzfrisitg weg.
        Thomas BraunT
        Thomas BraunT
        #1579
        @ub-privat
        Auf dem Raspi muss ein Paket wie
        mariadb-client-XXX
        installiert sein. Wobei XXX für die Version steht.
        Per
        sudo apt update
        apt policy mariadb-client<TAB-Taste><TAB-Taste>
        kannst du schauen was da verfügbar ist.
          @ub-privat
          mariadb-client-XXX
          Per
          sudo apt update
          ub.privatU
          ub.privatU
          ub.privat
          #1580
          mariadb-client-10.0 mariadb-client-10.3 mariadb-client-core-10.0 mariadb-client-core-10.3
            Thomas BraunT
            Thomas BraunT
            #1581
            @ub-privat
            Und auf der anderen Kiste läuft welche Version? Ich würde da möglichst nah herangehen mit der Nummer.
              @ub-privat
              ub.privatU
              ub.privatU
              ub.privat
              #1582
              Server-Version: 10.3.29-MariaDB - Source distribution
                Thomas BraunT
                Thomas BraunT
                #1583
                @ub-privat
                sudo apt install mariadb-client-10.3
                ub.privatU 2 Antworten Letzte Antwort
                  @ub-privat
                  ub.privatU
                  ub.privatU
                  ub.privat
                  #1584
                  das System noch einmal neu gebootet. Nun nochmals manuell das Backup anstoßen?
                    @ub-privat
                    ub.privatU
                    ub.privatU
                    ub.privat
                    schrieb am zuletzt editiert von ub.privat
                    #1585
                    Schaut schon ein wenig "besser" aus:
                    [DEBUG] [iobroker] - host.raspberrypi 15818 states saved
                    [DEBUG] [iobroker] - host.raspberrypi 18629 objects saved
                    [DEBUG] [iobroker] - Backup created: /opt/iobroker/backups/iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz
                    [DEBUG] [influxDB] - Backup created: /opt/iobroker/backups/influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz
                    [ERROR] [mysql] - [IGNORED] Error: Command failed: mysqldump  -u ioBroker -p**** iobroker -h 192.168.178.20 -P 3307 > /opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.sql
                    mysqldump: Got error: 1045: "Access denied for user 'ioBroker'@'raspberrypi-3.fritz.box' (using password: YES)" when trying to connect
                    [DEBUG] [googledrive] - Google Drive: Copy iobroker_2021_12_14-18_36_25_backupiobroker.tar.gz...
                    [DEBUG] [googledrive] - Google Drive: Copy influxDB_2021_12_14-18_36_53_backupiobroker.tar.gz...
                    [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/mysql_2021_12_14-18_36_55_backupiobroker.tar.gz" not found
                    [ERROR] [googledrive] - Google Drive: File "/opt/iobroker/backups/historyDB_2021_12_14-18_36_58_backupiobroker.tar.gz" not found
                    [EXIT] 0
                    Nun kommt diese Fehlermeldung:
                    InFlux DB und ioBroker - Backup wurden geschrieben! Freu...
                    Jetzt nich die mySQL hinbekommen!
                    Ich verstehe aber nicht, warum jetzt die GZ-Datei geschrieben wird!?
                      [EXIT] 0
                      Thomas BraunT
                      Thomas BraunT
                      #1586
                      @ub-privat
                      Der User muss dann auf dem Server auch angelegt sein. Sonst darf der natürlich auch keinen mysqldump ausführen.
                        @ub-privat
                        ub.privatU
                        ub.privatU
                        ub.privat
                        #1587
                        ich muss nun in der MariaDB den Fritzbox-User mit dem entsprechenden Passwort anlegen/einrichten?
                        Puuh, da muss ich mal schauen, wie ich das hinbekomme...
                        wäre dies die korrekte Vorgehensweise?
                        https://forum.iobroker.net/topic/3327/mariadb-auf-diskstation-als-datenbank-für-flot
                          Thomas BraunT
                          Thomas BraunT
                          #1588
                          @ub-privat
                          Keine Ahnung von mariadb.
                            @ub-privat
                            ub.privatU
                            ub.privatU
                            ub.privat
                            #1589
                            OK, Schade.
                            Aktuell sind diese User eingerichtet:
                            aber ist denn 'ioBroker'@'raspberrypi-3.fritz.box' nicht gleich der Benutzer "iobroker"?
                            Wie gesagt, alles "learning by doing" und die grenzenlose Forumshilfe!
                              @ub-privat
                              ub.privatU
                              ub.privatU
                              ub.privat
                              #1590
                              dann werede ich erst einmal die iobroker- und influx-Backups beobachten!
                              Vielen Dank für deine Hilfe! DANKE.
                                OK, Schade.
                                mickymM
                                mickymM
                                mickym
                                #1591
                                gelöscht
                                • mickymM mickym
                                  gelöscht
                                  mickymM
                                  mickymM
                                  mickym
                                  #1592
                                  @ub-privat Ich versteh das alles ehrlich gesagt nicht. Du gibst doch in dem SQL-Adapter einen Benutzer an und den musst Du in der mySQL (mariaDB) anlegen. Das hat doch nichts mit irgendwelchen Domänennamen etc. zu tun.
                                  Bei mir heißt der auch zufälligerweise iobroker:
                                  Im backitup Adapter musst Du den mySQL Benutzernamen dann ja auch nochmal eintragen. Verstehe momentan nicht, wo das Problem liegt.
                                  • mickymM mickym
                                    ub.privatU
                                    ub.privatU
                                    ub.privat
                                    #1593
                                    @mickym
                                    die Einträge habe ich sowohl im SQL und Backitup-Adapter korrekt vorgenommen.
                                    In der MariaDB ist er auch angelegt --> siehe Bild weiter oben.
                                    Adapter sind auch korrekt = grün.
                                    Wo ist dein Bildauschnitt her?
                                    mickymM Thomas BraunT 2 Antworten Letzte Antwort
                                      @mickym
                                      mickymM
                                      mickymM
                                      mickym
                                      #1594
                                      @ub-privat Ich habe mir für Windows HeidiSQL installiert - damit kann ich die mariaDB easy mit der GUI administrieren. ;)
                                        @mickym
                                        Thomas BraunT
                                        Thomas BraunT
                                        #1595
                                        @ub-privat
                                        ioBroker (im Backitup-Adapter) ist nicht iobroker (auf der Maria)
                                        • mickymM mickym
                                          ub.privatU
                                          ub.privatU
                                          ub.privat
                                          #1596
                                          @mickym
                                          Da muss ich nch eine Menge lernen!
                                          33.2k
                                          84.3k
