  4. ioBroker.js-controller 1.5.6
testcall for action
150 Beiträge 31 Kommentatoren 32.4k Aufrufe 26 Beobachtet
  • M Marty56
    Hab es mal versucht, sieht nicht so gut aus.
    root@ioBroker-OPi2E:~# iobroker stop
    Stopping iobroker controller daemon...
    iobroker controller daemon stopped.
    Exit code for "killall.sh": 0
    root@ioBroker-OPi2E:~# cd ..
    root@ioBroker-OPi2E:/# cd opt
    root@ioBroker-OPi2E:/opt# cd iobroker
    root@ioBroker-OPi2E:/opt/iobroker# npm i iobroker.js-controller@1.5.5
    npm WARN lifecycle iobroker.js-controller@1.5.5~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.5.5 node lib/preinstallCheck.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
    > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/authenticate-pam/build'
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: No such file or directory
    compilation terminated.
    authenticate_pam.target.mk:92: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failed
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
    make: Leaving directory '/opt/iobroker/node_modules/authenticate-pam/build'
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.14.70-sunxi
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v6.14.4
    gyp ERR! node-gyp -v v3.4.0
    gyp ERR! not ok
    > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
    > node rebuild.js
    > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
    > node-gyp rebuild
    make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
      CXX(target) Release/obj.target/diskusage/src/main.o
      CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
      SOLINK_MODULE(target) Release/obj.target/diskusage.node
      COPY Release/diskusage.node
    make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
    > iobroker.js-controller@1.5.5 install /opt/iobroker/node_modules/iobroker.js-controller
    > node iobroker.js setup first
    > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/acme-v2/node_modules/rsa-compat
    > node lib/telemetry.js event:install
    > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/greenlock/node_modules/rsa-compat
    - asn1js@1.2.12 node_modules/asn1js
    - buffer-v6-polyfill@1.0.5 node_modules/buffer-v6-polyfill
    - node.extend@1.1.6 node_modules/certpem/node_modules/node.extend
    cliui@4.1.0 node_modules/iobroker.js-controller/node_modules/cliui -> node_modules/cliui
    - node.extend@1.1.6 node_modules/greenlock/node_modules/node.extend
    - arraybuffer.slice@0.0.7 node_modules/iobroker.js-controller/node_modules/arraybuffer.slice
    - camelcase@4.1.0 node_modules/iobroker.js-controller/node_modules/camelcase
    - component-emitter@1.2.1 node_modules/iobroker.js-controller/node_modules/component-emitter
    - debug@3.1.0 node_modules/iobroker.js-controller/node_modules/debug
    - engine.io-parser@2.1.2 node_modules/iobroker.js-controller/node_modules/engine.io-parser
    - isarray@2.0.1 node_modules/iobroker.js-controller/node_modules/isarray
    - socket.io-adapter@1.1.1 node_modules/iobroker.js-controller/node_modules/socket.io-adapter
    - socket.io-parser@3.2.0 node_modules/iobroker.js-controller/node_modules/socket.io-parser
    - ultron@1.1.1 node_modules/iobroker.js-controller/node_modules/ultron
    - ws@3.3.3 node_modules/iobroker.js-controller/node_modules/ws
    - engine.io@3.2.0 node_modules/iobroker.js-controller/node_modules/engine.io
    - xmlhttprequest-ssl@1.5.5 node_modules/iobroker.js-controller/node_modules/xmlhttprequest-ssl
    - engine.io-client@3.2.1 node_modules/iobroker.js-controller/node_modules/engine.io-client
    - socket.io-client@2.1.1 node_modules/iobroker.js-controller/node_modules/socket.io-client
    - socket.io@2.1.1 node_modules/iobroker.js-controller/node_modules/socket.io
    - yargs-parser@9.0.2 node_modules/iobroker.js-controller/node_modules/yargs/node_modules/yargs-parser
    - pkijs@1.3.33 node_modules/pkijs
    - certpem@1.0.1 node_modules/certpem
    - glob@7.1.2 node_modules/rimraf/node_modules/glob
    - bindings@1.1.1 node_modules/unix-dgram/node_modules/bindings
    - yargs-parser@4.2.1 node_modules/iobroker.js-controller/node_modules/yargs-parser
    yargs@11.1.0 node_modules/iobroker.js-controller/node_modules/yargs -> node_modules/yargs
    iobroker@1.0.0 /opt/iobroker
    └─┬ iobroker.js-controller@1.5.5
      ├─┬ diskusage@0.2.6
      │ └── nan@2.12.1
      ├─┬ greenlock@2.6.7
      │ ├── acme@1.2.0
      │ ├─┬ acme-v2@1.5.2
      │ │ └─┬ rsa-compat@1.9.2
      │ │   └── node-forge@0.7.6
      │ ├── cert-info@1.5.0
      │ ├── le-store-certbot@2.2.1
      │   ├── node-forge@0.7.6
      │   └─┬ ursa-optional@0.9.10
      │     ├─┬ bindings@1.4.0
      │     │ └── file-uri-to-path@1.0.0
      │     └── nan@2.12.1
      ├─┬ jsonwebtoken@8.4.0
      │ └─┬ jws@3.2.1
      │   └── jwa@1.2.0
      ├─┬ jszip@3.1.5
      │ └── pako@1.0.8
      ├── le-acme-core@2.1.4
      ├── le-sni-auto@2.1.6
      ├─┬ loadavg-windows@1.0.2
      │ └── weak-daemon@1.0.3
      ├─┬ node-schedule@1.3.1
      │ └─┬ cron-parser@2.7.3
      │   └── moment-timezone@0.5.23
      ├─┬ node.extend@2.0.2
      │ ├── has@1.0.3
      │ └── is@3.3.0
      ├─┬ pidusage@2.0.17
      │ └── safe-buffer@5.1.2
      ├─┬ prompt@1.0.0
      │ └─┬ utile@0.3.0
      │   └─┬ rimraf@2.6.3
      │     └── glob@7.1.3
      ├── pyconf@1.1.6
      ├─┬ redis@2.8.0
      │ └── redis-commands@1.4.0
      ├── safe-replace@1.1.0
      ├─┬ tar@4.4.8
      │ ├── chownr@1.1.1
      │ ├── minipass@2.3.5
      │ ├── minizlib@1.2.1
      │ └── yallist@3.0.3
      └── winston@2.4.4
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mymodule/package.json'
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    @Marty56 Hier wäre (rechtebedingt) noch ein --unsafe-perm anzuhängen, aber das preinstall script ist bei nem update nicht so nötig, also alles ok ie BF schon gesagt hat
    • M Marty56
      Ich konnte es jetzt einkreisen.
      javascript.0	2019-02-13 07:56:00.209	error	Error in callback: TypeError: Cannot read property 'common' of undefined
      javascript.0	2019-02-13 07:55:38.422	error	Error in callback: TypeError: Cannot read property 'common' of undefined
      javascript.0	2019-02-13 07:55:38.248	error	TypeError: Cannot read property 'common' of undefined
      javascript.0	2019-02-13 07:55:38.248	error	^
      javascript.0	2019-02-13 07:55:38.247	error	if (!language || !dayOfWeeksFull[language]) language = objects['system.config'].common.language;
      javascript.0	2019-02-13 07:55:38.247	error	script.js.common.Tagescharacteristik: /opt/iobroker/node_modules/iobroker.javascript/javascript.js:2712
      Es ist das Kommando formatDate(new Date(), "W hh:mm").
      Liegt nicht an meinen Scripts sondern wohl an der neuen js-controller Version
      Was funktioniert ist: formatDate(new Date(), "hh:mm")
      update:
      • WW, НН(cyrillic) - full week day as text
      • W, Н(cyrillic) - short week day as text
      funktionieren alle nicht mehr
      BluefoxB Offline
      BluefoxB Offline
      @Marty56 said in ioBroker.js-controller 1.5.4/1.5.5:
      Ich kann diesen Fehler nicht erklären. Reproduzieren kann ich auch nicht, aber ich habe js-controller@1.5.6 und javascript@3.6.5 gemacht.
      Kannst du ausprobieren? Erst javascript updaten und dann js-controller.
      cd /optOderHomeVerzeichnis/iobroker
      iobroker stop
      npm i iobroker.javascript@3.6.5 --production
      npm i iobroker.js-controller@1.5.6 --production
      iobroker u javascript
      iobroker start
      M sigi234S 2 Antworten Letzte Antwort
      • simatecS Offline
        simatecS Offline
        simatec
        Bei einer Iobroker Installation mit neuen Installer ist auf die korrekte Rechtevergabe zu achten.
        Der Befehl
        kann nicht einfach als anderer User ausgeführt werden, da sonst der User iobroker nicht alle Recht hat.
        • Besuche meine Github Seite
        • HowTo Restore ioBroker
        R apollon77A 2 Antworten Letzte Antwort
        • ? Offline
          js-controller 1.5.5 läuft hier einwandfrei.
          iobroker.admin - aktuell aus git
          iobroker.web - aktuell aus git
          iobroker.iot - aktuell aus git
          iobroker.javascript - aktuell aus git
          Node 8.15, NPM 6.7, Linux mint 18.3. in ner VM unter proxmox.
          ( Hauptsystem, 170 Netzwerkdevices und 88 MiHome - es wird genug traffic erzeugt.. ;-))
          Auf den Raspi's mit gleichen Versionen unter ARM auch keine Probleme.
          js-controller 1.5.5 wirkt im admin schneller. ( er aktualisiert die Seite sehr schnell )
          Testsystem frisch aufgesetzt und auf latest gestellt, auch Node 8.15, NPM6.7, Linux Mint 19.1, keine Fehler.
          ( hier sind nur ein paar Skripts am laufen)
          Ansonsten klasse, weiter so! Das neue Forum ist auch viel besser.
          Frage: auf 1.5.6 kann ich nicht updaten, npm findet die Version nicht?
          npm ERR! notarget No matching version found for iobroker.js-controller@1.5.6
          npm ERR! notarget In most cases you or one of your dependencies are requesting
          npm ERR! notarget a package version that doesn't exist.
          • frankjokeF Offline
            frankjokeF Offline
            frankjoke
            @Bluefox sagte in ioBroker.js-controller 1.5.6:
            Hab's versucht aber
            npm ERR! code ETARGET
            npm ERR!     /home/iobroker/.npm/_logs/2019-02-13T15_37_04_235Z-debug.log
            erhalten!
            p.s.: ich mach solche Sachen unter der neuen iobroker-Installation immer mit vorher:
            sudo -u iobroker sh
            Frank,
            • BluefoxB Bluefox
              iobroker stop
              iobroker start
              Marty56
              @Bluefox damit geht es wieder.
              HW:NUC (16 GB Ram)
              OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
              • BluefoxB Offline
                BluefoxB Offline
                Ich habe jetzt 1.5.6 auf npm gepuscht (war noch nicht und ich habe nicht bemerkt)
                M ? 2 Antworten Letzte Antwort
                • BluefoxB Bluefox
                  Marty56
                  @Bluefox
                  mit js-controller 1.5.5 und javscript 3.65 kein Problem
                  HW:NUC (16 GB Ram)
                  BluefoxB 1 Antwort Letzte Antwort
                  • M Marty56
                    @Bluefox
                    BluefoxB Offline
                    BluefoxB Offline
                    @Marty56 Und dein Script zeigt auch Wochentag richtig?
                    • BluefoxB Bluefox
                      Marty56
                      @Bluefox
                      log(formatDate(new Date(), "W hh:mm"));
                      Mi 17:16
                      sieht gut aus.
                      HW:NUC (16 GB Ram)
                      • BluefoxB Bluefox
                        @Bluefox Danke, funktioniert !
                        • MatzebhvM Offline
                          MatzebhvM Offline
                          Matzebhv
                          Moin,
                          hier fliegt der iobroker mit der Version alle 30sec. auseinander. Habe die 1.5.5 probiert und auch die 1.5.6.
                          admin.0	2019-02-13 18:19:16.539	info	terminating http server on port 8081
                          cloud.0	2019-02-13 18:19:10.594	info	Connection changed: connect
                          cloud.0	2019-02-13 18:19:10.437	info	Trying to connect as system.user.admin
                          host.raspberry	2019-02-13 18:19:05.979	info	instance system.adapter.upnp.0 terminated with code 0 (OK)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.emit (events.js:214:7)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at emitTwo (events.js:126:13)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
                          host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
                          host.raspberry	2019-02-13 18:19:05.660	info	iobroker exit 0
                          host.raspberry	2019-02-13 18:19:05.659	info	iobroker Starting node restart.js
                          host.raspberry	2019-02-13 18:19:05.539	info	iobroker _restart
                          host.raspberry	2019-02-13 18:19:05.539	error	RangeError: Maximum call stack size exceeded at Buffer.write (buffer.js:855:34) at fromString (buffer.js:319:20) at Function.Buffer.from (buffer.js:177:12) at new Buffer (buffer.js:158
                          host.raspberry	2019-02-13 18:19:05.538	error	uncaught exception: Maximum call stack size exceeded
                          iot.0	2019-02-13 18:19:04.819	info	Connection changed: connect
                          Matze
                          • MatzebhvM Matzebhv
                            Moin,
                            Matze
                            BluefoxB Offline
                            BluefoxB Offline
                            schrieb am zuletzt editiert von Bluefox
                            @Matzebhv Was sagt npm ls socket.io ?
                            • MatzebhvM Offline
                              MatzebhvM Offline
                              Matzebhv
                              @Bluefox : ich bin schon wieder auf 1.4.2 zurück. Kannst du dann damit noch was anfangen?
                              Und noch als Hinweis, Usern mit neuerer Version ( neuer Installer ) haut es beim Update die Berechtigungen auseinander. Da hast du dann Ordner mit Besitzer "root" dazwischen.
                              Matze
                              • simatecS simatec
                                Der Befehl
                                RappiRN
                                @simatec sagte in ioBroker.js-controller 1.5.6:
                                Der Befehl
                                Hier steht schon ein Hinweis darauf, das sollte natürlich auch im ioBroker-Admin angezeigt werden, als deutlichen Hinweis darauf, dass es zwei unterschiedliche Installationsvarianten gibt. Nicht dass es da noch große Diskussionen gibt!
                                Enrico
                                  mirK
                                  wie kommt man wieder zurück auf die 1.4.6 ?
                                  Vis funktioniert nicht - bekomme nur eine weiße seite nach dem laden angzeigt.
                                  Homer.J.H 1 Antwort Letzte Antwort
                                  • Homer.J.H Offline
                                    Homer.J.H Offline
                                    Homer.J.
                                    schrieb am zuletzt editiert von eric2905
                                    Hallo Bluefox,
                                    nach Update auf 1.5.6 funktioniert der Das Wetter Adapter nicht mehr steht dann das im Log.
                                    2019-02-13 16:45:15.828  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                                    zurück auf 1.4.2 und es geht wieder alles.
                                    Grüße
                                    Edit by eric2905, Logs & Co. bitte immer in Code-Tags setzen
                                    BluefoxB P 2 Antworten Letzte Antwort
                                    • M mirK
                                      Homer.J.H Offline
                                      Homer.J.H Offline
                                      Homer.J.
                                      @mirK
                                      cd /opt/iobroker
                                      iobroker stop
                                      npm i iobroker.js-controller@1.4.2 --production
                                      iobroker start
                                      Grüße
                                        Matze
                                        BluefoxB Offline
                                        BluefoxB Offline
                                        Участник @Matzebhv написал в ioBroker.js-controller 1.5.6:
                                        Natürlich..... nicht
                                        • BluefoxB Bluefox
                                          iobroker stop
                                          iobroker start
                                          sigi234S Online
                                          sigi234S Online
                                          sigi234
                                          Installiert, derzeit keine Probleme..............
                                          Platform: Windows
                                          Architecture: x64
                                          CPUs: 4
                                          Speed: 3912 MHz
                                          Model: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
                                          RAM: 7.9 GB
                                          System uptime: 23:07:29
                                          Node.js: v8.15.0
                                          NPM: 6.4.1
                                          Disk size: 232.3 GiB
                                          Disk free: 172.9 GiB
                                          adapters count: 253
                                          Uptime: 00:19:54
                                          Active instances: 39
                                          Immer Daten sichern!
