  4. ioBroker.js-controller 1.5.6
testcall for action
150 Beiträge 31 Kommentatoren 35.7k Aufrufe 26 Beobachtet
  • BluefoxB Bluefox
    Ich habe jetzt 1.5.6 auf npm gepuscht (war noch nicht und ich habe nicht bemerkt)
    @Bluefox Danke, funktioniert !
    • MatzebhvM
      MatzebhvM
      Matzebhv
      Moin,
      hier fliegt der iobroker mit der Version alle 30sec. auseinander. Habe die 1.5.5 probiert und auch die 1.5.6.
      admin.0	2019-02-13 18:19:16.539	info	terminating http server on port 8081
      cloud.0	2019-02-13 18:19:10.594	info	Connection changed: connect
      cloud.0	2019-02-13 18:19:10.437	info	Trying to connect as system.user.admin
      host.raspberry	2019-02-13 18:19:05.979	info	instance system.adapter.upnp.0 terminated with code 0 (OK)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.emit (events.js:214:7)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at emitTwo (events.js:126:13)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
      host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
      host.raspberry	2019-02-13 18:19:05.660	info	iobroker exit 0
      host.raspberry	2019-02-13 18:19:05.659	info	iobroker Starting node restart.js
      host.raspberry	2019-02-13 18:19:05.539	info	iobroker _restart
      host.raspberry	2019-02-13 18:19:05.539	error	RangeError: Maximum call stack size exceeded at Buffer.write (buffer.js:855:34) at fromString (buffer.js:319:20) at Function.Buffer.from (buffer.js:177:12) at new Buffer (buffer.js:158
      host.raspberry	2019-02-13 18:19:05.538	error	uncaught exception: Maximum call stack size exceeded
      iot.0	2019-02-13 18:19:04.819	info	Connection changed: connect
      Matze
      BluefoxB 1 Antwort Letzte Antwort
      • MatzebhvM Matzebhv
        Moin,
        Matze
        schrieb am zuletzt editiert von Bluefox
        @Matzebhv Was sagt npm ls socket.io ?
        • MatzebhvM
          MatzebhvM
          Matzebhv
          @Bluefox : ich bin schon wieder auf 1.4.2 zurück. Kannst du dann damit noch was anfangen?
          Und noch als Hinweis, Usern mit neuerer Version ( neuer Installer ) haut es beim Update die Berechtigungen auseinander. Da hast du dann Ordner mit Besitzer "root" dazwischen.
          Matze
          • simatecS simatec
            Bei einer Iobroker Installation mit neuen Installer ist auf die korrekte Rechtevergabe zu achten.
            Der Befehl
            npm i iobroker.js-controller@1.5.6
            kann nicht einfach als anderer User ausgeführt werden, da sonst der User iobroker nicht alle Recht hat.
            R
            R
            RappiRN
            @simatec sagte in ioBroker.js-controller 1.5.6:
            Der Befehl
            Hier steht schon ein Hinweis darauf, das sollte natürlich auch im ioBroker-Admin angezeigt werden, als deutlichen Hinweis darauf, dass es zwei unterschiedliche Installationsvarianten gibt. Nicht dass es da noch große Diskussionen gibt!
            Enrico
            • M
              M
              mirK
              wie kommt man wieder zurück auf die 1.4.6 ?
              Vis funktioniert nicht - bekomme nur eine weiße seite nach dem laden angzeigt.
              Homer.J.H 1 Antwort Letzte Antwort
              • Homer.J.H
                Homer.J.H
                Homer.J.
                schrieb am zuletzt editiert von eric2905
                Hallo Bluefox,
                nach Update auf 1.5.6 funktioniert der Das Wetter Adapter nicht mehr steht dann das im Log.
                2019-02-13 16:45:15.828  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                zurück auf 1.4.2 und es geht wieder alles.
                Edit by eric2905, Logs & Co. bitte immer in Code-Tags setzen
                BluefoxB P 2 Antworten Letzte Antwort
                • M mirK
                  Homer.J.H
                  Homer.J.H
                  Homer.J.
                  @mirK
                  cd /opt/iobroker
                  iobroker stop
                  npm i iobroker.js-controller@1.4.2 --production
                  iobroker start
                    Matze
                    Участник @Matzebhv написал в ioBroker.js-controller 1.5.6:
                    Natürlich..... nicht
                    • BluefoxB Bluefox
                      @Marty56 said in ioBroker.js-controller 1.5.4/1.5.5:
                      formatDate(new Date(), "hh:mm")
                      Ich kann diesen Fehler nicht erklären. Reproduzieren kann ich auch nicht, aber ich habe js-controller@1.5.6 und javascript@3.6.5 gemacht.
                      Kannst du ausprobieren? Erst javascript updaten und dann js-controller.
                      cd /optOderHomeVerzeichnis/iobroker
                      iobroker stop
                      npm i iobroker.javascript@3.6.5 --production
                      npm i iobroker.js-controller@1.5.6 --production
                      iobroker u javascript
                      iobroker start
                      sigi234S
                      sigi234S
                      @Bluefox sagte in ioBroker.js-controller 1.5.6:
                      Installiert, derzeit keine Probleme..............
                      Platform: Windows
                      Architecture: x64
                      CPUs: 4
                      Speed: 3912 MHz
                      Model: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
                      RAM: 7.9 GB
                      System uptime: 23:07:29
                      Node.js: v8.15.0
                      NPM: 6.4.1
                      Disk size: 232.3 GiB
                      Disk free: 172.9 GiB
                      adapters count: 253
                      Uptime: 00:19:54
                      Active instances: 39
                      • Homer.J.H Homer.J.
                        Hallo Bluefox,
                        @Homer1976 Eigentlich DasWetter läuft alle 15 Minuten und stoppt sich.
                        Code 11 ist genau das.
                        • BluefoxB Bluefox
                          sigi234S
                          sigi234S
                          Bei mit kommt jetzt auch ein Fehler:
                          daswetter.0	2019-02-13 20:30:02.224	error	at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8)
                          daswetter.0	2019-02-13 20:30:02.224	error	at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                          daswetter.0	2019-02-13 20:30:02.224	error	at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10)
                          daswetter.0	2019-02-13 20:30:02.224	error	at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14)
                          daswetter.0	2019-02-13 20:30:02.224	error	at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                          daswetter.0	2019-02-13 20:30:02.224	error	at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15)
                          daswetter.0	2019-02-13 20:30:02.224	error	at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16)
                          daswetter.0	2019-02-13 20:30:02.224	error	at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14)
                          daswetter.0	2019-02-13 20:30:02.224	error	at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                          daswetter.0	2019-02-13 20:30:02.224	error	at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12)
                          daswetter.0	2019-02-13 20:30:02.224	error	RangeError: Maximum call stack size exceeded
                          daswetter.0	2019-02-13 20:30:02.224	error	uncaught exception: Maximum call stack size exceeded
                          BluefoxB 2 Antworten Letzte Antwort
                          • sigi234S sigi234
                            @sigi234 npm ls socket.io ?
                            • BluefoxB Bluefox
                              sigi234S
                              sigi234S
                              +-- iobroker.admin@3.6.0
                              | `-- socket.io@1.7.2
                              +-- iobroker.js-controller@1.5.6
                              | `-- socket.io@1.7.2
                              `-- iobroker.socketio@2.1.1
                                `-- socket.io@1.7.2
                              • sigi234S sigi234
                                | `-- socket.io@1.7.2
                                | `-- socket.io@1.7.2
                                  `-- socket.io@1.7.2
                                @sigi234 Ist das nur DasWetter oder auch andere Adapter?
                                • BluefoxB Bluefox
                                  sigi234S
                                  sigi234S
                                  nur DasWetter
                                  Korrektur:
                                  iot.0	2019-02-13 22:55:09.962	error	Cannot report device state: null
                                  iot.0	2019-02-13 22:55:09.576	error	Cannot report device state: null
                                  iot.0	2019-02-13 22:55:09.563	error	Cannot report device state: null
                                  • sigi234S sigi234
                                    nur DasWetter
                                    Korrektur:
                                    @sigi234 node.js version ? npm ?
                                    • BluefoxB Bluefox
                                      sigi234S
                                      sigi234S
                                      Node.js: v8.15.0
                                      NPM: 6.4.1
                                        Hallo Bluefox,
                                        P
                                        P
                                        PrinzEisenherz1
                                        @Homer1976 sagte in ioBroker.js-controller 1.5.6:
                                        Hallo Bluefox,
                                        Nach der Installation hat erstmal der Shelly-Adapter tewas verrückt gespielt, sich aber nach m Neustart beruhigt.
                                        Jetzt hab ich derzeit nur die gleichen Fehlermeldungen vom dasWetter wie Homer 1976
                                        Ich bleibe jetzt aber mal auf Version 1.5.6 und schau mir das mal ne weile an was sich noch so alles tut
                                        Johnny
                                        Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                                        • lobomauL
                                          lobomauL
                                          lobomau
                                          Gestern hatte ich ohne Erfolg 1.5.4. versucht, heute 1.5.6.
                                          Ich denke ich habe woanders Probleme. Irgendwie habe ich neben opt/iobroker auch home/iobroker... im zweiten habe ich aber keine Rechte... sudo cd /home/iobroker geht auch nicht.
                                          NPM version: 6.4.1
                                          npm version >= 5: disabling package-lock
                                          Could not check npm version: Error: EACCES: permission denied, open '/opt/iobroker/.npmrc'
                                          Assuming that correct version is installed.
                                          > node-bluetooth@1.2.5 install /opt/iobroker/node_modules/node-bluetooth
                                          > node-gyp configure build
                                          gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/iobroker/.node-gyp/8.15.0"
                                          gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/node-bluetooth/.node-gyp"
                                          gyp WARN install got an error, rolling back install
                                          gyp ERR! configure error
                                          gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/node-bluetooth/.node-gyp'
                                          gyp ERR! System Linux 4.15.0-45-generic
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
                                          gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
                                          gyp ERR! node -v v8.15.0
                                          gyp ERR! node-gyp -v v3.8.0
                                          gyp ERR! not ok
                                          > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                                          > node rebuild.js
                                          ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                                          fs.js:646
                                            return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
                                          Error: EACCES: permission denied, open './stdout.log'
                                              at Object.fs.openSync (fs.js:646:18)
                                              at Object.fs.writeFileSync (fs.js:1299:33)
                                              at Object.<anonymous> (/opt/iobroker/node_modules/ursa-optional/rebuild.js:13:10)
                                              at Module._compile (module.js:653:30)
                                              at Object.Module._extensions..js (module.js:664:10)
                                              at Module.load (module.js:566:32)
                                              at tryModuleLoad (module.js:506:12)
                                              at Function.Module._load (module.js:498:3)
                                              at Function.Module.runMain (module.js:694:10)
                                              at startup (bootstrap_node.js:204:16)
                                          > usb@1.5.0 install /opt/iobroker/node_modules/usb
                                          > node-pre-gyp install --fallback-to-build
                                          node-pre-gyp WARN Using request for node-pre-gyp https download
                                          node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-x64.tar.gz
                                          node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
                                          gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
                                          gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/usb/.node-gyp'
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
                                          gyp ERR! cwd /opt/iobroker/node_modules/usb
                                          gyp ERR! not ok
                                          node-pre-gyp ERR! build error
                                          node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                                          node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                          node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
                                          node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                                          node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
                                          node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                                          node-pre-gyp ERR! System Linux 4.15.0-45-generic
                                          node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                          node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
                                          node-pre-gyp ERR! node -v v8.15.0
                                          node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                          node-pre-gyp ERR! not ok
                                          > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
                                          > node-gyp rebuild
                                          gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/diskusage/.node-gyp"
                                          gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/diskusage/.node-gyp'
                                          gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                          gyp ERR! cwd /opt/iobroker/node_modules/diskusage
                                          gyp ERR! not ok
                                          > iobroker.js-controller@1.5.6 install /opt/iobroker/node_modules/iobroker.js-controller
                                          > node iobroker.js setup first
                                          Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                                          Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                                          fs.js:885
                                            return binding.mkdir(pathModule._makeLong(path),
                                          Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                              at Object.fs.mkdirSync (fs.js:885:18)
                                              at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:157:58)
                                              at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:634:27
                                              at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:664:15)
                                              at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3159:5)
                                              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
                                          npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: `npm install node-pre-gyp`
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 243
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 (node_modules/node-bluetooth):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 install: `node-gyp configure build`
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 (node_modules/ursa-optional):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 install: `node rebuild.js`
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: `node-pre-gyp install --fallback-to-build`
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 (node_modules/diskusage):
                                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 install: `node-gyp rebuild`
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! iobroker.js-controller@1.5.6 install: `node iobroker.js setup first`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the iobroker.js-controller@1.5.6 install script.
                                          npm ERR!     /home/iobroker/.npm/_logs/2019-02-13T19_51_21_042Z-debug.log
                                          iobroker@iobroker-ubuntu:/opt/iobroker$
                                          Host: NUC8i3 mit Proxmox:
                                          • Slave: Pi4
                                          83.9k
