  4. ioBroker.js-controller 1.5.6
testcall for action
150 Beiträge 31 Kommentatoren 32.6k Aufrufe 26 Beobachtet
  • MatzebhvM Matzebhv
    Moin,
    hier fliegt der iobroker mit der Version alle 30sec. auseinander. Habe die 1.5.5 probiert und auch die 1.5.6.
    admin.0	2019-02-13 18:19:16.539	info	terminating http server on port 8081
    cloud.0	2019-02-13 18:19:10.594	info	Connection changed: connect
    cloud.0	2019-02-13 18:19:10.437	info	Trying to connect as system.user.admin
    host.raspberry	2019-02-13 18:19:05.979	info	instance system.adapter.upnp.0 terminated with code 0 (OK)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.emit (events.js:214:7)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at emitTwo (events.js:126:13)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
    host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
    host.raspberry	2019-02-13 18:19:05.660	info	iobroker exit 0
    host.raspberry	2019-02-13 18:19:05.659	info	iobroker Starting node restart.js
    host.raspberry	2019-02-13 18:19:05.539	info	iobroker _restart
    host.raspberry	2019-02-13 18:19:05.539	error	RangeError: Maximum call stack size exceeded at Buffer.write (buffer.js:855:34) at fromString (buffer.js:319:20) at Function.Buffer.from (buffer.js:177:12) at new Buffer (buffer.js:158
    host.raspberry	2019-02-13 18:19:05.538	error	uncaught exception: Maximum call stack size exceeded
    iot.0	2019-02-13 18:19:04.819	info	Connection changed: connect
    Matze
    BluefoxB Offline
    BluefoxB Offline
    schrieb am zuletzt editiert von Bluefox
    @Matzebhv Was sagt npm ls socket.io ?
    • MatzebhvM Offline
      MatzebhvM Offline
      Matzebhv
      @Bluefox : ich bin schon wieder auf 1.4.2 zurück. Kannst du dann damit noch was anfangen?
      Und noch als Hinweis, Usern mit neuerer Version ( neuer Installer ) haut es beim Update die Berechtigungen auseinander. Da hast du dann Ordner mit Besitzer "root" dazwischen.
      Matze
      BluefoxB 1 Antwort Letzte Antwort
      • simatecS simatec
        Bei einer Iobroker Installation mit neuen Installer ist auf die korrekte Rechtevergabe zu achten.
        Der Befehl
        npm i iobroker.js-controller@1.5.6
        kann nicht einfach als anderer User ausgeführt werden, da sonst der User iobroker nicht alle Recht hat.
        RappiRN
        @simatec sagte in ioBroker.js-controller 1.5.6:
        Der Befehl
        Hier steht schon ein Hinweis darauf, das sollte natürlich auch im ioBroker-Admin angezeigt werden, als deutlichen Hinweis darauf, dass es zwei unterschiedliche Installationsvarianten gibt. Nicht dass es da noch große Diskussionen gibt!
        Enrico
          mirK
          wie kommt man wieder zurück auf die 1.4.6 ?
          Vis funktioniert nicht - bekomme nur eine weiße seite nach dem laden angzeigt.
          Homer.J.H 1 Antwort Letzte Antwort
          • Homer.J.H Offline
            Homer.J.H Offline
            Homer.J.
            schrieb am zuletzt editiert von eric2905
            Hallo Bluefox,
            nach Update auf 1.5.6 funktioniert der Das Wetter Adapter nicht mehr steht dann das im Log.
            2019-02-13 16:45:15.828  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
            zurück auf 1.4.2 und es geht wieder alles.
            Edit by eric2905, Logs & Co. bitte immer in Code-Tags setzen
            BluefoxB P 2 Antworten Letzte Antwort
            • M mirK
              Homer.J.H Offline
              Homer.J.H Offline
              Homer.J.
              @mirK
              cd /opt/iobroker
              iobroker stop
              npm i iobroker.js-controller@1.4.2 --production
              iobroker start
                Matze
                BluefoxB Offline
                BluefoxB Offline
                Участник @Matzebhv написал в ioBroker.js-controller 1.5.6:
                Natürlich..... nicht
                • BluefoxB Bluefox
                  @Marty56 said in ioBroker.js-controller 1.5.4/1.5.5:
                  formatDate(new Date(), "hh:mm")
                  Ich kann diesen Fehler nicht erklären. Reproduzieren kann ich auch nicht, aber ich habe js-controller@1.5.6 und javascript@3.6.5 gemacht.
                  Kannst du ausprobieren? Erst javascript updaten und dann js-controller.
                  cd /optOderHomeVerzeichnis/iobroker
                  iobroker stop
                  npm i iobroker.javascript@3.6.5 --production
                  npm i iobroker.js-controller@1.5.6 --production
                  iobroker u javascript
                  iobroker start
                  sigi234S Online
                  sigi234S Online
                  @Bluefox sagte in ioBroker.js-controller 1.5.6:
                  Installiert, derzeit keine Probleme..............
                  Platform: Windows
                  Architecture: x64
                  CPUs: 4
                  Speed: 3912 MHz
                  Model: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
                  RAM: 7.9 GB
                  System uptime: 23:07:29
                  Node.js: v8.15.0
                  NPM: 6.4.1
                  Disk size: 232.3 GiB
                  Disk free: 172.9 GiB
                  adapters count: 253
                  Uptime: 00:19:54
                  Active instances: 39
                  • Homer.J.H Homer.J.
                    Hallo Bluefox,
                    BluefoxB Offline
                    BluefoxB Offline
                    @Homer1976 Eigentlich DasWetter läuft alle 15 Minuten und stoppt sich.
                    Code 11 ist genau das.
                    • BluefoxB Bluefox
                      sigi234S Online
                      sigi234S Online
                      Bei mit kommt jetzt auch ein Fehler:
                      daswetter.0	2019-02-13 20:30:02.224	error	at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8)
                      daswetter.0	2019-02-13 20:30:02.224	error	at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                      daswetter.0	2019-02-13 20:30:02.224	error	at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10)
                      daswetter.0	2019-02-13 20:30:02.224	error	at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14)
                      daswetter.0	2019-02-13 20:30:02.224	error	at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20)
                      daswetter.0	2019-02-13 20:30:02.224	error	at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15)
                      daswetter.0	2019-02-13 20:30:02.224	error	at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16)
                      daswetter.0	2019-02-13 20:30:02.224	error	at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14)
                      daswetter.0	2019-02-13 20:30:02.224	error	at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9)
                      daswetter.0	2019-02-13 20:30:02.224	error	at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12)
                      daswetter.0	2019-02-13 20:30:02.224	error	RangeError: Maximum call stack size exceeded
                      daswetter.0	2019-02-13 20:30:02.224	error	uncaught exception: Maximum call stack size exceeded
                      BluefoxB 2 Antworten Letzte Antwort
                      • sigi234S sigi234
                        BluefoxB Offline
                        BluefoxB Offline
                        @sigi234 npm ls socket.io ?
                        • BluefoxB Bluefox
                          sigi234S Online
                          sigi234S Online
                          +-- iobroker.admin@3.6.0
                          | `-- socket.io@1.7.2
                          +-- iobroker.js-controller@1.5.6
                          | `-- socket.io@1.7.2
                          `-- iobroker.socketio@2.1.1
                            `-- socket.io@1.7.2
                          • sigi234S sigi234
                            | `-- socket.io@1.7.2
                            | `-- socket.io@1.7.2
                              `-- socket.io@1.7.2
                            BluefoxB Offline
                            BluefoxB Offline
                            @sigi234 Ist das nur DasWetter oder auch andere Adapter?
                            • BluefoxB Bluefox
                              sigi234S Online
                              sigi234S Online
                              nur DasWetter
                              Korrektur:
                              iot.0	2019-02-13 22:55:09.962	error	Cannot report device state: null
                              iot.0	2019-02-13 22:55:09.576	error	Cannot report device state: null
                              iot.0	2019-02-13 22:55:09.563	error	Cannot report device state: null
                              • sigi234S sigi234
                                nur DasWetter
                                Korrektur:
                                BluefoxB Offline
                                BluefoxB Offline
                                @sigi234 node.js version ? npm ?
                                • BluefoxB Bluefox
                                  sigi234S Online
                                  sigi234S Online
                                  Node.js: v8.15.0
                                  NPM: 6.4.1
                                    Hallo Bluefox,
                                    PrinzEisenherz1
                                    @Homer1976 sagte in ioBroker.js-controller 1.5.6:
                                    Hallo Bluefox,
                                    Nach der Installation hat erstmal der Shelly-Adapter tewas verrückt gespielt, sich aber nach m Neustart beruhigt.
                                    Jetzt hab ich derzeit nur die gleichen Fehlermeldungen vom dasWetter wie Homer 1976
                                    Ich bleibe jetzt aber mal auf Version 1.5.6 und schau mir das mal ne weile an was sich noch so alles tut
                                    Johnny
                                    Intel-NUC mit ProxMox: ioBroker,SQL, logging Strom- Gas- u. Wasserzähler;10Zoll Tab im Flur für VIS; weiteres: Homematic CCU2, Homeduino, Kameras, selbstgebaute Wetterstation;
                                    • lobomauL Offline
                                      lobomauL Offline
                                      lobomau
                                      Gestern hatte ich ohne Erfolg 1.5.4. versucht, heute 1.5.6.
                                      Ich denke ich habe woanders Probleme. Irgendwie habe ich neben opt/iobroker auch home/iobroker... im zweiten habe ich aber keine Rechte... sudo cd /home/iobroker geht auch nicht.
                                      NPM version: 6.4.1
                                      npm version >= 5: disabling package-lock
                                      Could not check npm version: Error: EACCES: permission denied, open '/opt/iobroker/.npmrc'
                                      Assuming that correct version is installed.
                                      > node-bluetooth@1.2.5 install /opt/iobroker/node_modules/node-bluetooth
                                      > node-gyp configure build
                                      gyp WARN EACCES user "root" does not have permission to access the dev dir "/home/iobroker/.node-gyp/8.15.0"
                                      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/node-bluetooth/.node-gyp"
                                      gyp WARN install got an error, rolling back install
                                      gyp ERR! configure error
                                      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/node-bluetooth/.node-gyp'
                                      gyp ERR! System Linux 4.15.0-45-generic
                                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"
                                      gyp ERR! cwd /opt/iobroker/node_modules/node-bluetooth
                                      gyp ERR! node -v v8.15.0
                                      gyp ERR! node-gyp -v v3.8.0
                                      gyp ERR! not ok
                                      > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
                                      > node rebuild.js
                                      ursaNative bindings compilation fail. This is not an issue. Modules that depend on it will use fallbacks.
                                      fs.js:646
                                        return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
                                      Error: EACCES: permission denied, open './stdout.log'
                                          at Object.fs.openSync (fs.js:646:18)
                                          at Object.fs.writeFileSync (fs.js:1299:33)
                                          at Object.<anonymous> (/opt/iobroker/node_modules/ursa-optional/rebuild.js:13:10)
                                          at Module._compile (module.js:653:30)
                                          at Object.Module._extensions..js (module.js:664:10)
                                          at Module.load (module.js:566:32)
                                          at tryModuleLoad (module.js:506:12)
                                          at Function.Module._load (module.js:498:3)
                                          at Function.Module.runMain (module.js:694:10)
                                          at startup (bootstrap_node.js:204:16)
                                      > usb@1.5.0 install /opt/iobroker/node_modules/usb
                                      > node-pre-gyp install --fallback-to-build
                                      node-pre-gyp WARN Using request for node-pre-gyp https download
                                      node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-x64.tar.gz
                                      node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
                                      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/usb/.node-gyp"
                                      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/usb/.node-gyp'
                                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"
                                      gyp ERR! cwd /opt/iobroker/node_modules/usb
                                      gyp ERR! not ok
                                      node-pre-gyp ERR! build error
                                      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
                                      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                      node-pre-gyp ERR! stack     at emitTwo (events.js:126:13)
                                      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:214:7)
                                      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:915:16)
                                      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
                                      node-pre-gyp ERR! System Linux 4.15.0-45-generic
                                      node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                      node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
                                      node-pre-gyp ERR! node -v v8.15.0
                                      node-pre-gyp ERR! node-pre-gyp -v v0.11.0
                                      node-pre-gyp ERR! not ok
                                      > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
                                      > node-gyp rebuild
                                      gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/diskusage/.node-gyp"
                                      gyp ERR! stack Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/diskusage/.node-gyp'
                                      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                                      gyp ERR! cwd /opt/iobroker/node_modules/diskusage
                                      gyp ERR! not ok
                                      > iobroker.js-controller@1.5.6 install /opt/iobroker/node_modules/iobroker.js-controller
                                      > node iobroker.js setup first
                                      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.bat'
                                      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
                                      fs.js:885
                                        return binding.mkdir(pathModule._makeLong(path),
                                      Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/../../tmp'
                                          at Object.fs.mkdirSync (fs.js:885:18)
                                          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/setupSetup.js:157:58)
                                          at /opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:634:27
                                          at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:664:15)
                                          at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup.js:3159:5)
                                          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:100)
                                      npm WARN onvif-snapshot@1.0.2 requires a peer of onvif@^0.5.5 but none is installed. You must install peer dependencies yourself.
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
                                      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 preinstall: `npm install node-pre-gyp`
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 243
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 (node_modules/node-bluetooth):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: node-bluetooth@1.2.5 install: `node-gyp configure build`
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 (node_modules/ursa-optional):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: ursa-optional@0.9.10 install: `node rebuild.js`
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: `node-pre-gyp install --fallback-to-build`
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 (node_modules/diskusage):
                                      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@0.2.6 install: `node-gyp rebuild`
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! errno 1
                                      npm ERR! iobroker.js-controller@1.5.6 install: `node iobroker.js setup first`
                                      npm ERR! Exit status 1
                                      npm ERR!
                                      npm ERR! Failed at the iobroker.js-controller@1.5.6 install script.
                                      npm ERR!     /home/iobroker/.npm/_logs/2019-02-13T19_51_21_042Z-debug.log
                                      iobroker@iobroker-ubuntu:/opt/iobroker$
                                      Host: NUC8i3 mit Proxmox:
                                      • Slave: Pi4
                                      • P Offline
                                        PrinzEisenherz1
                                        jetzt hab ich den shedule von daswetter geändert und nun kommt dauernd folgender Fehler
                                        host.ioBroker-VM	2019-02-13 21:00:38.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:37.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:36.001	warn	instance system.adapter.daswetter.0 already running with pid 4461
                                        host.ioBroker-VM	2019-02-13 21:00:35.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:34.010	info	instance system.adapter.daswetter.0 started with pid 4461
                                        host.ioBroker-VM	2019-02-13 21:00:33.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:32.829	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                                        host.ioBroker-VM	2019-02-13 21:00:32.002	warn	instance system.adapter.daswetter.0 already running with pid 4447
                                        host.ioBroker-VM	2019-02-13 21:00:31.003	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:30.001	warn	instance system.adapter.daswetter.0 already running with pid 4447
                                        host.ioBroker-VM	2019-02-13 21:00:29.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:28.003	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:27.274	warn	instance system.adapter.daswetter.0 already running with pid 4447
                                        host.ioBroker-VM	2019-02-13 21:00:26.002	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:25.010	info	instance system.adapter.daswetter.0 started with pid 4447
                                        host.ioBroker-VM	2019-02-13 21:00:24.457	info	instance scheduled system.adapter.daswetter.0 * */16 * * * *
                                        host.ioBroker-VM	2019-02-13 21:00:21.952	warn	stopInstance system.adapter.daswetter.0 not scheduled
                                        host.ioBroker-VM	2019-02-13 21:00:21.952	info	stopInstance system.adapter.daswetter.0
                                        host.ioBroker-VM	2019-02-13 21:00:21.952	info	object change system.adapter.daswetter.0
                                        host.ioBroker-VM	2019-02-13 21:00:19.497	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                                        host.ioBroker-VM	2019-02-13 21:00:18.238	info	instance system.adapter.weatherunderground.0 terminated with code 0 (OK)
                                        host.ioBroker-VM	2019-02-13 21:00:15.723	info	stopInstance canceled schedule system.adapter.daswetter.0
                                        host.ioBroker-VM	2019-02-13 21:00:15.723	info	stopInstance system.adapter.daswetter.0
                                        host.ioBroker-VM	2019-02-13 21:00:15.722	info	object change system.adapter.daswetter.0
                                        host.ioBroker-VM	2019-02-13 21:00:15.005	warn	instance system.adapter.daswetter.0 already running with pid 4418
                                        host.ioBroker-VM	2019-02-13 21:00:14.063	info	instance system.adapter.ical.0 terminated with code 0 (OK)
                                        host.ioBroker-VM	2019-02-13 21:00:14.059	info	instance system.adapter.weatherunderground.0 started with pid 4433
                                        host.ioBroker-VM	2019-02-13 21:00:14.039	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:13.000	warn	instance system.adapter.daswetter.0 already running with pid 4418
                                        host.ioBroker-VM	2019-02-13 21:00:12.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:11.043	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:10.008	info	instance system.adapter.daswetter.0 started with pid 4418
                                        host.ioBroker-VM	2019-02-13 21:00:09.837	error	instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                                        host.ioBroker-VM	2019-02-13 21:00:09.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:08.000	warn	instance system.adapter.daswetter.0 already running with pid 4306
                                        host.ioBroker-VM	2019-02-13 21:00:07.016	info	instance system.adapter.yr.0 terminated with code 0 (OK)
                                        host.ioBroker-VM	2019-02-13 21:00:07.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:06.000	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:05.001	warn	instance system.adapter.daswetter.0 already running with pid 4306
                                        host.ioBroker-VM	2019-02-13 21:00:04.628	info	instance system.adapter.dwd.0 terminated with code 0 (OK)
                                        host.ioBroker-VM	2019-02-13 21:00:04.001	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:03.013	warn	instance system.adapter.daswetter.0 does not started, because just executed
                                        host.ioBroker-VM	2019-02-13 21:00:02.037	warn	instance system.adapter.daswetter.0 already running with pid 4306
                                        • P PrinzEisenherz1
                                          BluefoxB Offline
                                          BluefoxB Offline
                                          Участник @PrinzEisenherz1 написал в ioBroker.js-controller 1.5.6:
                                          • */16 * * * *
                                          Kannst du auf "*/16 * * * *" ändern? Sonst wird es jede Sekunde ausgeführt
                                          P 1 Antwort Letzte Antwort
