ioBroker.js-controller 1.5.6
@Marty56 said in ioBroker.js-controller 1.5.4/1.5.5:
formatDate(new Date(), "hh:mm")
Ich kann diesen Fehler nicht erklären. Reproduzieren kann ich auch nicht, aber ich habe js-controller@1.5.6 und javascript@3.6.5 gemacht.
Kannst du ausprobieren? Erst javascript updaten und dann js-controller.cd /optOderHomeVerzeichnis/iobroker iobroker stop npm i iobroker.javascript@3.6.5 --production npm i iobroker.js-controller@1.5.6 --production iobroker u javascript iobroker start -
@Bluefox Danke, funktioniert !
Moin,
hier fliegt der iobroker mit der Version alle 30sec. auseinander. Habe die 1.5.5 probiert und auch die 1.5.6.admin.0 2019-02-13 18:19:16.539 info terminating http server on port 8081 cloud.0 2019-02-13 18:19:10.594 info Connection changed: connect cloud.0 2019-02-13 18:19:10.437 info Trying to connect as system.user.admin host.raspberry 2019-02-13 18:19:05.979 info instance system.adapter.upnp.0 terminated with code 0 (OK) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at WebSocket.emit (events.js:214:7) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at emitTwo (events.js:126:13) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12) host.raspberry 2019-02-13 18:19:05.979 error Caught by controller[0]: RangeError: Maximum call stack size exceeded host.raspberry 2019-02-13 18:19:05.660 info iobroker exit 0 host.raspberry 2019-02-13 18:19:05.659 info iobroker Starting node restart.js host.raspberry 2019-02-13 18:19:05.539 info iobroker _restart host.raspberry 2019-02-13 18:19:05.539 error RangeError: Maximum call stack size exceeded at Buffer.write (buffer.js:855:34) at fromString (buffer.js:319:20) at Function.Buffer.from (buffer.js:177:12) at new Buffer (buffer.js:158 host.raspberry 2019-02-13 18:19:05.538 error uncaught exception: Maximum call stack size exceeded iot.0 2019-02-13 18:19:04.819 info Connection changed: connectMatze
Moin,
@Bluefox : ich bin schon wieder auf 1.4.2 zurück. Kannst du dann damit noch was anfangen?
Und noch als Hinweis, Usern mit neuerer Version ( neuer Installer ) haut es beim Update die Berechtigungen auseinander. Da hast du dann Ordner mit Besitzer "root" dazwischen.Gruß
Matze -
Bei einer Iobroker Installation mit neuen Installer ist auf die korrekte Rechtevergabe zu achten.
Der Befehlnpm i iobroker.js-controller@1.5.6kann nicht einfach als anderer User ausgeführt werden, da sonst der User iobroker nicht alle Recht hat.
@simatec sagte in ioBroker.js-controller 1.5.6:
Hier steht schon ein Hinweis darauf, das sollte natürlich auch im ioBroker-Admin angezeigt werden, als deutlichen Hinweis darauf, dass es zwei unterschiedliche Installationsvarianten gibt. Nicht dass es da noch große Diskussionen gibt!
Enrico
Hallo Bluefox,
nach Update auf 1.5.6 funktioniert der Das Wetter Adapter nicht mehr steht dann das im Log.2019-02-13 16:45:15.828 - [31merror[39m: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)zurück auf 1.4.2 und es geht wieder alles.
Edit by eric2905, Logs & Co. bitte immer in Code-Tags setzen
wie kommt man wieder zurück auf die 1.4.6 ?
Vis funktioniert nicht - bekomme nur eine weiße seite nach dem laden angzeigt.
Matze -
Kannst du ausprobieren? Erst javascript updaten und dann js-controller.cd /optOderHomeVerzeichnis/iobroker iobroker stop npm i iobroker.javascript@3.6.5 --production npm i iobroker.js-controller@1.5.6 --production iobroker u javascript iobroker start@Bluefox sagte in ioBroker.js-controller 1.5.6:
npm i iobroker.js-controller@1.5.6 --productionInstalliert, derzeit keine Probleme..............
Platform: Windows
Architecture: x64
CPUs: 4
Speed: 3912 MHz
Model: Intel(R) Core(TM) i3-7100 CPU @ 3.90GHz
RAM: 7.9 GB
System uptime: 23:07:29
Node.js: v8.15.0
NPM: 6.4.1
Disk size: 232.3 GiB
Disk free: 172.9 GiB
adapters count: 253
Uptime: 00:19:54
Active instances: 39 -
Hallo Bluefox,
@Homer1976 Eigentlich DasWetter läuft alle 15 Minuten und stoppt sich.
Code 11 ist genau das.@Bluefox sagte in ioBroker.js-controller 1.5.6:
Code 11 ist genau das.Bei mit kommt jetzt auch ein Fehler:
daswetter.0 2019-02-13 20:30:02.224 error at WS.Transport.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\transport.js:145:8) daswetter.0 2019-02-13 20:30:02.224 error at WS.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20) daswetter.0 2019-02-13 20:30:02.224 error at WS.<anonymous> (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:268:10) daswetter.0 2019-02-13 20:30:02.224 error at Socket.onPacket (C:\ioBroker\node_modules\engine.io-client\lib\socket.js:451:14) daswetter.0 2019-02-13 20:30:02.224 error at Socket.Emitter.emit (C:\ioBroker\node_modules\engine.io-client\node_modules\component-emitter\index.js:133:20) daswetter.0 2019-02-13 20:30:02.224 error at Socket.<anonymous> (C:\ioBroker\node_modules\component-bind\index.js:21:15) daswetter.0 2019-02-13 20:30:02.224 error at Manager.ondata (C:\ioBroker\node_modules\socket.io-client\lib\manager.js:322:16) daswetter.0 2019-02-13 20:30:02.224 error at Decoder.add (C:\ioBroker\node_modules\socket.io-parser\index.js:237:14) daswetter.0 2019-02-13 20:30:02.224 error at decodeString (C:\ioBroker\node_modules\socket.io-parser\index.js:325:9) daswetter.0 2019-02-13 20:30:02.224 error at tryParse (C:\ioBroker\node_modules\socket.io-parser\index.js:336:12) daswetter.0 2019-02-13 20:30:02.224 error RangeError: Maximum call stack size exceeded daswetter.0 2019-02-13 20:30:02.224 error uncaught exception: Maximum call stack size exceeded -
@sigi234
npm ls socket.io?+-- iobroker.admin@3.6.0 | `-- socket.io@1.7.2 +-- iobroker.js-controller@1.5.6 | `-- socket.io@1.7.2 `-- iobroker.socketio@2.1.1 `-- socket.io@1.7.2 -
@sigi234
