  4. ioBroker.js-controller 1.5.6
testcall for action
150 Beiträge 31 Kommentatoren 32.6k Aufrufe 26 Beobachtet
  • BluefoxB Bluefox
    @Marty56 was für JS Version hast du?
    Marty56
    schrieb am zuletzt editiert von Marty56
    @Bluefox javascript 3.6.4
    Ich habe alles sonst auf default als repro.
    Also die Versionen, die unter http://download.iobroker.net/sources-dist.json liegen
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • M Marty56
      Hab es mal versucht, sieht nicht so gut aus.
      root@ioBroker-OPi2E:~# iobroker stop
      Stopping iobroker controller daemon...
      iobroker controller daemon stopped.
      Exit code for "killall.sh": 0
      root@ioBroker-OPi2E:~# cd ..
      root@ioBroker-OPi2E:/# cd opt
      root@ioBroker-OPi2E:/opt# cd iobroker
      root@ioBroker-OPi2E:/opt/iobroker# npm i iobroker.js-controller@1.5.5
      npm WARN lifecycle iobroker.js-controller@1.5.5~preinstall: cannot run in wd %s %s (wd=%s) iobroker.js-controller@1.5.5 node lib/preinstallCheck.js /opt/iobroker/node_modules/.staging/iobroker.js-controller-a76002ca
      > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/authenticate-pam/build'
        CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
      ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: No such file or directory
      compilation terminated.
      authenticate_pam.target.mk:92: recipe for target 'Release/obj.target/authenticate_pam/authenticate_pam.o' failed
      make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Error 1
      make: Leaving directory '/opt/iobroker/node_modules/authenticate-pam/build'
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      gyp ERR! stack     at emitTwo (events.js:106:13)
      gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
      gyp ERR! System Linux 4.14.70-sunxi
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      gyp ERR! node -v v6.14.4
      gyp ERR! node-gyp -v v3.4.0
      gyp ERR! not ok
      > ursa-optional@0.9.10 install /opt/iobroker/node_modules/ursa-optional
      > node rebuild.js
      > diskusage@0.2.6 install /opt/iobroker/node_modules/diskusage
      > node-gyp rebuild
      make: Entering directory '/opt/iobroker/node_modules/diskusage/build'
        CXX(target) Release/obj.target/diskusage/src/main.o
        CXX(target) Release/obj.target/diskusage/src/diskusage_posix.o
        SOLINK_MODULE(target) Release/obj.target/diskusage.node
        COPY Release/diskusage.node
      make: Leaving directory '/opt/iobroker/node_modules/diskusage/build'
      > iobroker.js-controller@1.5.5 install /opt/iobroker/node_modules/iobroker.js-controller
      > node iobroker.js setup first
      > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/acme-v2/node_modules/rsa-compat
      > node lib/telemetry.js event:install
      > rsa-compat@1.9.2 postinstall /opt/iobroker/node_modules/greenlock/node_modules/rsa-compat
      - asn1js@1.2.12 node_modules/asn1js
      - buffer-v6-polyfill@1.0.5 node_modules/buffer-v6-polyfill
      - node.extend@1.1.6 node_modules/certpem/node_modules/node.extend
      cliui@4.1.0 node_modules/iobroker.js-controller/node_modules/cliui -> node_modules/cliui
      - node.extend@1.1.6 node_modules/greenlock/node_modules/node.extend
      - arraybuffer.slice@0.0.7 node_modules/iobroker.js-controller/node_modules/arraybuffer.slice
      - camelcase@4.1.0 node_modules/iobroker.js-controller/node_modules/camelcase
      - component-emitter@1.2.1 node_modules/iobroker.js-controller/node_modules/component-emitter
      - debug@3.1.0 node_modules/iobroker.js-controller/node_modules/debug
      - engine.io-parser@2.1.2 node_modules/iobroker.js-controller/node_modules/engine.io-parser
      - isarray@2.0.1 node_modules/iobroker.js-controller/node_modules/isarray
      - socket.io-adapter@1.1.1 node_modules/iobroker.js-controller/node_modules/socket.io-adapter
      - socket.io-parser@3.2.0 node_modules/iobroker.js-controller/node_modules/socket.io-parser
      - ultron@1.1.1 node_modules/iobroker.js-controller/node_modules/ultron
      - ws@3.3.3 node_modules/iobroker.js-controller/node_modules/ws
      - engine.io@3.2.0 node_modules/iobroker.js-controller/node_modules/engine.io
      - xmlhttprequest-ssl@1.5.5 node_modules/iobroker.js-controller/node_modules/xmlhttprequest-ssl
      - engine.io-client@3.2.1 node_modules/iobroker.js-controller/node_modules/engine.io-client
      - socket.io-client@2.1.1 node_modules/iobroker.js-controller/node_modules/socket.io-client
      - socket.io@2.1.1 node_modules/iobroker.js-controller/node_modules/socket.io
      - yargs-parser@9.0.2 node_modules/iobroker.js-controller/node_modules/yargs/node_modules/yargs-parser
      - pkijs@1.3.33 node_modules/pkijs
      - certpem@1.0.1 node_modules/certpem
      - glob@7.1.2 node_modules/rimraf/node_modules/glob
      - bindings@1.1.1 node_modules/unix-dgram/node_modules/bindings
      - yargs-parser@4.2.1 node_modules/iobroker.js-controller/node_modules/yargs-parser
      yargs@11.1.0 node_modules/iobroker.js-controller/node_modules/yargs -> node_modules/yargs
      iobroker@1.0.0 /opt/iobroker
      └─┬ iobroker.js-controller@1.5.5
        ├─┬ diskusage@0.2.6
        │ └── nan@2.12.1
        ├─┬ greenlock@2.6.7
        │ ├── acme@1.2.0
        │ ├─┬ acme-v2@1.5.2
        │ │ └─┬ rsa-compat@1.9.2
        │ │   └── node-forge@0.7.6
        │ ├── cert-info@1.5.0
        │ ├── le-store-certbot@2.2.1
        │   ├── node-forge@0.7.6
        │   └─┬ ursa-optional@0.9.10
        │     ├─┬ bindings@1.4.0
        │     │ └── file-uri-to-path@1.0.0
        │     └── nan@2.12.1
        ├─┬ jsonwebtoken@8.4.0
        │ └─┬ jws@3.2.1
        │   └── jwa@1.2.0
        ├─┬ jszip@3.1.5
        │ └── pako@1.0.8
        ├── le-acme-core@2.1.4
        ├── le-sni-auto@2.1.6
        ├─┬ loadavg-windows@1.0.2
        │ └── weak-daemon@1.0.3
        ├─┬ node-schedule@1.3.1
        │ └─┬ cron-parser@2.7.3
        │   └── moment-timezone@0.5.23
        ├─┬ node.extend@2.0.2
        │ ├── has@1.0.3
        │ └── is@3.3.0
        ├─┬ pidusage@2.0.17
        │ └── safe-buffer@5.1.2
        ├─┬ prompt@1.0.0
        │ └─┬ utile@0.3.0
        │   └─┬ rimraf@2.6.3
        │     └── glob@7.1.3
        ├── pyconf@1.1.6
        ├─┬ redis@2.8.0
        │ └── redis-commands@1.4.0
        ├── safe-replace@1.1.0
        ├─┬ tar@4.4.8
        │ ├── chownr@1.1.1
        │ ├── minipass@2.3.5
        │ ├── minizlib@1.2.1
        │ └── yallist@3.0.3
        └── winston@2.4.4
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@^1.0.0 (node_modules/chokidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.javascript/node_modules/mymodule/package.json'
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: `node-gyp rebuild`
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      @Marty56 Hier wäre (rechtebedingt) noch ein --unsafe-perm anzuhängen, aber das preinstall script ist bei nem update nicht so nötig, also alles ok ie BF schon gesagt hat
      • M Marty56
        Ich konnte es jetzt einkreisen.
        javascript.0	2019-02-13 07:56:00.209	error	Error in callback: TypeError: Cannot read property 'common' of undefined
        javascript.0	2019-02-13 07:55:38.422	error	Error in callback: TypeError: Cannot read property 'common' of undefined
        javascript.0	2019-02-13 07:55:38.248	error	TypeError: Cannot read property 'common' of undefined
        javascript.0	2019-02-13 07:55:38.248	error	^
        javascript.0	2019-02-13 07:55:38.247	error	if (!language || !dayOfWeeksFull[language]) language = objects['system.config'].common.language;
        javascript.0	2019-02-13 07:55:38.247	error	script.js.common.Tagescharacteristik: /opt/iobroker/node_modules/iobroker.javascript/javascript.js:2712
        Es ist das Kommando formatDate(new Date(), "W hh:mm").
        Liegt nicht an meinen Scripts sondern wohl an der neuen js-controller Version
        Was funktioniert ist: formatDate(new Date(), "hh:mm")
        update:
        • WW, НН(cyrillic) - full week day as text
        • W, Н(cyrillic) - short week day as text
        funktionieren alle nicht mehr
        BluefoxB Offline
        BluefoxB Offline
        @Marty56 said in ioBroker.js-controller 1.5.4/1.5.5:
        Ich kann diesen Fehler nicht erklären. Reproduzieren kann ich auch nicht, aber ich habe js-controller@1.5.6 und javascript@3.6.5 gemacht.
        Kannst du ausprobieren? Erst javascript updaten und dann js-controller.
        cd /optOderHomeVerzeichnis/iobroker
        iobroker stop
        npm i iobroker.javascript@3.6.5 --production
        npm i iobroker.js-controller@1.5.6 --production
        iobroker u javascript
        iobroker start
        M sigi234S 2 Antworten Letzte Antwort
        • simatecS Offline
          simatecS Offline
          simatec
          Bei einer Iobroker Installation mit neuen Installer ist auf die korrekte Rechtevergabe zu achten.
          Der Befehl
          kann nicht einfach als anderer User ausgeführt werden, da sonst der User iobroker nicht alle Recht hat.
          • Besuche meine Github Seite
          • HowTo Restore ioBroker
          R apollon77A 2 Antworten Letzte Antwort
          • ? Offline
            js-controller 1.5.5 läuft hier einwandfrei.
            iobroker.admin - aktuell aus git
            iobroker.web - aktuell aus git
            iobroker.iot - aktuell aus git
            iobroker.javascript - aktuell aus git
            Node 8.15, NPM 6.7, Linux mint 18.3. in ner VM unter proxmox.
            ( Hauptsystem, 170 Netzwerkdevices und 88 MiHome - es wird genug traffic erzeugt.. ;-))
            Auf den Raspi's mit gleichen Versionen unter ARM auch keine Probleme.
            js-controller 1.5.5 wirkt im admin schneller. ( er aktualisiert die Seite sehr schnell )
            Testsystem frisch aufgesetzt und auf latest gestellt, auch Node 8.15, NPM6.7, Linux Mint 19.1, keine Fehler.
            ( hier sind nur ein paar Skripts am laufen)
            Ansonsten klasse, weiter so! Das neue Forum ist auch viel besser.
            Frage: auf 1.5.6 kann ich nicht updaten, npm findet die Version nicht?
            npm ERR! notarget No matching version found for iobroker.js-controller@1.5.6
            npm ERR! notarget In most cases you or one of your dependencies are requesting
            npm ERR! notarget a package version that doesn't exist.
            • frankjokeF Offline
              frankjokeF Offline
              frankjoke
              @Bluefox sagte in ioBroker.js-controller 1.5.6:
              Hab's versucht aber
              npm ERR! code ETARGET
              npm ERR!     /home/iobroker/.npm/_logs/2019-02-13T15_37_04_235Z-debug.log
              erhalten!
              p.s.: ich mach solche Sachen unter der neuen iobroker-Installation immer mit vorher:
              sudo -u iobroker sh
              Frank,
              NUC's, VM's und Raspi's unter Raspian, Ubuntu und Debian zum Testen.
              Adapter die ich selbst beigesteuert habe: BMW, broadlink2, radar2, systeminfo, km200, xs1 und einige im Anmarsch!
              • BluefoxB Bluefox
                iobroker stop
                iobroker start
                Marty56
                @Bluefox damit geht es wieder.
                HW:NUC (16 GB Ram)
                • BluefoxB Offline
                  BluefoxB Offline
                  Ich habe jetzt 1.5.6 auf npm gepuscht (war noch nicht und ich habe nicht bemerkt)
                  M ? 2 Antworten Letzte Antwort
                  • BluefoxB Bluefox
                    Marty56
                    @Bluefox
                    mit js-controller 1.5.5 und javscript 3.65 kein Problem
                    HW:NUC (16 GB Ram)
                    BluefoxB 1 Antwort Letzte Antwort
                    • M Marty56
                      @Bluefox
                      BluefoxB Offline
                      BluefoxB Offline
                      @Marty56 Und dein Script zeigt auch Wochentag richtig?
                      • BluefoxB Bluefox
                        Marty56
                        @Bluefox
                        log(formatDate(new Date(), "W hh:mm"));
                        Mi 17:16
                        sieht gut aus.
                        HW:NUC (16 GB Ram)
                        • BluefoxB Bluefox
                          @Bluefox Danke, funktioniert !
                          • MatzebhvM Offline
                            MatzebhvM Offline
                            Matzebhv
                            Moin,
                            hier fliegt der iobroker mit der Version alle 30sec. auseinander. Habe die 1.5.5 probiert und auch die 1.5.6.
                            admin.0	2019-02-13 18:19:16.539	info	terminating http server on port 8081
                            cloud.0	2019-02-13 18:19:10.594	info	Connection changed: connect
                            cloud.0	2019-02-13 18:19:10.437	info	Trying to connect as system.user.admin
                            host.raspberry	2019-02-13 18:19:05.979	info	instance system.adapter.upnp.0 terminated with code 0 (OK)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.emit (events.js:214:7)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at emitTwo (events.js:126:13)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:237:14)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at decodeString (/opt/iobroker/node_modules/socket.io-parser/index.js:325:9)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: at tryParse (/opt/iobroker/node_modules/socket.io-parser/index.js:336:12)
                            host.raspberry	2019-02-13 18:19:05.979	error	Caught by controller[0]: RangeError: Maximum call stack size exceeded
                            host.raspberry	2019-02-13 18:19:05.660	info	iobroker exit 0
                            host.raspberry	2019-02-13 18:19:05.659	info	iobroker Starting node restart.js
                            host.raspberry	2019-02-13 18:19:05.539	info	iobroker _restart
                            host.raspberry	2019-02-13 18:19:05.539	error	RangeError: Maximum call stack size exceeded at Buffer.write (buffer.js:855:34) at fromString (buffer.js:319:20) at Function.Buffer.from (buffer.js:177:12) at new Buffer (buffer.js:158
                            host.raspberry	2019-02-13 18:19:05.538	error	uncaught exception: Maximum call stack size exceeded
                            iot.0	2019-02-13 18:19:04.819	info	Connection changed: connect
                            Matze
                            • MatzebhvM Matzebhv
                              Moin,
                              Matze
                              BluefoxB Offline
                              BluefoxB Offline
                              schrieb am zuletzt editiert von Bluefox
                              @Matzebhv Was sagt npm ls socket.io ?
                              • MatzebhvM Offline
                                MatzebhvM Offline
                                Matzebhv
                                @Bluefox : ich bin schon wieder auf 1.4.2 zurück. Kannst du dann damit noch was anfangen?
                                Und noch als Hinweis, Usern mit neuerer Version ( neuer Installer ) haut es beim Update die Berechtigungen auseinander. Da hast du dann Ordner mit Besitzer "root" dazwischen.
                                Matze
                                • simatecS simatec
                                  Der Befehl
                                  RappiRN
                                  @simatec sagte in ioBroker.js-controller 1.5.6:
                                  Der Befehl
                                  Hier steht schon ein Hinweis darauf, das sollte natürlich auch im ioBroker-Admin angezeigt werden, als deutlichen Hinweis darauf, dass es zwei unterschiedliche Installationsvarianten gibt. Nicht dass es da noch große Diskussionen gibt!
                                  Enrico
                                    mirK
                                    wie kommt man wieder zurück auf die 1.4.6 ?
                                    Vis funktioniert nicht - bekomme nur eine weiße seite nach dem laden angzeigt.
                                    Homer.J.H 1 Antwort Letzte Antwort
                                    • Homer.J.H Offline
                                      Homer.J.H Offline
                                      Homer.J.
                                      schrieb am zuletzt editiert von eric2905
                                      Hallo Bluefox,
                                      nach Update auf 1.5.6 funktioniert der Das Wetter Adapter nicht mehr steht dann das im Log.
                                      2019-02-13 16:45:15.828  - error: host.iobroker instance system.adapter.daswetter.0 terminated with code 11 (Desired termination)
                                      zurück auf 1.4.2 und es geht wieder alles.
                                      Edit by eric2905, Logs & Co. bitte immer in Code-Tags setzen
                                      BluefoxB P 2 Antworten Letzte Antwort
                                      • M mirK
                                        Homer.J.H Offline
                                        Homer.J.H Offline
                                        Homer.J.
                                        @mirK
                                        cd /opt/iobroker
                                        iobroker stop
                                        npm i iobroker.js-controller@1.4.2 --production
                                        iobroker start
                                          Matze
                                          BluefoxB Offline
                                          BluefoxB Offline
                                          Участник @Matzebhv написал в ioBroker.js-controller 1.5.6:
                                          Natürlich..... nicht
