  4. IoBroker.zigbee Adapter - Gateway?
81 Beiträge 33 Kommentatoren 34.9k Aufrufe 7 Beobachtet
    thomson
    Moin zusammen.
    ich komme gerade nicht weiter. Habe den CC2531 USB sniffer mit CC2531ZNP-Prod.hex geflasht.
    Den Zigbee adapter installiert. Auf dem pi im Verzeichnis "/opt/iobroker" - "serialport-list" ausgeführt.
    Da steht dann:
    /dev/ttyAMA0
    /dev/ttyACM0    usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0012013D76-if0                0       Texas Instruments
    Was davon ist den nun der Port und was PanID ?
    Waren die anderen Schritte so richtig?
    im LOG steht
    zigbee.0	2018-08-08 20:15:55.817	info	Start on port: ttyACM0 with panID 6754
    zigbee.0	2018-08-08 20:15:55.795	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v6.14.3
    javascript.0	2018-08-08 20:15:55.139	info	script.js.common.RF_Bridge: 122000A001EA2BEBE8
    host.raspberrypi	2018-08-08 20:15:53.373	info	instance system.adapter.zigbee.0 started with pid 24252
    host.raspberrypi	2018-08-08 20:15:50.949	info	instance system.adapter.zigbee.0 terminated with code 0 (OK)
    Caught	2018-08-08 20:15:50.949	error	by controller[3]: Wed, 08 Aug 2018 18:15:50 GMT zigbee:controller info zigbee-shepherd stopped undefined
    Caught	2018-08-08 20:15:50.949	error	by controller[2]: at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    Caught	2018-08-08 20:15:50.949	error	by controller[2]: at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/component-emitter/index.js:133:20)
    Caught	2018-08-08 20:15:50.948	error	by controller[2]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    Caught	2018-08-08 20:15:50.948	error	by controller[2]: at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3400:34)
    Caught	2018-08-08 20:15:50.948	error	by controller[2]: at Adapter.emit (events.js:188:7)
    Caught	2018-08-08 20:15:50.948	error	by controller[2]: at emitOne (events.js:96:13)
    Caught	2018-08-08 20:15:50.947	error	by controller[2]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.zigbee/main.js:104:21)
    Caught	2018-08-08 20:15:50.947	error	by controller[2]: at letsPairing (/opt/iobroker/node_modules/iobroker.zigbee/main.js:286:19)
    Caught	2018-08-08 20:15:50.947	error	by controller[2]: at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:146:23)
    Caught	2018-08-08 20:15:50.946	error	by controller[2]: at ZShepherd.permitJoin (/opt/iobroker/node_modules/zigbee-shepherd/lib/shepherd.js:245:25)
    Caught	2018-08-08 20:15:50.946	error	by controller[2]: Wed, 08 Aug 2018 18:15:24 GMT zigbee:controller error Join failure. Error: Shepherd is not enabled.
    Caught	2018-08-08 20:15:50.946	error	by controller[1]: Wed, 08 Aug 2018 18:15:24 GMT zigbee:controller info Zigbee: allowing new devices to join. undefined
    Caught	2018-08-08 20:15:50.946	error	by controller[0]: Wed, 08 Aug 2018 18:15:24 GMT zigbee:controller debug Error while starting zigbee-shepherd, attemping to fix... (takes 60 seconds) undefined
    Caught	2018-08-08 20:15:50.945	error	by controller[0]: Wed, 08 Aug 2018 18:15:24 GMT zigbee-shepherd:init zigbee-shepherd booting...</anonymous></anonymous>
    • arteckA Offline
      arteckA Offline
      arteck
      das ist der port /dev/ttyACM0
      lass die panid so wie die ist
      ausserdem hast du ein Problem
      ich vermute aber weil der Port nicht definiert war
        thomson
        Danke für die Antwort.
        Habe ich drin. Der Adapter ist gelb.
        Wenn ich den Adapter neu starte kommt im LOG
        zigbee.0	2018-08-08 20:48:20.567	info	Start on port: ttyACM0 with panID 6754
        zigbee.0	2018-08-08 20:48:20.546	info	starting. Version 0.6.0 in /opt/iobroker/node_modules/iobroker.zigbee, node: v6.14.3
        host.raspberrypi	2018-08-08 20:48:18.188	info	instance system.adapter.zigbee.0 started with pid 25443
        host.raspberrypi	2018-08-08 20:48:15.720	info	instance system.adapter.zigbee.0 terminated with code 0 (OK)
        Caught	2018-08-08 20:48:15.720	error	by controller[1]: Wed, 08 Aug 2018 18:48:15 GMT zigbee:controller info zigbee-shepherd stopped undefined
        zigbee.0	2018-08-08 20:48:15.681	info	zigbee-shepherd stopped
        host.raspberrypi	2018-08-08 20:48:15.667	info	stopInstance system.adapter.zigbee.0 killing pid 24252
        host.raspberrypi	2018-08-08 20:48:15.666	info	object change system.adapter.zigbee.0
        • arteckA Offline
          arteckA Offline
          arteck
          nee die Library wird nicht gezogen
          ich habe meinen über node 8 laufen… ich weiss nicht ob die library mit node 6 läuft.. vielleicht äussert sich einer der es am laufen hat mit node 6
            thomson
            Kann ich da nicht einfach n Update machen?
            glaube der Stop kamaber weil ich auf den Aktualisieren butten gedrückt habe
            wenn ich im Adapter auf Pairing klicke. Bleibt das Feld leer. Versuche dabei einen Xiaomi MiJia temperature & humidity sensor anzulerenen.
            Drücke dabei auf den Knopf
            zigbee.0	2018-08-08 21:03:31.846	error	Join failure.. Error: Shepherd is not enabled.
            zigbee.0	2018-08-08 21:03:31.840	info	Zigbee: allowing new devices to join.
            zigbee.0	2018-08-08 20:50:26.311	error	Join failure.. Error: Shepherd is not enabled.
            zigbee.0	2018-08-08 20:50:26.289	info	Zigbee: allowing new devices to join.
            zigbee.0	2018-08-08 20:49:20.734	error	Error while starting zigbee-shepherd!. Error: Error: No such file or directory, cannot open ttyACM0
            zigbee.0	2018-08-08 20:49:20.700	info	Starting zigbee-shepherd
            • Alex1808A Offline
              Alex1808A Offline
              Alex1808
              @thomson:
              Drücke dabei auf den Knopf `
              Klar geht das nicht, ttyACM0 kann nich initialisiert werden.
              Was zeigt serialport-list ?
              • K Offline
                Knallix
                habe mir auch einen CC2531 USB zugelegt.
                Diesen habe ich dann geflasht mit dem CCDebugger. Hat auch alles soweit geklappt.
                Der PI erkennt den Stick auch.
                Beim reinstecken leuchtet einen Grüne LED. Dieses geht dann nach einer Zeit wieder aus // So OK ?
                Habe mir im IO-Broker den Zigbee-Adapter Version 0.7.0 installiert.
                Beim 1. mal Starten wurde er kurz Gelb und wechselte dann wieder auf Rot.
                Hat das Problem mit meinem npm / node.js was zutun ?
                Vielleicht kann mir ja jemand helfen. Muss ich hier noch was updaten ? :?: :?: :?
                host.raspberrypi	2018-08-19 18:11:48.090	info	Restart adapter system.adapter.zigbee.0 because enabled
                host.raspberrypi	2018-08-19 18:11:48.090	error	instance system.adapter.zigbee.0 terminated with code 1 ()
                Caught	2018-08-19 18:11:48.090	error	by controller[0]: at Object.Module._extensions..js (module.js:663:10)
                Caught	2018-08-19 18:11:48.090	error	by controller[0]: at Module._compile (module.js:652:30)
                Caught	2018-08-19 18:11:48.089	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                Caught	2018-08-19 18:11:48.089	error	by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
                Caught	2018-08-19 18:11:48.089	error	by controller[0]: at require (internal/module.js:11:18)
                Caught	2018-08-19 18:11:48.089	error	by controller[0]: at Module.require (module.js:596:17)
                Caught	2018-08-19 18:11:48.089	error	by controller[0]: at Function.Module._load (module.js:497:3)
                Caught	2018-08-19 18:11:48.089	error	by controller[0]: at tryModuleLoad (module.js:505:12)
                Caught	2018-08-19 18:11:48.089	error	by controller[0]: at Module.load (module.js:565:32)
                Caught	2018-08-19 18:11:48.089	error	by controller[0]: at Object.Module._extensions..node (module.js:681:18)
                Caught	2018-08-19 18:11:48.088	error	by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                Caught	2018-08-19 18:11:48.088	error	by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
                Caught	2018-08-19 18:11:48.088	error	by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
                Caught	2018-08-19 18:11:48.088	error	by controller[0]: was compiled against a different Node.js version using
                Caught	2018-08-19 18:11:48.088	error	by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                Caught	2018-08-19 18:11:48.088	error	by controller[0]: ^
                Caught	2018-08-19 18:11:48.088	error	by controller[0]: throw e
                Caught	2018-08-19 18:11:48.087	error	by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
                host.raspberrypi	2018-08-19 18:11:47.135	info	instance system.adapter.zigbee.0 started with pid 3477
                host.raspberrypi	2018-08-19 18:11:44.616	info	instance system.adapter.zigbee.0 terminated with code null ()
                host.raspberrypi	2018-08-19 18:11:44.616	warn	instance system.adapter.zigbee.0 terminated due to SIGTERM
                host.raspberrypi	2018-08-19 18:11:44.605	info	stopInstance system.adapter.zigbee.0 killing pid 3471
                host.raspberrypi	2018-08-19 18:11:44.604	info	object change system.adapter.zigbee.0
                host.raspberrypi	2018-08-19 18:11:44.396	info	instance system.adapter.zigbee.0 started with pid 3471</anonymous>
                • J Offline
                  J Riemann
                  Hast Du den Adapter auch richtig konfiguriert?
                  ****Viele Grüße!
                  Jörg****
                  • Jey CeeJ Offline
                    Jey CeeJ Offline
                    Jey Cee
                    Sieht eher nach einem Problem mit dem npm Paket serialport aus:
                    Die Log Ausgabe ist hier leider beschnitten um es sicher sagen zu können. Schau mal in die Log Datei.
                    Persönlicher Support
                    Spenden -> paypal.me/J3YC33
                    • K Offline
                      Knallix
                      Habe nur den COM-Port eingetragen ( /dev/ttyACM0 )
                      Meinst du das so ?
                      2018-08-19 21:12:42.243 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
                      2018-08-19 21:12:56.418 - info: host.raspberrypi object change system.adapter.zigbee.0
                      2018-08-19 21:12:56.418 - info: host.raspberrypi "system.adapter.zigbee.0" disabled
                      2018-08-19 21:13:13.243 - error: Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
                      2018-08-19 21:13:13.244 - error: Caught by controller[0]: throw e
                      2018-08-19 21:13:13.244 - error: Caught by controller[0]: ^
                      2018-08-19 21:13:13.244 - error: Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
                      2018-08-19 21:13:13.244 - error: Caught by controller[0]: was compiled against a different Node.js version using
                      2018-08-19 21:13:13.244 - error: Caught by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
                      2018-08-19 21:13:13.244 - error: Caught by controller[0]: NODE_MODULE_VERSION 64\. Please try re-compiling or re-installing
                      2018-08-19 21:13:13.244 - error: Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
                      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:718:18)
                      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:599:32)
                      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
                      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:530:3)
                      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:637:17)
                      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at require (internal/modules/cjs/helpers.js:20:18)
                      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
                      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
                      2018-08-19 21:13:13.246 - error: Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:689:30)
                      2018-08-19 21:13:13.246 - error: Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
                      2018-08-19 21:13:13.246 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 ()
                      2018-08-19 21:13:13.246 - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
                        thomson
                        Das hatte ich auch erst so. Die grüne LED muss an bleiben. Probiere mal einen anderen USB Port.
                        • J Offline
                          J Riemann
                          @Knallix:
                          Habe nur den COM-Port eingetragen ( /dev/ttyACM0 ) `
                          Schau mal hier…
                          viewtopic.php?f=20&t=16223#p170268
                          ****Viele Grüße!
                          Jörg****
                          • K Offline
                            Knallix
                            Hallo ,
                            danke für die Hilfe.
                            Nach einem " npm rebuild "
                            Neuinstallation von Zigbee
                            und eintragen des langen Pfads , war alles i. O. :)
                            Node.js : Version 10.8.0
                            NPM : 6.4.0
                              bishop
                              läuft bei mir alles bis jetzt ganz gut, habe 3 Tradfri Deckenleuchten und 2x E14 Lampen im betriebe die ich auch schalten kann. Ist es auch möglich die Fernbedienungen zu benutzen für die einzelnen Lampen?
                                paul.honka
                                heute habe ich meinen CC2530 erfolgreich geflasht.
                                Im IO Broker läuft schon der CC2531. Der CC2530 soll als Verstärker/Router dienen, da die Antenne des
                                CC2531 bischen dürftig ist. Wie bekomme ich den CC2530 in IO Broker?
                                Habe schon versucht in der Instanz unter Zigbee, Konfiguration, das Pairing angestossen und dann Spannung auf den CC2530, kein Erfolg
                                Beste Grüsse paul
                                • FredFF Online
                                  FredFF Online
                                  FredF
                                  Most Active Forum Testing
                                  Was sagt den die LED?
                                  Led blinking for some states.
                                  short fast blinks (one per second) – router is connecting to a network.
                                  short long blinks (one per 4 seconds) – normal operations.
                                  three short blinks – the router cannot send a report to a coordinator.
                                  Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
                                    paul.honka
                                    eine LED leuchtet nicht auf dem CC2530.
                                    Beste Grüsse paul
                                    • FredFF Online
                                      FredFF Online
                                      FredF
                                      Ohne leuchtende/blinkende LED scheint dann was nicht zu stimmen.
                                      Es soll beim verbinden die LED schnell blinken und wenn Verbindung zu Router erfolgreich war, alle 4 sekunden.
                                      Spannungsversorgung funktioniert?
                                      Mehr kann ich derzeit auch nicht sagen, da ich im Urlaub bin. Mein CC2530 kam kurz zuvor, so das ich ihn nicht mehr flashen konnte [emoji21]
                                      Bin mal gespannt ob das flashen und einbinden in den io bei mir dann klappt.
                                      Mit Tapatalk von unterwegs
                                        paul.honka
                                        Hallo, habe den CC2530 nochmals geflasht, Vergleich war ok.
                                        Habe jetzt den CC2530 nur noch mit 3,3V und GND von einem FTI versogt.
                                        Keine LED ist auf dm CC2530 an oder blinkt. CC2530 def.???
                                        Beste Grüsse paul
                                        • K Offline
                                          klaus
                                          Habe auch den CC2530 als Router geflasht erkannt wurde er auch nach ein Paar versuchen mit ein und ausschalten aber unter Objekte erscheint er mit false !!!
                                          wie erkenne ich ober er funktioniert ????? :roll:
