  4. IoBroker.zigbee Adapter - Gateway?
81 Beiträge 33 Kommentatoren 34.9k Aufrufe 7 Beobachtet
  • Jey CeeJ Offline
    Jey CeeJ Offline
    Jey Cee
    Sieht eher nach einem Problem mit dem npm Paket serialport aus:
    Caught	2018-08-19 18:11:48.088	error	by controller[0]: NODE_MODULE_VERSION 57\. Please try re-compiling or re-installing
    Caught	2018-08-19 18:11:48.088	error	by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
    Caught	2018-08-19 18:11:48.088	error	by controller[0]: was compiled against a different Node.js version using
    Die Log Ausgabe ist hier leider beschnitten um es sicher sagen zu können. Schau mal in die Log Datei.
    Persönlicher Support
    Spenden -> paypal.me/J3YC33
      Knallix
      Habe nur den COM-Port eingetragen ( /dev/ttyACM0 )
      Meinst du das so ?
      2018-08-19 21:12:42.243 - info: host.raspberrypi Restart adapter system.adapter.zigbee.0 because enabled
      2018-08-19 21:12:56.418 - info: host.raspberrypi object change system.adapter.zigbee.0
      2018-08-19 21:12:56.418 - info: host.raspberrypi "system.adapter.zigbee.0" disabled
      2018-08-19 21:13:13.243 - error: Caught by controller[0]: /opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:88
      2018-08-19 21:13:13.244 - error: Caught by controller[0]: throw e
      2018-08-19 21:13:13.244 - error: Caught by controller[0]: ^
      2018-08-19 21:13:13.244 - error: Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/serialport/build/Release/serialport.node'
      2018-08-19 21:13:13.244 - error: Caught by controller[0]: was compiled against a different Node.js version using
      2018-08-19 21:13:13.244 - error: Caught by controller[0]: NODE_MODULE_VERSION 48\. This version of Node.js requires
      2018-08-19 21:13:13.244 - error: Caught by controller[0]: NODE_MODULE_VERSION 64\. Please try re-compiling or re-installing
      2018-08-19 21:13:13.244 - error: Caught by controller[0]: the module (for instance, using `npm rebuild` or `npm install`).
      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:718:18)
      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:599:32)
      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at tryModuleLoad (internal/modules/cjs/loader.js:538:12)
      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:530:3)
      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:637:17)
      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at require (internal/modules/cjs/helpers.js:20:18)
      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at bindings (/opt/iobroker/node_modules/serialport/node_modules/bindings/bindings.js:81:44)
      2018-08-19 21:13:13.245 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/serialport/lib/bindings/linux.js:2:36)
      2018-08-19 21:13:13.246 - error: Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:689:30)
      2018-08-19 21:13:13.246 - error: Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:700:10)
      2018-08-19 21:13:13.246 - error: host.raspberrypi instance system.adapter.zigbee.0 terminated with code 1 ()
      2018-08-19 21:13:13.246 - info: host.raspberrypi Do not restart adapter system.adapter.zigbee.0 because disabled or deleted
        thomson
        Das hatte ich auch erst so. Die grüne LED muss an bleiben. Probiere mal einen anderen USB Port.
        • J Offline
          J Riemann
          @Knallix:
          Habe nur den COM-Port eingetragen ( /dev/ttyACM0 ) `
          Schau mal hier…
          viewtopic.php?f=20&t=16223#p170268
          ****Viele Grüße!
          Jörg****
            Knallix
            Hallo ,
            danke für die Hilfe.
            Nach einem " npm rebuild "
            Neuinstallation von Zigbee
            und eintragen des langen Pfads , war alles i. O. :)
            Node.js : Version 10.8.0
            NPM : 6.4.0
              bishop
              läuft bei mir alles bis jetzt ganz gut, habe 3 Tradfri Deckenleuchten und 2x E14 Lampen im betriebe die ich auch schalten kann. Ist es auch möglich die Fernbedienungen zu benutzen für die einzelnen Lampen?
              • P Offline
                paul.honka
                heute habe ich meinen CC2530 erfolgreich geflasht.
                Im IO Broker läuft schon der CC2531. Der CC2530 soll als Verstärker/Router dienen, da die Antenne des
                CC2531 bischen dürftig ist. Wie bekomme ich den CC2530 in IO Broker?
                Habe schon versucht in der Instanz unter Zigbee, Konfiguration, das Pairing angestossen und dann Spannung auf den CC2530, kein Erfolg
                Beste Grüsse paul
                • FredFF Online
                  FredFF Online
                  FredF
                  Most Active Forum Testing
                  Was sagt den die LED?
                  Led blinking for some states.
                  short fast blinks (one per second) – router is connecting to a network.
                  short long blinks (one per 4 seconds) – normal operations.
                  three short blinks – the router cannot send a report to a coordinator.
                  Gesendet von meinem HUAWEI VNS-L31 mit Tapatalk
                  • P Offline
                    paul.honka
                    eine LED leuchtet nicht auf dem CC2530.
                    Beste Grüsse paul
                    • FredFF Online
                      FredFF Online
                      FredF
                      Ohne leuchtende/blinkende LED scheint dann was nicht zu stimmen.
                      Es soll beim verbinden die LED schnell blinken und wenn Verbindung zu Router erfolgreich war, alle 4 sekunden.
                      Spannungsversorgung funktioniert?
                      Mehr kann ich derzeit auch nicht sagen, da ich im Urlaub bin. Mein CC2530 kam kurz zuvor, so das ich ihn nicht mehr flashen konnte [emoji21]
                      Bin mal gespannt ob das flashen und einbinden in den io bei mir dann klappt.
                      Mit Tapatalk von unterwegs
                      • P Offline
                        paul.honka
                        Hallo, habe den CC2530 nochmals geflasht, Vergleich war ok.
                        Habe jetzt den CC2530 nur noch mit 3,3V und GND von einem FTI versogt.
                        Keine LED ist auf dm CC2530 an oder blinkt. CC2530 def.???
                        Beste Grüsse paul
                          klaus
                          Habe auch den CC2530 als Router geflasht erkannt wurde er auch nach ein Paar versuchen mit ein und ausschalten aber unter Objekte erscheint er mit false !!!
                          wie erkenne ich ober er funktioniert ????? :roll:
                          • E Offline
                            Einklaus
                            gibt es hier die Möglichkeit einen schon geflashten Adapter zu erstehen bzw. wenn ich mir einen ZigBee CC253x Adapter besorge den Flashen zulassen ?
                            Habe ein Xiaomi Gateway und mir gefällt das ET-Syndrom (nach Hause telefonieren) vom Gateway nicht wirklich.
                            Die Flexibilität an sich scheint ja auch enorm zu sein, als mehr als sinnvoll umzusteigen.
                            (Ein)Klaus
                            Suche Mitleidende in der Nähe von Buxtehude / Apensen / Harsefeld zum Erfahrungs- /Ideenaustausch ...............
                            Iobroker über Window 10 (Mini PC),EZ-Control (FS20), Siemens Logo, Wolf ISM8 , Xiaomi Sauger, Fluoreon Wifi Heizregler , Zigbee (Xiaomi,HUE). Landroid WR141E, Tuya
                              Makkoo86
                              ich habe gestern den CC2530 bekommen und habe ihn geflasht (CC2530ZNP-Pro-Secure_LinkKeyJoin_mod.hex) und habe ihn an meinen Iobroker System eingehangen (Proxmox 5.2.1 Debian OS ,USB durchgereicht)
                              Habe USB-TTL Stick mit den CC2530 verbunden, wird auch in der VM angezeigt:
                              Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
                              Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                              Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                              Bus 002 Device 005: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
                              Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                              Bus 001 Device 002: ID 0627:0001 Adomax Technology Co., Ltd
                              Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
                              In dem Adapter habe ich die lange Veriante des com-ports augsewählt:
                              /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
                              Ampel wird nach refresh Gelb angezeigt und ich bekomme folgendes im Log (start und Versuch pairing)
                              zigbee.0 2018-09-20 21:20:36.871 error Join failure.. Error: Shepherd is not enabled.
                              zigbee.0 2018-09-20 21:20:36.863 info Zigbee: allowing new devices to join.
                              zigbee.0 2018-09-20 21:20:26.100 info Start on port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0 with panID 6754 channel 11
                              zigbee.0 2018-09-20 21:20:26.087 info starting. Version 0.7.1 in /opt/iobroker/node_modules/iobroker.zigbee, node: v8.12.0
                              host.Debian-Iobroker 2018-09-20 21:20:24.592 info instance system.adapter.zigbee.0 started with pid 1406
                              host.Debian-Iobroker 2018-09-20 21:20:22.114 info instance system.adapter.zigbee.0 terminated with code 0 (OK)
                              Caught 2018-09-20 21:20:22.113 error by controller[1]: Thu, 20 Sep 2018 19:20:22 GMT zigbee:controller info zigbee-shepherd stopped undefined
                              zigbee.0 2018-09-20 21:20:22.088 info zigbee-shepherd stopped
                              host.Debian-Iobroker 2018-09-20 21:20:22.081 info stopInstance system.adapter.zigbee.0 killing pid 1396
                              ****Edit:
                              Habe es hintbekommen falsche Firmware(CC2530ZNP-Pro-Secure_LinkKeyJoin.hex) und Rx und TX sind auf den CC2530 vertauscht :)****
                              Grüß
                              Marco
                                assid
                                wer Hilfe beim Flashen eines CC2531 Zigbee Sticks benötigt, oder einen fertigen Stick für zB. den ioBroker haben möchte, einfach eine PM an mich. Ich biete euch meine Hilfe an.
                                  Matthias.He
                                  @assid:
                                  Grüße `
                                  Hätte interesse an einen fertig geflashten CC2531 Zigbee Stick für ioBroker. Kann dir aber leider keine Nachricht schicken
                                    mz4
                                    @assid:
                                    Grüße `
                                    Hätte auch Interesse an einem Stick. (mit oder ohne externe Antenne?)
                                    • R Offline
                                      ramses
                                      Ach so ein Mist. jetzt ist alles aus China hier und dann stellt sich raus man brauch für den CC2531 auch noch ein "Download Cable" …
                                      also noch mal 6 Wochen auf Chinaware warten kotz :evil:
                                      • arteckA Offline
                                        arteckA Offline
                                        arteck
                                        @ramses:
                                        also noch mal 6 Wochen auf Chinaware warten kotz :evil: `
                                        den Debuger hast du ??
                                        • R Offline
                                          ramses
                                          @arteck:
                                          @ramses:
                                          den Debuger hast du ?? `
                                          Jop den habe ich. Hab nur vergessen das Download-Cable zu bestellen. Vermutlich geht es irgendwie bestimmt auch ohne, da das ding irgendwie nur wie ein Adapter fungiert von große Pinne auf kleine Pinne. Aber bevor ich jetzt große Bastelaktionen starte, warten wir erneut auf Ebay :-)
