  4. Test Adapter TP-Link Tapo
891 Beiträge 124 Kommentatoren 497.8k Aufrufe 108 Beobachtet
  • T tombox
    @mrbungle64 Eigenartig das sind ja lokale api warum ist da ein rate limit drauf
    mrbungle64M
    mrbungle64M
    mrbungle64
    schrieb am zuletzt editiert von mrbungle64
    #129
    @tombox sagte in Test Adapter TP-Link Tapo:
    Ich denke, dass das im Zusammenhang mit diesen Fehlern auftritt:
    2022-11-23 21:09:00.027  - info: tapo.0 (479641) Scheduled restart.
    2022-11-23 21:09:00.053  - info: tapo.0 (479641) terminating
    2022-11-23 21:09:00.056  - info: tapo.0 (479641) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-23 21:09:00.569  - warn: tapo.0 (479641) get state error: Connection is closed.
    2022-11-23 21:09:00.581  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.04": DB closed
    2022-11-23 21:09:00.583  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.03: DB closed
    2022-11-23 21:09:00.584  - warn: tapo.0 (479641) get state error: Connection is closed.
    2022-11-23 21:09:00.587  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.04: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.04": DB closed
    2022-11-23 21:09:00.592  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.05": Connection is closed.
    2022-11-23 21:09:00.595  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.04: DB closed
    2022-11-23 21:09:00.597  - warn: tapo.0 (479641) get state error: Connection is closed.
    2022-11-23 21:09:00.598  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.05: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.05": Connection is closed.
    2022-11-23 21:09:00.602  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.06": Connection is closed.
    2022-11-23 21:09:00.604  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.05: DB closed
    2022-11-23 21:09:00.605  - warn: tapo.0 (479641) get state error: Connection is closed.
    2022-11-23 21:09:00.606  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.06: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.06": Connection is closed.
    2022-11-23 21:09:01.287  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
    2022-11-23 21:09:01.290  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
    2022-11-23 21:09:02.882  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 479711
    2022-11-23 21:09:07.324  - info: tapo.0 (479711) starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#5869cef8f69a857a6c4970d13573d0a5edcba1d6) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
    2022-11-23 21:09:07.737  - info: tapo.0 (479711) Login tp TAPO App
    2022-11-23 21:09:08.262  - info: tapo.0 (479711) Login succesfull
    2022-11-23 21:09:08.492  - info: tapo.0 (479711) Found 3 devices
    2022-11-23 21:09:08.861  - info: tapo.0 (479711) Init device 8022xxxCF04 type P115 with ip 192.168.0.115
    2022-11-23 21:09:08.961  - info: tapo.0 (479711) Initialized 8022xxxCF04
    2022-11-23 21:09:09.253  - info: tapo.0 (479711) Init device 8022xxxDD97 type P115 with ip 192.168.0.117
    2022-11-23 21:09:09.355  - info: tapo.0 (479711) Initialized 8022xxxDD97
    2022-11-23 21:09:09.716  - info: tapo.0 (479711) Init device 8022xxx4523 type P115 with ip 192.168.0.116
    2022-11-23 21:09:09.818  - info: tapo.0 (479711) Initialized 8022xxx4523
    2022-11-23 21:09:09.991  - info: tapo.0 (479711) Wait for connections
    2022-11-23 21:10:00.052  - info: tapo.0 (479711) Scheduled restart.
    2022-11-23 21:10:00.170  - info: tapo.0 (479711) terminating
    2022-11-23 21:10:00.175  - info: tapo.0 (479711) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2022-11-23 21:10:00.702  - warn: tapo.0 (479711) get state error: Connection is closed.
    2022-11-23 21:10:00.713  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.04": DB closed
    2022-11-23 21:10:00.716  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.03: DB closed
    2022-11-23 21:10:00.718  - warn: tapo.0 (479711) get state error: Connection is closed.
    2022-11-23 21:10:00.720  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.04: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.04": DB closed
    2022-11-23 21:10:00.726  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.05": Connection is closed.
    2022-11-23 21:10:00.728  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.04: DB closed
    2022-11-23 21:10:00.729  - warn: tapo.0 (479711) get state error: Connection is closed.
    2022-11-23 21:10:00.730  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.05: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.05": Connection is closed.
    2022-11-23 21:10:00.735  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.06": Connection is closed.
    2022-11-23 21:10:00.737  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.05: DB closed
    2022-11-23 21:10:00.738  - warn: tapo.0 (479711) get state error: Connection is closed.
    2022-11-23 21:10:00.740  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.06: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.06": Connection is closed.
    2022-11-23 21:10:01.408  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
    2022-11-23 21:10:01.409  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
    2022-11-23 21:10:03.445  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 479768
    2022-11-23 21:10:08.789  - info: tapo.0 (479768) starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#5869cef8f69a857a6c4970d13573d0a5edcba1d6) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
    2022-11-23 21:10:09.164  - info: tapo.0 (479768) Login tp TAPO App
    2022-11-23 21:10:09.565  - error: tapo.0 (479768) Login failed
    2022-11-23 21:10:09.569  - error: tapo.0 (479768) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
    Das tritt mehrmals am Tag auf und die Instanz startet dann immer neu.
    Zur Info: das hier ist mit der GitHub Version. Die hatte ich installiert, weil genau das auch schon vorher mit der npm-Version aufgetreten ist.
    • mrbungle64M mrbungle64
      T
      T
      tombox
      #130
      @mrbungle64 Ja anscheinend wird der adapter jede minute neugestartet
      mrbungle64M 1 Antwort Letzte Antwort
      • T tombox
        mrbungle64M
        mrbungle64M
        mrbungle64
        #131
        Ich habe diese Datenpunkte jetzt mal gelöscht. Mal schauen wie es morgen läuft.
        Muss ja jetzt erst mal mind. 30 Minuten warten ;)
          T
          T
          tombox
          #132
          @mrbungle64 Bitte auch den tapo.0 (479641) Scheduled restart rausnehmen
          • G
            G
            Gabe
            #133
            Mit den Änderung die Tombox vorgenommen hat, funktioniert bei mir jetzt alles gut. Danke dir
            • G Gabe
              T
              T
              tombox
              #134
              @gabe also motionDetection wird auch immer korrekt gesetzt bei Bewegung und es gibt die states
              alert
              lensMask
              forceWhiteLamp
              ra juhaR G 2 Antworten Letzte Antwort
              • T tombox
                alert
                lensMask
                forceWhiteLamp
                ra juhaR
                ra juhaR
                ra juha
                #135
                @tombox: Wow. Sieht gut aus! Danke. Kann nun Alarm und Privatspäre toggeln. Super!!!
                • T tombox
                  alert
                  lensMask
                  forceWhiteLamp
                  G
                  G
                  Gabe
                  #136
                  @tombox
                  also ich nutze hauptsächlich lensMask und AlertConfig und das funktioniert super.
                  Aber auch motionEvent passt bei mir.
                  Gruß und Danke!!!
                  • T tombox
                    mrbungle64M
                    mrbungle64M
                    mrbungle64
                    #137
                    Guter Hinweis - seitdem ich die raus genommen habe läuft es scheinbar fehlerfrei durch (bisher) 👍
                    Aber warum wirken sich 3 Scheduled restarts am Tag so extrem negativ aus?
                      T
                      T
                      tombox
                      #138
                      @mrbungle64 Er war nicht auf 3 mal eingestellt sondern jede Minute
                      • T tombox
                        mrbungle64M
                        mrbungle64M
                        mrbungle64
                        #139
                        Ich verstehe, dass das in dem Log Auszug so aussieht - aber das war nicht so eingestellt.
                        Es war auf 9 Uhr und 21 Uhr eingestellt + dass ich zusätzlich Nachts die Instanz per Skript gestoppt hatte.
                        Die Probleme fingen um 9 Uhr (nach dem 1. Scheduled restart) an und dann hat sich die Instanz jede Minute aus irgendwelchen Gründen neu gestartet.
                        Hier noch mal ein Auszug aus dem Log um 9 Uhr inkl. den letzten Einträgen davor. Die waren von 8:45 - und ab 9 Uhr hat sich die tapo Instanz dann jede Minute neu gestartet
                        2022-11-23 08:45:06.257  - info: vanmoof-webapi.0 (465342) Terminated (NO_ERROR): Without reason
                        2022-11-23 08:45:06.830  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 terminated with code 0 (NO_ERROR)
                        2022-11-23 09:00:00.119  - info: tapo.0 (464412) Scheduled restart.
                        2022-11-23 09:00:00.244  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 started with pid 465595
                        2022-11-23 09:00:00.433  - info: tapo.0 (464412) terminating
                        2022-11-23 09:00:00.437  - info: tapo.0 (464412) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                        2022-11-23 09:00:00.955  - warn: tapo.0 (464412) get state error: Connection is closed.
                        2022-11-23 09:00:00.965  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.14": DB closed
                        2022-11-23 09:00:00.968  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.13: DB closed
                        2022-11-23 09:00:00.970  - warn: tapo.0 (464412) get state error: Connection is closed.
                        2022-11-23 09:00:00.972  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.14: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.14": DB closed
                        2022-11-23 09:00:00.978  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": Connection is closed.
                        2022-11-23 09:00:00.981  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.14: DB closed
                        2022-11-23 09:00:00.982  - warn: tapo.0 (464412) get state error: Connection is closed.
                        2022-11-23 09:00:00.983  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.15: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": Connection is closed.
                        2022-11-23 09:00:00.988  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
                        2022-11-23 09:00:00.990  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.15: DB closed
                        2022-11-23 09:00:00.991  - warn: tapo.0 (464412) get state error: Connection is closed.
                        2022-11-23 09:00:00.992  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.16: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
                        2022-11-23 09:00:02.442  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
                        2022-11-23 09:00:02.444  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
                        2022-11-23 09:00:04.337  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 465623
                        2022-11-23 09:00:05.659  - info: vanmoof-webapi.0 (465595) starting. Version 0.0.1 (non-npm: mrbungle64/ioBroker.vanmoof-webapi#7191e9a468c074a159c4e8468d731016437e2128) in /opt/iobroker/node_modules/iobroker.vanmoof-webapi, node: v16.18.1, js-controller: 4.0.23
                        2022-11-23 09:00:06.620  - info: vanmoof-webapi.0 (465595) Processing data for account: 'Sascha Hölzel'
                        2022-11-23 09:00:06.795  - info: vanmoof-webapi.0 (465595) Number of bikes: 1
                        2022-11-23 09:00:06.798  - info: vanmoof-webapi.0 (465595) Processing data for Bike #1 (id: 160905):
                        2022-11-23 09:00:09.456  - info: vanmoof-webapi.0 (465595) Terminated (NO_ERROR): Without reason
                        2022-11-23 09:00:10.100  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 terminated with code 0 (NO_ERROR)
                        2022-11-23 09:00:13.557  - info: tapo.0 (465623) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                        2022-11-23 09:00:13.986  - info: tapo.0 (465623) Login tp TAPO App
                        2022-11-23 09:00:14.614  - info: tapo.0 (465623) Login succesfull
                        2022-11-23 09:00:14.836  - info: tapo.0 (465623) Found 3 devices
                        2022-11-23 09:00:15.154  - info: tapo.0 (465623) Init device 8022xxxCF04 type P115 with ip 192.168.0.115
                        2022-11-23 09:00:15.473  - info: tapo.0 (465623) Initialized 8022xxxCF04
                        2022-11-23 09:00:15.716  - info: tapo.0 (465623) Init device 8022xxxxDD97 type P115 with ip 192.168.0.117
                        2022-11-23 09:00:15.933  - info: tapo.0 (465623) Initialized 8022xxxxDD97
                        2022-11-23 09:00:16.187  - info: tapo.0 (465623) Init device 8022xxxx4523 type P115 with ip 192.168.0.116
                        2022-11-23 09:00:16.318  - info: tapo.0 (465623) Initialized 8022xxxx4523
                        2022-11-23 09:00:16.433  - info: tapo.0 (465623) Wait for connections
                        2022-11-23 09:01:00.026  - info: tapo.0 (465623) Scheduled restart.
                        Ergänzung:
                        Ich vermute mal, dass der Scheduled Restart jede Minute nachgeholt wird, weil der Restart ja jeweils nicht erfolgreich ausgeführt werden konnte. Ist aber nur ein Gedanke was der Hintergrund von den minütlichen Neustarts sein könnte...
                        • T tombox
                          Hi ich habe ein neuen Adapter für TP-Link die mit der Tapo App überwacht werden können, geschrieben.
                          Der Adapter loggt sich über die Cloud ein um alle Geräte mit IP zu finden
                          Wenn das Gerät nicht als online erkannt wird kann manuell die IP gesetzt wird.
                          tapo.0.id.ip
                          Dann versucht er sich lokal mit username und Password auf die Geräte zu verbinden und zu steuern.
                          Aktuelle Werte:
                          tapo.0.id
                          Motion Detection funktioniert mit Stream User und Password
                          Minimum Node v14 muss installiert sein, sonst bekommt man exit code 25 beim installieren
                          Zum Installieren:
                          https://github.com/TA2k/ioBroker.tapo
                          Loginablauf:
                          Die Tapo App Zugangsdaten eingeben
                          Steuern
                          tapo.0.id.remote auf true setzen steuert den jeweiligen Befehl
                          Steckdose und Kamerasteuerung aktivieren
                          App auf Handy aufrufen
                          "ich" (rechts unten) aufrufen
                          "Dienste"
                          "Dienste von Drittanbietern"
                          "Kompatibilität mit Drittanbietern" auf "ON"
                          H
                          H
                          helfi9999
                          #140
                          tapo.0.id.ip
                          Aktuelle Werte:
                          tapo.0.id
                          Zum Installieren:
                          Unter Adapter Experten Modus aktivieren:
                          Unter Adapter das Github Icon klicken:
                          Benutzerdefiniert auswählen und die Url einfügen.
                          Dann unter Adapter den tapo Adapter suchen und ganz rechts auf das Plus klicken.
                          Loginablauf:
                          Steuern
                          Hallo habe es so wie deine Anleitung gemacht. Adapter wird nicht grün und folgende Log Meldung bekomme ich :
                          tapo.0
                          2022-11-26 14:42:53.750	info	Wait for connections
                          tapo.0
                          2022-11-26 14:42:53.736	warn	Login failed using cached device list
                          tapo.0
                          2022-11-26 14:42:53.735	error	Please set mfa in the instance settings
                          tapo.0
                          2022-11-26 14:42:53.723	info	Login tp TAPO App
                          tapo.0
                          2022-11-26 14:42:53.622	info	starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#8bb2e108a00246ade916287de7d71947043d3482) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                          host.Iobroker
                          2022-11-26 14:42:49.574	info	instance system.adapter.tapo.0 started with pid 40464
                          host.Iobroker
                          2022-11-26 14:42:47.060	info	instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.Iobroker
                          2022-11-26 14:42:46.425	info	stopInstance system.adapter.tapo.0 send kill signal
                          tapo.0
                          2022-11-26 14:42:46.268	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          tapo.0
                          2022-11-26 14:42:46.265	info	terminating
                          tapo.0
                          2022-11-26 14:42:46.262	info	Got terminate signal TERMINATE_YOURSELF
                          Könntest du mir bitte sagen was ich verkehrt mache??
                          Gruss helfi
                          Intel NUC mit Iobroker
                          • T
                            T
                            tombox
                            #141
                            @helfi9999 Du hast sicher MFA aktiv. Ich habe das nur blind eingebaut und ist bisher ungerüstet und geht anscheinend nicht
                            H 1 Antwort Letzte Antwort
                            • T tombox
                              H
                              H
                              helfi9999
                              #142
                              hi, wo stelle ich den MFA ein, und ohne läuft der Adapter nicht.
                              • H helfi9999
                                T
                                T
                                tombox
                                #143
                                @helfi9999 Der Adapter läuft nicht MIT MFA man müsste es also ausstellen
                                • T tombox
                                  H
                                  H
                                  helfi9999
                                  schrieb am zuletzt editiert von helfi9999
                                  #144
                                  Sorry wenn ich so blöd frage wo mache ich das im Adapter??
                                  CodierknechtC T 2 Antworten Letzte Antwort
                                  • H helfi9999
                                    CodierknechtC
                                    CodierknechtC
                                    Codierknecht
                                    #145
                                    @helfi9999 sagte in Test Adapter TP-Link Tapo:
                                    Nicht im Adapter, sondern in der Tapo-App.
                                    HmIP|ZigBee|Tasmota|Unifi
                                    Zabbix Certified Specialist
                                    • H helfi9999
                                      T
                                      T
                                      tombox
                                      #146
                                      @helfi9999 im Adapter gar nicht in deine tplink Profil Einstellungen
                                      • T tombox
                                        H
                                        H
                                        helfi9999
                                        #147
                                        Hi könntest du mir genau sagen wo in der app ???
                                        • T tombox
                                          tapo.0.id.ip
                                          Aktuelle Werte:
                                          tapo.0.id
                                          Zum Installieren:
                                          Loginablauf:
                                          Steuern
                                          "Dienste"
                                          H
                                          H
                                          helfi9999
                                          #148
                                          @tombox habe es endlich hinbekommen, das müsste auch gesagt werden das der Verifizierungscode raus genommen werden muss. 👍 😞 😊
                                          Gruss helfi
                                          84.2k
