  4. Test Adapter TP-Link Tapo
    apollon77A
887 Beiträge 123 Kommentatoren 455.3k Aufrufe 107 Beobachtet
  • P pfahlenbauer
    @tombox Ich habe ähnliche Probleme mit meinen Kamera's. Ich würde gerne die Strahler der Kameras (C320WS) ein- und ausschalten. Aber mir scheint auch es gibt Verbindungsprobleme. Auch wenn ich in der Tapo App Änderungen vornehme (z.B. Leuchtstärke), so ändert sich das iobroker Object "set brightness" nicht.
    Hier aus meinem Log:
    tapo.0
    2022-11-22 17:01:42.209	info	Wait for connections
    tapo.0
    2022-11-22 17:01:42.163	error	52 - Get Device Info failed
    tapo.0
    2022-11-22 17:01:42.162	info	Initialized 80217D4F5XXXXXXXXXXXX
    tapo.0
    2022-11-22 17:01:42.161	error	111 Error: connect ECONNREFUSED 192.168.178.110:80
    tapo.0
    2022-11-22 17:01:41.946	info	Unknown device type C320WS init as P100
    tapo.0
    2022-11-22 17:01:41.945	info	Init device 80217D4F5XXXXXXXXXXXXXXX type C320WS with ip 192.168.178.110
    tapo.0
    2022-11-22 17:01:41.744	error	52 - Get Device Info failed
    tapo.0
    2022-11-22 17:01:41.743	info	Initialized 8021AE79E9XXXXXXXXXXXXXXX
    tapo.0
    2022-11-22 17:01:41.742	error	111 Error: connect ECONNREFUSED 192.168.178.113:80
    tapo.0
    2022-11-22 17:01:41.542	info	Unknown device type C320WS init as P100
    tapo.0
    2022-11-22 17:01:41.541	info	Init device 8021AE79XXXXXXXXXXXXXXXXX type C320WS with ip 192.168.178.113
    tapo.0
    2022-11-22 17:01:41.366	error	52 - Get Device Info failed
    tapo.0
    2022-11-22 17:01:41.366	info	Initialized 80214550BEEXXXXXXXXXXXXXXXX
    tapo.0
    2022-11-22 17:01:41.363	error	111 Error: connect ECONNREFUSED 192.168.178.109:80
    tapo.0
    2022-11-22 17:01:41.238	info	Unknown device type C210 init as P100
    tapo.0
    2022-11-22 17:01:41.237	info	Init device 80214550BEEXXXXXXXXXXXXXXXX type C210 with ip 192.168.178.109
    tapo.0
    2022-11-22 17:01:41.011	info	Found 3 devices
    tapo.0
    2022-11-22 17:01:40.797	info	Login succesfull
    tapo.0
    2022-11-22 17:01:40.214	info	Login tp TAPO App
    tapo.0
    2022-11-22 17:01:40.153	info	starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.tapo, node: v14.20.0, js-controller: 4.0.23
    T
    T
    tombox
    #123
    @pfahlenbauer du musst die GitHub version installieren das man die strahler schalten kann habe ich noch nicht gesehen
    P 1 Antwort Letzte Antwort
    • T tombox
      P
      P
      pfahlenbauer
      #124
      @tombox Habe nun von GitHub installiert und bekomme den gleichen ONVIV SOAP faultwie @Gabe
      tapo.0
      2022-11-22 19:57:44.080	info	Wait for connections
      tapo.0
      2022-11-22 19:57:44.050	error	Error: ONVIF SOAP Fault: Authority failure
      tapo.0
      2022-11-22 19:57:43.952	info	Init device 80217D4F53XXXXXXXXXXXXXXXXXXXXXXXX type C320WS with ip 192.168.178.110
      tapo.0
      2022-11-22 19:57:43.687	error	Error: ONVIF SOAP Fault: Authority failure
      tapo.0
      2022-11-22 19:57:43.574	info	Init device 8021AE79E9CC0XXXXXXXXXXXXXXXX type C320WS with ip 192.168.178.113
      tapo.0
      2022-11-22 19:57:43.336	error	Error: ONVIF SOAP Fault: Authority failure
      tapo.0
      2022-11-22 19:57:43.189	info	Init device 80214550BEEXXXXXXXXXXXXXXXXXXXXX type C210 with ip 192.168.178.109
      tapo.0
      2022-11-22 19:57:42.921	info	Found 3 devices
      tapo.0
      2022-11-22 19:57:42.718	info	Login succesfull
      tapo.0
      2022-11-22 19:57:42.260	info	Login tp TAPO App
      tapo.0
      2022-11-22 19:57:42.196	info	starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#99bdbd2e2ba1bed5a907e1569e293924d49aef97) in /opt/iobroker/node_modules/iobroker.tapo, node: v14.20.0, js-controller: 4.0.23
      • P pfahlenbauer
        tapo.0
        tapo.0
        tapo.0
        tapo.0
        tapo.0
        tapo.0
        tapo.0
        tapo.0
        tapo.0
        tapo.0
        tapo.0
        T
        T
        tombox
        #125
        @pfahlenbauer ich habe noch eine version gebaut bei dem man den stream user eintragen kann was man anscheinend für die motion detection benötigt. für den strahler bräuchte ich Zugang zu einer Kamera um zu sehen welcher Befehl genau abgesetzt wird
        • T tombox
          P
          P
          pfahlenbauer
          #126
          @tombox Danke. Zugang zu meiner Kamera kann ich Dir geben. Schicke ich Dir per PN
          pfahlenbauer
          • T tombox
            Hi ich habe ein neuen Adapter für TP-Link die mit der Tapo App überwacht werden können, geschrieben.
            Der Adapter loggt sich über die Cloud ein um alle Geräte mit IP zu finden
            Wenn das Gerät nicht als online erkannt wird kann manuell die IP gesetzt wird.
            tapo.0.id.ip
            Dann versucht er sich lokal mit username und Password auf die Geräte zu verbinden und zu steuern.
            Aktuelle Werte:
            tapo.0.id
            Motion Detection funktioniert mit Stream User und Password
            Minimum Node v14 muss installiert sein, sonst bekommt man exit code 25 beim installieren
            Zum Installieren:
            https://github.com/TA2k/ioBroker.tapo
            Loginablauf:
            Die Tapo App Zugangsdaten eingeben
            Steuern
            tapo.0.id.remote auf true setzen steuert den jeweiligen Befehl
            Steckdose und Kamerasteuerung aktivieren
            App auf Handy aufrufen
            "ich" (rechts unten) aufrufen
            "Dienste"
            "Dienste von Drittanbietern"
            "Kompatibilität mit Drittanbietern" auf "ON"
            mrbungle64M
            mrbungle64M
            mrbungle64
            #127
            @tombox
            ich erreiche inzwischen recht schnell das "API rate limit".
            2022-11-23 21:30:14.067  - error: tapo.0 (480412) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
            2022-11-23 21:42:14.014  - error: tapo.0 (480804) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
            2022-11-23 21:59:28.199  - error: tapo.0 (481091) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
            Frage 1) Habt Ihr das auch schon gehabt?
            Frage 2) Welches Update-Intervall habt Ihr eingestellt?
            Ich hatte zuerst 10 Sekunden eingestellt - bis heute dann 15 Sekunden (bei 3 Tapo P115 Schaltsteckdosen)
            • mrbungle64M mrbungle64
              @tombox
              T
              T
              tombox
              #128
              @mrbungle64 Eigenartig das sind ja lokale api warum ist da ein rate limit drauf
              mrbungle64M 1 Antwort Letzte Antwort
              • T tombox
                mrbungle64M
                mrbungle64M
                mrbungle64
                schrieb am zuletzt editiert von mrbungle64
                #129
                @tombox sagte in Test Adapter TP-Link Tapo:
                Ich denke, dass das im Zusammenhang mit diesen Fehlern auftritt:
                2022-11-23 21:09:00.027  - info: tapo.0 (479641) Scheduled restart.
                2022-11-23 21:09:00.053  - info: tapo.0 (479641) terminating
                2022-11-23 21:09:00.056  - info: tapo.0 (479641) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2022-11-23 21:09:00.569  - warn: tapo.0 (479641) get state error: Connection is closed.
                2022-11-23 21:09:00.581  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.04": DB closed
                2022-11-23 21:09:00.583  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.03: DB closed
                2022-11-23 21:09:00.584  - warn: tapo.0 (479641) get state error: Connection is closed.
                2022-11-23 21:09:00.587  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.04: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.04": DB closed
                2022-11-23 21:09:00.592  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.05": Connection is closed.
                2022-11-23 21:09:00.595  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.04: DB closed
                2022-11-23 21:09:00.597  - warn: tapo.0 (479641) get state error: Connection is closed.
                2022-11-23 21:09:00.598  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.05: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.05": Connection is closed.
                2022-11-23 21:09:00.602  - error: tapo.0 (479641) Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.06": Connection is closed.
                2022-11-23 21:09:00.604  - warn: tapo.0 (479641) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d04.05: DB closed
                2022-11-23 21:09:00.605  - warn: tapo.0 (479641) get state error: Connection is closed.
                2022-11-23 21:09:00.606  - error: tapo.0 (479641) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d04.06: Cannot check object existence of "tapo.0.8022xxxDD97.past7d04.06": Connection is closed.
                2022-11-23 21:09:01.287  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
                2022-11-23 21:09:01.290  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
                2022-11-23 21:09:02.882  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 479711
                2022-11-23 21:09:07.324  - info: tapo.0 (479711) starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#5869cef8f69a857a6c4970d13573d0a5edcba1d6) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                2022-11-23 21:09:07.737  - info: tapo.0 (479711) Login tp TAPO App
                2022-11-23 21:09:08.262  - info: tapo.0 (479711) Login succesfull
                2022-11-23 21:09:08.492  - info: tapo.0 (479711) Found 3 devices
                2022-11-23 21:09:08.861  - info: tapo.0 (479711) Init device 8022xxxCF04 type P115 with ip 192.168.0.115
                2022-11-23 21:09:08.961  - info: tapo.0 (479711) Initialized 8022xxxCF04
                2022-11-23 21:09:09.253  - info: tapo.0 (479711) Init device 8022xxxDD97 type P115 with ip 192.168.0.117
                2022-11-23 21:09:09.355  - info: tapo.0 (479711) Initialized 8022xxxDD97
                2022-11-23 21:09:09.716  - info: tapo.0 (479711) Init device 8022xxx4523 type P115 with ip 192.168.0.116
                2022-11-23 21:09:09.818  - info: tapo.0 (479711) Initialized 8022xxx4523
                2022-11-23 21:09:09.991  - info: tapo.0 (479711) Wait for connections
                2022-11-23 21:10:00.052  - info: tapo.0 (479711) Scheduled restart.
                2022-11-23 21:10:00.170  - info: tapo.0 (479711) terminating
                2022-11-23 21:10:00.175  - info: tapo.0 (479711) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                2022-11-23 21:10:00.702  - warn: tapo.0 (479711) get state error: Connection is closed.
                2022-11-23 21:10:00.713  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.04": DB closed
                2022-11-23 21:10:00.716  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.03: DB closed
                2022-11-23 21:10:00.718  - warn: tapo.0 (479711) get state error: Connection is closed.
                2022-11-23 21:10:00.720  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.04: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.04": DB closed
                2022-11-23 21:10:00.726  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.05": Connection is closed.
                2022-11-23 21:10:00.728  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.04: DB closed
                2022-11-23 21:10:00.729  - warn: tapo.0 (479711) get state error: Connection is closed.
                2022-11-23 21:10:00.730  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.05: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.05": Connection is closed.
                2022-11-23 21:10:00.735  - error: tapo.0 (479711) Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.06": Connection is closed.
                2022-11-23 21:10:00.737  - warn: tapo.0 (479711) Could not perform strict object check of state tapo.0.8022xxxDD97.past7d06.05: DB closed
                2022-11-23 21:10:00.738  - warn: tapo.0 (479711) get state error: Connection is closed.
                2022-11-23 21:10:00.740  - error: tapo.0 (479711) Error: Could not check object existence of tapo.0.8022xxxDD97.past7d06.06: Cannot check object existence of "tapo.0.8022xxxDD97.past7d06.06": Connection is closed.
                2022-11-23 21:10:01.408  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
                2022-11-23 21:10:01.409  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
                2022-11-23 21:10:03.445  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 479768
                2022-11-23 21:10:08.789  - info: tapo.0 (479768) starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#5869cef8f69a857a6c4970d13573d0a5edcba1d6) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                2022-11-23 21:10:09.164  - info: tapo.0 (479768) Login tp TAPO App
                2022-11-23 21:10:09.565  - error: tapo.0 (479768) Login failed
                2022-11-23 21:10:09.569  - error: tapo.0 (479768) {"error_code":0,"result":{"lockedMinutes":30,"errorCode":"-20004","errorMsg":"API rate limit exceeded"}}
                Das tritt mehrmals am Tag auf und die Instanz startet dann immer neu.
                Zur Info: das hier ist mit der GitHub Version. Die hatte ich installiert, weil genau das auch schon vorher mit der npm-Version aufgetreten ist.
                  T
                  T
                  tombox
                  #130
                  @mrbungle64 Ja anscheinend wird der adapter jede minute neugestartet
                  • T tombox
                    mrbungle64M
                    mrbungle64M
                    mrbungle64
                    #131
                    Ich habe diese Datenpunkte jetzt mal gelöscht. Mal schauen wie es morgen läuft.
                    Muss ja jetzt erst mal mind. 30 Minuten warten ;)
                      T
                      T
                      tombox
                      #132
                      @mrbungle64 Bitte auch den tapo.0 (479641) Scheduled restart rausnehmen
                      • G
                        G
                        Gabe
                        #133
                        Mit den Änderung die Tombox vorgenommen hat, funktioniert bei mir jetzt alles gut. Danke dir
                        • G Gabe
                          T
                          T
                          tombox
                          #134
                          @gabe also motionDetection wird auch immer korrekt gesetzt bei Bewegung und es gibt die states
                          alert
                          lensMask
                          forceWhiteLamp
                          ra juhaR G 2 Antworten Letzte Antwort
                          • T tombox
                            alert
                            lensMask
                            forceWhiteLamp
                            ra juhaR
                            ra juhaR
                            ra juha
                            #135
                            @tombox: Wow. Sieht gut aus! Danke. Kann nun Alarm und Privatspäre toggeln. Super!!!
                            • T tombox
                              alert
                              lensMask
                              forceWhiteLamp
                              G
                              G
                              Gabe
                              #136
                              @tombox
                              also ich nutze hauptsächlich lensMask und AlertConfig und das funktioniert super.
                              Aber auch motionEvent passt bei mir.
                              Gruß und Danke!!!
                              • T tombox
                                mrbungle64M
                                mrbungle64M
                                mrbungle64
                                #137
                                Guter Hinweis - seitdem ich die raus genommen habe läuft es scheinbar fehlerfrei durch (bisher) 👍
                                Aber warum wirken sich 3 Scheduled restarts am Tag so extrem negativ aus?
                                  T
                                  T
                                  tombox
                                  #138
                                  @mrbungle64 Er war nicht auf 3 mal eingestellt sondern jede Minute
                                  • T tombox
                                    mrbungle64M
                                    mrbungle64M
                                    mrbungle64
                                    #139
                                    Ich verstehe, dass das in dem Log Auszug so aussieht - aber das war nicht so eingestellt.
                                    Es war auf 9 Uhr und 21 Uhr eingestellt + dass ich zusätzlich Nachts die Instanz per Skript gestoppt hatte.
                                    Die Probleme fingen um 9 Uhr (nach dem 1. Scheduled restart) an und dann hat sich die Instanz jede Minute aus irgendwelchen Gründen neu gestartet.
                                    Hier noch mal ein Auszug aus dem Log um 9 Uhr inkl. den letzten Einträgen davor. Die waren von 8:45 - und ab 9 Uhr hat sich die tapo Instanz dann jede Minute neu gestartet
                                    2022-11-23 08:45:06.257  - info: vanmoof-webapi.0 (465342) Terminated (NO_ERROR): Without reason
                                    2022-11-23 08:45:06.830  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 terminated with code 0 (NO_ERROR)
                                    2022-11-23 09:00:00.119  - info: tapo.0 (464412) Scheduled restart.
                                    2022-11-23 09:00:00.244  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 started with pid 465595
                                    2022-11-23 09:00:00.433  - info: tapo.0 (464412) terminating
                                    2022-11-23 09:00:00.437  - info: tapo.0 (464412) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                    2022-11-23 09:00:00.955  - warn: tapo.0 (464412) get state error: Connection is closed.
                                    2022-11-23 09:00:00.965  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.14": DB closed
                                    2022-11-23 09:00:00.968  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.13: DB closed
                                    2022-11-23 09:00:00.970  - warn: tapo.0 (464412) get state error: Connection is closed.
                                    2022-11-23 09:00:00.972  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.14: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.14": DB closed
                                    2022-11-23 09:00:00.978  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": Connection is closed.
                                    2022-11-23 09:00:00.981  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.14: DB closed
                                    2022-11-23 09:00:00.982  - warn: tapo.0 (464412) get state error: Connection is closed.
                                    2022-11-23 09:00:00.983  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.15: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.15": Connection is closed.
                                    2022-11-23 09:00:00.988  - error: tapo.0 (464412) Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
                                    2022-11-23 09:00:00.990  - warn: tapo.0 (464412) Could not perform strict object check of state tapo.0.8022xxxxDD97.past7d03.15: DB closed
                                    2022-11-23 09:00:00.991  - warn: tapo.0 (464412) get state error: Connection is closed.
                                    2022-11-23 09:00:00.992  - error: tapo.0 (464412) Error: Could not check object existence of tapo.0.8022xxxxDD97.past7d03.16: Cannot check object existence of "tapo.0.8022xxxxDD97.past7d03.16": Connection is closed.
                                    2022-11-23 09:00:02.442  - info: host.raspberrypi-3 instance system.adapter.tapo.0 scheduled normal terminated and will be restarted on schedule.
                                    2022-11-23 09:00:02.444  - info: host.raspberrypi-3 Restart adapter system.adapter.tapo.0 because enabled
                                    2022-11-23 09:00:04.337  - info: host.raspberrypi-3 instance system.adapter.tapo.0 started with pid 465623
                                    2022-11-23 09:00:05.659  - info: vanmoof-webapi.0 (465595) starting. Version 0.0.1 (non-npm: mrbungle64/ioBroker.vanmoof-webapi#7191e9a468c074a159c4e8468d731016437e2128) in /opt/iobroker/node_modules/iobroker.vanmoof-webapi, node: v16.18.1, js-controller: 4.0.23
                                    2022-11-23 09:00:06.620  - info: vanmoof-webapi.0 (465595) Processing data for account: 'Sascha Hölzel'
                                    2022-11-23 09:00:06.795  - info: vanmoof-webapi.0 (465595) Number of bikes: 1
                                    2022-11-23 09:00:06.798  - info: vanmoof-webapi.0 (465595) Processing data for Bike #1 (id: 160905):
                                    2022-11-23 09:00:09.456  - info: vanmoof-webapi.0 (465595) Terminated (NO_ERROR): Without reason
                                    2022-11-23 09:00:10.100  - info: host.raspberrypi-3 instance system.adapter.vanmoof-webapi.0 terminated with code 0 (NO_ERROR)
                                    2022-11-23 09:00:13.557  - info: tapo.0 (465623) starting. Version 0.0.6 in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                                    2022-11-23 09:00:13.986  - info: tapo.0 (465623) Login tp TAPO App
                                    2022-11-23 09:00:14.614  - info: tapo.0 (465623) Login succesfull
                                    2022-11-23 09:00:14.836  - info: tapo.0 (465623) Found 3 devices
                                    2022-11-23 09:00:15.154  - info: tapo.0 (465623) Init device 8022xxxCF04 type P115 with ip 192.168.0.115
                                    2022-11-23 09:00:15.473  - info: tapo.0 (465623) Initialized 8022xxxCF04
                                    2022-11-23 09:00:15.716  - info: tapo.0 (465623) Init device 8022xxxxDD97 type P115 with ip 192.168.0.117
                                    2022-11-23 09:00:15.933  - info: tapo.0 (465623) Initialized 8022xxxxDD97
                                    2022-11-23 09:00:16.187  - info: tapo.0 (465623) Init device 8022xxxx4523 type P115 with ip 192.168.0.116
                                    2022-11-23 09:00:16.318  - info: tapo.0 (465623) Initialized 8022xxxx4523
                                    2022-11-23 09:00:16.433  - info: tapo.0 (465623) Wait for connections
                                    2022-11-23 09:01:00.026  - info: tapo.0 (465623) Scheduled restart.
                                    Ergänzung:
                                    Ich vermute mal, dass der Scheduled Restart jede Minute nachgeholt wird, weil der Restart ja jeweils nicht erfolgreich ausgeführt werden konnte. Ist aber nur ein Gedanke was der Hintergrund von den minütlichen Neustarts sein könnte...
                                    • T tombox
                                      tapo.0.id.ip
                                      Aktuelle Werte:
                                      tapo.0.id
                                      Zum Installieren:
                                      Loginablauf:
                                      Steuern
                                      "Dienste"
                                      H
                                      H
                                      helfi9999
                                      #140
                                      tapo.0.id.ip
                                      Aktuelle Werte:
                                      tapo.0.id
                                      Zum Installieren:
                                      Unter Adapter Experten Modus aktivieren:
                                      Unter Adapter das Github Icon klicken:
                                      Benutzerdefiniert auswählen und die Url einfügen.
                                      Dann unter Adapter den tapo Adapter suchen und ganz rechts auf das Plus klicken.
                                      Loginablauf:
                                      Steuern
                                      Hallo habe es so wie deine Anleitung gemacht. Adapter wird nicht grün und folgende Log Meldung bekomme ich :
                                      tapo.0
                                      2022-11-26 14:42:53.750	info	Wait for connections
                                      tapo.0
                                      2022-11-26 14:42:53.736	warn	Login failed using cached device list
                                      tapo.0
                                      2022-11-26 14:42:53.735	error	Please set mfa in the instance settings
                                      tapo.0
                                      2022-11-26 14:42:53.723	info	Login tp TAPO App
                                      tapo.0
                                      2022-11-26 14:42:53.622	info	starting. Version 0.0.6 (non-npm: TA2k/ioBroker.tapo#8bb2e108a00246ade916287de7d71947043d3482) in /opt/iobroker/node_modules/iobroker.tapo, node: v16.18.1, js-controller: 4.0.23
                                      host.Iobroker
                                      2022-11-26 14:42:49.574	info	instance system.adapter.tapo.0 started with pid 40464
                                      host.Iobroker
                                      2022-11-26 14:42:47.060	info	instance system.adapter.tapo.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      host.Iobroker
                                      2022-11-26 14:42:46.425	info	stopInstance system.adapter.tapo.0 send kill signal
                                      tapo.0
                                      2022-11-26 14:42:46.268	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      tapo.0
                                      2022-11-26 14:42:46.265	info	terminating
                                      tapo.0
                                      2022-11-26 14:42:46.262	info	Got terminate signal TERMINATE_YOURSELF
                                      Könntest du mir bitte sagen was ich verkehrt mache??
                                      Gruss helfi
                                      Intel NUC mit Iobroker
                                      • T
                                        T
                                        tombox
                                        #141
                                        @helfi9999 Du hast sicher MFA aktiv. Ich habe das nur blind eingebaut und ist bisher ungerüstet und geht anscheinend nicht
                                        H 1 Antwort Letzte Antwort
                                        • T tombox
                                          H
                                          H
                                          helfi9999
                                          #142
                                          hi, wo stelle ich den MFA ein, und ohne läuft der Adapter nicht.
                                          83.9k
