  4. JavaScript
  5. [Skript] Absolute Feuchte berechnen
741 Beiträge 97 Kommentatoren 337.2k Aufrufe 82 Beobachtet
  • D3ltoroxpD D3ltoroxp
    In dieser Zeile steht.
       lueftenText = "Fenster zu:
    Ich habe das Script Spaß halber noch mal gestartet, dann hing erst kurz mein ioB und das war in der Log. Das war nachdem ich oben auf Expert Mode gegangen bin.
    host.iobroker
    	2022-11-10 17:03:29.419	error	instance system.adapter.javascript.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
    host.iobroker
    	2022-11-10 17:03:29.419	error	Caught by controller[0]: at processTimers (node:internal/timers:502:7)
    host.iobroker
    	2022-11-10 17:03:29.419	error	Caught by controller[0]: at listOnTimeout (node:internal/timers:559:17)
    host.iobroker
    	2022-11-10 17:03:29.419	error	Caught by controller[0]: at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/main.js:1180:50)
    host.iobroker
    	2022-11-10 17:03:29.419	error	Caught by controller[0]: at Array.forEach (<anonymous>)
    host.iobroker
    	2022-11-10 17:03:29.419	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/main.js:1182:70
    host.iobroker
    	2022-11-10 17:03:29.418	error	Caught by controller[0]: TypeError: Cannot create property 'setStatePerMinuteCounter' on boolean 'false'
    javascript.0
    	2022-11-10 17:03:24.246	error	Cannot create property 'setStatePerMinuteCounter' on boolean 'false'
    javascript.0
    	2022-11-10 17:03:24.246	error	TypeError: Cannot create property 'setStatePerMinuteCounter' on boolean 'false' at /opt/iobroker/node_modules/iobroker.javascript/main.js:1182:70 at Array.forEach (<anonymous>) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/main.js:1180:50) at listOnTimeout (node:internal/timers:559:17) at processTimers (node:internal/timers:502:7)
    javascript.0
    	2022-11-10 17:03:24.246	error	uncaught exception: Cannot create property 'setStatePerMinuteCounter' on boolean 'false'
    javascript.0
    	2022-11-10 17:03:19.324	error	at processImmediate (node:internal/timers:468:21)
    javascript.0
    	2022-11-10 17:03:19.324	error	at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1527:17)
    javascript.0
    	2022-11-10 17:03:19.324	error	at /opt/iobroker/node_modules/iobroker.javascript/main.js:2042:17
    javascript.0
    	2022-11-10 17:03:19.324	error	at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1954:37)
    javascript.0
    	2022-11-10 17:03:19.324	error	at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1702:24)
    javascript.0
    	2022-11-10 17:03:19.324	error	at Object.createScript (node:vm:265:10)
    javascript.0
    	2022-11-10 17:03:19.323	error	at new Script (node:vm:100:7)
    javascript.0
    	2022-11-10 17:03:19.323	error	SyntaxError: Invalid or unexpected token
    javascript.0
    	2022-11-10 17:03:19.323	error	^^^^^^^^^^^^
    javascript.0
    	2022-11-10 17:03:19.323	error	lueftenText = "Fenster zu:
    javascript.0
    	2022-11-10 17:03:19.323	error	script.js.Wetter.Lüftungsempfehlung_Taupunkt compile failed: at script.js.Wetter.Lüftungsempfehlung_Taupunkt:731
    #587
    @d3ltoroxp sagte in [Skript] Absolute Feuchte berechnen:
    und wann kommt das abschließende "?
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      #588
      das war in der Log.
      das wäre eben schon besser gewesen
      • D3ltoroxpD
        D3ltoroxpD
        D3ltoroxp
        schrieb am zuletzt editiert von D3ltoroxp
        #589
        @homoran Gute Frage, kenne mich mit so Javascripten überhaupt nicht aus. Wüsste auch nicht was ich an der Zeile gemacht haben sollte.
        Müsste so aussehen ?
        lueftenText = "Fenster zu:"
        Das stand vorher meines Wissens nicht drin. Erst beim zweiten mal starten.
          #590
          ich denke schon. kenne aber den Kontext nicht.
          D3ltoroxpD 1 Antwort Letzte Antwort
            D3ltoroxpD
            D3ltoroxpD
            D3ltoroxp
            #591
               if (b1lp && b2lp && b3lp) {
                   // Lüftungsempfehlung, alle bedingungenen erfüllt
                   lueftenText = "Bedingungen für Entfeuchten, Kühlen und Auskühlschutz erfüllt.";
                   setState(idLueften, true);
                   setState(idLueftenHys,false);
                    if (debug) log(raum + ': **Lüftungsempfehlung**');
                } else if (b1ln || b2ln || b3ln) {
                   // Fenster zu. Ein Ausschlusskriterium reicht für die Empfehlung "Fenster zu".
                   if (b1ln) lueftenText += b1lnText + "
                   if (b2ln) lueftenText += b2lnText + "
                   if (b3ln) lueftenText += b3lnText + "
                   setState(idLueften, false);
                   if (debug) log(raum + ': **Empfehlung Fenster zu**');
               } else {
                   // Hysterese. Keine Änderung der bisherigen Empfehlung.
                   if (debug) log(raum + ': **im Bereich der Hysterese** (keine Änderung der Lüftungsempfehlung');
                   if (getState(idLueften).val === null) setState(idLueften,false); // noch keine Empfehlung vorhanden, "Fenster zu" empfehlen
                   lueftenText = "Hysterese, keine Änderung der Lüftungsempfehlung";
                   setState(idLueftenHys,true);
               setState(idLueftenText, lueftenText);
                /* Erklärung Lüftungslogik (von Paul53)
                 } else {
              paul53P
              paul53P
              #592
              @d3ltoroxp
              Es sind Zeilenumbrüche vorhanden, wo keine sein sollen.
                     lueftenText = "Fenster zu:";
                     if (b1ln) lueftenText += b1lnText + "";
                     if (b2ln) lueftenText += b2lnText + "";
                     if (b3ln) lueftenText += b3lnText + "";
                @d3ltoroxp
                D3ltoroxpD
                D3ltoroxpD
                D3ltoroxp
                #593
                @paul53 hm was hab ich dann für ein Script erwischt ? Ich hab das hier irgendwo aus dem Thread. Bis auf oben, die Parameter die man anpassen kann habe ich nichts gemacht.
                Hättet ihr mir noch mal ein aktuelles das funktioniert ?
                Und wenn der die DP's und Ordnerstruktur anlegt, könnte ich das auch unter userdata machen lassen und nicht unter dem javascript Ordner ?
                Wenn ja was müsste ich dort an diesem Bereich mit angeben ?
                  paul53P
                  paul53P
                  #594
                  @d3ltoroxp sagte: was hab ich dann für ein Script erwischt ?
                  Die Fehler sind schon im Originalskript (erster Beitrag) enthalten.
                    paul53P
                    paul53P
                    #595
                    @d3ltoroxp sagte: könnte ich das auch unter userdata machen lassen und nicht unter dem javascript Ordner ?
                    // Pfade für die Datenpunkte:
                    var pfad        = "0_userdata.0.Raumklima.";   // Pfad unter dem die Datenpunkte  angelegt werden
                    Ich hoffe, dass es an dieser Stelle genügt.
                    D3ltoroxpD 2 Antworten Letzte Antwort
                      D3ltoroxpD
                      D3ltoroxpD
                      D3ltoroxp
                      #596
                      @paul53 Hm könntest du mir Helfen diese Fehler zu beheben, oder hast du ein Script das läuft ?
                        paul53P
                        paul53P
                        #597
                        @d3ltoroxp sagte: hast du ein Script das läuft ?
                        Nein, ich verwende das Skript nicht.
                        Habe schon gezeigt, wie es richtig aussehen muss.
                        Oder sollte dort eine Zeilenschaltung erfolgen? Dann so:
                               lueftenText = "Fenster zu:\n";
                               if (b1ln) lueftenText += b1lnText + "\n";
                               if (b2ln) lueftenText += b2lnText + "\n";
                               if (b3ln) lueftenText += b3lnText + "\n";
                          D3ltoroxpD
                          D3ltoroxpD
                          D3ltoroxp
                          #598
                          var pfad        = "Raumklima"   +".";   // Pfad unter dem die Datenpunkte in der Javascript-Instanz angelegt werden
                          // Unterpfade unterhalb des Hauptpfads
                          var raumPfad    = "Raum"        +".";   // Pfad unterhalb des Hauptpfads für die Räume
                          var controlPfad = "CONTROL"     +".";   // Pfad innerhalb des Raums für Kontrollparameter
                          var detailPfad  = "DETAILS"     +".";   // Pfad innerhalb des Raums für Detailparameter ("" und ohne ".", wenn kein Detailpfad gewünscht)
                          var detailEnginePfad = "DETAILS_Lüftungsempfehlung" + "."; // Pfad innerhalb des Raums für Detailparameter zur Lüftungsengine
                          var infoPfad    = "Skriptinfos" +".";   // Pfad für globale Skriptparameter zur Info
                          Dann fällt +"."; weg ?
                          Die anderen lasse ich so, oder muss dort dann auch 0_userdata.0.Raumklima. davor ?
                            paul53P
                            paul53P
                            #599
                            Ja, den Punkt habe ich direkt angehängt.
                            Ja, dort steht
                              Ja, dort steht
                              D3ltoroxpD
                              D3ltoroxpD
                              D3ltoroxp
                              #600
                              @paul53 Hm, Script ist aktiv, er sagt aber oben inaktiv.
                                #601
                                das bezieht sich nicht auf das Skript sondern auf die js-Instanz.
                                wenn du due nicht deaktivierthast und die nicht gerade abgestürzt ist kann das eine Falschmeldung sein. Das gab es vor Jahren mal.
                                • D3ltoroxpD
                                  D3ltoroxpD
                                  D3ltoroxp
                                  #602
                                  Da war noch ein Fehler in Zeile 738. Aber nun passt es und läuft. Danke euch.
                                  • D Dieter_P
                                    @boriswerner said in [Skript] Absolute Feuchte berechnen:
                                    @dieter_p
                                    Wo werden denn noch leere Ordner angelegt? Eigentlich sollte alles unter 0_userdata laufen. Vielleicht hab ich beim Ersetzen was übersehen?
                                    hiervon hab ich mich verwirren lassen:
                                    Die Bedingungen findest du im Skript sogar mit sehr guten Kommentaren ab Zeile 86:
                                    // Lüftungsempfehlung steuern mit 0,3 g/kg und 0,5 K Hysterese
                                    // Bedigungen fürs lüften
                                    var b1lp = (xa <= (xi - (hysEntfeuchten + 0.1)))    ? true : false;   // Bedingnung 1 lüften positv (Außenluft ist mind. 0,4 trockener als Innen)
                                    var b2lp = (ta <= (ti - 0.6))                       ? true : false;   // Bedingnung 2 lüften positv (Außentemperatur ist mindestens 0,6 Grad kühler als innen)
                                    var b3lp = (ti >= mih)                              ? true : false;   // Bedingnung 3 lüften positv (Innentemperatur ist höher als die Minimumtemperatur + Hysterese)
                                    var b4lp = (rh >= xh)                               ? true : false;   // Bedingnung 4 lüften positv (Relative Raumfeuchte ist höher als die Maximalfeuchtewert)
                                    // Bedingungen gegen das Lüften
                                    var b1ln = (xa >= (xi - 0.1))   ? true : false;   // Bedingnung 1 lüften negativ (Außenluft ist zu feucht)
                                    var b2ln = (ta >= (ti - 0.1))   ? true : false;   // Bedingnung 2 lüften negativ (Außentemperatur zu warm)
                                    var b3ln = (ti <= mit)          ? true : false;   // Bedingnung 3 lüften negativ (Innentemperatur niedriger als Mindesttemperatur)
                                    var b4ln = (rh <= xt)           ? true : false;   // Bedingnung 4 lüften negativ (Relative Raumfeuchte ist niedriger als die Mindestfeuchte)
                                    if (b1lp && b2lp && b3lp && b4lp) {
                                    } else if (b1ln || b2ln || b3ln || b4ln) {
                                    } else {
                                    Danke, also alle 4 Lüftungsauswertungen sind gleichwertig und sobald eine das Lüften empfiehlt, schaltet die Sammelmeldung um. Ok, da muß ich bei mir drüber nachdenken ob das zu Situation passt bzw. meinem Wunsch eine Empfehlung zu erhalten. Bsp. Raumkühlung ist nicht so mein Case. Wenn mir Warm ist mache ich von selbst das Fenster auf, mir geht es eher darum Feuchtigkeit/Schimmel zu vermeiden bei geringstem Heizen und hier eine Unterstützung zu haben. Aber b1-b4 auswerten nach Zweck sollte ja kein Ding sein :)
                                    Das mit der Genauigkeit der Sensoren ist natürlich so eine Sache. Ich hab 3 verschiedene, Aqara Zigbee, Xiaomi Bluetooth und Sonoff Zigbee. Die ersten beiden sind sich relativ einig, die Sonoffs sind in der Feuchtigkeit immer zu hoch. Ich hab jetzt nochmal verschiedene Tuyas im Zulauf und werde dann nochmal einen Vergleich zwischen allen machen.
                                    Und noch ein Fun Fact: Ich hab meine Sensoren meist über den Lichtschaltern verbaut. Gestern hab ich mich gewundert, warum im Wohnzimmer auf einmal 1 Grad mehr angezeigt werden als im direkt angrenzenden Esszimmer, ohne Sonneneinstrahlung. Bis mir aufgefallen, dass ich die Deckenspots seit langem mal wieder an hatte und der Dimmer im Lichtschalter den darüber sitzenden Sensor aufheizt...
                                    Durchaus nicht inkomplex. Der Sensor im ungeheizten Schlafzimmer auf der Fensterbank ist auch nochmal ein Gedanke bei mir Wert. Sonneneinstrahlung und Lüften erzeugt da sehr schnell verschiedene Ergebnisse durch ungünstige Positionierung des Sensors.
                                    Eine Abgleich aller Sensoren macht wohl zusätzlich Sinn.
                                    D
                                    D
                                    dodi666
                                    schrieb am zuletzt editiert von dodi666
                                    #603
                                    @dieter_p
                                    @boriswerner
                                    Hi, das mit den leeren Odnern unter "javascript.0." ist bei mir auch so.
                                    Ist das gewollt, oder kann man das ändern?
                                    Danke und Grüße
                                    Sascha
                                    paul53P boriswernerB 2 Antworten Letzte Antwort
                                    • D dodi666
                                      @dieter_p
                                      @boriswerner
                                      Danke und Grüße
                                      Sascha
                                      paul53P
                                      paul53P
                                      #604
                                      @dodi666 sagte: kann man das ändern?
                                      Zeile 463 im Skript Version 0.6.4.
                                             setObject("javascript." + instance + "." + channelId, {
                                      ändern in
                                             if(!channelId.startsWith('0_userdata.0')) channelId = "javascript." + instance + "." + channelId;
                                             setObject(channelId, {
                                      • D dodi666
                                        @dieter_p
                                        @boriswerner
                                        Danke und Grüße
                                        Sascha
                                        boriswernerB
                                        boriswernerB
                                        boriswerner
                                        #605
                                        @dodi666
                                        @D3ltoroxp die aktuellste vollständige Version findest du als 0.6.7 hier im Thread von mir. Die ist erstmal lauffähig.
                                        Da ist auch schon der Pfad unter 0_userdata (wie auch von @paul53 beschrieben). Es werden, wie @Dieter_P festgestellt hat noch Ordner unter javascript angelegt, das ist ein Fehler (@dodi666). Ich vermute es reicht Zeile 555 (im Original 0.6.7) in
                                        zu ändern, habe es aber noch nicht getestet. Ich versuche die Tage mal das anzupassen und auch die NaNs im JSON (siehe Beitrag von @jwerlsdf ) und die Anmerkungen von @paul53 bzgl "zu trocken" einzuarbeiten.
                                          ändern in
                                          D
                                          D
                                          dodi666
                                          #606
                                          @paul53 sagte in [Skript] Absolute Feuchte berechnen:
                                          Danke, funktioniert.
                                          boriswernerB 1 Antwort Letzte Antwort
                                          83.8k
