  3. Einsteigerfragen
  4. Installation
  5. cloud.0 Adapter Fehlermeldung Admin instance not defined
    apollon77A
38 Beiträge 7 Kommentatoren 6.5k Aufrufe 4 Beobachtet
  • JochenJ Jochen
    2022-09-29 14:08:11.164 - info: cloud.0 (1065) User accessed from cloud: pzvhrnGtaDl-q1oTAUzi
    2022-09-29 14:10:10.608 - info: cloud.0 (1065) User disconnected from cloud: pzvhrnGtaDl-q1oTAUzi
    2022-09-29 14:11:09.521 - info: cloud.0 (1065) User accessed from cloud: 571FCjNg4FmuW7hqAU0-
    2022-09-29 14:12:59.232 - warn: cloud.0 (1065) User disconnected from cloud: 0 571FCjNg4FmuW7hqAU0-
    2022-09-29 14:12:59.235 - info: cloud.0 (1065) User disconnected from cloud:
    2022-09-29 14:13:32.389 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:32.390 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:32.404 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:32.420 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:32.692 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:33.002 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:33.310 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:33.604 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:33.914 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:34.215 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:34.517 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:34.816 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:35.142 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:35.447 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:35.759 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:36.054 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:36.351 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:36.652 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:36.952 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:37.258 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:13:37.737 - info: cloud.0 (1065) User accessed from cloud: F45_2QblRpJ4TEvUAU2Q
    2022-09-29 14:13:42.286 - info: cloud.0 (1065) User accessed from cloud: CzgPPNB_Jt3lVwr_AU2W
    2022-09-29 14:13:42.322 - error: cloud.0 (1065) Received unknown command 1: name
    2022-09-29 14:13:45.330 - error: cloud.0 (1065) Cannot request web pages: File i-vis-switch-1.ejs not found: {}
    2022-09-29 14:13:45.405 - error: cloud.0 (1065) Cannot request web pages: File i-vis-button.ejs not found: {}
    2022-09-29 14:13:47.567 - error: cloud.0 (1065) Cannot request web pages: File i-vis-switch-1.ejs not found: {}
    2022-09-29 14:13:47.640 - error: cloud.0 (1065) Cannot request web pages: File i-vis-button.ejs not found: {}
    2022-09-29 14:13:51.685 - info: cloud.0 (1065) User disconnected from cloud: CzgPPNB_Jt3lVwr_AU2W
    2022-09-29 14:15:22.728 - info: cloud.0 (1065) User disconnected from cloud: F45_2QblRpJ4TEvUAU2Q
    2022-09-29 14:15:59.078 - info: cloud.0 (1065) User accessed from cloud: LDN6Rndl4-3sQe76AU3g
    2022-09-29 14:16:17.217 - info: cloud.0 (1065) received all objects
    2022-09-29 14:17:46.194 - info: cloud.0 (1065) User disconnected from cloud: LDN6Rndl4-3sQe76AU3g
    2022-09-29 14:17:46.452 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:17:46.492 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:18:09.950 - warn: cloud.0 (1065) Used invalid characters: 0_userdata.0.Noch_Verbraucher_eingeschaltet_? changed to 0_userdata.0.Noch_Verbraucher_eingeschaltet__
    2022-09-29 14:18:42.930 - info: cloud.0 (1065) received all objects
    2022-09-29 14:19:16.102 - warn: cloud.0 (1065) Used invalid characters: 0_userdata.0.Noch_Verbraucher_eingeschaltet__.Noch_Verbraucher_eingeschaltet_? changed to 0_userdata.0.Noch_Verbraucher_eingeschaltet__.Noch_Verbraucher_eingeschaltet__
    2022-09-29 14:19:23.269 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:23.271 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:23.273 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:23.308 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:23.567 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:23.881 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:24.179 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:24.467 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:24.755 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:25.054 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:25.342 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:25.638 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:25.941 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:26.230 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:26.539 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:26.823 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:27.121 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:27.419 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:27.715 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:28.003 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:28.636 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:28.948 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:29.239 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:29.553 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:29.558 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:19:34.622 - info: cloud.0 (1065) received all objects
    2022-09-29 14:19:57.312 - info: cloud.0 (1065) User accessed from cloud: 78l_vKjv-nv3okU2AU6K
    2022-09-29 14:20:55.188 - info: javascript.0 (813) Stop script script.js.common.Energie.Noch_Verbraucher_eingeschaltet__
    2022-09-29 14:21:01.676 - warn: cloud.0 (1065) User disconnected from cloud: 0 78l_vKjv-nv3okU2AU6K
    2022-09-29 14:21:01.680 - info: cloud.0 (1065) User disconnected from cloud:
    2022-09-29 14:21:01.688 - info: cloud.0 (1065) User disconnected from cloud: gXr3IVoOZEduz4DjAURB
    2022-09-29 14:22:33.850 - info: cloud.0 (1065) User accessed from cloud: PBzg5Cr07YXXvEYYAU7y
    2022-09-29 14:22:42.303 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:22:42.307 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:34.087 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:34.092 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:34.096 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:34.129 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:34.403 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:34.700 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:35.020 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:35.328 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:35.619 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:35.921 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:36.231 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:36.544 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:36.836 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:37.135 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:24:37.454 - info: cloud.0 (1065) User accessed from cloud: 6ewN_arEbvPrGCLpAU8t
    2022-09-29 14:25:33.791 - warn: cloud.0 (1065) User disconnected from cloud: 0 6ewN_arEbvPrGCLpAU8t
    2022-09-29 14:25:33.794 - info: cloud.0 (1065) User disconnected from cloud:
    2022-09-29 14:25:34.091 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:25:34.290 - error: cloud.0 (1065) Admin instance not defined. Please specify the lovelace instance in settings
    2022-09-29 14:26:43.292 - info: cloud.0 (1065) User accessed from cloud: n34UEuZqv2uz35jNAU91
    2022-09-29 14:26:54.962 - info: cloud.0 (1065) User disconnected from cloud: n34UEuZqv2uz35jNAU91
    2022-09-29 14:26:54.975 - info: cloud.0 (1065) User disconnected from cloud: PBzg5Cr07YXXvEYYAU7y
    2022-09-29 14:46:05.757 - info: cloud.0 (1065) Connection changed: disconnect
    2022-09-29 14:46:05.758 - info: cloud.0 (1065) Connection lost
    2022-09-29 14:46:35.830 - info: cloud.0 (1065) Trying to connect as system.user.admin to cloud
    2022-09-29 14:46:55.515 - info: cloud.0 (1065) Connection changed: connect
    2022-09-29 15:16:52.456 - info: web.0 (1004) ==> Connected system.user.admin from ::ffff:192.168.123.21
    2022-09-29 15:18:21.677 - info: web.0 (1004) <== Disconnect system.user.admin from ::ffff:192.168.123.21 vis.0
    2022-09-29 15:26:12.393 - info: admin.0 (581) failed connection to socket.io from ::ffff:192.168.123.196: Passport was not initialized
    2022-09-29 15:26:55.411 - info: admin.0 (581) ==> Connected system.user.admin from ::ffff:192.168.123.196
    JochenJ
    JochenJ
    Jochen
    Und wegen dem URL-Schlüssel für Dienste...
    Die Anmeldedaten sind ok. Wenn ich die "ändere" - also mit dem Gleichen überschreibe (was soll ich sonst da rein schreiben, wenn es richtig ist), dann lässt der mich ja noch nicht mal speichern.
    Oder ist das hier:
    • JochenJ Jochen
      Oder ist das hier:
      FredFF
      FredFF
      FredF
      Most Active Forum Testing
      @jochen sagte in cloud.0 Adapter Fehlermeldung Admin instance not defined:
      Dann muss aber der iot Skill wieder aktiviert werden
      JochenJ 3 Antworten Letzte Antwort
      • FredFF FredF
        JochenJ
        JochenJ
        Jochen
        @fredf Ich versuche es..
        • FredFF FredF
          JochenJ
          JochenJ
          Jochen
          @fredf Nee, das war es nicht. Habe den Button benutzt.
          "Zertifikate werden nach dem Start erneuert"
          iot Adapter startet wieder.
          skill deaktiviert und wieder aktiviert.
          iobroker.pro ausgeloggt und wieder eingeloggt.
          Diagnose immer noch gleich.
          • FredFF FredF
            JochenJ
            JochenJ
            Jochen
            @fredf ```
            2022-09-29 17:23:10.830 - info: host.raspberrypi stopInstance system.adapter.iot.0 (force=false, process=true)
            2022-09-29 17:23:10.837 - info: iot.0 (26671) Got terminate signal TERMINATE_YOURSELF
            2022-09-29 17:23:10.842 - info: iot.0 (26671) terminating
            2022-09-29 17:23:10.844 - info: iot.0 (26671) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2022-09-29 17:23:10.884 - info: iot.0 (26671) Connection changed: disconnect
            2022-09-29 17:23:10.885 - info: iot.0 (26671) Connection lost
            2022-09-29 17:23:10.894 - info: host.raspberrypi stopInstance system.adapter.iot.0 send kill signal
            2022-09-29 17:23:11.413 - info: host.raspberrypi instance system.adapter.iot.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2022-09-29 17:23:14.014 - info: host.raspberrypi instance system.adapter.iot.0 started with pid 29802
            2022-09-29 17:23:16.320 - info: iot.0 (29802) starting. Version 1.11.9 in /opt/iobroker/node_modules/iobroker.iot, node: v16.17.0, js-controller: 4.0.23
            2022-09-29 17:23:16.398 - info: iot.0 (29802) Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            2022-09-29 17:23:21.976 - info: iot.0 (29802) Connection changed: connect
            2022-09-29 17:23:51.374 - info: iot.0 (29802) Request devices
            2022-09-29 17:24:03.056 - info: admin.0 (581) <== Disconnect system.user.admin from ::ffff:192.168.123.196 iot
            2022-09-29 17:27:24.021 - info: admin.0 (581) ==> Connected system.user.admin from ::ffff:192.168.123.196
            2022-09-29 17:30:08.057 - info: admin.0 (581) <== Disconnect system.user.admin from ::ffff:192.168.123.196 iot
            • JochenJ Jochen
              @fredf ```
              FredFF
              FredFF
              FredF
              @jochen
              Das sind normale Meldungen, die ich vorhin auch hatte.
              Somit müsste die rote Meldung über die pro cloud weg sein, oder?
              JochenJ 2 Antworten Letzte Antwort
              • FredFF FredF
                @jochen
                JochenJ
                JochenJ
                Jochen
                @fredf Nee, eben nicht.
                • FredFF FredF
                  @jochen
                  JochenJ
                  JochenJ
                  Jochen
                  @fredf Das mit den Anmeldeinformationen neu hatte ich bestimmt auch schonmal versucht.
                  • JochenJ Jochen
                    FredFF
                    FredFF
                    FredF
                    @jochen Bei mir hatte es heute Mittag so funktioniert...
                    JochenJ 1 Antwort Letzte Antwort
                    • FredFF FredF
                      JochenJ
                      JochenJ
                      Jochen
                      @fredf Also mir sind die Ideen ausgegangen.
                      Beide oben beschriebenen Probleme existieren noch.
                      Zwischenzeitlich cloud Adapter gelöscht und wieder rein.
                      iot Adapter gelöscht und wieder rein.
                      lovelace Adapter rein (wegen der Fehlermeldung), konfiguriert, und dann wieder gelöscht (ich hatte den schonmal drauf, da ich nicht genau wusste, was das ist, und auch nicht, ob ich den brauche), falls die letzte Deinstallation nicht sauber gelaufen ist.
                      Sicherheitshalber noch Sonoff und Daikin Adapter raus und draußen gelassen (waren eh noch nicht in Benutzung).
                      web.0 Adapter nicht getraut, da ich schon eine ziemlich gute (für meine Vorstellungen...) Visualisierung aufgebaut habe, und der anzeigt, dass VIS davon abhängig ist.
                      Neuen App-Key auf iobroker.pro erstellt und eingetragen.
                      Zwischen jedem Schritt iobroker gestoppt, und den Fixer laufen lassen.
                      Ich habe im Heimnetzwerk keinerlei Probleme. Keine Fehlermeldungen, Nichts.
                      Nur wenn ich über iobroker.pro rein gehe, kommen die Fehlermeldungen wie oben im log zu sehen.
                      Ich bin mit meinem Latain am Ende.
                      Wenn noch Jemand Ideen hat, bin ich dankbar.
                      • JochenJ
                        JochenJ
                        Jochen
                        Gelöst:
                        Ich hatte das Häkchen im Admin.0 bei "Authentifizierung" gesetzt.
                        Ich kann mich nicht erinnern wann und warum...
                        Das hat das obenstehende Problem ausgelöst.
                        Nach viel rumprobieren gefunden und jetzt ist Ruhe in den Protokollen.
                        • JochenJ Jochen
                          Gelöst:
                          B
                          B
                          besc0029
                          @jochen Hallo erstmal, bin komplett neu hier und hab seit gestern Cloud Pro installiert mit der gleichen andauernd eintretenden Fehlermeldung "Admin instance not defined. Please specify the lovelace instance in settings
                          Leider half das Deaktivieren der Authentifizierung bei mir nicht. Hast Du ggf. sonst noch was angepasst?
                          Vielen Dank im voraus, viele Grüße
                          Bernhard
                          • B besc0029
                            Bernhard
                            JochenJ
                            JochenJ
                            Jochen
                            @besc0029 Hmmm. Nicht dass ich wüsste. Zumindest nichts Relevantes. Bin ja selber noch ziemlicher Newbie.. Bist Du im Cloud.0 mit dem App-Key, oder mit login und password drin ? Lovelace Adapter jemals drauf gehabt ? Bei mir ist der wieder runter.
                            Also ich habe nun im Admin Adapter das Häkchen bei Authentifizierung raus.
                            Im cloud.0 bin ich mit App-Key angemeldet, und unter "Erweiterte Einstellungen" habe ich links bei "Administratorzugriff" admin.0 eingetragen, und rechts "Zugang zum Lovelace" = kein.
                            Tritt die Fehlermeldung denn bei Dir auch nur auf, wenn Du über iobroker.pro darauf zugreifst ? So war es bei mir jedenfalls. Siehe oben.
                            • B besc0029
                              Bernhard
                              JochenJ
                              JochenJ
                              Jochen
                              @besc0029 Im cloud.0 unter Einstellungen unter den App-Key natürlich bei webinstanz noch web.0, aber ich glaube ohne kommst Du gar nicht rein..
                              draexlerD 1 Antwort Letzte Antwort
                              • JochenJ Jochen
                                draexlerD
                                draexlerD
                                draexler
                                Habt ihr schon eine Lösung gefunden?
                                Habe das gleiche Problem mit der "lovelace instance" Meldung, obwohl der Adapter gar nicht installiert ist....
                                Ich habe die Meldung im Log (aber nicht immer) wenn ich mit der iOS App auf den Broker zugreifen möchte.
                                • draexlerD draexler
                                  draexlerD
                                  draexlerD
                                  draexler
                                  @draexler Sorry, das ich nochmal rausgebe. Aber die Meldung stört mich ein bisschen... Weiter oben wurde ja geschrieben, das es half den Haken bei Authentifizierung rauszunehmen. Aber damit deaktiviere ich ja einen Sicherheitsaspekt. Oder für was steht diese Authentifizierung Möglichkeit?
                                  Sorry, aber hier will ich nicht rumspielen ;-)
                                    D
                                    D
                                    diro
                                    @draexler
                                    Hallo draexler, ich hatte das selbe Problem, gelöst habe ich es wie folgt...
                                    • Adapter cloud.0 geöffnet
                                      -- Erweiterte Einstellungen
                                      --- Administratorzugriff zulassen (hier konnte ich "admin" auswählen) nur auf pro
                                    Adapter neu gestartet und die Fehlermeldung war weg.
                                    • D diro
                                      @draexler
                                      draexlerD
                                      draexlerD
                                      draexler
                                      @diro Danke, das probiere ich mal aus. Wäre aber super wenn das trotzdem mal irgendwann gefixt wird, denn damit ist ja der Admin Adapter in der Cloud erreichbar.
                                        draexlerD
                                        draexlerD
                                        draexler
                                        Jetzt habe ich folgendes im Log...
                                        Klar was es bedeutet ist klar, aber ist das wirklich so??
                                        2023-01-05 09:17:50.372 - error: cloud.0 (247547) Cannot activate admin.0 for cloud, because authentication is enabled. Please create extra instance for cloud
                                        2023-01-05 09:18:20.517 - error: cloud.0 (247547) Cannot activate admin.0 for cloud, because authentication is enabled. Please create extra instance for cloud
                                        2023-01-05 10:05:20.522 - error: cloud.0 (247547) Received unknown command 1: name
                                        2023-01-05 10:05:23.188 - error: cloud.0 (247547) Cannot activate admin.0 for cloud, because authentication is enabled. Please create extra instance for cloud
                                          draexlerD
                                          draexlerD
                                          draexler
                                          schrieb am zuletzt editiert von draexler
                                          @draexler Da diese Meldung mit dem eigentlich Thema nicht zu tun mache ich hier ein neues Thema auf. Ist glaube ich sinnvoller.
                                          https://forum.iobroker.net/topic/61728/fernzugriff-per-cloudadapter-auf-iobroker
                                          84.0k
