  4. JavaScript
  5. Benötige Programmierhilfe Javascript
communicationjavascriptmonitoring
60 Beiträge 5 Kommentatoren 8.0k Aufrufe 4 Beobachtet
  • R Rushmed
    @oliverio sagte in Benötige Programmierhilfe Javascript:
    Kein Problem.
    Öffnen:
    30.8.2022, 19:58:37.852	[info ]: javascript.0 (1060380) script.js.Garage: execute command: open
    30.8.2022, 19:58:37.858	[info ]: javascript.0 (1060380) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661882317857,"q":0,"from":"system.adapter.javascript.0","lc":1661882317857,"c":"script.js.Garage"})
    30.8.2022, 19:58:37.872	[info ]: javascript.0 (1060380) script.js.Garage: cliend started
    30.8.2022, 19:58:37.873	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
    30.8.2022, 19:58:37.874	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
    30.8.2022, 19:58:37.909	[info ]: javascript.0 (1060380) script.js.Garage: client received: R;OK
    30.8.2022, 19:58:37.910	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
    30.8.2022, 19:58:37.910	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
    30.8.2022, 19:58:37.911	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
    30.8.2022, 19:58:38.225	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;opening
    30.8.2022, 19:58:38.225	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
    30.8.2022, 19:58:38.226	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
    30.8.2022, 19:58:38.226	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
    30.8.2022, 19:58:38.294	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;lightOn
    30.8.2022, 19:58:38.294	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
    30.8.2022, 19:58:38.295	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
    30.8.2022, 19:58:38.295	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
    30.8.2022, 19:58:39.294	[info ]: javascript.0 (1060380) script.js.Garage: client timeout
    30.8.2022, 19:58:39.295	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorEnd
    30.8.2022, 19:58:39.296	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
    Schließen:
    30.8.2022, 19:59:33.336	[info ]: javascript.0 (1060380) script.js.Garage: execute command: close
    30.8.2022, 19:59:33.337	[info ]: javascript.0 (1060380) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661882373337,"q":0,"from":"system.adapter.javascript.0","lc":1661882373337,"c":"script.js.Garage"})
    30.8.2022, 19:59:33.356	[info ]: javascript.0 (1060380) script.js.Garage: cliend started
    30.8.2022, 19:59:33.357	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
    30.8.2022, 19:59:33.357	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
    30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: client received: R;OK
    30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
    30.8.2022, 19:59:33.397	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
    30.8.2022, 19:59:33.398	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
    30.8.2022, 19:59:33.755	[info ]: javascript.0 (1060380) script.js.Garage: client received: S;Garagentor;closing
    30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorStart
    30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
    30.8.2022, 19:59:33.756	[info ]: javascript.0 (1060380) script.js.Garage: setTimeout(ms=1000)
    30.8.2022, 19:59:34.755	[info ]: javascript.0 (1060380) script.js.Garage: client timeout
    30.8.2022, 19:59:34.756	[info ]: javascript.0 (1060380) script.js.Garage: client terminatorEnd
    30.8.2022, 19:59:34.757	[info ]: javascript.0 (1060380) script.js.Garage: clearTimeout() => cleared
    Zur Info, VErbose ist noch aktiviert und die DPs für Status Licht, Tor werden nicht beschrieben.
    OliverIOO Offline
    OliverIOO Offline
    OliverIO
    @rushmed
    schau mal an dem schraubenschlüssel oben rechts, ob da debug aus ist?
    dadurch werden keine datenpunkte beschrieben. also es muss aus sein
    Meine Adapter und Widgets
    Links im Profil
    R 1 Antwort Letzte Antwort
    • OliverIOO OliverIO
      @rushmed
      Rushmed
      @oliverio Debug ist aus. Wie gesagt verbose war an. Habs mal deaktiviert und getastet, ändert nichts.
      Das Leeren von 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command hat seit dus eingebaut hast immer geklappt.
      Also geht Schreiben offensichtlich.
      • R Rushmed
        OliverIOO Offline
        OliverIOO Offline
        OliverIO
        @rushmed
        ich habe nochmal die logausgabe um einen parameter erweitert und die timeout zeit auf 10 Sekunden erhöht.
        Der Status der ankommt müsste schon richtig sein. In der Entscheidungsmatrix greift er aber nicht. Das prüfen wir damit.
        Darüber hinaus kommt nur einmal "closing" und sonst nix. wenn dann wollen wir ja nach einer weile zumindest wissen das dann tatsächlich closed ist
        könntest du parallel bitte auch dieser Firma eine EMail senden, das sie dir eine aktualisierte API-Beschreibung senden? Deine verlinkte scheint ja nicht ganz aktuell zu sein.
        Ich erhoffe mir, das da auch ein paar mehr Details zur generellen Statusabfrage drin steht.
        Also am besten dem Hersteller und nicht irgendeinem Vertriebspartner.
        var net = require('net');
        var dp_door = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor"; //door state
        var dp_light = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht"; //light state
        var dp_cmd = "0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command"; //Befehlsdatenpunkt: Mögliche Werte: open, close, stop, lighton, lightoff. Nach Beschreiben wird der Datenpunkt wieder auf leer gesetzt
        var deviceName = "Garagentor";
        var host = "192.168.178.149";
        var port = 2785;
        function sendMessage(host, port, message) {
        var timeout = 10000;                           //timeout für Antwort vom Server
        var time2termination = 10000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
        var terminator;
        var terminatorStart;
        var terminatorEnd;
        return new Promise((resolve, reject) => {     // Funktion ist asynchron, daher Rückgabe promise
          var client = new net.Socket();                 // Erzeugen eines neuen Verbindungsobjekts
          client.connect(port, host, function() {     // Gerät über host:port anwählen und Verbindung erzeugen
            console.debug('cliend started');
            terminatorStart();                        // Time starten, der die Verbindung beendet, falls keine Antwort mehr kommt
            client.setTimeout(timeout);               // internes timeout setzen
            client.write(message);                    // Nachricht an Gerät senden
          client.on('data', function(data) {          // Wenn daten ankommen, dann verarbeiten
            console.log('client received: ' + data + " for device: " + deviceName);
            terminatorStart();                        // Den Timeout verlängern
            var dataS = data.toString();              // Datenbuffer in lesbaren Text umwandeln
            switch(dataS) {                           // je nach rückgabewert unterschiedliche Bearbeitung
                case "S;"+deviceName+";open":         // wenn open
                setState(dp_door,"open");             // dann Datenpunkt setzen
                break;
                case "S;"+deviceName+";closed":
                setState(dp_door,"closed");
                break;
                case "S;"+deviceName+";opening":
                setState(dp_door,"opening");
                break;
                case "S;"+deviceName+";closing":
                setState(dp_door,"closing");
                break;
                case "S;"+deviceName+";lightOn":
                setState(dp_light,"lightOn");
                break;
                case "S;"+deviceName+";lightOff":
                setState(dp_light,"lightOff");
                break;
          client.on("error",(err)=>{                  // wenn ein Fehler entsteht
            console.log("client error");
            terminatorEnd();                          // dann timeout beenden
           client.end();                             // Kommunikation beenden
            resolve(err);                             // und Fehlerdetails zurückgeben
          client.on("timeout",()=>{                   // wenn timeout entsteht
            console.log("client timeout");
            resolve("timeout");                       // text timeout zurückgeben
          terminatorStart = function() {              // timeout starten oder verlängern
            console.log("client terminatorStart");
            if (terminator) clearTimeout(terminator); // evtl vorhanden timeout beenden
            terminator = setTimeout(() => {           // neuen timeout starten. wenn timeout eintritt, dann folgende funktionen ausführen
              console.log('cliend ended');
              client.end();                           // kommunikation beenden
              resolve("ok");                          // ok zurückgeben
            }, time2termination);                     // zeit für timeout angeben
          terminatorEnd = function() {                // timeout beenden
            console.log("client terminatorEnd");
        on(dp_cmd, function (obj) {                     // trigger wenn datenpunkt beschrieben wird
          var cmd;
          if (!obj.state.ack) {                       // aber nur wenn es sich um einen unbestätigten wert handelt
              cmd = String(obj.state.val).toLowerCase();  // Datenpunktinhalt in Kleinbuchstaben umwandeln
              console.debug('execute command: ' + cmd);
              switch(cmd) {                           // je nach Datenpunktinhalt verschiedene Befehle
                  case "open":                        // wenn open
                      sendMessage(host, port, "C;"+deviceName+";open"); // dann richtigen Befehl an Gerät senden
                      break;
                  case "close":
                      sendMessage(host, port, "C;"+deviceName+";close");
                      break;
                  case "stop":
                      sendMessage(host, port, "C;"+deviceName+";stop");
                      break;
                  case "lighton":
                      sendMessage(host, port, "C;"+deviceName+";lightOn");
                      break;
                  case "lightoff":
                      sendMessage(host, port, "C;"+deviceName+";lightOff");
                      break;
              setState(obj.id, {val: "", ack: true}); // datenpunkt auf leer als bestätigt setzen
        Links im Profil
          @rushmed
          var port = 2785;
          var terminator;
          var terminatorEnd;
                  break;
                  break;
                  break;
                  break;
                  break;
                  break;
            var cmd;
                        break;
                    case "close":
                        break;
                    case "stop":
                        break;
                    case "lighton":
                        break;
                    case "lightoff":
                        break;
          Rushmed
          @oliverio Antwort von Marantec vom 03.06.2022 08:21:
          Guten Tag Herr x,
          vielen Dank für Ihre Anfrage.
          Anbei erhalten Sie eine Übersicht der Befehle
          Status                                      Code
          Tor ist geöffnet:                        S;'garageDoorName';open
          Tor ist geschlossen:                 S;'garageDoorName';closed
          Tor öffnet sich:                         S;'garageDoorName';opening
          Tor schließt sich:                      S;'garageDoorName';closing
          Antriebsbeleuchtung ist an:     S;'garageDoorName';lightOn
          Antriebsbeleuchtung ist aus:   S:'garageDoorName';lightOff
          Befehl                                      Code
          Öffnen:                                    C;'garageDoorName';open
          Schließen:                               C;'garageDoorName';close
          Stop:                                       C;'garageDoorName';stop
          Antriebsbeleuchtung an:         C;'garageDoorName';lightOn
          Antriebsbeleuchtung aus:       C;'garageDoorName';lightOf
          garageDoorName = Der Name Ihres Tores
          Mit freundlichen Grüßen / Best regards
          Christian Pieper
          T +49 5247 705-221 · F +49 5247 705-234
          service@marantec.de · www.marantec.com
          Vermutlich fehlt beim letzten Befehl das zweite "f".
          Open:
          31.8.2022, 11:51:12.425	[info ]: javascript.0 (612549) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661939472425,"q":0,"from":"system.adapter.javascript.0","lc":1661939472425,"c":"script.js.Garage"})
          31.8.2022, 11:51:12.440	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
          31.8.2022, 11:51:12.441	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
          31.8.2022, 11:51:12.472	[info ]: javascript.0 (612549) script.js.Garage: client received: R;OK
          for device: Garagentor
          31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
          31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
          31.8.2022, 11:51:12.473	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
          31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;opening
          31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
          31.8.2022, 11:51:12.696	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
          31.8.2022, 11:51:12.697	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
          31.8.2022, 11:51:12.760	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
          31.8.2022, 11:51:12.761	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
          31.8.2022, 11:51:12.762	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
          31.8.2022, 11:51:12.762	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
          31.8.2022, 11:51:22.760	[info ]: javascript.0 (612549) script.js.Garage: client timeout
          31.8.2022, 11:51:22.762	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
          31.8.2022, 11:51:22.762	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
          Close:
          31.8.2022, 11:52:45.628	[info ]: javascript.0 (612549) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661939565627,"q":0,"from":"system.adapter.javascript.0","lc":1661939565627,"c":"script.js.Garage"})
          31.8.2022, 11:52:45.646	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
          31.8.2022, 11:52:45.646	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
          31.8.2022, 11:52:45.698	[info ]: javascript.0 (612549) script.js.Garage: client received: R;OK
          31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
          31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
          31.8.2022, 11:52:45.699	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
          31.8.2022, 11:52:46.144	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
          31.8.2022, 11:52:46.145	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
          31.8.2022, 11:52:46.145	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
          31.8.2022, 11:52:46.146	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=10000)
          31.8.2022, 11:52:56.144	[info ]: javascript.0 (612549) script.js.Garage: client timeout
          31.8.2022, 11:52:56.145	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
          31.8.2022, 11:52:56.145	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
          Ja stimmt, die Bestätigung der Endlagen kommt nichtmehr an. Mit dem neuen Code auch nicht.
          Auch die Datenpunkte bleiben leer.
          Nach dem Schließen bleibt die Lampe noch drei Minuten an. Die Bestätigung des Ausschaltens kommt jetzt auch nicht mehr an.
          Soll ich verbose jetzt weiter aktiviert lassen oder nicht?
          Danke vorab!
          • R Rushmed
            Guten Tag Herr x,
            Status                                      Code
            Befehl                                      Code
            Christian Pieper
            Open:
            Close:
            Danke vorab!
            OliverIOO Offline
            OliverIOO Offline
            OliverIO
            @rushmed
            ja, 2 Probleme haben wir noch.
            1. der Vergleich zwischen
              S;Gagentor;opening
              und
              S;Gagentor;opening
            schlägt fehl, ob die beiden gleich sind.
            1. die Rückmeldung für den Abschluss der Aktion fehlt noch.
              Wenn du sagst, das Licht bleibt noch 3 Minuten an, dann setzen wir den Timeout mal auf 4 Minuten,
              Ersetze bitte die folgenden 2 Zeilen
            mit
            var timeout = 4*60*1000;                           //timeout für Antwort vom Server
            var time2termination = 4*60*1000;                  //genereller Timeout falls gar keine Reaktion mehr kommt
            Du musst dann auch 4 Minuten Warten bis die Aktion abgeschlossen ist.
            Auch nicht den javascript-adapter stoppen
            Am Schluss muss im Log immer
            client timeout
            stehen
            Leider hat dir der Support einfach nur die Schlüsselworte mitgeteilt, aber auch nix zum Kommunikationsverhalten, was das Gerät macht wenn der Befehl close oder open gegeben wird.
            Wird nur einmal opening gesendet, oder mehrfach?
            Wie kann man den Status abfragen ohne einen Befehl zu geben, steht leider auch nirgends
            Besser wäre eine API, bei der man Befehle geben kann und separat den Status abfragen kann,
            So ist man viel flexibler.
            Aber man sieht ja, das sie dir keine richtige API-Beschreibung gegeben haben, sondern nur die Befehlsauflistung.
            Du hast ja nach API-Beschreibung gefragt?
            verbose erst mal so lassen. das stört nicht und gibt aktuell eher mehr informationen aus dem skriptablauf
            Links im Profil
              @rushmed
                S;Gagentor;opening
                und
                S;Gagentor;opening
              mit
              client timeout
              stehen
              Rushmed
              @oliverio Zu1) Hast du da noch ne Idee? Ansonsten eürde es mir reichen wenn opening, closing, closed, lighton und lightoff in einem Datenpunkt landen. Dann werte ich die Status mit Blockly selber aus.
              zu2) Habe das halboffene Tor zugefahren, lightoff kam an.
              31.8.2022, 19:27:24.317	[info ]: javascript.0 (612549) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1661966844317,"q":0,"from":"system.adapter.javascript.0","lc":1661966844317,"c":"script.js.Garage"})
              31.8.2022, 19:27:24.331	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:24.332	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:24.380	[info ]: javascript.0 (612549) script.js.Garage: client received: R;OK
              31.8.2022, 19:27:24.380	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:24.380	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:24.381	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:24.608	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
              31.8.2022, 19:27:24.609	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:24.609	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:24.609	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:24.610	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
              31.8.2022, 19:27:24.610	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:24.610	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:24.611	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:24.611	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closing
              31.8.2022, 19:27:24.612	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:24.612	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:24.612	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:24.672	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
              31.8.2022, 19:27:24.672	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:24.673	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:24.673	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:24.674	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
              31.8.2022, 19:27:24.674	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:24.674	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:24.674	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:24.675	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOn
              31.8.2022, 19:27:24.675	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:24.675	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:24.676	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:35.420	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closed
              31.8.2022, 19:27:35.421	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:35.421	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:35.421	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:35.422	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closed
              31.8.2022, 19:27:35.423	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:35.423	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:35.423	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:27:35.424	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;closed
              31.8.2022, 19:27:35.424	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:27:35.424	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:27:35.424	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:30:34.088	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOff
              31.8.2022, 19:30:34.089	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:30:34.089	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:30:34.089	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:30:34.090	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOff
              31.8.2022, 19:30:34.090	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:30:34.090	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:30:34.091	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:30:34.091	[info ]: javascript.0 (612549) script.js.Garage: client received: S;Garagentor;lightOff
              31.8.2022, 19:30:34.092	[info ]: javascript.0 (612549) script.js.Garage: client terminatorStart
              31.8.2022, 19:30:34.092	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:30:34.092	[info ]: javascript.0 (612549) script.js.Garage: setTimeout(ms=240000)
              31.8.2022, 19:34:34.088	[info ]: javascript.0 (612549) script.js.Garage: client timeout
              31.8.2022, 19:34:34.089	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
              31.8.2022, 19:34:34.089	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:34:34.090	[info ]: javascript.0 (612549) script.js.Garage: client timeout
              31.8.2022, 19:34:34.090	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
              31.8.2022, 19:34:34.090	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              31.8.2022, 19:34:34.092	[info ]: javascript.0 (612549) script.js.Garage: client timeout
              31.8.2022, 19:34:34.092	[info ]: javascript.0 (612549) script.js.Garage: client terminatorEnd
              31.8.2022, 19:34:34.092	[info ]: javascript.0 (612549) script.js.Garage: clearTimeout() => cleared
              zu3) Nein ich habe nicht nach API gefragt. Ich wollte eine Anleitung zur Integration, sowie eine Liste möglicher Befehle.
              Ich frage da nochmal nach, aber die Antwort wird lange dauern.
              Können wir bitte die Antwort von R; in einem DP ausgeben? Wäre aber nur nice to have und eigentlich nur bei der Einrichtung eines Antriebs interessant.
              • R Rushmed
                OliverIOO Offline
                OliverIOO Offline
                OliverIO
                @rushmed
                also von der Rückmeldung sind jetzt alle Informationen enthalten.
                Auch wenn da wieder ein paar zuviele Abfragen gleichzeitig laufen (3 stück),
                aber hier habe ich noch was gefunden an dem es gelegen haben könnte
                bitte vor dem test den javascriptadapter einmal stoppen und wieder starten.
                warum das
                S;Gagentor;opening
                nicht gleich
                S;Gagentor;opening
                ist
                ich habe noch was entdeckt und einen zusätzlichen Befehl eingefügt. der sollte das Problem beheben
                hat das letzte Schließen nur 11 Sekunden gedauert?
                var port = 2785;
                var terminator;
                var terminatorEnd;
                   console.log('client received: x' + data + " for device: " + deviceName);
                   var dataS = data.toString().trim();              // Datenbuffer in lesbaren Text umwandeln
                       break;
                       break;
                       break;
                       break;
                       break;
                       break;
                   client.end();
                 var cmd;
                             break;
                         case "close":
                             break;
                         case "stop":
                             break;
                         case "lighton":
                             break;
                         case "lightoff":
                             break;
                Links im Profil
                  @rushmed
                  warum das
                  S;Gagentor;opening
                  nicht gleich
                  S;Gagentor;opening
                  ist
                  var port = 2785;
                  var terminator;
                  var terminatorEnd;
                         break;
                         break;
                         break;
                         break;
                         break;
                         break;
                     client.end();
                   var cmd;
                               break;
                           case "close":
                               break;
                           case "stop":
                               break;
                           case "lighton":
                               break;
                           case "lightoff":
                               break;
                  Rushmed
                  schrieb am zuletzt editiert von Rushmed
                  @oliverio
                  lightOn:
                  1.9.2022, 05:57:50.085	[info ]: javascript.0 (1403834) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662004670085,"q":0,"from":"system.adapter.javascript.0","lc":1662004670085,"c":"script.js.Garage"})
                  1.9.2022, 05:57:50.099	[info ]: javascript.0 (1403834) script.js.Garage: client terminatorStart
                  1.9.2022, 05:57:50.100	[info ]: javascript.0 (1403834) script.js.Garage: setTimeout(ms=240000)
                  1.9.2022, 05:57:50.151	[info ]: javascript.0 (1403834) script.js.Garage: client received: xR;OK
                  1.9.2022, 05:57:50.152	[info ]: javascript.0 (1403834) script.js.Garage: client terminatorStart
                  1.9.2022, 05:57:50.152	[info ]: javascript.0 (1403834) script.js.Garage: clearTimeout() => cleared
                  1.9.2022, 05:57:50.152	[info ]: javascript.0 (1403834) script.js.Garage: setTimeout(ms=240000)
                  1.9.2022, 05:57:50.317	[info ]: javascript.0 (1403834) script.js.Garage: client received: xS;Garagentor;lightOn
                  1.9.2022, 05:57:50.318	[info ]: javascript.0 (1403834) script.js.Garage: client terminatorStart
                  1.9.2022, 05:57:50.318	[info ]: javascript.0 (1403834) script.js.Garage: clearTimeout() => cleared
                  1.9.2022, 05:57:50.319	[info ]: javascript.0 (1403834) script.js.Garage: setTimeout(ms=240000)
                  1.9.2022, 05:57:50.319	[info ]: javascript.0 (1403834) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662004670319,"q":0,"from":"system.adapter.javascript.0","lc":1662004670319,"c":"script.js.Garage"})
                  Open und Close sahen auch gut aus, hab aber erst heut abend Zeit um zu warten bis dasa licht aus geht.
                  Die Datenpunkte werden beschrieben. Super!
                  @rushmed sagte in Benötige Programmierhilfe Javascript:
                  Deswegen hat das Schließen weniger lange gedauert als sonst.
                  Warum war denn jetzt S;Gagentor;opening ungleich S;Gagentor;opening?
                  Ist es noch möglich Antworten von manuellen Eingaben (App, Fernbedienung und am Antrieb direkt) die nach time2termination passieren?
                  • OliverIOO Offline
                    OliverIOO Offline
                    OliverIO
                    @rushmed
                    code nochmal umgestellt.
                    der client-dienst läuft jetzt solange das skript läuft
                    mit der Funktion send Message kannst du wie gehabt die Nachrichten senden
                    der client-dienst wird beendet, sobald das skript gestoppt wird
                    theoretisch müsste der client dienst nun auf alle nachrichten hören, die das garagentor sendet.
                    einen timeout gibt es nicht mehr, ausser das garagentor sendet, das ende ist. aber das hatten wir bisher noch nicht gesehen
                    Am Ende der Nachricht hat noch ein Zeilenumbruch gehangen. Das ist mir in den Lognachrichten entgangen. Der trim-Befehl filtert diese Zeichen dann raus.
                    Daher
                    S;Gagentor;opening\n ungleich S;Gagentor;opening
                    \n ist eine Notation für die nicht sichtbaren Steuerzeichen, hier newline
                    var port = 2785;
                    var client;
                    function startClient() {
                            console.log('cliend started');
                                    break;
                                    break;
                                    break;
                                    break;
                                    break;
                                    break;
                            console.log("client error " + err.toString());
                            if (!client) {
                                console.log("No Client available");
                                resolve("Error");
                                return;
                            resolve("OK");
                    onStop (function(){
                         /* do something when script is stopped */
                         if (client) {
                            console.log('client ended ');
                            client.end();
                    }, 1000);
                    startClient();
                     var cmd;
                         console.log('execute command: ' + cmd);
                                 break;
                             case "close":
                                 break;
                             case "stop":
                                 break;
                             case "lighton":
                                 break;
                             case "lightoff":
                                 break;
                    Links im Profil
                      @rushmed
                      Daher
                      var port = 2785;
                      var client;
                                      break;
                                      break;
                                      break;
                                      break;
                                      break;
                                      break;
                              if (!client) {
                                  resolve("Error");
                                  return;
                              resolve("OK");
                      onStop (function(){
                           if (client) {
                              client.end();
                      }, 1000);
                      startClient();
                       var cmd;
                                   break;
                               case "close":
                                   break;
                               case "stop":
                                   break;
                               case "lighton":
                                   break;
                               case "lightoff":
                                   break;
                      Rushmed
                      @oliverio Ok, danke.
                      Ich würde heute Abend dann alle mögliche Szenarien durchtesten. Benötigst du noch Logs oder soll ich etwas bestimmtes testen?
                      • R Rushmed
                        OliverIOO Offline
                        OliverIOO Offline
                        OliverIO
                        @rushmed
                        ne erst mal nicht, ausser es passiert etwas besonderes.
                        bitte mal auch skript mehrmals starten und stoppen und dann schauen wieviele gleiche nachrichten kommen.
                        Links im Profil
                          @rushmed
                          Rushmed
                          @oliverio Das läuft soweit klasse, supervielen Dank!
                          Nach Script Neustart, aus und an Schalten kann ich doppelte aber bisher auch nur doppelte Rückmeldungen provozieren.
                          1.9.2022, 20:09:07.380	[info ]: javascript.0 (1961154) Stop script script.js.Garage
                          1.9.2022, 20:09:07.382	[info ]: javascript.0 (1961154) script.js.Garage: client ended
                          1.9.2022, 20:09:08.366	[info ]: javascript.0 (1961154) Start javascript script.js.Garage
                          1.9.2022, 20:09:08.404	[info ]: javascript.0 (1961154) script.js.Garage: onStop(timeout=1000)
                          1.9.2022, 20:09:08.407	[info ]: javascript.0 (1961154) script.js.Garage: subscribe: {"pattern":{"id":"0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command","change":"ne","q":0},"name":"script.js.Garage"}
                          1.9.2022, 20:09:08.408	[info ]: javascript.0 (1961154) script.js.Garage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          1.9.2022, 20:09:08.424	[info ]: javascript.0 (1961154) script.js.Garage: cliend started
                          1.9.2022, 20:09:22.539	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lighton
                          1.9.2022, 20:09:22.540	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055762540,"q":0,"from":"system.adapter.javascript.0","lc":1662055762540,"c":"script.js.Garage"})
                          1.9.2022, 20:09:22.586	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
                          1.9.2022, 20:09:22.872	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:09:22.873	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055762873,"q":0,"from":"system.adapter.javascript.0","lc":1662055762873,"c":"script.js.Garage"})
                          1.9.2022, 20:09:39.711	[info ]: javascript.0 (1961154) Stop script script.js.Garage
                          1.9.2022, 20:09:39.777	[info ]: javascript.0 (1961154) Start javascript script.js.Garage
                          1.9.2022, 20:09:39.826	[info ]: javascript.0 (1961154) script.js.Garage: onStop(timeout=1000)
                          1.9.2022, 20:09:39.828	[info ]: javascript.0 (1961154) script.js.Garage: subscribe: {"pattern":{"id":"0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command","change":"ne","q":0},"name":"script.js.Garage"}
                          1.9.2022, 20:09:39.828	[info ]: javascript.0 (1961154) script.js.Garage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          1.9.2022, 20:09:39.841	[info ]: javascript.0 (1961154) script.js.Garage: cliend started
                          1.9.2022, 20:10:14.468	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lightoff
                          1.9.2022, 20:10:14.469	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055814469,"q":0,"from":"system.adapter.javascript.0","lc":1662055814469,"c":"script.js.Garage"})
                          1.9.2022, 20:10:14.470	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lightoff
                          1.9.2022, 20:10:14.472	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055814471,"q":0,"from":"system.adapter.javascript.0","lc":1662055814469,"c":"script.js.Garage"})
                          1.9.2022, 20:10:14.525	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
                          1.9.2022, 20:10:14.552	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
                          1.9.2022, 20:10:15.732	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:10:15.733	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055815733,"q":0,"from":"system.adapter.javascript.0","lc":1662055815733,"c":"script.js.Garage"})
                          1.9.2022, 20:10:15.734	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:10:15.737	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055815737,"q":0,"from":"system.adapter.javascript.0","lc":1662055815733,"c":"script.js.Garage"})
                          1.9.2022, 20:10:26.293	[info ]: javascript.0 (1961154) Stop script script.js.Garage
                          1.9.2022, 20:10:26.295	[info ]: javascript.0 (1961154) script.js.Garage: client ended
                          1.9.2022, 20:10:27.303	[info ]: javascript.0 (1961154) Start javascript script.js.Garage
                          1.9.2022, 20:10:27.308	[info ]: javascript.0 (1961154) script.js.Garage: onStop(timeout=1000)
                          1.9.2022, 20:10:27.309	[info ]: javascript.0 (1961154) script.js.Garage: subscribe: {"pattern":{"id":"0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command","change":"ne","q":0},"name":"script.js.Garage"}
                          1.9.2022, 20:10:27.309	[info ]: javascript.0 (1961154) script.js.Garage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          1.9.2022, 20:10:27.319	[info ]: javascript.0 (1961154) script.js.Garage: cliend started
                          1.9.2022, 20:10:35.826	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lighton
                          1.9.2022, 20:10:35.828	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055835828,"q":0,"from":"system.adapter.javascript.0","lc":1662055835828,"c":"script.js.Garage"})
                          1.9.2022, 20:10:36.069	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
                          1.9.2022, 20:10:36.286	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:10:36.287	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055836287,"q":0,"from":"system.adapter.javascript.0","lc":1662055836287,"c":"script.js.Garage"})
                          1.9.2022, 20:10:36.287	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:10:36.288	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055836288,"q":0,"from":"system.adapter.javascript.0","lc":1662055836287,"c":"script.js.Garage"})
                          1.9.2022, 20:10:55.516	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lightoff
                          1.9.2022, 20:10:55.516	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055855516,"q":0,"from":"system.adapter.javascript.0","lc":1662055855516,"c":"script.js.Garage"})
                          1.9.2022, 20:10:55.558	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
                          1.9.2022, 20:10:56.676	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:10:56.677	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055856677,"q":0,"from":"system.adapter.javascript.0","lc":1662055856677,"c":"script.js.Garage"})
                          1.9.2022, 20:10:56.678	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:10:56.678	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055856678,"q":0,"from":"system.adapter.javascript.0","lc":1662055856677,"c":"script.js.Garage"})
                          1.9.2022, 20:11:17.185	[info ]: javascript.0 (1961154) Stop script script.js.Garage
                          1.9.2022, 20:11:17.187	[info ]: javascript.0 (1961154) script.js.Garage: client ended
                          1.9.2022, 20:11:21.690	[info ]: javascript.0 (1961154) Start javascript script.js.Garage
                          1.9.2022, 20:11:21.695	[info ]: javascript.0 (1961154) script.js.Garage: onStop(timeout=1000)
                          1.9.2022, 20:11:21.696	[info ]: javascript.0 (1961154) script.js.Garage: subscribe: {"pattern":{"id":"0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command","change":"ne","q":0},"name":"script.js.Garage"}
                          1.9.2022, 20:11:21.696	[info ]: javascript.0 (1961154) script.js.Garage: registered 1 subscription, 0 schedules, 0 messages, 0 logs and 0 file subscriptions
                          1.9.2022, 20:11:21.705	[info ]: javascript.0 (1961154) script.js.Garage: cliend started
                          1.9.2022, 20:11:30.967	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lightoff
                          1.9.2022, 20:11:30.968	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055890968,"q":0,"from":"system.adapter.javascript.0","lc":1662055890968,"c":"script.js.Garage"})
                          1.9.2022, 20:11:31.081	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
                          1.9.2022, 20:11:46.199	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lighton
                          1.9.2022, 20:11:46.200	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055906200,"q":0,"from":"system.adapter.javascript.0","lc":1662055906200,"c":"script.js.Garage"})
                          1.9.2022, 20:11:46.244	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
                          1.9.2022, 20:11:46.486	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:11:46.487	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055906487,"q":0,"from":"system.adapter.javascript.0","lc":1662055906487,"c":"script.js.Garage"})
                          1.9.2022, 20:11:46.487	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:11:46.488	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055906488,"q":0,"from":"system.adapter.javascript.0","lc":1662055906487,"c":"script.js.Garage"})
                          1.9.2022, 20:12:16.341	[info ]: javascript.0 (1961154) script.js.Garage: execute command: lighton
                          1.9.2022, 20:12:16.342	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Command, state={"val":"","ack":true,"ts":1662055936342,"q":0,"from":"system.adapter.javascript.0","lc":1662055936342,"c":"script.js.Garage"})
                          1.9.2022, 20:12:16.401	[info ]: javascript.0 (1961154) script.js.Garage: client received: R;OK
                          1.9.2022, 20:12:38.113	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:12:38.114	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055958114,"q":0,"from":"system.adapter.javascript.0","lc":1662055958114,"c":"script.js.Garage"})
                          1.9.2022, 20:12:38.114	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:12:38.115	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055958115,"q":0,"from":"system.adapter.javascript.0","lc":1662055958114,"c":"script.js.Garage"})
                          1.9.2022, 20:12:44.504	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:12:44.505	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055964505,"q":0,"from":"system.adapter.javascript.0","lc":1662055964505,"c":"script.js.Garage"})
                          1.9.2022, 20:12:44.505	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:12:44.506	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055964506,"q":0,"from":"system.adapter.javascript.0","lc":1662055964505,"c":"script.js.Garage"})
                          1.9.2022, 20:12:46.161	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:12:46.162	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055966162,"q":0,"from":"system.adapter.javascript.0","lc":1662055966162,"c":"script.js.Garage"})
                          1.9.2022, 20:12:46.163	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:12:46.164	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662055966163,"q":0,"from":"system.adapter.javascript.0","lc":1662055966162,"c":"script.js.Garage"})
                          1.9.2022, 20:12:56.426	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;opening
                          1.9.2022, 20:12:56.426	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"opening","ack":false,"ts":1662055976426,"q":0,"from":"system.adapter.javascript.0","lc":1662055976426,"c":"script.js.Garage"})
                          1.9.2022, 20:12:56.427	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;opening
                          1.9.2022, 20:12:56.427	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"opening","ack":false,"ts":1662055976427,"q":0,"from":"system.adapter.javascript.0","lc":1662055976426,"c":"script.js.Garage"})
                          1.9.2022, 20:12:56.502	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:12:56.502	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055976502,"q":0,"from":"system.adapter.javascript.0","lc":1662055976502,"c":"script.js.Garage"})
                          1.9.2022, 20:12:56.507	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOn
                          1.9.2022, 20:12:56.508	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOn","ack":false,"ts":1662055976508,"q":0,"from":"system.adapter.javascript.0","lc":1662055976502,"c":"script.js.Garage"})
                          1.9.2022, 20:13:12.637	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;closing
                          1.9.2022, 20:13:12.638	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"closing","ack":false,"ts":1662055992638,"q":0,"from":"system.adapter.javascript.0","lc":1662055992638,"c":"script.js.Garage"})
                          1.9.2022, 20:13:12.639	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;closing
                          1.9.2022, 20:13:12.640	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"closing","ack":false,"ts":1662055992639,"q":0,"from":"system.adapter.javascript.0","lc":1662055992638,"c":"script.js.Garage"})
                          1.9.2022, 20:13:13.538	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;closed
                          1.9.2022, 20:13:13.538	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"closed","ack":false,"ts":1662055993538,"q":0,"from":"system.adapter.javascript.0","lc":1662055993538,"c":"script.js.Garage"})
                          1.9.2022, 20:13:13.539	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;closed
                          1.9.2022, 20:13:13.539	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Tor, state={"val":"closed","ack":false,"ts":1662055993539,"q":0,"from":"system.adapter.javascript.0","lc":1662055993538,"c":"script.js.Garage"})
                          1.9.2022, 20:16:12.242	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:16:12.242	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662056172242,"q":0,"from":"system.adapter.javascript.0","lc":1662056172242,"c":"script.js.Garage"})
                          1.9.2022, 20:16:12.243	[info ]: javascript.0 (1961154) script.js.Garage: client received: S;Garagentor;lightOff
                          1.9.2022, 20:16:12.243	[info ]: javascript.0 (1961154) script.js.Garage: setForeignState(id=0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht, state={"val":"lightOff","ack":false,"ts":1662056172243,"q":0,"from":"system.adapter.javascript.0","lc":1662056172242,"c":"script.js.Garage"})
                          Kannst du bitte noch diese Meldungen noch aus dem Log entfernen:
                          • R Rushmed
                            OliverIOO Offline
                            OliverIOO Offline
                            OliverIO
                            @rushmed
                            das ist die verbose Einstellung, oben rechts im skript
                            wenn du die ausmachst, dann kommt die nicht mehr
                            Links im Profil
                            • R Offline
                              Rushmed
                              @oliverio Ok, probiere ich aus.
                              Könnte man Licht auch als einen boolschen Datenpunkt anlegen über den sowohl manuell gesteuert als auch die Status der Lampe zurück gegeben werden?
                              Die Ausgabe von R; im LOG ist denke ich sinnvoll. Vor allem falls bei der ersten Einrichtung etwas schiefgeht. Vll. muss auch nicht R;OK in den LOG sondern nur die möglichen Fehler.
                              Anwort Bedeutung
                              Error: Invalid command Ungültiger Befehl
                              Error: Not enough parameters
                              Error: Unknown garage Garage ist nicht bekannt. Kontrollieren Sie den Namen der Garage in ihrer Smart Home Anwendung oder in der maveo app.
                              Ich kann den Command DP nicht mit InfluxDB loggen, die Datenreihe bleibt leer. Wir der Wert so schnell zurück gesetzt dass Influx das nicht mitbekommt?
                              • R Rushmed
                                Anwort Bedeutung
                                OliverIOO Offline
                                OliverIOO Offline
                                OliverIO
                                @rushmed said in Benötige Programmierhilfe Javascript:
                                Theoretisch schon, aber du ja jetzt einen lesbaren Status
                                und ein Vergleich auf == "LightOn" oder auf == true
                                kommt auf das selbe heraus
                                Da muss ich mal schauen. eigentlich wollte ich ja console.debug machen, aber das hat zu einem Fehler geführt. Gedacht war, das nicht zu viel im log erscheint, sondern nur wenn man das will.
                                wenn du einzelne Nachrichten ausschalten willst, dann kannst du vor dem Befehle console.log
                                das Kommentarzeichen // schreiben. Dann werden die Anweisungen nicht mehr ausgeführt
                                Anwort Bedeutung
                                Nein, InfluxDB wird nur bestätigte Nachrichten aufzeichnen.
                                Du schreibst den Befehl auch als unbestätigt rein. Musst du aber auch, der Trigger hört aktuell nur auf unbestätigte Nachrichten
                                Links im Profil
                                  Anwort Bedeutung
                                  Rushmed
                                  @oliverio OK danke, verbose deaktiviert, funktioniert.
                                  Ich brauche das für meine Alexas als ein Gerät (DP) der sowohl zum Steuern da ist als auch immer den aktuellen Status beinhaltet. Habe einen DP Lampe Garagentor angelgt den ich an und aus schalten kann. Den hab ich dann als Write für einen Alias Garagentorbeleuchtung eingetragen und Status Garagentorbeleuchtung als Read. Vom Status habe ich vorher die Ausgabe im Script auf true/false geändert. Das funktioniert nicht, vermutlich weil DP 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht als Typ Sting und nicht Boolean kommt. 0_userdata.0.Eigene_Datenpunkte.Garage.Garage_Status_Licht als boolean festzulegen geht auch nicht, dan meckert das Script.
                                  Sorry, Fehlalarm. Die Fehler erscheinen wir gewünscht im Log.
                                  Hab das Resultat unserer Arbeit hier zusammengefasst.
                                  • Gerudom 0G Offline
                                    Gerudom 0G Offline
                                    Gerudom 0
                                    Hallo, wie verhält es sich denn wenn das Garagentor auf Status "Intermediate" steht. Also gekippt ist ?
                                    Im Status steht hier nur "Opening" was falsch ist. Hat da jemand eine Idee ? Ich finde es nirgends in den Beschreibungen
                                    • Gerudom 0G Gerudom 0
                                      OliverIOO Offline
                                      OliverIOO Offline
                                      OliverIO
                                      @gerudom-0
                                      und wo kommt der neue Status her?
                                      Der ist nirgends beschrieben oder erwähnt hier.
                                      Die Doku vom Hersteller ist auch sehr dürftig.
                                      Was sollte den deiner Meinung nach passieren?
                                      Links im Profil
                                        Gerudom 0G Offline
                                        Gerudom 0
                                        @oliverio naja also mein Garagentor kann kippen. In der App wäre es der Button in der Mitte Lüften. Warum der Status nicht beschrieben ist kann ich nicht sagen. Das es ihn aber gibt ist Fakt. Auf diesem Status zählt der dann nämlich die Zeit nach dem drücken. Warum relevant? Ich hab ne Lichtsteuerung die das Tor beleuchtet. Licht geh an wenn Status opening und bei Open mach dies und das. Gleiches Spiel bei Close. Der Status intermediate wird warum auch immer in der API mit dem Dauerstatus Opening quittiert. In meiner Lichtsteuerung also Dauerlicht... Kann das nicht abfangen. Ein logisches und mit negierter Open Abfrage funktioniert leider auch nur bedingt. Es ist schon echt komisch was die Marantec Firma da seit Jahren produziert.
                                        OliverIOO R 2 Antworten Letzte Antwort
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          Ok, wir versuchen es mal langsam
                                          @gerudom-0 sagte in Benötige Programmierhilfe Javascript:
                                          Ja das ist klar, das du es siehst. Problem ist, das wir nur die ankommenden Daten interpretieren können ohne das wir das sehen.
                                          Lüften? Ich habe den Garagentoröffner nicht. Ich habe nicht mal eine Garage. Von daher weiß ich nichts von einer Fernbedienung oder wie sie aussieht.
                                          Nochmal die Frage, hast du den auf der Schnittstelle gesehen? Sendet das Garagentor diese Daten? oder ist es nur das was du siehst: Tor ist gestoppt?
                                          Welche Zeit? Wo sieht man das das der zählt? Aus den bisherigen Berichten kommen keine Einzeldaten zur Zeit. ggfs. wird der Status Opening mehrmals wiederholt. Allerdings konnte ich da noch keine Regel ableiten, auf Basis der man was interpretieren kann.
                                          Weil ich genau den Status (also das Skript), den die Steuerung übermittelt, übersetze und dann direkt in einen Datenpunkt schreibe.
                                          Frag doch mal beim Support an, wie du das auf der Schnittstelle erkennen kannst? Leider ist die Dokumentation etwas älter und mittlerweile sendet die Steuerung auch leicht abgewandelte Daten. Ein aktuelles offizielles Dokument das zum aktuellen Status passt habe ich nicht gesehen.
                                          Links im Profil
