  4. Test ioBroker unter Windows installieren - 2022 Edition
275 Beiträge 27 Kommentatoren 95.9k Aufrufe 20 Beobachtet
  • JB_SullivanJ
    JB_SullivanJ
    JB_Sullivan
    schrieb am zuletzt editiert von JB_Sullivan
    Auch die manuelle Installation via Kommandozeile funktioniert nicht
    0 info it worked if it ends with ok
    1 warn npm npm does not support Node.js v16.15.1
    2 warn npm You should probably upgrade to a newer version of node as we
    3 warn npm can't make any promises that npm will work with this version.
    4 warn npm Supported releases of Node.js are the latest release of 6, 8, 9, 10, 11, 12.
    5 warn npm You can find the latest version at https://nodejs.org/
    6 verbose cli [
    6 verbose cli   'C:\\Program Files\\nodejs\\node.exe',
    6 verbose cli   'C:\\Users\\SmartHome\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js',
    6 verbose cli   'install',
    6 verbose cli   '@iobroker/install@latest',
    6 verbose cli   '--global',
    6 verbose cli   '--prefix',
    6 verbose cli   'C:\\Users\\SmartHome\\AppData\\Roaming\\npm-cache\\_npx\\5484',
    6 verbose cli   '--loglevel',
    6 verbose cli   'error',
    6 verbose cli   '--json'
    6 verbose cli ]
    7 info using npm@6.9.0
    8 info using node@v16.15.1
    9 verbose npm-session 0a4d3002ca044574
    10 silly install loadCurrentTree
    11 silly install readGlobalPackageData
    12 http fetch GET 304 https://registry.npmjs.org/@iobroker%2finstall 1692ms (from cache)
    13 silly pacote tag manifest for @iobroker/install@latest fetched in 1713ms
    14 verbose stack TypeError: cb.apply is not a function
    14 verbose stack     at C:\Users\SmartHome\AppData\Roaming\npm\node_modules\npm\node_modules\graceful-fs\polyfills.js:285:20
    14 verbose stack     at FSReqCallback.oncomplete (node:fs:199:5)
    15 verbose cwd C:\iobroker\GLT
    16 verbose Windows_NT 10.0.19044
    17 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\SmartHome\\AppData\\Roaming\\npm\\node_modules\\npm\\bin\\npm-cli.js" "install" "@iobroker/install@latest" "--global" "--prefix" "C:\\Users\\SmartHome\\AppData\\Roaming\\npm-cache\\_npx\\5484" "--loglevel" "error" "--json"
    18 verbose node v16.15.1
    19 verbose npm  v6.9.0
    20 error cb.apply is not a function
    21 verbose exit [ 1, true ]
    • NegaleinN
      NegaleinN
      Negalein
      Hallo
      @sigi234 @apollon77
      Wegen einem SSD-Crash auf meinem Proxmox-Server musste ich jetzt ioB auf dem Win-Rechner installieren.
      Funktionierte auch perfekt.
      Dann Backitup installiert und das gestrige Backup einspielen wollen.
      Es kam die Meldung, dass ein neuer Tab mit den Logs des Backup aufgemacht wird.
      Tab wurde keiner geöffnet und ioB ist seit 10 Minuten nicht mehr erreichbar.
      Muss ich vor dem Einspielen des Backups auf Beta wechseln (war in der urspr. Inst. auf Beta)?
      Service läuft (war gerade beendet)
      Edit:
      hier ein neuer Versuch.
      Beim Start des Restores wird der Dienst (iobroker.exe) kurz darauf beendet.
      Nach 10 Min. hab ich ihn wieder händisch gestartet. ioB startet dann wieder, aber es wirde nichts vom Backup wiederhergestellt. :(
      2022-07-16 17:36:39.577 - info: host.PC-Nega iobroker.js-controller version 4.0.23 js-controller starting
      2022-07-16 17:36:39.580 - info: host.PC-Nega Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-07-16 17:36:39.580 - info: host.PC-Nega hostname: PC-Nega, node: v16.15.1
      2022-07-16 17:36:39.580 - info: host.PC-Nega ip addresses: fe80::a923:aa5b:39d6:dd7f 10.0.1.31 fe80::8825:49e9:fafd:205f 172.19.96.1
      2022-07-16 17:36:39.659 - info: host.PC-Nega connected to Objects and States
      2022-07-16 17:36:39.665 - info: host.PC-Nega Node.js version has changed from unknown to 16.15.1
      2022-07-16 17:36:39.677 - info: host.PC-Nega added notifications configuration of host
      2022-07-16 17:36:39.814 - info: host.PC-Nega 2 instances found
      2022-07-16 17:36:39.816 - info: host.PC-Nega starting 2 instances
      2022-07-16 17:36:39.838 - info: host.PC-Nega instance system.adapter.admin.0 started with pid 2652
      2022-07-16 17:36:40.670 - info: admin.0 (2652) starting. Version 5.3.8 in C:/ioBroker/node_modules/iobroker.admin, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:36:40.678 - info: admin.0 (2652) requesting all states
      2022-07-16 17:36:40.679 - info: admin.0 (2652) requesting all objects
      2022-07-16 17:36:40.704 - info: admin.0 (2652) received all objects
      2022-07-16 17:36:40.736 - info: admin.0 (2652) http server listening on port 8081
      2022-07-16 17:36:40.736 - info: admin.0 (2652) Use link "http://localhost:8081" to configure.
      2022-07-16 17:36:40.756 - warn: admin.0 (2652) Repository cannot be read: Active repo - stable
      2022-07-16 17:36:40.756 - warn: admin.0 (2652) Active repository "stable cannot be read
      2022-07-16 17:36:42.784 - info: host.PC-Nega Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      2022-07-16 17:36:43.846 - info: host.PC-Nega instance system.adapter.discovery.0 started with pid 1248
      2022-07-16 17:36:44.583 - info: discovery.0 (1248) starting. Version 3.0.3 in C:/ioBroker/node_modules/iobroker.discovery, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:37:58.721 - info: host.PC-Nega stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-07-16 17:37:58.724 - info: admin.0 (2652) Got terminate signal TERMINATE_YOURSELF
      2022-07-16 17:37:58.724 - info: host.PC-Nega stopInstance system.adapter.admin.0 send kill signal
      2022-07-16 17:37:58.725 - info: admin.0 (2652) terminating http server on port 8081
      2022-07-16 17:37:58.726 - info: admin.0 (2652) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-16 17:37:59.248 - info: host.PC-Nega instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-16 17:38:01.748 - info: host.PC-Nega instance system.adapter.admin.0 started with pid 15032
      2022-07-16 17:38:02.624 - info: admin.0 (15032) starting. Version 5.3.8 in C:/ioBroker/node_modules/iobroker.admin, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:38:02.656 - info: admin.0 (15032) requesting all states
      2022-07-16 17:38:02.656 - info: admin.0 (15032) requesting all objects
      2022-07-16 17:38:02.786 - info: admin.0 (15032) received all objects
      2022-07-16 17:38:02.844 - info: admin.0 (15032) https server listening on port 8081
      2022-07-16 17:38:02.844 - info: admin.0 (15032) Use link "https://localhost:8081" to configure.
      2022-07-16 17:38:07.368 - info: admin.0 (15032) failed connection to socket.io from ::1:
      2022-07-16 17:38:07.370 - error: admin.0 (15032) Error: "error"
      2022-07-16 17:38:54.348 - info: host.PC-Nega stopInstance system.adapter.admin.0 (force=false, process=true)
      2022-07-16 17:38:54.351 - info: host.PC-Nega stopInstance system.adapter.admin.0 send kill signal
      2022-07-16 17:38:54.383 - info: host.PC-Nega stopInstance system.adapter.discovery.0 (force=false, process=true)
      2022-07-16 17:38:54.384 - info: discovery.0 (1248) Got terminate signal TERMINATE_YOURSELF
      2022-07-16 17:38:54.385 - info: discovery.0 (1248) terminating
      2022-07-16 17:38:54.385 - info: discovery.0 (1248) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-16 17:38:54.387 - info: host.PC-Nega stopInstance system.adapter.discovery.0 send kill signal
      2022-07-16 17:38:54.390 - info: admin.0 (15032) Got terminate signal TERMINATE_YOURSELF
      2022-07-16 17:38:54.393 - info: admin.0 (15032) terminating https server on port 8081
      2022-07-16 17:38:54.394 - info: admin.0 (15032) terminating
      2022-07-16 17:38:54.394 - info: admin.0 (15032) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-16 17:38:55.015 - info: host.PC-Nega instance system.adapter.discovery.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-16 17:38:55.045 - info: host.PC-Nega instance system.adapter.admin.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-16 17:38:57.376 - info: host.PC-Nega instance system.adapter.admin.0 started with pid 27544
      2022-07-16 17:38:57.404 - info: host.PC-Nega instance system.adapter.discovery.0 started with pid 14464
      2022-07-16 17:38:58.174 - info: discovery.0 (14464) starting. Version 3.0.3 in C:/ioBroker/node_modules/iobroker.discovery, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:38:58.270 - info: admin.0 (27544) starting. Version 5.3.8 in C:/ioBroker/node_modules/iobroker.admin, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:38:58.302 - info: admin.0 (27544) requesting all states
      2022-07-16 17:38:58.303 - info: admin.0 (27544) requesting all objects
      2022-07-16 17:38:58.428 - info: admin.0 (27544) received all objects
      2022-07-16 17:38:58.465 - warn: admin.0 (27544) Repository cannot be read: Active repo - beta
      2022-07-16 17:38:58.466 - warn: admin.0 (27544) Active repository "beta cannot be read
      2022-07-16 17:38:58.479 - info: admin.0 (27544) https server listening on port 8081
      2022-07-16 17:38:58.479 - info: admin.0 (27544) Use link "https://localhost:8081" to configure.
      2022-07-16 17:39:23.233 - info: host.PC-Nega Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2022-07-16 17:40:08.058 - info: host.PC-Nega iobroker add backitup --host PC-Nega
      2022-07-16 17:40:10.089 - error: host.PC-Nega iobroker npm WARN config global `--global`, `--local` are deprecated. Use `--location=global` instead.
      2022-07-16 17:40:10.090 - info: host.PC-Nega iobroker NPM version: 8.11.0
      2022-07-16 17:40:10.090 - info: host.PC-Nega iobroker Installing iobroker.backitup@2.4.10... (System call)
      2022-07-16 17:40:17.204 - info: host.PC-Nega iobroker
      2022-07-16 17:40:17.205 - info: host.PC-Nega iobroker added 79 packages, and audited 520 packages in 6s
      39 packages are looking for funding
      run `npm fund` for details
      2022-07-16 17:40:17.216 - info: host.PC-Nega iobroker
      12 vulnerabilities (3 low, 7 moderate, 1 high, 1 critical)
      To address issues that do not require attention, run:
      npm audit fix
      2022-07-16 17:40:17.217 - info: host.PC-Nega iobroker
      To address all issues (including breaking changes), run:
      npm audit fix --force
      Run `npm audit` for details.
      2022-07-16 17:40:17.241 - info: host.PC-Nega iobroker host.PC-Nega install adapter backitup
      2022-07-16 17:40:17.258 - info: host.PC-Nega iobroker upload [10] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
      2022-07-16 17:40:17.269 - info: host.PC-Nega iobroker upload [9] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
      2022-07-16 17:40:17.273 - info: host.PC-Nega iobroker upload [8] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
      2022-07-16 17:40:17.276 - info: host.PC-Nega iobroker upload [7] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
      2022-07-16 17:40:17.280 - info: host.PC-Nega iobroker upload [6] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
      2022-07-16 17:40:17.284 - info: host.PC-Nega iobroker upload [5] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
      2022-07-16 17:40:17.288 - info: host.PC-Nega iobroker upload [4] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
      2022-07-16 17:40:17.291 - info: host.PC-Nega iobroker upload [3] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
      2022-07-16 17:40:17.295 - info: host.PC-Nega iobroker upload [2] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
      2022-07-16 17:40:17.298 - info: host.PC-Nega iobroker upload [1] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
      2022-07-16 17:40:17.301 - info: host.PC-Nega iobroker upload [0] backitup.admin C:/ioBroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
      2022-07-16 17:40:17.315 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup created/updated
      2022-07-16 17:40:17.329 - info: host.PC-Nega iobroker host.PC-Nega create instance backitup
      2022-07-16 17:40:17.333 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.alive created
      2022-07-16 17:40:17.335 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.connected created
      2022-07-16 17:40:17.337 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.compactMode created
      2022-07-16 17:40:17.339 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.cpu created
      2022-07-16 17:40:17.341 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.cputime created
      2022-07-16 17:40:17.343 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.memHeapUsed created
      2022-07-16 17:40:17.345 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.memHeapTotal created
      2022-07-16 17:40:17.347 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.memRss created
      2022-07-16 17:40:17.349 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.uptime created
      2022-07-16 17:40:17.351 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.inputCount created
      2022-07-16 17:40:17.352 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.outputCount created
      2022-07-16 17:40:17.357 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.eventLoopLag created
      2022-07-16 17:40:17.359 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.sigKill created
      2022-07-16 17:40:17.361 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0.logLevel created
      2022-07-16 17:40:17.363 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.info created
      2022-07-16 17:40:17.364 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.info.latestBackup created
      2022-07-16 17:40:17.365 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.info.ccuNextTime created
      2022-07-16 17:40:17.368 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.info.iobrokerNextTime created
      2022-07-16 17:40:17.372 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.history created
      2022-07-16 17:40:17.373 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.history.html created
      2022-07-16 17:40:17.375 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.history.json created
      2022-07-16 17:40:17.377 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.history.ccuLastTime created
      2022-07-16 17:40:17.379 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.history.iobrokerLastTime created
      2022-07-16 17:40:17.380 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.history.ccuSuccess created
      2022-07-16 17:40:17.382 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.history.iobrokerSuccess created
      2022-07-16 17:40:17.384 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.oneClick created
      2022-07-16 17:40:17.385 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.oneClick.ccu created
      2022-07-16 17:40:17.387 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.oneClick.iobroker created
      2022-07-16 17:40:17.388 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.output created
      2022-07-16 17:40:17.390 - info: host.PC-Nega iobroker host.PC-Nega object backitup.0.output.line created
      2022-07-16 17:40:17.391 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.info.ccuNextTime: none
      2022-07-16 17:40:17.392 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.info.iobrokerNextTime: none
      2022-07-16 17:40:17.394 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.history.html: No backups yet
      2022-07-16 17:40:17.395 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.history.json: []
      2022-07-16 17:40:17.397 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.history.ccuLastTime: No backups yet
      2022-07-16 17:40:17.398 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.history.iobrokerLastTime: No backups yet
      2022-07-16 17:40:17.400 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.history.ccuSuccess: false
      2022-07-16 17:40:17.401 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.history.iobrokerSuccess: false
      2022-07-16 17:40:17.402 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.oneClick.ccu: false
      2022-07-16 17:40:17.404 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.oneClick.iobroker: false
      2022-07-16 17:40:17.405 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.0.output.line:
      2022-07-16 17:40:17.409 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.0 created
      2022-07-16 17:40:18.427 - info: host.PC-Nega iobroker exit 0
      2022-07-16 17:40:20.432 - info: host.PC-Nega instance system.adapter.backitup.0 started with pid 5468
      2022-07-16 17:40:21.205 - info: backitup.0 (5468) starting. Version 2.4.10 in C:/ioBroker/node_modules/iobroker.backitup, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:40:21.222 - info: backitup.0 (5468) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-16 17:40:46.096 - info: host.PC-Nega Updating repository "beta" under "http://download.iobroker.net/sources-dist-latest.json"
      2022-07-16 17:41:08.191 - info: host.PC-Nega iobroker add backitup --host PC-Nega
      2022-07-16 17:41:08.998 - info: host.PC-Nega iobroker host.PC-Nega create instance backitup
      2022-07-16 17:41:09.003 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.alive created
      2022-07-16 17:41:09.005 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.connected created
      2022-07-16 17:41:09.007 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.compactMode created
      2022-07-16 17:41:09.009 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.cpu created
      2022-07-16 17:41:09.011 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.cputime created
      2022-07-16 17:41:09.012 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.memHeapUsed created
      2022-07-16 17:41:09.014 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.memHeapTotal created
      2022-07-16 17:41:09.016 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.memRss created
      2022-07-16 17:41:09.018 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.uptime created
      2022-07-16 17:41:09.021 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.inputCount created
      2022-07-16 17:41:09.024 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.outputCount created
      2022-07-16 17:41:09.025 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.eventLoopLag created
      2022-07-16 17:41:09.027 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.sigKill created
      2022-07-16 17:41:09.029 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1.logLevel created
      2022-07-16 17:41:09.031 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.info created
      2022-07-16 17:41:09.032 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.info.latestBackup created
      2022-07-16 17:41:09.034 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.info.ccuNextTime created
      2022-07-16 17:41:09.036 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.info.iobrokerNextTime created
      2022-07-16 17:41:09.037 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.history created
      2022-07-16 17:41:09.039 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.history.html created
      2022-07-16 17:41:09.040 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.history.json created
      2022-07-16 17:41:09.042 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.history.ccuLastTime created
      2022-07-16 17:41:09.044 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.history.iobrokerLastTime created
      2022-07-16 17:41:09.048 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.history.ccuSuccess created
      2022-07-16 17:41:09.049 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.history.iobrokerSuccess created
      2022-07-16 17:41:09.051 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.oneClick created
      2022-07-16 17:41:09.052 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.oneClick.ccu created
      2022-07-16 17:41:09.053 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.oneClick.iobroker created
      2022-07-16 17:41:09.055 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.output created
      2022-07-16 17:41:09.057 - info: host.PC-Nega iobroker host.PC-Nega object backitup.1.output.line created
      2022-07-16 17:41:09.058 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.info.ccuNextTime: none
      2022-07-16 17:41:09.059 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.info.iobrokerNextTime: none
      2022-07-16 17:41:09.061 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.history.html: No backups yet
      2022-07-16 17:41:09.063 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.history.json: []
      2022-07-16 17:41:09.066 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.history.ccuLastTime: No backups yet
      2022-07-16 17:41:09.069 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.history.iobrokerLastTime: No backups yet
      2022-07-16 17:41:09.071 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.history.ccuSuccess: false
      2022-07-16 17:41:09.072 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.history.iobrokerSuccess: false
      2022-07-16 17:41:09.075 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.oneClick.ccu: false
      2022-07-16 17:41:09.077 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.oneClick.iobroker: false
      2022-07-16 17:41:09.078 - info: host.PC-Nega iobroker host.PC-Nega Set default value of backitup.1.output.line:
      2022-07-16 17:41:09.087 - info: host.PC-Nega iobroker host.PC-Nega object system.adapter.backitup.1 created
      2022-07-16 17:41:10.110 - info: host.PC-Nega iobroker exit 0
      2022-07-16 17:41:12.111 - info: host.PC-Nega instance system.adapter.backitup.1 started with pid 26356
      2022-07-16 17:41:12.873 - info: backitup.1 (26356) starting. Version 2.4.10 in C:/ioBroker/node_modules/iobroker.backitup, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:41:12.890 - info: backitup.1 (26356) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-16 17:44:44.738 - error: host.PC-Nega instance system.adapter.admin.0 terminated with code 4294967295 (4294967295)
      2022-07-16 17:44:44.739 - info: host.PC-Nega Restart adapter system.adapter.admin.0 because enabled
      2022-07-16 17:44:45.080 - error: host.PC-Nega instance system.adapter.discovery.0 terminated with code 4294967295 (4294967295)
      2022-07-16 17:44:45.080 - info: host.PC-Nega Restart adapter system.adapter.discovery.0 because enabled
      2022-07-16 17:44:45.424 - error: host.PC-Nega instance system.adapter.backitup.0 terminated with code 4294967295 (4294967295)
      2022-07-16 17:44:45.424 - info: host.PC-Nega Restart adapter system.adapter.backitup.0 because enabled
      2022-07-16 17:44:46.457 - error: host.PC-Nega instance system.adapter.backitup.1 terminated with code 4294967295 (4294967295)
      2022-07-16 17:44:46.457 - info: host.PC-Nega Restart adapter system.adapter.backitup.1 because enabled
      2022-07-16 17:45:16.431 - info: host.PC-Nega iobroker.js-controller version 4.0.23 js-controller starting
      2022-07-16 17:45:16.433 - info: host.PC-Nega Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-07-16 17:45:16.434 - info: host.PC-Nega hostname: PC-Nega, node: v16.15.1
      2022-07-16 17:45:16.434 - info: host.PC-Nega ip addresses: fe80::a923:aa5b:39d6:dd7f 10.0.1.31 fe80::8825:49e9:fafd:205f 172.19.96.1
      2022-07-16 17:45:16.644 - info: host.PC-Nega connected to Objects and States
      2022-07-16 17:45:16.651 - info: host.PC-Nega added notifications configuration of host
      2022-07-16 17:45:16.799 - info: host.PC-Nega 4 instances found
      2022-07-16 17:45:16.801 - info: host.PC-Nega starting 4 instances
      2022-07-16 17:45:16.822 - info: host.PC-Nega instance system.adapter.admin.0 started with pid 14548
      2022-07-16 17:45:17.528 - error: admin.0 (14548) admin.0 already running
      2022-07-16 17:45:17.529 - warn: admin.0 (14548) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-07-16 17:45:18.047 - error: host.PC-Nega instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-07-16 17:45:18.047 - info: host.PC-Nega Restart adapter system.adapter.admin.0 because enabled
      2022-07-16 17:45:20.821 - info: host.PC-Nega instance system.adapter.discovery.0 started with pid 22860
      2022-07-16 17:45:21.388 - error: discovery.0 (22860) discovery.0 already running
      2022-07-16 17:45:21.389 - warn: discovery.0 (22860) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-07-16 17:45:21.911 - error: host.PC-Nega instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-07-16 17:45:21.911 - info: host.PC-Nega Restart adapter system.adapter.discovery.0 because enabled
      2022-07-16 17:45:24.811 - info: host.PC-Nega instance system.adapter.backitup.0 started with pid 19532
      2022-07-16 17:45:25.407 - error: backitup.0 (19532) backitup.0 already running
      2022-07-16 17:45:25.408 - warn: backitup.0 (19532) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-07-16 17:45:25.932 - error: host.PC-Nega instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-07-16 17:45:25.933 - info: host.PC-Nega Restart adapter system.adapter.backitup.0 because enabled
      2022-07-16 17:45:28.818 - info: host.PC-Nega instance system.adapter.backitup.1 started with pid 25516
      2022-07-16 17:45:29.406 - error: backitup.1 (25516) backitup.1 already running
      2022-07-16 17:45:29.407 - warn: backitup.1 (25516) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-07-16 17:45:29.924 - error: host.PC-Nega instance system.adapter.backitup.1 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-07-16 17:45:29.924 - info: host.PC-Nega Restart adapter system.adapter.backitup.1 because enabled
      2022-07-16 17:45:48.064 - info: host.PC-Nega instance system.adapter.admin.0 started with pid 17716
      2022-07-16 17:45:48.910 - info: admin.0 (17716) starting. Version 5.3.8 in C:/ioBroker/node_modules/iobroker.admin, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:45:48.942 - info: admin.0 (17716) requesting all states
      2022-07-16 17:45:48.943 - info: admin.0 (17716) requesting all objects
      2022-07-16 17:45:49.207 - info: admin.0 (17716) received all objects
      2022-07-16 17:45:49.298 - info: admin.0 (17716) https server listening on port 8081
      2022-07-16 17:45:49.299 - info: admin.0 (17716) Use link "https://localhost:8081" to configure.
      2022-07-16 17:45:50.355 - error: admin.0 (17716) Error: "error"
      2022-07-16 17:45:51.922 - info: host.PC-Nega instance system.adapter.discovery.0 started with pid 31528
      2022-07-16 17:45:52.628 - info: discovery.0 (31528) starting. Version 3.0.3 in C:/ioBroker/node_modules/iobroker.discovery, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:45:55.945 - info: host.PC-Nega instance system.adapter.backitup.0 started with pid 33756
      2022-07-16 17:45:56.705 - info: backitup.0 (33756) starting. Version 2.4.10 in C:/ioBroker/node_modules/iobroker.backitup, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:45:56.726 - info: backitup.0 (33756) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-16 17:45:59.941 - info: host.PC-Nega instance system.adapter.backitup.1 started with pid 14012
      2022-07-16 17:46:00.695 - info: backitup.1 (14012) starting. Version 2.4.10 in C:/ioBroker/node_modules/iobroker.backitup, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:46:00.713 - info: backitup.1 (14012) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-16 17:46:29.153 - info: host.PC-Nega "system.adapter.backitup.0" disabled
      2022-07-16 17:46:29.154 - info: host.PC-Nega stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-16 17:46:29.156 - info: backitup.0 (33756) Got terminate signal TERMINATE_YOURSELF
      2022-07-16 17:46:29.156 - info: host.PC-Nega stopInstance system.adapter.backitup.0 send kill signal
      2022-07-16 17:46:29.156 - info: backitup.0 (33756) cleaned everything up...
      2022-07-16 17:46:29.157 - info: backitup.0 (33756) terminating
      2022-07-16 17:46:29.157 - info: backitup.0 (33756) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-16 17:46:29.676 - info: host.PC-Nega instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-16 17:46:37.779 - info: host.PC-Nega "system.adapter.backitup.0" enabled
      2022-07-16 17:46:37.791 - info: host.PC-Nega instance system.adapter.backitup.0 started with pid 11328
      2022-07-16 17:46:38.546 - info: backitup.0 (11328) starting. Version 2.4.10 in C:/ioBroker/node_modules/iobroker.backitup, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:46:38.564 - info: backitup.0 (11328) [iobroker] backup was activated at 02:40 every 1 day(s)
      2022-07-16 17:47:39.613 - info: host.PC-Nega "system.adapter.backitup.1" disabled
      2022-07-16 17:47:39.614 - info: host.PC-Nega stopInstance system.adapter.backitup.1 (force=false, process=true)
      2022-07-16 17:47:39.615 - info: backitup.1 (14012) Got terminate signal TERMINATE_YOURSELF
      2022-07-16 17:47:39.615 - info: host.PC-Nega stopInstance system.adapter.backitup.1 send kill signal
      2022-07-16 17:47:39.616 - info: backitup.1 (14012) cleaned everything up...
      2022-07-16 17:47:39.616 - info: backitup.1 (14012) terminating
      2022-07-16 17:47:39.617 - info: backitup.1 (14012) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-16 17:47:40.141 - info: host.PC-Nega instance system.adapter.backitup.1 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-16 17:47:51.050 - info: host.PC-Nega iobroker del backitup.1
      2022-07-16 17:47:51.787 - info: host.PC-Nega iobroker Delete instance "backitup.1"
      2022-07-16 17:47:51.793 - info: host.PC-Nega iobroker host.PC-Nega Counted 1 instances of backitup.1
      2022-07-16 17:47:51.796 - info: host.PC-Nega iobroker host.PC-Nega Counted 4 channels of backitup.1
      2022-07-16 17:47:51.799 - info: host.PC-Nega iobroker host.PC-Nega Counted 12 states of backitup.1
      2022-07-16 17:47:51.801 - info: host.PC-Nega iobroker host.PC-Nega Counted 15 states of system.adapter.backitup.1
      2022-07-16 17:47:51.802 - info: host.PC-Nega iobroker host.PC-Nega Counted 12 states (io.backitup.1.*) from states
      2022-07-16 17:47:51.805 - info: host.PC-Nega iobroker host.PC-Nega Counted 15 states (system.adapter.backitup.1.*) from states
      2022-07-16 17:47:51.982 - info: host.PC-Nega iobroker host.PC-Nega Counted 1 objects of backitup.1
      2022-07-16 17:47:51.983 - info: host.PC-Nega iobroker host.PC-Nega Deleting 33 object(s).
      2022-07-16 17:47:52.020 - info: host.PC-Nega object deleted system.adapter.backitup.1
      2022-07-16 17:47:52.025 - info: host.PC-Nega iobroker host.PC-Nega Deleting 27 state(s).
      2022-07-16 17:47:53.066 - info: host.PC-Nega iobroker exit 0
      2022-07-16 17:48:25.103 - info: host.PC-Nega stopInstance system.adapter.backitup.0 (force=false, process=true)
      2022-07-16 17:48:25.105 - info: host.PC-Nega stopInstance system.adapter.backitup.0 send kill signal
      2022-07-16 17:48:25.105 - info: backitup.0 (11328) Got terminate signal TERMINATE_YOURSELF
      2022-07-16 17:48:25.105 - info: backitup.0 (11328) cleaned everything up...
      2022-07-16 17:48:25.106 - info: backitup.0 (11328) terminating
      2022-07-16 17:48:25.106 - info: backitup.0 (11328) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2022-07-16 17:48:25.636 - info: host.PC-Nega instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2022-07-16 17:48:28.118 - info: host.PC-Nega instance system.adapter.backitup.0 started with pid 33496
      2022-07-16 17:48:28.856 - info: backitup.0 (33496) starting. Version 2.4.10 in C:/ioBroker/node_modules/iobroker.backitup, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 17:49:42.241 - error: host.PC-Nega instance system.adapter.admin.0 terminated with code 4294967295 (4294967295)
      2022-07-16 17:49:42.241 - info: host.PC-Nega Restart adapter system.adapter.admin.0 because enabled
      2022-07-16 17:49:42.592 - error: host.PC-Nega instance system.adapter.discovery.0 terminated with code 4294967295 (4294967295)
      2022-07-16 17:49:42.592 - info: host.PC-Nega Restart adapter system.adapter.discovery.0 because enabled
      2022-07-16 17:49:43.612 - error: host.PC-Nega instance system.adapter.backitup.0 terminated with code 4294967295 (4294967295)
      2022-07-16 17:49:43.612 - info: host.PC-Nega Restart adapter system.adapter.backitup.0 because enabled
      2022-07-16 18:00:23.937 - info: host.PC-Nega iobroker.js-controller version 4.0.23 js-controller starting
      2022-07-16 18:00:23.939 - info: host.PC-Nega Copyright (c) 2014-2022 bluefox, 2014 hobbyquaker
      2022-07-16 18:00:23.939 - info: host.PC-Nega hostname: PC-Nega, node: v16.15.1
      2022-07-16 18:00:23.940 - info: host.PC-Nega ip addresses: fe80::a923:aa5b:39d6:dd7f 10.0.1.31 fe80::8825:49e9:fafd:205f 172.19.96.1
      2022-07-16 18:00:24.144 - info: host.PC-Nega connected to Objects and States
      2022-07-16 18:00:24.155 - info: host.PC-Nega added notifications configuration of host
      2022-07-16 18:00:24.304 - info: host.PC-Nega 3 instances found
      2022-07-16 18:00:24.307 - info: host.PC-Nega starting 3 instances
      2022-07-16 18:00:24.329 - info: host.PC-Nega instance system.adapter.admin.0 started with pid 15456
      2022-07-16 18:00:25.048 - error: admin.0 (15456) admin.0 already running
      2022-07-16 18:00:25.049 - warn: admin.0 (15456) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-07-16 18:00:25.568 - error: host.PC-Nega instance system.adapter.admin.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-07-16 18:00:25.568 - info: host.PC-Nega Restart adapter system.adapter.admin.0 because enabled
      2022-07-16 18:00:28.326 - info: host.PC-Nega instance system.adapter.discovery.0 started with pid 20384
      2022-07-16 18:00:28.905 - error: discovery.0 (20384) discovery.0 already running
      2022-07-16 18:00:28.906 - warn: discovery.0 (20384) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-07-16 18:00:29.433 - error: host.PC-Nega instance system.adapter.discovery.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-07-16 18:00:29.433 - info: host.PC-Nega Restart adapter system.adapter.discovery.0 because enabled
      2022-07-16 18:00:32.320 - info: host.PC-Nega instance system.adapter.backitup.0 started with pid 9652
      2022-07-16 18:00:32.962 - error: backitup.0 (9652) backitup.0 already running
      2022-07-16 18:00:32.963 - warn: backitup.0 (9652) Terminated (ADAPTER_ALREADY_RUNNING): Without reason
      2022-07-16 18:00:33.487 - error: host.PC-Nega instance system.adapter.backitup.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)
      2022-07-16 18:00:33.488 - info: host.PC-Nega Restart adapter system.adapter.backitup.0 because enabled
      2022-07-16 18:00:55.579 - info: host.PC-Nega instance system.adapter.admin.0 started with pid 32868
      2022-07-16 18:00:56.402 - info: admin.0 (32868) starting. Version 5.3.8 in C:/ioBroker/node_modules/iobroker.admin, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 18:00:56.435 - info: admin.0 (32868) requesting all states
      2022-07-16 18:00:56.436 - info: admin.0 (32868) requesting all objects
      2022-07-16 18:00:56.702 - info: admin.0 (32868) received all objects
      2022-07-16 18:00:56.789 - info: admin.0 (32868) https server listening on port 8081
      2022-07-16 18:00:56.789 - info: admin.0 (32868) Use link "https://localhost:8081" to configure.
      2022-07-16 18:00:57.004 - error: admin.0 (32868) Error: "error"
      2022-07-16 18:00:59.448 - info: host.PC-Nega instance system.adapter.discovery.0 started with pid 1508
      2022-07-16 18:01:00.146 - info: discovery.0 (1508) starting. Version 3.0.3 in C:/ioBroker/node_modules/iobroker.discovery, node: v16.15.1, js-controller: 4.0.23
      2022-07-16 18:01:03.503 - info: host.PC-Nega instance system.adapter.backitup.0 started with pid 30724
      2022-07-16 18:01:04.265 - info: backitup.0 (30724) starting. Version 2.4.10 in C:/ioBroker/node_modules/iobroker.backitup, node: v16.15.1, js-controller: 4.0.23
      ° Fixer ---> iob fix
      • G
        G
        Gregor
        Leider hat auch bei mir das zurückspielen nicht funktioniert. Backup Datei wird nicht eingespielt. Sowohl nicht über die Weboberfläche als auch nicht über die Konsole.
        Das Kopieren des gesammten IO-Data Ordners hat nur zufolge, dass sie im Verzeichnis auftauchen aber nicht in der Weboberfläche.
        Gibt es hierzu schon eine Lösung?
        Running Admin shell
        ioBroker wird beendet.
        ioBroker wurde erfolgreich beendet.
        C:\ioBroker>iobroker restore 0
        host.DESKTOP-KPUH0GA Using backup file 2022_03_14-21_17_00_backupiobroker.tar.gz
        iobroker controller daemon is not running
        host.DESKTOP-KPUH0GA OK.
        Uncaught Rejection: TypeError: Cannot read properties of undefined (reading 'hostname')
            at BackupRestore._restoreAfterStop (C:\ioBroker\node_modules\iobroker.js-controller\lib\setup\setupBackup.js:696:52)
            at Daemon.<anonymous> (C:\ioBroker\node_modules\iobroker.js-controller\lib\setup\setupBackup.js:1128:49)
            at Daemon.emit (node:events:539:35)
            at Daemon.emit (node:domain:475:12)
            at Daemon._kill (C:\ioBroker\node_modules\daemonize2\lib\daemonize.js:246:14)
            at Daemon.stop (C:\ioBroker\node_modules\daemonize2\lib\daemonize.js:185:17)
            at C:\ioBroker\node_modules\iobroker.js-controller\lib\setup\setupBackup.js:1132:24
        This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
        C:\ioBroker>iobroker update
        Used repository: stable
        Adapter    "accuweather"  : 1.2.1    , installed 1.2.4
        Adapter    "admin"        : 5.3.8    , installed 5.3.8
        Adapter    "alexa2"       : 3.11.2   , installed 3.17.2
        Adapter    "backitup"     : 2.4.9    , installed 2.4.9
        Adapter    "cloud"        : 4.1.1    , installed 4.2.0
        Adapter    "daswetter"    : 3.1.2    , installed 3.1.3
        Adapter    "discovergy"   : 0.5.8    , installed 0.5.8
        Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
        Adapter    "dwd"          : 2.8.3    , installed 2.8.3
        Adapter    "fritzbox"     : 0.2.1    , installed 0.5.0
        Adapter    "fritzdect"    : 2.2.3    , installed 2.2.3
        Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
        Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
        Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
        Adapter    "ical"         : 1.13.1   , installed 1.13.1
        Adapter    "info"         : 1.9.19   , installed 1.9.18 [Updatable]
        Adapter    "iogopro"      : 0.2.6    , installed 0.2.6
        Adapter    "iot"          : 1.11.8   , installed 1.11.8
        Adapter    "javascript"   : 5.7.0    , installed 5.8.5
        Controller "js-controller": 4.0.23   , installed 4.0.23
        Adapter    "material"     : 1.1.2    , installed 1.1.2
        Adapter    "parser"       : 1.1.7    , installed 1.1.8
        Adapter    "samsung"      : 0.5.8    , installed 0.5.11
        Adapter    "sayit"        : 1.12.3   , installed 1.12.6
        Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
        Adapter    "socketio"     : 4.2.0    , installed 6.1.8
        Adapter    "solarwetter"  : 1.0.0    , installed 1.0.0
        Adapter    "sonos"        : 2.2.3    , installed 2.2.3
        Adapter    "spotify-premium": 1.2.1  , installed 1.2.2
        Adapter    "sprinklecontrol": 0.2.9  , installed 0.2.11
        Adapter    "terminal"     : 0.2.6    , installed 0.2.6
        Adapter    "text2command" : 2.2.2    , installed 2.2.2
        Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
        Adapter    "tuya"         : 3.6.15   , installed 3.6.15
        Adapter    "vis-fancyswitch": 1.1.0  , installed 1.0.0  [Updatable]
        Adapter    "vis-google-fonts": 1.0.3 , installed 1.0.3
        Adapter    "vis-hqwidgets": 1.2.0    , installed 1.2.0
        Adapter    "vis-icontwo"  : 0.89.0   , installed 0.87.0 [Updatable]
        Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
        Adapter    "vis-jqui-mfd" : 1.0.12   , installed 1.0.5  [Updatable]
        Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
        Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
        Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
        Adapter    "vis-timeandweather": 1.1.7, installed 1.2.2
        Adapter    "vis-weather"  : 2.5.5    , installed 2.5.5
        Adapter    "weatherunderground": 3.4.2, installed 3.4.2
        Adapter    "web"          : 4.3.0    , installed 5.2.4
        Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
        Adapter    "ws"           : 1.3.0    , installed 2.1.3
        Adapter    "yr"           : 5.3.0    , installed 5.3.0
        Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
        apollon77A willi5W 2 Antworten Letzte Antwort
        • G Gregor
          Running Admin shell
          apollon77A
          apollon77A
          @gregor Dann js-controller downgraden ... mit wecher controller Version wurde das Backup denn im März erstellt? Dann ggf controller downgrade, backup restore, controller upgrade
          G 1 Antwort Letzte Antwort
          • apollon77A apollon77
            G
            G
            Gregor
            @apollon77 wenn ich das noch wüsste? Kann ich das irgendwo in einer der Dateien sehen. Hatte damals aus den gesamten Ordner gespeichert?
            • G Gregor
              apollon77A
              apollon77A
              @gregor an sich in node_modules/iobroker.js-controller/package.json
              • sigi234S sigi234
                @thomas-braun sagte in Test ioBroker unter Windows installieren - 2022 Edition:
                Aber wie kommst du auf npm 8.11.0?
                Habe mal in der CMD ein Update gemacht, da stand:
                Es gibt eine neure Version auf 8.11.0
                Habe mit den Installer auch schon neu installiert, da kommt ja V 14
                Egal was ich dann mache , NPM bleibt auf 8.11.0
                M
                M
                michihorn
                @sigi234 Wie hast du das Update denn gemacht, ich würde gerne auch updaten
                Michael
                • M michihorn
                  Michael
                  sigi234S
                  sigi234S
                  @michihorn sagte in Test ioBroker unter Windows installieren - 2022 Edition:
                  Michael
                  Kein Update, neu installiert und alles vom alten zurückgespielt.
                  • apollon77A
                    apollon77A
                    Hi All,
                    sorry für die verzögerung. jetzt geht es hier aber weiter.
                    Unter https://iobroker.live/images/win/iobroker-installer.exe haben wir eine neue Installer exe die jetzt Node.js 16 mitbringt ... könnt Ihr die bitte mal checken? Danke!
                    Ingo und Bluefox
                    mcm1957M K 2 Antworten Letzte Antwort
                      Hi All,
                      Ingo und Bluefox
                      mcm1957M
                      mcm1957M
                      mcm1957
                      @apollon77
                      Bitte prüfen, ob es mit angemessenem Aufwand möglich ist die Version in den Dateinamen einfließen zu lassen. Wenn alle Versionen beim Download per Default iobroker-installer.exe heißen, kommen sie (zumindest mir) leicht durcheinander. Besser wäre (meiner Ansicht nach) iobroker-installer-1.1.2.exe (oder so ähnlich)
                      Support Repositoryverwaltung.
                      LESEN - gute Forenbeitrage
                      mcm1957M 2 Antworten Letzte Antwort
                      • mcm1957M mcm1957
                        @apollon77
                        mcm1957M
                        mcm1957M
                        mcm1957
                        @apollon77
                        Im Moment scheint der Download weiterhin die alte Version auszuliefern.
                        Download v. heute 16:40
                        Download von eben:
                        Eine Testinstallation der "neuen" Version hat bestätigt, dass die Version nicht neu ist :-)
                        • mcm1957M mcm1957
                          @apollon77
                          Download von eben:
                          apollon77A
                          apollon77A
                          @mcm57 Dnake, gebe es weiter
                            Hi All,
                            Ingo und Bluefox
                            K
                            K
                            klassisch
                            schrieb am zuletzt editiert von klassisch
                            @apollon77 sagte in Test ioBroker unter Windows installieren - 2022 Edition:
                            Setze gerade ein System auf,das produktiv gehen soll, wenn es stabil wird
                            Ich habe nach der Instalallation ioBroker gestoppt und das iobroker-data meines derzeitigen Produktivsystems reinkopiert.
                            Dann ioBroker gestartet und dieAdapter deaktiviert,
                            Unter der Haube wurde wohl kräftig Adapter neu gebaut
                            C:\Users\admin>iobroker -version
                            4.0.23
                            C:\Users\admin>node -v
                            v16.15.1
                            C:\Users\admin>npm -v
                            8.11.0
                            C:\Users\admin>
                            passt das, oder habe ich etwas verhauen?
                            apollon77A HomoranH 2 Antworten Letzte Antwort
                            • K klassisch
                              4.0.23
                              v16.15.1
                              8.11.0
                              C:\Users\admin>
                              apollon77A
                              apollon77A
                              @klassisch sieht für mich ok aus ... warum npm aktuell mit diesen warn messages wegen geänderter Konfig um sich wirft hab ich noch keine ahnung
                                K
                                K
                                klassisch
                                @apollon77 Danke, dann wage ich es demnächst mal das System als Produktivsystem einzusetzen.
                                • K
                                  K
                                  klassisch
                                  Bin jetzt mit dem Produktivsystem auf die neue Installation.
                                  Dabei habe ich die IP Adresse unter der Fritte so geändert, daß der neue Rechner mit ioBroker die IP von alten ioBroker Rechner bekommen hat. Sollte also alles ansprechbar sein wie bisher. Das Prozedere habe ich in den letzten Jahren mehrfach gemacht.
                                  Jetzt habe ich einen seltsamen Effekt, daß die admin Seiten Ports :8082 :8081 von aussen nicht mehr ansprechbar sind und auch die HM sowie ein paar MQTT Geräte keinen Zugriff mehr haben.
                                  Vom ioBroker Rechner aus geht Admin sowohl per localhost als auch per ID.
                                  Der Rechner ist anpingbar und wird im Netzwerk auch gefunden. Freigegebene Ordner sehe ich.
                                  Hat jemand eine Idee was ich noch wie freigeben muß, damit ich den Admin, Flot etc auch von aussen sehe?
                                  nik82N apollon77A 2 Antworten Letzte Antwort
                                  • K klassisch
                                    4.0.23
                                    v16.15.1
                                    8.11.0
                                    C:\Users\admin>
                                    @klassisch sagte in Test ioBroker unter Windows installieren - 2022 Edition:
                                    ich kenne mich mit Windows nicht aus, aber wimre sind diese Dateien auf die bisherige node/npm Version gebaut und müssten zumindest einen rebuild erfahren.
                                    Dazu könnte möglicherweise passen
                                    müsste aber @apollon77 was zu sagen
                                    • K klassisch
                                      nik82N
                                      nik82N
                                      nik82
                                      @klassisch
                                      Das wäre ja super wenn jetzt eine Migration gehen würde.
                                      Du hast du den alten iobroker-data Ordner drüber kopiert?
                                      Hast du den neuen Iobroker im gleichen Verzeichnis wie vorher drin oder in einem anderen?
                                      P.S. Wegen dem Admin von außen, schau mal ob du im Admin auch die 0.0.0.0 als IP Adresse drin hast:
                                      • mcm1957M mcm1957
                                        @apollon77
                                        mcm1957M
                                        mcm1957M
                                        mcm1957
                                        @apollon77
                                        Ich glaub ich hab rausgefunden, warum gestern die "neue" Installation node 14 geliefert hat.
                                        Die Version 1.1.0 des Installers war schon gestern VOR deinen Announcements aktiv. Daher waren die Downloaddaten bei meinem Reinstallationsversuch natürlich identisch.
                                        Version 1.1.0 -> liefert Node 16 aus
                                        Version 1.0.1 -> liefert Node 14 aus
                                        NUR wenn die Version 1.0.1 installiert ist / war dann macht die Installation von 1.1.0 scheinbar keinen Upgrade von node (und meldet auch nichts diesbezügliches). Erst nachdem ich node 14.x.x via Windows Programme desinstalliuert habe wurde Node 16.x (mit ein paar Problemchen) installiert.
                                        Ich teste das Ganze nochmals und schreib dann eine Zusammenfassung.
                                        • nik82N nik82
                                          @klassisch
                                          K
                                          K
                                          klassisch
                                          @nik82 sagte in Test ioBroker unter Windows installieren - 2022 Edition:
                                          ja, einfach lieblos drüber kopiert. Der Rechner baut dann nach dem ioBroker Start anscheinend recht viele Adapter neu. Die gehen nach und nach offline und im Log findet man build Nachrichten
                                          In einem anderen. Früher bei @Stabilostick Installer konnte man einen Instanznamen wählen und dann gab es entsprechende Ordner
                                          Beim neuen Installer ist einiges anders:
                                          • die Daten liegen unterc:\users\admin , c:\users\admin\iobroker-data
                                          • das ganze läuft unter Admin und es wurde eine Passwortvergabe erzwungen. Warum und wofür auch immer.
                                          Ja, das ist bei mir noch immer genau so
                                          Ich habe kein https aktiviert.
                                          Es wird mir aber in diesem Menue angezeigt, daß iobroker unter admin läuft
                                          Vielleicht gibt es dadurch Rechteprobleme?
                                          33.2k
                                          84.3k
