  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
812 Beiträge 97 Kommentatoren 485.5k Aufrufe 83 Beobachtet
  • bahnuhrB
    bahnuhrB
    bahnuhr
    #413
    hab das jetzt auch mal gemacht:
    Es kommt:
    dieter@VM-iobroker:/opt/iobroker/node_modules$ cd canvas
    dieter@VM-iobroker:/opt/iobroker/node_modules/canvas$ npm install
    [sudo] Passwort für dieter:
    npm WARN deprecated har-validator@5.1.5: this library is no longer supported
    npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
    > canvas@2.9.1 install
    > node-pre-gyp install --fallback-to-build
    node-pre-gyp info it worked if it ends with ok
    node-pre-gyp info using node-pre-gyp@1.0.9
    node-pre-gyp info using node@16.15.1 | linux | x64
    [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" already installed
    Pass --update-binary to reinstall or --build-from-source to recompile
    node-pre-gyp info ok
    added 449 packages, and audited 469 packages in 45s
    51 packages are looking for funding
      run `npm fund` for details
    3 vulnerabilities (2 moderate, 1 critical)
    To address all issues (including breaking changes), run:
      npm audit fix --force
    Run `npm audit` for details.
    Sind diese Meldungen richtig ?
    und bei ls canvas kommt wieder:
    dieter@VM-iobroker:/opt/iobroker$ npm ls canvas
    iobroker.inst@2.0.3 /opt/iobroker
    ├── canvas@2.9.1 extraneous
    └─┬ iobroker.mihome-vacuum@3.3.3
      └── canvas@2.9.1
    Danke.
    • bahnuhrB bahnuhr
      Es kommt:
        └── canvas@2.9.1
      apollon77A
      apollon77A
      #414
      @bahnuhr Sieht spontan gut aus ... tut es denn? und ja du hast jetzt ein "extranous "canvas .... tja ... is so :-)
      bahnuhrB Siggi0904S 2 Antworten Letzte Antwort
      • apollon77A apollon77
        bahnuhrB
        bahnuhrB
        bahnuhr
        #415
        @apollon77 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
        ja, funktioniert. Karte wird angezeigt.
        soll ich denn canvas bei /home/dieter irgendwie löschen?
        Oder lass ich es jetzt so?
        Danke.
          Siggi0904S
          Siggi0904S
          Siggi0904
          #416
          @apollon77 bei mir bleibt die Meldung gleich nach dem Start vom Adapter.
          CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
          • bahnuhrB bahnuhr
            apollon77A
            apollon77A
            #417
            @bahnuhr Ja das kannste löschen. Das ist dem iobroker egal
              bahnuhrB
              bahnuhrB
              bahnuhr
              #418
              und wie ?
              Danke.
              • bahnuhrB bahnuhr
                und wie ?
                apollon77A
                apollon77A
                #419
                @bahnuhr Lösch das ganze /home/dieter/node_modules?? Wenn da nix anderes war. Sonst "npm uninstall canvas" in /home/dieter
                • Siggi0904S Siggi0904
                  apollon77A
                  apollon77A
                  #420
                  @siggi0904 Hmmm ... Nicht hilfreich wenn der Adapter die echte Fehlermeldung versteckt ... Keine Ahnung ... versuch instanz zu löschen und adapter uninstall und neu installieren
                  bahnuhrB Siggi0904S 3 Antworten Letzte Antwort
                    bahnuhrB
                    bahnuhrB
                    bahnuhr
                    #421
                    Ich hatte nur die Instanz neu gestartet, dann war die fehlermeldung weg.
                    Danke.
                      bahnuhrB
                      bahnuhrB
                      bahnuhr
                      #422
                      habe erst uninstall, dann das ganze Verz. gelöscht.
                      Scheint geklappt zu haben.
                      unter (opt/iobroker kommt aber bei ls immer noch: extraneous
                      Naja, klappt ja.
                      Danke.
                        Siggi0904S
                        Siggi0904S
                        Siggi0904
                        #423
                        @apollon77 Beim Adapater deinstallieren hängt er gerade.
                          Siggi0904S
                          Siggi0904S
                          Siggi0904
                          #424
                          @apollon77 Neuinstallation von Adapter und Instance hat scheinbar geklappt.
                          Zum node.js noch eine Frage:
                          Sollte man da jetzt irgendwie aufräumen?
                          Oder wenn alles läuft Finger weg von den npm Befehlen?
                            Thomas BraunT
                            Thomas BraunT
                            #425
                            @siggi0904
                            Von npm direkt lässt man besser die Finger.
                            nodejs ist jetzt sauber installiert?
                            uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            sagt dazu?
                            Siggi0904S 1 Antwort Letzte Antwort
                              @siggi0904
                              sagt dazu?
                              Siggi0904S
                              Siggi0904S
                              Siggi0904
                              #426
                              @thomas-braun Sieht ganz sauber aus:
                              login as: iobroker
                              iobroker@192.168.178.64's password:
                              Linux iobroker 5.10.0-9-amd64 #1 SMP Debian 5.10.70-1 (2021-09-30) x86_64
                              permitted by applicable law.
                              You have new mail.
                              Last login: Sun Jun 19 13:00:41 2022 from 192.168.178.41
                              iobroker@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                              [sudo] Passwort für iobroker:
                              ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                              iobroker@iobroker:~$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              x86_64
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.15.1
                              v16.15.1
                              8.11.0
                              iobroker
                              /home/iobroker
                              OK:1 http://deb.debian.org/debian bullseye InRelease
                              OK:2 http://phoscon.de/apt/deconz bullseye InRelease
                              OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                              OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                              OK:5 https://deb.debian.org/debian-security bullseye-security InRelease
                              Alle Pakete sind aktuell.
                              nodejs:
                                Installiert:           16.15.1-deb-1nodesource1
                                Installationskandidat: 16.15.1-deb-1nodesource1
                                Versionstabelle:
                               *** 16.15.1-deb-1nodesource1 500
                                      500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                   12.22.5~dfsg-2~11u1 500
                                      500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                      500 https://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                                login as: iobroker
                                You have new mail.
                                x86_64
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.15.1
                                v16.15.1
                                8.11.0
                                iobroker
                                /home/iobroker
                                nodejs:
                                  Versionstabelle:
                                Thomas BraunT
                                Thomas BraunT
                                #427
                                @siggi0904 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                                Bis auf den ungeschickten username 'iobroker'.
                                  Siggi0904S
                                  Siggi0904S
                                  Siggi0904
                                  #428
                                  Jo, das will ich aber ungern angehen.
                                  Solange da keiner meckert, würd ich das so lassen.
                                    Thomas BraunT
                                    Thomas BraunT
                                    #429
                                    @siggi0904
                                    Leg dir halt einen user 'siggi' oder sowas an und lass den 'iobroker' in Ruh.
                                      @siggi0904
                                      Siggi0904S
                                      Siggi0904S
                                      Siggi0904
                                      #430
                                      da muss ich auch bei den Gruppen und Rechten aufpassen, dass der alles erhält.
                                      Wüsste nicht, wo ich da überall drauf achten muss.
                                        Thomas BraunT
                                        Thomas BraunT
                                        #431
                                        @siggi0904
                                        Die Gruppen kommen im Standard mit, es muss dann nur noch die Gruppe 'sudo' dem neuen user hinzugefügt werden.
                                        Geht in einer Zeile:
                                        sudo adduser siggi -G sudo
                                        In die Gruppe 'iobroker' würde ich den neuen user dann auch noch packen.
                                          @e-i-k-e sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                                          /opt/iobroker/node_modules/epoll
                                          cd /opt/iobroker/node_modules/epollund dann npm install
                                          E
                                          E
                                          e-i-k-e
                                          #432
                                          Ich habe bei zwei Slave ein anderes problem mit dem rpi2 Adapter.
                                          rpi2.1
                                          2022-06-19 18:25:19.807	error	cannot use GPIO: TypeError: Cannot read properties of null (reading 'setMode')
                                          rpi2.1
                                          2022-06-19 18:25:19.800	error	Cannot initialize GPIO: Error: Cannot find module 'rpi-gpio'Require stack:- /opt/iobroker/node_modules/iobroker.rpi2/main.js
                                          rpi2.1
                                          2022-06-19 18:25:19.441	info	starting. Version 1.2.0 in /opt/iobroker/node_modules/iobroker.rpi2, node: v16.15.1, js-controller: 4.0.23
                                          DIesmal brachte das up-/downgraden nichts.
                                          Und wenn ich deinen genannten Befehl versuch, verläuft dieser ins nichts. :/
                                          pi@raspberrypi-display1:~ $ cd /opt/iobroker/node_modules/epoll
                                          -bash: cd: /opt/iobroker/node_modules/epoll: Datei oder Verzeichnis nicht gefund        en
                                          Hast du noch eine Idee?
                                          Liebe Grüße
                                          83.8k
