  4. [How-to] Node.js ioBroker richtig updaten-2021/22 Edition
    6.7k
812 Beiträge 97 Kommentatoren 456.9k Aufrufe 83 Beobachtet
    @siggi0904
    Stell dich in
    /opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules/canvas
    und dann
    npm install
    Siggi0904S Offline
    Siggi0904S Offline
    Siggi0904
    #410
    @thomas-braun hm, da gibt es kein Canvas.
    iobroker@iobroker:/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules$ ls -lisa
    insgesamt 20
     537574 4 drwxrwxr-x+ 5 iobroker iobroker 4096 17. Mai 19:28 .
     524336 4 drwxrwxr-x+ 5 iobroker iobroker 4096 17. Mai 19:28 ..
     524332 4 drwxrwxr-x+ 6 iobroker iobroker 4096 17. Mai 19:28 qs
    2891192 4 drwxrwxr-x+ 3 iobroker iobroker 4096  6. Nov 2021  request
    2891190 4 drwxrwxr-x+ 3 iobroker iobroker 4096  6. Nov 2021  tough-cookie
    • Siggi0904S Siggi0904
      insgesamt 20
      #411
      @siggi0904 Dann nimm /opt/iobroker/node_modules/canvas
      und genau das sagte mein Satz oben. Schau wo es ist und da wo es ist mach den Befehl
      Siggi0904S 1 Antwort Letzte Antwort
      • apollon77A apollon77
        Siggi0904S Offline
        Siggi0904S Offline
        Siggi0904
        #412
        @apollon77
        Das lief soweit durch. Folgende Meldung kam:
        insgesamt 20
        iobroker@iobroker:/opt/iobroker/node_modules/iobroker.mihome-vacuum/node_modules$ cd ..
        iobroker@iobroker:/opt/iobroker/node_modules/iobroker.mihome-vacuum$ cd ..
        iobroker@iobroker:/opt/iobroker/node_modules$ cd canvas/
        iobroker@iobroker:/opt/iobroker/node_modules/canvas$ npm install
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated mkdirp@0.5.1: Legacy versions of mkdirp are no longer supported. Please update to mkdirp 1.x. (Note that the API surface has changed to use Promises in 1.x.)
        > canvas@2.9.1 install
        > node-pre-gyp install --fallback-to-build
        node-pre-gyp info it worked if it ends with ok
        node-pre-gyp info using node-pre-gyp@1.0.9
        node-pre-gyp info using node@16.15.1 | linux | x64
        [canvas] Success: "/opt/iobroker/node_modules/canvas/build/Release/canvas.node" already installed
        Pass --update-binary to reinstall or --build-from-source to recompile
        node-pre-gyp info ok
        added 448 packages, and audited 466 packages in 58s
        51 packages are looking for funding
          run `npm fund` for details
        3 vulnerabilities (2 moderate, 1 critical)
        To address all issues (including breaking changes), run:
          npm audit fix --force
        Run `npm audit` for details.
        • bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          #413
          hab das jetzt auch mal gemacht:
          Es kommt:
          dieter@VM-iobroker:/opt/iobroker/node_modules$ cd canvas
          dieter@VM-iobroker:/opt/iobroker/node_modules/canvas$ npm install
          [sudo] Passwort für dieter:
          added 449 packages, and audited 469 packages in 45s
          Sind diese Meldungen richtig ?
          und bei ls canvas kommt wieder:
          dieter@VM-iobroker:/opt/iobroker$ npm ls canvas
          iobroker.inst@2.0.3 /opt/iobroker
          ├── canvas@2.9.1 extraneous
          └─┬ iobroker.mihome-vacuum@3.3.3
            └── canvas@2.9.1
          Danke.
          • bahnuhrB bahnuhr
            Es kommt:
              └── canvas@2.9.1
            #414
            @bahnuhr Sieht spontan gut aus ... tut es denn? und ja du hast jetzt ein "extranous "canvas .... tja ... is so :-)
            bahnuhrB Siggi0904S 2 Antworten Letzte Antwort
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              #415
              @apollon77 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
              ja, funktioniert. Karte wird angezeigt.
              soll ich denn canvas bei /home/dieter irgendwie löschen?
              Oder lass ich es jetzt so?
              Danke.
                Siggi0904S Offline
                Siggi0904S Offline
                Siggi0904
                #416
                @apollon77 bei mir bleibt die Meldung gleich nach dem Start vom Adapter.
                CANVAS package not installed....please install Canvas package manually or disable Map in config see also https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/blob/master/lib/canvaserror.md
                • bahnuhrB bahnuhr
                  #417
                  @bahnuhr Ja das kannste löschen. Das ist dem iobroker egal
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    #418
                    und wie ?
                    Danke.
                    • bahnuhrB bahnuhr
                      und wie ?
                      #419
                      @bahnuhr Lösch das ganze /home/dieter/node_modules?? Wenn da nix anderes war. Sonst "npm uninstall canvas" in /home/dieter
                        #420
                        @siggi0904 Hmmm ... Nicht hilfreich wenn der Adapter die echte Fehlermeldung versteckt ... Keine Ahnung ... versuch instanz zu löschen und adapter uninstall und neu installieren
                        bahnuhrB Siggi0904S 3 Antworten Letzte Antwort
                          bahnuhrB Online
                          bahnuhrB Online
                          bahnuhr
                          #421
                          Ich hatte nur die Instanz neu gestartet, dann war die fehlermeldung weg.
                          Danke.
                            bahnuhrB Online
                            bahnuhrB Online
                            bahnuhr
                            #422
                            habe erst uninstall, dann das ganze Verz. gelöscht.
                            Scheint geklappt zu haben.
                            unter (opt/iobroker kommt aber bei ls immer noch: extraneous
                            Naja, klappt ja.
                            Danke.
                              Siggi0904S Offline
                              Siggi0904S Offline
                              Siggi0904
                              #423
                              @apollon77 Beim Adapater deinstallieren hängt er gerade.
                                Siggi0904S Offline
                                Siggi0904S Offline
                                Siggi0904
                                #424
                                @apollon77 Neuinstallation von Adapter und Instance hat scheinbar geklappt.
                                Zum node.js noch eine Frage:
                                Sollte man da jetzt irgendwie aufräumen?
                                Oder wenn alles läuft Finger weg von den npm Befehlen?
                                  #425
                                  @siggi0904
                                  Von npm direkt lässt man besser die Finger.
                                  nodejs ist jetzt sauber installiert?
                                  uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                  sagt dazu?
                                    @siggi0904
                                    sagt dazu?
                                    Siggi0904S Offline
                                    Siggi0904S Offline
                                    Siggi0904
                                    #426
                                    @thomas-braun Sieht ganz sauber aus:
                                    login as: iobroker
                                    iobroker@192.168.178.64's password:
                                    Linux iobroker 5.10.0-9-amd64 #1 SMP Debian 5.10.70-1 (2021-09-30) x86_64
                                    permitted by applicable law.
                                    You have new mail.
                                    Last login: Sun Jun 19 13:00:41 2022 from 192.168.178.41
                                    iobroker@iobroker:~$ sudo ln -s /usr/bin/node /usr/bin/nodejs
                                    [sudo] Passwort für iobroker:
                                    ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                                    iobroker@iobroker:~$ uname -m && which nodejs node npm && nodejs -v && node -v && npm -v && whoami && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                    x86_64
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    v16.15.1
                                    v16.15.1
                                    8.11.0
                                    iobroker
                                    /home/iobroker
                                    OK:1 http://deb.debian.org/debian bullseye InRelease
                                    OK:2 http://phoscon.de/apt/deconz bullseye InRelease
                                    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    OK:5 https://deb.debian.org/debian-security bullseye-security InRelease
                                    Alle Pakete sind aktuell.
                                    nodejs:
                                      Installiert:           16.15.1-deb-1nodesource1
                                      Installationskandidat: 16.15.1-deb-1nodesource1
                                      Versionstabelle:
                                     *** 16.15.1-deb-1nodesource1 500
                                            500 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages
                                         12.22.5~dfsg-2~11u1 500
                                            500 http://deb.debian.org/debian bullseye/main amd64 Packages
                                            500 https://deb.debian.org/debian-security bullseye-security/main amd64 Packages
                                      login as: iobroker
                                      You have new mail.
                                      x86_64
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      v16.15.1
                                      v16.15.1
                                      8.11.0
                                      iobroker
                                      /home/iobroker
                                      nodejs:
                                        Versionstabelle:
                                      #427
                                      @siggi0904 sagte in [How-to] Node.js ioBroker richtig updaten-2021/22 Edition:
                                      Bis auf den ungeschickten username 'iobroker'.
                                        Siggi0904S Offline
                                        Siggi0904S Offline
                                        Siggi0904
                                        #428
                                        Jo, das will ich aber ungern angehen.
                                        Solange da keiner meckert, würd ich das so lassen.
                                          #429
                                          @siggi0904
                                          Leg dir halt einen user 'siggi' oder sowas an und lass den 'iobroker' in Ruh.
