  3. Off Topic
  4. Grafana
  5. Fritzbox mit Grafana visualisieren [Version 2022]
    1.5k
Geplant Angeheftet Gesperrt Verschoben Grafana
144 Beiträge 12 Kommentatoren 38.8k Aufrufe 16 Beobachtet
  • Damrak2022D Damrak2022
    @crunchip Okay, habe eine Fehlermeldung entdeckt:
    pi@homebridge:~ $ sudo systemctl status grafana-server
    ● grafana-server.service - Grafana instance
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendo>
         Active: failed (Result: exit-code) since Thu 2022-04-21 07:29:06 BST; 14mi>
           Docs: http://docs.grafana.org
        Process: 18558 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --p>
       Main PID: 18558 (code=exited, status=1/FAILURE)
            CPU: 356ms
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Scheduled restar>
    Apr 21 07:29:06 homebridge systemd[1]: Stopped Grafana instance.
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Start request re>
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Failed with resu>
    Apr 21 07:29:06 homebridge systemd[1]: Failed to start Grafana instance.
    lines 1-13/13 (END)
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor>
         Active: failed (Result: exit-code) since Thu 2022-04-21 07:29:06 BST; 14min>
        Process: 18558 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pi>
            CPU: 356ms
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Scheduled restart>
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Start request rep>
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Failed with resul>
    lines 1-13/13 (END)
         Loaded: loaded (/lib/systemd/system/grafana-server.service; enabled; vendor preset: enabled)
         Active: failed (Result: exit-code) since Thu 2022-04-21 07:29:06 BST; 14min ago
        Process: 18558 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR>
            CPU: 356ms
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Scheduled restart job, restart counte>
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Start request repeated too quickly.
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Failed with result 'exit-code'.
    lines 1-13/13 (END)
        Process: 18558 ExecStart=/usr/sbin/grafana-server --config=${CONF_FILE} --pidfile=${PID_FILE_DIR}/grafan>
            CPU: 356ms
    Apr 21 07:29:06 homebridge systemd[1]: grafana-server.service: Scheduled restart job, restart counter is at >
    lines 1-13/13 (END)
    Kannst Du mir bitte sagen was ich jetzt machen muss?
    crunchipC
    crunchipC
    Developer Global Moderator Most Active Forum Testing
    @damrak2022 sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
    In der Grafana .ini steht das:
    aber anscheinend ist meine Grafana .ini leer
    ja was jetzt, leer oder nicht leer, hattest du falsch aufgerufen?
      Damrak2022D
      Damrak2022D
      Damrak2022
      @crunchip ja, und jetzt einen Fehler gefunden - siehe Post darüber
      Mit besten Grüßen
      Andy
                CPU: 356ms
        lines 1-13/13 (END)
                CPU: 356ms
        lines 1-13/13 (END)
                CPU: 356ms
        lines 1-13/13 (END)
                CPU: 356ms
        lines 1-13/13 (END)
        crunchipC
        crunchipC
        da gab es mal einen Versionssprung da gab es Probleme mit dem startscript, sollte bei dir allerdings jetzt nicht zu treffen, ist ja ne frische installation.
        Fakt ist, dein Grafana Service startet nicht, somit kommst du auch nicht auf die Seite.
        möglicherweise hast du irgend etwas in der .ini verfummelt.
        am einfachsten ist, du löscht Grafana incl Config und installierst es neu
          Damrak2022D
          Damrak2022D
          Damrak2022
          @crunchip Sind dann alle Dashboards weg, wahrscheinlich ja, oder? ( wäre nicht ganz so dramatisch )
          Mit welchem Befehl kann ich deinstallieren und dann wieder neu installieren?
          Mit besten Grüßen
          Andy
            crunchipC
            crunchipC
            ja, was hast du denn bis jetzt alles für dashboards? du hast doch gerade erst begonnen
            sudo apt-get purge --auto-remove grafana
              Damrak2022D
              Damrak2022D
              Damrak2022
              @crunchip 4 Stück mit insgesamt 11 Panels, aber das ist nicht schlimm.
              Und wie installiere ich dann sauber?
              Mit besten Grüßen
              Andy
              Damrak2022D crunchipC 2 Antworten Letzte Antwort
                Damrak2022D
                Damrak2022D
                Damrak2022
                @damrak2022 Wieso nicht installiert? Ich konnte doch die .ini aufrufen
                Reading package lists... Done
                Package 'grafana' is not installed, so not removed
                0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.```
                Mit besten Grüßen
                Andy
                  crunchipC
                  crunchipC
                  wie haste denn zuvor installiert?
                    Damrak2022D
                    Damrak2022D
                    Damrak2022
                    @crunchip Via Anleitung bei smarthome-tricks
                    Mit besten Grüßen
                    Andy
                      crunchipC
                      crunchipC
                      @damrak2022 https://grafana.com/tutorials/install-grafana-on-raspberry-pi/
                        Damrak2022D
                        Damrak2022D
                        Damrak2022
                        @crunchip okay und was ist mit der Meldung das Grafana nicht installiert sei - kann ja wohl nicht stimmen. Ich kann die .ini immer noch aufrufen und da steht z.B. auch der Secret Sexy drin, also muss ja was vorhanden sein. Das möchte ich halt erst wegbekommen.
                        Mit besten Grüßen
                        Andy
                          crunchipC
                          crunchipC
                          was kommt wenn du es so probierst?
                          sudo apt-get remove --auto-remove grafana
                          bzw zeig mal zuvor die Ausgabe von
                          apt policy grafana
                          frampF 1 Antwort Letzte Antwort
                          • RoddiEFR
                            RoddiEFR
                            RoddiEF
                            Ich hab das ganze mal aus Interesse nach dem hier auf einem Pi-4 4GB installiert, was auch Anfänglich funktioniert hat.
                            Aber, die Services laufen zwar , eine Verbindung zur Fritzbox kommt nicht zustande da " Unhandled python exception in init callback: OSError: fritzcollectd: Failed to connect to fritz.box", was mir sagt das mein FritzOS wohl zu neu ist.
                            Ach und was mir noch Einfällt, ich musste bei "sudo apt-get install -y python-pip" bei python-pip nach python eine 3 mit angeben also "sudo apt-get install -y python3-pip" da es sonst nicht Funktionierte.
                            Ansonsten lief alles , wie gesagt , ohne Problem durch.
                            Mfg.
                            Ich bin wie ich bin, was anderes bekommt man nicht !!
                            crunchipC Damrak2022D 2 Antworten Letzte Antwort
                            • RoddiEFR RoddiEF
                              Mfg.
                              crunchipC
                              crunchipC
                              @roddief theoretisch kann man sich die Werte auch mit dem upnp Adapter direkt im iobroker holen. Hatte das damals so laufen.
                              • RoddiEFR RoddiEF
                                Mfg.
                                Damrak2022D
                                Damrak2022D
                                Damrak2022
                                @roddief Das mit der 3 angeben habe ich gemacht
                                Nun hat mir ja @crunchip empfohlen, mein gesamtes Grafana zu löschen, weil ich nicht mehr auf die Webseite komme.
                                Wenn ich allerdings den Befehl
                                eingebe bekomme ich folgendes:
                                pi@homebridge:~ $ sudo apt-get remove --auto-remove grafana
                                Allerdings komme ich noch in die Grafana.ini was ich garnicht verstehe
                                Mit dem Befehl:
                                apt policy grafana
                                zeigt er mir folgendes:
                                pi@homebridge:~ $ apt policy grafana
                                grafana:
                                  Installed: (none)
                                  Candidate: 7.0.0
                                  Version table:
                                     7.0.0 500
                                        500 https://packages.grafana.com/enterprise/deb stable/main armhf Packag
                                Und nun schreibst Du das Fritz=s wohl zu neu ist.
                                Wie mache ich nun weiter?
                                Wie bekomme ich die ganzen schon installierten Pakete vorn fritz Collectd weg, falls notwendig
                                Und vor allem, wie komme ich wieder auf die Grafana Oberfläche?
                                Mit besten Grüßen
                                Andy
                                  Mit dem Befehl:
                                  apt policy grafana
                                  grafana:
                                    Installed: (none)
                                    Candidate: 7.0.0
                                    Version table:
                                       7.0.0 500
                                  Thomas BraunT
                                  Thomas BraunT
                                  @damrak2022
                                  config-Dateien werden nicht unbedingt gelöscht.
                                  Da müsste man prunen.
                                  Hast du grafana immer schön über apt / einen Paketmanager installiert oder mal 'irgendwie' am System vorbei?
                                  Zum Fritz-Zeuch:
                                  '/home/pi/.local/bin' which is not on PATH.
                                  bedeutet, dass die Befehle zwar direkt aufrufbar sind, aber nicht per simplem Konsolenkommando, weil an der Stelle nicht danach gesucht wird, weil nicht im default $PATH.
                                    @damrak2022
                                    Zum Fritz-Zeuch:
                                    Damrak2022D
                                    Damrak2022D
                                    Damrak2022
                                    @thomas-braun Grafana habe ich per Anleitung bei smarthome-tricks: Grafana und Influxdb installieren gemacht
                                    Jetzt habe ich versucht das ganze fritzcollectd mit dem Befehl
                                    pip uninstall fritzcollectd
                                    zu löschen und bekomme dies:
                                    pi@homebridge:~ $ pip uninstall fritzcollectd
                                    Found existing installation: fritzcollectd 0.7.0
                                    Uninstalling fritzcollectd-0.7.0:
                                      Would remove:
                                        /usr/local/lib/python3.9/dist-packages/fritzcollectd-0.7.0.dist-info/*
                                        /usr/local/lib/python3.9/dist-packages/fritzcollectd/*
                                    Proceed (y/n)? y
                                    ERROR: Exception:
                                    Traceback (most recent call last):
                                      File "/usr/lib/python3.9/shutil.py", line 806, in move
                                        os.rename(src, real_dst)
                                    PermissionError: [Errno 13] Permission denied: '/usr/local/lib/python3.9/dist-packages/fritzcollectd-0.7.0.dist-info/' -> '/tmp/pip-uninstall-t5dydebm'
                                    During handling of the above exception, another exception occurred:
                                      File "/usr/lib/python3/dist-packages/pip/_internal/cli/base_command.py", line 223, in _main
                                        status = self.run(options, args)
                                      File "/usr/lib/python3/dist-packages/pip/_internal/commands/uninstall.py", line 89, in run
                                        uninstall_pathset = req.uninstall(
                                      File "/usr/lib/python3/dist-packages/pip/_internal/req/req_install.py", line 694, in uninstall
                                        uninstalled_pathset.remove(auto_confirm, verbose)
                                      File "/usr/lib/python3/dist-packages/pip/_internal/req/req_uninstall.py", line 403, in remove
                                        moved.stash(path)
                                      File "/usr/lib/python3/dist-packages/pip/_internal/req/req_uninstall.py", line 292, in stash
                                        renames(path, new_path)
                                      File "/usr/lib/python3/dist-packages/pip/_internal/utils/misc.py", line 355, in renames
                                        shutil.move(old, new)
                                      File "/usr/lib/python3.9/shutil.py", line 818, in move
                                        rmtree(src)
                                      File "/usr/lib/python3.9/shutil.py", line 718, in rmtree
                                        _rmtree_safe_fd(fd, path, onerror)
                                      File "/usr/lib/python3.9/shutil.py", line 675, in _rmtree_safe_fd
                                        onerror(os.unlink, fullname, sys.exc_info())
                                      File "/usr/lib/python3.9/shutil.py", line 673, in _rmtree_safe_fd
                                        os.unlink(entry.name, dir_fd=topfd)
                                    PermissionError: [Errno 13] Permission denied: 'INSTALLER'
                                    pi@homebridge:~ $
                                    Bin nun echt ratlos
                                    Mit besten Grüßen
                                    Andy
                                        Would remove:
                                      Proceed (y/n)? y
                                      ERROR: Exception:
                                          moved.stash(path)
                                          rmtree(src)
                                      pi@homebridge:~ $
                                      Bin nun echt ratlos
                                      Thomas BraunT
                                      Thomas BraunT
                                      Muss wohl mit root-Rechten rausgeklopft werden:
                                      sudo pip uninstall fritzcollectd
                                        Damrak2022D
                                        Damrak2022D
                                        Damrak2022
                                        @thomas-braun sagte in Fritzbox mit Grafana visualisieren [Version 2022]:
                                        Das mit dem sudo vergesse ich immer - ja hat geklappt.
                                        Kannst Du mir noch sagen wie ich das mit Grafana hinbekomme? Seltsamerweise komme ich ja noch zur Grafana .ini
                                        Wenn das dann wieder läuft möchte ich die FritzBox laut dieser Anleitung einbinden
                                        Anleitung
                                        Bei dieser Anleitung bin ich beim letzten Versuch an diesem Punkt gescheitert:
                                        # Erst die INI kopieren:
                                        sudo cp /opt/fritzinfluxdb/./fritzinfluxdb.ini-sample /opt/fritzinfluxdb/fritzinfluxdb.ini
                                        # In der INI die Einstellungen zur Fritzbox vornehmen (am besten einen neuen Benutzer in der Fritzbox anlegen und die Credentials hier verwenden):
                                        sudo nano /opt/fritzinfluxdb/fritzinfluxdb.ini
                                        Wie muss ich andieser Stelle exakt vorgehen?
                                        Mit besten Grüßen
                                        Andy
                                          Anleitung
                                          Thomas BraunT
                                          Thomas BraunT
                                          @damrak2022
                                          Ich hab grafana nicht im Einsatz. Aber grafana.ini hört sich nach einer der config files an, nicht mehr.
                                          apt policy grafana*
                                          liefert?
                                          83.8k
