  4. js-controller 3.3 jetzt im STABLE!
    apollon77A
344 Beiträge 61 Kommentatoren 141.9k Aufrufe 46 Beobachtet
  • H hegse
    Gerade das Update auf die aktuellste Version gemacht.
    Bekomme folgende Meldung angezeigt:
    hegse@Iobroker:~$ iobroker upgrade self
    Update js-controller from @3.3.21 to @3.3.22
    NPM version: 6.14.15
    npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
    In file included from ../authenticate_pam.cc:23:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2294:7: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
     2294 |     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
    ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
      107 |   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
    ../../nan/nan.h:1026:46: note: declared here
     1026 |   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../authenticate_pam.cc:147:83: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
      147 |   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
    In file included from /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:67,
                     from ../../nan/nan.h:56,
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, v8::Local<v8::Value>)’
     3717 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3717:43: note:   candidate expects 2 arguments, 1 provided
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note: candidate: ‘v8::MaybeLocal<v8::Value> v8::Object::Get(v8::Local<v8::Context>, uint32_t)’
     3720 |   V8_WARN_UNUSED_RESULT MaybeLocal<Value> Get(Local<Context> context,
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3720:43: note:   candidate expects 2 arguments, 1 provided
    ../authenticate_pam.cc:150:30: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
      150 |    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
          |                              char [128]
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/v8.h:3037:26: note:   initializing argument 1 of ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’ 3037 |   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    ../authenticate_pam.cc:152:69: error: no matching function for call to ‘v8::Array::Get(v8::Local<v8::String>)’
      152 |   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
    ../authenticate_pam.cc:155:29: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
      155 |    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
          |                             char [128]
    ../authenticate_pam.cc:160:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
      160 |  username->WriteUtf8(m->username, sizeof(m->username) - 1);
          |                         char [128]
    ../authenticate_pam.cc:161:25: error: cannot convert ‘char [128]’ to ‘v8::Isolate*’
      161 |  password->WriteUtf8(m->password, sizeof(m->password) - 1);
          |                         char [128]
    ../authenticate_pam.cc: At global scope:
    ../authenticate_pam.cc:170:6: error: variable or field ‘init’ declared void
      170 | void init(Handle<Object> exports) {
    ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
    ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
    In file included from ../../nan/nan.h:56,
    ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope; did you mean ‘int’?
      175 | NODE_MODULE(authenticate_pam, init);
    /home/iobroker/.cache/node-gyp/14.18.1/include/node/node.h:787:36: note: in definition of macro ‘NODE_MODULE_X’
      787 |       (node::addon_register_func) (regfunc),                          \
    ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
    make: *** [authenticate_pam.target.mk:111: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:400:28)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:282:12)
    gyp ERR! System Linux 5.10.0-9-amd64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v14.18.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    Soweit läuft alles nach dem Update.
    Thomas BraunT
    Thomas BraunT
    #286
    @hegse
    Ist da zufällig der Adapter terminal installiert? Dann schmeiß den raus.
    H 1 Antwort Letzte Antwort
      @hegse
      H
      H
      hegse
      #287
      @thomas-braun ja der ist installiert.
      Alles klar, dann schmeiß ich den mal raus. Besten Dank!
      • B
        B
        BlueEssi
        #288
        Hallo zusammen, ist die Liste der inkompatiblen Adapter am Thread-Anfang immer noch aktuell? Ich habe inzwischen leider das Problem, dass 3-4 meiner Adapter auf dieser Liste stehen, aber andere Adapter das Upgrade voraussetzen um auf den aktuellen Stand aufzurüsten.
        • B BlueEssi
          apollon77A
          apollon77A
          #289
          @blueessi Die Aussage geht anders rum: Folgende Adapter müssen aktualisiert werden weil sie in den damals aktuellen Versionen nicht vollständig kompatibel waren.
          Das hat mit "eine neue version des Adapters braucht bitte js.cotnroller in Version X" nichts zu tun. Das soll verhindern das Du dir dein System kaputt machst
          • apollon77A apollon77
            B
            B
            BlueEssi
            #290
            @apollon77 Das beantwortet leider nicht meine Frage. Wie bekomme ich raus, ob meine benötigten Adapter mit 3.3 kompatibel sind?
            Thomas BraunT apollon77A 2 Antworten Letzte Antwort
            • B BlueEssi
              Thomas BraunT
              Thomas BraunT
              #291
              @blueessi
              Im stable-Repo alles auf Stand bringen.
              • B BlueEssi
                apollon77A
                apollon77A
                #292
                @blueessi Wenn Du so rum fragst ist die obige Liste und Infos in diesem Thread (falls wir welche vergessen haben zu adden) aktuell und exakt wie @Thomas-Braun sagt: Wenn alles in Stable aktuell ist - oder du die adapter die du wegen "Zu altem js-controller" nicht updaten kannst gemerkt sind und gleich als erstes nach dem update aktualisiert werden ... dann sollte das nach grobem Wissen passen
                  B
                  B
                  BlueEssi
                  #293
                  @apollon77 OK, danke. Es sieht so aus, dass ich mich wohl noch eine Weile gedulden muss um auf 3.3 hochrüsten zu können. Ich hoffe, die "alten" Adapter werden irgendwann überhaupt nachgezogen.
                  • B BlueEssi
                    Thomas BraunT
                    Thomas BraunT
                    #294
                    @blueessi
                    Wie schaut denn das überhaupt aus bei dir?
                    iobroker update -i
                    • B BlueEssi
                      apollon77A
                      apollon77A
                      #295
                      @blueessi naja wenn Du genau liesst ist das einzige was die alten Adapter ggf tun ist "Info" logging zu machen das was nicht stimmt ... ehrlich ... Loglevel hochsetzen in der Wartezeit und gut ... ich denke nicht das das vom Update abhalten sollte
                        B
                        B
                        BlueEssi
                        #296
                        @apollon77 Ok, das war mir nicht bewusst. Vielleicht könntest du den Hinweis in der Inkompatibilitäts-Auflistung oben ergänzen. Ich werde es testen. Danke.
                        • S
                          S
                          sandro_gera
                          #297
                          Hallo an alle,
                          ich hab folgende Fehlermeldung bekommen
                          pi@RaspBerry4BioBroker:~ $ iob upgrade self
                          npm install iobroker.js-controller@3.3.22 --loglevel error --unsafe-perm --prefi                       x "/opt/iobroker" (System call)
                          Server Cannot move /opt/iobroker/iobroker-data/objects.json.new to /opt/iobroker                       /iobroker-data/objects.json: ENOENT: no such file or directory, stat '/opt/iobro                       ker/iobroker-data/objects.json.new'. Try direct write as fallback
                          Das update scheint aber funktioniert zu haben.
                          Muß ich jetzt irgend etwas unternehmen?
                          Master RPI4 8GB, Slave RPI3 1GB
                          Node.js v18.17.1, npm: 9.6.7,
                          JS-Controller: 5.0.16
                          • S sandro_gera
                            Hallo an alle,
                            apollon77A
                            apollon77A
                            #298
                            @sandro_gera Ne, das ist am Ende nur ne Info meldung. Wenn sonst kein Fehler ds ist ist oder kam alles ok
                            • NWHN
                              NWHN
                              NWH
                              #299
                              Hallo
                              Wollte wie immer das update per Konsole machen, aber diesmal kommt diese Meldung.
                              Wer kann mir sagen warum ich nicht auf die Version 3.3.22 komme.
                              Iobrocker läuft auf eine Synology im docker.
                              Neu gestartet habe ich auch schon.
                              Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                              • NWHN NWH
                                Hallo
                                Thomas BraunT
                                Thomas BraunT
                                #300
                                @nwh
                                Keine Screenshots aus der Konsole. Text als Text in CodeTags posten.
                                Und auch keine Phantasie-Kommandos verwenden.
                                apt upgrade
                                für das System,
                                für den js-controller.
                                NWHN 1 Antwort Letzte Antwort
                                • NWHN NWH
                                  Hallo
                                  GlasfaserG
                                  GlasfaserG
                                  #301
                                  @nwh sagte in js-controller 3.3 jetzt im STABLE!:
                                  Aber nicht so !!
                                  So:
                                  pkill -u iobroker
                                    @nwh
                                    apt upgrade
                                    für das System,
                                    NWHN
                                    NWHN
                                    NWH
                                    #302
                                    Ja tut mir leid. Kommt nicht wieder vor.
                                    Danke für die Info, hat schon funktioniert.
                                    • R
                                      R
                                      root_
                                      #303
                                      Wie komme ich von der 3.3.22 wieder auf die 3.3.21?
                                      • R root_
                                        #304
                                        @root_ sagte in js-controller 3.3 jetzt im STABLE!:
                                        warum willst du das?
                                        in 3.3.22 ist ein Bug behoben worden
                                        • R
                                          R
                                          root_
                                          #305
                                          Weil mein iPad 4 nicht mehr funktioniert.
                                          HomoranH apollon77A 2 Antworten Letzte Antwort
                                          83.9k
