  4. [Tester gesucht] WireGuard UI Installer
68 Beiträge 11 Kommentatoren 11.3k Aufrufe 14 Beobachtet
  • CrunkFXC CrunkFX
    @david-g nochmal bitte aber mit sudo
    David G.D Online
    David G.D Online
    David G.
    @crunkfx
    Wird ohne Bestätigung angenommen.
    Hab mal einen Status nachgeschoben.
    Last login: Sun Nov 28 14:09:34 2021 from 192.168.99.77
    pi@iobroker:~ $ sudo systemctl start wireguard-ui
    pi@iobroker:~ $ sudo systemctl status wireguard-ui
    ● wireguard-ui.service
       Loaded: loaded (/etc/systemd/system/wireguard-ui.service; en   Active: failed (Result: exit-code) since Sun 2021-11-28 14:4  Process: 31190 ExecStart=/opt/wireguard-ui/wireguard-ui (code Main PID: 31190 (code=exited, status=203/EXEC)
    Nov 28 14:40:08 iobroker systemd[1]: Started wireguard-ui.serviNov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: MainNov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: Faillines 1-11/11 (END)...skipping...
    Nov 28 14:40:08 iobroker systemd[1]: Started wireguard-ui.serviNov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: MainNov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: Fail~
       Loaded: loaded (/etc/systemd/system/wireguard-ui.service; en   Active: failed (Result: exit-code) since Sun 2021-11-28 14:4  Process: 31190 ExecStart=/opt/wireguard-ui/wireguard-ui (code● wireguard-ui.service
       Loaded: loaded (/etc/systemd/system/wireguard-ui.service; en   Active: failed (Result: exit-code) since Sun 2021-11-28 14:4  Process: 31190 ExecStart=/opt/wireguard-ui/wireguard-ui (code Main PID: 31190 (code=exited, status=203/EXEC)                Nov 28 14:40:08 iobroker systemd[1]: Started wireguard-ui.serviNov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[31190]: wireguard-ui.service: Nov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: MainNov 28 14:40:08 iobroker systemd[1]: wireguard-ui.service: Fail~
    lines 1-11/11 (END)
    • dslraserD dslraser
      @crunkfx sagte in [Tester gesucht] WireGuard UI Installer:
      @dslraser @BBTown
      Ich habe nun den Installer komplett Entdockert😳(Steht so bestimmt im Duden!).
      Wer testen möchte und bereits die Docker Variante am laufen hat macht folgendes:
      docker stop wgui
      docker rm wgui
      Anschließend für alle:
      wget https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/installer-wgui.sh -O installer-wgui.sh && bash installer-wgui.sh
      Die Konfigdaten liegen im Ordner:
      /opt/wireguard-ui/db
      wer damit spielen möchte.
      Ich bin noch unterwegs. Wenn ich heute Abend zu Hause bin werde ich es probieren.
      Vielen Dank für Deine Mühe.
      dslraserD Offline
      dslraserD Offline
      dslraser
      @dslraser sagte in [Tester gesucht] WireGuard UI Installer:
      EDIT: gibt es eine Möglichkeit bei der Installation "Pausen" einzulegen ? So kann ich leider nichtmal sehen wo der Fehler auftritt.
      CrunkFXC 1 Antwort Letzte Antwort
      • CrunkFXC CrunkFX
        @dslraser @BBTown
        docker stop wgui
        docker rm wgui
        BBTownB Offline
        BBTownB Offline
        BBTown
        @dslraser @BBTown
        Ich habe nun den Installer komplett Entdockert(Steht so bestimmt im Duden!).
        ich schau mal, dass ich das Montag hinbekomme.
        Vielen Dank schon einmal vorweg !! 👍
          CrunkFXC Offline
          CrunkFXC Offline
          CrunkFX
          Forum Testing
          @dslraser Ich packe eine Fehleranalyse in die neue Version
          • CrunkFXC CrunkFX
            dslraserD Offline
            dslraserD Offline
            dslraser
            EDIT: jetzt habe ich noch einen Raspi probiert....
            Failed to stop wireguard-ui.service: Unit wireguard-ui.service not loaded./user
            #### 1.   Updates werden geholt und Installiert────────────────────────────────
            #apt update wird ausgführt
            WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                    │ Dieser Installer wird Wireguard-UI, sowie alle           │
            #Erfolgreichotwendigen Pakete und Paketquellen laden und            │
            #apt upgrade wird ausgführt                                         │
            #Erfolgreich                                                        │
            #### 3.   WireGuard-UI wird installiert                             │
            --2021-11-28 23:11:12--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.path                                             │
            Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.109.133, 185.199.108.133, 185.199.110.133, ...───────────────┤
            Verbindungsaufbau zu raw.githubusercontent.com (raw.githubusercontent.com)|185.199.109.133|:443 … verbunden.────────────────────────────────────────┘
            HTTP-Anforderung gesendet, auf Antwort wird gewartet … 200 OK
            Länge: 143 [text/plain]
            Wird in »/etc/systemd/system/wgui.path« gespeichert.
            /etc/systemd/system 100%[===================>]     143  --.-KB/s    in 0s
            2021-11-28 23:11:12 (1,93 MB/s) - »/etc/systemd/system/wgui.path« gespeichert [143/143]
            --2021-11-28 23:11:12--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.service
            Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.109.133, 185.199.108.133, ...
            Verbindungsaufbau zu raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443 … verbunden.
            Länge: 172 [text/plain]
            Wird in »/etc/systemd/system/wgui.service« gespeichert.
            /etc/systemd/system 100%[===================>]     172  --.-KB/s    in 0s
            2021-11-28 23:11:13 (1,66 MB/s) - »/etc/systemd/system/wgui.service« gespeichert [172/172]
            --2021-11-28 23:11:13--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/wireguard-ui.service
            Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.110.133, 185.199.111.133, 185.199.109.133, ...
            Verbindungsaufbau zu raw.githubusercontent.com (raw.githubusercontent.com)|185.199.110.133|:443 … verbunden.
            Länge: 150 [text/plain]
            Wird in »/etc/systemd/system/wireguard-ui.service« gespeichert.
            /etc/systemd/system 100%[===================>]     150  --.-KB/s    in 0s
            2021-11-28 23:11:13 (1,59 MB/s) - »/etc/systemd/system/wireguard-ui.service« gespeichert [150/150]
            tar: install.tar.gz: Funktion open fehlgeschlagen: Datei oder Verzeichnis nicht gefunden
            tar: Error is not recoverable: exiting now
            rm: das Entfernen von 'install.tar.gz' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
            Created symlink /etc/systemd/system/multi-user.target.wants/wgui.path → /etc/systemd/system/wgui.path.
            Created symlink /etc/systemd/system/wgui.path.requires/wgui.service → /etc/systemd/system/wgui.service.
            Job for wgui.service failed because the control process exited with error code.
            See "systemctl status wgui.service" and "journalctl -xe" for details.
            Created symlink /etc/systemd/system/default.target.wants/wireguard-ui.service → /etc/systemd/system/wireguard-ui.service.
            root@raspberrypi:~#
              #Erfolgreich                                                        │
              root@raspberrypi:~#
              CrunkFXC Offline
              CrunkFXC Offline
              CrunkFX
              Forum Testing
              @dslraser Interessant, scheinbar lädt er die benötigte Datei nicht mit. Kannst du mir den Output von
              uname -i
              Zeigen. Ich denke ihr arbeitet beide mit einer 64Bit arm Plattform. Die ist (noch) nicht implementiert.
              • David G.D David G.
                @crunkfx
                Jetzt kommt was.
                Aber auch mit Fehler:
                wireguard-ui-install V1.0.3 Stand 27.11.2021     @2021 forum.
                ┌─────────────────Wollen Sie fortfahren?───────────────────┐
                │ Dieser Installer wird Wireguard-UI, sowie alle           │   │ notwendigen Pakete und Paketquellen laden und            │
                │ installieren.                                            │
                │               <  Ja  >        < Nein >                   │
                #Erfolgreich
                #Erfolgreich
                mkdir: das Verzeichnis „/opt/wireguard-ui“ kann nicht angelegt werden: Die Datei existiert bereits
                --2021-11-28 14:03:52--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.path
                Auflösen des Hostnamens raw.githubusercontent.com (raw.githubusercontent.com)… 185.199.111.133, 185.199.109.133, 185.199.110.133, ...
                /etc/systemd/sy 100%[======>]     143  --.-KB/s    in 0s
                2021-11-28 14:03:52 (2,99 MB/s) - »/etc/systemd/system/wgui.path« gespeichert [143/143]
                --2021-11-28 14:03:52--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.service
                ┌─────────────────────────ERROR────────────────────────────┐   │ Ups. Irgendwas ist da schiefgeleufen ;(                  │   │                                                          │
                │                         <  OK  >                         │
                CrunkFXC Offline
                CrunkFXC Offline
                CrunkFX
                Forum Testing
                @david-g Kannst auch du mir den Output von
                uname -i
                zeigen.
                Danke😉
                • CrunkFXC CrunkFX
                  uname -i
                  zeigen.
                  Danke😉
                  David G.D Online
                  David G.D Online
                  David G.
                  @crunkfx
                  pi@iobroker:~ $ uname -i
                  unknown
                    @crunkfx
                    unknown
                    CrunkFXC Offline
                    CrunkFXC Offline
                    CrunkFX
                    Forum Testing
                    @david-g kannst du bitte noch
                    uname -m
                    Hinterherschieben
                    • CrunkFXC CrunkFX
                      uname -m
                      Hinterherschieben
                      David G.D Online
                      David G.D Online
                      David G.
                      @crunkfx
                      pi@iobroker:~ $ uname -m
                      armv7l
                      Screenshot von alles Spezifikationen von dem System. Das Forum erlaubt leider keinen Upload weil die Auflösung zu hoch ist. Sind zusammengefügte Screenshots weil die App alles untereinander anzeigt.
                      klick
                      CrunkFXC 2 Antworten Letzte Antwort
                        @crunkfx
                        armv7l
                        klick
                        CrunkFXC Offline
                        CrunkFXC Offline
                        CrunkFX
                        Forum Testing
                        @david-g Danke ich werde mal schauen was ich machen kann
                        • WszeneW Offline
                          WszeneW Offline
                          Wszene
                          Ich muss mal ganz bescheiden fragen
                          Wird Wireguard gleich mit installiert oder sollte das schon vorher installiert sein?
                          Danke im Voraus
                          Marcel
                          Meine Hard- & Software:
                          • CC2652P Zigbee Stick
                          • Lichtschalter mit Tasmota
                          • IKEA TRÅDFRI Glühbirnen
                          • Aqara Sensoren
                          • WszeneW Wszene
                            Danke im Voraus
                            Marcel
                            CrunkFXC Offline
                            CrunkFXC Offline
                            CrunkFX
                            Forum Testing
                            @wszene Das muss hierfür leider schon Installiert sein. Wenn du Proxmox nutzt habe ich dazu bereits eine Anleitung mit Installer gemacht. Sobald der WGUI Installer hier vernünftig läuft, werde ich die Wireguard Installation integrieren.
                            WszeneW 1 Antwort Letzte Antwort
                              @crunkfx
                              armv7l
                              klick
                              CrunkFXC Offline
                              CrunkFXC Offline
                              CrunkFX
                              Forum Testing
                              @david-g @dslraser Ich habe das Script für Raspi und Konsorten angepasst. Bitte stellt sicher, dass beim Installer oben in der Zeile V1.0.4 angezeigt wird sonst die .sh Datei löschen und neu ausführen.
                              • CrunkFXC CrunkFX
                                WszeneW Offline
                                WszeneW Offline
                                Wszene
                                @crunkfx
                                Ich danke dir
                                Ich wollte es nur wissen da ich Wireguard schon in einem LXC laufen habe
                                • Aqara Sensoren
                                • WszeneW Wszene
                                  @crunkfx
                                  Ich danke dir
                                  CrunkFXC Offline
                                  CrunkFXC Offline
                                  CrunkFX
                                  Forum Testing
                                  @wszene Kein Problem, dann sollte der Installer funktionieren, falls nicht bitte melden.
                                  • CrunkFXC CrunkFX
                                    dslraserD Offline
                                    dslraserD Offline
                                    dslraser
                                    @crunkfx
                                    Das ist jetzt wieder ein Tinkerboard S
                                    Failed to stop wireguard-ui.service: Unit wireguard-ui.service not loaded./user/crunkfx
                                    #### 1.   Updates werden geholt und Installiert───────────────────────────────────────────────────────────────────────────
                                    #Erfolgreich
                                    #Erfolgreich                  │ Dieser Installer wird Wireguard-UI, sowie alle           │
                                    #### 3.   WireGuard-UI wird installiertigen Pakete und Paketquellen laden und            │
                                    --2021-11-29 13:56:51--  https://github.com/ngoduykhanh/wireguard-ui/releases/download/v0.3.5/wireguard-ui-v0.3.5-linux-arm.tar.gz                       │                                                          │
                                    Resolving github.com (github.com)... 140.82.121.4                                        │
                                    Connecting to github.com (github.com)|140.82.121.4|:443... connected.                    │
                                    HTTP request sent, awaiting response... 302 Found                                        │
                                    Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/256406208/c7c92014-4382-403f-a3d9-044543548bd0?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20211129%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20211129T125651Z&X-Amz-Expires=300&X-Amz-Signature=3d1a47b0214dfbf95881587ff77dde2920e728037537627f69052faeab05bf46&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=256406208&response-content-disposition=attachment%3B%20filename%3Dwireguard-ui-v0.3.5-linux-arm.tar.gz&response-content-type=application%2Foctet-stream [following]
                                    --2021-11-29 13:56:51--  https://objects.githubusercontent.com/github-production-release-asset-2e65be/256406208/c7c92014-4382-403f-a3d9-044543548bd0?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=AKIAIWNJYAX4CSVEH53A%2F20211129%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20211129T125651Z&X-Amz-Expires=300&X-Amz-Signature=3d1a47b0214dfbf95881587ff77dde2920e728037537627f69052faeab05bf46&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=256406208&response-content-disposition=attachment%3B%20filename%3Dwireguard-ui-v0.3.5-linux-arm.tar.gz&response-content-type=application%2Foctet-stream
                                    Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.109.133, 185.199.108.133, 185.199.110.133, ...
                                    Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.109.133|:443... connected.
                                    HTTP request sent, awaiting response... 200 OK
                                    Length: 8928215 (8.5M) [application/octet-stream]
                                    Saving to: ‘/opt/wireguard-ui/install.tar.gz’
                                    /opt/wireguard-ui/install.tar. 100%[===================================================>]   8.51M  7.23MB/s    in 1.2s
                                    2021-11-29 13:56:53 (7.23 MB/s) - ‘/opt/wireguard-ui/install.tar.gz’ saved [8928215/8928215]
                                    --2021-11-29 13:56:53--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.path
                                    Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.110.133, 185.199.108.133, ...
                                    Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... connected.
                                    Length: 143 [text/plain]
                                    Saving to: ‘/etc/systemd/system/wgui.path’
                                    /etc/systemd/system/wgui.path  100%[===================================================>]     143  --.-KB/s    in 0s
                                    2021-11-29 13:56:53 (3.54 MB/s) - ‘/etc/systemd/system/wgui.path’ saved [143/143]
                                    --2021-11-29 13:56:53--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/main/wireguard/wgui.service
                                    Length: 172 [text/plain]
                                    Saving to: ‘/etc/systemd/system/wgui.service’
                                    /etc/systemd/system/wgui.servi 100%[===================================================>]     172  --.-KB/s    in 0s
                                    2021-11-29 13:56:53 (1.75 MB/s) - ‘/etc/systemd/system/wgui.service’ saved [172/172]
                                    --2021-11-29 13:56:53--  https://raw.githubusercontent.com/KleSecGmbH/ioBroker/dev/wireguard/wireguard-ui.service
                                    Length: 150 [text/plain]
                                    Saving to: ‘/etc/systemd/system/wireguard-ui.service’
                                    /etc/systemd/system/wireguard- 100%[===================================================>]     150  --.-KB/s    in 0s
                                    2021-11-29 13:56:54 (3.86 MB/s) - ‘/etc/systemd/system/wireguard-ui.service’ saved [150/150]
                                    tinkerboard:~:#
                                    Edit: wie mache ich jetzt die eigentliche Installation von WG ? Der Rest, also die UI läuft.
                                    • CrunkFXC CrunkFX
                                      David G.D Online
                                      David G.D Online
                                      David G.
                                      @crunkfx
                                      Ist durchgelaufen und läuft.
                                      Muss gestehen, hab das jetzt blind getestet weil ich schonmal von Wireguard gelesen hab und es cool fand.
                                      Was hat das Skript jetzt alles erledigt?
                                      Bzw was muss ich noch machen um mich verbinden zu können?
                                        @crunkfx
                                        CrunkFXC Offline
                                        CrunkFXC Offline
                                        CrunkFX
                                        Forum Testing
                                        schrieb am zuletzt editiert von CrunkFX
                                        @david-g Das Skript installiert im aktuellen Status nur das User Interface. Das ist der erste step. Da das jetzt funktioniert werde ich das Skript erweitern um für die verschiedenen Nativen Plattformen (also kein LXC, dazu gibt's ja ne Anleitung) einen Wireguard Installer als Komplettpaket bereitzustellen.
                                        David G.D dslraserD 2 Antworten Letzte Antwort
                                        • CrunkFXC CrunkFX
                                          David G.D Online
                                          David G.D Online
                                          David G.
                                          @crunkfx
                                          Dann warte ich mal ab.
                                          Dann kann ich den Komfort vom Skript nutzen und zugleich testen ob dann alles klappt.
