  5. [Frage BLOCKLY ] Klingel Bild per Telegram versenden / Snapshot von Cam per Telegram versenden
157 Beiträge 36 Kommentatoren 63.8k Aufrufe 31 Beobachtet
  • GlasfaserG Glasfaser
    @maxpd
    Nimm mal diese Blockly
     <variables>
       <variable type="timeout" id="timeout">timeout</variable>
     </variables>
     <block type="on_ext" id="*Wd9o_3QBbmu7n(.|H9M" x="0" y="0">
       <mutation xmlns="http://www.w3.org/1999/xhtml" items="2"></mutation>
       <value name="OID0">
         <shadow type="field_oid" id="x;IGNi$;5Kn:kB`tq1{$">
         </shadow>
       </value>
       <value name="OID1">
         <shadow type="field_oid" id="@nInN9t]rzjFfqw{DoLD">
         </shadow>
       </value>
       <statement name="STATEMENT">
         <block type="controls_if" id=",E+)WRA_=k%0lckb]:h[">
           <value name="IF0">
             <block type="logic_compare" id="mc*;#$q(in/W,^NYSm0.">
               <field name="OP">EQ</field>
               <value name="A">
                 <block type="on_source" id=")!]cHIs5IHqe:aSL?i;W">
                 </block>
               </value>
               <value name="B">
                 <block type="logic_boolean" id=":W8j?iohfcdV4;W)j-:+">
                 </block>
               </value>
             </block>
           </value>
           <statement name="DO0">
             <block type="debug" id="}8RCQT8,f)4Z_@C)y|jz">
               <value name="TEXT">
                 <shadow type="text" id="-rVRQ4^8Kdn,N2(0%6`;">
                   <field name="TEXT">Auslösung</field>
                 </shadow>
               </value>
               <next>
                 <block type="exec" id="0?HLe|@]G@3[q4L[tx|t">
                   <mutation xmlns="http://www.w3.org/1999/xhtml" with_statement="false"></mutation>
                   <field name="WITH_STATEMENT">FALSE</field>
                   <field name="LOG"></field>
                   <value name="COMMAND">
                     <shadow type="text" id=".#9er8iN6K=urJvj_Uo|">
                       <field name="TEXT">wget --output-document /tmp/DoorBird.jpg "http://user:passwort@192.168.178.54/bha-api/image.cgi"</field>
                     </shadow>
                   </value>
                   <next>
                     <block type="timeouts_settimeout" id="9J*b:4r8O.XG.h{=|~/*">
                       <field name="DELAY">3000</field>
                       <field name="UNIT">ms</field>
                         <block type="telegram" id="RWDx)$R22ue?FT{1ER4x">
                           <value name="MESSAGE">
                             <shadow type="text" id="+!xJbKp]),=E8{`2)2xz">
                               <field name="TEXT">/tmp/DoorBird.jpg</field>
                             </shadow>
                           </value>
                           <next>
                             <block type="debug" id="4%(B5A*-h1xWWsXR)Pca">
                               <value name="TEXT">
                                 <shadow type="text" id="T21O!9-q|87SHR{y+vGm">
                                   <field name="TEXT">Bildversand</field>
                                 </shadow>
                               </value>
                             </block>
                           </next>
                         </block>
                       </statement>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </statement>
     </block>
    </xml>
    M
    M
    maxpd
    #86
    @glasfaser Auch mit diesem Blockly erhalte ich nur den Pfad als Text.
    Aber pass mal auf:
    Ich habe exec jetzt erst aktiviert. Das ist standardmäßig nicht aktiv.
    Jetzt wird mir nicht mehr der Pfad ausgegeben, sondern gar nichts :D
    Habe es nun mit ", aber auch mit ' getestet
    Log dazu sieht so aus
    Habe jetzt noch / und ohne / zwischen Ziel und Originalpfad in der exec getestet, weil dort sich die Vorgaben hier im Topic auch unterschieden haben.
    Das hats gebracht. Ohne / ist korrekt. Ich habe ein Bild :) Merci.
    maxpd
    GlasfaserG S 2 Antworten Letzte Antwort
    • M maxpd
      Aber pass mal auf:
      GlasfaserG
      GlasfaserG
      #87
      @maxpd sagte in [Frage BLOCKLY ] Klingel Bild per Telegram versenden / Snapshot von Cam per Telegram versenden:
      Das hats gebracht. Ohne / ist korrekt. Ich habe ein Bild Merci.
      Dann ist ja gut .... freut mich das du es selber hinbekommen hast ;)
      • M maxpd
        Aber pass mal auf:
        S
        S
        Sub7
        #88
        @maxpd
        Und wie sieht das ganze jetzt fertig aus? Ich stehe im Moment vor dem selben Problem und verstehe nicht ganz was der Fehler war den du zuletzt behoben hast. Bitte genauer erklären.
        • S Sub7
          @maxpd
          M
          M
          maxpd
          #89
          @sub7 I'm Endeffekt genau das letzte blocky von Glasfaser, nur das man im js Adapter exec aktivieren muss.
          maxpd
            Zuerst habe ich per SSH einen Ordner angelegt:
            mkdir /opt/iobroker/ipcam
            Man muss dir URL der Kamera für das Bild heraus finden. Hier findet man einige Angaben https://www.ispyconnect.com/sources.aspx
            Wenn man die URL hat testet man diese im Browser ob dort das Bild aufgerufen wird. In meinen Fall sieht die URL so aus:
            http://benutzer:passwort@192.168.0.55/Streaming/channels/1/picture
            Hat man das Bild geöffnet und es hat funktioniert zurück perr SSH zum iobroker PC und gibt ein:
            wget --output-document /opt/iobroker/ipcam/alarm.jpg 'http://benutzer:passwort@192.168.0.55/Streaming/channels/1/picture'
            Das Bild wird im Ordner gespeichert mit dem Namen alarm.jpg und dieses kann man per Telegram versenden.
            In den Einstellungen der javascript Instanz habe ich bei Erlaube das Kommando "exec" den Hacken gesetzt.
            Ich hoffe ich habe es richtig erklärt und man kann es auch verstehen. Bin nicht so der Profi im skripten..
            Blockly im Spoiler als Beispiel:
             <xml xmlns="http://www.w3.org/1999/xhtml"><block type="on_ext" id="jj8??y8i*v{!Fb0^jZ!*" x="-438" y="-262"><mutation items="1"></mutation>
                <value name="OID0"><shadow type="field_oid" id="XEKh|+XF~3OC@EHY5{8{"><field name="oid">mihome.0.devices.sensor_motion_aq2_158d0001e514d4.state</field></shadow></value>
                <statement name="STATEMENT"><block type="controls_if" id="xXlCTj)t?n*Gg:j44f#Y"><value name="IF0"><block type="logic_compare" id="pMPW|b)g/=L3!yP`vsW6"><field name="OP">EQ</field>
                        <value name="A"><block type="get_value" id="5c7%aB|)K}(rNJ)#Jzd1"><field name="ATTR">val</field>
                            <field name="OID">mihome.0.devices.sensor_motion_aq2_158d0001e514d4.state</field></block></value>
                        <value name="B"><block type="logic_boolean" id="Lhj]yTw*W`/`leEqri.g"><field name="BOOL">TRUE</field></block></value></block></value>
                    <statement name="DO0"><block type="comment" id="eogMqz*f:xk9TWEY/!4#"><field name="COMMENT">Speichert das erste Bild bei Erkennung einer Bewegung</field>
                        <next><block type="exec" id="BEjD=u,#e-;T;d-e9D;r"><mutation with_statement="false"></mutation>
                            <value name="COMMAND"><shadow type="text" id="p+g^=?Sl15wP.0/4C~~B"><field name="TEXT">wget --output-document /opt/iobroker/ipcam/alarm.jpg 'http://benutzer:passwort@192.168.0.55/Streaming/channels/1/picture'</field></shadow></value>
                            <next><block type="comment" id="qm0bnl/,Dq4PjA`4!8ao"><field name="COMMENT">Es wird 2500ms gewartet um dieses speichern auszuführen</field>
                                <next><block type="timeouts_settimeout" id="e=c#~E)j;S+#onaowS77"><field name="NAME">timeout</field>
                                    <field name="DELAY">2500</field>
                                    <statement name="STATEMENT"><block type="comment" id="cLfsL/.hZGyA%n?O!-:5"><field name="COMMENT">Und hier wird es versendet</field>
                                        <next><block type="telegram" id="FbkrL,IGK%]5xBi#Yj,="><field name="INSTANCE">.0</field>
                                            <value name="MESSAGE"><shadow type="text" id="wXLWD;.*8||`3_5J8(UB"><field name="TEXT">/opt/iobroker/ipcam/alarm.jpg</field></shadow></value></block></next></block></statement>
                                    <next><block type="comment" id="Fu=MNqw/7gDC_n{i|=UN"><field name="COMMENT">Nach dem ersten Bild wird nach 4000ms das nächste Bild gespeichert</field>
                                        <next><block type="timeouts_settimeout" id="f55+L@!5F9d*i7)8.z}-"><field name="NAME">timeout2</field>
                                            <field name="DELAY">4000</field>
                                            <statement name="STATEMENT"><block type="exec" id="d~FCu]aLbH_s[eN3oB3H"><mutation with_statement="false"></mutation>
                                                <value name="COMMAND"><shadow type="text" id="q^pJl9(1bxjm4FLFJFlT"><field name="TEXT">wget --output-document /opt/iobroker/ipcam/alarm.jpg 'http://benutzer:passwort@192.168.0.55/Streaming/channels/1/picture'</field></shadow></value>
                                                <next><block type="comment" id="KW^QIsb%Axd:Sp^9@vZ%"><field name="COMMENT">Es wird 2500ms gewartet um dieses speichern auszuführen</field>
                                                    <next><block type="timeouts_settimeout" id="kqLD0XWHPVb*R%96uP;%"><field name="NAME">timeout3</field>
                                                        <statement name="STATEMENT"><block type="comment" id="Vo3{l~+:~RYcTronq]q*"><field name="COMMENT">Und hier wird es versendet</field>
                                                            <next><block type="telegram" id="3p`vo?Dq*N;FLI4BR{`q"><field name="INSTANCE">.0</field>
        <value name="MESSAGE"><shadow type="text" id="GsAgr]aq}s-1MR0mg|-W"><field name="TEXT">/opt/iobroker/ipcam/alarm.jpg</field></shadow></value></block></next></block></statement></block></next></block></next></block></statement>
                                            <next><block type="comment" id="ma^~d4aFY-ahr*7)hhQy"><field name="COMMENT">ab hier so oft wiederholen wie man es möchte</field></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block></statement></block></xml>
            T
            T
            Thomsguy
            #90
            @brainbug Hallo,
            habe gerade dein Blockly getestet. Bekomme aber im Log nen Fehler.
            1. Cannot send photo [chatId - 205338609]: Error: ETELEGRAM: 400 Bad Request: file must be non-empty
            Hast du mir noch n Tipp was ich machen kann
            Das Verzeichniss habe ich erstellt mit ipcam
            DIe Adresse wenn ich sie im Browser eingebe, zeigt mir auch ein Bild der Kamera.
            Viele Grüße
            GlasfaserG crunchipC 2 Antworten Letzte Antwort
            • T Thomsguy
              @brainbug Hallo,
              Viele Grüße
              GlasfaserG
              GlasfaserG
              #91
              @thomsguy
              Lese mal ein paar Beiträge über deinem und nimm mal mein Blockly
                @thomsguy
                T
                T
                Thomsguy
                #92
                @glasfaser Muss ich da dann vorher wieder ein neues Verzeichniss machen?
                • T Thomsguy
                  @brainbug Hallo,
                  Viele Grüße
                  crunchipC
                  crunchipC
                  Developer Global Moderator Most Active Forum Testing
                  #93
                  @thomsguy kenn jetzt das blockly zwar nicht, ETELEGRAM: 400 Bad Request: file must be non-empty , aus dem Stehgreif heraus würde ich sagen, das Bild ist noch nicht da, bevor du versenden möchtest, also timeout erhöhen
                  • T Thomsguy
                    GlasfaserG
                    GlasfaserG
                    #94
                    @thomsguy sagte in [Frage BLOCKLY ] Klingel Bild per Telegram versenden / Snapshot von Cam per Telegram versenden:
                    Nein , einfach ausführen .
                      T
                      T
                      Thomsguy
                      #95
                      @glasfaser OK, danke
                      • S
                        S
                        StefanRS
                        #96
                        ich hab eine Frage zum Exec Befehl.
                        Dieser wird leider nicht ausgeführt. Der Rest funktioniert.
                        Wenn ich den Befehl direkt im IoBrokerTerminal ausführe, wird das Bild im Ordner abgelegt.
                        Aber wenn der Befehl über das Skript läuft, passiert nix.
                        Woran kann das liegen?
                        P.S: Mein IoBroker läuft als Docker.
                        hydrotecH -cs-- 2 Antworten Letzte Antwort
                        • S StefanRS
                          hydrotecH
                          hydrotecH
                          hydrotec
                          #97
                          @stefanrs
                          versuch mal den Befehl.
                          (Anpassung an deine Umgebung erforderlich)
                          wget --quiet --output-document /opt/iobroker/iobroker-data/tmp/dafang01/dafang01.jpg --user <username> --password <password> https://192.168.XXX.XXX/cgi-bin/currentpic.cgi --no-check-certificate
                          Damit hatte ich ursprünglich meine snapshots der WebCam abgeholt, und per telegram versendet.
                          Mit nctalk benötige ich das jetzt nicht mehr ;-)
                          Gruß, Karsten
                          Ubuntu 22.04 LTS (LXD/LXC)
                          admin: v6.3.5
                          js-controller: v4.0.24
                          node: v18.16.1
                          npm: v9.5.1
                          repository: stable
                          • S StefanRS
                            -cs--
                            -cs--
                            -cs-
                            #98
                            @stefanrs sagte in [Frage BLOCKLY ] Klingel Bild per Telegram versenden / Snapshot von Cam per Telegram versenden:
                            Die Rechte der Ordner sind richtig auf iobroker?
                            Hatte zu meinen Anfängen auch das Problem, hatte damals vergessen, dass die Ordnerrechte falsch waren.
                            Von Unterwegs hab ich die Befehle dazu leider nicht im Kopf.
                            • hydrotecH hydrotec
                              @stefanrs
                              Gruß, Karsten
                              S
                              S
                              StefanRS
                              #99
                              @hydrotec Das hat leider nix gebracht. Legt das Bild im Ordner nicht ab.
                              hydrotecH 1 Antwort Letzte Antwort
                              • -cs-- -cs-
                                S
                                S
                                StefanRS
                                #100
                                @csr dumme Frage: Wie kann ich die Rechte überprüfen? Hab direkt auf der NAS die Berechtigungen für den Ordner auf Lesen/Schreiben gesetzt und im IOBroker bin ich als Admin User drin.
                                -cs-- 1 Antwort Letzte Antwort
                                • S StefanRS
                                  hydrotecH
                                  hydrotecH
                                  hydrotec
                                  schrieb am zuletzt editiert von hydrotec
                                  #101
                                  @stefanrs
                                  hast du bei der javascript instance auch das Ausführen von exec erlaubt?
                                  admin: v6.3.5
                                  node: v18.16.1
                                  npm: v9.5.1
                                  repository: stable
                                    @stefanrs
                                    S
                                    S
                                    StefanRS
                                    #102
                                    @hydrotec ja, hab ich vorher schon aktiviert.
                                    Stand Gott sei Dank als Fehlermeldung im Protokoll :-)
                                    • S StefanRS
                                      hydrotecH
                                      hydrotecH
                                      hydrotec
                                      #103
                                      @stefanrs
                                      Dann poste doch bitte einmal deinen Befehl komplett.
                                      (anonymisiert und in codetags)
                                      bzw.
                                      Erstell mal ein neues blockly, und da legst du nur den exec Befehl rein.
                                      Einmal starten, und nachsehen ob das Bild gespeichert wird.
                                      admin: v6.3.5
                                      node: v18.16.1
                                      npm: v9.5.1
                                      repository: stable
                                      • S StefanRS
                                        -cs--
                                        -cs--
                                        -cs-
                                        schrieb am zuletzt editiert von -cs-
                                        #104
                                        @stefanrs
                                        Kann erst morgen nachschlagen, bin immer noch unterwegs.
                                        • S
                                          S
                                          StefanRS
                                          #105
                                          Es liegt wohl an den Rechten. Ich hab den Ordner zum Testen unter vis.0 angelegt, das Skript gestartet und jetzt funktioniert es.
                                          Muss ich mich mal schlaumachen, wie ich Rechte für Ordner in iobroker vergebe.
                                          Thema hat sich somit erledigt
                                          Danke für eure Hilfe :-)
                                          33.2k
                                          84.3k
