  4. Test Adapter mihome-vacuum v2.0.x
    apollon77A
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 746.4k Aufrufe 118 Beobachtet
  • B bjoegibbard
    danke, habe alles ausgeführt. Aber leider keine Besserung.
    Thomas BraunT
    Thomas BraunT
    #1353
    @bjoegibbard
    which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
    cd /opt/iobroker
    npm cache clean --force
    npm install authenticate-pam
      @bjoegibbard
      cd /opt/iobroker
      B
      B
      bjoegibbard
      schrieb am zuletzt editiert von bjoegibbard
      #1354
      /usr/bin/nodejs
      v12.20.1
      /usr/bin/node
      v12.20.1
      /usr/bin/npm
      6.14.10
      nodejs:
        Installiert:           12.20.1-1nodesource1
        Installationskandidat: 12.20.1-1nodesource1
        Versionstabelle:
       *** 12.20.1-1nodesource1 500
              500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
           10.23.1~dfsg-1~deb10u1 500
      /opt/iobroker $ npm cache clean --force
      npm WARN using --force I sure hope you know what you are doing.
      > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
      > node-gyp rebuild
      make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
        CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
      In file included from ../authenticate_pam.cc:23:
      ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
      ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
           , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
      ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
      ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
       keCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
      ../../nan/nan.h:1026:46: note: declared here
         NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
      ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
      ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       al<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
      In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8-internal.h:14,
                       from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:27,
                       from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
                       from ../../nan/nan.h:56,
      /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:3553:51: note: declared here
         V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
      /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
         declarator __attribute__((deprecated(message)))
      ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
          serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
      In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
      /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
         int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
      /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
      ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
      ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
          remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
      ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        username->WriteUtf8(m->username, sizeof(m->username) - 1);
      ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        password->WriteUtf8(m->password, sizeof(m->password) - 1);
      ../authenticate_pam.cc: At global scope:
      ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
       void init(Handle<Object> exports) {
      ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
      ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
                 rand_r
      ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
      ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
      In file included from ../../nan/nan.h:56,
      ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
       NODE_MODULE(authenticate_pam, init);
      /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:36: note: in definition of macro ‘NODE_MODULE_X’
             (node::addon_register_func) (regfunc),                          \
      ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
      ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
      make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
      make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
      gyp ERR! build error
      gyp ERR! stack Error: `make` failed with exit code: 2
      gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
      gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
      gyp ERR! System Linux 5.4.83-v7l+
      gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
      gyp ERR! node -v v12.20.1
      gyp ERR! node-gyp -v v5.1.0
      gyp ERR! not ok
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/chokidar/node_modules/fsevents):
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! authenticate-pam@1.0.2 install: `node-gyp rebuild`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the authenticate-pam@1.0.2 install script.
      npm ERR!     /home/iobroker/.npm/_logs/2021-01-24T16_44_12_411Z-debug.log
      pi@raspberrypi4-iob:/opt/iobroker $
      da ist wieder dieser doofe gyp ERR! -.-
      • B bjoegibbard
        /usr/bin/nodejs
        v12.20.1
        /usr/bin/node
        v12.20.1
        /usr/bin/npm
        6.14.10
        nodejs:
          Versionstabelle:
        > node-gyp rebuild
                   rand_r
        gyp ERR! not ok
        npm ERR! errno 1
        npm ERR!
        Thomas BraunT
        Thomas BraunT
        #1355
        @bjoegibbard
        authenticate_pam
        Keine Ahnung. Vielleicht baut das Modul nicht mehr gegen aktuelle node-Versionen. Das ist ja schon über ein Jahr nicht mehr angefasst worden.
        Welcher Adapter braucht das Ding eigentlich?
        npm list authenticate-pam
        Dürfte der terminal-Adapter sein. Braucht eh keiner.
        iobroker del terminal
        cd /opt/iobroker
        Danach sollte Ruhe von der Seite sein.
        N 1 Antwort Letzte Antwort
          @bjoegibbard
          authenticate_pam
          cd /opt/iobroker
          N
          N
          nu_81
          schrieb am zuletzt editiert von nu_81
          #1356
          Hatte lange Zeit ein ioBroker (mit altem Stand ohne Updates einzuspielen) auf einem Igel laufen
          mit dem ich meinen S50 per Szene gesteuert habe.
          Konkret hatte ich eine Szene "MAP_EG_Laden" erstellt.
          Hierin wurde per SSH auf dem Roborock die Map Dateien getauscht und anschließend kurz gestartet und pausiert um die Karten auch wirklich zu laden.
          Diese Szene habe ich dann vor jede andere Szene gepackt um dann die einzelnen Zonen anzufahren:
          Das hat auch immer zuverlässig funktioniert.
          Habe nun auf einen Raspberry mit aktueller Version gewechselt und da klappt es leider nicht mehr.
          Immer wieder erscheint die Meldung
          "should trigger cleaning all , but is currently active(5). Add to queue"
          Der S50 reagiert dann auch überhaupt nicht, wenn ich z.B. Start auf true setze.
          Muss ich z.B. den Pause Befehl manuell wieder auf false setzten um z.B. die Zonenreinigung zu starten?
          Manchmal funktioniert es wieder wenn ich vor den Befehlen den "Home" Befehl mit rein nehme.
          Es scheint eine neue Funktion der Queue zu geben, die ich hier scheinbar falsch bediene.
          Das hier funktioniert z.B. manchmal:
          Hier noch der obere Teil im aufgeklappten Zustand:
          Aber auch hier kommt manchmal die Meldung mit der Queue.
          Habe auch schon mal versucht "clearQueue" auf true zwischendurch einzusetzen. Aber auch das hilft nicht.
          Leider verstehe ich da das Konzept der Queue auch nicht so recht.
          Kann man die Queue Funktion irgendwie abschalten?
          Wie kann ich die Queue eventuell löschen um den S50 zu "befreien" sodass er wieder Befehle annimmt?
          Wie sollte ich hier am besten vorgehen um es wieder wie vorher zum laufen zu bekommen?
          Gruß Nu
          • N nu_81
            Gruß Nu
            D
            D
            dirkhe
            #1357
            @nu_81 die queue ist dafür da, dass du einfach mehrere Räume starten kannst unser die dann nacheinander abarbeitet.
            Wenn er nicht startet hat er eher verbindindungsprobleme. Sobald er wieder verbunden ist, sollte er starten.
            • D dirkhe
              N
              N
              nu_81
              #1358
              Glaube nicht dass es Verbindungsprobleme sind.
              Er reagiert z.B. überhaupt nicht auf start, gibt stattdessen die Meldung ins Log.
              Auf z.B. auf Home oder "Wo bist du" reagiert er sofort.
              • N nu_81
                D
                D
                dirkhe
                #1359
                @nu_81 dann stell den adapter mal auf debug und poste das Log hier.
                • D dirkhe
                  S
                  S
                  Sweatchuck
                  #1360
                  kurze Frage...
                  Meine beiden Robrock (S5 und S6) wollen ein Firmware-Update durchführen.
                  Von Version 3.5.8_2076 auf 3.5.8_2652 beim S6 bzw. 3.5.7_002008 auf 3.5.8_002034.
                  Da momentan aber alles super funktioniert will ich nicht einfach ein Update fahren und deshalb mal nachfragen ob jemand von euch Erfahrungen dies bzgl. hat. Angeblich handelt es sich dabei nur ein Bugfix?!
                  Beste Grüße
                  • JackDanielJ
                    JackDanielJ
                    JackDaniel
                    #1361
                    keine probleme hier
                    Carpe diem
                    • S Sweatchuck
                      kurze Frage...
                      Beste Grüße
                      #1362
                      @sweatchuck
                      nee, meine 4 auch, mach doch mal, dann wissen wir ja, obs dann noch geht.. :-)
                      • JackDanielJ JackDaniel
                        keine probleme hier
                        #1363
                        @jackdaniel mit Adapter Version ..??
                        • JackDanielJ
                          JackDanielJ
                          JackDaniel
                          #1364
                          bei mir läuft die 2.2.4
                          Carpe diem
                          • S
                            S
                            Snapergy
                            schrieb am zuletzt editiert von Snapergy
                            #1365
                            Puh, bin gerade echt am verzweifeln. Ich habe nichts weiter gemacht (zumindest nicht, dass ich wüsste), aber die Map lädt nicht mehr und es kommt immer folgender Fehler:
                            answer map_slot is currently not supported!
                            Was kann ich machen?
                            EDIT: Hab die Lösung gefunden. Für alle, die das gleiche Problem haben:
                            https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/119
                            Lag am Update von NodeJS...
                            • S
                              S
                              Schwabe
                              schrieb am zuletzt editiert von Schwabe
                              #1366
                              DANKE erstmal für diesen tollen Adapter und die kontinuierliche Arbeit daran.
                              Wegen einem bevorstehenden Wechsel von einem ASUS TinkerBoard S auf ein Windows10 Ubunto-System habe ich aktuell 2 Versionen von dem Adapter laufen.
                              Auf dem TinkerBoard S habe ich die Version 1.1.5 installiert und kann nicht auf die Version 2.1.1 updaten. Das Update wird stets mit einem Fehler beendet und der Adpater ist dann auch aus der VIS verschwunden. Ansonsten läuft diese Version zu meiner vollen Zufriedenheit.
                              Mein Hauptproblem ist jedoch das der Adapter auf dem Ubuntu in der Version 2.1.1 bei "Gelb" bleibt. Ich kann zwar den Server (Germany) abfragen und den S6 übernehmen, doch der Adapter bleibt "Gelb".
                              Die Konfigurationen sind gleich, wie auf den Screenshots zu sehen.
                              Ich freue mich über jede Hilfe.
                              Der LOG von dem Ubuntu-System ist folgender:
                              2021-02-18 14:02:03.591 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                              2021-02-18 14:02:03.593 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                              2021-02-18 14:02:03.594 - info: mihome-vacuum.0 (915) Got terminate signal TERMINATE_YOURSELF
                              2021-02-18 14:02:03.595 - info: mihome-vacuum.0 (915) terminating
                              2021-02-18 14:02:03.595 - info: mihome-vacuum.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2021-02-18 14:02:04.111 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2021-02-18 14:02:06.615 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 1020
                              2021-02-18 14:02:07.105 - info: mihome-vacuum.0 (1020) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                              2021-02-18 14:02:07.146 - info: mihome-vacuum.0 (1020) Expert mode enabled, states created
                              2021-02-18 14:02:07.146 - info: mihome-vacuum.0 (1020) Create state clean_home for controlling by cloud adapter
                              2021-02-18 14:02:07.671 - info: mihome-vacuum.0 (1020) set nächster Timer: Nicht verfügbar
                              2021-02-18 14:02:08.330 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:03:09.810 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:04:11.431 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:05:00.020 - info: host.Server instance system.adapter.dwd.0 started with pid 1035
                              2021-02-18 14:05:00.580 - info: dwd.0 (1035) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                              2021-02-18 14:05:00.940 - info: dwd.0 (1035) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2021-02-18 14:05:01.450 - info: host.Server instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2021-02-18 14:05:13.192 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:06:14.647 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:07:16.150 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:08:01.090 - info: hm-rpc.0 (536) xmlrpc <- listDevices ["hm-rpc.0"]
                              2021-02-18 14:08:01.117 - info: hm-rpc.0 (536) xmlrpc -> 0 devices
                              2021-02-18 14:08:01.223 - info: hm-rpc.0 (536) xmlrpc <- newDevices 170
                              2021-02-18 14:08:01.246 - info: hm-rpc.0 (536) new HMIP devices/channels after filter: 0
                              2021-02-18 14:08:17.620 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:09:19.121 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:10:00.023 - info: host.Server instance system.adapter.dwd.0 started with pid 1050
                              2021-02-18 14:10:00.597 - info: dwd.0 (1050) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                              2021-02-18 14:10:00.983 - info: dwd.0 (1050) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2021-02-18 14:10:01.493 - info: host.Server instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2021-02-18 14:10:20.475 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:11:22.013 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                              2021-02-18 14:11:55.186 - info: host.Server "system.adapter.mihome-vacuum.0" disabled
                              2021-02-18 14:11:55.188 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                              2021-02-18 14:11:55.188 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                              2021-02-18 14:11:55.190 - info: mihome-vacuum.0 (1020) Got terminate signal TERMINATE_YOURSELF
                              2021-02-18 14:11:55.191 - info: mihome-vacuum.0 (1020) terminating
                              2021-02-18 14:11:55.191 - info: mihome-vacuum.0 (1020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                              2021-02-18 14:11:55.707 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                              2021-02-18 14:11:57.923 - info: host.Server "system.adapter.mihome-vacuum.0" enabled
                              2021-02-18 14:11:57.941 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 1065
                              2021-02-18 14:11:58.436 - info: mihome-vacuum.0 (1065) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                              2021-02-18 14:11:58.478 - info: mihome-vacuum.0 (1065) Expert mode enabled, states created
                              2021-02-18 14:11:58.478 - info: mihome-vacuum.0 (1065) Create state clean_home for controlling by cloud adapter
                              2021-02-18 14:11:59.004 - info: mihome-vacuum.0 (1065) set nächster Timer: Nicht verfügbar
                              2021-02-18 14:12:00.045 - info: host.Server instance system.adapter.weatherunderground.1 started with pid 1080
                              2021-02-18 14:12:00.519 - info: weatherunderground.1 (1080) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.20.2, js-controller: 3.1.6
                              2021-02-18 14:12:03.888 - info: weatherunderground.1 (1080) Terminated (NO_ERROR): Without reason
                              2021-02-18 14:12:04.068 - info: host.Server instance system.adapter.weatherunderground.0 started with pid 1095
                              2021-02-18 14:12:04.393 - info: host.Server instance system.adapter.weatherunderground.1 terminated with code 0 (NO_ERROR)
                              2021-02-18 14:12:04.544 - info: weatherunderground.0 (1095) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.20.2, js-controller: 3.1.6
                              2021-02-18 14:12:08.195 - info: weatherunderground.0 (1095) Terminated (NO_ERROR): Without reason
                              2021-02-18 14:12:08.705 - info: host.Server instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                              • S Schwabe
                                haselchenH
                                haselchenH
                                haselchen
                                #1367
                                @schwabe
                                Ich kann nur raten, aber im rechten Screenshot steht für V1 und S5 und Du hast einen S6.....
                                • haselchenH haselchen
                                  @schwabe
                                  S
                                  S
                                  Schwabe
                                  #1368
                                  @haselchen das mit dem S6 ist mir klar, doch der Adapter läuft ja, lässt sich nur nicht updaten.
                                  Wichtiger wäre mir jedoch den Ubuntu ans laufen zu bekommen, der andere wird eh irgendwann abgeschaltet.
                                  • S Schwabe
                                    haselchenH
                                    haselchenH
                                    haselchen
                                    #1369
                                    @schwabe
                                    Pragmatische Lösung , wenn es geht, die 1.1.5 auf Ubuntu installieren?
                                    Das war die letzte Version, mit der dein Sauger funktionierte?
                                    Edit:
                                    Laufen beide Adapter gleichzeitig? (Tinker und Ubuntu?)
                                    Oder hast du mal das WIFI resettet, dass der Token nicht mehr stimmt?
                                      @schwabe
                                      Edit:
                                      S
                                      S
                                      Schwabe
                                      #1370
                                      @haselchen danke für den Tipp, ich musste zwar erstmal auf den 2.0.7 zurück um überhaupt den 1.1.5 angezeigt zu bekommen, doch hat es endgültig geklappt. Leider ist das Problem damit nicht gelöst, der Adapter bleibt "gelb"
                                      Ja aktuell laufen beide ioBroker und somit auch beide Adapter gleichzeitig. Doch auch die vorübergehende Deaktiverung des ThinkerBoardS Adapters bringt beim Ubuntu keine Besserung. Der Token muss noch stimmen, sonst könnte der ThinkerBoardS Adapter nicht funktionieren und ich würde über die Server Suche einen den Neuen finden, oder?
                                      Hier dazu mein letzter Log:
                                      2021-02-18 19:23:00.831 - info: mihome-vacuum.0 (3441) Got terminate signal TERMINATE_YOURSELF
                                      2021-02-18 19:23:00.831 - info: mihome-vacuum.0 (3441) terminating
                                      2021-02-18 19:23:00.832 - info: mihome-vacuum.0 (3441) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2021-02-18 19:23:01.347 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2021-02-18 19:23:03.854 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3456
                                      2021-02-18 19:23:04.287 - warn: mihome-vacuum.0 (3456) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                      2021-02-18 19:23:04.288 - warn: mihome-vacuum.0 (3456) This object will not be created in future versions. Please report this to the developer.
                                      2021-02-18 19:23:04.351 - info: mihome-vacuum.0 (3456) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                      2021-02-18 19:23:04.370 - info: mihome-vacuum.0 (3456) Expert mode disabled, states deleted
                                      2021-02-18 19:23:04.371 - info: mihome-vacuum.0 (3456) Cloud control disabled
                                      2021-02-18 19:23:04.375 - info: mihome-vacuum.0 (3456) Disconnect
                                      2021-02-18 19:23:04.900 - info: mihome-vacuum.0 (3456) set nächster Timer: Nicht verfügbar
                                      2021-02-18 19:23:20.469 - info: host.Server iobroker upgrade mihome-vacuum@1.1.5
                                      2021-02-18 19:23:21.486 - info: host.Server iobroker Update mihome-vacuum from @2.0.7 to @1.1.5
                                      2021-02-18 19:23:21.674 - info: host.Server iobroker NPM version: 6.14.11
                                      2021-02-18 19:23:21.675 - info: host.Server iobroker npm install iobroker.mihome-vacuum@1.1.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                      2021-02-18 19:23:23.918 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                      2021-02-18 19:23:24.376 - info: mihome-vacuum.0 (3456) Disconnect
                                      2021-02-18 19:23:25.458 - info: host.Server iobroker upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                      2021-02-18 19:23:25.491 - info: host.Server iobroker Update "system.adapter.mihome-vacuum.0"
                                      2021-02-18 19:23:25.497 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                      2021-02-18 19:23:25.499 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                      2021-02-18 19:23:25.499 - info: mihome-vacuum.0 (3456) Got terminate signal TERMINATE_YOURSELF
                                      2021-02-18 19:23:25.500 - info: mihome-vacuum.0 (3456) terminating
                                      2021-02-18 19:23:25.500 - info: mihome-vacuum.0 (3456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2021-02-18 19:23:25.551 - info: host.Server iobroker upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                      2021-02-18 19:23:25.605 - info: host.Server iobroker upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                      2021-02-18 19:23:25.667 - info: host.Server iobroker upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                      2021-02-18 19:23:25.730 - info: host.Server iobroker upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                      2021-02-18 19:23:25.783 - info: host.Server iobroker Adapter "mihome-vacuum" updated
                                      2021-02-18 19:23:26.009 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2021-02-18 19:23:26.793 - info: host.Server iobroker exit 0
                                      2021-02-18 19:23:28.517 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3502
                                      2021-02-18 19:23:28.836 - warn: mihome-vacuum.0 (3502) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                      2021-02-18 19:23:28.836 - warn: mihome-vacuum.0 (3502) This object will not be created in future versions. Please report this to the developer.
                                      2021-02-18 19:23:28.908 - info: mihome-vacuum.0 (3502) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                      2021-02-18 19:23:28.925 - info: mihome-vacuum.0 (3502) Expert mode disabled, states deleded
                                      2021-02-18 19:23:28.925 - info: mihome-vacuum.0 (3502) Cloud control disabled
                                      2021-02-18 19:23:36.444 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                      2021-02-18 19:23:36.445 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                      2021-02-18 19:23:36.447 - info: mihome-vacuum.0 (3502) Got terminate signal TERMINATE_YOURSELF
                                      2021-02-18 19:23:36.448 - info: mihome-vacuum.0 (3502) terminating
                                      2021-02-18 19:23:36.449 - info: mihome-vacuum.0 (3502) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2021-02-18 19:23:36.960 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2021-02-18 19:23:39.469 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3517
                                      2021-02-18 19:23:39.775 - warn: mihome-vacuum.0 (3517) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                      2021-02-18 19:23:39.776 - warn: mihome-vacuum.0 (3517) This object will not be created in future versions. Please report this to the developer.
                                      2021-02-18 19:23:39.845 - info: mihome-vacuum.0 (3517) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                      2021-02-18 19:23:39.863 - info: mihome-vacuum.0 (3517) Expert mode disabled, states deleded
                                      2021-02-18 19:23:39.863 - info: mihome-vacuum.0 (3517) Cloud control disabled
                                      2021-02-18 19:23:44.595 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                      2021-02-18 19:23:44.595 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                      2021-02-18 19:23:44.596 - info: mihome-vacuum.0 (3517) Got terminate signal TERMINATE_YOURSELF
                                      2021-02-18 19:23:44.597 - info: mihome-vacuum.0 (3517) terminating
                                      2021-02-18 19:23:44.597 - info: mihome-vacuum.0 (3517) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2021-02-18 19:23:45.109 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2021-02-18 19:23:47.618 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3532
                                      2021-02-18 19:23:47.922 - warn: mihome-vacuum.0 (3532) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                      2021-02-18 19:23:47.922 - warn: mihome-vacuum.0 (3532) This object will not be created in future versions. Please report this to the developer.
                                      2021-02-18 19:23:47.982 - info: mihome-vacuum.0 (3532) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                      2021-02-18 19:23:47.999 - info: mihome-vacuum.0 (3532) Expert mode enabled, states created
                                      2021-02-18 19:23:48.000 - info: mihome-vacuum.0 (3532) Cloud control disabled
                                      2021-02-18 19:23:52.233 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                      2021-02-18 19:23:52.234 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                      2021-02-18 19:23:52.235 - info: mihome-vacuum.0 (3532) Got terminate signal TERMINATE_YOURSELF
                                      2021-02-18 19:23:52.235 - info: mihome-vacuum.0 (3532) terminating
                                      2021-02-18 19:23:52.236 - info: mihome-vacuum.0 (3532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      2021-02-18 19:23:52.747 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      2021-02-18 19:23:55.258 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3547
                                      2021-02-18 19:23:55.563 - warn: mihome-vacuum.0 (3547) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                      2021-02-18 19:23:55.563 - warn: mihome-vacuum.0 (3547) This object will not be created in future versions. Please report this to the developer.
                                      2021-02-18 19:23:55.626 - info: mihome-vacuum.0 (3547) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                      2021-02-18 19:23:55.644 - info: mihome-vacuum.0 (3547) Expert mode enabled, states created
                                      2021-02-18 19:23:55.644 - info: mihome-vacuum.0 (3547) Cloud control disabled
                                      • S Schwabe
                                        D
                                        D
                                        dirkhe
                                        #1371
                                        @schwabe installiere den aktuellen Adapter, Stelle den Adapter mal auf debug und poste das hier. Denk dran, das es manchmal dauern kann, bis er sich connected. Oft hilft es auch, wenn man gleichzeitig in die mihome App geht
                                        • D dirkhe
                                          S
                                          S
                                          Schwabe
                                          #1372
                                          @dirkhe Danke für die Hilfe.
                                          Ich habe den Adapter aktualisiert und auf Debug gestellt. Dann habe ich ein paar Einstellungen vorgenommen und den Adapter einmal neu gestartet. Zudem ist seit über 12 Stunden der Adapter auf dem TinkerBoardS deaktiviert. Der Adpater bleibt weiterhin "Gelb".
                                          Hier der LOG:
                                          mihome-vacuum.0	2021-02-19 08:05:06.261	debug	(8721) Xiaomi Cloud: Login successful
                                          mihome-vacuum.0	2021-02-19 08:05:04.771	info	(8721) set nächster Timer: Nicht verfügbar
                                          mihome-vacuum.0	2021-02-19 08:05:04.264	debug	(8721) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                          mihome-vacuum.0	2021-02-19 08:05:04.253	debug	(8721) server started on 0.0.0.0:53421
                                          mihome-vacuum.0	2021-02-19 08:05:04.250	info	(8721) Create state clean_home for controlling by cloud adapter
                                          mihome-vacuum.0	2021-02-19 08:05:04.250	info	(8721) Expert mode enabled, states created
                                          mihome-vacuum.0	2021-02-19 08:05:04.247	debug	(8721) Xiaomi Cloud: Logging in
                                          mihome-vacuum.0	2021-02-19 08:05:04.247	debug	(8721) load Map creator... true
                                          mihome-vacuum.0	2021-02-19 08:05:04.209	info	(8721) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                          mihome-vacuum.0	2021-02-19 08:05:04.107	debug	(8721) statesDB connected
                                          mihome-vacuum.0	2021-02-19 08:05:04.107	debug	(8721) States connected to redis: 127.0.0.1:9000
                                          mihome-vacuum.0	2021-02-19 08:05:04.102	debug	(8721) States create System PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:05:04.102	debug	(8721) States create User PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:05:04.099	debug	(8721) Redis States: Use Redis connection: 127.0.0.1:9000
                                          mihome-vacuum.0	2021-02-19 08:05:04.098	debug	(8721) objectDB connected
                                          mihome-vacuum.0	2021-02-19 08:05:04.097	debug	(8721) Objects connected to redis: 127.0.0.1:9001
                                          mihome-vacuum.0	2021-02-19 08:05:04.088	debug	(8721) Objects client initialize lua scripts
                                          mihome-vacuum.0	2021-02-19 08:05:04.088	debug	(8721) Objects create User PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:05:04.088	debug	(8721) Objects create System PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:05:04.087	debug	(8721) Objects client ready ... initialize now
                                          mihome-vacuum.0	2021-02-19 08:05:04.077	debug	(8721) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.Server	2021-02-19 08:05:03.708	info	instance system.adapter.mihome-vacuum.0 started with pid 8721
                                          host.Server	2021-02-19 08:05:01.434	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          host.Server	2021-02-19 08:05:01.201	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          dwd.0	2021-02-19 08:05:00.926	info	(8706) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          mihome-vacuum.0	2021-02-19 08:05:00.688	info	(8691) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          mihome-vacuum.0	2021-02-19 08:05:00.688	info	(8691) terminating
                                          mihome-vacuum.0	2021-02-19 08:05:00.687	info	(8691) Got terminate signal TERMINATE_YOURSELF
                                          host.Server	2021-02-19 08:05:00.686	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                          host.Server	2021-02-19 08:05:00.686	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                          dwd.0	2021-02-19 08:05:00.613	info	(8706) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                                          host.Server	2021-02-19 08:05:00.033	info	instance system.adapter.dwd.0 started with pid 8706
                                          mihome-vacuum.0	2021-02-19 08:04:56.597	debug	(8691) Xiaomi Cloud: Login successful
                                          mihome-vacuum.0	2021-02-19 08:04:55.360	info	(8691) set nächster Timer: Nicht verfügbar
                                          mihome-vacuum.0	2021-02-19 08:04:54.857	debug	(8691) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                          mihome-vacuum.0	2021-02-19 08:04:54.846	debug	(8691) server started on 0.0.0.0:53421
                                          mihome-vacuum.0	2021-02-19 08:04:54.843	info	(8691) Create state clean_home for controlling by cloud adapter
                                          mihome-vacuum.0	2021-02-19 08:04:54.842	info	(8691) Expert mode enabled, states created
                                          mihome-vacuum.0	2021-02-19 08:04:54.840	debug	(8691) Xiaomi Cloud: Logging in
                                          mihome-vacuum.0	2021-02-19 08:04:54.840	debug	(8691) load Map creator... true
                                          mihome-vacuum.0	2021-02-19 08:04:54.799	info	(8691) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                          mihome-vacuum.0	2021-02-19 08:04:54.700	debug	(8691) statesDB connected
                                          mihome-vacuum.0	2021-02-19 08:04:54.700	debug	(8691) States connected to redis: 127.0.0.1:9000
                                          mihome-vacuum.0	2021-02-19 08:04:54.694	debug	(8691) States create System PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:04:54.693	debug	(8691) States create User PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:04:54.691	debug	(8691) Redis States: Use Redis connection: 127.0.0.1:9000
                                          mihome-vacuum.0	2021-02-19 08:04:54.690	debug	(8691) objectDB connected
                                          mihome-vacuum.0	2021-02-19 08:04:54.689	debug	(8691) Objects connected to redis: 127.0.0.1:9001
                                          mihome-vacuum.0	2021-02-19 08:04:54.681	debug	(8691) Objects client initialize lua scripts
                                          mihome-vacuum.0	2021-02-19 08:04:54.681	debug	(8691) Objects create User PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:04:54.681	debug	(8691) Objects create System PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:04:54.680	debug	(8691) Objects client ready ... initialize now
                                          mihome-vacuum.0	2021-02-19 08:04:54.670	debug	(8691) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.Server	2021-02-19 08:04:54.303	info	instance system.adapter.mihome-vacuum.0 started with pid 8691
                                          host.Server	2021-02-19 08:04:51.842	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          mihome-vacuum.0	2021-02-19 08:04:51.284	info	(8676) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          mihome-vacuum.0	2021-02-19 08:04:51.283	info	(8676) terminating
                                          mihome-vacuum.0	2021-02-19 08:04:51.283	info	(8676) Got terminate signal TERMINATE_YOURSELF
                                          host.Server	2021-02-19 08:04:51.280	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                          host.Server	2021-02-19 08:04:51.279	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                          mihome-vacuum.0	2021-02-19 08:04:42.923	debug	(8676) Xiaomi Cloud: Login successful
                                          mihome-vacuum.0	2021-02-19 08:04:40.900	info	(8676) set nächster Timer: Nicht verfügbar
                                          mihome-vacuum.0	2021-02-19 08:04:40.394	debug	(8676) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                          mihome-vacuum.0	2021-02-19 08:04:40.383	debug	(8676) server started on 0.0.0.0:53421
                                          mihome-vacuum.0	2021-02-19 08:04:40.380	info	(8676) Create state clean_home for controlling by cloud adapter
                                          mihome-vacuum.0	2021-02-19 08:04:40.380	info	(8676) Expert mode enabled, states created
                                          mihome-vacuum.0	2021-02-19 08:04:40.377	debug	(8676) Xiaomi Cloud: Logging in
                                          mihome-vacuum.0	2021-02-19 08:04:40.377	debug	(8676) load Map creator... true
                                          mihome-vacuum.0	2021-02-19 08:04:40.280	info	(8676) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                          mihome-vacuum.0	2021-02-19 08:04:40.188	debug	(8676) statesDB connected
                                          mihome-vacuum.0	2021-02-19 08:04:40.188	debug	(8676) States connected to redis: 127.0.0.1:9000
                                          mihome-vacuum.0	2021-02-19 08:04:40.183	debug	(8676) States create System PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:04:40.182	debug	(8676) States create User PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:04:40.179	debug	(8676) Redis States: Use Redis connection: 127.0.0.1:9000
                                          mihome-vacuum.0	2021-02-19 08:04:40.179	debug	(8676) objectDB connected
                                          mihome-vacuum.0	2021-02-19 08:04:40.178	debug	(8676) Objects connected to redis: 127.0.0.1:9001
                                          mihome-vacuum.0	2021-02-19 08:04:40.170	debug	(8676) Objects client initialize lua scripts
                                          mihome-vacuum.0	2021-02-19 08:04:40.170	debug	(8676) Objects create User PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:04:40.169	debug	(8676) Objects create System PubSub Client
                                          mihome-vacuum.0	2021-02-19 08:04:40.167	debug	(8676) Objects client ready ... initialize now
                                          mihome-vacuum.0	2021-02-19 08:04:40.157	debug	(8676) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          host.Server	2021-02-19 08:04:39.786	info	instance system.adapter.mihome-vacuum.0 started with pid 8676
                                          host.Server	2021-02-19 08:04:37.278	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                          mihome-vacuum.0	2021-02-19 08:04:36.764	info	(6066) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                          mihome-vacuum.0	2021-02-19 08:04:36.764	info	(6066) terminating
                                          mihome-vacuum.0	2021-02-19 08:04:36.763	info	(6066) Got terminate signal TERMINATE_YOURSELF
                                          host.Server	2021-02-19 08:04:36.761	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                          host.Server	2021-02-19 08:04:36.760	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                          tr-064.0	2021-02-19 08:04:34.434	info	(726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpec
                                          mihome-vacuum.0	2021-02-19 08:04:08.726	debug	(6066) sendTo "discovery" to system.adapter.admin.0 from system.adapter.mihome-vacuum.0
                                          mihome-vacuum.0	2021-02-19 08:04:08.726	debug	(6066) discover__[{"did":"259591246","token":"3657354e664a5a4b4b74306d524c6f52","longitude":"0.00000000","latitude":"0.00000000","name":"Eltern","pid":"0","localip":"192.168.1.135","mac":"04:CF:8C:F8
                                          mihome-vacuum.0	2021-02-19 08:04:08.724	debug	(6066) {"code":0,"message":"ok","result":{"list":[{"did":"259591246","token":"3657354e664a5a4b4b74306d524c6f52","longitude":"0.00000000","latitude":"0.00000000","name":"Eltern","pid":"0","localip":"1
                                          mihome-vacuum.0	2021-02-19 08:04:08.564	debug	(6066) GET devices from:https://de.api.io.mi.com/app/home/device_list
                                          mihome-vacuum.0	2021-02-19 08:04:08.546	debug	(6066) Xiaomi Cloud: Login successful
                                          mihome-vacuum.0	2021-02-19 08:04:06.695	debug	(6066) Xiaomi Cloud: Logging in
                                          mihome-vacuum.0	2021-02-19 08:03:51.246	debug	(6066) system.adapter.admin.0: logging true
                                          mihome-vacuum.0	2021-02-19 08:03:47.255	debug	(6066) system.adapter.admin.0: logging false
                                          83.9k
