  4. Test Adapter mihome-vacuum v2.0.x
    apollon77A
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 763.2k Aufrufe 118 Beobachtet
  • B bjoegibbard
    /usr/bin/nodejs
    v12.20.1
    /usr/bin/node
    v12.20.1
    /usr/bin/npm
    6.14.10
    nodejs:
      Installiert:           12.20.1-1nodesource1
      Installationskandidat: 12.20.1-1nodesource1
      Versionstabelle:
     *** 12.20.1-1nodesource1 500
            500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
         10.23.1~dfsg-1~deb10u1 500
    /opt/iobroker $ npm cache clean --force
    npm WARN using --force I sure hope you know what you are doing.
    npm install authenticate-pam
    > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
    > node-gyp rebuild
    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
      CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
    In file included from ../authenticate_pam.cc:23:
    ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
    ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
         , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
    ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
    ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
     keCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
    ../../nan/nan.h:1026:46: note: declared here
       NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
    ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
     al<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
    In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8-internal.h:14,
                     from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:27,
                     from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
                     from ../../nan/nan.h:56,
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:3553:51: note: declared here
       V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
    In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
       int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
    ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
    ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
        remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
    ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
      username->WriteUtf8(m->username, sizeof(m->username) - 1);
    ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
      password->WriteUtf8(m->password, sizeof(m->password) - 1);
    ../authenticate_pam.cc: At global scope:
    ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
     void init(Handle<Object> exports) {
    ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
    ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
               rand_r
    ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
    ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
    In file included from ../../nan/nan.h:56,
    ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
     NODE_MODULE(authenticate_pam, init);
    /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:36: note: in definition of macro ‘NODE_MODULE_X’
           (node::addon_register_func) (regfunc),                          \
    ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
    ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
    make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
    gyp ERR! System Linux 5.4.83-v7l+
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v12.20.1
    gyp ERR! node-gyp -v v5.1.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/chokidar/node_modules/fsevents):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! authenticate-pam@1.0.2 install: `node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the authenticate-pam@1.0.2 install script.
    npm ERR!     /home/iobroker/.npm/_logs/2021-01-24T16_44_12_411Z-debug.log
    pi@raspberrypi4-iob:/opt/iobroker $
    da ist wieder dieser doofe gyp ERR! -.-
    Thomas BraunT
    Thomas BraunT
    #1355
    @bjoegibbard
    authenticate_pam
    Keine Ahnung. Vielleicht baut das Modul nicht mehr gegen aktuelle node-Versionen. Das ist ja schon über ein Jahr nicht mehr angefasst worden.
    Welcher Adapter braucht das Ding eigentlich?
    npm list authenticate-pam
    Dürfte der terminal-Adapter sein. Braucht eh keiner.
    iobroker del terminal
    cd /opt/iobroker
    Danach sollte Ruhe von der Seite sein.
    N 1 Antwort Letzte Antwort
      @bjoegibbard
      authenticate_pam
      cd /opt/iobroker
      N
      N
      nu_81
      schrieb am zuletzt editiert von nu_81
      #1356
      Hatte lange Zeit ein ioBroker (mit altem Stand ohne Updates einzuspielen) auf einem Igel laufen
      mit dem ich meinen S50 per Szene gesteuert habe.
      Konkret hatte ich eine Szene "MAP_EG_Laden" erstellt.
      Hierin wurde per SSH auf dem Roborock die Map Dateien getauscht und anschließend kurz gestartet und pausiert um die Karten auch wirklich zu laden.
      Diese Szene habe ich dann vor jede andere Szene gepackt um dann die einzelnen Zonen anzufahren:
      Das hat auch immer zuverlässig funktioniert.
      Habe nun auf einen Raspberry mit aktueller Version gewechselt und da klappt es leider nicht mehr.
      Immer wieder erscheint die Meldung
      "should trigger cleaning all , but is currently active(5). Add to queue"
      Der S50 reagiert dann auch überhaupt nicht, wenn ich z.B. Start auf true setze.
      Muss ich z.B. den Pause Befehl manuell wieder auf false setzten um z.B. die Zonenreinigung zu starten?
      Manchmal funktioniert es wieder wenn ich vor den Befehlen den "Home" Befehl mit rein nehme.
      Es scheint eine neue Funktion der Queue zu geben, die ich hier scheinbar falsch bediene.
      Das hier funktioniert z.B. manchmal:
      Hier noch der obere Teil im aufgeklappten Zustand:
      Aber auch hier kommt manchmal die Meldung mit der Queue.
      Habe auch schon mal versucht "clearQueue" auf true zwischendurch einzusetzen. Aber auch das hilft nicht.
      Leider verstehe ich da das Konzept der Queue auch nicht so recht.
      Kann man die Queue Funktion irgendwie abschalten?
      Wie kann ich die Queue eventuell löschen um den S50 zu "befreien" sodass er wieder Befehle annimmt?
      Wie sollte ich hier am besten vorgehen um es wieder wie vorher zum laufen zu bekommen?
      Gruß Nu
      • N nu_81
        Gruß Nu
        D
        D
        dirkhe
        #1357
        @nu_81 die queue ist dafür da, dass du einfach mehrere Räume starten kannst unser die dann nacheinander abarbeitet.
        Wenn er nicht startet hat er eher verbindindungsprobleme. Sobald er wieder verbunden ist, sollte er starten.
        • D dirkhe
          N
          N
          nu_81
          #1358
          Glaube nicht dass es Verbindungsprobleme sind.
          Er reagiert z.B. überhaupt nicht auf start, gibt stattdessen die Meldung ins Log.
          Auf z.B. auf Home oder "Wo bist du" reagiert er sofort.
          • N nu_81
            D
            D
            dirkhe
            #1359
            @nu_81 dann stell den adapter mal auf debug und poste das Log hier.
            • D dirkhe
              S
              S
              Sweatchuck
              #1360
              kurze Frage...
              Meine beiden Robrock (S5 und S6) wollen ein Firmware-Update durchführen.
              Von Version 3.5.8_2076 auf 3.5.8_2652 beim S6 bzw. 3.5.7_002008 auf 3.5.8_002034.
              Da momentan aber alles super funktioniert will ich nicht einfach ein Update fahren und deshalb mal nachfragen ob jemand von euch Erfahrungen dies bzgl. hat. Angeblich handelt es sich dabei nur ein Bugfix?!
              Beste Grüße
              • JackDanielJ
                JackDanielJ
                JackDaniel
                #1361
                keine probleme hier
                Carpe diem
                • S Sweatchuck
                  kurze Frage...
                  Beste Grüße
                  #1362
                  @sweatchuck
                  nee, meine 4 auch, mach doch mal, dann wissen wir ja, obs dann noch geht.. :-)
                  • JackDanielJ JackDaniel
                    keine probleme hier
                    #1363
                    @jackdaniel mit Adapter Version ..??
                    • JackDanielJ
                      JackDanielJ
                      JackDaniel
                      #1364
                      bei mir läuft die 2.2.4
                      Carpe diem
                      • S
                        S
                        Snapergy
                        schrieb am zuletzt editiert von Snapergy
                        #1365
                        Puh, bin gerade echt am verzweifeln. Ich habe nichts weiter gemacht (zumindest nicht, dass ich wüsste), aber die Map lädt nicht mehr und es kommt immer folgender Fehler:
                        answer map_slot is currently not supported!
                        Was kann ich machen?
                        EDIT: Hab die Lösung gefunden. Für alle, die das gleiche Problem haben:
                        https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/119
                        Lag am Update von NodeJS...
                        • S
                          S
                          Schwabe
                          schrieb am zuletzt editiert von Schwabe
                          #1366
                          DANKE erstmal für diesen tollen Adapter und die kontinuierliche Arbeit daran.
                          Wegen einem bevorstehenden Wechsel von einem ASUS TinkerBoard S auf ein Windows10 Ubunto-System habe ich aktuell 2 Versionen von dem Adapter laufen.
                          Auf dem TinkerBoard S habe ich die Version 1.1.5 installiert und kann nicht auf die Version 2.1.1 updaten. Das Update wird stets mit einem Fehler beendet und der Adpater ist dann auch aus der VIS verschwunden. Ansonsten läuft diese Version zu meiner vollen Zufriedenheit.
                          Mein Hauptproblem ist jedoch das der Adapter auf dem Ubuntu in der Version 2.1.1 bei "Gelb" bleibt. Ich kann zwar den Server (Germany) abfragen und den S6 übernehmen, doch der Adapter bleibt "Gelb".
                          Die Konfigurationen sind gleich, wie auf den Screenshots zu sehen.
                          Ich freue mich über jede Hilfe.
                          Der LOG von dem Ubuntu-System ist folgender:
                          2021-02-18 14:02:03.591 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                          2021-02-18 14:02:03.593 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                          2021-02-18 14:02:03.594 - info: mihome-vacuum.0 (915) Got terminate signal TERMINATE_YOURSELF
                          2021-02-18 14:02:03.595 - info: mihome-vacuum.0 (915) terminating
                          2021-02-18 14:02:03.595 - info: mihome-vacuum.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2021-02-18 14:02:04.111 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2021-02-18 14:02:06.615 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 1020
                          2021-02-18 14:02:07.105 - info: mihome-vacuum.0 (1020) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                          2021-02-18 14:02:07.146 - info: mihome-vacuum.0 (1020) Expert mode enabled, states created
                          2021-02-18 14:02:07.146 - info: mihome-vacuum.0 (1020) Create state clean_home for controlling by cloud adapter
                          2021-02-18 14:02:07.671 - info: mihome-vacuum.0 (1020) set nächster Timer: Nicht verfügbar
                          2021-02-18 14:02:08.330 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:03:09.810 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:04:11.431 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:05:00.020 - info: host.Server instance system.adapter.dwd.0 started with pid 1035
                          2021-02-18 14:05:00.580 - info: dwd.0 (1035) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                          2021-02-18 14:05:00.940 - info: dwd.0 (1035) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2021-02-18 14:05:01.450 - info: host.Server instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2021-02-18 14:05:13.192 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:06:14.647 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:07:16.150 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:08:01.090 - info: hm-rpc.0 (536) xmlrpc <- listDevices ["hm-rpc.0"]
                          2021-02-18 14:08:01.117 - info: hm-rpc.0 (536) xmlrpc -> 0 devices
                          2021-02-18 14:08:01.223 - info: hm-rpc.0 (536) xmlrpc <- newDevices 170
                          2021-02-18 14:08:01.246 - info: hm-rpc.0 (536) new HMIP devices/channels after filter: 0
                          2021-02-18 14:08:17.620 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:09:19.121 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:10:00.023 - info: host.Server instance system.adapter.dwd.0 started with pid 1050
                          2021-02-18 14:10:00.597 - info: dwd.0 (1050) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                          2021-02-18 14:10:00.983 - info: dwd.0 (1050) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2021-02-18 14:10:01.493 - info: host.Server instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2021-02-18 14:10:20.475 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:11:22.013 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                          2021-02-18 14:11:55.186 - info: host.Server "system.adapter.mihome-vacuum.0" disabled
                          2021-02-18 14:11:55.188 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                          2021-02-18 14:11:55.188 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                          2021-02-18 14:11:55.190 - info: mihome-vacuum.0 (1020) Got terminate signal TERMINATE_YOURSELF
                          2021-02-18 14:11:55.191 - info: mihome-vacuum.0 (1020) terminating
                          2021-02-18 14:11:55.191 - info: mihome-vacuum.0 (1020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                          2021-02-18 14:11:55.707 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          2021-02-18 14:11:57.923 - info: host.Server "system.adapter.mihome-vacuum.0" enabled
                          2021-02-18 14:11:57.941 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 1065
                          2021-02-18 14:11:58.436 - info: mihome-vacuum.0 (1065) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                          2021-02-18 14:11:58.478 - info: mihome-vacuum.0 (1065) Expert mode enabled, states created
                          2021-02-18 14:11:58.478 - info: mihome-vacuum.0 (1065) Create state clean_home for controlling by cloud adapter
                          2021-02-18 14:11:59.004 - info: mihome-vacuum.0 (1065) set nächster Timer: Nicht verfügbar
                          2021-02-18 14:12:00.045 - info: host.Server instance system.adapter.weatherunderground.1 started with pid 1080
                          2021-02-18 14:12:00.519 - info: weatherunderground.1 (1080) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.20.2, js-controller: 3.1.6
                          2021-02-18 14:12:03.888 - info: weatherunderground.1 (1080) Terminated (NO_ERROR): Without reason
                          2021-02-18 14:12:04.068 - info: host.Server instance system.adapter.weatherunderground.0 started with pid 1095
                          2021-02-18 14:12:04.393 - info: host.Server instance system.adapter.weatherunderground.1 terminated with code 0 (NO_ERROR)
                          2021-02-18 14:12:04.544 - info: weatherunderground.0 (1095) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.20.2, js-controller: 3.1.6
                          2021-02-18 14:12:08.195 - info: weatherunderground.0 (1095) Terminated (NO_ERROR): Without reason
                          2021-02-18 14:12:08.705 - info: host.Server instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                          • S Schwabe
                            haselchenH
                            haselchenH
                            haselchen
                            #1367
                            @schwabe
                            Ich kann nur raten, aber im rechten Screenshot steht für V1 und S5 und Du hast einen S6.....
                            • haselchenH haselchen
                              @schwabe
                              S
                              S
                              Schwabe
                              #1368
                              @haselchen das mit dem S6 ist mir klar, doch der Adapter läuft ja, lässt sich nur nicht updaten.
                              Wichtiger wäre mir jedoch den Ubuntu ans laufen zu bekommen, der andere wird eh irgendwann abgeschaltet.
                              • S Schwabe
                                haselchenH
                                haselchenH
                                haselchen
                                #1369
                                @schwabe
                                Pragmatische Lösung , wenn es geht, die 1.1.5 auf Ubuntu installieren?
                                Das war die letzte Version, mit der dein Sauger funktionierte?
                                Edit:
                                Laufen beide Adapter gleichzeitig? (Tinker und Ubuntu?)
                                Oder hast du mal das WIFI resettet, dass der Token nicht mehr stimmt?
                                  @schwabe
                                  Edit:
                                  S
                                  S
                                  Schwabe
                                  #1370
                                  @haselchen danke für den Tipp, ich musste zwar erstmal auf den 2.0.7 zurück um überhaupt den 1.1.5 angezeigt zu bekommen, doch hat es endgültig geklappt. Leider ist das Problem damit nicht gelöst, der Adapter bleibt "gelb"
                                  Ja aktuell laufen beide ioBroker und somit auch beide Adapter gleichzeitig. Doch auch die vorübergehende Deaktiverung des ThinkerBoardS Adapters bringt beim Ubuntu keine Besserung. Der Token muss noch stimmen, sonst könnte der ThinkerBoardS Adapter nicht funktionieren und ich würde über die Server Suche einen den Neuen finden, oder?
                                  Hier dazu mein letzter Log:
                                  2021-02-18 19:23:00.831 - info: mihome-vacuum.0 (3441) Got terminate signal TERMINATE_YOURSELF
                                  2021-02-18 19:23:00.831 - info: mihome-vacuum.0 (3441) terminating
                                  2021-02-18 19:23:00.832 - info: mihome-vacuum.0 (3441) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-18 19:23:01.347 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-18 19:23:03.854 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3456
                                  2021-02-18 19:23:04.287 - warn: mihome-vacuum.0 (3456) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                  2021-02-18 19:23:04.288 - warn: mihome-vacuum.0 (3456) This object will not be created in future versions. Please report this to the developer.
                                  2021-02-18 19:23:04.351 - info: mihome-vacuum.0 (3456) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                  2021-02-18 19:23:04.370 - info: mihome-vacuum.0 (3456) Expert mode disabled, states deleted
                                  2021-02-18 19:23:04.371 - info: mihome-vacuum.0 (3456) Cloud control disabled
                                  2021-02-18 19:23:04.375 - info: mihome-vacuum.0 (3456) Disconnect
                                  2021-02-18 19:23:04.900 - info: mihome-vacuum.0 (3456) set nächster Timer: Nicht verfügbar
                                  2021-02-18 19:23:20.469 - info: host.Server iobroker upgrade mihome-vacuum@1.1.5
                                  2021-02-18 19:23:21.486 - info: host.Server iobroker Update mihome-vacuum from @2.0.7 to @1.1.5
                                  2021-02-18 19:23:21.674 - info: host.Server iobroker NPM version: 6.14.11
                                  2021-02-18 19:23:21.675 - info: host.Server iobroker npm install iobroker.mihome-vacuum@1.1.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                  2021-02-18 19:23:23.918 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                  2021-02-18 19:23:24.376 - info: mihome-vacuum.0 (3456) Disconnect
                                  2021-02-18 19:23:25.458 - info: host.Server iobroker upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                  2021-02-18 19:23:25.491 - info: host.Server iobroker Update "system.adapter.mihome-vacuum.0"
                                  2021-02-18 19:23:25.497 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                  2021-02-18 19:23:25.499 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                  2021-02-18 19:23:25.499 - info: mihome-vacuum.0 (3456) Got terminate signal TERMINATE_YOURSELF
                                  2021-02-18 19:23:25.500 - info: mihome-vacuum.0 (3456) terminating
                                  2021-02-18 19:23:25.500 - info: mihome-vacuum.0 (3456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-18 19:23:25.551 - info: host.Server iobroker upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                  2021-02-18 19:23:25.605 - info: host.Server iobroker upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                  2021-02-18 19:23:25.667 - info: host.Server iobroker upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                  2021-02-18 19:23:25.730 - info: host.Server iobroker upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                  2021-02-18 19:23:25.783 - info: host.Server iobroker Adapter "mihome-vacuum" updated
                                  2021-02-18 19:23:26.009 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-18 19:23:26.793 - info: host.Server iobroker exit 0
                                  2021-02-18 19:23:28.517 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3502
                                  2021-02-18 19:23:28.836 - warn: mihome-vacuum.0 (3502) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                  2021-02-18 19:23:28.836 - warn: mihome-vacuum.0 (3502) This object will not be created in future versions. Please report this to the developer.
                                  2021-02-18 19:23:28.908 - info: mihome-vacuum.0 (3502) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                  2021-02-18 19:23:28.925 - info: mihome-vacuum.0 (3502) Expert mode disabled, states deleded
                                  2021-02-18 19:23:28.925 - info: mihome-vacuum.0 (3502) Cloud control disabled
                                  2021-02-18 19:23:36.444 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                  2021-02-18 19:23:36.445 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                  2021-02-18 19:23:36.447 - info: mihome-vacuum.0 (3502) Got terminate signal TERMINATE_YOURSELF
                                  2021-02-18 19:23:36.448 - info: mihome-vacuum.0 (3502) terminating
                                  2021-02-18 19:23:36.449 - info: mihome-vacuum.0 (3502) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-18 19:23:36.960 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-18 19:23:39.469 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3517
                                  2021-02-18 19:23:39.775 - warn: mihome-vacuum.0 (3517) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                  2021-02-18 19:23:39.776 - warn: mihome-vacuum.0 (3517) This object will not be created in future versions. Please report this to the developer.
                                  2021-02-18 19:23:39.845 - info: mihome-vacuum.0 (3517) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                  2021-02-18 19:23:39.863 - info: mihome-vacuum.0 (3517) Expert mode disabled, states deleded
                                  2021-02-18 19:23:39.863 - info: mihome-vacuum.0 (3517) Cloud control disabled
                                  2021-02-18 19:23:44.595 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                  2021-02-18 19:23:44.595 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                  2021-02-18 19:23:44.596 - info: mihome-vacuum.0 (3517) Got terminate signal TERMINATE_YOURSELF
                                  2021-02-18 19:23:44.597 - info: mihome-vacuum.0 (3517) terminating
                                  2021-02-18 19:23:44.597 - info: mihome-vacuum.0 (3517) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-18 19:23:45.109 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-18 19:23:47.618 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3532
                                  2021-02-18 19:23:47.922 - warn: mihome-vacuum.0 (3532) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                  2021-02-18 19:23:47.922 - warn: mihome-vacuum.0 (3532) This object will not be created in future versions. Please report this to the developer.
                                  2021-02-18 19:23:47.982 - info: mihome-vacuum.0 (3532) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                  2021-02-18 19:23:47.999 - info: mihome-vacuum.0 (3532) Expert mode enabled, states created
                                  2021-02-18 19:23:48.000 - info: mihome-vacuum.0 (3532) Cloud control disabled
                                  2021-02-18 19:23:52.233 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                  2021-02-18 19:23:52.234 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                  2021-02-18 19:23:52.235 - info: mihome-vacuum.0 (3532) Got terminate signal TERMINATE_YOURSELF
                                  2021-02-18 19:23:52.235 - info: mihome-vacuum.0 (3532) terminating
                                  2021-02-18 19:23:52.236 - info: mihome-vacuum.0 (3532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                  2021-02-18 19:23:52.747 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                  2021-02-18 19:23:55.258 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3547
                                  2021-02-18 19:23:55.563 - warn: mihome-vacuum.0 (3547) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                  2021-02-18 19:23:55.563 - warn: mihome-vacuum.0 (3547) This object will not be created in future versions. Please report this to the developer.
                                  2021-02-18 19:23:55.626 - info: mihome-vacuum.0 (3547) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                  2021-02-18 19:23:55.644 - info: mihome-vacuum.0 (3547) Expert mode enabled, states created
                                  2021-02-18 19:23:55.644 - info: mihome-vacuum.0 (3547) Cloud control disabled
                                  • S Schwabe
                                    D
                                    D
                                    dirkhe
                                    #1371
                                    @schwabe installiere den aktuellen Adapter, Stelle den Adapter mal auf debug und poste das hier. Denk dran, das es manchmal dauern kann, bis er sich connected. Oft hilft es auch, wenn man gleichzeitig in die mihome App geht
                                    • D dirkhe
                                      S
                                      S
                                      Schwabe
                                      #1372
                                      @dirkhe Danke für die Hilfe.
                                      Ich habe den Adapter aktualisiert und auf Debug gestellt. Dann habe ich ein paar Einstellungen vorgenommen und den Adapter einmal neu gestartet. Zudem ist seit über 12 Stunden der Adapter auf dem TinkerBoardS deaktiviert. Der Adpater bleibt weiterhin "Gelb".
                                      Hier der LOG:
                                      mihome-vacuum.0	2021-02-19 08:05:06.261	debug	(8721) Xiaomi Cloud: Login successful
                                      mihome-vacuum.0	2021-02-19 08:05:04.771	info	(8721) set nächster Timer: Nicht verfügbar
                                      mihome-vacuum.0	2021-02-19 08:05:04.264	debug	(8721) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                      mihome-vacuum.0	2021-02-19 08:05:04.253	debug	(8721) server started on 0.0.0.0:53421
                                      mihome-vacuum.0	2021-02-19 08:05:04.250	info	(8721) Create state clean_home for controlling by cloud adapter
                                      mihome-vacuum.0	2021-02-19 08:05:04.250	info	(8721) Expert mode enabled, states created
                                      mihome-vacuum.0	2021-02-19 08:05:04.247	debug	(8721) Xiaomi Cloud: Logging in
                                      mihome-vacuum.0	2021-02-19 08:05:04.247	debug	(8721) load Map creator... true
                                      mihome-vacuum.0	2021-02-19 08:05:04.209	info	(8721) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                      mihome-vacuum.0	2021-02-19 08:05:04.107	debug	(8721) statesDB connected
                                      mihome-vacuum.0	2021-02-19 08:05:04.107	debug	(8721) States connected to redis: 127.0.0.1:9000
                                      mihome-vacuum.0	2021-02-19 08:05:04.102	debug	(8721) States create System PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:05:04.102	debug	(8721) States create User PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:05:04.099	debug	(8721) Redis States: Use Redis connection: 127.0.0.1:9000
                                      mihome-vacuum.0	2021-02-19 08:05:04.098	debug	(8721) objectDB connected
                                      mihome-vacuum.0	2021-02-19 08:05:04.097	debug	(8721) Objects connected to redis: 127.0.0.1:9001
                                      mihome-vacuum.0	2021-02-19 08:05:04.088	debug	(8721) Objects client initialize lua scripts
                                      mihome-vacuum.0	2021-02-19 08:05:04.088	debug	(8721) Objects create User PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:05:04.088	debug	(8721) Objects create System PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:05:04.087	debug	(8721) Objects client ready ... initialize now
                                      mihome-vacuum.0	2021-02-19 08:05:04.077	debug	(8721) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      host.Server	2021-02-19 08:05:03.708	info	instance system.adapter.mihome-vacuum.0 started with pid 8721
                                      host.Server	2021-02-19 08:05:01.434	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      host.Server	2021-02-19 08:05:01.201	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      dwd.0	2021-02-19 08:05:00.926	info	(8706) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      mihome-vacuum.0	2021-02-19 08:05:00.688	info	(8691) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      mihome-vacuum.0	2021-02-19 08:05:00.688	info	(8691) terminating
                                      mihome-vacuum.0	2021-02-19 08:05:00.687	info	(8691) Got terminate signal TERMINATE_YOURSELF
                                      host.Server	2021-02-19 08:05:00.686	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                      host.Server	2021-02-19 08:05:00.686	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                      dwd.0	2021-02-19 08:05:00.613	info	(8706) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                                      host.Server	2021-02-19 08:05:00.033	info	instance system.adapter.dwd.0 started with pid 8706
                                      mihome-vacuum.0	2021-02-19 08:04:56.597	debug	(8691) Xiaomi Cloud: Login successful
                                      mihome-vacuum.0	2021-02-19 08:04:55.360	info	(8691) set nächster Timer: Nicht verfügbar
                                      mihome-vacuum.0	2021-02-19 08:04:54.857	debug	(8691) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                      mihome-vacuum.0	2021-02-19 08:04:54.846	debug	(8691) server started on 0.0.0.0:53421
                                      mihome-vacuum.0	2021-02-19 08:04:54.843	info	(8691) Create state clean_home for controlling by cloud adapter
                                      mihome-vacuum.0	2021-02-19 08:04:54.842	info	(8691) Expert mode enabled, states created
                                      mihome-vacuum.0	2021-02-19 08:04:54.840	debug	(8691) Xiaomi Cloud: Logging in
                                      mihome-vacuum.0	2021-02-19 08:04:54.840	debug	(8691) load Map creator... true
                                      mihome-vacuum.0	2021-02-19 08:04:54.799	info	(8691) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                      mihome-vacuum.0	2021-02-19 08:04:54.700	debug	(8691) statesDB connected
                                      mihome-vacuum.0	2021-02-19 08:04:54.700	debug	(8691) States connected to redis: 127.0.0.1:9000
                                      mihome-vacuum.0	2021-02-19 08:04:54.694	debug	(8691) States create System PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:04:54.693	debug	(8691) States create User PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:04:54.691	debug	(8691) Redis States: Use Redis connection: 127.0.0.1:9000
                                      mihome-vacuum.0	2021-02-19 08:04:54.690	debug	(8691) objectDB connected
                                      mihome-vacuum.0	2021-02-19 08:04:54.689	debug	(8691) Objects connected to redis: 127.0.0.1:9001
                                      mihome-vacuum.0	2021-02-19 08:04:54.681	debug	(8691) Objects client initialize lua scripts
                                      mihome-vacuum.0	2021-02-19 08:04:54.681	debug	(8691) Objects create User PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:04:54.681	debug	(8691) Objects create System PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:04:54.680	debug	(8691) Objects client ready ... initialize now
                                      mihome-vacuum.0	2021-02-19 08:04:54.670	debug	(8691) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      host.Server	2021-02-19 08:04:54.303	info	instance system.adapter.mihome-vacuum.0 started with pid 8691
                                      host.Server	2021-02-19 08:04:51.842	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      mihome-vacuum.0	2021-02-19 08:04:51.284	info	(8676) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      mihome-vacuum.0	2021-02-19 08:04:51.283	info	(8676) terminating
                                      mihome-vacuum.0	2021-02-19 08:04:51.283	info	(8676) Got terminate signal TERMINATE_YOURSELF
                                      host.Server	2021-02-19 08:04:51.280	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                      host.Server	2021-02-19 08:04:51.279	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                      mihome-vacuum.0	2021-02-19 08:04:42.923	debug	(8676) Xiaomi Cloud: Login successful
                                      mihome-vacuum.0	2021-02-19 08:04:40.900	info	(8676) set nächster Timer: Nicht verfügbar
                                      mihome-vacuum.0	2021-02-19 08:04:40.394	debug	(8676) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
                                      mihome-vacuum.0	2021-02-19 08:04:40.383	debug	(8676) server started on 0.0.0.0:53421
                                      mihome-vacuum.0	2021-02-19 08:04:40.380	info	(8676) Create state clean_home for controlling by cloud adapter
                                      mihome-vacuum.0	2021-02-19 08:04:40.380	info	(8676) Expert mode enabled, states created
                                      mihome-vacuum.0	2021-02-19 08:04:40.377	debug	(8676) Xiaomi Cloud: Logging in
                                      mihome-vacuum.0	2021-02-19 08:04:40.377	debug	(8676) load Map creator... true
                                      mihome-vacuum.0	2021-02-19 08:04:40.280	info	(8676) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                      mihome-vacuum.0	2021-02-19 08:04:40.188	debug	(8676) statesDB connected
                                      mihome-vacuum.0	2021-02-19 08:04:40.188	debug	(8676) States connected to redis: 127.0.0.1:9000
                                      mihome-vacuum.0	2021-02-19 08:04:40.183	debug	(8676) States create System PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:04:40.182	debug	(8676) States create User PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:04:40.179	debug	(8676) Redis States: Use Redis connection: 127.0.0.1:9000
                                      mihome-vacuum.0	2021-02-19 08:04:40.179	debug	(8676) objectDB connected
                                      mihome-vacuum.0	2021-02-19 08:04:40.178	debug	(8676) Objects connected to redis: 127.0.0.1:9001
                                      mihome-vacuum.0	2021-02-19 08:04:40.170	debug	(8676) Objects client initialize lua scripts
                                      mihome-vacuum.0	2021-02-19 08:04:40.170	debug	(8676) Objects create User PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:04:40.169	debug	(8676) Objects create System PubSub Client
                                      mihome-vacuum.0	2021-02-19 08:04:40.167	debug	(8676) Objects client ready ... initialize now
                                      mihome-vacuum.0	2021-02-19 08:04:40.157	debug	(8676) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                      host.Server	2021-02-19 08:04:39.786	info	instance system.adapter.mihome-vacuum.0 started with pid 8676
                                      host.Server	2021-02-19 08:04:37.278	info	instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                      mihome-vacuum.0	2021-02-19 08:04:36.764	info	(6066) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      mihome-vacuum.0	2021-02-19 08:04:36.764	info	(6066) terminating
                                      mihome-vacuum.0	2021-02-19 08:04:36.763	info	(6066) Got terminate signal TERMINATE_YOURSELF
                                      host.Server	2021-02-19 08:04:36.761	info	stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                      host.Server	2021-02-19 08:04:36.760	info	stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                      tr-064.0	2021-02-19 08:04:34.434	info	(726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpec
                                      mihome-vacuum.0	2021-02-19 08:04:08.726	debug	(6066) sendTo "discovery" to system.adapter.admin.0 from system.adapter.mihome-vacuum.0
                                      mihome-vacuum.0	2021-02-19 08:04:08.726	debug	(6066) discover__[{"did":"259591246","token":"3657354e664a5a4b4b74306d524c6f52","longitude":"0.00000000","latitude":"0.00000000","name":"Eltern","pid":"0","localip":"192.168.1.135","mac":"04:CF:8C:F8
                                      mihome-vacuum.0	2021-02-19 08:04:08.724	debug	(6066) {"code":0,"message":"ok","result":{"list":[{"did":"259591246","token":"3657354e664a5a4b4b74306d524c6f52","longitude":"0.00000000","latitude":"0.00000000","name":"Eltern","pid":"0","localip":"1
                                      mihome-vacuum.0	2021-02-19 08:04:08.564	debug	(6066) GET devices from:https://de.api.io.mi.com/app/home/device_list
                                      mihome-vacuum.0	2021-02-19 08:04:08.546	debug	(6066) Xiaomi Cloud: Login successful
                                      mihome-vacuum.0	2021-02-19 08:04:06.695	debug	(6066) Xiaomi Cloud: Logging in
                                      mihome-vacuum.0	2021-02-19 08:03:51.246	debug	(6066) system.adapter.admin.0: logging true
                                      mihome-vacuum.0	2021-02-19 08:03:47.255	debug	(6066) system.adapter.admin.0: logging false
                                      • S Schwabe
                                        Hier der LOG:
                                        D
                                        D
                                        dirkhe
                                        #1373
                                        @schwabe was ich da sehe, ist das der Adapter ständig neu startet. Normalerweise sollte man sehen, wie er versucht sich zu verbinden. Da stimmt irgendwas gar nicht.
                                        • D dirkhe
                                          S
                                          S
                                          Schwabe
                                          #1374
                                          @dirkhe die Neustarts habe ich initialisiert, damit Logs geschrieben werden. Bei jedem Neustart sollte der Adapter ja alle Phasen durchlaufen, oder? Mittlerweile sind weitere 16 Stunden vorbei, der ThinkerBoardS Adapter ist noch immer deaktiviert, ich habe mehrfach die App geöffnet, doch der Adapter bleibt "gelb"
                                          Das ist der einzige Eintrag, welcher durch den Adapter in der letzten Stunde gemacht wurde:
                                          mihome-vacuum.0	2021-02-19 23:54:16.473	debug	(13884) system.adapter.admin.0: logging true
                                          83.9k
