  4. Test Adapter mihome-vacuum v2.0.x
    apollon77A
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 745.5k Aufrufe 118 Beobachtet
    @bjoegibbard Nicht unbedingt.
    Kannst du aber mal nachinstallieren.
    Und ich würde node auf Stand bringen.
    sudo apt update
    sudo apt dist-upgrade
    sudo reboot
    (Wenn es schon sauber installiert war...)
    B
    B
    bjoegibbard
    #1352
    danke, habe alles ausgeführt. Aber leider keine Besserung.
    • B bjoegibbard
      Thomas BraunT
      Thomas BraunT
      #1353
      @bjoegibbard
      which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      cd /opt/iobroker
      npm cache clean --force
      npm install authenticate-pam
        @bjoegibbard
        cd /opt/iobroker
        B
        B
        bjoegibbard
        schrieb am zuletzt editiert von bjoegibbard
        #1354
        /usr/bin/nodejs
        v12.20.1
        /usr/bin/node
        v12.20.1
        /usr/bin/npm
        6.14.10
        nodejs:
          Installiert:           12.20.1-1nodesource1
          Installationskandidat: 12.20.1-1nodesource1
          Versionstabelle:
         *** 12.20.1-1nodesource1 500
                500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
             10.23.1~dfsg-1~deb10u1 500
        /opt/iobroker $ npm cache clean --force
        npm WARN using --force I sure hope you know what you are doing.
        > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
        > node-gyp rebuild
        make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
          CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
        In file included from ../authenticate_pam.cc:23:
        ../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
        ../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]
             , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
        ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:
        ../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]
         keCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);
        ../../nan/nan.h:1026:46: note: declared here
           NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(
        ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:
        ../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
         al<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());
        In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8-internal.h:14,
                         from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:27,
                         from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
                         from ../../nan/nan.h:56,
        /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:3553:51: note: declared here
           V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));
        /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
           declarator __attribute__((deprecated(message)))
        ../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
            serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);
        In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
        /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
           int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,
        /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
        ../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]
           res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());
        ../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
            remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);
        ../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
          username->WriteUtf8(m->username, sizeof(m->username) - 1);
        ../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’
          password->WriteUtf8(m->password, sizeof(m->password) - 1);
        ../authenticate_pam.cc: At global scope:
        ../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void
         void init(Handle<Object> exports) {
        ../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
        ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’
                   rand_r
        ../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token
        ../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope
        In file included from ../../nan/nan.h:56,
        ../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope
         NODE_MODULE(authenticate_pam, init);
        /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:36: note: in definition of macro ‘NODE_MODULE_X’
               (node::addon_register_func) (regfunc),                          \
        ../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’
        ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’
        make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
        make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
        gyp ERR! build error
        gyp ERR! stack Error: `make` failed with exit code: 2
        gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
        gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
        gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
        gyp ERR! System Linux 5.4.83-v7l+
        gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
        gyp ERR! node -v v12.20.1
        gyp ERR! node-gyp -v v5.1.0
        gyp ERR! not ok
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/chokidar/node_modules/fsevents):
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
        npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! authenticate-pam@1.0.2 install: `node-gyp rebuild`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the authenticate-pam@1.0.2 install script.
        npm ERR!     /home/iobroker/.npm/_logs/2021-01-24T16_44_12_411Z-debug.log
        pi@raspberrypi4-iob:/opt/iobroker $
        da ist wieder dieser doofe gyp ERR! -.-
        • B bjoegibbard
          /usr/bin/nodejs
          v12.20.1
          /usr/bin/node
          v12.20.1
          /usr/bin/npm
          6.14.10
          nodejs:
            Versionstabelle:
          > node-gyp rebuild
                     rand_r
          gyp ERR! not ok
          npm ERR! errno 1
          npm ERR!
          Thomas BraunT
          Thomas BraunT
          #1355
          @bjoegibbard
          authenticate_pam
          Keine Ahnung. Vielleicht baut das Modul nicht mehr gegen aktuelle node-Versionen. Das ist ja schon über ein Jahr nicht mehr angefasst worden.
          Welcher Adapter braucht das Ding eigentlich?
          npm list authenticate-pam
          Dürfte der terminal-Adapter sein. Braucht eh keiner.
          iobroker del terminal
          cd /opt/iobroker
          Danach sollte Ruhe von der Seite sein.
          N 1 Antwort Letzte Antwort
            @bjoegibbard
            authenticate_pam
            cd /opt/iobroker
            N
            N
            nu_81
            schrieb am zuletzt editiert von nu_81
            #1356
            Hatte lange Zeit ein ioBroker (mit altem Stand ohne Updates einzuspielen) auf einem Igel laufen
            mit dem ich meinen S50 per Szene gesteuert habe.
            Konkret hatte ich eine Szene "MAP_EG_Laden" erstellt.
            Hierin wurde per SSH auf dem Roborock die Map Dateien getauscht und anschließend kurz gestartet und pausiert um die Karten auch wirklich zu laden.
            Diese Szene habe ich dann vor jede andere Szene gepackt um dann die einzelnen Zonen anzufahren:
            Das hat auch immer zuverlässig funktioniert.
            Habe nun auf einen Raspberry mit aktueller Version gewechselt und da klappt es leider nicht mehr.
            Immer wieder erscheint die Meldung
            "should trigger cleaning all , but is currently active(5). Add to queue"
            Der S50 reagiert dann auch überhaupt nicht, wenn ich z.B. Start auf true setze.
            Muss ich z.B. den Pause Befehl manuell wieder auf false setzten um z.B. die Zonenreinigung zu starten?
            Manchmal funktioniert es wieder wenn ich vor den Befehlen den "Home" Befehl mit rein nehme.
            Es scheint eine neue Funktion der Queue zu geben, die ich hier scheinbar falsch bediene.
            Das hier funktioniert z.B. manchmal:
            Hier noch der obere Teil im aufgeklappten Zustand:
            Aber auch hier kommt manchmal die Meldung mit der Queue.
            Habe auch schon mal versucht "clearQueue" auf true zwischendurch einzusetzen. Aber auch das hilft nicht.
            Leider verstehe ich da das Konzept der Queue auch nicht so recht.
            Kann man die Queue Funktion irgendwie abschalten?
            Wie kann ich die Queue eventuell löschen um den S50 zu "befreien" sodass er wieder Befehle annimmt?
            Wie sollte ich hier am besten vorgehen um es wieder wie vorher zum laufen zu bekommen?
            Gruß Nu
            • N nu_81
              Gruß Nu
              D
              D
              dirkhe
              #1357
              @nu_81 die queue ist dafür da, dass du einfach mehrere Räume starten kannst unser die dann nacheinander abarbeitet.
              Wenn er nicht startet hat er eher verbindindungsprobleme. Sobald er wieder verbunden ist, sollte er starten.
              • D dirkhe
                N
                N
                nu_81
                #1358
                Glaube nicht dass es Verbindungsprobleme sind.
                Er reagiert z.B. überhaupt nicht auf start, gibt stattdessen die Meldung ins Log.
                Auf z.B. auf Home oder "Wo bist du" reagiert er sofort.
                • N nu_81
                  D
                  D
                  dirkhe
                  #1359
                  @nu_81 dann stell den adapter mal auf debug und poste das Log hier.
                  • D dirkhe
                    S
                    S
                    Sweatchuck
                    #1360
                    kurze Frage...
                    Meine beiden Robrock (S5 und S6) wollen ein Firmware-Update durchführen.
                    Von Version 3.5.8_2076 auf 3.5.8_2652 beim S6 bzw. 3.5.7_002008 auf 3.5.8_002034.
                    Da momentan aber alles super funktioniert will ich nicht einfach ein Update fahren und deshalb mal nachfragen ob jemand von euch Erfahrungen dies bzgl. hat. Angeblich handelt es sich dabei nur ein Bugfix?!
                    Beste Grüße
                    • JackDanielJ
                      JackDanielJ
                      JackDaniel
                      #1361
                      keine probleme hier
                      Carpe diem
                      • S Sweatchuck
                        kurze Frage...
                        Beste Grüße
                        #1362
                        @sweatchuck
                        nee, meine 4 auch, mach doch mal, dann wissen wir ja, obs dann noch geht.. :-)
                        • JackDanielJ JackDaniel
                          keine probleme hier
                          #1363
                          @jackdaniel mit Adapter Version ..??
                          • JackDanielJ
                            JackDanielJ
                            JackDaniel
                            #1364
                            bei mir läuft die 2.2.4
                            Carpe diem
                            • S
                              S
                              Snapergy
                              schrieb am zuletzt editiert von Snapergy
                              #1365
                              Puh, bin gerade echt am verzweifeln. Ich habe nichts weiter gemacht (zumindest nicht, dass ich wüsste), aber die Map lädt nicht mehr und es kommt immer folgender Fehler:
                              answer map_slot is currently not supported!
                              Was kann ich machen?
                              EDIT: Hab die Lösung gefunden. Für alle, die das gleiche Problem haben:
                              https://github.com/iobroker-community-adapters/ioBroker.mihome-vacuum/issues/119
                              Lag am Update von NodeJS...
                              • S
                                S
                                Schwabe
                                schrieb am zuletzt editiert von Schwabe
                                #1366
                                DANKE erstmal für diesen tollen Adapter und die kontinuierliche Arbeit daran.
                                Wegen einem bevorstehenden Wechsel von einem ASUS TinkerBoard S auf ein Windows10 Ubunto-System habe ich aktuell 2 Versionen von dem Adapter laufen.
                                Auf dem TinkerBoard S habe ich die Version 1.1.5 installiert und kann nicht auf die Version 2.1.1 updaten. Das Update wird stets mit einem Fehler beendet und der Adpater ist dann auch aus der VIS verschwunden. Ansonsten läuft diese Version zu meiner vollen Zufriedenheit.
                                Mein Hauptproblem ist jedoch das der Adapter auf dem Ubuntu in der Version 2.1.1 bei "Gelb" bleibt. Ich kann zwar den Server (Germany) abfragen und den S6 übernehmen, doch der Adapter bleibt "Gelb".
                                Die Konfigurationen sind gleich, wie auf den Screenshots zu sehen.
                                Ich freue mich über jede Hilfe.
                                Der LOG von dem Ubuntu-System ist folgender:
                                2021-02-18 14:02:03.591 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                2021-02-18 14:02:03.593 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                2021-02-18 14:02:03.594 - info: mihome-vacuum.0 (915) Got terminate signal TERMINATE_YOURSELF
                                2021-02-18 14:02:03.595 - info: mihome-vacuum.0 (915) terminating
                                2021-02-18 14:02:03.595 - info: mihome-vacuum.0 (915) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-02-18 14:02:04.111 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-02-18 14:02:06.615 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 1020
                                2021-02-18 14:02:07.105 - info: mihome-vacuum.0 (1020) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                2021-02-18 14:02:07.146 - info: mihome-vacuum.0 (1020) Expert mode enabled, states created
                                2021-02-18 14:02:07.146 - info: mihome-vacuum.0 (1020) Create state clean_home for controlling by cloud adapter
                                2021-02-18 14:02:07.671 - info: mihome-vacuum.0 (1020) set nächster Timer: Nicht verfügbar
                                2021-02-18 14:02:08.330 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:03:09.810 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:04:11.431 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:05:00.020 - info: host.Server instance system.adapter.dwd.0 started with pid 1035
                                2021-02-18 14:05:00.580 - info: dwd.0 (1035) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                                2021-02-18 14:05:00.940 - info: dwd.0 (1035) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-02-18 14:05:01.450 - info: host.Server instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-02-18 14:05:13.192 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:06:14.647 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:07:16.150 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:08:01.090 - info: hm-rpc.0 (536) xmlrpc <- listDevices ["hm-rpc.0"]
                                2021-02-18 14:08:01.117 - info: hm-rpc.0 (536) xmlrpc -> 0 devices
                                2021-02-18 14:08:01.223 - info: hm-rpc.0 (536) xmlrpc <- newDevices 170
                                2021-02-18 14:08:01.246 - info: hm-rpc.0 (536) new HMIP devices/channels after filter: 0
                                2021-02-18 14:08:17.620 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:09:19.121 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:10:00.023 - info: host.Server instance system.adapter.dwd.0 started with pid 1050
                                2021-02-18 14:10:00.597 - info: dwd.0 (1050) starting. Version 2.5.2 in /opt/iobroker/node_modules/iobroker.dwd, node: v12.20.2, js-controller: 3.1.6
                                2021-02-18 14:10:00.983 - info: dwd.0 (1050) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-02-18 14:10:01.493 - info: host.Server instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-02-18 14:10:20.475 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:11:22.013 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                2021-02-18 14:11:55.186 - info: host.Server "system.adapter.mihome-vacuum.0" disabled
                                2021-02-18 14:11:55.188 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                2021-02-18 14:11:55.188 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                2021-02-18 14:11:55.190 - info: mihome-vacuum.0 (1020) Got terminate signal TERMINATE_YOURSELF
                                2021-02-18 14:11:55.191 - info: mihome-vacuum.0 (1020) terminating
                                2021-02-18 14:11:55.191 - info: mihome-vacuum.0 (1020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                2021-02-18 14:11:55.707 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                2021-02-18 14:11:57.923 - info: host.Server "system.adapter.mihome-vacuum.0" enabled
                                2021-02-18 14:11:57.941 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 1065
                                2021-02-18 14:11:58.436 - info: mihome-vacuum.0 (1065) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                2021-02-18 14:11:58.478 - info: mihome-vacuum.0 (1065) Expert mode enabled, states created
                                2021-02-18 14:11:58.478 - info: mihome-vacuum.0 (1065) Create state clean_home for controlling by cloud adapter
                                2021-02-18 14:11:59.004 - info: mihome-vacuum.0 (1065) set nächster Timer: Nicht verfügbar
                                2021-02-18 14:12:00.045 - info: host.Server instance system.adapter.weatherunderground.1 started with pid 1080
                                2021-02-18 14:12:00.519 - info: weatherunderground.1 (1080) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.20.2, js-controller: 3.1.6
                                2021-02-18 14:12:03.888 - info: weatherunderground.1 (1080) Terminated (NO_ERROR): Without reason
                                2021-02-18 14:12:04.068 - info: host.Server instance system.adapter.weatherunderground.0 started with pid 1095
                                2021-02-18 14:12:04.393 - info: host.Server instance system.adapter.weatherunderground.1 terminated with code 0 (NO_ERROR)
                                2021-02-18 14:12:04.544 - info: weatherunderground.0 (1095) starting. Version 3.2.1 in /opt/iobroker/node_modules/iobroker.weatherunderground, node: v12.20.2, js-controller: 3.1.6
                                2021-02-18 14:12:08.195 - info: weatherunderground.0 (1095) Terminated (NO_ERROR): Without reason
                                2021-02-18 14:12:08.705 - info: host.Server instance system.adapter.weatherunderground.0 terminated with code 0 (NO_ERROR)
                                • S Schwabe
                                  haselchenH
                                  haselchenH
                                  haselchen
                                  #1367
                                  @schwabe
                                  Ich kann nur raten, aber im rechten Screenshot steht für V1 und S5 und Du hast einen S6.....
                                  • haselchenH haselchen
                                    @schwabe
                                    S
                                    S
                                    Schwabe
                                    #1368
                                    @haselchen das mit dem S6 ist mir klar, doch der Adapter läuft ja, lässt sich nur nicht updaten.
                                    Wichtiger wäre mir jedoch den Ubuntu ans laufen zu bekommen, der andere wird eh irgendwann abgeschaltet.
                                    • S Schwabe
                                      haselchenH
                                      haselchenH
                                      haselchen
                                      #1369
                                      @schwabe
                                      Pragmatische Lösung , wenn es geht, die 1.1.5 auf Ubuntu installieren?
                                      Das war die letzte Version, mit der dein Sauger funktionierte?
                                      Edit:
                                      Laufen beide Adapter gleichzeitig? (Tinker und Ubuntu?)
                                      Oder hast du mal das WIFI resettet, dass der Token nicht mehr stimmt?
                                        @schwabe
                                        Edit:
                                        S
                                        S
                                        Schwabe
                                        #1370
                                        @haselchen danke für den Tipp, ich musste zwar erstmal auf den 2.0.7 zurück um überhaupt den 1.1.5 angezeigt zu bekommen, doch hat es endgültig geklappt. Leider ist das Problem damit nicht gelöst, der Adapter bleibt "gelb"
                                        Ja aktuell laufen beide ioBroker und somit auch beide Adapter gleichzeitig. Doch auch die vorübergehende Deaktiverung des ThinkerBoardS Adapters bringt beim Ubuntu keine Besserung. Der Token muss noch stimmen, sonst könnte der ThinkerBoardS Adapter nicht funktionieren und ich würde über die Server Suche einen den Neuen finden, oder?
                                        Hier dazu mein letzter Log:
                                        2021-02-18 19:23:00.831 - info: mihome-vacuum.0 (3441) Got terminate signal TERMINATE_YOURSELF
                                        2021-02-18 19:23:00.831 - info: mihome-vacuum.0 (3441) terminating
                                        2021-02-18 19:23:00.832 - info: mihome-vacuum.0 (3441) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2021-02-18 19:23:01.347 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2021-02-18 19:23:03.854 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3456
                                        2021-02-18 19:23:04.287 - warn: mihome-vacuum.0 (3456) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        2021-02-18 19:23:04.288 - warn: mihome-vacuum.0 (3456) This object will not be created in future versions. Please report this to the developer.
                                        2021-02-18 19:23:04.351 - info: mihome-vacuum.0 (3456) starting. Version 2.0.7 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                        2021-02-18 19:23:04.370 - info: mihome-vacuum.0 (3456) Expert mode disabled, states deleted
                                        2021-02-18 19:23:04.371 - info: mihome-vacuum.0 (3456) Cloud control disabled
                                        2021-02-18 19:23:04.375 - info: mihome-vacuum.0 (3456) Disconnect
                                        2021-02-18 19:23:04.900 - info: mihome-vacuum.0 (3456) set nächster Timer: Nicht verfügbar
                                        2021-02-18 19:23:20.469 - info: host.Server iobroker upgrade mihome-vacuum@1.1.5
                                        2021-02-18 19:23:21.486 - info: host.Server iobroker Update mihome-vacuum from @2.0.7 to @1.1.5
                                        2021-02-18 19:23:21.674 - info: host.Server iobroker NPM version: 6.14.11
                                        2021-02-18 19:23:21.675 - info: host.Server iobroker npm install iobroker.mihome-vacuum@1.1.5 --loglevel error --unsafe-perm --prefix "/opt/iobroker" (System call)
                                        2021-02-18 19:23:23.918 - info: tr-064.0 (726) forEachConfiguredDevice: in GetSpecificHostEntry 1(Mandy/ A8:DB:03:65:DB:6F) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
                                        2021-02-18 19:23:24.376 - info: mihome-vacuum.0 (3456) Disconnect
                                        2021-02-18 19:23:25.458 - info: host.Server iobroker upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript
                                        2021-02-18 19:23:25.491 - info: host.Server iobroker Update "system.adapter.mihome-vacuum.0"
                                        2021-02-18 19:23:25.497 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                        2021-02-18 19:23:25.499 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                        2021-02-18 19:23:25.499 - info: mihome-vacuum.0 (3456) Got terminate signal TERMINATE_YOURSELF
                                        2021-02-18 19:23:25.500 - info: mihome-vacuum.0 (3456) terminating
                                        2021-02-18 19:23:25.500 - info: mihome-vacuum.0 (3456) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2021-02-18 19:23:25.551 - info: host.Server iobroker upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png
                                        2021-02-18 19:23:25.605 - info: host.Server iobroker upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html
                                        2021-02-18 19:23:25.667 - info: host.Server iobroker upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html
                                        2021-02-18 19:23:25.730 - info: host.Server iobroker upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png
                                        2021-02-18 19:23:25.783 - info: host.Server iobroker Adapter "mihome-vacuum" updated
                                        2021-02-18 19:23:26.009 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2021-02-18 19:23:26.793 - info: host.Server iobroker exit 0
                                        2021-02-18 19:23:28.517 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3502
                                        2021-02-18 19:23:28.836 - warn: mihome-vacuum.0 (3502) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        2021-02-18 19:23:28.836 - warn: mihome-vacuum.0 (3502) This object will not be created in future versions. Please report this to the developer.
                                        2021-02-18 19:23:28.908 - info: mihome-vacuum.0 (3502) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                        2021-02-18 19:23:28.925 - info: mihome-vacuum.0 (3502) Expert mode disabled, states deleded
                                        2021-02-18 19:23:28.925 - info: mihome-vacuum.0 (3502) Cloud control disabled
                                        2021-02-18 19:23:36.444 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                        2021-02-18 19:23:36.445 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                        2021-02-18 19:23:36.447 - info: mihome-vacuum.0 (3502) Got terminate signal TERMINATE_YOURSELF
                                        2021-02-18 19:23:36.448 - info: mihome-vacuum.0 (3502) terminating
                                        2021-02-18 19:23:36.449 - info: mihome-vacuum.0 (3502) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2021-02-18 19:23:36.960 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2021-02-18 19:23:39.469 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3517
                                        2021-02-18 19:23:39.775 - warn: mihome-vacuum.0 (3517) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        2021-02-18 19:23:39.776 - warn: mihome-vacuum.0 (3517) This object will not be created in future versions. Please report this to the developer.
                                        2021-02-18 19:23:39.845 - info: mihome-vacuum.0 (3517) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                        2021-02-18 19:23:39.863 - info: mihome-vacuum.0 (3517) Expert mode disabled, states deleded
                                        2021-02-18 19:23:39.863 - info: mihome-vacuum.0 (3517) Cloud control disabled
                                        2021-02-18 19:23:44.595 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                        2021-02-18 19:23:44.595 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                        2021-02-18 19:23:44.596 - info: mihome-vacuum.0 (3517) Got terminate signal TERMINATE_YOURSELF
                                        2021-02-18 19:23:44.597 - info: mihome-vacuum.0 (3517) terminating
                                        2021-02-18 19:23:44.597 - info: mihome-vacuum.0 (3517) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2021-02-18 19:23:45.109 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2021-02-18 19:23:47.618 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3532
                                        2021-02-18 19:23:47.922 - warn: mihome-vacuum.0 (3532) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        2021-02-18 19:23:47.922 - warn: mihome-vacuum.0 (3532) This object will not be created in future versions. Please report this to the developer.
                                        2021-02-18 19:23:47.982 - info: mihome-vacuum.0 (3532) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                        2021-02-18 19:23:47.999 - info: mihome-vacuum.0 (3532) Expert mode enabled, states created
                                        2021-02-18 19:23:48.000 - info: mihome-vacuum.0 (3532) Cloud control disabled
                                        2021-02-18 19:23:52.233 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 (force=false, process=true)
                                        2021-02-18 19:23:52.234 - info: host.Server stopInstance system.adapter.mihome-vacuum.0 send kill signal
                                        2021-02-18 19:23:52.235 - info: mihome-vacuum.0 (3532) Got terminate signal TERMINATE_YOURSELF
                                        2021-02-18 19:23:52.235 - info: mihome-vacuum.0 (3532) terminating
                                        2021-02-18 19:23:52.236 - info: mihome-vacuum.0 (3532) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                        2021-02-18 19:23:52.747 - info: host.Server instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                        2021-02-18 19:23:55.258 - info: host.Server instance system.adapter.mihome-vacuum.0 started with pid 3547
                                        2021-02-18 19:23:55.563 - warn: mihome-vacuum.0 (3547) Object mihome-vacuum.0.info.dnd is invalid: obj.common.type has an invalid value (switch) but has to be one of number, string, boolean, array, object, mixed, file, json
                                        2021-02-18 19:23:55.563 - warn: mihome-vacuum.0 (3547) This object will not be created in future versions. Please report this to the developer.
                                        2021-02-18 19:23:55.626 - info: mihome-vacuum.0 (3547) starting. Version 1.1.5 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.20.2, js-controller: 3.1.6
                                        2021-02-18 19:23:55.644 - info: mihome-vacuum.0 (3547) Expert mode enabled, states created
                                        2021-02-18 19:23:55.644 - info: mihome-vacuum.0 (3547) Cloud control disabled
                                        • S Schwabe
                                          D
                                          D
                                          dirkhe
                                          #1371
                                          @schwabe installiere den aktuellen Adapter, Stelle den Adapter mal auf debug und poste das hier. Denk dran, das es manchmal dauern kann, bis er sich connected. Oft hilft es auch, wenn man gleichzeitig in die mihome App geht
                                          83.9k
