  4. Test Adapter mihome-vacuum v2.0.x
xiaomiroborockmihome-vacuummap
1.5k Beiträge 144 Kommentatoren 785.0k Aufrufe 118 Beobachtet
    @bjoegibbard
    Bitte keine zerstückelten Screenshots posten sondern Log Texte auch als Text (in CodeTags) hier rein.
    B
    B
    bjoegibbard
    #1343
    2021-01-24 16:23:20.048  - info: mihome-vacuum.0 (5705) terminating
    2021-01-24 16:23:20.049  - info: mihome-vacuum.0 (5705) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    2021-01-24 16:23:20.721  - info: host.raspberrypi4-iob instance system.adapter.mihome-vacuum.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    2021-01-24 16:23:23.077  - info: host.raspberrypi4-iob instance system.adapter.mihome-vacuum.0 started with pid 6418
    2021-01-24 16:23:24.434  - debug: mihome-vacuum.0 (6418) Redis Objects: Use Redis connection: veraendert
    2021-01-24 16:23:24.471  - debug: mihome-vacuum.0 (6418) Objects client ready ... initialize now
    2021-01-24 16:23:24.474  - debug: mihome-vacuum.0 (6418) Objects create System PubSub Client
    2021-01-24 16:23:24.475  - debug: mihome-vacuum.0 (6418) Objects create User PubSub Client
    2021-01-24 16:23:24.477  - debug: mihome-vacuum.0 (6418) Objects client initialize lua scripts
    2021-01-24 16:23:24.504  - debug: mihome-vacuum.0 (6418) Objects connected to redis: veraendert
    2021-01-24 16:23:24.513  - debug: mihome-vacuum.0 (6418) objectDB connected
    2021-01-24 16:23:24.516  - debug: mihome-vacuum.0 (6418) Redis States: Use Redis connection: veraendert
    2021-01-24 16:23:24.527  - debug: mihome-vacuum.0 (6418) States create System PubSub Client
    2021-01-24 16:23:24.528  - debug: mihome-vacuum.0 (6418) States create User PubSub Client
    2021-01-24 16:23:24.540  - debug: mihome-vacuum.0 (6418) States connected to redis: veraendert
    2021-01-24 16:23:24.541  - debug: mihome-vacuum.0 (6418) statesDB connected
    2021-01-24 16:23:25.703  - info: mihome-vacuum.0 (6418) starting. Version 2.2.4 in /opt/iobroker/node_modules/iobroker.mihome-vacuum, node: v12.18.3, js-controller: 3.2.8
    2021-01-24 16:23:25.801  - debug: mihome-vacuum.0 (6418) load Map creator... true
    2021-01-24 16:23:25.803  - debug: mihome-vacuum.0 (6418) Xiaomi Cloud: Logging in
    2021-01-24 16:23:25.812  - info: mihome-vacuum.0 (6418) Expert mode enabled, states created
    2021-01-24 16:23:25.813  - info: mihome-vacuum.0 (6418) Cloud control disabled
    2021-01-24 16:23:25.827  - debug: mihome-vacuum.0 (6418) server started on veraendert
    2021-01-24 16:23:25.899  - info: mihome-vacuum.0 (6418) change states from State control.fan_power
    2021-01-24 16:23:25.900  - info: mihome-vacuum.0 (6418) extend state mop for State control.fan_power
    2021-01-24 16:23:25.901  - info: mihome-vacuum.0 (6418) New generation or new fw(3.5.8,002034) detected, create new states goto and zoneclean
    2021-01-24 16:23:25.910  - debug: mihome-vacuum.0 (6418) Receive <<< Helo <<< veraendert
    2021-01-24 16:23:25.911  - warn: mihome-vacuum.0 (6418) Time difference between Mihome Vacuum and ioBroker: 1 sec
    2021-01-24 16:23:25.911  - info: mihome-vacuum.0 (6418) connecting, this can take up to 10 minutes ...
    2021-01-24 16:23:25.913  - debug: mihome-vacuum.0 (6418) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    2021-01-24 16:23:25.919  - debug: mihome-vacuum.0 (6418) No suitable Lua script, fallback to keys!: function(doc) { if (doc.type === 'state') emit(doc._id, doc) }
    2021-01-24 16:23:25.936  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":1,"method":"get_status"}
    2021-01-24 16:23:25.945  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[{"msg_ver":3,"msg_seq":2614,"state":8,"battery":96,"clean_time":690,"clean_area":13170000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":0,"fan_power":104,"dnd_enabled":0,"map_status":1,"lock_status":0}],"id":1}
    2021-01-24 16:23:25.948  - debug: mihome-vacuum.0 (6418) sendTo "getStatus" to system.adapter.mihome-vacuum.0 from system.adapter.mihome-vacuum.0
    2021-01-24 16:23:25.965  - info: mihome-vacuum.0 (6418) Connected
    2021-01-24 16:23:26.167  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":2,"method":"miIO.info"}
    2021-01-24 16:23:26.169  - debug: mihome-vacuum.0 (6418) Next WiFi check: 24.01 16:24
    2021-01-24 16:23:26.179  - debug: mihome-vacuum.0 (6418) Receive <<< {"partner_id":"","id":2,"code":0,"message":"ok","result":{"hw_ver":"Linux","fw_ver":"3.5.8_002034","ap":{"ssid":"veraendert","bssid":"veraendert","rssi":-23},"netif":{"localIp":"veraendert","mask":"veraendert","gw":"veraendert"},"miio_ver":"miio-client 3.5.8","model":"roborock.vacuum.s5","mac":"veraendert","token":"veraendert","life":47353}}
    2021-01-24 16:23:26.367  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":3,"method":"get_sound_volume"}
    2021-01-24 16:23:26.373  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[100],"id":3}
    2021-01-24 16:23:26.377  - info: mihome-vacuum.0 (6418) set nächster Timer: Nicht verfügbar
    2021-01-24 16:23:26.567  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":4,"method":"get_consumable"}
    2021-01-24 16:23:26.574  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[{"main_brush_work_time":11011,"side_brush_work_time":11011,"filter_work_time":11011,"filter_element_work_time":0,"sensor_dirty_time":11011}],"id":4}
    2021-01-24 16:23:26.768  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":5,"method":"get_clean_summary"}
    2021-01-24 16:23:26.777  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[1662944,24087925000,1159,[1611500298,1611498316,1611498123,1611497130,1611492488,1611492296,1611492277,1611492234,1611491816,1611423950,1611423782,1611422676,1611416509,1611402090,1610826971,1610824848,1610819714,1610793254,1610793182,1610793133]],"id":5}
    2021-01-24 16:23:26.782  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":6,"method":"get_clean_record","params":[1611500298]}
    2021-01-24 16:23:26.795  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[[1611500298,1611501039,690,13170000,0,0,2,1]],"id":6}
    2021-01-24 16:23:26.968  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":7,"method":"get_carpet_mode"}
    2021-01-24 16:23:26.970  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":8,"method":"get_room_mapping"}
    2021-01-24 16:23:26.976  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}],"id":7}
    2021-01-24 16:23:26.978  - info: mihome-vacuum.0 (6418) create state for carpet_mode
    2021-01-24 16:23:26.981  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[],"id":8}
    2021-01-24 16:23:26.982  - debug: mihome-vacuum.0 (6418) Empty array try to get from Map
    2021-01-24 16:23:26.983  - debug: mihome-vacuum.0 (6418) get rooms from map
    2021-01-24 16:23:26.984  - debug: mihome-vacuum.0 (6418) get rooms from map pending...
    2021-01-24 16:23:26.990  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":9,"method":"get_clean_record","params":[1611498316]}
    2021-01-24 16:23:26.999  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[[1611498316,1611498317,0,0,0,0,2,1]],"id":9}
    2021-01-24 16:23:27.167  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":10,"method":"get_map_v1"}
    2021-01-24 16:23:27.173  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":["retry"],"id":10}
    2021-01-24 16:23:27.193  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":11,"method":"get_clean_record","params":[1611498123]}
    2021-01-24 16:23:27.205  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[[1611498123,1611498170,40,602500,0,0,2,1]],"id":11}
    2021-01-24 16:23:27.394  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":12,"method":"get_clean_record","params":[1611497130]}
    2021-01-24 16:23:27.404  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[[1611497130,1611497739,602,11325000,0,0,2,1]],"id":12}
    2021-01-24 16:23:27.596  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":13,"method":"get_clean_record","params":[1611492488]}
    2021-01-24 16:23:27.602  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":[[1611492488,1611492494,5,0,0,0,2,1]],"id":13}
    2021-01-24 16:23:27.675  - debug: mihome-vacuum.0 (6418) sendMsg[1] >>> {"id":14,"method":"get_map_v1"}
    2021-01-24 16:23:27.676  - debug: mihome-vacuum.0 (6418) 0. Mappointer_nomap___retry
    2021-01-24 16:23:27.688  - debug: mihome-vacuum.0 (6418) Receive <<< {"result":["robomap%veraendert"],"id":veraendert}
    2021-01-24 16:23:27.688  - debug: mihome-vacuum.0 (6418) Mappointer_updated
    • haselchenH haselchen
      @bjoegibbard
      Keine Fehlermeldung. Scheint alles okay zu sein?!
      Was steht jetzt im Ordner Map?
      Und wie @Thomas-Braun schrieb, bitte in Code Tags.
      B
      B
      bjoegibbard
      #1344
      @haselchen
      Jo, habe es mal fix im code tag gepostet.
      Hat sich nicht verändert.
      Aber wie gesagt get device geht irgendwie immer noch nicht :/
      • haselchenH
        haselchenH
        haselchen
        #1345
        @bjoegibbard
        Da meine Kräfte langsam schwinden, hilft es vielleicht nur noch den Entwickler zu fragen
        @Meistertr
          @bjoegibbard
          @Meistertr
          B
          B
          bjoegibbard
          #1346
          @haselchen
          Danke euch dennoch erstmal!
          • B bjoegibbard
            @haselchen
            haselchenH
            haselchenH
            haselchen
            #1347
            @bjoegibbard
            Ich denke das hakt an irgendeiner Einstellung.
            Adapter Einstellungen hatte ich ja gepostet, die solltest du auch so haben.
            Bleiben nur noch die App Einstellungen.
            Da müsste man Stück für Stück alles durchgehen. Aber das kriege ich heute nicht mehr hin.
            • B
              B
              bjoegibbard
              schrieb am zuletzt editiert von bjoegibbard
              #1348
              @haselchen
              Mir ist gerade noch ein Fehler aufgefallen.
              Egal welchen adapter ich update. Ich bekomme immer eine sehr ähnliche Fehlermeldung:
              Update web from @3.0.12 to @3.2.3
              host.raspberrypi4-iob Adapter "system.adapter.web.0" is stopped.
              NPM version: 6.14.6npm install iobroker.web@3.2.3 --loglevel error --prefix "/opt/iobroker" (System call)
              In file included from ../authenticate_pam.cc:23:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
              ../authenticate_pam.cc: In function ‘void after_doing_auth(uv_work_t*, int)’:../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~../authenticate_pam.cc:107:87: warning: ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated [-Wdeprecated-declarations]   Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(m->callback), 1, args);        ^In file included from ../authenticate_pam.cc:23:../../nan/nan.h:1026:46: note: declared here   NAN_DEPRECATED inline v8::Local<v8::Value> MakeCallback(                                              ^~~~~~~~~~~~
              ../authenticate_pam.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Authenticate(Nan::NAN_METHOD_ARGS_TYPE)’:../authenticate_pam.cc:147:83: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   Local<Value> res = options->Get(Nan::New<String>("serviceName").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:150:69: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    serviceName->WriteUtf8(m->serviceName, sizeof(m->serviceName) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:152:69: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]   res = options->Get(Nan::New<String>("remoteHost").ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../authenticate_pam.cc:155:66: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’    remoteHost->WriteUtf8(m->remoteHost, sizeof(m->remoteHost) - 1);        ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:160:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  username->WriteUtf8(m->username, sizeof(m->username) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc:161:58: error: no matching function for call to ‘v8::String::WriteUtf8(char [128], unsigned int)’  password->WriteUtf8(m->password, sizeof(m->password) - 1);                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:67,                 from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’   int WriteUtf8(Isolate* isolate, char* buffer, int length = -1,       ^~~~~~~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’../authenticate_pam.cc: At global scope:../authenticate_pam.cc:170:11: error: variable or field ‘init’ declared void void init(Handle<Object> exports) {           ^~~~~~../authenticate_pam.cc:170:11: error: ‘Handle’ was not declared in this scope
              ../authenticate_pam.cc:170:11: note: suggested alternative: ‘rand_r’ void init(Handle<Object> exports) {           ^~~~~~           rand_r../authenticate_pam.cc:170:24: error: expected primary-expression before ‘>’ token void init(Handle<Object> exports) {                        ^../authenticate_pam.cc:170:26: error: ‘exports’ was not declared in this scope void init(Handle<Object> exports) {                          ^~~~~~~
              In file included from ../../nan/nan.h:56,                 from ../authenticate_pam.cc:23:../authenticate_pam.cc:175:31: error: ‘init’ was not declared in this scope NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
              ../authenticate_pam.cc:175:31: note: suggested alternative: ‘int’ NODE_MODULE(authenticate_pam, init);                               ^~~~/home/iobroker/.cache/node-gyp/12.18.3/include/node/node.h:608:36: note: in definition of macro ‘NODE_MODULE_X’       (node::addon_register_func) (regfunc),                          \                                    ^~~~~~~../authenticate_pam.cc:175:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(authenticate_pam, init); ^~~~~~~~~~~
              make: *** [authenticate_pam.target.mk:109: Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
              gyp ERR! build error
              gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)
              gyp ERR! stack     at ChildProcess.emit (events.js:315:20)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
              gyp ERR! System Linux 5.4.51-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pamgyp ERR! node -v v12.18.3gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
              Könnte es auch daran liegen?
              Hier habe ich als beispiel mal den web adapter geupdated.
              Die Anleitung habe ich jetzt auch noch ausprobiert, ohne Erfolg:
              https://gitmemory.com/issue/iobroker-community-adapters/ioBroker.mihome-vacuum/206/752936194
              Ich bin auch noch durch die App gegangen. Da scheint mir alles richtig :(
              • B bjoegibbard
                @haselchen
                Thomas BraunT
                Thomas BraunT
                Most Active Developer
                #1349
                @bjoegibbard sagte in Test Adapter mihome-vacuum v2.0.x:
                authenticate_pam
                Schau mal ob libpam0g-dev und/oder libreadline-dev installiert ist:
                apt policy libpam0g-dev libreadline-dev
                  authenticate_pam
                  B
                  B
                  bjoegibbard
                  #1350
                  libpam0g-dev:
                    Installiert:           1.3.1-5+rpt2
                    Installationskandidat: 1.3.1-5+rpt2
                    Versionstabelle:
                   *** 1.3.1-5+rpt2 500
                          500 http://archive.raspberrypi.org/debian buster/main armhf Packages
                       1.3.1-5 500
                  libreadline-dev:
                    Installiert:           (keine)
                    Installationskandidat: 7.0-5
                    Versionstabelle:
                       7.0-5 500
                  libreadline-dev scheint zu fehlen?
                  • B bjoegibbard
                    libpam0g-dev:
                      Versionstabelle:
                         1.3.1-5 500
                    libreadline-dev:
                      Versionstabelle:
                         7.0-5 500
                    Thomas BraunT
                    Thomas BraunT
                    #1351
                    @bjoegibbard Nicht unbedingt.
                    Kannst du aber mal nachinstallieren.
                    Und ich würde node auf Stand bringen.
                    sudo apt update
                    sudo apt dist-upgrade
                    sudo reboot
                    (Wenn es schon sauber installiert war...)
                      sudo apt update
                      sudo reboot
                      B
                      B
                      bjoegibbard
                      #1352
                      danke, habe alles ausgeführt. Aber leider keine Besserung.
                      • B bjoegibbard
                        Thomas BraunT
                        Thomas BraunT
                        #1353
                        @bjoegibbard
                        which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
                        cd /opt/iobroker
                        npm cache clean --force
                        npm install authenticate-pam
                          @bjoegibbard
                          cd /opt/iobroker
                          B
                          B
                          bjoegibbard
                          #1354
                          /usr/bin/nodejs
                          v12.20.1
                          /usr/bin/node
                          v12.20.1
                          /usr/bin/npm
                          6.14.10
                          nodejs:
                            Installiert:           12.20.1-1nodesource1
                            Installationskandidat: 12.20.1-1nodesource1
                            Versionstabelle:
                           *** 12.20.1-1nodesource1 500
                                  500 https://deb.nodesource.com/node_12.x buster/main armhf Packages
                               10.23.1~dfsg-1~deb10u1 500
                          /opt/iobroker $ npm cache clean --force
                          npm WARN using --force I sure hope you know what you are doing.
                          > authenticate-pam@1.0.2 install /opt/iobroker/node_modules/authenticate-pam
                          > node-gyp rebuild
                          make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird betreten
                            CXX(target) Release/obj.target/authenticate_pam/authenticate_pam.o
                          In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8-internal.h:14,
                                           from /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:27,
                                           from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
                          /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:3553:51: note: declared here
                          /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’
                          In file included from /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:67,
                          /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note: candidate: ‘int v8::String::WriteUtf8(v8::Isolate*, char*, int, int*, int) const’
                          /home/iobroker/.cache/node-gyp/12.20.1/include/node/v8.h:2878:7: note:   no known conversion for argument 1 from ‘char [128]’ to ‘v8::Isolate*’
                                     rand_r
                          /home/iobroker/.cache/node-gyp/12.20.1/include/node/node.h:737:36: note: in definition of macro ‘NODE_MODULE_X’
                          make: Verzeichnis „/opt/iobroker/node_modules/authenticate-pam/build“ wird verlassen
                          gyp ERR! stack     at ChildProcess.emit (events.js:314:20)
                          gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:276:12)
                          gyp ERR! System Linux 5.4.83-v7l+
                          gyp ERR! node -v v12.20.1
                          gyp ERR! not ok
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.1 (node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman-converters/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/chokidar/node_modules/fsevents):
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.13 (node_modules/zigbee-herdsman/node_modules/fsevents):
                          npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.13: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                          npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/zigbee-herdsman/node_modules/jest-haste-map/node_modules/fsevents):
                          npm ERR! code ELIFECYCLE
                          npm ERR! errno 1
                          npm ERR! authenticate-pam@1.0.2 install: `node-gyp rebuild`
                          npm ERR! Exit status 1
                          npm ERR!
                          npm ERR! Failed at the authenticate-pam@1.0.2 install script.
                          npm ERR!     /home/iobroker/.npm/_logs/2021-01-24T16_44_12_411Z-debug.log
                          pi@raspberrypi4-iob:/opt/iobroker $
                          da ist wieder dieser doofe gyp ERR! -.-
                          • B bjoegibbard
                            /usr/bin/nodejs
                            v12.20.1
                            /usr/bin/node
                            v12.20.1
                            /usr/bin/npm
                            6.14.10
                            nodejs:
                              Versionstabelle:
                            > node-gyp rebuild
                                       rand_r
                            gyp ERR! not ok
                            npm ERR! errno 1
                            npm ERR!
                            Thomas BraunT
                            Thomas BraunT
                            #1355
                            @bjoegibbard
                            authenticate_pam
                            Keine Ahnung. Vielleicht baut das Modul nicht mehr gegen aktuelle node-Versionen. Das ist ja schon über ein Jahr nicht mehr angefasst worden.
                            Welcher Adapter braucht das Ding eigentlich?
                            npm list authenticate-pam
                            Dürfte der terminal-Adapter sein. Braucht eh keiner.
                            iobroker del terminal
                            cd /opt/iobroker
                            Danach sollte Ruhe von der Seite sein.
                            N 1 Antwort Letzte Antwort
                              @bjoegibbard
                              authenticate_pam
                              cd /opt/iobroker
                              N
                              N
                              nu_81
                              schrieb am zuletzt editiert von nu_81
                              #1356
                              Hatte lange Zeit ein ioBroker (mit altem Stand ohne Updates einzuspielen) auf einem Igel laufen
                              mit dem ich meinen S50 per Szene gesteuert habe.
                              Konkret hatte ich eine Szene "MAP_EG_Laden" erstellt.
                              Hierin wurde per SSH auf dem Roborock die Map Dateien getauscht und anschließend kurz gestartet und pausiert um die Karten auch wirklich zu laden.
                              Diese Szene habe ich dann vor jede andere Szene gepackt um dann die einzelnen Zonen anzufahren:
                              Das hat auch immer zuverlässig funktioniert.
                              Habe nun auf einen Raspberry mit aktueller Version gewechselt und da klappt es leider nicht mehr.
                              Immer wieder erscheint die Meldung
                              "should trigger cleaning all , but is currently active(5). Add to queue"
                              Der S50 reagiert dann auch überhaupt nicht, wenn ich z.B. Start auf true setze.
                              Muss ich z.B. den Pause Befehl manuell wieder auf false setzten um z.B. die Zonenreinigung zu starten?
                              Manchmal funktioniert es wieder wenn ich vor den Befehlen den "Home" Befehl mit rein nehme.
                              Es scheint eine neue Funktion der Queue zu geben, die ich hier scheinbar falsch bediene.
                              Das hier funktioniert z.B. manchmal:
                              Hier noch der obere Teil im aufgeklappten Zustand:
                              Aber auch hier kommt manchmal die Meldung mit der Queue.
                              Habe auch schon mal versucht "clearQueue" auf true zwischendurch einzusetzen. Aber auch das hilft nicht.
                              Leider verstehe ich da das Konzept der Queue auch nicht so recht.
                              Kann man die Queue Funktion irgendwie abschalten?
                              Wie kann ich die Queue eventuell löschen um den S50 zu "befreien" sodass er wieder Befehle annimmt?
                              Wie sollte ich hier am besten vorgehen um es wieder wie vorher zum laufen zu bekommen?
                              Gruß Nu
                              • N nu_81
                                Gruß Nu
                                D
                                D
                                dirkhe
                                #1357
                                @nu_81 die queue ist dafür da, dass du einfach mehrere Räume starten kannst unser die dann nacheinander abarbeitet.
                                Wenn er nicht startet hat er eher verbindindungsprobleme. Sobald er wieder verbunden ist, sollte er starten.
                                • D dirkhe
                                  N
                                  N
                                  nu_81
                                  #1358
                                  Glaube nicht dass es Verbindungsprobleme sind.
                                  Er reagiert z.B. überhaupt nicht auf start, gibt stattdessen die Meldung ins Log.
                                  Auf z.B. auf Home oder "Wo bist du" reagiert er sofort.
                                  • N nu_81
                                    D
                                    D
                                    dirkhe
                                    #1359
                                    @nu_81 dann stell den adapter mal auf debug und poste das Log hier.
                                    • D dirkhe
                                      S
                                      S
                                      Sweatchuck
                                      #1360
                                      kurze Frage...
                                      Meine beiden Robrock (S5 und S6) wollen ein Firmware-Update durchführen.
                                      Von Version 3.5.8_2076 auf 3.5.8_2652 beim S6 bzw. 3.5.7_002008 auf 3.5.8_002034.
                                      Da momentan aber alles super funktioniert will ich nicht einfach ein Update fahren und deshalb mal nachfragen ob jemand von euch Erfahrungen dies bzgl. hat. Angeblich handelt es sich dabei nur ein Bugfix?!
                                      Beste Grüße
                                      • JackDanielJ
                                        JackDanielJ
                                        JackDaniel
                                        #1361
                                        keine probleme hier
                                        Carpe diem
                                        • S Sweatchuck
                                          kurze Frage...
                                          Beste Grüße
                                          #1362
                                          @sweatchuck
                                          nee, meine 4 auch, mach doch mal, dann wissen wir ja, obs dann noch geht.. :-)
                                          84.1k
