  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • R rehmosch
    Servus,
    hat jemand eine Idee?```
    fb-checkpresence.0 2021-01-25 10:52:23.830 warn (28990) createMemberObjects: "no family members defined! Objects are not created!"
    fb-checkpresence.0 2021-01-25 10:52:23.829 info (28990) createGlobalObjects finished successfully
    fb-checkpresence.0 2021-01-25 10:52:23.764 info (28990) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0 2021-01-25 10:52:23.762 info (28990) terminating
    fb-checkpresence.0 2021-01-25 10:52:23.761 info (28990) cleaned everything up ...
    fb-checkpresence.0 2021-01-25 10:52:23.759 info (28990) Got terminate signal TERMINATE_YOURSELF
    fb-checkpresence.0 2021-01-25 10:52:23.458 warn (28990) chkService: "can not get services!"
    fb-checkpresence.0 2021-01-25 10:52:23.457 warn (28990) chkService: "can not get services!"
    fb-checkpresence.0 2021-01-25 10:52:23.456 warn (28990) chkService: "can not get services!"
    fb-checkpresence.0 2021-01-25 10:52:23.455 warn (28990) chkService: "can not get services!"
    fb-checkpresence.0 2021-01-25 10:52:23.454 warn (28990) chkService: "can not get services!"
    fb-checkpresence.0 2021-01-25 10:52:23.453 warn (28990) chkService: "can not get services!"
    fb-checkpresence.0 2021-01-25 10:52:23.452 warn (28990) chkService: "can not get services!"
    fb-checkpresence.0 2021-01-25 10:52:23.451 warn (28990) chkService: "can not get services!"
    fb-checkpresence.0 2021-01-25 10:52:23.446 error (28990) Can not get services! Adapter stops
    fb-checkpresence.0 2021-01-25 10:52:23.446 error (28990) getServices: {"message":"connect ETIMEDOUT 192.168.1.1:49000","name":"Error","stack":"Error: connect ETIMEDOUT 192.168.1.1:49000\n at TCPConnectWrap.afterConnect [as oncomplete] (net.js:110
    fb-checkpresence.0 2021-01-25 10:50:10.165 info (28990) start fb-checkpresence: ip-address: "192.168.1.1" - interval devices: 1 Min. - interval members: 60 s
    fb-checkpresence.0 2021-01-25 10:50:10.084 info (28990) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.23.1, js-controller: 3.2.7
    fb-checkpresence.0 2021-01-25 10:50:02.871 info (26596) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0 2021-01-25 10:50:02.870 info (26596) terminating
    fb-checkpresence.0 2021-01-25 10:50:02.868 error (26596) onUnload: TypeError: Cannot read property 'exitRequest' of null
    fb-checkpresence.0 2021-01-25 10:50:02.866 info (26596) Got terminate signal TERMINATE_YOURSELF
    fb-checkpresence.0 2021-01-25 10:48:59.067 info (26596) start fb-checkpresence: ip-address: "192.168.1.1" - interval devices: 1 Min. - interval members: 60 s
    fb-checkpresence.0 2021-01-25 10:48:59.019 info (26596) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.fb-checkpresence, node: v10.23.1, js-controller: 3.2.7
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    schrieb am zuletzt editiert von afuerhoff
    #335
    @rehmosch
    Ist die Fritzbox richtig konfiguriert?
    Tr064 Unterstützung, User eingerichtet, ...
    Es scheint überhaupt kein Zugriff auf die Fritzbox möglich zu sein.
    R 1 Antwort Letzte Antwort
    • afuerhoffA afuerhoff
      @rehmosch
      rehmosch
      #336
      @afuerhoff Danke hat geklappt ;) Musste beide Adapter nochmals installieren, doch erst nach 10 Minuten (nach der Installation) waren keine Fehlermeldungen mehr da ;)
      RP4/Conbee II/Pihilips Hue/HarmonyHub/Sonos/Alexa/Aqara Sensoren/Tradfri/ZigbeeThermostate/Xiaomi Saugroboter/Smarte Türklingel & Briefkasten ...
      • GrizzelbeeG Grizzelbee
        @flo1988 sagte in Test Adapter fb-checkpresence v1.1.x:
        War er, wie der Name sagt, nicht irgendwie als Anwesenheitsadapter gedacht?
        Eigentlich könnte man den Adapter auch so langsam "Zeige mir alle Infos der FritzBox an" nennen...
        Die Frage kam kürzlich (glaube ich) schon einmal auf... und ich bin da komplett bei @Flo1988.
        Ich bin zwar auch nur Nutzer des Adapters, fände es aber auch sauberer wenn der Adapter sich wieder auf das konzentrieren würde wofür er eigentlich gedacht ist/war. Klein, schlank, übersichtlich, schnell. Alles, was nicht mit der Anwesenheitskontrolle zu tun hat, könnte dann ja vielleicht in den TR-064 Adapter überführt werden.
        Oder - alternativ - tatsächlich die Umbenennung in "FritzBox 2.0" Adapter. Oder "FritzBox ehanced", oder, oder, oder ... dann ggf. vielleicht mit Freischaltung gewünschter Feature-Gruppen über die Config.
        [] Presence Check
        [] Fritzbox external connection information
        [] Fritzbox internel connection information
        [] Fritzbox Devices information
        [] Call Monitor
        @afuerhoff Verstehe mich um Gottes Willen bitte nicht falsch: Ich entwickel selber drei Adapter und weiß nur zu gut wie viel Arbeit da drin steckt und womit man so alles kämpft. Ich weiß deine Arbeit also wirklich zu schätzen und profitiere ja selber davon. Aber ... der Adaptername und die angebotenen Features passen wirklich nicht mehr so richtig zusammen. Und warum nicht dein Wissen und deine Erfahrungen mit in den TR-064 einbringen? Ich könnte mir gut vorstellen, das man dir da nur zu gerne die Federführung überlassen würde. ;)
        viele Grüße
        grizzelbee
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        #337
        @grizzelbee sagte in Test Adapter fb-checkpresence v1.1.x:
        Hallo, ich hab da die letzten Tage auch drüber nachgedacht. Auf der einen Seite gibt es User Wünsche, die man gerne erfüllen würde und auf der anderen Seite verändert sich dadurch aber der Fokus des Adapters. Eine Zwickmühle. Ich hab den Adapter mal angefangen um mich mit einem bekannten Thema in die Adapterentwicklung und auch in Javascript einzuarbeiten. Ich war selbst überrascht, wie viele inzwischen den Adapter nutzen.
        Ich denke, ich werde die Adapterentwicklung wieder auf die Hauptfunktionen konzentrieren. Das hilft auch mir, da ich nur begrenzt Zeit für die Entwicklung habe.
        Ich hoffe, dass dadurch einige von den Usern nicht enttäuscht sind.
        Viele Grüße
        Achim
        PS: Alles was drin ist, bleibt natürlich im Adapter und in der Konfiguration werde ich einzelne Funktionalitäten konfigurierbar machen.
        Pedder007P L 2 Antworten Letzte Antwort
          Viele Grüße
          Achim
          Pedder007P Offline
          Pedder007P Offline
          Pedder007
          #338
          @afuerhoff
          Ich finde der Adapter ist echt klasse geworden - so als Mini-NW/FB-Überwachung - gerade während des Homeschoolings mit 3 Kids ... ;-)
          ... verstehe aber, wenn es dann nun wahrscheinlich auch genug des Guten ist :-)
          Pedder
          All @Proxmox/Trixie auf HP Elitedesk 800 G4; Zigbee: ZigStar (LAN), ~110Devices
          Unifi, Motioneye/3Reolinks, PiHole, Bosch CS7800i via BBQKees/EMS-ESP, Fronius/BYD 11kWp via Modbus
          Under construction: Smart-WoMo auf Raspi4
          • afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #339
            Eine Frage noch zu der neuen Funktionalität der Hilfe Funktion in der Adapter Konfiguration (Danke an @Mic für die aus meiner Sicht tolle Idee im Smart Control Adapter).
            Wie gefällt euch die?
            ? Pedder007P 2 Antworten Letzte Antwort
              #340
              @afuerhoff super, ich fands bei MICs Adapter schon toll, denn endlich ist die Hilfe da, wo sie sein soll.
              Muss man halt auch lesen und drauf klicken... :-)
              afuerhoffA sigi234S 2 Antworten Letzte Antwort
                afuerhoffA Offline
                afuerhoffA Offline
                afuerhoff
                #341
                @ilovegym
                Ich denke damit könnte ich die Tooltips in der Konfig abschalten. Oder was meint ihr.
                sigi234S ? GrizzelbeeG 3 Antworten Letzte Antwort
                  @ilovegym
                  sigi234S Online
                  sigi234S Online
                  #342
                  @afuerhoff sagte in Test Adapter fb-checkpresence v1.1.x:
                  @ilovegym
                    Pedder007P Offline
                    Pedder007P Offline
                    Pedder007
                    #343
                    @afuerhoff hatte bisher immer alles per Try-and Error konfiguriert, aber die Hilfe sieht sehr gut aus! ... hätte ich die mal früher gesehen ;-)
                    Pedder
                      sigi234S Online
                      sigi234S Online
                      #344
                      @ilovegym sagte in Test Adapter fb-checkpresence v1.1.x:
                      Jupp, darum würde ich die Hintergrund Farbe oder Schrift ändern ( Orange - Lime ? )
                        @ilovegym
                        #345
                        @afuerhoff nee nicht die Tooltips... ich mag die.. :-)
                          @ilovegym
                          GrizzelbeeG Offline
                          GrizzelbeeG Offline
                          Grizzelbee
                          schrieb am zuletzt editiert von Grizzelbee
                          #346
                          @ilovegym
                          Du kannst sie auch einfach drunter schreiben. So mache ich das immer:
                          Index_m.html:
                                 <!-- For example columns with settings: -->
                                  <div class="row">
                                      <div class="input-field col s12 m4">
                                          <input class="value" id="email" type="text">
                                          <label for="email" class="translate">Lbl_email</label>
                                          <span class="translate">email_desc</span>
                                      </div>
                                          <input class="value" id="Password" type="password" maxlength="32">
                                          <label for="Password" class="translate">Lbl_Password</label>
                                          <span class="translate">password_desc</span>
                                      </div>
                          Übersetzung dann über i18n und gulp:
                          i18n/en/translate.json:
                              "Celsius": "Celsius",
                              "Fahrenheit": "Fahrenheit",
                              "Kelvin": "Kelvin",
                              "Lbl_Password": "Password",
                              "Lbl_country": "Country code",
                              "Lbl_email": "eMail",
                              "Lbl_temperatureUnit": "Temperature unit",
                              "Poll_Interval": "Poll interval",
                              "Poll_Interval_desc": "Request new status and sensor information from devices every X seconds.",
                              "country_desc": "ISO-Code of the country you created your dyson Account in.",
                              "email_desc": "email address of your dyson account.",
                              "password_desc": "Password of your dyson account.",
                              "temperatureUnit_desc": "Unit to display the temperature."
                          Ich würde beides machen. Die Infos ergänzen sich ja und ersetzen sich nicht völlig.
                            @ilovegym
                            Index_m.html:
                                    <div class="row">
                                        </div>
                                        </div>
                                "Kelvin": "Kelvin",
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            #347
                            @grizzelbee
                            Danke für den Vorschlag. Schaue ich mir mal an.
                            • F Flo1988
                              Rückmeldung zur Beta:
                              Hab die Neuste 1.1.2 von GitHub gestern geladen und läuft bisher ohne Probleme.
                              Allerdings nutze ich nur die Anwesenheitskontrolle der Familienmitglieder mit 10s Abfrageintervall.
                              Die Aktualisierung der Objekte nur noch bei Änderung scheint auch zu klappen.
                              Ich glaube weiter oben die Frage gelesen zu haben, ob es nicht möglich wäre eine Verzögerung einzubauen, da die Geräte öfters mal die Verbindung verlieren.
                              Ich nutze die Anwesenheitskontrolle für meine Alarmanlage, zur Steuerung der Heizung, etc.
                              Bisher hatte ich den TR064 Adapter, das Objekt "Presence" und "AbsenceAll" von fb-checkpresence ist hier aber viel besser und macht die Scripte kleiner.
                              Leider habe ich auch das Problem, dass mehrfach pro Tag beide iPhones gleichzeitig die Verbindung verlieren und kurzzeitig die Alarmanlage aktiviert wird, bzw sich die Heizung abschaltet. Sehr ärgerlich!
                              Einerseits wäre es eine spitzenmäßige Funktion (Abwesenheit erst nach Einstellbarer Verzögerung) für den Adapter, andererseits finde ich hin jetzt schon so langsam etwas überladen und es kommen ja auch ständig neue Wünsche dazu...
                              Daher hier vielleicht für jeden der Probleme mit den Verbindungsabbrüchen hat, ein kleines Script, welches man sich dazwischen schalten kann um die ständigen Abbrüche los zu werden.
                              Zwei Variablen im javascript Ordner anlegen mit "Anwesenheit" und "Abwesenheit" oder ähnliches und folgendes als Blockly-Script:
                              Die Abwesenheit verzögert sich dadurch um 15sek, wenn man das Haus verlässt, die Anwesenheit wird aber sofort ohne Verzögerung erkannt.
                              Seit dem keine kurzzeitige Aktivierung der Alarmanlage mehr 😊
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              #348
                              Hallo, komme auf das Thema einmal zurück. Danke für die Idee/ Vorschlag.
                              Das Thema Verzögerung / Filterung hatte ich immer schon im Hinterkopf. Ich stelle mir das so vor das eine Anwesenheit sofort erkannt wird. Eine Abwesenheit aber nochmal nach einer gewissen Verzögerung überprüft wird. Damit kann man kurzfristige Abbrüche in der Verbindung herausfiltern. Die Filterung könnte man pro Familienmitglied einschalten. Die Verzögerungszeit kann für alle gleich konfiguriert werden.
                              Was haltet ihr davon?
                              ? J GrizzelbeeG F 4 Antworten Letzte Antwort
                                #349
                                @afuerhoff ja, das hört sich perfekt an!
                                  Jadi
                                  #350
                                  @afuerhoff sehr gute Idee, wollte die Funktion schon über ein Skript lösen.
                                    GrizzelbeeG Offline
                                    GrizzelbeeG Offline
                                    Grizzelbee
                                    #351
                                    Ich mache das bereits in einem Script um die Tür automatisch abzuschließen. Wenn PresenceAll auf false gegangen ist, warte ich zwei Minuten um prüfe dann noch einmal. Wenn dann immernoch alle weg sind, schließe ich ab.
                                    Viel Mehr Aufwand würde ich da aber nicht reinstecken. Die FB hat nun mal das Problem, dass sie immer mal wieder kurzzeitig die Verbindungen verliert. Das nervt einfach. Die Idee für den Puffer und eine konfigurierbare Zeit finde ich gut - aber da es ein generalles FB-Probelm ist, würde ich das nicht komplizierter als nötig machen und es einfach immer bei Abwesenheit und für alle machen. Normalerweise reichen ja wenige Sekunden.
                                    FenriswolfF 1 Antwort Letzte Antwort
                                      FenriswolfF Offline
                                      FenriswolfF Offline
                                      Fenriswolf
                                      #352
                                      @afuerhoff
                                      Ich würd eine Verzögerung begrüßen, momentan ist es bei mir teilweise so, das die Alarmanlage meldet, das sie sich gleich aktiviert ... momentan habe ich da eine Verzögerung eingebaut, würde aber es aber besser finden, wenn das von der FB durch zeitversetzte Mehrfachprüfung abgefangen wird.
                                      in diesem Sinne .... bis denne
                                        Flo1988
                                        #353
                                        @afuerhoff
                                        Eine Verzögerung wäre spitzenmäßig!!!
                                        Ich habe weiter oben mein Script gepostet, welches ich aktuell einsetze.
                                        Davor hatte ich täglich zahlreiche ungewollte Abwesenheiten.
                                        Seit das Script läuft 0 und die Alarmanlage aktiviert sich trotzdem zuverlässig.
                                        Demnach reicht eine 15 Sekunden Verzögerung beim Gehen bereits aus um bei mir alle Verbindungsabbrüche zu filtern.
                                        Zu lange sollte sie auch nicht sein, da ich z.B. Fenster überwache und beim Gehen melde, wenn noch ein Fenster offen ist.
                                        Wenn man dann schon 2min mit dem Auto gefahren ist, ist es auch etwas spät...
                                        Es gibt aber auch sicher Anwender die es eher etwas träger wünschen, da vielleicht die WLAN Abdeckung im Haus nicht überall vorhanden ist.
                                        Eine einstellbare Verzögerung wäre sicher die beste Lösung.
                                        Bezüglich dem Punkt eine oder individuell für jedes Gerät würde es für meine Anwendungszwecke reichen eine für alle Geräte.
                                        Gibt es Anwendungsszenarien wo für jedes Gerät eine individuelle Verzögerung benötigt wird?
                                        Für die Anwesenheit würde ich auch keine Verzögerung einbauen.
                                        Es soll ja sofort erkannt werden, wenn jemand daheim ist (Thema Alarmanlage deaktivieren...).
                                        Gibt es Fälle bei denen eine kurze Anwesenheit gefiltert werden soll?
                                          Aktuelle Test Version 1.1.25
                                          Veröffentlichungsdatum 21.01.2023
                                          Github Link https://github.com/afuerhoff/ioBroker.fb-checkpresence
                                          npm im Latest verfügbar
                                          Hinweis: Adapter muss nach Installation von Github einmal neu gestartet werden.
                                          Änderungen:
                                          1.1.0
                                          • second interval for family members implemented
                                          • mesh info added
                                          • configuration validation added
                                          • switch on, off guest wlan
                                          • switch on, off internet access of devices
                                          • structural changes
                                          • code optimization
                                          • new datapoint absenceAll
                                          • neue Funktion Reboot
                                          1.1.1
                                          • Admin Konfiguration optimiert
                                          • Im Dateformat dürfen jetzt auch Bindestriche benutzt werden
                                          • https workaround implementiert (Konfiguration)-> es gab einen Fall, wo der Adapter nicht mit * https die Fritzbox abfragen konnte.
                                          • Connection check wurde optimiert
                                          • Dokumentation geändert
                                          • Mesh Handling optimiert -> es werden jetzt die Channels im Klartext angelegt. Dies verhindert, dass sich die Id's ändern.
                                          1.1.2
                                          • Gäste WLAN QR-Code ist als State implementiert und kann mit dem Basic Bool SVG Widget benutzt werden.
                                          • Die Presence states werden nur geändert, wenn es eine Änderung gibt.
                                          • Die Benutzerrechte des Users werden ausgelesen und mit den unterstützten Services der Fritzbox abgeglichen. Es muss der Service unterstützt werden und die Benutzerrechte zum Service passen. Ist dies nicht der Fall, werden nur die Funktionen ausgeführt, die dann möglich sind. Man kann also die Accessrights (FRITZ!Box Einstellungen, Smart Home, ...) in der Fritzbox reduzieren ohne Fehler zu bekommen. Im Log wird das beim Start einmal als Warnung ausgegeben.
                                          • Der Name des Devices kann jetzt ebenfalls genutzt werden. Hierfür muss das Familienmitglied genauso wie in der Fritzbox benannt werden. (Achtung: Wenn der Name nur in der Fritzbox manuell umbenannt wurde und nicht im Handy, dann wird bei eingeschalteter Mac-Verschleierung der Name des neu in der Fritzbox hinzugefügten Devices ein anderer sein)
                                          • active / inactive Device Zähler korrigiert
                                          • 10s Intervall Bug gefixed
                                          • Dokumentation angepasst
                                          • PresentGuests state eingebaut
                                          Änderungen 1.1.3:
                                          • Familiengruppen. Diese werden im Ordner familyMembers angelegt.
                                          • Kompatibilitätsmodus -> in Zukunft gibt es nur noch den presence state bei den Familienmitgliedern. Nicht mehr den auf der obersten Ebene am Familienmitglied.
                                          • In der Konfiguration habe ich noch ein paar Optionen aufgenommen
                                          • Die Dialogboxen habe ich optimiert
                                          • Ein Filter kann jetzt pro Familienmitglied eingeschaltet werden. Ist ein Familienmitglied true wird sofort der Status gesetzt. Bei false wird nach der Filterzeit nochmal auf den Wert geschaut und nur dann der Status gesetzt falls der Status ebenfalls false ist.
                                          • Für das Passwort Handling nutze ich jetzt die neue ioBroker Funktionalität
                                          • und diverse Änderungen unter der Haube
                                          ich habe eine neue Testversion auf Github hochgeladen. Bitte testet diese und gebt hier Rückmeldung über Probleme mit der neuen Version.
                                          Wichtigste Neuerungen sind das Ein- und Ausschalten des Gäste-WLAN. Das deaktivieren des Internetzugriffs von Geräten und ein zusätzliches Interval für Familienmitglieder.
                                          Die Eingaben auf der Konfigurationsseite werden jetzt überprüft und ggfs. das Speichern deakiviert. Im Bereich der fb-devices werden jetzt zusätzliche Mesh-Informationen angelegt, falls dies in der Konfiguration aktiviert wurde.
                                          Viel Spaß beim Testen.
                                          Gäste-WLAN ein-, ausschalten -> Datenpunkt wlan
                                          Internetzugriff ein-, ausschalten -> fb-devices Datenpunkt disabled = true (Internet aus)
                                          #354
                                          @afuerhoff
                                          Wenn Du dich mehr auf die Anwesenheitsfunktion des Adapters konzentrieren magst, dann haette ich folgende Vorschlaege, die ich gut gebrauchen koennte:
                                          a) Family Members
                                          - pro Person mehr Geraete zuweisen, erst wenn alle offline sind, ist das Member weg
                                          ( smartwatch, smartphone1, smartphone2 alles einer Person )
                                          • Zeitverzoegerung pro Member bei Absence and coming different
                                          b) neu: Family Groups
                                          • hier kann man Family Members einer Group zuordnen
                                          • sind alle in der Group weg, gilt die Group als absence
                                          • Idee dahinter: Ich habe ein Haus mit 3 Parteien, 3x2 Members, jetzt muesste ich mir den Adapter 3x installieren, was zu unnoetigen Traffic auf die Fritzbox fuehrt... es reicht, wenn das ein Adapter macht.
                                          Denke, wenn du schon umbaust, dann richtig :-)
                                          Was halten die anderen davon? Natuerlich alle Members und Groups mit den jetzt vorhandenen Datenpunkten.
                                          Stephan SchleichS afuerhoffA 2 Antworten Letzte Antwort
