  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • sigi234S sigi234
    @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
    @Fenriswolf @sigi234
    Ich habe ein Update hochgeladen. Bitte neu testen. Am Besten einmal die Objekte unter fb-devices löschen. Die sind falsch angelegt worden.
    Schaut wieder gut aus. Bis auf die Warn wegen Beta JS Controller.
    afuerhoffA Offline
    afuerhoffA Offline
    afuerhoff
    #272
    @sigi234
    Welche Warnungen meinst du ? Die vom Post oben?
    Hast Du die Objekte einmal gelöscht?
    • afuerhoffA afuerhoff
      @sigi234
      sigi234S Online
      sigi234S Online
      #273
      Ja
      Log:
      2021-01-14 21:51:08.500 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.name" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.link" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.rx_rcpi" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.501 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.CCU3.LAN.type" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.name" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.link" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.rx_rcpi" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_rx" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.cur_data_rate_tx" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.502 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Bad.WLAN.type" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.name" has no existing object, this might lead to an error in future versions
      2021-01-14 21:51:08.503 - warn: fb-checkpresence.0 (13616) State "fb-checkpresence.0.fb-devices.Dot-Buero.WLAN.link" has no existing object, this might lead to an error in future versions
      • sigi234S sigi234
        Ja
        Log:
        afuerhoffA Offline
        afuerhoffA Offline
        afuerhoff
        #274
        @sigi234
        Kannst Du mal ein Bild der entsprechenden Objekte posten. CCU3 sollte z.B. als Device angelegt sein.
          @sigi234
          sigi234S Online
          sigi234S Online
          #275
          @sigi234
          RAW Lan Name:
            "from": "system.adapter.fb-checkpresence.0",
            "user": "system.user.admin",
            "ts": 1610657469997,
            "common": {
              "name": "fb-devices.CCU3.LAN.name",
              "desc": "name of the interface",
              "role": "value",
              "type": "string",
              "def": "",
              "read": true,
              "write": false
            "native": {},
            "acl": {
              "object": 1636,
              "owner": "system.user.admin",
              "state": 1636
            "_id": "fb-checkpresence.0.fb-devices.CCU3.LAN.name",
            "type": "state"
          afuerhoffA R 2 Antworten Letzte Antwort
          • sigi234S sigi234
            @sigi234
            RAW Lan Name:
              "common": {
                "role": "value",
                "type": "string",
                "def": "",
                "read": true,
                "write": false
              "native": {},
              "acl": {
                "object": 1636,
                "state": 1636
              "type": "state"
            afuerhoffA Offline
            afuerhoffA Offline
            afuerhoff
            #276
            @sigi234
            Da verstehe ich die Meldung vom JS-Controller nicht. Ist doch als Objekt angelegt.
              FenriswolfF Offline
              FenriswolfF Offline
              Fenriswolf
              #277
              Werde ich morgen im Laufe des Tages testen und berichten.
                @sigi234
                sigi234S Online
                sigi234S Online
                #278
                @sigi234
                Ja, ist bei andere Adapter auch so.
                Neueste Meldung:
                fb-checkpresence.0	2021-01-14 22:42:56.416	error	(8292) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
                afuerhoffA 2 Antworten Letzte Antwort
                • sigi234S sigi234
                  @sigi234
                  Neueste Meldung:
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  #279
                  @sigi234
                  Kannst Du mal das Log vom Start an posten. Da kommen die Meldungen was alles unterstützt wird.
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    #280
                    @sigi234
                    fb-checkpresence.0	2021-01-14 23:06:34.085	debug	(9028) loopFamily ends after 5,187158400 s
                    fb-checkpresence.0	2021-01-14 23:06:33.426	debug	(9028) Handy-xxx: No history item before this day is available
                    fb-checkpresence.0	2021-01-14 23:06:33.426	debug	(9028) history Handy-xxx cntHistory: 15421
                    fb-checkpresence.0	2021-01-14 23:06:33.230	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:06:33.230	debug	(9028) history cntActualDay: 15422
                    fb-checkpresence.0	2021-01-14 23:06:33.059	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:06:32.102	debug	(9028) Handy-Ilse: No history item before this day is available
                    fb-checkpresence.0	2021-01-14 23:06:32.102	debug	(9028) history Handy-xxxx cntHistory: 15424
                    fb-checkpresence.0	2021-01-14 23:06:31.869	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:06:31.869	debug	(9028) history cntActualDay: 15425
                    fb-checkpresence.0	2021-01-14 23:06:31.622	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:06:30.784	debug	(9028) Handy-xxxxxx: No history item before this day is available
                    fb-checkpresence.0	2021-01-14 23:06:30.783	debug	(9028) history Handy-xxxxxx cntHistory: 15422
                    fb-checkpresence.0	2021-01-14 23:06:30.410	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:06:30.409	debug	(9028) history cntActualDay: 15423
                    fb-checkpresence.0	2021-01-14 23:06:29.928	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:06:29.904	debug	(9028) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.99","MACAddress":"xxxxxxxxxx","Active":"1","HostName":"CCU3","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE_Speed":"1000",
                    fb-checkpresence.0	2021-01-14 23:05:37.540	info	(9028) createFbDeviceObjects finished successfully
                    fb-checkpresence.0	2021-01-14 23:05:36.457	debug	(9028) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.99","MACAddress":"xxxxxxx","Active":"1","HostName":"CCU3","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE_Speed":"1000",
                    fb-checkpresence.0	2021-01-14 23:05:35.845	debug	(9028) system.adapter.admin.0: logging true
                    fb-checkpresence.0	2021-01-14 23:05:35.693	info	(9028) createMemberObjects finished successfully
                    fb-checkpresence.0	2021-01-14 23:05:35.688	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:05:35.594	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:05:35.461	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
                    fb-checkpresence.0	2021-01-14 23:05:35.367	info	(9028) createGlobalObjects finished successfully
                    fb-checkpresence.0	2021-01-14 23:05:35.159	debug	(9028) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
                    fb-checkpresence.0	2021-01-14 23:05:35.152	info	(9028) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.148	info	(9028) service DeviceConfig1-Reboot is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.143	info	(9028) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.139	info	(9028) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.134	info	(9028) service DeviceInfo1-GetInfo is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.129	info	(9028) service WLANConfiguration3-GetSecurityKeys is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.124	info	(9028) service WLANConfiguration3-GetInfo is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.117	info	(9028) service WLANConfiguration3-SetEnable is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.112	info	(9028) service WANPPPConnection1-GetInfo is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.106	info	(9028) service DeviceInfo1-GetSecurityPort is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.101	info	(9028) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.096	info	(9028) service Hosts1-GetSpecificHostEntry is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.091	info	(9028) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.084	info	(9028) service Hosts1-X_AVM-DE_GetHostListPath is supported
                    fb-checkpresence.0	2021-01-14 23:05:35.078	debug	(9028) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"220","Major":"148","Minor":"7","Patch":"20","Bui
                    fb-checkpresence.0	2021-01-14 23:05:34.984	debug	(9028) configuratuion mesh info: true
                    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration fb-devices true
                    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration familymembers: [{"familymember":"Handy-xxxxxxxx-Privat","macaddress":"xxxxxxxxxx","ipaddress":"192.168.178.47","useip":true,"usename":true,"comment":"","enabled":true},{"famil
                    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration dateformat: <dd.mm.yyyy HH:MM>
                    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration history: <history.0>
                    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration user: <iobroker>
                    fb-checkpresence.0	2021-01-14 23:05:34.982	info	(9028) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 2 Min. - interval members: 60 s
                    fb-checkpresence.0	2021-01-14 23:05:34.975	info	(9028) starting. Version 1.1.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.2.6-0
                    fb-checkpresence.0	2021-01-14 23:05:34.828	debug	(9028) statesDB connected
                    fb-checkpresence.0	2021-01-14 23:05:34.827	debug	(9028) States connected to redis: 127.0.0.1:9000
                    fb-checkpresence.0	2021-01-14 23:05:34.820	debug	(9028) States create User PubSub Client
                    fb-checkpresence.0	2021-01-14 23:05:34.819	debug	(9028) States create System PubSub Client
                    fb-checkpresence.0	2021-01-14 23:05:34.814	debug	(9028) Redis States: Use Redis connection: 127.0.0.1:9000
                    fb-checkpresence.0	2021-01-14 23:05:34.813	debug	(9028) objectDB connected
                    fb-checkpresence.0	2021-01-14 23:05:34.810	debug	(9028) Objects connected to redis: 127.0.0.1:9013
                    fb-checkpresence.0	2021-01-14 23:05:34.794	debug	(9028) Objects client initialize lua scripts
                    fb-checkpresence.0	2021-01-14 23:05:34.793	debug	(9028) Objects create User PubSub Client
                    fb-checkpresence.0	2021-01-14 23:05:34.793	debug	(9028) Objects create System PubSub Client
                    fb-checkpresence.0	2021-01-14 23:05:34.792	debug	(9028) Objects client ready ... initialize now
                    fb-checkpresence.0	2021-01-14 23:05:34.775	debug	(9028) Redis Objects: Use Redis connection: 127.0.0.1:9013
                    fb-checkpresence.0	2021-01-14 23:05:30.727	info	(15940) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    fb-checkpresence.0	2021-01-14 23:05:30.727	info	(15940) terminating
                    fb-checkpresence.0	2021-01-14 23:05:30.726	info	(15940) cleaned everything up ...
                    fb-checkpresence.0	2021-01-14 23:05:30.726	info	(15940) Got terminate signal TERMINATE_YOURSELF
                    • sigi234S sigi234
                      @sigi234
                      Neueste Meldung:
                      afuerhoffA Offline
                      afuerhoffA Offline
                      afuerhoff
                      #281
                      @sigi234 said in Test Adapter fb-checkpresence v1.1.x:
                      Neueste Meldung:
                      Kommt die Meldung regelmäßig? Es wäre hilfreich zu wissen welche anderen Meldungen davor oder danach kommen.
                        Neueste Meldung:
                        sigi234S Online
                        sigi234S Online
                        #282
                        Nein
                        fb-checkpresence.0	2021-01-14 23:22:13.034	info	(15516) createFbDeviceObjects finished successfully
                        fb-checkpresence.0	2021-01-14 23:22:10.412	info	(15516) createMemberObjects finished successfully
                        fb-checkpresence.0	2021-01-14 23:22:10.021	info	(15516) createGlobalObjects finished successfully
                        fb-checkpresence.0	2021-01-14 23:22:09.823	info	(15516) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.819	info	(15516) service DeviceConfig1-Reboot is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.814	info	(15516) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.809	info	(15516) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.805	info	(15516) service DeviceInfo1-GetInfo is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.800	info	(15516) service WLANConfiguration3-GetSecurityKeys is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.795	info	(15516) service WLANConfiguration3-GetInfo is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.789	info	(15516) service WLANConfiguration3-SetEnable is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.783	info	(15516) service WANPPPConnection1-GetInfo is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.777	info	(15516) service DeviceInfo1-GetSecurityPort is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.772	info	(15516) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.767	info	(15516) service Hosts1-GetSpecificHostEntry is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.763	info	(15516) service Hosts1-X_AVM-DE_GetMeshListPath is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.757	info	(15516) service Hosts1-X_AVM-DE_GetHostListPath is supported
                        fb-checkpresence.0	2021-01-14 23:22:09.677	info	(15516) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 2 Min. - interval members: 60 s
                        fb-checkpresence.0	2021-01-14 23:22:09.671	info	(15516) starting. Version 1.1.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.2.6-0
                        host.Medion(Test)	2021-01-14 23:22:08.889	info	instance system.adapter.fb-checkpresence.0 started with pid 15516
                        host.Medion(Test)	2021-01-14 23:22:06.454	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                        host.Medion(Test)	2021-01-14 23:22:05.792	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
                        fb-checkpresence.0	2021-01-14 23:22:05.796	info	(13144) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                        fb-checkpresence.0	2021-01-14 23:22:05.796	info	(13144) terminating
                        fb-checkpresence.0	2021-01-14 23:22:05.795	info	(13144) cleaned everything up ...
                        fb-checkpresence.0	2021-01-14 23:22:05.792	info	(13144) Got terminate signal TERMINATE_YOURSELF
                        Jetzt schaut es wieder normal aus. Denke es hat was mit den JS Controller zu tun.
                        • sigi234S sigi234
                          Nein
                          afuerhoffA Offline
                          afuerhoffA Offline
                          afuerhoff
                          #283
                          @sigi234
                          Bitte mal beobachten.
                          Hast Du schon mal den QR-Code vom Gäste Wlan testen können?
                            @sigi234
                            sigi234S Online
                            sigi234S Online
                            #284
                            @sigi234
                            Gerade dabei, warte kurz.
                            Keine Anzeige?
                            • sigi234S sigi234
                              @sigi234
                              Keine Anzeige?
                              afuerhoffA Offline
                              afuerhoffA Offline
                              afuerhoff
                              schrieb am zuletzt editiert von afuerhoff
                              #285
                              @sigi234
                              Hast Du mit dem Basic Bool SVG Widget gemacht?
                              Hatte ich auch etwas nach gesucht
                                @sigi234
                                sigi234S Online
                                sigi234S Online
                                #286
                                @afuerhoff
                                Geht jetzt, wird nur in der Runtime sichtbar.
                                  FenriswolfF Offline
                                  FenriswolfF Offline
                                  Fenriswolf
                                  #287
                                  Guten Morgen,
                                  habe getestet und sieht gut aus.
                                  Frage: Gibt es die Möglichkeit auch ein "presentGuest" zu bekommen? Im Format wie "presentMembers". Könnte das dann im Blockly als Liste verwenden.
                                  • FenriswolfF Fenriswolf
                                    Guten Morgen,
                                    Dominik F.D Offline
                                    Dominik F.D Offline
                                    Dominik F.
                                    #288
                                    @fenriswolf
                                    Gibt es doch:
                                    fb-checkpresence.0.guest.presence
                                    FenriswolfF 1 Antwort Letzte Antwort
                                    • Dominik F.D Dominik F.
                                      @fenriswolf
                                      Gibt es doch:
                                      FenriswolfF Offline
                                      FenriswolfF Offline
                                      Fenriswolf
                                      #289
                                      @dominik-f said in Test Adapter fb-checkpresence v1.1.x:
                                      @fenriswolf
                                      Gibt es doch:
                                      Das gibt aber nur true oder false aus, aber nicht den Gerätenamen wie bei presentMembers.
                                        @fenriswolf
                                        Gibt es doch:
                                        afuerhoffA Offline
                                        afuerhoffA Offline
                                        afuerhoff
                                        #290
                                        @fenriswolf
                                        Dafür gibt es die HTML oder Json Liste.
                                          @fenriswolf
                                          FenriswolfF Offline
                                          FenriswolfF Offline
                                          Fenriswolf
                                          #291
                                          @fenriswolf
                                          ja, das habe ich ja gesehen, aber da müsste ich erst mühsehlig extrahieren. In der anderen Liste ist es einfach eine Aufzählung durch Komma getrennt ;-)
