  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • afuerhoffA afuerhoff
    @sigi234
    Da verstehe ich die Meldung vom JS-Controller nicht. Ist doch als Objekt angelegt.
    sigi234S Online
    sigi234S Online
    #278
    @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
    @sigi234
    Ja, ist bei andere Adapter auch so.
    Neueste Meldung:
    fb-checkpresence.0	2021-01-14 22:42:56.416	error	(8292) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
    afuerhoffA 2 Antworten Letzte Antwort
    • sigi234S sigi234
      @sigi234
      Neueste Meldung:
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      #279
      @sigi234
      Kannst Du mal das Log vom Start an posten. Da kommen die Meldungen was alles unterstützt wird.
        @sigi234
        sigi234S Online
        sigi234S Online
        #280
        @sigi234
        fb-checkpresence.0	2021-01-14 23:06:34.085	debug	(9028) loopFamily ends after 5,187158400 s
        fb-checkpresence.0	2021-01-14 23:06:33.426	debug	(9028) Handy-xxx: No history item before this day is available
        fb-checkpresence.0	2021-01-14 23:06:33.426	debug	(9028) history Handy-xxx cntHistory: 15421
        fb-checkpresence.0	2021-01-14 23:06:33.230	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:06:33.230	debug	(9028) history cntActualDay: 15422
        fb-checkpresence.0	2021-01-14 23:06:33.059	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:06:32.102	debug	(9028) Handy-Ilse: No history item before this day is available
        fb-checkpresence.0	2021-01-14 23:06:32.102	debug	(9028) history Handy-xxxx cntHistory: 15424
        fb-checkpresence.0	2021-01-14 23:06:31.869	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:06:31.869	debug	(9028) history cntActualDay: 15425
        fb-checkpresence.0	2021-01-14 23:06:31.622	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:06:30.784	debug	(9028) Handy-xxxxxx: No history item before this day is available
        fb-checkpresence.0	2021-01-14 23:06:30.783	debug	(9028) history Handy-xxxxxx cntHistory: 15422
        fb-checkpresence.0	2021-01-14 23:06:30.410	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:06:30.409	debug	(9028) history cntActualDay: 15423
        fb-checkpresence.0	2021-01-14 23:06:29.928	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:06:29.904	debug	(9028) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.99","MACAddress":"xxxxxxxxxx","Active":"1","HostName":"CCU3","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE_Speed":"1000",
        fb-checkpresence.0	2021-01-14 23:05:37.540	info	(9028) createFbDeviceObjects finished successfully
        fb-checkpresence.0	2021-01-14 23:05:36.457	debug	(9028) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.99","MACAddress":"xxxxxxx","Active":"1","HostName":"CCU3","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE_Speed":"1000",
        fb-checkpresence.0	2021-01-14 23:05:35.845	debug	(9028) system.adapter.admin.0: logging true
        fb-checkpresence.0	2021-01-14 23:05:35.693	info	(9028) createMemberObjects finished successfully
        fb-checkpresence.0	2021-01-14 23:05:35.688	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:05:35.594	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:05:35.461	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
        fb-checkpresence.0	2021-01-14 23:05:35.367	info	(9028) createGlobalObjects finished successfully
        fb-checkpresence.0	2021-01-14 23:05:35.159	debug	(9028) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
        fb-checkpresence.0	2021-01-14 23:05:35.152	info	(9028) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
        fb-checkpresence.0	2021-01-14 23:05:35.148	info	(9028) service DeviceConfig1-Reboot is supported
        fb-checkpresence.0	2021-01-14 23:05:35.143	info	(9028) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
        fb-checkpresence.0	2021-01-14 23:05:35.139	info	(9028) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
        fb-checkpresence.0	2021-01-14 23:05:35.134	info	(9028) service DeviceInfo1-GetInfo is supported
        fb-checkpresence.0	2021-01-14 23:05:35.129	info	(9028) service WLANConfiguration3-GetSecurityKeys is supported
        fb-checkpresence.0	2021-01-14 23:05:35.124	info	(9028) service WLANConfiguration3-GetInfo is supported
        fb-checkpresence.0	2021-01-14 23:05:35.117	info	(9028) service WLANConfiguration3-SetEnable is supported
        fb-checkpresence.0	2021-01-14 23:05:35.112	info	(9028) service WANPPPConnection1-GetInfo is supported
        fb-checkpresence.0	2021-01-14 23:05:35.106	info	(9028) service DeviceInfo1-GetSecurityPort is supported
        fb-checkpresence.0	2021-01-14 23:05:35.101	info	(9028) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0	2021-01-14 23:05:35.096	info	(9028) service Hosts1-GetSpecificHostEntry is supported
        fb-checkpresence.0	2021-01-14 23:05:35.091	info	(9028) service Hosts1-X_AVM-DE_GetMeshListPath is supported
        fb-checkpresence.0	2021-01-14 23:05:35.084	info	(9028) service Hosts1-X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0	2021-01-14 23:05:35.078	debug	(9028) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"220","Major":"148","Minor":"7","Patch":"20","Bui
        fb-checkpresence.0	2021-01-14 23:05:34.984	debug	(9028) configuratuion mesh info: true
        fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration fb-devices true
        fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration familymembers: [{"familymember":"Handy-xxxxxxxx-Privat","macaddress":"xxxxxxxxxx","ipaddress":"192.168.178.47","useip":true,"usename":true,"comment":"","enabled":true},{"famil
        fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration dateformat: <dd.mm.yyyy HH:MM>
        fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration history: <history.0>
        fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration user: <iobroker>
        fb-checkpresence.0	2021-01-14 23:05:34.982	info	(9028) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 2 Min. - interval members: 60 s
        fb-checkpresence.0	2021-01-14 23:05:34.975	info	(9028) starting. Version 1.1.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.2.6-0
        fb-checkpresence.0	2021-01-14 23:05:34.828	debug	(9028) statesDB connected
        fb-checkpresence.0	2021-01-14 23:05:34.827	debug	(9028) States connected to redis: 127.0.0.1:9000
        fb-checkpresence.0	2021-01-14 23:05:34.820	debug	(9028) States create User PubSub Client
        fb-checkpresence.0	2021-01-14 23:05:34.819	debug	(9028) States create System PubSub Client
        fb-checkpresence.0	2021-01-14 23:05:34.814	debug	(9028) Redis States: Use Redis connection: 127.0.0.1:9000
        fb-checkpresence.0	2021-01-14 23:05:34.813	debug	(9028) objectDB connected
        fb-checkpresence.0	2021-01-14 23:05:34.810	debug	(9028) Objects connected to redis: 127.0.0.1:9013
        fb-checkpresence.0	2021-01-14 23:05:34.794	debug	(9028) Objects client initialize lua scripts
        fb-checkpresence.0	2021-01-14 23:05:34.793	debug	(9028) Objects create User PubSub Client
        fb-checkpresence.0	2021-01-14 23:05:34.793	debug	(9028) Objects create System PubSub Client
        fb-checkpresence.0	2021-01-14 23:05:34.792	debug	(9028) Objects client ready ... initialize now
        fb-checkpresence.0	2021-01-14 23:05:34.775	debug	(9028) Redis Objects: Use Redis connection: 127.0.0.1:9013
        fb-checkpresence.0	2021-01-14 23:05:30.727	info	(15940) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fb-checkpresence.0	2021-01-14 23:05:30.727	info	(15940) terminating
        fb-checkpresence.0	2021-01-14 23:05:30.726	info	(15940) cleaned everything up ...
        fb-checkpresence.0	2021-01-14 23:05:30.726	info	(15940) Got terminate signal TERMINATE_YOURSELF
        • sigi234S sigi234
          @sigi234
          Neueste Meldung:
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #281
          @sigi234 said in Test Adapter fb-checkpresence v1.1.x:
          Neueste Meldung:
          Kommt die Meldung regelmäßig? Es wäre hilfreich zu wissen welche anderen Meldungen davor oder danach kommen.
            Neueste Meldung:
            sigi234S Online
            sigi234S Online
            #282
            Nein
            fb-checkpresence.0	2021-01-14 23:22:13.034	info	(15516) createFbDeviceObjects finished successfully
            fb-checkpresence.0	2021-01-14 23:22:10.412	info	(15516) createMemberObjects finished successfully
            fb-checkpresence.0	2021-01-14 23:22:10.021	info	(15516) createGlobalObjects finished successfully
            fb-checkpresence.0	2021-01-14 23:22:09.823	info	(15516) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
            fb-checkpresence.0	2021-01-14 23:22:09.819	info	(15516) service DeviceConfig1-Reboot is supported
            fb-checkpresence.0	2021-01-14 23:22:09.814	info	(15516) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
            fb-checkpresence.0	2021-01-14 23:22:09.809	info	(15516) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
            fb-checkpresence.0	2021-01-14 23:22:09.805	info	(15516) service DeviceInfo1-GetInfo is supported
            fb-checkpresence.0	2021-01-14 23:22:09.800	info	(15516) service WLANConfiguration3-GetSecurityKeys is supported
            fb-checkpresence.0	2021-01-14 23:22:09.795	info	(15516) service WLANConfiguration3-GetInfo is supported
            fb-checkpresence.0	2021-01-14 23:22:09.789	info	(15516) service WLANConfiguration3-SetEnable is supported
            fb-checkpresence.0	2021-01-14 23:22:09.783	info	(15516) service WANPPPConnection1-GetInfo is supported
            fb-checkpresence.0	2021-01-14 23:22:09.777	info	(15516) service DeviceInfo1-GetSecurityPort is supported
            fb-checkpresence.0	2021-01-14 23:22:09.772	info	(15516) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
            fb-checkpresence.0	2021-01-14 23:22:09.767	info	(15516) service Hosts1-GetSpecificHostEntry is supported
            fb-checkpresence.0	2021-01-14 23:22:09.763	info	(15516) service Hosts1-X_AVM-DE_GetMeshListPath is supported
            fb-checkpresence.0	2021-01-14 23:22:09.757	info	(15516) service Hosts1-X_AVM-DE_GetHostListPath is supported
            fb-checkpresence.0	2021-01-14 23:22:09.677	info	(15516) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 2 Min. - interval members: 60 s
            fb-checkpresence.0	2021-01-14 23:22:09.671	info	(15516) starting. Version 1.1.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.2.6-0
            host.Medion(Test)	2021-01-14 23:22:08.889	info	instance system.adapter.fb-checkpresence.0 started with pid 15516
            host.Medion(Test)	2021-01-14 23:22:06.454	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            host.Medion(Test)	2021-01-14 23:22:05.792	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
            fb-checkpresence.0	2021-01-14 23:22:05.796	info	(13144) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            fb-checkpresence.0	2021-01-14 23:22:05.796	info	(13144) terminating
            fb-checkpresence.0	2021-01-14 23:22:05.795	info	(13144) cleaned everything up ...
            fb-checkpresence.0	2021-01-14 23:22:05.792	info	(13144) Got terminate signal TERMINATE_YOURSELF
            Jetzt schaut es wieder normal aus. Denke es hat was mit den JS Controller zu tun.
            • sigi234S sigi234
              Nein
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              #283
              @sigi234
              Bitte mal beobachten.
              Hast Du schon mal den QR-Code vom Gäste Wlan testen können?
                @sigi234
                sigi234S Online
                sigi234S Online
                #284
                @sigi234
                Gerade dabei, warte kurz.
                Keine Anzeige?
                • sigi234S sigi234
                  @sigi234
                  Keine Anzeige?
                  afuerhoffA Offline
                  afuerhoffA Offline
                  afuerhoff
                  schrieb am zuletzt editiert von afuerhoff
                  #285
                  @sigi234
                  Hast Du mit dem Basic Bool SVG Widget gemacht?
                  Hatte ich auch etwas nach gesucht
                    @sigi234
                    sigi234S Online
                    sigi234S Online
                    #286
                    @afuerhoff
                    Geht jetzt, wird nur in der Runtime sichtbar.
                      @Fenriswolf @sigi234
                      Ich habe ein Update hochgeladen. Bitte neu testen. Am Besten einmal die Objekte unter fb-devices löschen. Die sind falsch angelegt worden.
                      FenriswolfF Offline
                      FenriswolfF Offline
                      Fenriswolf
                      #287
                      Guten Morgen,
                      habe getestet und sieht gut aus.
                      Frage: Gibt es die Möglichkeit auch ein "presentGuest" zu bekommen? Im Format wie "presentMembers". Könnte das dann im Blockly als Liste verwenden.
                      • FenriswolfF Fenriswolf
                        Guten Morgen,
                        Dominik F.D Offline
                        Dominik F.D Offline
                        Dominik F.
                        #288
                        @fenriswolf
                        Gibt es doch:
                        fb-checkpresence.0.guest.presence
                        FenriswolfF 1 Antwort Letzte Antwort
                        • Dominik F.D Dominik F.
                          @fenriswolf
                          Gibt es doch:
                          FenriswolfF Offline
                          FenriswolfF Offline
                          Fenriswolf
                          #289
                          @dominik-f said in Test Adapter fb-checkpresence v1.1.x:
                          @fenriswolf
                          Gibt es doch:
                          Das gibt aber nur true oder false aus, aber nicht den Gerätenamen wie bei presentMembers.
                            @fenriswolf
                            Gibt es doch:
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            #290
                            @fenriswolf
                            Dafür gibt es die HTML oder Json Liste.
                              @fenriswolf
                              FenriswolfF Offline
                              FenriswolfF Offline
                              Fenriswolf
                              #291
                              @fenriswolf
                              ja, das habe ich ja gesehen, aber da müsste ich erst mühsehlig extrahieren. In der anderen Liste ist es einfach eine Aufzählung durch Komma getrennt ;-)
                                @fenriswolf
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #292
                                @fenriswolf
                                Du kannst doch z.B. im Vis eine basic table für die json Liste benutzen.
                                  @fenriswolf
                                  FenriswolfF Offline
                                  FenriswolfF Offline
                                  Fenriswolf
                                  schrieb am zuletzt editiert von Fenriswolf
                                  #293
                                  @fenriswolf
                                  Ich brauche die Liste nicht für Vis, sondern für Alexa ;-)
                                    @fenriswolf
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #294
                                    @fenriswolf
                                    Baue ich ein
                                      Aktuelle Test Version 1.1.25
                                      Veröffentlichungsdatum 21.01.2023
                                      Github Link https://github.com/afuerhoff/ioBroker.fb-checkpresence
                                      npm im Latest verfügbar
                                      Hinweis: Adapter muss nach Installation von Github einmal neu gestartet werden.
                                      Änderungen:
                                      1.1.0
                                      • second interval for family members implemented
                                      • mesh info added
                                      • configuration validation added
                                      • switch on, off guest wlan
                                      • switch on, off internet access of devices
                                      • structural changes
                                      • code optimization
                                      • new datapoint absenceAll
                                      • neue Funktion Reboot
                                      1.1.1
                                      • Admin Konfiguration optimiert
                                      • Im Dateformat dürfen jetzt auch Bindestriche benutzt werden
                                      • https workaround implementiert (Konfiguration)-> es gab einen Fall, wo der Adapter nicht mit * https die Fritzbox abfragen konnte.
                                      • Connection check wurde optimiert
                                      • Dokumentation geändert
                                      • Mesh Handling optimiert -> es werden jetzt die Channels im Klartext angelegt. Dies verhindert, dass sich die Id's ändern.
                                      1.1.2
                                      • Gäste WLAN QR-Code ist als State implementiert und kann mit dem Basic Bool SVG Widget benutzt werden.
                                      • Die Presence states werden nur geändert, wenn es eine Änderung gibt.
                                      • Die Benutzerrechte des Users werden ausgelesen und mit den unterstützten Services der Fritzbox abgeglichen. Es muss der Service unterstützt werden und die Benutzerrechte zum Service passen. Ist dies nicht der Fall, werden nur die Funktionen ausgeführt, die dann möglich sind. Man kann also die Accessrights (FRITZ!Box Einstellungen, Smart Home, ...) in der Fritzbox reduzieren ohne Fehler zu bekommen. Im Log wird das beim Start einmal als Warnung ausgegeben.
                                      • Der Name des Devices kann jetzt ebenfalls genutzt werden. Hierfür muss das Familienmitglied genauso wie in der Fritzbox benannt werden. (Achtung: Wenn der Name nur in der Fritzbox manuell umbenannt wurde und nicht im Handy, dann wird bei eingeschalteter Mac-Verschleierung der Name des neu in der Fritzbox hinzugefügten Devices ein anderer sein)
                                      • active / inactive Device Zähler korrigiert
                                      • 10s Intervall Bug gefixed
                                      • Dokumentation angepasst
                                      • PresentGuests state eingebaut
                                      Änderungen 1.1.3:
                                      • Familiengruppen. Diese werden im Ordner familyMembers angelegt.
                                      • Kompatibilitätsmodus -> in Zukunft gibt es nur noch den presence state bei den Familienmitgliedern. Nicht mehr den auf der obersten Ebene am Familienmitglied.
                                      • In der Konfiguration habe ich noch ein paar Optionen aufgenommen
                                      • Die Dialogboxen habe ich optimiert
                                      • Ein Filter kann jetzt pro Familienmitglied eingeschaltet werden. Ist ein Familienmitglied true wird sofort der Status gesetzt. Bei false wird nach der Filterzeit nochmal auf den Wert geschaut und nur dann der Status gesetzt falls der Status ebenfalls false ist.
                                      • Für das Passwort Handling nutze ich jetzt die neue ioBroker Funktionalität
                                      • und diverse Änderungen unter der Haube
                                      ich habe eine neue Testversion auf Github hochgeladen. Bitte testet diese und gebt hier Rückmeldung über Probleme mit der neuen Version.
                                      Wichtigste Neuerungen sind das Ein- und Ausschalten des Gäste-WLAN. Das deaktivieren des Internetzugriffs von Geräten und ein zusätzliches Interval für Familienmitglieder.
                                      Die Eingaben auf der Konfigurationsseite werden jetzt überprüft und ggfs. das Speichern deakiviert. Im Bereich der fb-devices werden jetzt zusätzliche Mesh-Informationen angelegt, falls dies in der Konfiguration aktiviert wurde.
                                      Viel Spaß beim Testen.
                                      Gäste-WLAN ein-, ausschalten -> Datenpunkt wlan
                                      Internetzugriff ein-, ausschalten -> fb-devices Datenpunkt disabled = true (Internet aus)
                                      sigi234S Online
                                      sigi234S Online
                                      #295
                                      Hallo, was ist der Unterschied in den Familien Einstellungen Benutze IP oder Name?
                                      • sigi234S sigi234
                                        afuerhoffA Offline
                                        afuerhoffA Offline
                                        afuerhoff
                                        #296
                                        @sigi234
                                        Unabhängig von der Mac oder Ip wird der Devicename in der Fritzbox genutzt. Ist für die gedacht, die entweder die Verschleierung der Mac nicht ausschalten können oder wollen. Ich habe oben im ersten Post hierzu noch etwas hinzugefügt.
                                        • afuerhoffA Offline
                                          afuerhoffA Offline
                                          afuerhoff
                                          #297
                                          ich habe gerade ein neues Update zum Testen eingespielt. Hier wurde nur der State presentGuests (@Fenriswolf) mit hinzugefügt.
