  4. Test Adapter fb-checkpresence v1.1.x
avmfb-checkpresencefritzboxtr-064
948 Beiträge 89 Kommentatoren 397.6k Aufrufe 78 Beobachtet
  • afuerhoffA afuerhoff
    @sigi234
    Kannst Du mal das Log vom Start an posten. Da kommen die Meldungen was alles unterstützt wird.
    sigi234S Online
    sigi234S Online
    #280
    @afuerhoff said in Test Adapter fb-checkpresence v1.1.x:
    @sigi234
    fb-checkpresence.0	2021-01-14 23:06:34.085	debug	(9028) loopFamily ends after 5,187158400 s
    fb-checkpresence.0	2021-01-14 23:06:33.426	debug	(9028) Handy-xxx: No history item before this day is available
    fb-checkpresence.0	2021-01-14 23:06:33.426	debug	(9028) history Handy-xxx cntHistory: 15421
    fb-checkpresence.0	2021-01-14 23:06:33.230	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:06:33.230	debug	(9028) history cntActualDay: 15422
    fb-checkpresence.0	2021-01-14 23:06:33.059	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:06:32.102	debug	(9028) Handy-Ilse: No history item before this day is available
    fb-checkpresence.0	2021-01-14 23:06:32.102	debug	(9028) history Handy-xxxx cntHistory: 15424
    fb-checkpresence.0	2021-01-14 23:06:31.869	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:06:31.869	debug	(9028) history cntActualDay: 15425
    fb-checkpresence.0	2021-01-14 23:06:31.622	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:06:30.784	debug	(9028) Handy-xxxxxx: No history item before this day is available
    fb-checkpresence.0	2021-01-14 23:06:30.783	debug	(9028) history Handy-xxxxxx cntHistory: 15422
    fb-checkpresence.0	2021-01-14 23:06:30.410	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:06:30.409	debug	(9028) history cntActualDay: 15423
    fb-checkpresence.0	2021-01-14 23:06:29.928	debug	(9028) sendTo "getHistory" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:06:29.904	debug	(9028) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.99","MACAddress":"xxxxxxxxxx","Active":"1","HostName":"CCU3","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE_Speed":"1000",
    fb-checkpresence.0	2021-01-14 23:05:37.540	info	(9028) createFbDeviceObjects finished successfully
    fb-checkpresence.0	2021-01-14 23:05:36.457	debug	(9028) getDeviceList: [{"Index":"1","IPAddress":"192.168.178.99","MACAddress":"xxxxxxx","Active":"1","HostName":"CCU3","InterfaceType":"Ethernet","X_AVM-DE_Port":"1","X_AVM-DE_Speed":"1000",
    fb-checkpresence.0	2021-01-14 23:05:35.845	debug	(9028) system.adapter.admin.0: logging true
    fb-checkpresence.0	2021-01-14 23:05:35.693	info	(9028) createMemberObjects finished successfully
    fb-checkpresence.0	2021-01-14 23:05:35.688	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:05:35.594	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:05:35.461	debug	(9028) sendTo "getEnabledDPs" to system.adapter.history.0 from system.adapter.fb-checkpresence.0
    fb-checkpresence.0	2021-01-14 23:05:35.367	info	(9028) createGlobalObjects finished successfully
    fb-checkpresence.0	2021-01-14 23:05:35.159	debug	(9028) ssl-port {"status":200,"result":true,"resultData":{"$":{"xmlns:u":"urn:dslforum-org:service:DeviceInfo:1"},"NewSecurityPort":"49443"},"errNo":0,"errorMsg":""}
    fb-checkpresence.0	2021-01-14 23:05:35.152	info	(9028) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
    fb-checkpresence.0	2021-01-14 23:05:35.148	info	(9028) service DeviceConfig1-Reboot is supported
    fb-checkpresence.0	2021-01-14 23:05:35.143	info	(9028) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
    fb-checkpresence.0	2021-01-14 23:05:35.139	info	(9028) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
    fb-checkpresence.0	2021-01-14 23:05:35.134	info	(9028) service DeviceInfo1-GetInfo is supported
    fb-checkpresence.0	2021-01-14 23:05:35.129	info	(9028) service WLANConfiguration3-GetSecurityKeys is supported
    fb-checkpresence.0	2021-01-14 23:05:35.124	info	(9028) service WLANConfiguration3-GetInfo is supported
    fb-checkpresence.0	2021-01-14 23:05:35.117	info	(9028) service WLANConfiguration3-SetEnable is supported
    fb-checkpresence.0	2021-01-14 23:05:35.112	info	(9028) service WANPPPConnection1-GetInfo is supported
    fb-checkpresence.0	2021-01-14 23:05:35.106	info	(9028) service DeviceInfo1-GetSecurityPort is supported
    fb-checkpresence.0	2021-01-14 23:05:35.101	info	(9028) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
    fb-checkpresence.0	2021-01-14 23:05:35.096	info	(9028) service Hosts1-GetSpecificHostEntry is supported
    fb-checkpresence.0	2021-01-14 23:05:35.091	info	(9028) service Hosts1-X_AVM-DE_GetMeshListPath is supported
    fb-checkpresence.0	2021-01-14 23:05:35.084	info	(9028) service Hosts1-X_AVM-DE_GetHostListPath is supported
    fb-checkpresence.0	2021-01-14 23:05:35.078	debug	(9028) services loaded successfully{"root":{"$":{"xmlns":"urn:dslforum-org:device-1-0"},"specVersion":{"major":"1","minor":"0"},"systemVersion":{"HW":"220","Major":"148","Minor":"7","Patch":"20","Bui
    fb-checkpresence.0	2021-01-14 23:05:34.984	debug	(9028) configuratuion mesh info: true
    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration fb-devices true
    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration familymembers: [{"familymember":"Handy-xxxxxxxx-Privat","macaddress":"xxxxxxxxxx","ipaddress":"192.168.178.47","useip":true,"usename":true,"comment":"","enabled":true},{"famil
    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration dateformat: <dd.mm.yyyy HH:MM>
    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration history: <history.0>
    fb-checkpresence.0	2021-01-14 23:05:34.983	debug	(9028) configuration user: <iobroker>
    fb-checkpresence.0	2021-01-14 23:05:34.982	info	(9028) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 2 Min. - interval members: 60 s
    fb-checkpresence.0	2021-01-14 23:05:34.975	info	(9028) starting. Version 1.1.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.2.6-0
    fb-checkpresence.0	2021-01-14 23:05:34.828	debug	(9028) statesDB connected
    fb-checkpresence.0	2021-01-14 23:05:34.827	debug	(9028) States connected to redis: 127.0.0.1:9000
    fb-checkpresence.0	2021-01-14 23:05:34.820	debug	(9028) States create User PubSub Client
    fb-checkpresence.0	2021-01-14 23:05:34.819	debug	(9028) States create System PubSub Client
    fb-checkpresence.0	2021-01-14 23:05:34.814	debug	(9028) Redis States: Use Redis connection: 127.0.0.1:9000
    fb-checkpresence.0	2021-01-14 23:05:34.813	debug	(9028) objectDB connected
    fb-checkpresence.0	2021-01-14 23:05:34.810	debug	(9028) Objects connected to redis: 127.0.0.1:9013
    fb-checkpresence.0	2021-01-14 23:05:34.794	debug	(9028) Objects client initialize lua scripts
    fb-checkpresence.0	2021-01-14 23:05:34.793	debug	(9028) Objects create User PubSub Client
    fb-checkpresence.0	2021-01-14 23:05:34.793	debug	(9028) Objects create System PubSub Client
    fb-checkpresence.0	2021-01-14 23:05:34.792	debug	(9028) Objects client ready ... initialize now
    fb-checkpresence.0	2021-01-14 23:05:34.775	debug	(9028) Redis Objects: Use Redis connection: 127.0.0.1:9013
    fb-checkpresence.0	2021-01-14 23:05:30.727	info	(15940) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    fb-checkpresence.0	2021-01-14 23:05:30.727	info	(15940) terminating
    fb-checkpresence.0	2021-01-14 23:05:30.726	info	(15940) cleaned everything up ...
    fb-checkpresence.0	2021-01-14 23:05:30.726	info	(15940) Got terminate signal TERMINATE_YOURSELF
    • sigi234S sigi234
      @sigi234
      Da verstehe ich die Meldung vom JS-Controller nicht. Ist doch als Objekt angelegt.
      Ja, ist bei andere Adapter auch so.
      Neueste Meldung:
      fb-checkpresence.0	2021-01-14 22:42:56.416	error	(8292) soapAction xml2js GetInfo status=500 errNo=4 401 Invalid Action
      afuerhoffA Offline
      afuerhoffA Offline
      afuerhoff
      #281
      @sigi234 said in Test Adapter fb-checkpresence v1.1.x:
      Neueste Meldung:
      Kommt die Meldung regelmäßig? Es wäre hilfreich zu wissen welche anderen Meldungen davor oder danach kommen.
        Neueste Meldung:
        sigi234S Online
        sigi234S Online
        #282
        Nein
        fb-checkpresence.0	2021-01-14 23:22:13.034	info	(15516) createFbDeviceObjects finished successfully
        fb-checkpresence.0	2021-01-14 23:22:10.412	info	(15516) createMemberObjects finished successfully
        fb-checkpresence.0	2021-01-14 23:22:10.021	info	(15516) createGlobalObjects finished successfully
        fb-checkpresence.0	2021-01-14 23:22:09.823	info	(15516) service LANConfigSecurity1-X_AVM-DE_GetCurrentUser is supported
        fb-checkpresence.0	2021-01-14 23:22:09.819	info	(15516) service DeviceConfig1-Reboot is supported
        fb-checkpresence.0	2021-01-14 23:22:09.814	info	(15516) service X_AVM-DE_HostFilter-GetWANAccessByIP is supported
        fb-checkpresence.0	2021-01-14 23:22:09.809	info	(15516) service X_AVM-DE_HostFilter-DisallowWANAccessByIP is supported
        fb-checkpresence.0	2021-01-14 23:22:09.805	info	(15516) service DeviceInfo1-GetInfo is supported
        fb-checkpresence.0	2021-01-14 23:22:09.800	info	(15516) service WLANConfiguration3-GetSecurityKeys is supported
        fb-checkpresence.0	2021-01-14 23:22:09.795	info	(15516) service WLANConfiguration3-GetInfo is supported
        fb-checkpresence.0	2021-01-14 23:22:09.789	info	(15516) service WLANConfiguration3-SetEnable is supported
        fb-checkpresence.0	2021-01-14 23:22:09.783	info	(15516) service WANPPPConnection1-GetInfo is supported
        fb-checkpresence.0	2021-01-14 23:22:09.777	info	(15516) service DeviceInfo1-GetSecurityPort is supported
        fb-checkpresence.0	2021-01-14 23:22:09.772	info	(15516) service Hosts1-X_AVM-DE_GetSpecificHostEntryByIP is supported
        fb-checkpresence.0	2021-01-14 23:22:09.767	info	(15516) service Hosts1-GetSpecificHostEntry is supported
        fb-checkpresence.0	2021-01-14 23:22:09.763	info	(15516) service Hosts1-X_AVM-DE_GetMeshListPath is supported
        fb-checkpresence.0	2021-01-14 23:22:09.757	info	(15516) service Hosts1-X_AVM-DE_GetHostListPath is supported
        fb-checkpresence.0	2021-01-14 23:22:09.677	info	(15516) start fb-checkpresence: ip-address: "192.168.178.1" - interval devices: 2 Min. - interval members: 60 s
        fb-checkpresence.0	2021-01-14 23:22:09.671	info	(15516) starting. Version 1.1.2 in C:/Program Files/iobroker/Test/node_modules/iobroker.fb-checkpresence, node: v12.20.1, js-controller: 3.2.6-0
        host.Medion(Test)	2021-01-14 23:22:08.889	info	instance system.adapter.fb-checkpresence.0 started with pid 15516
        host.Medion(Test)	2021-01-14 23:22:06.454	info	instance system.adapter.fb-checkpresence.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.Medion(Test)	2021-01-14 23:22:05.792	info	stopInstance system.adapter.fb-checkpresence.0 send kill signal
        fb-checkpresence.0	2021-01-14 23:22:05.796	info	(13144) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        fb-checkpresence.0	2021-01-14 23:22:05.796	info	(13144) terminating
        fb-checkpresence.0	2021-01-14 23:22:05.795	info	(13144) cleaned everything up ...
        fb-checkpresence.0	2021-01-14 23:22:05.792	info	(13144) Got terminate signal TERMINATE_YOURSELF
        Jetzt schaut es wieder normal aus. Denke es hat was mit den JS Controller zu tun.
        • sigi234S sigi234
          Nein
          afuerhoffA Offline
          afuerhoffA Offline
          afuerhoff
          #283
          @sigi234
          Bitte mal beobachten.
          Hast Du schon mal den QR-Code vom Gäste Wlan testen können?
            @sigi234
            sigi234S Online
            sigi234S Online
            #284
            @sigi234
            Gerade dabei, warte kurz.
            Keine Anzeige?
            • sigi234S sigi234
              @sigi234
              Keine Anzeige?
              afuerhoffA Offline
              afuerhoffA Offline
              afuerhoff
              schrieb am zuletzt editiert von afuerhoff
              #285
              @sigi234
              Hast Du mit dem Basic Bool SVG Widget gemacht?
              Hatte ich auch etwas nach gesucht
                @sigi234
                sigi234S Online
                sigi234S Online
                #286
                @afuerhoff
                Geht jetzt, wird nur in der Runtime sichtbar.
                  @Fenriswolf @sigi234
                  Ich habe ein Update hochgeladen. Bitte neu testen. Am Besten einmal die Objekte unter fb-devices löschen. Die sind falsch angelegt worden.
                  FenriswolfF Offline
                  FenriswolfF Offline
                  Fenriswolf
                  #287
                  Guten Morgen,
                  habe getestet und sieht gut aus.
                  Frage: Gibt es die Möglichkeit auch ein "presentGuest" zu bekommen? Im Format wie "presentMembers". Könnte das dann im Blockly als Liste verwenden.
                  • FenriswolfF Fenriswolf
                    Guten Morgen,
                    Dominik F.D Offline
                    Dominik F.D Offline
                    Dominik F.
                    #288
                    @fenriswolf
                    Gibt es doch:
                    fb-checkpresence.0.guest.presence
                    FenriswolfF 1 Antwort Letzte Antwort
                    • Dominik F.D Dominik F.
                      @fenriswolf
                      Gibt es doch:
                      FenriswolfF Offline
                      FenriswolfF Offline
                      Fenriswolf
                      #289
                      @dominik-f said in Test Adapter fb-checkpresence v1.1.x:
                      @fenriswolf
                      Gibt es doch:
                      Das gibt aber nur true oder false aus, aber nicht den Gerätenamen wie bei presentMembers.
                        @fenriswolf
                        Gibt es doch:
                        afuerhoffA Offline
                        afuerhoffA Offline
                        afuerhoff
                        #290
                        @fenriswolf
                        Dafür gibt es die HTML oder Json Liste.
                          @fenriswolf
                          FenriswolfF Offline
                          FenriswolfF Offline
                          Fenriswolf
                          #291
                          @fenriswolf
                          ja, das habe ich ja gesehen, aber da müsste ich erst mühsehlig extrahieren. In der anderen Liste ist es einfach eine Aufzählung durch Komma getrennt ;-)
                            @fenriswolf
                            afuerhoffA Offline
                            afuerhoffA Offline
                            afuerhoff
                            #292
                            @fenriswolf
                            Du kannst doch z.B. im Vis eine basic table für die json Liste benutzen.
                              @fenriswolf
                              FenriswolfF Offline
                              FenriswolfF Offline
                              Fenriswolf
                              schrieb am zuletzt editiert von Fenriswolf
                              #293
                              @fenriswolf
                              Ich brauche die Liste nicht für Vis, sondern für Alexa ;-)
                                @fenriswolf
                                afuerhoffA Offline
                                afuerhoffA Offline
                                afuerhoff
                                #294
                                @fenriswolf
                                Baue ich ein
                                  Aktuelle Test Version 1.1.25
                                  Veröffentlichungsdatum 21.01.2023
                                  Github Link https://github.com/afuerhoff/ioBroker.fb-checkpresence
                                  npm im Latest verfügbar
                                  Hinweis: Adapter muss nach Installation von Github einmal neu gestartet werden.
                                  Änderungen:
                                  1.1.0
                                  • second interval for family members implemented
                                  • mesh info added
                                  • configuration validation added
                                  • switch on, off guest wlan
                                  • switch on, off internet access of devices
                                  • structural changes
                                  • code optimization
                                  • new datapoint absenceAll
                                  • neue Funktion Reboot
                                  1.1.1
                                  • Admin Konfiguration optimiert
                                  • Im Dateformat dürfen jetzt auch Bindestriche benutzt werden
                                  • https workaround implementiert (Konfiguration)-> es gab einen Fall, wo der Adapter nicht mit * https die Fritzbox abfragen konnte.
                                  • Connection check wurde optimiert
                                  • Dokumentation geändert
                                  • Mesh Handling optimiert -> es werden jetzt die Channels im Klartext angelegt. Dies verhindert, dass sich die Id's ändern.
                                  1.1.2
                                  • Gäste WLAN QR-Code ist als State implementiert und kann mit dem Basic Bool SVG Widget benutzt werden.
                                  • Die Presence states werden nur geändert, wenn es eine Änderung gibt.
                                  • Die Benutzerrechte des Users werden ausgelesen und mit den unterstützten Services der Fritzbox abgeglichen. Es muss der Service unterstützt werden und die Benutzerrechte zum Service passen. Ist dies nicht der Fall, werden nur die Funktionen ausgeführt, die dann möglich sind. Man kann also die Accessrights (FRITZ!Box Einstellungen, Smart Home, ...) in der Fritzbox reduzieren ohne Fehler zu bekommen. Im Log wird das beim Start einmal als Warnung ausgegeben.
                                  • Der Name des Devices kann jetzt ebenfalls genutzt werden. Hierfür muss das Familienmitglied genauso wie in der Fritzbox benannt werden. (Achtung: Wenn der Name nur in der Fritzbox manuell umbenannt wurde und nicht im Handy, dann wird bei eingeschalteter Mac-Verschleierung der Name des neu in der Fritzbox hinzugefügten Devices ein anderer sein)
                                  • active / inactive Device Zähler korrigiert
                                  • 10s Intervall Bug gefixed
                                  • Dokumentation angepasst
                                  • PresentGuests state eingebaut
                                  Änderungen 1.1.3:
                                  • Familiengruppen. Diese werden im Ordner familyMembers angelegt.
                                  • Kompatibilitätsmodus -> in Zukunft gibt es nur noch den presence state bei den Familienmitgliedern. Nicht mehr den auf der obersten Ebene am Familienmitglied.
                                  • In der Konfiguration habe ich noch ein paar Optionen aufgenommen
                                  • Die Dialogboxen habe ich optimiert
                                  • Ein Filter kann jetzt pro Familienmitglied eingeschaltet werden. Ist ein Familienmitglied true wird sofort der Status gesetzt. Bei false wird nach der Filterzeit nochmal auf den Wert geschaut und nur dann der Status gesetzt falls der Status ebenfalls false ist.
                                  • Für das Passwort Handling nutze ich jetzt die neue ioBroker Funktionalität
                                  • und diverse Änderungen unter der Haube
                                  ich habe eine neue Testversion auf Github hochgeladen. Bitte testet diese und gebt hier Rückmeldung über Probleme mit der neuen Version.
                                  Wichtigste Neuerungen sind das Ein- und Ausschalten des Gäste-WLAN. Das deaktivieren des Internetzugriffs von Geräten und ein zusätzliches Interval für Familienmitglieder.
                                  Die Eingaben auf der Konfigurationsseite werden jetzt überprüft und ggfs. das Speichern deakiviert. Im Bereich der fb-devices werden jetzt zusätzliche Mesh-Informationen angelegt, falls dies in der Konfiguration aktiviert wurde.
                                  Viel Spaß beim Testen.
                                  Gäste-WLAN ein-, ausschalten -> Datenpunkt wlan
                                  Internetzugriff ein-, ausschalten -> fb-devices Datenpunkt disabled = true (Internet aus)
                                  sigi234S Online
                                  sigi234S Online
                                  #295
                                  Hallo, was ist der Unterschied in den Familien Einstellungen Benutze IP oder Name?
                                  • sigi234S sigi234
                                    afuerhoffA Offline
                                    afuerhoffA Offline
                                    afuerhoff
                                    #296
                                    @sigi234
                                    Unabhängig von der Mac oder Ip wird der Devicename in der Fritzbox genutzt. Ist für die gedacht, die entweder die Verschleierung der Mac nicht ausschalten können oder wollen. Ich habe oben im ersten Post hierzu noch etwas hinzugefügt.
                                    • afuerhoffA Offline
                                      afuerhoffA Offline
                                      afuerhoff
                                      #297
                                      ich habe gerade ein neues Update zum Testen eingespielt. Hier wurde nur der State presentGuests (@Fenriswolf) mit hinzugefügt.
                                        FenriswolfF Offline
                                        FenriswolfF Offline
                                        Fenriswolf
                                        #298
                                        ich danke dir, genau das habe ich benötigt.
                                        • Stephan SchleichS Stephan Schleich
                                          @afuerhoff Up und Download Speed wäre auch noch ganz nice, dann könnte ,man unpn endlich weglassen 😊
                                          Edit: inklusive dem Aktualisierungsbutton
                                          Stephan SchleichS Offline
                                          Stephan Schleich
                                          schrieb am zuletzt editiert von Stephan Schleich
                                          #299
                                          @stephan-schleich said in Test Adapter fb-checkpresence v1.1.x:
                                          @afuerhoff wäre diese info auch möglich mit aufzunehmen?
                                          DSL only reconnect wäre auch nice, auch glaub den Fritzbox reboot gitbs ja bereits
