  4. Beta Test js-controller 3.2.x auf GitHub
js-controller
287 Beiträge 25 Kommentatoren 85.5k Aufrufe 29 Beobachtet
  • apollon77A apollon77
    @lobomau passt.
    lobomauL
    lobomauL
    lobomau
    #86
    @apollon77 hab mir den nächsten slave einen Pi1 vorgenommen. Diesmal zuerst den fix gestartet, aber fürhrt zum gleichen Fehler (?) wie beim Pi3. Ich mache dann gleich wieder den Schritt wie beim Pi3.
    pi@raspberrypi:~ $ cd /opt/iobroker
    pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
    pi@raspberrypi:/opt/iobroker $ sudo iobroker fix
    library: loaded
    Library version=2020-12-07
        Welcome to the ioBroker installation fixer!
        Script version: 2020-12-07
        Installing prerequisites (1/3)
    Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
    Hit:2 http://archive.raspberrypi.org/debian buster InRelease
    Reading package lists... Done
    Installed gcc-c++
        Checking ioBroker user and directory permissions (2/3)
        Checking autostart (3/3)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    pi@raspberrypi:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
    > iobroker.js-controller@3.2.4 preinstall /opt/iobroker/node_modules/iobroker.js                             -controller
    > node lib/preinstallCheck.js
    Could not check npm version: Error: Timeout
    Assuming that correct version is installed.
    > iobroker.js-controller@3.2.4 install /opt/iobroker/node_modules/iobroker.js-co                             ntroller
    > node iobroker.js setup first
    Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/io                             broker/node_modules/iobroker.js-controller/lib/setup/../../../../reinstall.js'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.                             bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
    Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
    fs.js:114
        throw err;
    Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-                             controller/lib/setup/../../tmp'
        at Object.mkdirSync (fs.js:757:3)
        at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/                             setupSetup.js:835:16)
        at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/set                             up.js:272:23)
        at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-con                             troller/lib/setup.js:2643:5)
        at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob                             roker.js:1:24)
        at Module._compile (internal/modules/cjs/loader.js:778:30)
        at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
        at Module.load (internal/modules/cjs/loader.js:653:32)
        at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
        at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/ch                             okidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                             2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                             )
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1
    npm ERR! iobroker.js-controller@3.2.4 install: `node iobroker.js setup first`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the iobroker.js-controller@3.2.4 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional log                             ging output above.
    npm ERR!     /root/.npm/_logs/2021-01-10T08_43_13_360Z-debug.log
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
    • lobomauL lobomau
      library: loaded
      Installed gcc-c++
      Autostart enabled!
      fs.js:114
          throw err;
      npm ERR! errno 1
      npm ERR!
      lobomauL
      lobomauL
      lobomau
      #87
      @apollon77 ich habe alle Geräte auf 3.2.4 angehoben und alle Adapter sind grün.
      ABER: es klappte immer nur mit
      sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
      Und der Fix brachte auch nichts.
      • Slave: Pi4
      • SBorgS
        SBorgS
        SBorg
        #88
        @apollon77 Moin Ingo, den VIS-Dateimanager kann ich unter file-DB bestätigen. Er "bastelt" da pro Klick auf den /vis.0/ - Ordner jedes mal einen neuen Slash mit an ;)
        LG SBorg ( SBorg auf GitHub)
        apollon77A sigi234S 2 Antworten Letzte Antwort
        • lobomauL lobomau
          Thomas BraunT
          Thomas BraunT
          #89
          @lobomau
          Man macht das auch ja nicht mit
          sudo npm
          oder
          sudo iobroker
          Damit haust du das ganze als root ins System! Das ist falsch.
            @lobomau
            sudo npm
            oder
            sudo iobroker
            apollon77A
            apollon77A
            #90
            @Thomas-Braun da hast du recht hab ich gar nicht gesehen gehabt ;-))
            • SBorgS SBorg
              apollon77A
              apollon77A
              #91
              @SBorg konnte es lokal nachstellen. Schaue ich nachher an
              • SBorgS SBorg
                sigi234S
                sigi234S
                #92
                @SBorg sagte in Beta Test js-controller 3.2.x auf GitHub:
                Jupp, und der Ordner Projekt ist auch weg!
                • WalW
                  WalW
                  Wal
                  #93
                  Eben mal den Controller aktualisiert, habe sonst nichts zu tun :-)
                  Ohne Fehler durchgelaufen.
                  Installierte Adapter:
                  Proxmox System:
                  Walter
                  DoorIO-Adapter
                  • SBorgS
                    SBorgS
                    SBorg
                    #94
                    Ich hatte es zwar schon lt. Anzeige im ioB bemerkt, aber er braucht wohl offensichtlich weniger RAM :)
                    Ich weiß nur gerade nicht ob der aktuelle 3.1.6 auch satte 2GB beim starten braucht, könnte aber auch dem da gerade durchgeführtem Update auf die 3.2.4 geschuldet sein...
                    WalW 1 Antwort Letzte Antwort
                      Mal andere Frage: Schaut mal ob jemand hier einejn Eintrag hat (unter "Objekte", Expertenmodus, "system.host.NAME.notifications" ... Falls das bei jemandem nicht leer ist bitte iobroker mal stoppen und in iobroker-data nach der notifications.json schauen und den Inhalt mal posten ... Danke :-)
                      #95
                      @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
                      Bitteschön, beim Server, sollte Enigma, Mihome-Vacuum gewesen sein...
                      {"restartLoop":{"count":4}}
                      mehr steht da leider nicht, hab auf den Datenpunkt mal die History angesetzt und lass mir das in der View anzeigen, bzw. einfach per Telegram schicken, wenn sich was ändert.. :-)
                        lobomauL
                        lobomauL
                        lobomau
                        #96
                        bei meinem Pi3 slave steht
                        {"restartLoop":{"count":1}}
                        notifivation.json leer:
                        pi@raspberrypi:/opt $ cd iobroker
                        pi@raspberrypi:/opt/iobroker $ cd iobroker-data
                        pi@raspberrypi:/opt/iobroker/iobroker-data $ ls
                        backup-objects  iobroker.json       objects.json      states.json
                        files           notifications.json  objects.json.bak  states.json.bak
                        pi@raspberrypi:/opt/iobroker/iobroker-data $ sudo nano notifications.json
                          GNU nano 3.2                   notifications.json
                        • Slave: Pi4
                          Thomas BraunT
                          Thomas BraunT
                          #97
                          @apollon77
                          notifications.json
                          {"system":{"restartLoop":{"system.adapter.mihome-vacuum.0":[{"message":"Restart loop detected","ts":1610197549296}],"system.adapter.zigbee.0":[{"message":"Restart loop detected","ts":1610196881536}]}}}
                            @Feuersturm was sagt „iobroker setup custom“ bei der objects databank für einen Typ? File oder redis?
                            FeuersturmF
                            FeuersturmF
                            Feuersturm
                            #98
                            Ich nutze dann wohl file :-)
                            proxmox@ioBrokerBETA:~$ iobroker setup custom
                            Current configuration:
                            - Objects database:
                              - Type: file
                            • lobomauL
                              lobomauL
                              lobomau
                              #99
                              Bei mir machen RAM und CPU folgendes. Ursache kenne ich noch nicht.
                              • Slave: Pi4
                              • SBorgS SBorg
                                WalW
                                WalW
                                Wal
                                #100
                                @SBorg ,
                                nicht schlecht dein Speicherverbrauch. Bei mir sind es ca. 200MB weniger, von 1,4GB auf 1,14GB.
                                Instanzen siehe oben, Grafana läuft auch noch im gleichen Container.
                                Walter
                                DoorIO-Adapter
                                • lobomauL lobomau
                                  apollon77A
                                  apollon77A
                                  #101
                                  @lobomau hast du vorm checken Des file iobroker gestoppt ;-))
                                    lobomauL
                                    lobomauL
                                    lobomau
                                    #102
                                    @apollon77 ja
                                    • Slave: Pi4
                                    • FeuersturmF Feuersturm
                                      - Objects database:
                                        - Type: file
                                      apollon77A
                                      apollon77A
                                      #103
                                      @Feuersturm Danke. Dachte ich mir
                                      • lobomauL lobomau
                                        apollon77A
                                        apollon77A
                                        #104
                                        @lobomau interessant. Glaube da solltest du mal auf Prozess Ebene schauen
                                          lobomauL
                                          lobomauL
                                          lobomau
                                          schrieb am zuletzt editiert von lobomau
                                          #105
                                          @apollon77 ich bin eine Erkenntnis reicher. Meine Abstürze kommen scheinbar nicht von alleine.
                                          Habe eben einen DP gestartet zu loggen mit influxDB, schon gehen RAM und CPU wieder hoch bis zum Teilabsturz.
                                          Ich lasse das mal paar Stunden laufen und probiere dann einen weitere DP zu loggen für 100% Gewissheit.
                                          Zu früh gefreut... der letzte Anstieg kam vonm alleine :-(
                                          • Slave: Pi4
                                          83.9k
