  4. Beta Test js-controller 3.2.x auf GitHub
js-controller
287 Beiträge 25 Kommentatoren 95.3k Aufrufe 29 Beobachtet
  • lobomauL lobomau
    @apollon77 ich glaube es hat geklappt:
    pi@Pi3:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
    library: loaded
    Library version=2020-12-07
    ioBroker is not installed in /opt/iobroker! Cannot fix anything...
    pi@Pi3:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-cont                                                        roller
    > iobroker.js-controller@3.2.4 preinstall /opt/iobroker/node_modules/iobroker.js                                                        -controller
    > node lib/preinstallCheck.js
    NPM version: 6.14.10
    > iobroker.js-controller@3.2.4 install /opt/iobroker/node_modules/iobroker.js-co                                                        ntroller
    > node iobroker.js setup first
    object 0_userdata.0.example_state created
    object _design/system updated
    ioBroker configuration updated
    > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
    > node scripts/postinstall
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/ch                                                        okidar/node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                                        2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                                        )
    + iobroker.js-controller@3.2.4
    added 87 packages from 45 contributors, removed 3 packages and moved 1 package i                                                        n 178.757s
    11 packages are looking for funding
      run `npm fund` for details
    pi@Pi3:/opt/iobroker $ sudo npm fund
    iobroker.inst@2.0.3
    ├─┬ https://github.com/sponsors/isaacs
    │ └── glob@7.1.6
    ├─┬ https://github.com/sponsors/epoberezkin
    │ └── ajv@6.12.3
    ├─┬ https://github.com/sponsors/RubenVerborgh
    │ └── follow-redirects@1.13.0
    ├─┬ https://github.com/sponsors/ljharb
    │ └── is-nan@1.3.0, resolve@1.17.0, has-symbols@1.0.1
    ├─┬ https://opencollective.com/ioredis
    │ └── ioredis@4.19.4
    ├─┬ https://github.com/sponsors/jonschlinkert
    │ └── picomatch@2.2.2
    ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
    │ └── wrap-ansi@7.0.0
    ├─┬ https://github.com/chalk/ansi-styles?sponsor=1
    │ └── ansi-styles@4.3.0
    ├─┬ https://github.com/sponsors/feross
    │ └── safe-buffer@5.2.1, simple-concat@1.0.1
    ├─┬ https://www.patreon.com/feross
    ├─┬ https://feross.org/support
    └─┬ https://github.com/sponsors/sindresorhus
      └── mimic-response@2.1.0
    pi@Pi3:/opt/iobroker $ sudo iobroker start
    apollon77A
    apollon77A
    #85
    @lobomau passt.
    • apollon77A apollon77
      @lobomau passt.
      lobomauL
      lobomauL
      lobomau
      #86
      @apollon77 hab mir den nächsten slave einen Pi1 vorgenommen. Diesmal zuerst den fix gestartet, aber fürhrt zum gleichen Fehler (?) wie beim Pi3. Ich mache dann gleich wieder den Schritt wie beim Pi3.
      pi@raspberrypi:~ $ cd /opt/iobroker
      pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
      pi@raspberrypi:/opt/iobroker $ sudo iobroker fix
      library: loaded
          Welcome to the ioBroker installation fixer!
          Script version: 2020-12-07
          Installing prerequisites (1/3)
      Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
      Hit:2 http://archive.raspberrypi.org/debian buster InRelease
      Reading package lists... Done
      Installed gcc-c++
          Checking ioBroker user and directory permissions (2/3)
          Checking autostart (3/3)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      pi@raspberrypi:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
      Could not check npm version: Error: Timeout
      Assuming that correct version is installed.
      Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/io                             broker/node_modules/iobroker.js-controller/lib/setup/../../../../reinstall.js'
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.                             bat'
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
      Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
      fs.js:114
          throw err;
      Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-                             controller/lib/setup/../../tmp'
          at Object.mkdirSync (fs.js:757:3)
          at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/                             setupSetup.js:835:16)
          at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/set                             up.js:272:23)
          at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-con                             troller/lib/setup.js:2643:5)
          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob                             roker.js:1:24)
          at Module._compile (internal/modules/cjs/loader.js:778:30)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
          at Module.load (internal/modules/cjs/loader.js:653:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
          at Function.Module._load (internal/modules/cjs/loader.js:585:3)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! iobroker.js-controller@3.2.4 install: `node iobroker.js setup first`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the iobroker.js-controller@3.2.4 install script.
      npm ERR! This is probably not a problem with npm. There is likely additional log                             ging output above.
      npm ERR!     /root/.npm/_logs/2021-01-10T08_43_13_360Z-debug.log
      Host: NUC8i3 mit Proxmox:
      • Slave: Pi4
      • lobomauL lobomau
        library: loaded
        Installed gcc-c++
        Autostart enabled!
        fs.js:114
            throw err;
        npm ERR! errno 1
        npm ERR!
        lobomauL
        lobomauL
        lobomau
        #87
        @apollon77 ich habe alle Geräte auf 3.2.4 angehoben und alle Adapter sind grün.
        ABER: es klappte immer nur mit
        sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
        Und der Fix brachte auch nichts.
        • Slave: Pi4
        • SBorgS
          SBorgS
          SBorg
          #88
          @apollon77 Moin Ingo, den VIS-Dateimanager kann ich unter file-DB bestätigen. Er "bastelt" da pro Klick auf den /vis.0/ - Ordner jedes mal einen neuen Slash mit an ;)
          LG SBorg ( SBorg auf GitHub)
          apollon77A sigi234S 2 Antworten Letzte Antwort
          • lobomauL lobomau
            Thomas BraunT
            Thomas BraunT
            Most Active Developer
            #89
            @lobomau
            Man macht das auch ja nicht mit
            sudo npm
            oder
            sudo iobroker
            Damit haust du das ganze als root ins System! Das ist falsch.
              @lobomau
              sudo npm
              oder
              sudo iobroker
              apollon77A
              apollon77A
              #90
              @Thomas-Braun da hast du recht hab ich gar nicht gesehen gehabt ;-))
              • SBorgS SBorg
                apollon77A
                apollon77A
                #91
                @SBorg konnte es lokal nachstellen. Schaue ich nachher an
                • SBorgS SBorg
                  sigi234S
                  sigi234S
                  #92
                  @SBorg sagte in Beta Test js-controller 3.2.x auf GitHub:
                  Jupp, und der Ordner Projekt ist auch weg!
                  • WalW
                    WalW
                    Wal
                    #93
                    Eben mal den Controller aktualisiert, habe sonst nichts zu tun :-)
                    Ohne Fehler durchgelaufen.
                    Installierte Adapter:
                    Proxmox System:
                    Walter
                    DoorIO-Adapter
                    • SBorgS
                      SBorgS
                      SBorg
                      #94
                      Ich hatte es zwar schon lt. Anzeige im ioB bemerkt, aber er braucht wohl offensichtlich weniger RAM :)
                      Ich weiß nur gerade nicht ob der aktuelle 3.1.6 auch satte 2GB beim starten braucht, könnte aber auch dem da gerade durchgeführtem Update auf die 3.2.4 geschuldet sein...
                      WalW 1 Antwort Letzte Antwort
                        Mal andere Frage: Schaut mal ob jemand hier einejn Eintrag hat (unter "Objekte", Expertenmodus, "system.host.NAME.notifications" ... Falls das bei jemandem nicht leer ist bitte iobroker mal stoppen und in iobroker-data nach der notifications.json schauen und den Inhalt mal posten ... Danke :-)
                        #95
                        @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
                        Bitteschön, beim Server, sollte Enigma, Mihome-Vacuum gewesen sein...
                        {"restartLoop":{"count":4}}
                        mehr steht da leider nicht, hab auf den Datenpunkt mal die History angesetzt und lass mir das in der View anzeigen, bzw. einfach per Telegram schicken, wenn sich was ändert.. :-)
                          lobomauL
                          lobomauL
                          lobomau
                          #96
                          bei meinem Pi3 slave steht
                          {"restartLoop":{"count":1}}
                          notifivation.json leer:
                          pi@raspberrypi:/opt $ cd iobroker
                          pi@raspberrypi:/opt/iobroker $ cd iobroker-data
                          pi@raspberrypi:/opt/iobroker/iobroker-data $ ls
                          backup-objects  iobroker.json       objects.json      states.json
                          files           notifications.json  objects.json.bak  states.json.bak
                          pi@raspberrypi:/opt/iobroker/iobroker-data $ sudo nano notifications.json
                            GNU nano 3.2                   notifications.json
                          • Slave: Pi4
                            Thomas BraunT
                            Thomas BraunT
                            #97
                            @apollon77
                            notifications.json
                            {"system":{"restartLoop":{"system.adapter.mihome-vacuum.0":[{"message":"Restart loop detected","ts":1610197549296}],"system.adapter.zigbee.0":[{"message":"Restart loop detected","ts":1610196881536}]}}}
                              @Feuersturm was sagt „iobroker setup custom“ bei der objects databank für einen Typ? File oder redis?
                              FeuersturmF
                              FeuersturmF
                              Feuersturm
                              #98
                              Ich nutze dann wohl file :-)
                              proxmox@ioBrokerBETA:~$ iobroker setup custom
                              Current configuration:
                              - Objects database:
                                - Type: file
                              • lobomauL
                                lobomauL
                                lobomau
                                #99
                                Bei mir machen RAM und CPU folgendes. Ursache kenne ich noch nicht.
                                • Slave: Pi4
                                • SBorgS SBorg
                                  WalW
                                  WalW
                                  Wal
                                  #100
                                  @SBorg ,
                                  nicht schlecht dein Speicherverbrauch. Bei mir sind es ca. 200MB weniger, von 1,4GB auf 1,14GB.
                                  Instanzen siehe oben, Grafana läuft auch noch im gleichen Container.
                                  Walter
                                  DoorIO-Adapter
                                  • lobomauL lobomau
                                    apollon77A
                                    apollon77A
                                    #101
                                    @lobomau hast du vorm checken Des file iobroker gestoppt ;-))
                                      lobomauL
                                      lobomauL
                                      lobomau
                                      #102
                                      @apollon77 ja
                                      • Slave: Pi4
                                      • FeuersturmF Feuersturm
                                        - Objects database:
                                          - Type: file
                                        apollon77A
                                        apollon77A
                                        #103
                                        @Feuersturm Danke. Dachte ich mir
                                        • lobomauL lobomau
                                          apollon77A
                                          apollon77A
                                          #104
                                          @lobomau interessant. Glaube da solltest du mal auf Prozess Ebene schauen
                                          84.1k
