  4. Beta Test js-controller 3.2.x auf GitHub
js-controller
287 Beiträge 25 Kommentatoren 96.5k Aufrufe 29 Beobachtet
  • apollon77A apollon77
    @lobomau iobroker fix bitte, dann nochmal versuchen. Danke
    lobomauL
    lobomauL
    lobomau
    schrieb am zuletzt editiert von lobomau
    #83
    @apollon77 hab ich kein ioBroker mehr!?
    der zweite Befehl mit fix.sh hatte auch nicht geklappt.
    Nun läuft gerade durch:
    sudo -H -u iobroker npm install ioBroker/ioBroker.js-controller
    Host: NUC8i3 mit Proxmox:
    • Slave: Pi4
    • lobomauL lobomau
      lobomauL
      lobomauL
      lobomau
      #84
      @apollon77 ich glaube es hat geklappt:
      pi@Pi3:/opt/iobroker $ curl -sL https://iobroker.net/fix.sh | bash -
      library: loaded
      Library version=2020-12-07
      ioBroker is not installed in /opt/iobroker! Cannot fix anything...
      pi@Pi3:/opt/iobroker $ sudo -H -u iobroker npm install ioBroker/ioBroker.js-cont                                                        roller
      > iobroker.js-controller@3.2.4 preinstall /opt/iobroker/node_modules/iobroker.js                                                        -controller
      > node lib/preinstallCheck.js
      NPM version: 6.14.10
      > iobroker.js-controller@3.2.4 install /opt/iobroker/node_modules/iobroker.js-co                                                        ntroller
      > node iobroker.js setup first
      object 0_userdata.0.example_state created
      object _design/system updated
      ioBroker configuration updated
      > @root/acme@3.1.0 postinstall /opt/iobroker/node_modules/@root/acme
      > node scripts/postinstall
      npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@~2.3.1 (node_modules/ch                                                        okidar/node_modules/fsevents):
      npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@                                                        2.3.1: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}                                                        )
      + iobroker.js-controller@3.2.4
      added 87 packages from 45 contributors, removed 3 packages and moved 1 package i                                                        n 178.757s
      11 packages are looking for funding
        run `npm fund` for details
      pi@Pi3:/opt/iobroker $ sudo npm fund
      iobroker.inst@2.0.3
      ├─┬ https://github.com/sponsors/isaacs
      │ └── glob@7.1.6
      ├─┬ https://github.com/sponsors/epoberezkin
      │ └── ajv@6.12.3
      ├─┬ https://github.com/sponsors/RubenVerborgh
      │ └── follow-redirects@1.13.0
      ├─┬ https://github.com/sponsors/ljharb
      │ └── is-nan@1.3.0, resolve@1.17.0, has-symbols@1.0.1
      ├─┬ https://opencollective.com/ioredis
      │ └── ioredis@4.19.4
      ├─┬ https://github.com/sponsors/jonschlinkert
      │ └── picomatch@2.2.2
      ├─┬ https://github.com/chalk/wrap-ansi?sponsor=1
      │ └── wrap-ansi@7.0.0
      ├─┬ https://github.com/chalk/ansi-styles?sponsor=1
      │ └── ansi-styles@4.3.0
      ├─┬ https://github.com/sponsors/feross
      │ └── safe-buffer@5.2.1, simple-concat@1.0.1
      ├─┬ https://www.patreon.com/feross
      ├─┬ https://feross.org/support
      └─┬ https://github.com/sponsors/sindresorhus
        └── mimic-response@2.1.0
      pi@Pi3:/opt/iobroker $ sudo iobroker start
      • Slave: Pi4
      • lobomauL lobomau
        library: loaded
        iobroker.inst@2.0.3
        │ └── glob@7.1.6
        │ └── ajv@6.12.3
        apollon77A
        apollon77A
        #85
        @lobomau passt.
          @lobomau passt.
          lobomauL
          lobomauL
          lobomau
          #86
          @apollon77 hab mir den nächsten slave einen Pi1 vorgenommen. Diesmal zuerst den fix gestartet, aber fürhrt zum gleichen Fehler (?) wie beim Pi3. Ich mache dann gleich wieder den Schritt wie beim Pi3.
          pi@raspberrypi:~ $ cd /opt/iobroker
          pi@raspberrypi:/opt/iobroker $ sudo iobroker stop
          pi@raspberrypi:/opt/iobroker $ sudo iobroker fix
          library: loaded
              Welcome to the ioBroker installation fixer!
              Script version: 2020-12-07
              Installing prerequisites (1/3)
          Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
          Hit:2 http://archive.raspberrypi.org/debian buster InRelease
          Reading package lists... Done
          Installed gcc-c++
              Checking ioBroker user and directory permissions (2/3)
              Checking autostart (3/3)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          pi@raspberrypi:/opt/iobroker $ sudo npm install ioBroker/ioBroker.js-controller
          Could not check npm version: Error: Timeout
          Assuming that correct version is installed.
          Cannot write file. Not critical: Error: EACCES: permission denied, open '/opt/io                             broker/node_modules/iobroker.js-controller/lib/setup/../../../../reinstall.js'
          Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../_service_iobroker.                             bat'
          Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iobroker.bat'
          Cannot delete file. Not critical: Error: EACCES: permission denied, unlink '/opt                             /iobroker/node_modules/iobroker.js-controller/lib/setup/../../iob.bat'
          fs.js:114
              throw err;
          Error: EACCES: permission denied, mkdir '/opt/iobroker/node_modules/iobroker.js-                             controller/lib/setup/../../tmp'
              at Object.mkdirSync (fs.js:757:3)
              at Setup.setup (/opt/iobroker/node_modules/iobroker.js-controller/lib/setup/                             setupSetup.js:835:16)
              at processCommand (/opt/iobroker/node_modules/iobroker.js-controller/lib/set                             up.js:272:23)
              at Object.module.exports.execute (/opt/iobroker/node_modules/iobroker.js-con                             troller/lib/setup.js:2643:5)
              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iob                             roker.js:1:24)
              at Module._compile (internal/modules/cjs/loader.js:778:30)
              at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
              at Module.load (internal/modules/cjs/loader.js:653:32)
              at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
              at Function.Module._load (internal/modules/cjs/loader.js:585:3)
          npm ERR! code ELIFECYCLE
          npm ERR! errno 1
          npm ERR! iobroker.js-controller@3.2.4 install: `node iobroker.js setup first`
          npm ERR! Exit status 1
          npm ERR!
          npm ERR! Failed at the iobroker.js-controller@3.2.4 install script.
          npm ERR! This is probably not a problem with npm. There is likely additional log                             ging output above.
          npm ERR!     /root/.npm/_logs/2021-01-10T08_43_13_360Z-debug.log
          • Slave: Pi4
          • lobomauL lobomau
            library: loaded
            Installed gcc-c++
            Autostart enabled!
            fs.js:114
                throw err;
            npm ERR! errno 1
            npm ERR!
            lobomauL
            lobomauL
            lobomau
            #87
            @apollon77 ich habe alle Geräte auf 3.2.4 angehoben und alle Adapter sind grün.
            ABER: es klappte immer nur mit
            Und der Fix brachte auch nichts.
            • Slave: Pi4
            • SBorgS
              SBorgS
              SBorg
              #88
              @apollon77 Moin Ingo, den VIS-Dateimanager kann ich unter file-DB bestätigen. Er "bastelt" da pro Klick auf den /vis.0/ - Ordner jedes mal einen neuen Slash mit an ;)
              LG SBorg ( SBorg auf GitHub)
              apollon77A sigi234S 2 Antworten Letzte Antwort
              • lobomauL lobomau
                Thomas BraunT
                Thomas BraunT
                Most Active Developer
                #89
                @lobomau
                Man macht das auch ja nicht mit
                sudo npm
                oder
                sudo iobroker
                Damit haust du das ganze als root ins System! Das ist falsch.
                  @lobomau
                  sudo npm
                  oder
                  sudo iobroker
                  apollon77A
                  apollon77A
                  #90
                  @Thomas-Braun da hast du recht hab ich gar nicht gesehen gehabt ;-))
                  • SBorgS SBorg
                    apollon77A
                    apollon77A
                    #91
                    @SBorg konnte es lokal nachstellen. Schaue ich nachher an
                    • SBorgS SBorg
                      sigi234S
                      sigi234S
                      #92
                      @SBorg sagte in Beta Test js-controller 3.2.x auf GitHub:
                      Jupp, und der Ordner Projekt ist auch weg!
                      • WalW
                        WalW
                        Wal
                        #93
                        Eben mal den Controller aktualisiert, habe sonst nichts zu tun :-)
                        Ohne Fehler durchgelaufen.
                        Installierte Adapter:
                        Proxmox System:
                        Walter
                        DoorIO-Adapter
                        • SBorgS
                          SBorgS
                          SBorg
                          #94
                          Ich hatte es zwar schon lt. Anzeige im ioB bemerkt, aber er braucht wohl offensichtlich weniger RAM :)
                          Ich weiß nur gerade nicht ob der aktuelle 3.1.6 auch satte 2GB beim starten braucht, könnte aber auch dem da gerade durchgeführtem Update auf die 3.2.4 geschuldet sein...
                          WalW 1 Antwort Letzte Antwort
                            Mal andere Frage: Schaut mal ob jemand hier einejn Eintrag hat (unter "Objekte", Expertenmodus, "system.host.NAME.notifications" ... Falls das bei jemandem nicht leer ist bitte iobroker mal stoppen und in iobroker-data nach der notifications.json schauen und den Inhalt mal posten ... Danke :-)
                            #95
                            @apollon77 sagte in Beta Test js-controller 3.2.x auf GitHub:
                            Bitteschön, beim Server, sollte Enigma, Mihome-Vacuum gewesen sein...
                            {"restartLoop":{"count":4}}
                            mehr steht da leider nicht, hab auf den Datenpunkt mal die History angesetzt und lass mir das in der View anzeigen, bzw. einfach per Telegram schicken, wenn sich was ändert.. :-)
                              lobomauL
                              lobomauL
                              lobomau
                              #96
                              bei meinem Pi3 slave steht
                              {"restartLoop":{"count":1}}
                              notifivation.json leer:
                              pi@raspberrypi:/opt $ cd iobroker
                              pi@raspberrypi:/opt/iobroker $ cd iobroker-data
                              pi@raspberrypi:/opt/iobroker/iobroker-data $ ls
                              backup-objects  iobroker.json       objects.json      states.json
                              files           notifications.json  objects.json.bak  states.json.bak
                              pi@raspberrypi:/opt/iobroker/iobroker-data $ sudo nano notifications.json
                                GNU nano 3.2                   notifications.json
                              • Slave: Pi4
                                Thomas BraunT
                                Thomas BraunT
                                #97
                                @apollon77
                                notifications.json
                                {"system":{"restartLoop":{"system.adapter.mihome-vacuum.0":[{"message":"Restart loop detected","ts":1610197549296}],"system.adapter.zigbee.0":[{"message":"Restart loop detected","ts":1610196881536}]}}}
                                  @Feuersturm was sagt „iobroker setup custom“ bei der objects databank für einen Typ? File oder redis?
                                  FeuersturmF
                                  FeuersturmF
                                  Feuersturm
                                  #98
                                  Ich nutze dann wohl file :-)
                                  proxmox@ioBrokerBETA:~$ iobroker setup custom
                                  Current configuration:
                                  - Objects database:
                                    - Type: file
                                  • lobomauL
                                    lobomauL
                                    lobomau
                                    #99
                                    Bei mir machen RAM und CPU folgendes. Ursache kenne ich noch nicht.
                                    • Slave: Pi4
                                    • SBorgS SBorg
                                      WalW
                                      WalW
                                      Wal
                                      #100
                                      @SBorg ,
                                      nicht schlecht dein Speicherverbrauch. Bei mir sind es ca. 200MB weniger, von 1,4GB auf 1,14GB.
                                      Instanzen siehe oben, Grafana läuft auch noch im gleichen Container.
                                      Walter
                                      DoorIO-Adapter
                                      • lobomauL lobomau
                                        apollon77A
                                        apollon77A
                                        #101
                                        @lobomau hast du vorm checken Des file iobroker gestoppt ;-))
                                          lobomauL
                                          lobomauL
                                          lobomau
                                          #102
                                          @apollon77 ja
                                          • Slave: Pi4
                                          84.1k
