  4. Test Adapter Adapter-fritzdect v2.1.x GitHub
fritzdect
197 Beiträge 24 Kommentatoren 43.5k Aufrufe 24 Beobachtet
  • F foxthefox
    @Chaot
    habe eine 2.1.2 ohne info.connection erstellt
    ChaotC Offline
    ChaotC Offline
    Chaot
    @foxthefox Adapter ist noch gelb (falls du das gemeint hast)
    Ansonsten sieht alles normal aus bisher:
    fritzdect.0	2021-01-04 14:57:42.750	info	(26143) setting up thermostat nextchange
    fritzdect.0	2021-01-04 14:57:42.736	info	(26143) setting up thermostat
    fritzdect.0	2021-01-04 14:57:42.734	info	(26143) setting up groupinfo
    fritzdect.0	2021-01-04 14:57:42.731	info	(26143) CREATE groups 1
    fritzdect.0	2021-01-04 14:57:42.725	info	(26143) setting up thermostat nextchange
    fritzdect.0	2021-01-04 14:57:42.710	info	(26143) setting up thermostat
    fritzdect.0	2021-01-04 14:57:42.709	info	(26143) setting up temperatur
    fritzdect.0	2021-01-04 14:57:42.702	info	(26143) setting up thermostat nextchange
    fritzdect.0	2021-01-04 14:57:42.684	info	(26143) setting up thermostat
    fritzdect.0	2021-01-04 14:57:42.682	info	(26143) setting up temperatur
    fritzdect.0	2021-01-04 14:57:42.672	info	(26143) setting up thermostat nextchange
    fritzdect.0	2021-01-04 14:57:42.653	info	(26143) setting up thermostat
    fritzdect.0	2021-01-04 14:57:42.652	info	(26143) setting up temperatur
    fritzdect.0	2021-01-04 14:57:42.644	info	(26143) setting up thermostat nextchange
    fritzdect.0	2021-01-04 14:57:42.625	info	(26143) setting up thermostat
    fritzdect.0	2021-01-04 14:57:42.623	info	(26143) setting up temperatur
    fritzdect.0	2021-01-04 14:57:42.616	info	(26143) setting up thermostat nextchange
    fritzdect.0	2021-01-04 14:57:42.603	info	(26143) setting up thermostat
    fritzdect.0	2021-01-04 14:57:42.601	info	(26143) setting up temperatur
    fritzdect.0	2021-01-04 14:57:42.593	info	(26143) setting up thermostat nextchange
    fritzdect.0	2021-01-04 14:57:42.572	info	(26143) setting up thermostat
    fritzdect.0	2021-01-04 14:57:42.570	info	(26143) setting up temperatur
    fritzdect.0	2021-01-04 14:57:42.560	info	(26143) setting up thermostat nextchange
    fritzdect.0	2021-01-04 14:57:42.539	info	(26143) setting up thermostat
    fritzdect.0	2021-01-04 14:57:42.537	info	(26143) setting up temperatur
    fritzdect.0	2021-01-04 14:57:42.512	info	(26143) CREATE Devices 7
    fritzdect.0	2021-01-04 14:57:42.204	info	(26143) fritzdect entered ready
    fritzdect.0	2021-01-04 14:57:42.177	info	(26143) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.20.0, js-controller: 3.1.6
    host.ioBroker	2021-01-04 14:57:40.786	info	instance system.adapter.fritzdect.0 started with pid 26143
    F 1 Antwort Letzte Antwort
    • E ente34
      Ich habe eine DECT200 Steckdose, die nicht erreichbar ist (Schublade).
      Für mich sieht es so aus, als würde er dann die Schleife abbrechen,
      jedenfalls erhalten die nachfolgenden DECT-Devices keine Istwerte mehr
      Kann das sein?
      Sind Logfiles gewünscht?
      foxthefox
      @ente34
      das sollte nicht passieren.
      Ich bräuchte dann mal den output von "Meine Geräte"
      Logs ggf. später
      Adapterüberblick: Profil Github;
      Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
      Ein Aufruf: video
      E 1 Antwort Letzte Antwort
      • F foxthefox
        @ente34
        Logs ggf. später
        ente34
        @foxthefox sagte in Test Adapter Adapter-fritzdect v2.1.x GitHub:
        "Meine Geräte"
        Sorry, was meinst Du mit "Meine Geräte"?
        • E ente34
          "Meine Geräte"
          foxthefox
          @ente34
          in den Einstellungen zum Adapter gibt es eine Taste:
          Ein Aufruf: video
          • F foxthefox
            @ente34
            ente34
            @foxthefox Meine Geräte.txt
            Hier
            • E ente34
              Hier
              foxthefox
              @ente34
              OK
              wenn present=0 für ein Gerät gemeldet wird, dann wird das update Übersprungen.
              Hatte hier allerdings alles abgebrochen und nicht nur das Gerät.
              Sollte mit der 2.1.3 von GitHub nun gehen.
              Ein Aufruf: video
              • ChaotC Chaot
                foxthefox
                @Chaot sagte in Test Adapter Adapter-fritzdect v2.1.x GitHub:
                das hängt höchstwahrscheinlich mit den weiterhin vorhandenen Objektbaum zusammen.
                nur die Instanz löschen und neu erstellen sollte es bereinigen.
                Ein Aufruf: video
                • F foxthefox
                  @ente34
                  OK
                  ente34
                  @foxthefox
                  Das ging ja schnell, sieht jetzt besser aus!
                  Hier noch eine Bitte um Erweiterung, kann man einen Datenpunkt "DeviceInUse" oder ähnlich einbauen?
                  Bislang bringt das nicht erreichbare Device alle 5 Minuten eine Warning ins logfile (Habe dann den Adapter Loglevel auf "error" gesetzt)
                  • E ente34
                    @foxthefox
                    foxthefox
                    schrieb am zuletzt editiert von foxthefox
                    @ente34
                    eigentlich sollte es keine Warnung mehr geben.
                    Früher war es eine Warnung für present=0, habe es jetzt aber auf Debug umgestellt.
                    Wenn also der Loglevel wieder auf info steht, müsstest du nicht sehen. Außer die info,warn,errors.
                    Kannst du aus dem Log mal die Meldung posten?
                    Ein Aufruf: video
                    • F foxthefox
                      @ente34
                      ente34
                      @foxthefox
                      Ich nehme alles zurück und behaupte das Gegenteil.
                      Versehentlich in der Produktiv-Instanz mit dem alten Adapter geschaut.
                      Off Topic: Das mit der vis Abhängigkeit (anderer Thread) hat mich auch gewundert, ich hatte auf dem Testsystem nämlich auch keine vis.
                      Vielen Dank für den Support!
                      • E ente34
                        @foxthefox
                        foxthefox
                        @ente34
                        das mit der VIS Abhängigkeit kam vom adapter-creator und man denkt sich manchmal nicht viel dabei.
                        mit 2.1.4 sollte es heraus sein (kein Abhängigkeit mehr)
                        Ein Aufruf: video
                        E 2 Antworten Letzte Antwort
                        • F foxthefox
                          @ente34
                          ente34
                          @foxthefox
                          In der Zwischenzeit habe ich zwei log errors bekommen:
                          fritzdect.0	2021-01-04 17:01:11.819	error	(10360) no response part in returned message
                          fritzdect.0	2021-01-04 17:01:11.819	error	(10360) fritzbox returned this {"msg":"get error in http request","function":"get_login_state","error":{"errno":"ENETUNREACH","code":"ENETUNREACH","syscall":"connect","address":"192.168.168.1","port"
                          backitup.0	2021-01-04 17:01:11.787	debug	(19236) system.adapter.admin.0: logging false
                          backitup.0	2021-01-04 16:50:23.835	debug	(19236) system.adapter.admin.0: logging true
                          host.NB03490	2021-01-04 16:50:11.145	info	Update repository "Beta (latest)" under "http://download.iobroker.net/sources-dist-latest.json"
                          backitup.0	2021-01-04 16:44:16.788	debug	(19236) system.adapter.admin.0: logging false
                          info.0	2021-01-04 16:44:16.582	error	(4952) Error: getaddrinfo ENOTFOUND raw.githubusercontent.com
                          fritzdect.0	2021-01-04 16:44:14.793	error	(10360) no response part in returned message
                          fritzdect.0	2021-01-04 16:44:14.792	error	(10360) fritzbox returned this {"msg":"get error in http request","function":"get_login_state","error":{"errno":"ENETUNREACH","code":"ENETUNREACH","syscall":"connect","address":"192.168.168.1","port"
                          • F foxthefox
                            ChaotC Offline
                            ChaotC Offline
                            Chaot
                            @foxthefox Danke.
                            Objektbaum löschen hat gereicht.
                            • F foxthefox
                              Aktuelle Test Version 2.1.7
                              Veröffentlichungsdatum 03.01.2021
                              Github Link https://github.com/foxthefox/ioBroker.fritzdect
                              Changes
                              Habe den Adapter komplett überarbeitet:
                              • auf klassenbasierte Struktur umgestellt
                              • die Routinen komplett überarbeitet (hälfte des Codes)
                              • eine neue API für die Fritzbox erstellt, damit ab 7.25 auch mit dem neuen Verschlüsselungsverfahren ein login möglich ist
                              • DECT500 und ihre Gruppen sind enthalten
                              • Rolladensteuerung ist drin
                              • DECT440 hat nun untergeordnete Buttons
                              • wenn es neue Datenpunkte seitens der fritzbox gibt, wird eine Warnung ausgegeben
                              BREAKING Change!
                              Durch die Überarbeitung sind nun alle Objekte mit DECT_ ohne irgendwelche Zusätze mit 200 o.ä.
                              Am Anfang gab es nur die Steckdose und Thermostat und nun ist es überholt.
                              des Weiteren sind die Datenpunkte nun mit den Namen aus der Fritzbox-API gleich. Das vereinfacht das Einlesen und Update ungemein.
                              Ich hoffe es funktioniert soweit alles noch (ich habe nur DECT200 und DECT300 und da scheint es OK).
                              Klaus
                              PS. mit der Ampel muß ich noch schauen, ob ich das so richtig interpretiert habe.
                              stefande
                              @foxthefox
                              Bei mir wird eine neue Objektstruktur angelegt unter:
                              fritzdect.0.08761046xxx
                              vorher:
                              fritzdect.0.DECT200_08761046xxx
                              • E ente34
                                @foxthefox
                                foxthefox
                                @ente34 sagte in Test Adapter Adapter-fritzdect v2.1.x GitHub:
                                ENETUNREACH
                                dürfte nicht zwingend was mit dem Adapter zu tun haben, wenn das Netz nicht erreichbar ist.
                                Da solltest du mal dein Netzwerk beobachten.
                                Ein Aufruf: video
                                • S stefande
                                  @foxthefox
                                  vorher:
                                  foxthefox
                                  @stefande
                                  das kann ich irgendwie nicht nachvollziehen.
                                  die states haben bei mir statisch immer ein 'DECT_' beim erzeugen drin.
                                  Welche Schritte hast du den durchgeführt um auf die neue Version zu kommen?
                                  Ein Aufruf: video
                                  • F foxthefox
                                    @stefande
                                    stefande
                                    @stefande
                                    Mir wurde heute Morgen die Version 2.0.0 in latest angeboten. Die hab ich installiert.
                                    Der Adapter ist dann neu gestartet, allerdings konnte ich über die Vis nichts mehr steuern, und die Stromwerte wurden auch nicht mehr aktualisiert. Inzwischen hatte ich die 2.1.4 installiert, ohne Verbesserung.
                                    Mir ist dann aufgefallen, dass ich das Gerät jetzt zweimal im Objektbaum habe. Einmal mit und einmal ohne DECT_.
                                    Mit Adapter Version 2.x werden die States ohne DECT_ aktualisiert - Mit einer Version 1.x wie ursprünglich die States mit DECT_.
                                    Bin jetzt wieder auf 1.x zurück gegangen, da ich einige Werte protokolliere.
                                    • S stefande
                                      @stefande
                                      foxthefox
                                      @stefande
                                      mit 2.x ist die Struktur eine Neue!
                                      es fängt alles mit DECT_ an. Nichts mehr mit DECT200_ oder Comet_ oder so ähnlich.
                                      Das war am Anfang evtl. mal richtig, aber mittlerweile überholt.
                                      Somit ist auch erklärbar, warum in vis manches nicht mehr sichtbar ist, da die neuen Datenpunkte in vis nachgezogen werden müssen.
                                      Ein Aufruf: video
                                      • F foxthefox
                                        @stefande
                                        stefande
                                        @stefande
                                        Das ist aber doof! Es muss dann nicht nur in der Vis sondern auch in Iqontrol, Float geändert werden, und die alten Daten in der Historie sind auch wech.
                                        Mir ist auch noch aufgefallen, dass die Datenpunkte Temp und Temp Offset auch geändert wurden.
                                        F ? liv-in-skyL ChaotC 4 Antworten Letzte Antwort
                                        • S stefande
                                          @stefande
                                          foxthefox
                                          @stefande
                                          Ich habe den gesamten code neu strukturiert, da es nicht mehr handhabbar war.
                                          Da die Datenpunkte auch noch anders benutzt waren, als die API es liefert, wurde es zusätzlich schwieriger.
                                          Mit der Adaption auf die Namen aus der API macht es sich alles viel einfacher beim Update.
                                          Und ja, es ist blöd mit einem breaking change, aber nur so lässt sich der code noch irgendwie warten. Es kommen ja immer mehr Dinge dazu und die universelle Struktur, die nun implementiert ist, lässt dies besser zu.
                                          Ein Aufruf: video
