  4. Test Adapter Adapter-fritzdect v2.1.x GitHub
fritzdect
197 Beiträge 24 Kommentatoren 43.4k Aufrufe 24 Beobachtet
  • ChaotC Chaot
    @foxthefox Wenn ich den Button "My Colours" klicke kommt:
    fritzdect.0	2021-01-04 11:28:29.709	error	(5147) unhandled promise rejection: undefined
    Unhandled	2021-01-04 11:28:29.707	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    Adapter bleibt momentan gelb.
    fritzdect.0	2021-01-04 11:33:20.894	info	(12777) setting up thermostat nextchange
    fritzdect.0	2021-01-04 11:33:20.865	info	(12777) setting up thermostat
    fritzdect.0	2021-01-04 11:33:20.863	info	(12777) setting up groupinfo
    fritzdect.0	2021-01-04 11:33:20.860	info	(12777) CREATE groups 1
    fritzdect.0	2021-01-04 11:33:20.853	info	(12777) setting up thermostat nextchange
    fritzdect.0	2021-01-04 11:33:20.826	info	(12777) setting up thermostat
    fritzdect.0	2021-01-04 11:33:20.825	info	(12777) setting up temperatur
    fritzdect.0	2021-01-04 11:33:20.812	info	(12777) setting up thermostat nextchange
    fritzdect.0	2021-01-04 11:33:20.793	info	(12777) setting up thermostat
    fritzdect.0	2021-01-04 11:33:20.792	info	(12777) setting up temperatur
    fritzdect.0	2021-01-04 11:33:20.783	info	(12777) setting up thermostat nextchange
    fritzdect.0	2021-01-04 11:33:20.762	info	(12777) setting up thermostat
    fritzdect.0	2021-01-04 11:33:20.761	info	(12777) setting up temperatur
    fritzdect.0	2021-01-04 11:33:20.752	info	(12777) setting up thermostat nextchange
    fritzdect.0	2021-01-04 11:33:20.727	info	(12777) setting up thermostat
    fritzdect.0	2021-01-04 11:33:20.724	info	(12777) setting up temperatur
    fritzdect.0	2021-01-04 11:33:20.705	info	(12777) setting up thermostat nextchange
    fritzdect.0	2021-01-04 11:33:20.677	info	(12777) setting up thermostat
    fritzdect.0	2021-01-04 11:33:20.674	info	(12777) setting up temperatur
    fritzdect.0	2021-01-04 11:33:20.664	info	(12777) setting up thermostat nextchange
    fritzdect.0	2021-01-04 11:33:20.634	info	(12777) setting up thermostat
    fritzdect.0	2021-01-04 11:33:20.631	info	(12777) setting up temperatur
    fritzdect.0	2021-01-04 11:33:20.615	info	(12777) setting up thermostat nextchange
    fritzdect.0	2021-01-04 11:33:20.577	info	(12777) setting up thermostat
    fritzdect.0	2021-01-04 11:33:20.574	info	(12777) setting up temperatur
    fritzdect.0	2021-01-04 11:33:20.523	info	(12777) CREATE Devices 7
    fritzdect.0	2021-01-04 11:33:20.187	info	(12777) fritzdect entered ready
    fritzdect.0	2021-01-04 11:33:20.144	info	(12777) starting. Version 2.1.1 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.20.0, js-controller: 3.1.6
    host.ioBroker	2021-01-04 11:33:18.720	info	instance system.adapter.fritzdect.0 started with pid 12777
    host.ioBroker	2021-01-04 11:33:18.582	info	"system.adapter.fritzdect.0" enabled
    Verbunden mit Fritzdect---- false
    foxthefox
    @Chaot
    das mit den Farben schmeiße ich bestimmt wieder raus.
    Habe keine Idee was ich da und vor allem wann setzen soll :-(
    War aus dem adapter-creator mit dabei und hab da was versucht, eh es verwirrt kommt es raus.
    Theoretisch ist der adapter online, ist aber immer nur für kurze Zeit mit der Fritzbox verbunden und das lässt sich evtl. so nicht abbilden.
    Die Colors sind ohnehin etwas problematisch und noch nicht fertig. Die kann ich derzeitig nicht nach JSON wandeln, da das Format von der Fritzbox irgendwie blöd ist. Deswegen übergebe ich direkt das XML als Resultat und das mag ggf. das sendTo nicht.
    Also ggf. ein externer Fehler wegen inkompatiblen Format??!
    Aber schön zu wissen, daß die anderen gehen.
    Adapterüberblick: Profil Github;
    Wenn der Adapter gefällt und nützlich ist, bitte ins Repo gehen und Star setzen. Danke
    Ein Aufruf: video
    • F foxthefox
      @Chaot
      ChaotC Offline
      ChaotC Offline
      Chaot
      @foxthefox Was soll das eigentlich sein mit den Farben?
      F 1 Antwort Letzte Antwort
      • ChaotC Chaot
        foxthefox
        @Chaot
        ich habe einen Datenpunkt info.connection, der macht wohl den Zustand Verbunden = false, und somit wir der Adapter gelb.
        Bei zyklischen Polling macht es ggf. keinen Sinn den Verbindungsstatus zur Fritzbox zu zeigen.
        Ein Aufruf: video
        • F foxthefox
          @Chaot
          ChaotC Offline
          ChaotC Offline
          Chaot
          @foxthefox Ich denke mal das das wirklich keiner braucht. Einmaliger Verbindungstest beim Einrichten ist ja drin.
          • ChaotC Chaot
            foxthefox
            @Chaot
            habe eine 2.1.2 ohne info.connection erstellt
            Ein Aufruf: video
            • E Offline
              ente34
              Ich habe eine DECT200 Steckdose, die nicht erreichbar ist (Schublade).
              Für mich sieht es so aus, als würde er dann die Schleife abbrechen,
              jedenfalls erhalten die nachfolgenden DECT-Devices keine Istwerte mehr
              Kann das sein?
              Sind Logfiles gewünscht?
              • F foxthefox
                @Chaot
                ChaotC Offline
                ChaotC Offline
                Chaot
                @foxthefox Adapter ist noch gelb (falls du das gemeint hast)
                Ansonsten sieht alles normal aus bisher:
                fritzdect.0	2021-01-04 14:57:42.750	info	(26143) setting up thermostat nextchange
                fritzdect.0	2021-01-04 14:57:42.736	info	(26143) setting up thermostat
                fritzdect.0	2021-01-04 14:57:42.734	info	(26143) setting up groupinfo
                fritzdect.0	2021-01-04 14:57:42.731	info	(26143) CREATE groups 1
                fritzdect.0	2021-01-04 14:57:42.725	info	(26143) setting up thermostat nextchange
                fritzdect.0	2021-01-04 14:57:42.710	info	(26143) setting up thermostat
                fritzdect.0	2021-01-04 14:57:42.709	info	(26143) setting up temperatur
                fritzdect.0	2021-01-04 14:57:42.702	info	(26143) setting up thermostat nextchange
                fritzdect.0	2021-01-04 14:57:42.684	info	(26143) setting up thermostat
                fritzdect.0	2021-01-04 14:57:42.682	info	(26143) setting up temperatur
                fritzdect.0	2021-01-04 14:57:42.672	info	(26143) setting up thermostat nextchange
                fritzdect.0	2021-01-04 14:57:42.653	info	(26143) setting up thermostat
                fritzdect.0	2021-01-04 14:57:42.652	info	(26143) setting up temperatur
                fritzdect.0	2021-01-04 14:57:42.644	info	(26143) setting up thermostat nextchange
                fritzdect.0	2021-01-04 14:57:42.625	info	(26143) setting up thermostat
                fritzdect.0	2021-01-04 14:57:42.623	info	(26143) setting up temperatur
                fritzdect.0	2021-01-04 14:57:42.616	info	(26143) setting up thermostat nextchange
                fritzdect.0	2021-01-04 14:57:42.603	info	(26143) setting up thermostat
                fritzdect.0	2021-01-04 14:57:42.601	info	(26143) setting up temperatur
                fritzdect.0	2021-01-04 14:57:42.593	info	(26143) setting up thermostat nextchange
                fritzdect.0	2021-01-04 14:57:42.572	info	(26143) setting up thermostat
                fritzdect.0	2021-01-04 14:57:42.570	info	(26143) setting up temperatur
                fritzdect.0	2021-01-04 14:57:42.560	info	(26143) setting up thermostat nextchange
                fritzdect.0	2021-01-04 14:57:42.539	info	(26143) setting up thermostat
                fritzdect.0	2021-01-04 14:57:42.537	info	(26143) setting up temperatur
                fritzdect.0	2021-01-04 14:57:42.512	info	(26143) CREATE Devices 7
                fritzdect.0	2021-01-04 14:57:42.204	info	(26143) fritzdect entered ready
                fritzdect.0	2021-01-04 14:57:42.177	info	(26143) starting. Version 2.1.2 in /opt/iobroker/node_modules/iobroker.fritzdect, node: v12.20.0, js-controller: 3.1.6
                host.ioBroker	2021-01-04 14:57:40.786	info	instance system.adapter.fritzdect.0 started with pid 26143
                • E ente34
                  Kann das sein?
                  foxthefox
                  @ente34
                  das sollte nicht passieren.
                  Ich bräuchte dann mal den output von "Meine Geräte"
                  Logs ggf. später
                  Ein Aufruf: video
                  E 1 Antwort Letzte Antwort
                  • F foxthefox
                    @ente34
                    Logs ggf. später
                    ente34
                    @foxthefox sagte in Test Adapter Adapter-fritzdect v2.1.x GitHub:
                    "Meine Geräte"
                    Sorry, was meinst Du mit "Meine Geräte"?
                    • E ente34
                      "Meine Geräte"
                      foxthefox
                      @ente34
                      in den Einstellungen zum Adapter gibt es eine Taste:
                      Ein Aufruf: video
                      • F foxthefox
                        @ente34
                        ente34
                        @foxthefox Meine Geräte.txt
                        Hier
                        • E ente34
                          Hier
                          foxthefox
                          @ente34
                          OK
                          wenn present=0 für ein Gerät gemeldet wird, dann wird das update Übersprungen.
                          Hatte hier allerdings alles abgebrochen und nicht nur das Gerät.
                          Sollte mit der 2.1.3 von GitHub nun gehen.
                          Ein Aufruf: video
                          • ChaotC Chaot
                            foxthefox
                            @Chaot sagte in Test Adapter Adapter-fritzdect v2.1.x GitHub:
                            das hängt höchstwahrscheinlich mit den weiterhin vorhandenen Objektbaum zusammen.
                            nur die Instanz löschen und neu erstellen sollte es bereinigen.
                            Ein Aufruf: video
                            • F foxthefox
                              @ente34
                              OK
                              ente34
                              @foxthefox
                              Das ging ja schnell, sieht jetzt besser aus!
                              Hier noch eine Bitte um Erweiterung, kann man einen Datenpunkt "DeviceInUse" oder ähnlich einbauen?
                              Bislang bringt das nicht erreichbare Device alle 5 Minuten eine Warning ins logfile (Habe dann den Adapter Loglevel auf "error" gesetzt)
                              • E ente34
                                @foxthefox
                                foxthefox
                                schrieb am zuletzt editiert von foxthefox
                                @ente34
                                eigentlich sollte es keine Warnung mehr geben.
                                Früher war es eine Warnung für present=0, habe es jetzt aber auf Debug umgestellt.
                                Wenn also der Loglevel wieder auf info steht, müsstest du nicht sehen. Außer die info,warn,errors.
                                Kannst du aus dem Log mal die Meldung posten?
                                Ein Aufruf: video
                                • F foxthefox
                                  @ente34
                                  ente34
                                  @foxthefox
                                  Ich nehme alles zurück und behaupte das Gegenteil.
                                  Versehentlich in der Produktiv-Instanz mit dem alten Adapter geschaut.
                                  Off Topic: Das mit der vis Abhängigkeit (anderer Thread) hat mich auch gewundert, ich hatte auf dem Testsystem nämlich auch keine vis.
                                  Vielen Dank für den Support!
                                  • E ente34
                                    @foxthefox
                                    foxthefox
                                    @ente34
                                    das mit der VIS Abhängigkeit kam vom adapter-creator und man denkt sich manchmal nicht viel dabei.
                                    mit 2.1.4 sollte es heraus sein (kein Abhängigkeit mehr)
                                    Ein Aufruf: video
                                    E 2 Antworten Letzte Antwort
                                    • F foxthefox
                                      @ente34
                                      ente34
                                      @foxthefox
                                      In der Zwischenzeit habe ich zwei log errors bekommen:
                                      fritzdect.0	2021-01-04 17:01:11.819	error	(10360) no response part in returned message
                                      fritzdect.0	2021-01-04 17:01:11.819	error	(10360) fritzbox returned this {"msg":"get error in http request","function":"get_login_state","error":{"errno":"ENETUNREACH","code":"ENETUNREACH","syscall":"connect","address":"192.168.168.1","port"
                                      backitup.0	2021-01-04 17:01:11.787	debug	(19236) system.adapter.admin.0: logging false
                                      backitup.0	2021-01-04 16:50:23.835	debug	(19236) system.adapter.admin.0: logging true
                                      host.NB03490	2021-01-04 16:50:11.145	info	Update repository "Beta (latest)" under "http://download.iobroker.net/sources-dist-latest.json"
                                      backitup.0	2021-01-04 16:44:16.788	debug	(19236) system.adapter.admin.0: logging false
                                      info.0	2021-01-04 16:44:16.582	error	(4952) Error: getaddrinfo ENOTFOUND raw.githubusercontent.com
                                      fritzdect.0	2021-01-04 16:44:14.793	error	(10360) no response part in returned message
                                      fritzdect.0	2021-01-04 16:44:14.792	error	(10360) fritzbox returned this {"msg":"get error in http request","function":"get_login_state","error":{"errno":"ENETUNREACH","code":"ENETUNREACH","syscall":"connect","address":"192.168.168.1","port"
                                      • F foxthefox
                                        ChaotC Offline
                                        ChaotC Offline
                                        Chaot
                                        @foxthefox Danke.
                                        Objektbaum löschen hat gereicht.
                                        • F foxthefox
                                          Aktuelle Test Version 2.1.7
                                          Veröffentlichungsdatum 03.01.2021
                                          Github Link https://github.com/foxthefox/ioBroker.fritzdect
                                          Changes
                                          Habe den Adapter komplett überarbeitet:
                                          • auf klassenbasierte Struktur umgestellt
                                          • die Routinen komplett überarbeitet (hälfte des Codes)
                                          • eine neue API für die Fritzbox erstellt, damit ab 7.25 auch mit dem neuen Verschlüsselungsverfahren ein login möglich ist
                                          • DECT500 und ihre Gruppen sind enthalten
                                          • Rolladensteuerung ist drin
                                          • DECT440 hat nun untergeordnete Buttons
                                          • wenn es neue Datenpunkte seitens der fritzbox gibt, wird eine Warnung ausgegeben
                                          BREAKING Change!
                                          Durch die Überarbeitung sind nun alle Objekte mit DECT_ ohne irgendwelche Zusätze mit 200 o.ä.
                                          Am Anfang gab es nur die Steckdose und Thermostat und nun ist es überholt.
                                          des Weiteren sind die Datenpunkte nun mit den Namen aus der Fritzbox-API gleich. Das vereinfacht das Einlesen und Update ungemein.
                                          Ich hoffe es funktioniert soweit alles noch (ich habe nur DECT200 und DECT300 und da scheint es OK).
                                          Klaus
                                          PS. mit der Ampel muß ich noch schauen, ob ich das so richtig interpretiert habe.
                                          stefande
                                          @foxthefox
                                          Bei mir wird eine neue Objektstruktur angelegt unter:
                                          fritzdect.0.08761046xxx
                                          vorher:
                                          fritzdect.0.DECT200_08761046xxx
