  4. IoBroker.phantomjs
IoBroker.phantomjs
148 Beiträge 32 Kommentatoren 35.1k Aufrufe 19 Beobachtet
  • David G.D David G.
    @Thomas-Braun
    War nicht installiert.
    Habe ich nachgeholt.
    Allerdings klappt es immer noch nicht.....
    $ ./iobroker url "https://github.com/ioBroker/ioBroker.phantomjs"
    install https://github.com/ioBroker/ioBroker.phantomjs/tarball/f05bc61c8e3cc86371492d2c6e89d44a2eed6aee
    NPM version: 6.14.6
    npm install https://github.com/ioBroker/ioBroker.phantomjs/tarball/f05bc61c8e3cc86371492d2c6e89d44a2eed6aee --loglevel error --prefix "/opt/iobroker" (System call)
    Unexpected platform or architecture: linux/armIt seems there is no binary available for your platform/architectureTry to install PhantomJS globally
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1
    npm
     ERR! phantomjs-prebuilt@2.1.16 install: `node install.js`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the phantomjs-prebuilt@2.1.16 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm
    ERR!     /home/iobroker/.npm/_logs/2020-08-17T04_05_56_483Z-debug.log
    ERROR: host.iobroker Cannot install https://github.com/ioBroker/ioBroker.phantomjs/tarball/f05bc61c8e3cc86371492d2c6e89d44a2eed6aee: 1
    #102
    @David-G
    cd /opt/iobroker
    npm cache clean --force
    lsb_release -a && whoami && which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      @David-G
      cd /opt/iobroker
      David G.D Online
      David G.D Online
      David G.
      #103
      @Thomas-Braun
      Danke, aber es will immer noch nicht.....
      Alle Befehle ausgeführt.
      Anbei die Ergebnisse.
      NPM version: 6.14.6
      npm
      npm
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-08-17T05_01_22_677Z-debug.log
      pi@iobroker:/opt/iobroker $ lsb_release -a && whoami && which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
      No LSB modules are available.
      Distributor ID:  Raspbian
      Description:  Raspbian GNU/Linux 10 (buster)
      Release:  10
      Codename:  buster
      pi
      /usr/bin/nodejs
      v10.22.0
      /usr/bin/node
      v10.22.0
      /usr/bin/npm
      6.14.6
      nodejs:
        Installiert:           10.22.0-1nodesource1
        Installationskandidat: 10.22.0-1nodesource1
        Versionstabelle:
       *** 10.22.0-1nodesource1 500
              500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
              100 /var/lib/dpkg/status
           10.21.0~dfsg-1~deb10u1+rpi1 500
              500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
      Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
        @Thomas-Braun
        NPM version: 6.14.6
        npm
        npm
        Release:  10
        Codename:  buster
        pi
        /usr/bin/nodejs
        v10.22.0
        /usr/bin/node
        v10.22.0
        /usr/bin/npm
        6.14.6
        nodejs:
          Versionstabelle:
        #104
        @David-G
        It is used prebuild package of phantomjs. If for your system the prebuild does not exist, you cannot use this adapter. On some linux systems the additional library "libfontconfig" is required. It can be installed as follow:
        Vielleicht mal noch libfontconfig nachinstallieren.
        sudo apt install libfontconfig
          @David-G
          David G.D Online
          David G.D Online
          David G.
          #105
          @Thomas-Braun
          pi@iobroker:~ $ sudo apt install libfontconfig
          Hinweis: »libfontconfig1« wird an Stelle von »libfontconfig« gewählt.
          libfontconfig1 ist schon die neueste Version (2.13.1-2).
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Hat nichts aktualisiert.
          Hat nur irgendwie ein libfontconfig1 angenommen.
            @Thomas-Braun
            #106
            @David-G
            Ja, das ist okay. Dann geht das bei dir nicht wegen des Hinweises aus git.
              @Thomas-Braun
              NPM version: 6.14.6
              npm
              npm
              Release:  10
              Codename:  buster
              pi
              /usr/bin/nodejs
              v10.22.0
              /usr/bin/node
              v10.22.0
              /usr/bin/npm
              6.14.6
              nodejs:
                Versionstabelle:
              OliverIOO Offline
              OliverIOO Offline
              OliverIO
              #107
              @David-G
              Wenn phamtomjs für deine Platform nicht vorkompiliert existiert musst du es selber machen.
              Befolge dazu diese Anweisungen.
              https://phantomjs.org/build.html
              Evtl. Wird aus den daraus resultierenden Fehlermeldungen deutlich, wo das Problem wirklich liegt.
              Wenn das dann erfolgreich durchläuft, dann kannst du die obige Installation erneut durchführen.
              Meine Adapter und Widgets
              Links im Profil
              Miro S.M 1 Antwort Letzte Antwort
              • OliverIOO OliverIO
                @David-G
                Miro S.M Offline
                Miro S.M Offline
                Miro S.
                #108
                @OliverIO said in IoBroker.phantomjs:
                @David-G
                Ich habe die Installation nach deiner verlinkten Seite ausprobiert diese ist angeblich auch durchgelaufen aber ich finde keine Instanze im IObroker von phantom js. Habe es dann nochmal über den Adapter probiert und bekomme diese Fehlermeldung
                $ ./iobroker add phantomjs  --host raspberrypi
                NPM version: 6.14.6
                npm install iobroker.phantomjs@1.0.1 --loglevel error --prefix "/opt/iobroker" (System call)
                npm
                 ERR!
                npm
                npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-08-19T10_26_32_229Z-debug.log
                ERROR: host.raspberrypi Cannot install iobroker.phantomjs@1.0.1: 1
                Kann mir jemand helfen ich weiß nicht wie ich es installiert bekomme ?
                I 1 Antwort Letzte Antwort
                • Miro S.M Miro S.
                  @David-G
                  NPM version: 6.14.6
                  npm
                   ERR!
                  npm
                  I Offline
                  I Offline
                  I-Punkt
                  #109
                  @Miro-S Soweit ich mich erinnere, ist die Kombi "phantomjs&Raspberrypi" nicht ganz unproblematisch. Lt. dieser Seite (https://github.com/fg2it/phantomjs-on-raspberry) gibt es wohl keine offiziellen binaries dafür. Vielleicht helfen dir ja die fertigen binaries von dort weiter. Achte darauf, welchen Pi-Version (1a, 1b, 2 ...) du hast, die haben ggf. unterschiedliche ARM-Strukturen (ARMv6, ARMv7 usw.)
                  Ich selber bin mit der Kombination nie so recht glücklich geworden. Als es dann irgendwann mal lief, stellte sich heraus, das der Pi zu schwach war, die gewünschten Sites zu rendern.
                  • I I-Punkt
                    Miro S.M Offline
                    Miro S.M Offline
                    Miro S.
                    #110
                    @I-Punkt Okey, danke. Ich habe den 4B, dann ist da wohl keiner dabei. Gibt es eventuell eine alternative Graphen zu rendern und dann zu nutzen? Nutze gerade Flot und wollte dann mit Phantom den Graphen rendern.
                    I OliverIOO 2 Antworten Letzte Antwort
                    • Miro S.M Miro S.
                      I Offline
                      I Offline
                      I-Punkt
                      #111
                      @Miro-S Wäre vielleicht ein Versuch wert -> https://www.npmjs.com/package/html-to-image Könnte mir vorstellen, daß sich das als package in die Javascript-Engine in iobroker einbinden und dann von dort benutzen läßt.
                      Ansonsten mal die Suchmaschine deiner Wahl mit "html to image" füttern.
                      • I I-Punkt
                        David G.D Online
                        David G.D Online
                        David G.
                        #112
                        @I-Punkt
                        Für diese Variante hab ich mich vorgestern entschieden.
                        Klappt sehr gut.
                        Hab mich hier an dem Post orientiert.
                        Screenshot Flot-Charts über Telegram verschicken
                        • Miro S.M Miro S.
                          OliverIOO Offline
                          OliverIOO Offline
                          OliverIO
                          #113
                          @Miro-S
                          Wenn dein Build erfolgreich durchgelaufen ist, hast du doch dein binary für den 4b.
                          Du musst es nur noch an die richtige Stelle kopieren.
                          Da ich Phantomjs nicht verwende, kann ich dir die richtige Stelle leider nicht sagen. Evtl jemand, der das erfolgreich installiert hat.
                          Links im Profil
                            @Miro-S
                            dtp
                            schrieb am zuletzt editiert von dtp
                            #114
                            ich bekomme leider auch eine 127-Fehlermeldung.
                            phantomjs.0	2020-12-30 14:46:44.845	error	(586) {"killed":false,"code":127,"signal":null,"cmd":"/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs --ignore-ssl-errors=true /opt/iobroker/node_modules/iobroker.phantomjs/lib
                            Bei mir läuft der ioBroker im Docker-Container auf einer Synology DiskStation. Das Nachinstallieren von libfontconfig schlug leider fehl.
                            Jemand noch eine Idee?
                            • D dtp
                              dtp
                              #115
                              Man, man, man, was für ein Mist. Es hat in der Vergangenheit eigentlich immer funktioniert und nun will es nicht mehr. Gut, hatte den Adapter bestimmt ein Jahr nicht im Einsatz, aber so ganz ist mir nicht klar, was die Ursache sein könnte.
                              Hab den Adapter vollständig deinstalliert und neu installiert. -> Ohne Erfolg.
                              Hab den Docker-Container auf Version 5.1.0 aktualisiert. > Ohne Erfolg.
                              Hab den Docker-Container von host auf bridge umgestellt. -> Ohne Erfolg.
                              Hab "apt-get install libfontconfig" ausgeführt. -> Da ändert sich der Fehlercode immerhin von 127 auf 1.
                              Bin ratlos.
                              • D dtp
                                Bin ratlos.
                                dtp
                                #116
                                Wenn ich in meinem Docker-Container (node: v12.20.0, npm: 6.14.8) das Paket libfontconfig lade, dann erhalte ich ja den Fehlercode 1 statt 127. Doch diesen bekomme ich einfach nicht weg.
                                Bei der Adapter-Installation erhalte ich noch die folgende Fehlermeldung
                                ERROR: Cannot detect "sudo -n apt-get -v": sudo: Hostname ioBroker kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
                                Kann das der Grund für den Error Code 1 sein? Oder gibt es da ggf. andere Inkompatibilitäten?
                                Thomas BraunT GlasfaserG OliverIOO 3 Antworten Letzte Antwort
                                • D dtp
                                  #117
                                  @dtp Das dürfte daran liegen, dass in dem Container sudo nicht aktiv ist.
                                  • D dtp
                                    GlasfaserG Offline
                                    GlasfaserG Offline
                                    #118
                                    @dtp sagte in IoBroker.phantomjs:
                                    https://forum.iobroker.net/topic/37410/hostname-fehlt/1
                                      dtp
                                      #119
                                      Ich hatte den Container auch schon mal im Bridge-Modus laufen lassen. An dem Problem mit phantomjs hatte das aber leider nichts geändert. Bisher habe ich auch noch keine Nachteile entdecken können, wenn ich den Container im Host-Modus laufen lasse, außer eben, dass der sudo-Fehler bei jeder Adapter-Installation angezeigt wird.
                                      • D dtp
                                        dtp
                                        #120
                                        So, hab den Container jetzt noch mal im Bridge-Modus mit Port 8081 und PACKAGES libfontconfig gestartet. Der sudo-Fehler ist zwar erwartungsgemäß verschwunden, aber der Fehlercode 1 der phantomjs-Instanz ist leider geblieben.
                                        • D dtp
                                          OliverIOO Offline
                                          OliverIOO Offline
                                          OliverIO
                                          #121
                                          @dtp
                                          poste bitte mal das komplette log der installation. evtl untersuchst du hier folgefehler eines anderen problems
                                          ideal wäre, wenn du die installation von der shell aus startest (iob add phantomjs)
                                          hast du geprüft, ob die zugrunde liegende bibliothek phantomjs (also nicht der adapter sonder die verwendete bibliothek) erfolgreich installiert wurde und funktioniert? (in der shell im ordner von iobroker: npm install phantomjs-prebuilt)
                                          Links im Profil
