  4. IoBroker.phantomjs
IoBroker.phantomjs
148 Beiträge 32 Kommentatoren 35.1k Aufrufe 19 Beobachtet
  • apollon77A apollon77
    Das Issue gehört zum Admin Adapter ... https://github.com/ioBroker/ioBroker.admin/blob/master/src/lib/js/selectID.js#L2405
    #98
    @apollon77 sagte in IoBroker.phantomjs:
    Done
      Done
      David G.D Online
      David G.D Online
      David G.
      #99
      Wollte den Adapter auch mal testen.
      Bekomme ihn leider nicht installiert.
      Sieht einer den Fehler?
      Kommando-Ausführung: $ ./iobroker url "https://github.com/ioBroker/ioBroker.phantomjs" --debug
      Fertig mit Fehler: host.iobroker Cannot install https://github.com/ioBroker/ioBroker.phantomjs/tarball/f05bc61c8e3cc86371492d2c6e89d44a2eed6aee: 1
      NPM version: 6.14.6
      npm install https://github.com/ioBroker/ioBroker.phantomjs/tarball/f05bc61c8e3cc86371492d2c6e89d44a2eed6aee --loglevel error --prefix "/opt/iobroker" (System call)
      > node-bluetooth@1.2.6 install /opt/iobroker/node_modules/node-bluetooth> node-gyp configure build
      make: Verzeichnis „/opt/iobroker/node_modules/node-bluetooth/build“ wird betreten
        CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/BluetoothSerialPort.o
      In file included from ../src/DeviceINQ.h:17,                 from ../src/linux/BluetoothSerialPort.cc:13:../node_modules/nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../node_modules/nan/nan.h:2294:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
      In file included from ../src/linux/BluetoothSerialPort.cc:12:../src/linux/BluetoothSerialPort.cc: At global scope:/home/iobroker/.cache/node-gyp/10.22.0/include/node/node.h:573:43: warning: cast between incompatible function types from ‘void (*)(v8::Handle<v8::Object>)’ {aka ‘void (*)(v8::Local<v8::Object>)’} to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/10.22.0/include/node/node.h:607:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/linux/BluetoothSerialPort.cc:23:1: note: in expansion of macro ‘NODE_MODULE’ NODE_MODULE(BluetoothSerialPort, InitAll) ^~~~~~~~~~~
      In file included from /home/iobroker/.cache/node-gyp/10.22.0/include/node/node.h:63,                 from ../src/linux/BluetoothSerialPort.cc:12:/home/iobroker/.cache/node-gyp/10.22.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = node::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)]’:/home/iobroker/.cache/node-gyp/10.22.0/include/node/node_object_wrap.h:84:78:   required from here/home/iobroker/.cache/node-gyp/10.22.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<node::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<node::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]                reinterpret_cast<Callback>(callback), type);                ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
      /home/iobroker/.cache/node-gyp/10.22.0/include/node/v8.h: In instantiation of ‘void v8::PersistentBase<T>::SetWeak(P*, typename v8::WeakCallbackInfo<P>::Callback, v8::WeakCallbackType) [with P = Nan::ObjectWrap; T = v8::Object; typename v8::WeakCallbackInfo<P>::Callback = void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)]’:../node_modules/nan/nan_object_wrap.h:65:61:   required from here/home/iobroker/.cache/node-gyp/10.22.0/include/node/v8.h:9502:16: warning: cast between incompatible function types from ‘v8::WeakCallbackInfo<Nan::ObjectWrap>::Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<Nan::ObjectWrap>&)’} to ‘Callback’ {aka ‘void (*)(const v8::WeakCallbackInfo<void>&)’} [-Wcast-function-type]
        CXX(target) Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o
      ../src/linux/DeviceINQ.cc:35:14: fatal error: bluetooth/bluetooth.h: Datei oder Verzeichnis nicht gefunden     #include <bluetooth/bluetooth.h>              ^~~~~~~~~~~~~~~~~~~~~~~compilation terminated.
      make: *** [BluetoothSerialPort.target.mk:107: Release/obj.target/BluetoothSerialPort/src/linux/DeviceINQ.o] Fehler 1make: Verzeichnis „/opt/iobroker/node_modules/node-bluetooth/build“ wird verlassen
      gyp
       ERR!
      build error
      gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:191:23)gyp ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
      gyp ERR! System Linux 5.4.51-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "build"gyp ERR! cwd /opt/iobroker/node_modules/node-bluetoothgyp ERR! node -v v10.22.0gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
      > phantomjs-prebuilt@2.1.16 install /opt/iobroker/node_modules/phantomjs-prebuilt> node install.js
      PhantomJS not found on PATH
      Unexpected platform or architecture: linux/armIt seems there is no binary available for your platform/architectureTry to install PhantomJS globally
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm
      ERR! phantomjs-prebuilt@2.1.16 install: `node install.js`npm ERR! Exit status 1
      npm ERR! npm
      ERR! Failed at the phantomjs-prebuilt@2.1.16 install script.npm ERR!
       This is probably not a problem with npm. There is likely additional logging output above.
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-08-16T19_54_55_528Z-debug.log
      ERROR: host.iobroker Cannot install https://github.com/ioBroker/ioBroker.phantomjs/tarball/f05bc61c8e3cc86371492d2c6e89d44a2eed6aee: 1
      • David G.D David G.
        NPM version: 6.14.6
        gyp
         ERR!
        build error
        npm ERR! errno 1
        npm
        npm ERR! npm
        #100
        @David-G Hast du libbluetooh-dev installiert?
        apt policy libbluetooth-dev
          David G.D Online
          David G.D Online
          David G.
          #101
          @Thomas-Braun
          War nicht installiert.
          Habe ich nachgeholt.
          Allerdings klappt es immer noch nicht.....
          NPM version: 6.14.6
          npm
           ERR! code ELIFECYCLEnpm ERR! errno 1
          npm
           ERR! phantomjs-prebuilt@2.1.16 install: `node install.js`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the phantomjs-prebuilt@2.1.16 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
          ERR!     /home/iobroker/.npm/_logs/2020-08-17T04_05_56_483Z-debug.log
            @Thomas-Braun
            NPM version: 6.14.6
            npm
            npm
            #102
            @David-G
            cd /opt/iobroker
            npm cache clean --force
            lsb_release -a && whoami && which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              @David-G
              cd /opt/iobroker
              David G.D Online
              David G.D Online
              David G.
              #103
              @Thomas-Braun
              Danke, aber es will immer noch nicht.....
              Alle Befehle ausgeführt.
              Anbei die Ergebnisse.
              NPM version: 6.14.6
              npm
              npm
              npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-08-17T05_01_22_677Z-debug.log
              pi@iobroker:/opt/iobroker $ lsb_release -a && whoami && which nodejs && nodejs -v && which node && node -v && which npm && npm -v && apt policy nodejs
              No LSB modules are available.
              Distributor ID:  Raspbian
              Description:  Raspbian GNU/Linux 10 (buster)
              Release:  10
              Codename:  buster
              pi
              /usr/bin/nodejs
              v10.22.0
              /usr/bin/node
              v10.22.0
              /usr/bin/npm
              6.14.6
              nodejs:
                Installiert:           10.22.0-1nodesource1
                Installationskandidat: 10.22.0-1nodesource1
                Versionstabelle:
               *** 10.22.0-1nodesource1 500
                      500 https://deb.nodesource.com/node_10.x buster/main armhf Packages
                      100 /var/lib/dpkg/status
                   10.21.0~dfsg-1~deb10u1+rpi1 500
                      500 http://raspbian.raspberrypi.org/raspbian buster/main armhf Packages
              Thomas BraunT OliverIOO 2 Antworten Letzte Antwort
                @Thomas-Braun
                NPM version: 6.14.6
                npm
                npm
                Release:  10
                Codename:  buster
                pi
                /usr/bin/nodejs
                v10.22.0
                /usr/bin/node
                v10.22.0
                /usr/bin/npm
                6.14.6
                nodejs:
                  Versionstabelle:
                #104
                @David-G
                It is used prebuild package of phantomjs. If for your system the prebuild does not exist, you cannot use this adapter. On some linux systems the additional library "libfontconfig" is required. It can be installed as follow:
                Vielleicht mal noch libfontconfig nachinstallieren.
                sudo apt install libfontconfig
                  @David-G
                  David G.D Online
                  David G.D Online
                  David G.
                  #105
                  @Thomas-Braun
                  pi@iobroker:~ $ sudo apt install libfontconfig
                  Hinweis: »libfontconfig1« wird an Stelle von »libfontconfig« gewählt.
                  libfontconfig1 ist schon die neueste Version (2.13.1-2).
                  0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                  Hat nichts aktualisiert.
                  Hat nur irgendwie ein libfontconfig1 angenommen.
                    @Thomas-Braun
                    #106
                    @David-G
                    Ja, das ist okay. Dann geht das bei dir nicht wegen des Hinweises aus git.
                      @Thomas-Braun
                      NPM version: 6.14.6
                      npm
                      npm
                      Release:  10
                      Codename:  buster
                      pi
                      /usr/bin/nodejs
                      v10.22.0
                      /usr/bin/node
                      v10.22.0
                      /usr/bin/npm
                      6.14.6
                      nodejs:
                        Versionstabelle:
                      OliverIOO Offline
                      OliverIOO Offline
                      OliverIO
                      #107
                      @David-G
                      Wenn phamtomjs für deine Platform nicht vorkompiliert existiert musst du es selber machen.
                      Befolge dazu diese Anweisungen.
                      https://phantomjs.org/build.html
                      Evtl. Wird aus den daraus resultierenden Fehlermeldungen deutlich, wo das Problem wirklich liegt.
                      Wenn das dann erfolgreich durchläuft, dann kannst du die obige Installation erneut durchführen.
                      Meine Adapter und Widgets
                      Links im Profil
                      Miro S.M 1 Antwort Letzte Antwort
                      • OliverIOO OliverIO
                        @David-G
                        Miro S.M Offline
                        Miro S.M Offline
                        Miro S.
                        #108
                        @OliverIO said in IoBroker.phantomjs:
                        @David-G
                        Ich habe die Installation nach deiner verlinkten Seite ausprobiert diese ist angeblich auch durchgelaufen aber ich finde keine Instanze im IObroker von phantom js. Habe es dann nochmal über den Adapter probiert und bekomme diese Fehlermeldung
                        $ ./iobroker add phantomjs  --host raspberrypi
                        NPM version: 6.14.6
                        npm install iobroker.phantomjs@1.0.1 --loglevel error --prefix "/opt/iobroker" (System call)
                        npm
                         ERR!
                        npm
                        npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-08-19T10_26_32_229Z-debug.log
                        ERROR: host.raspberrypi Cannot install iobroker.phantomjs@1.0.1: 1
                        Kann mir jemand helfen ich weiß nicht wie ich es installiert bekomme ?
                        I 1 Antwort Letzte Antwort
                        • Miro S.M Miro S.
                          @David-G
                          NPM version: 6.14.6
                          npm
                           ERR!
                          npm
                          I Offline
                          I Offline
                          I-Punkt
                          #109
                          @Miro-S Soweit ich mich erinnere, ist die Kombi "phantomjs&Raspberrypi" nicht ganz unproblematisch. Lt. dieser Seite (https://github.com/fg2it/phantomjs-on-raspberry) gibt es wohl keine offiziellen binaries dafür. Vielleicht helfen dir ja die fertigen binaries von dort weiter. Achte darauf, welchen Pi-Version (1a, 1b, 2 ...) du hast, die haben ggf. unterschiedliche ARM-Strukturen (ARMv6, ARMv7 usw.)
                          Ich selber bin mit der Kombination nie so recht glücklich geworden. Als es dann irgendwann mal lief, stellte sich heraus, das der Pi zu schwach war, die gewünschten Sites zu rendern.
                          • I I-Punkt
                            Miro S.M Offline
                            Miro S.M Offline
                            Miro S.
                            #110
                            @I-Punkt Okey, danke. Ich habe den 4B, dann ist da wohl keiner dabei. Gibt es eventuell eine alternative Graphen zu rendern und dann zu nutzen? Nutze gerade Flot und wollte dann mit Phantom den Graphen rendern.
                            I OliverIOO 2 Antworten Letzte Antwort
                            • Miro S.M Miro S.
                              I Offline
                              I Offline
                              I-Punkt
                              #111
                              @Miro-S Wäre vielleicht ein Versuch wert -> https://www.npmjs.com/package/html-to-image Könnte mir vorstellen, daß sich das als package in die Javascript-Engine in iobroker einbinden und dann von dort benutzen läßt.
                              Ansonsten mal die Suchmaschine deiner Wahl mit "html to image" füttern.
                              • I I-Punkt
                                David G.D Online
                                David G.D Online
                                David G.
                                #112
                                @I-Punkt
                                Für diese Variante hab ich mich vorgestern entschieden.
                                Klappt sehr gut.
                                Hab mich hier an dem Post orientiert.
                                Screenshot Flot-Charts über Telegram verschicken
                                • Miro S.M Miro S.
                                  OliverIOO Offline
                                  OliverIOO Offline
                                  OliverIO
                                  #113
                                  @Miro-S
                                  Wenn dein Build erfolgreich durchgelaufen ist, hast du doch dein binary für den 4b.
                                  Du musst es nur noch an die richtige Stelle kopieren.
                                  Da ich Phantomjs nicht verwende, kann ich dir die richtige Stelle leider nicht sagen. Evtl jemand, der das erfolgreich installiert hat.
                                  Links im Profil
                                    @Miro-S
                                    dtp
                                    schrieb am zuletzt editiert von dtp
                                    #114
                                    ich bekomme leider auch eine 127-Fehlermeldung.
                                    phantomjs.0	2020-12-30 14:46:44.845	error	(586) {"killed":false,"code":127,"signal":null,"cmd":"/opt/iobroker/node_modules/phantomjs-prebuilt/lib/phantom/bin/phantomjs --ignore-ssl-errors=true /opt/iobroker/node_modules/iobroker.phantomjs/lib
                                    Bei mir läuft der ioBroker im Docker-Container auf einer Synology DiskStation. Das Nachinstallieren von libfontconfig schlug leider fehl.
                                    Jemand noch eine Idee?
                                    • D dtp
                                      dtp
                                      #115
                                      Man, man, man, was für ein Mist. Es hat in der Vergangenheit eigentlich immer funktioniert und nun will es nicht mehr. Gut, hatte den Adapter bestimmt ein Jahr nicht im Einsatz, aber so ganz ist mir nicht klar, was die Ursache sein könnte.
                                      Hab den Adapter vollständig deinstalliert und neu installiert. -> Ohne Erfolg.
                                      Hab den Docker-Container auf Version 5.1.0 aktualisiert. > Ohne Erfolg.
                                      Hab den Docker-Container von host auf bridge umgestellt. -> Ohne Erfolg.
                                      Hab "apt-get install libfontconfig" ausgeführt. -> Da ändert sich der Fehlercode immerhin von 127 auf 1.
                                      Bin ratlos.
                                      • D dtp
                                        Bin ratlos.
                                        dtp
                                        #116
                                        Wenn ich in meinem Docker-Container (node: v12.20.0, npm: 6.14.8) das Paket libfontconfig lade, dann erhalte ich ja den Fehlercode 1 statt 127. Doch diesen bekomme ich einfach nicht weg.
                                        Bei der Adapter-Installation erhalte ich noch die folgende Fehlermeldung
                                        ERROR: Cannot detect "sudo -n apt-get -v": sudo: Hostname ioBroker kann nicht aufgelöst werden: Der Name oder der Dienst ist nicht bekannt
                                        Kann das der Grund für den Error Code 1 sein? Oder gibt es da ggf. andere Inkompatibilitäten?
                                        Thomas BraunT GlasfaserG OliverIOO 3 Antworten Letzte Antwort
                                        • D dtp
                                          #117
                                          @dtp Das dürfte daran liegen, dass in dem Container sudo nicht aktiv ist.
