  4. [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen
adapateradapterneu hiertesttestentesterwled
655 Beiträge 73 Kommentatoren 302.6k Aufrufe 79 Beobachtet
  • W wohlstandskind2711
    Tagchen,
    kurze Frage, die Warnmeldungen, an was könnten die liegen?
      <variables>
        <variable type="timeout" id="timeout3">timeout3</variable>
        <variable type="timeout" id="timeout2">timeout2</variable>
      </variables>
      <block type="on_ext" id="zBkZB8ijuy}8jed3+y8+" x="-437" y="-37">
        <value name="OID0">
          <shadow type="field_oid" id="tO[d(C?x:r{3EYzS8*|I">
            <field name="oid">mihome.0.devices.sensor_motion_aq2_158d00036bbd98.state</field>
          </shadow>
        </value>
        <statement name="STATEMENT">
          <block type="controls_if" id="wwvZ)s15f{%;m:==HXFA">
            <value name="IF0">
              <block type="logic_operation" id="_4}YMQSQ6H[uz1|Lw(Xn">
                <field name="OP">AND</field>
                <value name="A">
                  <block type="on_source" id="Y?XmA,;V28H09y;1)gkh">
                  </block>
                </value>
                <value name="B">
                  <block type="time_compare_ex" id="^_fIR)Qlq}h{`-9DpUoo">
                    <mutation xmlns="http://www.w3.org/1999/xhtml" end_time="true" actual_time="true"></mutation>
                    <field name="USE_ACTUAL_TIME">TRUE</field>
                    <field name="OPTION">between</field>
                    <value name="START_TIME">
                      <shadow type="text" id="=FU+U_5kf-$n%{gJRbH)">
                        <field name="TEXT">19:45</field>
                      </shadow>
                    </value>
                    <value name="END_TIME">
                      <shadow type="text" id="(E+]CA2n]?H?6#Y1$|?-">
                        <field name="TEXT">08:00</field>
                      </shadow>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="timeouts_cleartimeout" id="YihiGR+F6WhCE^yaUqWi">
                <field name="NAME">timeout3</field>
                <next>
                  <block type="control" id="rfS#FPojQg-yU0e:;dIy">
                    <field name="OID">wled.0.cc50e3e8493b.seg.0.on</field>
                    <value name="VALUE">
                      <block type="logic_boolean" id="REEAcX?9l/:{F0_qO+K3">
                      </block>
                    </value>
                    <next>
                      <block type="control" id="Y?=TY%#k2W2yloXp65x*">
                        <field name="OID">wled.0.cc50e3e8493b.seg.0.fx</field>
                          <block type="math_number" id="ZYZyhnBx2@ASCThm#GnN">
                            <field name="NUM">3</field>
                          </block>
                        </value>
                        <next>
                          <block type="timeouts_settimeout" id="T,.y/6aghV;.@eWE;|b9">
                            <field name="NAME">timeout2</field>
                            <field name="DELAY">6000</field>
                            <field name="UNIT">ms</field>
                              <block type="control" id=";gTd,VswrRG6wc=b7+h%">
                                  <block type="math_number" id=")kZU}V46r.52;Nv~tQJ3">
                                    <field name="NUM">0</field>
                                  </block>
                                </value>
                              </block>
                            </statement>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </statement>
            <value name="IF1">
              <block type="on_source" id="YHY~m6oT%%`!hVZq-Lvd">
              </block>
            </value>
            <statement name="DO1">
              <block type="timeouts_settimeout" id="X)k@Ge?HDqIF`8.oO)My">
                <field name="DELAY">1</field>
                <field name="UNIT">min</field>
                  <block type="control" id="i~T7Y8=JV%VQG|Eu},?X">
                      <block type="logic_boolean" id="J2MMkOK@[5v48$:e[sab">
                      </block>
                    </value>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </statement>
      </block>
    </xml>![javascript - ioBroker.png](/assets/uploads/files/1591121367468-javascript-iobroker.png)
    2020-06-02 19:56:48.472 - warn: wled.0 (25234) State attribute definition missing for + lm
    2020-06-02 19:56:48.479 - warn: wled.0 (25234) State attribute definition missing for + lip
    2020-06-02 19:56:48.681 - warn: wled.0 (25234) State attribute definition missing for + lor
    2020-06-02 19:57:19.326 - warn: wled.0 (25234) State attribute definition missing for + lm
    2020-06-02 19:57:19.332 - warn: wled.0 (25234) State attribute definition missing for + lip
    2020-06-02 19:57:19.538 - warn: wled.0 (25234) State attribute definition missing for + lor
    2020-06-02 19:57:50.060 - warn: wled.0 (25234) State attribute definition missing for + lm
    2020-06-02 19:57:50.068 - warn: wled.0 (25234) State attribute definition missing for + lip
    2020-06-02 19:57:50.279 - warn: wled.0 (25234) State attribute definition missing for + lor
    TTBerlinT
    TTBerlinT
    TTBerlin
    #243
    @wohlstandskind2711 meines Erachtens gibt es dazu schon ein Issue auf github DutchmanNL ist wahrscheinlich noch nicht dazu gekommen, den Adapter zu bearbeiten.
    iobroker unter Debian Trixiea uf Dell Optiplex 9020 micro
    Node.js v22.19.0
    NPM 10.9.3
    js-controller 7.07
    JavaScript 8.9.2
    Admin 7.7.2
    • Basti97B
      Basti97B
      Basti97
      #244
      Weiß einer von euch ob man über Wled und mit dessen Adapter auch zusätzlich weiße LEDs steuern kann. Als Zusatz für die ws2812 LEDs.
      Iobroker läuft als VM auf Proxmoxserver x folgende Hersteller im Einsatz Sonoff, Gosund, Siemens x Aofo über Tasmota x Zigbee x das Smarthome wächst und wächst
      • Basti97B Basti97
        #245
        @Basti97 sollte gehen. Siehe gelb markiertes im Bild.
        Basti97B 1 Antwort Letzte Antwort
          Basti97B
          Basti97B
          Basti97
          #246
          @Beliar_666 Danke für deine Hilfe dann werde ich mich mal an das Projekt Wagen.😀
          • Basti97B
            Basti97B
            Basti97
            schrieb am zuletzt editiert von Basti97
            #247
            Kann man an Wled bzw in den Adapter ein zusätzlichen Kanal noch einfügen? Zum Beispiel für weiße LEds.
            • DutchmanD Dutchman
              Hi Leute,
              Da ich mit anderen Baustellen (SourceAnalytix) nicht voran kam brauchte ich mal ein Erfolgserlebnis, daraus ist WLED entstanden und Energie die anderen weiter zu machen :).
              WLED - Github Project by @Aircoookie
              Was ist WLED : Firmware die es ermöglicht LED-stripes (z.b. ws2812b) an zu steuern.
              Ich benutze diese z.b. als deco fur meine Bilder, als Treppenbeleuchtung oder auch Ambi-Light am Fernseher.
              Aktuelle Test Version 0.6.5
              Veröffentlichungsdatum 04-06-2022
              Github Link https://github.com/iobroker-community-adapters/ioBroker.wled
              Der adapter ermoeglicht es (fast) alles funktionalitaeten die in WLED integriert sind auch per iobroker. zu steuern.
              Dazu gehört :
              • Autodetect der devices
              • An/Aus
              • dimmen
              • Farben steuern in RGB (auch per segment unterschiedlich)
              • Effekte an/aus (auch per segment unterschiedlich)
              Ich würde mich über feedback freuen !
              Momentan muss er nog per GitHub link (oder npm i iobroker.wled) installiert werden, innerhalb der naesten Tagen auch per admin.
              Sollte die auto discovery nicht gehen, ich werden auch noch manuelles eintragen einbauen siehe dazu github
              (issue bitte auch auf GitHub hinterlegen)
              S
              S
              stefande
              #248
              @Dutchman
              Mit der WLED Version 0.10.0 wurde die Api geändert und der Adapter läuft nicht mehr.
              Dieses Issue wurde schon mehrfach auf Github gemeldet.
              Könntest du dich bitte der Sache mal annehmen?
              Danke im Voraus
              • Basti97B
                Basti97B
                Basti97
                #249
                Wer hat schon eine schöne View bzw Widget für WLED gebastelt. Mir fehlen einfach die Vorstellungen. :)
                • SeRoS
                  SeRoS
                  SeRo
                  #250
                  Habe mir spontan ein Lampe gebaut über die ich dann verschiedene Datenpunkte visuell darstelle wie Waschmaschine fertig, Haustürklingeln etc.
                  Jetzt kam mir gestern die Idee, dass man den Countdown von Alexa ja auch visualisieren könnte. Dieser wird ja auch pro gerät mit dem Alexa Adapter in einem DP ausgegeben, welchen man prima weiter verweden kann.
                  Hatte mir gedacht:
                  Start = 100% der Segmente an bis
                  Endzeit = alle LEDS aus (oder auch 10 Sekunden von ende anfangen zu Blinken)
                  So könnte man auf einen kurzen Blick erkennen wie lange in etwa der Countdown noch läuft.
                  Hat dies schonmal jemand, am einfachsten für mich natürlich über Blockly, umgesetzt?
                  liv-in-skyL BluelinuxB 2 Antworten Letzte Antwort
                  • SeRoS SeRo
                    Hatte mir gedacht:
                    liv-in-skyL
                    liv-in-skyL
                    #251
                    @SeRo ist garnicht so einfach - das problem bei der sache ist, dass du über den alexa2 nur anfang und ende bekommst - aber es wird nicht gezählt - d.h du mußt dir einen eigenen timer starten
                    teoretisch könnte man das in dieses script einbinden:
                    https://forum.iobroker.net/topic/23694/vorage-blockly-alexa-timer-sichtbar-machen-vis
                    dort gibt es einen datenpunkt, der alle 10 sekunden upgedatet wird - jede sekunde abzubilden ist eher schwierig, da du extrem viele led bräuchtest - man müßte sich das je nach länge des timer und anzahl der leds wohl selbst brechnen, was eine led darstellt
                    ich habe aber auch mal so eine idee gehabt und noch dieses script - das problem ist die abweichung wieviel sekunden (float) ist eine led (integer) - dadurch kommt es zu verschiebungen bzw. die anzahl der leds ist nicht die anzahl sekunden
                    das script berechnet den start und kann in zwei zweige gehen - ist die timer sekunden zahl großer oder kleiner der anzahl der leds - ist sie größer werden zuerst alle leds hochgezählt, bis zu den letzten sekunden (abhängig von der anzahl der leds) und dann werden diese abgezählt (könnte man in verschiedenen farben machen) (es wird also zweimal durchlaufen)
                    ist die sekunden anzahl kleiner wie die led anzahl werden direkt die sekunden gezählt
                    das script legt keine datenpunkte an- du gibst einfach die led-anzahl im script ein, den alexa-device datenpunkt (mit dem du testest), auch in den triggern muss die richtige alexa ausgewält werden, startest einen alexa timer und beobachtest das log - dann wird schon klar, was passiert - es wird noch nix gesteuet, nur im log kann man anhand des counter ersehen, wieviele leds gerade leuchten
                    das script beruht auf eine anzeige, in der man jede led einzeln setzen kann
                     <variables>
                       <variable id="lp)|C~1YzlmV=!aECQ:3">block</variable>
                       <variable id="q/b-(8E.v4q/X!_sO2HN">myDatenpunkt</variable>
                       <variable id="T/D`R%0}ltZeQQ3H.@~S">anzahlLED</variable>
                       <variable id="v]Bot]Cr198W`W(G2Z=N">counterSchedule1</variable>
                       <variable id="1Z?b!Ylx^F7oUk-B$z!#">counterSchedule2</variable>
                       <variable type="cron" id="schedule1">schedule1</variable>
                       <variable type="cron" id="schedule7">schedule7</variable>
                       <variable id="R%lWvmO=hes-b]6hb^+X">zeitArr</variable>
                       <variable type="cron" id="schedule4">schedule4</variable>
                       <variable type="cron" id="schedule5">schedule5</variable>
                     </variables>
                     <block type="procedures_defcustomreturn" id="S,OvPC,f10e-tN:]Fo0L" x="163" y="12">
                       <mutation statements="false"></mutation>
                       <field name="NAME">diffSchedule1</field>
                       <field name="SCRIPT">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</field>
                     </block>
                     <block type="procedures_defcustomreturn" id="_v?oRi+9}$IYE.;Hg)*Z" x="162" y="62">
                       <field name="NAME">arrSchedule2</field>
                       <field name="SCRIPT">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</field>
                     </block>
                     <block type="debug" id="P,Hzr1BsC3)ATSWBkDSx" disabled="true" x="1063" y="37">
                       <value name="TEXT">
                         <shadow type="text">
                         </shadow>
                         <block type="procedures_callcustomreturn" id="g(;+M5yEA?``n,0,i@i/">
                           <mutation name="diffSchedule1"></mutation>
                         </block>
                       </value>
                     </block>
                     <block type="procedures_defcustomnoreturn" id="uCvXF}LQp8}tBw0Tc!$M" x="738" y="62">
                       <field name="NAME">etwas tun</field>
                       <field name="SCRIPT">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</field>
                     </block>
                     <block type="variables_set" id="c!FMw;}}xU9,c?AWlvd(" x="263" y="187">
                       <field name="VAR" id="lp)|C~1YzlmV=!aECQ:3">block</field>
                         <block type="logic_boolean" id="-7*Gv$GYnKv_HC+n`/QC">
                         </block>
                       </value>
                       <next>
                         <block type="comment" id="nTAP(pLOn!~|cK9vfL~r">
                           <field name="COMMENT">hier datewnpunkt definieren</field>
                           <next>
                             <block type="variables_set" id="_X:=pOP,ak]UvKaek^6o">
                               <field name="VAR" id="q/b-(8E.v4q/X!_sO2HN">myDatenpunkt</field>
                                 <block type="text" id="/|gSx~s{2y)3YS2C$82u">
                                   <field name="TEXT">alexa2.0.Echo-Devices.G0911B0592830RM7.Timer.nextTimerDate</field>
                                 </block>
                               </value>
                               <next>
                                 <block type="comment" id="R;nzR-}iesL$Y(tE[Ga3">
                                   <field name="COMMENT">hier ledanzahl setzen</field>
                                   <next>
                                     <block type="variables_set" id="+b59.,p/Lsjy/xeMdy}S">
                                       <field name="VAR" id="T/D`R%0}ltZeQQ3H.@~S">anzahlLED</field>
                                         <block type="math_number" id="Tm7ev+L(a`?PDr0,c##1">
                                           <field name="NUM">120</field>
                                         </block>
                                       </value>
                                       <next>
                                         <block type="on" id="ZumJx{B1zY1pD;`SiXvv">
                                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592830RM7.Timer.nextTimerDate</field>
                                             <block type="controls_if" id="%H+BsPTp*]%5@K9?~,w4">
                                               <value name="IF0">
                                                 <block type="logic_compare" id="z;qeffeoS^T03!jx-^r,">
                                                   <field name="OP">NEQ</field>
                                                   <value name="A">
                                                     <block type="get_value" id="drD?dVV:x-F8-ejY2%*B">
                                                     </block>
                                                   </value>
                                                   <value name="B">
                                                     <block type="math_number" id="zMwX^[;bRKZtO,p;v;%?">
                                                     </block>
                                                   </value>
                                                 </block>
                                               </value>
                                                 <block type="variables_set" id="|nB5a$LK0=W{{tTrnZy6">
                                                     <block type="logic_boolean" id="Rq74uTCN2)=k}a0cK+EY">
                                                     </block>
                                                   </value>
                                                   <next>
                                                     <block type="controls_if" id="6@;FhplFhH`iR%U@Zc]R">
                                                       <value name="IF0">
                                                         <block type="logic_compare" id="qY#hxqI#Z]|v,Z-1dmde">
                                                           <field name="OP">GT</field>
                                                           <value name="A">
                                                             <block type="procedures_callcustomreturn" id="$$-1*|Se!-+K{|nS#J4C">
                                                             </block>
                                                           </value>
                                                           <value name="B">
                                                             <block type="variables_get" id="eB[oKnntCukK;pfr(O0N">
                                                             </block>
                                                           </value>
                                                         </block>
                                                       </value>
                                                         <block type="variables_set" id="w@rt=ZY/Uibj]U7zgpJA">
                                                           <field name="VAR" id="v]Bot]Cr198W`W(G2Z=N">counterSchedule1</field>
                                                             <block type="math_number" id="SrHPw]GtDXSKrYSK#?sM">
                                                               <field name="NUM">2</field>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="schedule_create" id="#JR7/CzWJQ/_r-r`Jybw">
                                                               <field name="NAME">schedule1</field>
                                                               <value name="SCHEDULE">
        <shadow type="field_cron" id="X[u:/bTuqM].2HROkT8g">
        <field name="CRON">*/10 * * * * *</field>
        </shadow>
        <block type="text_join" id="7/=GAud{1ITJvDf%hwG5">
        <value name="ADD0">
        <block type="text" id="o[S|JSrR+B39iWgz]`xK">
        <field name="TEXT">*/</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="math_round" id="61Ag2/7wM7@_=@I]6sy~">
        <field name="OP">ROUNDDOWN</field>
        <value name="NUM">
        <shadow type="math_number">
        <field name="NUM">3.1</field>
        </shadow>
        <block type="math_arithmetic" id="%a3}zrtAdb.v3}eeUzcG">
        <field name="OP">DIVIDE</field>
        <value name="A">
        <field name="NUM">1</field>
        </shadow>
        <block type="procedures_callcustomreturn" id=".5~?hKlyWw.N1|7okp{Q">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="TbV3dk@Fk)wqaRpy3jm%">
        <field name="NUM">60</field>
        </shadow>
        <block type="variables_get" id="9eyI3Qgs0kuvP}Pd!}Ok">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="+1vg!8W7oCfhm27YlZ}X">
        <field name="TEXT"> * * * * *</field>
        </block>
        </value>
        </block>
                                                               </value>
        <block type="math_change" id="zCy!tnsQW:XLQq[Bc6kl">
        <value name="DELTA">
        <shadow type="math_number" id="BB;[DaaTj_}D+Y-VC3Lb">
        <field name="NUM">-1</field>
        </shadow>
        <block type="math_number" id="aoG8XR@ufe%p7.xZ_Wl_">
        </block>
        </value>
        <next>
        <block type="comment" id="16jbI~+a~%SxqDNn!^rm">
        <field name="COMMENT">Anzahl LEDs</field>
        <next>
        <block type="debug" id="](@mDTo7g6;Vt1~Tha]l">
        <value name="TEXT">
        <shadow type="text" id="-$B+k8x^%F}f$I.AXlq?">
        <field name="TEXT">abschnitt weniger</field>
        </shadow>
        <block type="text_join" id="tAsoWm%FGm^f{U@0TId#">
        <value name="ADD0">
        <block type="text" id="L__L9BYa{Z$FSZBb{a{$">
        <field name="TEXT">großer Counter: </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="eM5b}M,Ax/tw3#5JW0ai">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </statement>
                                                               <next>
        <block type="variables_set" id="02uw!8*.Qd#|.?J$_M$|">
        <field name="VAR" id="1Z?b!Ylx^F7oUk-B$z!#">counterSchedule2</field>
        <block type="math_number" id="dZ%Z4[eN4aoLDydJFbc9">
        </block>
        </value>
        <next>
        <block type="variables_set" id="%{l2:y}jRYLo:Y^_VoLB">
        <field name="VAR" id="R%lWvmO=hes-b]6hb^+X">zeitArr</field>
        <block type="procedures_callcustomreturn" id="G9/X+{=cR*kRT1s!WITC">
        <mutation name="arrSchedule2"></mutation>
        </block>
        </value>
        <next>
        <block type="schedule_create" id="df980j$Sn9=gBLwbwqld">
        <field name="NAME">schedule4</field>
        <shadow type="field_cron">
        <field name="CRON">* * * * *</field>
        </shadow>
        <block type="cron_builder" id="oeMP+*]~V+hpUgUgrkKt">
        <mutation xmlns="http://www.w3.org/1999/xhtml" seconds="true" as_line="false"></mutation>
        <field name="LINE">FALSE</field>
        <field name="WITH_SECONDS">TRUE</field>
        <value name="DOW">
        <shadow type="text" id="O=wfI^j#I_?v(s.gTW8o">
        <field name="TEXT">*</field>
        </shadow>
        </value>
        <value name="MONTHS">
        <shadow type="text" id="Vj;Q!LDQWbV=4=J4#;lH">
        </shadow>
        </value>
        <value name="DAYS">
        <shadow type="text" id="rgY(JFQEI2liA%scG5)Z">
        </shadow>
        </value>
        <value name="HOURS">
        </shadow>
        <block type="lists_getIndex" id="w1HkYO2cC0!lBs`tJGt|">
        <mutation statement="false" at="true"></mutation>
        <field name="MODE">GET</field>
        <field name="WHERE">FROM_START</field>
        <block type="variables_get" id="C#?J26]y/d.2oS189uze">
        </block>
        </value>
        <value name="AT">
        <block type="math_number" id="S.-cI0a;$SXlyqnB2~cs">
        </block>
        </value>
        </block>
        </value>
        <value name="MINUTES">
        </shadow>
        <block type="lists_getIndex" id="(|;cM2a7r:AiS7^6PMsB">
        <block type="variables_get" id="69;aGIl)3I^7[dDarZ.=">
        </block>
        </value>
        <value name="AT">
        <block type="math_number" id="K!(ame{z?GOfL2A.QLQ?">
        </block>
        </value>
        </block>
        </value>
        <value name="SECONDS">
        </shadow>
        <block type="lists_getIndex" id="+JCkH3e0T=Ey+o^WE:J%">
        <block type="variables_get" id="COX{EM6N0(eOS6xJ^BS*">
        </block>
        </value>
        <value name="AT">
        <block type="math_number" id="jo8PqDKPK1k8a_C,{T4v">
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
        <block type="schedule_clear" id="`t1f|FGU*w$}od8c{IXp">
        <next>
        <block type="schedule_create" id="7o9)m`;o3_2rWMBg7hJ:">
        <field name="NAME">schedule5</field>
        <shadow type="field_cron" id="[Vl/0aIV#WV~OIK)??os">
        <field name="CRON">* * * * * *</field>
        </shadow>
        </value>
        <block type="comment" id="u/9*[bl;O-*8~590(_B7">
        <next>
        <block type="math_change" id="9nTsaOMiyo,3vXM~T0O,">
        <shadow type="math_number" id="^1Q6bH46y{[j=5C,cp$(">
        </shadow>
        <block type="math_number" id="{u1;+6W83h`sa)m@elF-">
        </block>
        </value>
        <next>
        <block type="debug" id="uY?3*WmZ@413(Dv%J3qn">
        <value name="TEXT">
        <shadow type="text" id="G^+-Qp3wtQwFci/f%0l*">
        <field name="TEXT">sekunde weniger</field>
        </shadow>
        <block type="text_join" id="qj9}9,oLV{N*j+qy.sjg">
        <value name="ADD0">
        <block type="text" id="*FtW/jRMSKLkNqY=_bvx">
        <field name="TEXT">letzte Sekunden - kleiner Counter: </field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="Z[g6$81Ms#964kQ6w0MX">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </statement>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </next>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                       <statement name="ELSE">
                                                         <block type="variables_set" id="/2c*,GDY;~3ZOA:Ycl-z">
                                                             <block type="math_arithmetic" id="G{8i7ULPYu.bg7=^p)^o">
                                                               <value name="A">
        <shadow type="math_number" id="Tvr:cdHhpy_|I.2lA:O3">
        </shadow>
        <block type="math_arithmetic" id="b2`tp@)wskR@=IsKQQ1|">
        <value name="A">
        <shadow type="math_number" id="TZR^LFcUkZIe8vWQP.S*">
        </shadow>
        <block type="variables_get" id="Dno+c+39)$|g.@%e49Xg">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="4!62})smH9:]^j/_Ph,{">
        </shadow>
        <block type="procedures_callcustomreturn" id="Q:S|j@WrMAC!LKh1c[O@">
        </block>
        </value>
        </block>
                                                               </value>
                                                               <value name="B">
        <shadow type="math_number" id=")e{`0_8g*;17@e{M~k1Z">
        </shadow>
        <block type="math_number" id="?.F;kL/TIoAP4t3DN#(F">
        </block>
                                                               </value>
                                                             </block>
                                                           </value>
                                                           <next>
                                                             <block type="schedule_create" id="Hvc~-I;3#!H{8m1fj$ci">
                                                               <field name="NAME">schedule7</field>
        <shadow type="field_cron" id="0_o@cQC_nbiT@Q2vNA.R">
        </shadow>
                                                               </value>
        <block type="comment" id="VJpc:OY:y{-v#pq=}@]7">
        <next>
        <block type="math_change" id="2$Uj-_m{p0/8)$9J)w#U">
        </shadow>
        <block type="math_number" id="IeeF#PwSo5w0s`%KhW+^">
        </block>
        </value>
        <next>
        <block type="debug" id="P2$0feTPAys$oU~=SzVw">
        <value name="TEXT">
        <shadow type="text" id="`7!x{bIgZwsThzY[^)wY">
        </shadow>
        <block type="text_join" id="*h)|ild},]Zct/hfXp6r">
        <value name="ADD0">
        <block type="text" id="L81fDhTU0yU[g1BnFFB_">
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="$yQ3EByd7THDTh3fETX/">
        </block>
        </value>
        </block>
        </value>
        </block>
        </next>
        </block>
        </next>
        </block>
                                                               </statement>
                                                             </block>
                                                           </next>
                                                         </block>
                                                       </statement>
                                                     </block>
                                                   </next>
                                                 </block>
                                               </statement>
                                             </block>
                                           </statement>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </next>
                         </block>
                       </next>
                     </block>
                     <block type="on" id="=Bi:+3#h1,j$8-itMBHj" x="1287" y="238">
                         <block type="controls_if" id="fDQwOUK:KeTF,EE1s]5]">
                           <value name="IF0">
                             <block type="logic_compare" id="|V3gJ=g9tnpk%NA9Q@rN">
                               <field name="OP">EQ</field>
                               <value name="A">
                                 <block type="get_value" id="x9~C2VD{G:{im==9p(40">
                                 </block>
                               </value>
                               <value name="B">
                                 <block type="math_number" id="oDj2RFe.t;~8H9u%m9RL">
                                 </block>
                               </value>
                             </block>
                           </value>
                             <block type="schedule_clear" id="nIslQ_MMZ(_C^_hv%Zmx">
                               <next>
                                 <block type="schedule_clear" id="!OLS2z:hOf0$bE(-=LZ0">
                                   <next>
                                     <block type="schedule_clear" id="ppblrW0tGz3((ZcR`*O_">
                                       <next>
                                         <block type="schedule_clear" id="Q:C}w}=bR@o1T~rrvCur">
                                           <next>
                                             <block type="variables_set" id="`[bI~:4IumS=q]6@mcj0">
                                                 <block type="logic_boolean" id="QESI}[!$mo]K@Czt]Q-0">
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="debug" id="THy+F5Fz*4!b}cT+4PnJ">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="~:n7RX?*p{N-%`@mT6w0">
                                                       <field name="TEXT">BIN RAUS</field>
                                                     </shadow>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </statement>
                       <next>
                         <block type="on" id="Qlmv@A{i[WO}B!I$7{vc">
                           <field name="OID">alexa2.0.Echo-Devices.G0911B0592830RM7.Timer.triggered</field>
                           <field name="CONDITION">true</field>
                             <block type="schedule_clear" id="{MaL?UwL8*RBrL?,uQ|r">
                               <next>
                                 <block type="schedule_clear" id="t}b~h/4HG`0p!.Gougs~">
                                   <next>
                                     <block type="schedule_clear" id="USQP{{dkZ`*3j*}F+ZB4">
                                       <next>
                                         <block type="schedule_clear" id="+tww+Y?{uD2fnt@Gb%I)">
                                           <next>
                                             <block type="variables_set" id="rFmMl*(d8,?1l/*i|v0T">
                                                 <block type="logic_boolean" id="M{o7tbW#/s|a;rz4dQbE">
                                                 </block>
                                               </value>
                                               <next>
                                                 <block type="debug" id="`5o;yQ}8%ja*Ng~UB1L.">
                                                   <value name="TEXT">
                                                     <shadow type="text" id="tPNt^-PEPX8~UC6(1Kxx">
                                                     </shadow>
                                                   </value>
                                                 </block>
                                               </next>
                                             </block>
                                           </next>
                                         </block>
                                       </next>
                                     </block>
                                   </next>
                                 </block>
                               </next>
                             </block>
                           </statement>
                         </block>
                       </next>
                     </block>
                    </xml>
                    • SeRoS SeRo
                      Hatte mir gedacht:
                      BluelinuxB
                      BluelinuxB
                      Bluelinux
                      #252
                      @SeRo Halli Hallo... coole idee... magst du mal deine Skripte dafür zur verfügung stellen????
                      • S
                        S
                        smarthome2020
                        #253
                        Hi
                        Ich hab aktuell einen Wemos D1 mini mit McLightning in Betrieb.
                        WS2812b mit externem Netzteil (5V,10A). Datapin ist an GPIO 4 angeschlossen und der Wemos wird ebenfalls über das Netzteil versorgt.
                        Ich lese überall etwas von den Widerständen zwischen GPIO und der Dataleitung des WS2812b. Braucht man den? Ich hab aktuell keinen dazwischen und über McLightning läuft es alles. Wollte nun auf WLED umsteigen.
                        Kann mir kurz einer was dazu erklären? Hab schon ne halbe Stunde gesucht :D Wüsste auch nicht wie groß der Widerstand sein muss. Im Netz scheinen Leute unterschiedliche zu verwenden.
                        Vielen Dank für die Hilfe.
                        S Basti97B capitaenzC 3 Antworten Letzte Antwort
                        • S smarthome2020
                          Hi
                          S
                          S
                          stefande
                          #254
                          @smarthome2020
                          Ein Widerstand mit 330 oder 470 Ohm soll die 1. LED wohl vor Spannungsspitzen auf der Data Leitung schützen.
                          Ich hab bisher aber mehrere Projekte auch ohne Widerstand realisiert, ohne dass was passiert ist.
                          • S smarthome2020
                            Hi
                            Basti97B
                            Basti97B
                            Basti97
                            #255
                            @smarthome2020 Ich nutze auch kein Widerstand. Bei dem Datenpin
                            • S smarthome2020
                              Hi
                              capitaenzC
                              capitaenzC
                              capitaenz
                              #256
                              @smarthome2020
                              Mit einem Widerstand von 330 Ohm reagiert der Streifen bei mit nicht mehr und ohne unzuverlässig.
                              Ich setze einen Wemos D1 Mini mit 165 LED auf gut 5 Metern ein.
                              Der Wemos hat ein Signalpegel von 3,3V und der Streifen benötigt ein 5V Signalpegel, aber mindestens 3,5V.
                              Ich habe diesen Hack eingesetzt:
                              Hack
                              Leif
                              ioBroker auf Synology DS920+ (SSD Raid / 20GB RAM) im VMM
                              • capitaenzC capitaenz
                                @smarthome2020
                                Hack
                                Leif
                                DutchmanD
                                DutchmanD
                                Dutchman
                                #257
                                DutchmanD 2 Antworten Letzte Antwort
                                  DutchmanD
                                  DutchmanD
                                  Dutchman
                                  #258
                                  Dieser Beitrag wurde gelöscht!
                                    DutchmanD
                                    DutchmanD
                                    Dutchman
                                    #259
                                    • Palm_ManiacP
                                      Palm_ManiacP
                                      Palm_Maniac
                                      #260
                                      ich habe seit kurzem meinen ersten LED-Stripe (370LEDs) in Betrieb, angesteuert mit einer NodeMCU und WLED-Firmware. Um alles in iobroker zu bekommen, habe ich natürlich auch den Adapter hier installiert. Es wurde alles auf Anhieb gefunden und eine Menge Datenpunkte angelegt.
                                      Eine Sache ist mir aufgefallen. Wenn ich den Stripe über das Web-Interface oder Alexa ein- oder ausschalte, aktualisiert sich der entsprechende Datenpunkt nicht, er bleibt immer auf den letzten Wert, den ich manuell gesetzt habe. WLED reagiert aber auf alle Änderungen, also True oder False. Läuft da bei mir was schief, oder ist da noch ein Wurm drin?
                                      X 1 Antwort Letzte Antwort
                                      • Palm_ManiacP Palm_Maniac
                                        X
                                        X
                                        xorks
                                        #261
                                        @Palm_Maniac
                                        Hey, wollte gerade einen Thread aufmachen wegen genau diesem Problem.
                                        Nutze auch den Wled adapter und habe ein Blockly Script gebastelt, damit mir Anrufe Visuell angezeigt werden. Leider wird der Switch ON/OFF datenpunkt nur auf "true" gesetzt wenn wled eingeschaltet wird, leider aber nicht auf "false" sobald Wled ausgeschaltet wird... und somit funktioniert mein script nicht korrekt :(
                                        wenn ich z.b. die Farbe Lila eingeschaltet habe, und es ruft jemand an, dann springt die Farbe auf rot und es wird ein effekt dargestellt.
                                        sobald der anrufer auflegt, wird die uhrsprungsfarbe lila wieder aktiviert.. das klappt auch alles wunderbar.
                                        Wenn meine LEDs aber ausgeschaltet sind, und es ruft jemand an, schaltet sich das band nach dem anruf nicht mehr aus, weil der datenpunkt weiterhin auf true steht.
                                        sollte ich einen eigenen thread machen ?
                                        liebe grüße
                                        • X xorks
                                          @Palm_Maniac
                                          liebe grüße
                                          DutchmanD
                                          DutchmanD
                                          Dutchman
                                          #262
                                          @xorks sagte in [WLED] LED streifen (WS2812B,WS2811,SK6812,APA102) bedienen:
                                          Nope nicht nötig, ich muss die API analysieren ob es an WLED oder dem adapter liegt : https://github.com/iobroker-community-adapters/ioBroker.wled/issues/40
                                          84.2k
